path: root/kernel/cpuset.c
2008-06-06cpusets: fix bug when adding nonexistent cpu or memLai Jiangshan
Adding a nonexistent cpu to a cpuset will be omitted quietly. It should return -EINVAL. Example: (real_nr_cpus <= 4 < NR_CPUS or cpu#4 was just offline) # cat cpus 0-1 # /bin/echo 4 > cpus # /bin/echo $? 0 # cat cpus # The same occurs when add a nonexistent mem. This patch will fix this bug. And when *buf == "", the check is unneeded. Signed-off-by: Lai Jiangshan <laijs@cn.fujitsu.com> Acked-by: Paul Jackson <pj@sgi.com> Cc: David Rientjes <rientjes@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-08Fix cpuset sched_relax_domain_level control filePaul Menage
Due to a merge conflict, the sched_relax_domain_level control file was marked as being handled by cpuset_read/write_u64, but the code to handle it was actually in cpuset_common_file_read/write. Since the value being written/read is in fact a signed integer, it should be treated as such; this patch adds cpuset_read/write_s64 functions, and uses them to handle the sched_relax_domain_level file. With this patch, the sched_relax_domain_level can be read and written, and the correct contents seen/updated. Signed-off-by: Paul Menage <menage@google.com> Cc: Hidetoshi Seto <seto.hidetoshi@jp.fujitsu.com> Cc: Paul Jackson <pj@sgi.com> Cc: Ingo Molnar <mingo@elte.hu> Reviewed-by: Li Zefan <lizf@cn.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-29Cpuset hardwall flag: add a mem_hardwall flag to cpusetsPaul Menage
This flag provides the hardwalling properties of mem_exclusive, without enforcing the exclusivity. Either mem_hardwall or mem_exclusive is sufficient to prevent GFP_KERNEL allocations from passing outside the cpuset's assigned nodes. Signed-off-by: Paul Menage <menage@google.com> Acked-by: Paul Jackson <pj@sgi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-29Cpuset hardwall flag: switch cpusets to use the bulk cgroup_add_files() APIPaul Menage
Currently the cpusets mem_exclusive flag is overloaded to mean both "no-overlapping" and "no GFP_KERNEL allocations outside this cpuset". These patches add a new mem_hardwall flag with just the allocation restriction part of the mem_exclusive semantics, without breaking backwards-compatibility for those who continue to use just mem_exclusive. Additionally, the cgroup control file registration for cpusets is cleaned up to reduce boilerplate. This patch: This change tidies up the cpusets control file definitions, and reduces the amount of boilerplate required to add/change control files in the future. Signed-off-by: Paul Menage <menage@google.com> Reviewed-by: Li Zefan <lizf@cn.fujitsu.com> Acked-by: Paul Jackson <pj@sgi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-29kernel/cpuset.c: make 3 functions staticAdrian Bunk
Make the following needlessly global functions static: - cpuset_test_cpumask() - cpuset_change_cpumask() - cpuset_do_move_task() Signed-off-by: Adrian Bunk <bunk@kernel.org> Acked-by: Paul Jackson <pj@sgi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-29CGroup API files: update cpusets to use cgroup structured file APIPaul Menage
Many of the cpusets control files are simple integer values, which don't require the overhead of memory allocations for reads and writes. Move the handlers for these control files into cpuset_read_u64() and cpuset_write_u64(). [akpm@linux-foundation.org: ad dmissing `break'] Signed-off-by: Paul Menage <menage@google.com> Cc: "Li Zefan" <lizf@cn.fujitsu.com> Cc: Balbir Singh <balbir@in.ibm.com> Cc: Paul Jackson <pj@sgi.com> Cc: Pavel Emelyanov <xemul@openvz.org> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: "YAMAMOTO Takashi" <yamamoto@valinux.co.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-28kernel: fix integer as NULL pointer warningsHarvey Harrison
kernel/cpuset.c:1268:52: warning: Using plain integer as NULL pointer kernel/pid_namespace.c:95:24: warning: Using plain integer as NULL pointer Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Reviewed-by: Paul Jackson <pj@sgi.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-28mempolicy: rename mpol_copy to mpol_dupLee Schermerhorn
This patch renames mpol_copy() to mpol_dup() because, well, that's what it does. Like, e.g., strdup() for strings, mpol_dup() takes a pointer to an existing mempolicy, allocates a new one and copies the contents. In a later patch, I want to use the name mpol_copy() to copy the contents from one mempolicy to another like, e.g., strcpy() does for strings. Signed-off-by: Lee Schermerhorn <lee.schermerhorn@hp.com> Cc: Christoph Lameter <clameter@sgi.com> Cc: David Rientjes <rientjes@google.com> Cc: Mel Gorman <mel@csn.ul.ie> Cc: Andi Kleen <ak@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-28mm: filter based on a nodemask as well as a gfp_maskMel Gorman
The MPOL_BIND policy creates a zonelist that is used for allocations controlled by that mempolicy. As the per-node zonelist is already being filtered based on a zone id, this patch adds a version of __alloc_pages() that takes a nodemask for further filtering. This eliminates the need for MPOL_BIND to create a custom zonelist. A positive benefit of this is that allocations using MPOL_BIND now use the local node's distance-ordered zonelist instead of a custom node-id-ordered zonelist. I.e., pages will be allocated from the closest allowed node with available memory. [Lee.Schermerhorn@hp.com: Mempolicy: update stale documentation and comments] [Lee.Schermerhorn@hp.com: Mempolicy: make dequeue_huge_page_vma() obey MPOL_BIND nodemask] [Lee.Schermerhorn@hp.com: Mempolicy: make dequeue_huge_page_vma() obey MPOL_BIND nodemask rework] Signed-off-by: Mel Gorman <mel@csn.ul.ie> Acked-by: Christoph Lameter <clameter@sgi.com> Signed-off-by: Lee Schermerhorn <lee.schermerhorn@hp.com> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Mel Gorman <mel@csn.ul.ie> Cc: Hugh Dickins <hugh@veritas.com> Cc: Nick Piggin <nickpiggin@yahoo.com.au> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-28mm: have zonelist contains structs with both a zone pointer and zone_idxMel Gorman
Filtering zonelists requires very frequent use of zone_idx(). This is costly as it involves a lookup of another structure and a substraction operation. As the zone_idx is often required, it should be quickly accessible. The node idx could also be stored here if it was found that accessing zone->node is significant which may be the case on workloads where nodemasks are heavily used. This patch introduces a struct zoneref to store a zone pointer and a zone index. The zonelist then consists of an array of these struct zonerefs which are looked up as necessary. Helpers are given for accessing the zone index as well as the node index. [kamezawa.hiroyu@jp.fujitsu.com: Suggested struct zoneref instead of embedding information in pointers] [hugh@veritas.com: mm-have-zonelist: fix memcg ooms] [hugh@veritas.com: just return do_try_to_free_pages] [hugh@veritas.com: do_try_to_free_pages gfp_mask redundant] Signed-off-by: Mel Gorman <mel@csn.ul.ie> Acked-by: Christoph Lameter <clameter@sgi.com> Acked-by: David Rientjes <rientjes@google.com> Signed-off-by: Lee Schermerhorn <lee.schermerhorn@hp.com> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Mel Gorman <mel@csn.ul.ie> Cc: Christoph Lameter <clameter@sgi.com> Cc: Nick Piggin <nickpiggin@yahoo.com.au> Signed-off-by: Hugh Dickins <hugh@veritas.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-19sched, cpuset: customize sched domains, coreHidetoshi Seto
[rebased for sched-devel/latest] - Add a new cpuset file, having levels: sched_relax_domain_level - Modify partition_sched_domains() and build_sched_domains() to take attributes parameter passed from cpuset. - Fill newidle_idx for node domains which currently unused but might be required if sched_relax_domain_level become higher. - We can change the default level by boot option 'relax_domain_level='. Signed-off-by: Hidetoshi Seto <seto.hidetoshi@jp.fujitsu.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-04-19cpumask: use new cpus_scnprintf functionMike Travis
* Cleaned up references to cpumask_scnprintf() and added new cpulist_scnprintf() interfaces where appropriate. * Fix some small bugs (or code efficiency improvments) for various uses of cpumask_scnprintf. * Clean up some checkpatch errors. Signed-off-by: Mike Travis <travis@sgi.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-04-19cpuset: modify cpuset_set_cpus_allowed to use cpumask pointerMike Travis
* Modify cpuset_cpus_allowed to return the currently allowed cpuset via a pointer argument instead of as the function return value. * Use new set_cpus_allowed_ptr function. * Cleanup CPU_MASK_ALL and NODE_MASK_ALL uses. Depends on: [sched-devel]: sched: add new set_cpus_allowed_ptr function Signed-off-by: Mike Travis <travis@sgi.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-03-05cpusets: fix obsolete commentDavid Rientjes
mm migration is no longer done in cpuset_update_task_memory_state() so it can no longer take current->mm->mmap_sem, so fix the obsolete comment. [ This changed in commit 04c19fa6f16047abff2288ddbc1f0798ede5a849 ("cpuset: migrate all tasks in cpuset at once") when the mm migration was moved from cpuset_update_task_memory_state() to update_nodemask() ] Signed-off-by: David Rientjes <rientjes@google.com> Cc: Paul Jackson <pj@sgi.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-08proc: seqfile convert proc_pid_status to properly handle pid namespacesEric W. Biederman
Currently we possibly lookup the pid in the wrong pid namespace. So seq_file convert proc_pid_status which ensures the proper pid namespaces is passed in. [akpm@linux-foundation.org: coding-style fixes] [akpm@linux-foundation.org: build fix] [akpm@linux-foundation.org: another build fix] [akpm@linux-foundation.org: s390 build fix] [akpm@linux-foundation.org: fix task_name() output] [akpm@linux-foundation.org: fix nommu build] Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Cc: Andrew Morgan <morgan@kernel.org> Cc: Serge Hallyn <serue@us.ibm.com> Cc: Cedric Le Goater <clg@fr.ibm.com> Cc: Pavel Emelyanov <xemul@openvz.org> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Paul Menage <menage@google.com> Cc: Paul Jackson <pj@sgi.com> Cc: David Rientjes <rientjes@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-07hotplug cpu move tasks in empty cpusets - refinementsPaul Jackson
- Narrow the scope of callback_mutex in scan_for_empty_cpusets(). - Avoid rewriting the cpus, mems of cpusets except when it is likely that we'll be changing them. - Have remove_tasks_in_empty_cpuset() also check for empty mems. Signed-off-by: Paul Jackson <pj@sgi.com> Acked-by: Cliff Wickman <cpw@sgi.com> Cc: David Rientjes <rientjes@google.com> Cc: Paul Menage <menage@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-07hotplug cpu: move tasks in empty cpusets to parent various other fixesPaul Jackson
Various minor formatting and comment tweaks to Cliff Wickman's [PATCH_3_of_3]_cpusets__update_cpumask_revision.patch I had had "iff", meaning "if and only if" in a comment. However, except for ancient mathematicians, the abbreviation "iff" was a tad too cryptic. Cliff changed it to "if", presumably figuring that the "iff" was a typo. However, it was the "only if" half of the conjunction that was most interesting. Reword to emphasis the "only if" aspect. The locking comment for remove_tasks_in_empty_cpuset() was wrong; it said callback_mutex had to be held on entry. The opposite is true. Several mentions of attach_task() in comments needed to be changed to cgroup_attach_task(). A comment about notify_on_release was no longer relevant, as the line of code it had commented, namely: set_bit(CS_RELEASED_RESOURCE, &parent->flags); is no longer present in that place in the cpuset.c code. Similarly a comment about notify_on_release before the scan_for_empty_cpusets() routine was no longer relevant. Removed extra parentheses and unnecessary return statement. Renamed attach_task() to cpuset_attach() in various comments. Removed comment about not needing memory migration, as it seems the migration is done anyway, via the cpuset_attach() callback from cgroup_attach_task(). Signed-off-by: Paul Jackson <pj@sgi.com> Acked-by: Cliff Wickman <cpw@sgi.com> Cc: David Rientjes <rientjes@google.com> Cc: Paul Menage <menage@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-07cgroups: update comments in cpuset.cPaul Menage
Some of the comments in kernel/cpuset.c were stale following the transition to control groups; this patch updates them to more closely match reality. Signed-off-by: Paul Menage <menage@google.com> Acked-by: Paul Jackson <pj@sgi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-07cpusets: update_cpumask revisionCliff Wickman
Use the new function cgroup_scan_tasks() to step through all tasks in a cpuset. [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Cliff Wickman <cpw@sgi.com> Cc: Paul Menage <menage@google.com> Cc: Paul Jackson <pj@sgi.com> Cc: David Rientjes <rientjes@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-07hotplug cpu: move tasks in empty cpusets to parentCliff Wickman
This patch corrects a situation that occurs when one disables all the cpus in a cpuset. Currently, the disabled (cpu-less) cpuset inherits the cpus of its parent, which is incorrect because it may then overlap its cpu-exclusive sibling. Tasks of an empty cpuset should be moved to the cpuset which is the parent of their current cpuset. Or if the parent cpuset has no cpus, to its parent, etc. And the empty cpuset should be released (if it is flagged notify_on_release). Depends on the cgroup_scan_tasks() function (proposed by David Rientjes) to iterate through all tasks in the cpu-less cpuset. We are deliberately avoiding a walk of the tasklist. [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Cliff Wickman <cpw@sgi.com> Cc: Paul Menage <menage@google.com> Cc: Paul Jackson <pj@sgi.com> Cc: David Rientjes <rientjes@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-01-25cpu-hotplug: replace lock_cpu_hotplug() with get_online_cpus()Gautham R Shenoy
Replace all lock_cpu_hotplug/unlock_cpu_hotplug from the kernel and use get_online_cpus and put_online_cpus instead as it highlights the refcount semantics in these operations. The new API guarantees protection against the cpu-hotplug operation, but it doesn't guarantee serialized access to any of the local data structures. Hence the changes needs to be reviewed. In case of pseries_add_processor/pseries_remove_processor, use cpu_maps_update_begin()/cpu_maps_update_done() as we're modifying the cpu_present_map there. Signed-off-by: Gautham R Shenoy <ego@in.ibm.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2007-10-19hotplug cpu: migrate a task within its cpusetCliff Wickman
When a cpu is disabled, move_task_off_dead_cpu() is called for tasks that have been running on that cpu. Currently, such a task is migrated: 1) to any cpu on the same node as the disabled cpu, which is both online and among that task's cpus_allowed 2) to any cpu which is both online and among that task's cpus_allowed It is typical of a multithreaded application running on a large NUMA system to have its tasks confined to a cpuset so as to cluster them near the memory that they share. Furthermore, it is typical to explicitly place such a task on a specific cpu in that cpuset. And in that case the task's cpus_allowed includes only a single cpu. This patch would insert a preference to migrate such a task to some cpu within its cpuset (and set its cpus_allowed to its entire cpuset). With this patch, migrate the task to: 1) to any cpu on the same node as the disabled cpu, which is both online and among that task's cpus_allowed 2) to any online cpu within the task's cpuset 3) to any cpu which is both online and among that task's cpus_allowed In order to do this, move_task_off_dead_cpu() must make a call to cpuset_cpus_allowed_locked(), a new subset of cpuset_cpus_allowed(), that will not block. (name change - per Oleg's suggestion) Calls are made to cpuset_lock() and cpuset_unlock() in migration_call() to set the cpuset mutex during the whole migrate_live_tasks() and migrate_dead_tasks() procedure. [akpm@linux-foundation.org: build fix] [pj@sgi.com: Fix indentation and spacing] Signed-off-by: Cliff Wickman <cpw@sgi.com> Cc: Oleg Nesterov <oleg@tv-sign.ru> Cc: Christoph Lameter <clameter@sgi.com> Cc: Paul Jackson <pj@sgi.com> Cc: Ingo Molnar <mingo@elte.hu> Signed-off-by: Paul Jackson <pj@sgi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-19Fix cpusets update_cpumaskPaul Menage
Cause writes to cpuset "cpus" file to update cpus_allowed for member tasks: - collect batches of tasks under tasklist_lock and then call set_cpus_allowed() on them outside the lock (since this can sleep). - add a simple generic priority heap type to allow efficient collection of batches of tasks to be processed without duplicating or missing any tasks in subsequent batches. - make "cpus" file update a no-op if the mask hasn't changed - fix race between update_cpumask() and sched_setaffinity() by making sched_setaffinity() post-check that it's not running on any cpus outside cpuset_cpus_allowed(). [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Paul Menage <menage@google.com> Cc: Paul Jackson <pj@sgi.com> Cc: David Rientjes <rientjes@google.com> Cc: Nick Piggin <nickpiggin@yahoo.com.au> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Balbir Singh <balbir@in.ibm.com> Cc: Cedric Le Goater <clg@fr.ibm.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Serge Hallyn <serue@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-19cpusets: decrustify cpuset mask update codePaul Jackson
Decrustify the kernel/cpuset.c 'cpus' and 'mems' updating code. Other than subtle improvements in the consistency of identifying white space at the beginning and end of passed in masks, this doesn't make any visible difference in behaviour. But it's one or two hundred kernel text bytes smaller, and easier to understand. [akpm@linux-foundation.org: coding-style fix] Signed-off-by: Paul Jackson <pj@sgi.com> Reviewed-by: Paul Menage <menage@google.com> Cc: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-19cpuset sched_load_balance flagPaul Jackson
Add a new per-cpuset flag called 'sched_load_balance'. When enabled in a cpuset (the default value) it tells the kernel scheduler that the scheduler should provide the normal load balancing on the CPUs in that cpuset, sometimes moving tasks from one CPU to a second CPU if the second CPU is less loaded and if that task is allowed to run there. When disabled (write "0" to the file) then it tells the kernel scheduler that load balancing is not required for the CPUs in that cpuset. Now even if this flag is disabled for some cpuset, the kernel may still have to load balance some or all the CPUs in that cpuset, if some overlapping cpuset has its sched_load_balance flag enabled. If there are some CPUs that are not in any cpuset whose sched_load_balance flag is enabled, the kernel scheduler will not load balance tasks to those CPUs. Moreover the kernel will partition the 'sched domains' (non-overlapping sets of CPUs over which load balancing is attempted) into the finest granularity partition that it can find, while still keeping any two CPUs that are in the same shed_load_balance enabled cpuset in the same element of the partition. This serves two purposes: 1) It provides a mechanism for real time isolation of some CPUs, and 2) it can be used to improve performance on systems with many CPUs by supporting configurations in which load balancing is not done across all CPUs at once, but rather only done in several smaller disjoint sets of CPUs. This mechanism replaces the earlier overloading of the per-cpuset flag 'cpu_exclusive', which overloading was removed in an earlier patch: cpuset-remove-sched-domain-hooks-from-cpusets See further the Documentation and comments in the code itself. [akpm@linux-foundation.org: don't be weird] Signed-off-by: Paul Jackson <pj@sgi.com> Acked-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-19Task Control Groups: make cpusets a client of cgroupsPaul Menage
Remove the filesystem support logic from the cpusets system and makes cpusets a cgroup subsystem The "cpuset" filesystem becomes a dummy filesystem; attempts to mount it get passed through to the cgroup filesystem with the appropriate options to emulate the old cpuset filesystem behaviour. Signed-off-by: Paul Menage <menage@google.com> Cc: Serge E. Hallyn <serue@us.ibm.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Dave Hansen <haveblue@us.ibm.com> Cc: Balbir Singh <balbir@in.ibm.com> Cc: Paul Jackson <pj@sgi.com> Cc: Kirill Korotaev <dev@openvz.org> Cc: Herbert Poetzl <herbert@13thfloor.at> Cc: Srivatsa Vaddagiri <vatsa@in.ibm.com> Cc: Cedric Le Goater <clg@fr.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-19cpuset: zero malloc - revert the old cpuset fixPaul Jackson
The cpuset code to present a list of tasks using a cpuset to user space could write to an array that it had kmalloc'd, after a kmalloc request of zero size. The problem was that the code didn't check for writes past the allocated end of the array until -after- the first write. This is a race condition that is likely rare -- it would only show up if a cpuset went from being empty to having a task in it, during the brief time between the allocation and the first write. Prior to roughly 2.6.22 kernels, this was also a benign problem, because a zero kmalloc returned a few usable bytes anyway, and no harm was done with the bogus write. With the 2.6.22 kernel changes to make issue a warning if code tries to write to the location returned from a zero size allocation, this problem is no longer benign. This cpuset code would occassionally trigger that warning. The fix is trivial -- check before storing into the array, not after, whether the array is big enough to hold the store. Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: "Serge E. Hallyn" <serue@us.ibm.com> Cc: Balbir Singh <balbir@in.ibm.com> Cc: Dave Hansen <haveblue@us.ibm.com> Cc: Herbert Poetzl <herbert@13thfloor.at> Cc: Kirill Korotaev <dev@openvz.org> Cc: Paul Menage <menage@google.com> Cc: Srivatsa Vaddagiri <vatsa@in.ibm.com> Cc: Christoph Lameter <clameter@sgi.com> Signed-off-by: Paul Jackson <pj@sgi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-18whitespace fixes: cpusetDaniel Walker
Signed-off-by: Daniel Walker <dwalker@mvista.com> Cc: Paul Jackson <pj@sgi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-17oom: compare cpuset mems_allowed instead of exclusive ancestorsDavid Rientjes
Instead of testing for overlap in the memory nodes of the the nearest exclusive ancestor of both current and the candidate task, it is better to simply test for intersection between the task's mems_allowed in their task descriptors. This does not require taking callback_mutex since it is only used as a hint in the badness scoring. Tasks that do not have an intersection in their mems_allowed with the current task are not explicitly restricted from being OOM killed because it is quite possible that the candidate task has allocated memory there before and has since changed its mems_allowed. Cc: Andrea Arcangeli <andrea@suse.de> Acked-by: Christoph Lameter <clameter@sgi.com> Signed-off-by: David Rientjes <rientjes@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16cpuset: remove sched domain hooks from cpusetsPaul Jackson
Remove the cpuset hooks that defined sched domains depending on the setting of the 'cpu_exclusive' flag. The cpu_exclusive flag can only be set on a child if it is set on the parent. This made that flag painfully unsuitable for use as a flag defining a partitioning of a system. It was entirely unobvious to a cpuset user what partitioning of sched domains they would be causing when they set that one cpu_exclusive bit on one cpuset, because it depended on what CPUs were in the remainder of that cpusets siblings and child cpusets, after subtracting out other cpu_exclusive cpusets. Furthermore, there was no way on production systems to query the result. Using the cpu_exclusive flag for this was simply wrong from the get go. Fortunately, it was sufficiently borked that so far as I know, almost no successful use has been made of this. One real time group did use it to affectively isolate CPUs from any load balancing efforts. They are willing to adapt to alternative mechanisms for this, such as someway to manipulate the list of isolated CPUs on a running system. They can do without this present cpu_exclusive based mechanism while we develop an alternative. There is a real risk, to the best of my understanding, of users accidentally setting up a partitioned scheduler domains, inhibiting desired load balancing across all their CPUs, due to the nonobvious (from the cpuset perspective) side affects of the cpu_exclusive flag. Furthermore, since there was no way on a running system to see what one was doing with sched domains, this change will be invisible to any using code. Unless they have real insight to the scheduler load balancing choices, they will be unable to detect that this change has been made in the kernel's behaviour. Initial discussion on lkml of this patch has generated much comment. My (probably controversial) take on that discussion is that it has reached a rough concensus that the current cpuset cpu_exclusive mechanism for defining sched domains is borked. There is no concensus on the replacement. But since we can remove this mechanism, and since its continued presence risks causing unwanted partitioning of the schedulers load balancing, we should remove it while we can, as we proceed to work the replacement scheduler domain mechanisms. Signed-off-by: Paul Jackson <pj@sgi.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Nick Piggin <nickpiggin@yahoo.com.au> Cc: Christoph Lameter <clameter@engr.sgi.com> Cc: Dinakar Guniguntala <dino@in.ibm.com> Cc: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16Group short-lived and reclaimable kernel allocationsMel Gorman
This patch marks a number of allocations that are either short-lived such as network buffers or are reclaimable such as inode allocations. When something like updatedb is called, long-lived and unmovable kernel allocations tend to be spread throughout the address space which increases fragmentation. This patch groups these allocations together as much as possible by adding a new MIGRATE_TYPE. The MIGRATE_RECLAIMABLE type is for allocations that can be reclaimed on demand, but not moved. i.e. they can be migrated by deleting them and re-reading the information from elsewhere. Signed-off-by: Mel Gorman <mel@csn.ul.ie> Cc: Andy Whitcroft <apw@shadowen.org> Cc: Christoph Lameter <clameter@sgi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16Memoryless nodes: Use N_HIGH_MEMORY for cpusetsChristoph Lameter
cpusets try to ensure that any node added to a cpuset's mems_allowed is on-line and contains memory. The assumption was that online nodes contained memory. Thus, it is possible to add memoryless nodes to a cpuset and then add tasks to this cpuset. This results in continuous series of oom-kill and apparent system hang. Change cpusets to use node_states[N_HIGH_MEMORY] [a.k.a. node_memory_map] in place of node_online_map when vetting memories. Return error if admin attempts to write a non-empty mems_allowed node mask containing only memoryless-nodes. Signed-off-by: Lee Schermerhorn <lee.schermerhorn@hp.com> Signed-off-by: Bob Picco <bob.picco@hp.com> Signed-off-by: Nishanth Aravamudan <nacc@us.ibm.com> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Mel Gorman <mel@skynet.ie> Signed-off-by: Christoph Lameter <clameter@sgi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-18usermodehelper: Tidy up waitingJeremy Fitzhardinge
Rather than using a tri-state integer for the wait flag in call_usermodehelper_exec, define a proper enum, and use that. I've preserved the integer values so that any callers I've missed should still work OK. Signed-off-by: Jeremy Fitzhardinge <jeremy@xensource.com> Cc: James Bottomley <James.Bottomley@HansenPartnership.com> Cc: Randy Dunlap <randy.dunlap@oracle.com> Cc: Christoph Hellwig <hch@infradead.org> Cc: Andi Kleen <ak@suse.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Johannes Berg <johannes@sipsolutions.net> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Bjorn Helgaas <bjorn.helgaas@hp.com> Cc: Joel Becker <joel.becker@oracle.com> Cc: Tony Luck <tony.luck@intel.com> Cc: Kay Sievers <kay.sievers@vrfy.org> Cc: Srivatsa Vaddagiri <vatsa@in.ibm.com> Cc: Oleg Nesterov <oleg@tv-sign.ru> Cc: David Howells <dhowells@redhat.com>
2007-07-17Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/avi/kvm * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/avi/kvm: (80 commits) KVM: Use CPU_DYING for disabling virtualization KVM: Tune hotplug/suspend IPIs KVM: Keep track of which cpus have virtualization enabled SMP: Allow smp_call_function_single() to current cpu i386: Allow smp_call_function_single() to current cpu x86_64: Allow smp_call_function_single() to current cpu HOTPLUG: Adapt thermal throttle to CPU_DYING HOTPLUG: Adapt cpuset hotplug callback to CPU_DYING HOTPLUG: Add CPU_DYING notifier KVM: Clean up #includes KVM: Remove kvmfs in favor of the anonymous inodes source KVM: SVM: Reliably detect if SVM was disabled by BIOS KVM: VMX: Remove unnecessary code in vmx_tlb_flush() KVM: MMU: Fix Wrong tlb flush order KVM: VMX: Reinitialize the real-mode tss when entering real mode KVM: Avoid useless memory write when possible KVM: Fix x86 emulator writeback KVM: Add support for in-kernel pio handlers KVM: VMX: Fix interrupt checking on lightweight exit KVM: Adds support for in-kernel mmio handlers ...
2007-07-16Reduce cpuset.c write_lock_irq() to read_lock()Paul Menage
cpuset.c:update_nodemask() uses a write_lock_irq() on tasklist_lock to block concurrent forks; a read_lock() suffices and is less intrusive. Signed-off-by: Paul Menage<menage@google.com> Acked-by: Paul Jackson <pj@sgi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-16HOTPLUG: Adapt cpuset hotplug callback to CPU_DYINGAvi Kivity
CPU_DYING is called in atomic context, so don't try to take any locks. Signed-off-by: Avi Kivity <avi@qumranet.com>
2007-06-16cpuset: zero malloc - fix for old cpusetsPaul Jackson
2007-05-09use simple_read_from_buffer in kernel/Akinobu Mita
Cleanup using simple_read_from_buffer() for /dev/cpuset/tasks and /proc/config.gz. Cc: Paul Jackson <pj@sgi.com> Cc: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08cpusets: allow empty {cpus,mems}_allowed to be set for unpopulated cpusetDavid Rientjes
You currently cannot remove all cpus or mems from cpus_allowed or mems_allowed of a cpuset. We now allow both if there are no attached tasks. Acked-by: Paul Jackson <pj@sgi.com> Cc: Christoph Lameter <clameter@engr.sgi.com> Signed-off-by: Paul Menage <menage@google.com> Signed-off-by: David Rientjes <rientjes@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08Fix race between attach_task and cpuset_exitSrivatsa Vaddagiri
Currently cpuset_exit() changes the exiting task's ->cpuset pointer w/o taking task_lock(). This can lead to ugly races between attach_task and cpuset_exit. Details of the races are described at http://lkml.org/lkml/2007/3/24/132. Patch below closes those races. Signed-off-by: Srivatsa Vaddagiri <vatsa@in.ibm.com> Cc: Paul Jackson <pj@sgi.com> Cc: Balbir Singh <balbir@in.ibm.com> Cc: Paul Menage <menage@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-07cpusets: allow TIF_MEMDIE threads to allocate anywhereDavid Rientjes
OOM killed tasks have access to memory reserves as specified by the TIF_MEMDIE flag in the hopes that it will quickly exit. If such a task has memory allocations constrained by cpusets, we may encounter a deadlock if a blocking task cannot exit because it cannot allocate the necessary memory. We allow tasks that have the TIF_MEMDIE flag to allocate memory anywhere, including outside its cpuset restriction, so that it can quickly die regardless of whether it is __GFP_HARDWALL. Cc: Andi Kleen <ak@suse.de> Cc: Paul Jackson <pj@sgi.com> Cc: Christoph Lameter <clameter@engr.sgi.com> Signed-off-by: David Rientjes <rientjes@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-12[PATCH] mark struct inode_operations const 2Arjan van de Ven
2007-02-12[PATCH] mark struct file_operations const 7Arjan van de Ven
Many struct file_operations in the kernel can be "const". Marking them const moves these to the .rodata section, which avoids false sharing with potential dirty data. In addition it'll catch accidental writes at compile time to these shared resources. Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-12-30[PATCH] cpuset procfs warning fixAndrew Morton
fs/proc/base.c:1869: warning: initialization discards qualifiers from pointer target type fs/proc/base.c:2150: warning: initialization discards qualifiers from pointer target type Cc: Paul Jackson <pj@sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-13[PATCH] cpuset: rework cpuset_zone_allowed apiPaul Jackson
Elaborate the API for calling cpuset_zone_allowed(), so that users have to explicitly choose between the two variants: cpuset_zone_allowed_hardwall() cpuset_zone_allowed_softwall() Until now, whether or not you got the hardwall flavor depended solely on whether or not you or'd in the __GFP_HARDWALL gfp flag to the gfp_mask argument. If you didn't specify __GFP_HARDWALL, you implicitly got the softwall version. Unfortunately, this meant that users would end up with the softwall version without thinking about it. Since only the softwall version might sleep, this led to bugs with possible sleeping in interrupt context on more than one occassion. The hardwall version requires that the current tasks mems_allowed allows the node of the specified zone (or that you're in interrupt or that __GFP_THISNODE is set or that you're on a one cpuset system.) The softwall version, depending on the gfp_mask, might allow a node if it was allowed in the nearest enclusing cpuset marked mem_exclusive (which requires taking the cpuset lock 'callback_mutex' to evaluate.) This patch removes the cpuset_zone_allowed() call, and forces the caller to explicitly choose between the hardwall and the softwall case. If the caller wants the gfp_mask to determine this choice, they should (1) be sure they can sleep or that __GFP_HARDWALL is set, and (2) invoke the cpuset_zone_allowed_softwall() routine. This adds another 100 or 200 bytes to the kernel text space, due to the few lines of nearly duplicate code at the top of both cpuset_zone_allowed_* routines. It should save a few instructions executed for the calls that turned into calls of cpuset_zone_allowed_hardwall, thanks to not having to set (before the call) then check (within the call) the __GFP_HARDWALL flag. For the most critical call, from get_page_from_freelist(), the same instructions are executed as before -- the old cpuset_zone_allowed() routine it used to call is the same code as the cpuset_zone_allowed_softwall() routine that it calls now. Not a perfect win, but seems worth it, to reduce this chance of hitting a sleeping with irq off complaint again. Signed-off-by: Paul Jackson <pj@sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-08[PATCH] struct path: convert kernelJosef Sipek
2006-12-07[PATCH] cpuset: allow a larger buffer for writes to cpuset filesPaul Menage
When using fake NUMA setup, the number of memory nodes can greatly exceed the number of CPUs. So the current limit in cpuset_common_file_write() is insufficient. Signed-off-by: Paul Menage <menage@google.com> Acked-by: Paul Jackson <pj@sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-07[PATCH] struct seq_operations and struct file_operations constificationHelge Deller
- move some file_operations structs into the .rodata section - move static strings from policy_types[] array into the .rodata section - fix generic seq_operations usages, so that those structs may be defined as "const" as well [akpm@osdl.org: couple of fixes] Signed-off-by: Helge Deller <deller@gmx.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-07[PATCH] hotplug CPU: clean up hotcpu_notifier() useIngo Molnar
There was lots of #ifdef noise in the kernel due to hotcpu_notifier(fn, prio) not correctly marking 'fn' as used in the !HOTPLUG_CPU case, and thus generating compiler warnings of unused symbols, hence forcing people to add #ifdefs. the compiler can skip truly unused functions just fine: text data bss dec hex filename 1624412 728710 3674856 6027978 5bfaca vmlinux.before 1624412 728710 3674856 6027978 5bfaca vmlinux.after [akpm@osdl.org: topology.c fix] Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
