path: root/kernel/cpuset.c
2014-07-17cpuset,mempolicy: fix sleeping function called from invalid contextGu Zheng
commit 391acf970d21219a2a5446282d3b20eace0c0d7a upstream. When runing with the kernel(3.15-rc7+), the follow bug occurs: [ 9969.258987] BUG: sleeping function called from invalid context at kernel/locking/mutex.c:586 [ 9969.359906] in_atomic(): 1, irqs_disabled(): 0, pid: 160655, name: python [ 9969.441175] INFO: lockdep is turned off. [ 9969.488184] CPU: 26 PID: 160655 Comm: python Tainted: G A 3.15.0-rc7+ #85 [ 9969.581032] Hardware name: FUJITSU-SV PRIMEQUEST 1800E/SB, BIOS PRIMEQUEST 1000 Series BIOS Version 1.39 11/16/2012 [ 9969.706052] ffffffff81a20e60 ffff8803e941fbd0 ffffffff8162f523 ffff8803e941fd18 [ 9969.795323] ffff8803e941fbe0 ffffffff8109995a ffff8803e941fc58 ffffffff81633e6c [ 9969.884710] ffffffff811ba5dc ffff880405c6b480 ffff88041fdd90a0 0000000000002000 [ 9969.974071] Call Trace: [ 9970.003403] [<ffffffff8162f523>] dump_stack+0x4d/0x66 [ 9970.065074] [<ffffffff8109995a>] __might_sleep+0xfa/0x130 [ 9970.130743] [<ffffffff81633e6c>] mutex_lock_nested+0x3c/0x4f0 [ 9970.200638] [<ffffffff811ba5dc>] ? kmem_cache_alloc+0x1bc/0x210 [ 9970.272610] [<ffffffff81105807>] cpuset_mems_allowed+0x27/0x140 [ 9970.344584] [<ffffffff811b1303>] ? __mpol_dup+0x63/0x150 [ 9970.409282] [<ffffffff811b1385>] __mpol_dup+0xe5/0x150 [ 9970.471897] [<ffffffff811b1303>] ? __mpol_dup+0x63/0x150 [ 9970.536585] [<ffffffff81068c86>] ? copy_process.part.23+0x606/0x1d40 [ 9970.613763] [<ffffffff810bf28d>] ? trace_hardirqs_on+0xd/0x10 [ 9970.683660] [<ffffffff810ddddf>] ? monotonic_to_bootbased+0x2f/0x50 [ 9970.759795] [<ffffffff81068cf0>] copy_process.part.23+0x670/0x1d40 [ 9970.834885] [<ffffffff8106a598>] do_fork+0xd8/0x380 [ 9970.894375] [<ffffffff81110e4c>] ? __audit_syscall_entry+0x9c/0xf0 [ 9970.969470] [<ffffffff8106a8c6>] SyS_clone+0x16/0x20 [ 9971.030011] [<ffffffff81642009>] stub_clone+0x69/0x90 [ 9971.091573] [<ffffffff81641c29>] ? system_call_fastpath+0x16/0x1b The cause is that cpuset_mems_allowed() try to take mutex_lock(&callback_mutex) under the rcu_read_lock(which was hold in __mpol_dup()). And in cpuset_mems_allowed(), the access to cpuset is under rcu_read_lock, so in __mpol_dup, we can reduce the rcu_read_lock protection region to protect the access to cpuset only in current_cpuset_is_being_rebound(). So that we can avoid this bug. This patch is a temporary solution that just addresses the bug mentioned above, can not fix the long-standing issue about cpuset.mems rebinding on fork(): "When the forker's task_struct is duplicated (which includes ->mems_allowed) and it races with an update to cpuset_being_rebound in update_tasks_nodemask() then the task's mems_allowed doesn't get updated. And the child task's mems_allowed can be wrong if the cpuset's nodemask changes before the child has been added to the cgroup's tasklist." Signed-off-by: Gu Zheng <guz.fnst@cn.fujitsu.com> Acked-by: Li Zefan <lizefan@huawei.com> Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-03-23cpuset: fix a race condition in __cpuset_node_allowed_softwall()Li Zefan
commit 99afb0fd5f05aac467ffa85c36778fec4396209b upstream. It's not safe to access task's cpuset after releasing task_lock(). Holding callback_mutex won't help. Signed-off-by: Li Zefan <lizefan@huawei.com> Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-12-04cpuset: Fix memory allocator deadlockPeter Zijlstra
commit 0fc0287c9ed1ffd3706f8b4d9b314aa102ef1245 upstream. Juri hit the below lockdep report: [ 4.303391] ====================================================== [ 4.303392] [ INFO: SOFTIRQ-safe -> SOFTIRQ-unsafe lock order detected ] [ 4.303394] 3.12.0-dl-peterz+ #144 Not tainted [ 4.303395] ------------------------------------------------------ [ 4.303397] kworker/u4:3/689 [HC0[0]:SC0[0]:HE0:SE1] is trying to acquire: [ 4.303399] (&p->mems_allowed_seq){+.+...}, at: [<ffffffff8114e63c>] new_slab+0x6c/0x290 [ 4.303417] [ 4.303417] and this task is already holding: [ 4.303418] (&(&q->__queue_lock)->rlock){..-...}, at: [<ffffffff812d2dfb>] blk_execute_rq_nowait+0x5b/0x100 [ 4.303431] which would create a new lock dependency: [ 4.303432] (&(&q->__queue_lock)->rlock){..-...} -> (&p->mems_allowed_seq){+.+...} [ 4.303436] [ 4.303898] the dependencies between the lock to be acquired and SOFTIRQ-irq-unsafe lock: [ 4.303918] -> (&p->mems_allowed_seq){+.+...} ops: 2762 { [ 4.303922] HARDIRQ-ON-W at: [ 4.303923] [<ffffffff8108ab9a>] __lock_acquire+0x65a/0x1ff0 [ 4.303926] [<ffffffff8108cbe3>] lock_acquire+0x93/0x140 [ 4.303929] [<ffffffff81063dd6>] kthreadd+0x86/0x180 [ 4.303931] [<ffffffff816ded6c>] ret_from_fork+0x7c/0xb0 [ 4.303933] SOFTIRQ-ON-W at: [ 4.303933] [<ffffffff8108abcc>] __lock_acquire+0x68c/0x1ff0 [ 4.303935] [<ffffffff8108cbe3>] lock_acquire+0x93/0x140 [ 4.303940] [<ffffffff81063dd6>] kthreadd+0x86/0x180 [ 4.303955] [<ffffffff816ded6c>] ret_from_fork+0x7c/0xb0 [ 4.303959] INITIAL USE at: [ 4.303960] [<ffffffff8108a884>] __lock_acquire+0x344/0x1ff0 [ 4.303963] [<ffffffff8108cbe3>] lock_acquire+0x93/0x140 [ 4.303966] [<ffffffff81063dd6>] kthreadd+0x86/0x180 [ 4.303969] [<ffffffff816ded6c>] ret_from_fork+0x7c/0xb0 [ 4.303972] } Which reports that we take mems_allowed_seq with interrupts enabled. A little digging found that this can only be from cpuset_change_task_nodemask(). This is an actual deadlock because an interrupt doing an allocation will hit get_mems_allowed()->...->__read_seqcount_begin(), which will spin forever waiting for the write side to complete. Cc: John Stultz <john.stultz@linaro.org> Cc: Mel Gorman <mgorman@suse.de> Reported-by: Juri Lelli <juri.lelli@gmail.com> Signed-off-by: Peter Zijlstra <peterz@infradead.org> Tested-by: Juri Lelli <juri.lelli@gmail.com> Acked-by: Li Zefan <lizefan@huawei.com> Acked-by: Mel Gorman <mgorman@suse.de> Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-08-20cpuset: fix the return value of cpuset_write_u64()Li Zefan
commit a903f0865a190f8778c73df1a810ea6e25e5d7cf upstream. Writing to this file always returns -ENODEV: # echo 1 > cpuset.memory_pressure_enabled -bash: echo: write error: No such device Signed-off-by: Li Zefan <lizefan@huawei.com> Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-05-01Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull VFS updates from Al Viro, Misc cleanups all over the place, mainly wrt /proc interfaces (switch create_proc_entry to proc_create(), get rid of the deprecated create_proc_read_entry() in favor of using proc_create_data() and seq_file etc). 7kloc removed. * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (204 commits) don't bother with deferred freeing of fdtables proc: Move non-public stuff from linux/proc_fs.h to fs/proc/internal.h proc: Make the PROC_I() and PDE() macros internal to procfs proc: Supply a function to remove a proc entry by PDE take cgroup_open() and cpuset_open() to fs/proc/base.c ppc: Clean up scanlog ppc: Clean up rtas_flash driver somewhat hostap: proc: Use remove_proc_subtree() drm: proc: Use remove_proc_subtree() drm: proc: Use minor->index to label things, not PDE->name drm: Constify drm_proc_list[] zoran: Don't print proc_dir_entry data in debug reiserfs: Don't access the proc_dir_entry in r_open(), r_start() r_show() proc: Supply an accessor for getting the data from a PDE's parent airo: Use remove_proc_subtree() rtl8192u: Don't need to save device proc dir PDE rtl8187se: Use a dir under /proc/net/r8180/ proc: Add proc_mkdir_data() proc: Move some bits from linux/proc_fs.h to linux/{of.h,signal.h,tty.h} proc: Move PDE_NET() to fs/proc/proc_net.c ...
2013-05-01take cgroup_open() and cpuset_open() to fs/proc/base.cAl Viro
2013-04-29Merge branch 'for-3.10' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tj/cgroup Pull cgroup updates from Tejun Heo: - Fixes and a lot of cleanups. Locking cleanup is finally complete. cgroup_mutex is no longer exposed to individual controlelrs which used to cause nasty deadlock issues. Li fixed and cleaned up quite a bit including long standing ones like racy cgroup_path(). - device cgroup now supports proper hierarchy thanks to Aristeu. - perf_event cgroup now supports proper hierarchy. - A new mount option "__DEVEL__sane_behavior" is added. As indicated by the name, this option is to be used for development only at this point and generates a warning message when used. Unfortunately, cgroup interface currently has too many brekages and inconsistencies to implement a consistent and unified hierarchy on top. The new flag is used to collect the behavior changes which are necessary to implement consistent unified hierarchy. It's likely that this flag won't be used verbatim when it becomes ready but will be enabled implicitly along with unified hierarchy. The option currently disables some of broken behaviors in cgroup core and also .use_hierarchy switch in memcg (will be routed through -mm), which can be used to make very unusual hierarchy where nesting is partially honored. It will also be used to implement hierarchy support for blk-throttle which would be impossible otherwise without introducing a full separate set of control knobs. This is essentially versioning of interface which isn't very nice but at this point I can't see any other options which would allow keeping the interface the same while moving towards hierarchy behavior which is at least somewhat sane. The planned unified hierarchy is likely to require some level of adaptation from userland anyway, so I think it'd be best to take the chance and update the interface such that it's supportable in the long term. Maintaining the existing interface does complicate cgroup core but shouldn't put too much strain on individual controllers and I think it'd be manageable for the foreseeable future. Maybe we'll be able to drop it in a decade. Fix up conflicts (including a semantic one adding a new #include to ppc that was uncovered by header the file changes) as per Tejun. * 'for-3.10' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/cgroup: (45 commits) cpuset: fix compile warning when CONFIG_SMP=n cpuset: fix cpu hotplug vs rebuild_sched_domains() race cpuset: use rebuild_sched_domains() in cpuset_hotplug_workfn() cgroup: restore the call to eventfd->poll() cgroup: fix use-after-free when umounting cgroupfs cgroup: fix broken file xattrs devcg: remove parent_cgroup. memcg: force use_hierarchy if sane_behavior cgroup: remove cgrp->top_cgroup cgroup: introduce sane_behavior mount option move cgroupfs_root to include/linux/cgroup.h cgroup: convert cgroupfs_root flag bits to masks and add CGRP_ prefix cgroup: make cgroup_path() not print double slashes Revert "cgroup: remove bind() method from cgroup_subsys." perf: make perf_event cgroup hierarchical cgroup: implement cgroup_is_descendant() cgroup: make sure parent won't be destroyed before its children cgroup: remove bind() method from cgroup_subsys. devcg: remove broken_hierarchy tag cgroup: remove cgroup_lock_is_held() ...
2013-04-29Merge branch 'for-3.10' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/wqLinus Torvalds
Pull workqueue updates from Tejun Heo: "A lot of activities on workqueue side this time. The changes achieve the followings. - WQ_UNBOUND workqueues - the workqueues which are per-cpu - are updated to be able to interface with multiple backend worker pools. This involved a lot of churning but the end result seems actually neater as unbound workqueues are now a lot closer to per-cpu ones. - The ability to interface with multiple backend worker pools are used to implement unbound workqueues with custom attributes. Currently the supported attributes are the nice level and CPU affinity. It may be expanded to include cgroup association in future. The attributes can be specified either by calling apply_workqueue_attrs() or through /sys/bus/workqueue/WQ_NAME/* if the workqueue in question is exported through sysfs. The backend worker pools are keyed by the actual attributes and shared by any workqueues which share the same attributes. When attributes of a workqueue are changed, the workqueue binds to the worker pool with the specified attributes while leaving the work items which are already executing in its previous worker pools alone. This allows converting custom worker pool implementations which want worker attribute tuning to use workqueues. The writeback pool is already converted in block tree and there are a couple others are likely to follow including btrfs io workers. - WQ_UNBOUND's ability to bind to multiple worker pools is also used to make it NUMA-aware. Because there's no association between work item issuer and the specific worker assigned to execute it, before this change, using unbound workqueue led to unnecessary cross-node bouncing and it couldn't be helped by autonuma as it requires tasks to have implicit node affinity and workers are assigned randomly. After these changes, an unbound workqueue now binds to multiple NUMA-affine worker pools so that queued work items are executed in the same node. This is turned on by default but can be disabled system-wide or for individual workqueues. Crypto was requesting NUMA affinity as encrypting data across different nodes can contribute noticeable overhead and doing it per-cpu was too limiting for certain cases and IO throughput could be bottlenecked by one CPU being fully occupied while others have idle cycles. While the new features required a lot of changes including restructuring locking, it didn't complicate the execution paths much. The unbound workqueue handling is now closer to per-cpu ones and the new features are implemented by simply associating a workqueue with different sets of backend worker pools without changing queue, execution or flush paths. As such, even though the amount of change is very high, I feel relatively safe in that it isn't likely to cause subtle issues with basic correctness of work item execution and handling. If something is wrong, it's likely to show up as being associated with worker pools with the wrong attributes or OOPS while workqueue attributes are being changed or during CPU hotplug. While this creates more backend worker pools, it doesn't add too many more workers unless, of course, there are many workqueues with unique combinations of attributes. Assuming everything else is the same, NUMA awareness costs an extra worker pool per NUMA node with online CPUs. There are also a couple things which are being routed outside the workqueue tree. - block tree pulled in workqueue for-3.10 so that writeback worker pool can be converted to unbound workqueue with sysfs control exposed. This simplifies the code, makes writeback workers NUMA-aware and allows tuning nice level and CPU affinity via sysfs. - The conversion to workqueue means that there's no 1:1 association between a specific worker, which makes writeback folks unhappy as they want to be able to tell which filesystem caused a problem from backtrace on systems with many filesystems mounted. This is resolved by allowing work items to set debug info string which is printed when the task is dumped. As this change involves unifying implementations of dump_stack() and friends in arch codes, it's being routed through Andrew's -mm tree." * 'for-3.10' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/wq: (84 commits) workqueue: use kmem_cache_free() instead of kfree() workqueue: avoid false negative WARN_ON() in destroy_workqueue() workqueue: update sysfs interface to reflect NUMA awareness and a kernel param to disable NUMA affinity workqueue: implement NUMA affinity for unbound workqueues workqueue: introduce put_pwq_unlocked() workqueue: introduce numa_pwq_tbl_install() workqueue: use NUMA-aware allocation for pool_workqueues workqueue: break init_and_link_pwq() into two functions and introduce alloc_unbound_pwq() workqueue: map an unbound workqueues to multiple per-node pool_workqueues workqueue: move hot fields of workqueue_struct to the end workqueue: make workqueue->name[] fixed len workqueue: add workqueue->unbound_attrs workqueue: determine NUMA node of workers accourding to the allowed cpumask workqueue: drop 'H' from kworker names of unbound worker pools workqueue: add wq_numa_tbl_len and wq_numa_possible_cpumask[] workqueue: move pwq_pool_locking outside of get/put_unbound_pool() workqueue: fix memory leak in apply_workqueue_attrs() workqueue: fix unbound workqueue attrs hashing / comparison workqueue: fix race condition in unbound workqueue free path workqueue: remove pwq_lock which is no longer used ...
2013-04-29kernel/cpuset.c: use register_hotmemory_notifier()Andrew Morton
Use the new interface, remove one ifdef. No code size changes. We could/should have been using __meminit/__meminitdata here but there's now no point in doing that because all this code is elided at compile time. Cc: Li Zefan <lizefan@huawei.com> Cc: Tejun Heo <tj@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-04-27cpuset: fix compile warning when CONFIG_SMP=nLi Zefan
Reported by Fengguang's kbuild test robot: kernel/cpuset.c:787: warning: 'generate_sched_domains' defined but not used Introduced by commit e0e80a02e5701c8790bd348ab59edb154fbda60b ("cpuset: use rebuild_sched_domains() in cpuset_hotplug_workfn()), which removed generate_sched_domains() from cpuset_hotplug_workfn(). Reported-by: Fengguang Wu <fengguang.wu@intel.com> Signed-off-by: Li Zefan <lizefan@huawei.com> Signed-off-by: Tejun Heo <tj@kernel.org>
2013-04-27cpuset: fix cpu hotplug vs rebuild_sched_domains() raceLi Zefan
rebuild_sched_domains() might pass doms with offlined cpu to partition_sched_domains(), which results in an oops: general protection fault: 0000 [#1] SMP ... RIP: 0010:[<ffffffff81077a1e>] [<ffffffff81077a1e>] get_group+0x6e/0x90 ... Call Trace: [<ffffffff8107f07c>] build_sched_domains+0x70c/0xcb0 [<ffffffff8107f2a7>] ? build_sched_domains+0x937/0xcb0 [<ffffffff81173f64>] ? kfree+0xe4/0x1b0 [<ffffffff8107f6e0>] ? partition_sched_domains+0xc0/0x470 [<ffffffff8107f905>] partition_sched_domains+0x2e5/0x470 [<ffffffff8107f6e0>] ? partition_sched_domains+0xc0/0x470 [<ffffffff810c9007>] ? generate_sched_domains+0xc7/0x530 [<ffffffff810c94a8>] rebuild_sched_domains_locked+0x38/0x70 [<ffffffff810cb4a4>] cpuset_write_resmask+0x1a4/0x500 [<ffffffff810c8700>] ? cpuset_mount+0xe0/0xe0 [<ffffffff810c7f50>] ? cpuset_read_u64+0x100/0x100 [<ffffffff810be890>] ? cgroup_iter_next+0x90/0x90 [<ffffffff810cb300>] ? cpuset_css_offline+0x70/0x70 [<ffffffff810c1a73>] cgroup_file_write+0x133/0x2e0 [<ffffffff8118995b>] vfs_write+0xcb/0x130 [<ffffffff8118a174>] sys_write+0x64/0xa0 Reported-by: Li Zhong <zhong@linux.vnet.ibm.com> Signed-off-by: Li Zefan <lizefan@huawei.com> Signed-off-by: Tejun Heo <tj@kernel.org>
2013-04-27cpuset: use rebuild_sched_domains() in cpuset_hotplug_workfn()Li Zhong
In cpuset_hotplug_workfn(), partition_sched_domains() is called without hotplug lock held, which is actually needed (stated in the function header of partition_sched_domains()). This patch tries to use rebuild_sched_domains() to solve the above issue, and makes the code looks a little simpler. Signed-off-by: Li Zhong <zhong@linux.vnet.ibm.com> Signed-off-by: Li Zefan <lizefan@huawei.com> Signed-off-by: Tejun Heo <tj@kernel.org>
2013-04-07cgroup, cpuset: replace move_member_tasks_to_cpuset() with ↵Tejun Heo
cgroup_transfer_tasks() When a cpuset becomes empty (no CPU or memory), its tasks are transferred with the nearest ancestor with execution resources. This is implemented using cgroup_scan_tasks() with a callback which grabs cgroup_mutex and invokes cgroup_attach_task() on each task. Both cgroup_mutex and cgroup_attach_task() are scheduled to be unexported. Implement cgroup_transfer_tasks() in cgroup proper which is essentially the same as move_member_tasks_to_cpuset() except that it takes cgroups instead of cpusets and @to comes before @from like normal functions with those arguments, and replace move_member_tasks_to_cpuset() with it. Signed-off-by: Tejun Heo <tj@kernel.org> Acked-by: Li Zefan <lizefan@huawei.com>
2013-03-20cgroup: consolidate cgroup_attach_task() and cgroup_attach_proc()Li Zefan
These two functions share most of the code. Signed-off-by: Li Zefan <lizefan@huawei.com> Signed-off-by: Tejun Heo <tj@kernel.org>
2013-03-19sched: replace PF_THREAD_BOUND with PF_NO_SETAFFINITYTejun Heo
PF_THREAD_BOUND was originally used to mark kernel threads which were bound to a specific CPU using kthread_bind() and a task with the flag set allows cpus_allowed modifications only to itself. Workqueue is currently abusing it to prevent userland from meddling with cpus_allowed of workqueue workers. What we need is a flag to prevent userland from messing with cpus_allowed of certain kernel tasks. In kernel, anyone can (incorrectly) squash the flag, and, for worker-type usages, restricting cpus_allowed modification to the task itself doesn't provide meaningful extra proection as other tasks can inject work items to the task anyway. This patch replaces PF_THREAD_BOUND with PF_NO_SETAFFINITY. sched_setaffinity() checks the flag and return -EINVAL if set. set_cpus_allowed_ptr() is no longer affected by the flag. This will allow simplifying workqueue worker CPU affinity management. Signed-off-by: Tejun Heo <tj@kernel.org> Acked-by: Ingo Molnar <mingo@kernel.org> Reviewed-by: Lai Jiangshan <laijs@cn.fujitsu.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de>
2013-03-12cpuset: fix RCU lockdep splat in cpuset_print_task_mems_allowed()Li Zefan
Sasha reported a lockdep warning when OOM was triggered. The reason is cgroup_name() should be called with rcu_read_lock() held. Reported-by: Sasha Levin <sasha.levin@oracle.com> Signed-off-by: Li Zefan <lizefan@huawei.com> Signed-off-by: Tejun Heo <tj@kernel.org>
2013-03-04cpuset: use cgroup_name() in cpuset_print_task_mems_allowed()Li Zefan
Use cgroup_name() instead of cgrp->dentry->name. This makes the code a bit simpler. While at it, remove cpuset_name and make cpuset_nodelist a local variable to cpuset_print_task_mems_allowed(). Signed-off-by: Li Zefan <lizefan@huawei.com> Signed-off-by: Tejun Heo <tj@kernel.org>
2013-02-20Merge branch 'for-3.9-cpuset' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tj/cgroup Pull cpuset changes from Tejun Heo: - Synchornization has seen a lot of changes with focus on decoupling cpuset synchronization from cgroup internal locking. After this change, there only remain a couple of mostly trivial dependencies on cgroup_lock outside cgroup core proper. cgroup_lock is scheduled to be unexported in this devel cycle. This will finally remove the fragile locking order around cgroup (cgroup locking wants to / should be one of the outermost but yet has been acquired from deep inside individual controllers). - At this point, Li is most knowlegeable with cpuset and taking over the maintainership of cpuset. * 'for-3.9-cpuset' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/cgroup: cpuset: drop spurious retval assignment in proc_cpuset_show() cpuset: fix RCU lockdep splat cpuset: update MAINTAINERS cpuset: remove cpuset->parent cpuset: replace cpuset->stack_list with cpuset_for_each_descendant_pre() cpuset: replace cgroup_mutex locking with cpuset internal locking cpuset: schedule hotplug propagation from cpuset_attach() if the cpuset is empty cpuset: pin down cpus and mems while a task is being attached cpuset: make CPU / memory hotplug propagation asynchronous cpuset: drop async_rebuild_sched_domains() cpuset: don't nest cgroup_mutex inside get_online_cpus() cpuset: reorganize CPU / memory hotplug handling cpuset: cleanup cpuset[_can]_attach() cpuset: introduce cpuset_for_each_child() cpuset: introduce CS_ONLINE cpuset: introduce ->css_on/offline() cpuset: remove fast exit path from remove_tasks_in_empty_cpuset() cpuset: remove unused cpuset_unlock()
2013-02-18cpuset: fix cpuset_print_task_mems_allowed() vs rename() raceLi Zefan
rename() will change dentry->d_name. The result of this race can be worse than seeing partially rewritten name, but we might access a stale pointer because rename() will re-allocate memory to hold a longer name. It's safe in the protection of dentry->d_lock. v2: check NULL dentry before acquiring dentry lock. Signed-off-by: Li Zefan <lizefan@huawei.com> Signed-off-by: Tejun Heo <tj@kernel.org> Cc: stable@vger.kernel.org
2013-01-15cpuset: drop spurious retval assignment in proc_cpuset_show()Li Zefan
proc_cpuset_show() has a spurious -EINVAL assignment which does nothing. Remove it. This patch doesn't make any functional difference. tj: Rewrote patch description. Signed-off-by: Li Zefan <lizefan@huawei.com> Signed-off-by: Tejun Heo <tj@kernel.org>
2013-01-15cpuset: fix RCU lockdep splatLi Zefan
5d21cc2db040d01f8c19b8602f6987813e1176b4 ("cpuset: replace cgroup_mutex locking with cpuset internal locking") incorrectly converted proc_cpuset_show() from cgroup_lock() to cpuset_mutex. proc_cpuset_show() is accessing cgroup hierarchy proper to determine cgroup path which can't be protected by cpuset_mutex. This triggered the following RCU warning. =============================== [ INFO: suspicious RCU usage. ] 3.8.0-rc3-next-20130114-sasha-00016-ga107525-dirty #262 Tainted: G W ------------------------------- include/linux/cgroup.h:534 suspicious rcu_dereference_check() usage! other info that might help us debug this: rcu_scheduler_active = 1, debug_locks = 1 2 locks held by trinity/7514: #0: (&p->lock){+.+.+.}, at: [<ffffffff812b06aa>] seq_read+0x3a/0x3e0 #1: (cpuset_mutex){+.+...}, at: [<ffffffff811abae4>] proc_cpuset_show+0x84/0x190 stack backtrace: Pid: 7514, comm: trinity Tainted: G W +3.8.0-rc3-next-20130114-sasha-00016-ga107525-dirty #262 Call Trace: [<ffffffff81182cab>] lockdep_rcu_suspicious+0x10b/0x120 [<ffffffff811abb71>] proc_cpuset_show+0x111/0x190 [<ffffffff812b0827>] seq_read+0x1b7/0x3e0 [<ffffffff812b0670>] ? seq_lseek+0x110/0x110 [<ffffffff8128b4fb>] do_loop_readv_writev+0x4b/0x90 [<ffffffff8128b776>] do_readv_writev+0xf6/0x1d0 [<ffffffff8128b8ee>] vfs_readv+0x3e/0x60 [<ffffffff8128b960>] sys_readv+0x50/0xd0 [<ffffffff83d33d18>] tracesys+0xe1/0xe6 The operation can be performed under RCU read lock. Replace cpuset_mutex locking with RCU read locking. tj: Rewrote patch description. Reported-by: Sasha Levin <sasha.levin@oracle.com> Signed-off-by: Li Zefan <lizefan@huawei.com> Signed-off-by: Tejun Heo <tj@kernel.org>
2013-01-07cpuset: remove cpuset->parentTejun Heo
cgroup already tracks the hierarchy. Follow cgroup->parent to find the parent and drop cpuset->parent. Signed-off-by: Tejun Heo <tj@kernel.org> Reviewed-by: Michal Hocko <mhocko@suse.cz> Acked-by: Li Zefan <lizefan@huawei.com>
2013-01-07cpuset: replace cpuset->stack_list with cpuset_for_each_descendant_pre()Tejun Heo
Implement cpuset_for_each_descendant_pre() and replace the cpuset-specific tree walking using cpuset->stack_list with it. Signed-off-by: Tejun Heo <tj@kernel.org> Reviewed-by: Michal Hocko <mhocko@suse.cz> Acked-by: Li Zefan <lizefan@huawei.com>
2013-01-07cpuset: replace cgroup_mutex locking with cpuset internal lockingTejun Heo
Supposedly for historical reasons, cpuset depends on cgroup core for locking. It depends on cgroup_mutex in cgroup callbacks and grabs cgroup_mutex from other places where it wants to be synchronized. This is majorly messy and highly prone to introducing circular locking dependency especially because cgroup_mutex is supposed to be one of the outermost locks. As previous patches already plugged possible races which may happen by decoupling from cgroup_mutex, replacing cgroup_mutex with cpuset specific cpuset_mutex is mostly straight-forward. Introduce cpuset_mutex, replace all occurrences of cgroup_mutex with it, and add cpuset_mutex locking to places which inherited cgroup_mutex from cgroup core. The only complication is from cpuset wanting to initiate task migration when a cpuset loses all cpus or memory nodes. Task migration may go through full cgroup and all subsystem locking and should be initiated without holding any cpuset specific lock; however, a previous patch already made hotplug handled asynchronously and moving the task migration part outside other locks is easy. cpuset_propagate_hotplug_workfn() now invokes remove_tasks_in_empty_cpuset() without holding any lock. Signed-off-by: Tejun Heo <tj@kernel.org> Acked-by: Li Zefan <lizefan@huawei.com>
2013-01-07cpuset: schedule hotplug propagation from cpuset_attach() if the cpuset is emptyTejun Heo
cpuset is scheduled to be decoupled from cgroup_lock which will make hotplug handling race with task migration. cpus or mems will be allowed to go offline between ->can_attach() and ->attach(). If hotplug takes down all cpus or mems of a cpuset while attach is in progress, ->attach() may end up putting tasks into an empty cpuset. This patchset makes ->attach() schedule hotplug propagation if the cpuset is empty after attaching is complete. This will move the tasks to the nearest ancestor which can execute and the end result would be as if hotplug handling happened after the tasks finished attaching. cpuset_write_resmask() now also flushes cpuset_propagate_hotplug_wq to wait for propagations scheduled directly by cpuset_attach(). This currently doesn't make any functional difference as everything is protected by cgroup_mutex but enables decoupling the locking. Signed-off-by: Tejun Heo <tj@kernel.org> Acked-by: Li Zefan <lizefan@huawei.com>
2013-01-07cpuset: pin down cpus and mems while a task is being attachedTejun Heo
cpuset is scheduled to be decoupled from cgroup_lock which will make configuration updates race with task migration. Any config update will be allowed to happen between ->can_attach() and ->attach(). If such config update removes either all cpus or mems, by the time ->attach() is called, the condition verified by ->can_attach(), that the cpuset is capable of hosting the tasks, is no longer true. This patch adds cpuset->attach_in_progress which is incremented from ->can_attach() and decremented when the attach operation finishes either successfully or not. validate_change() treats cpusets w/ non-zero ->attach_in_progress like cpusets w/ tasks and refuses to remove all cpus or mems from it. This currently doesn't make any functional difference as everything is protected by cgroup_mutex but enables decoupling the locking. Signed-off-by: Tejun Heo <tj@kernel.org> Acked-by: Li Zefan <lizefan@huawei.com>
2013-01-07cpuset: make CPU / memory hotplug propagation asynchronousTejun Heo
cpuset_hotplug_workfn() has been invoking cpuset_propagate_hotplug() directly to propagate hotplug updates to !root cpusets; however, this has the following problems. * cpuset locking is scheduled to be decoupled from cgroup_mutex, cgroup_mutex will be unexported, and cgroup_attach_task() will do cgroup locking internally, so propagation can't synchronously move tasks to a parent cgroup while walking the hierarchy. * We can't use cgroup generic tree iterator because propagation to each cpuset may sleep. With propagation done asynchronously, we can lose the rather ugly cpuset specific iteration. Convert cpuset_propagate_hotplug() to cpuset_propagate_hotplug_workfn() and execute it from newly added cpuset->hotplug_work. The work items are run on an ordered workqueue, so the propagation order is preserved. cpuset_hotplug_workfn() schedules all propagations while holding cgroup_mutex and waits for completion without cgroup_mutex. Each in-flight propagation holds a reference to the cpuset->css. This patch doesn't cause any functional difference. Signed-off-by: Tejun Heo <tj@kernel.org> Acked-by: Li Zefan <lizefan@huawei.com>
2013-01-07cpuset: drop async_rebuild_sched_domains()Tejun Heo
In general, we want to make cgroup_mutex one of the outermost locks and be able to use get_online_cpus() and friends from cgroup methods. With cpuset hotplug made async, get_online_cpus() can now be nested inside cgroup_mutex. Currently, cpuset avoids nesting get_online_cpus() inside cgroup_mutex by bouncing sched_domain rebuilding to a work item. As such nesting is allowed now, remove the workqueue bouncing code and always rebuild sched_domains synchronously. This also nests sched_domains_mutex inside cgroup_mutex, which is intended and should be okay. Signed-off-by: Tejun Heo <tj@kernel.org> Acked-by: Li Zefan <lizefan@huawei.com>
2013-01-07cpuset: don't nest cgroup_mutex inside get_online_cpus()Tejun Heo
CPU / memory hotplug path currently grabs cgroup_mutex from hotplug event notifications. We want to separate cpuset locking from cgroup core and make cgroup_mutex outer to hotplug synchronization so that, among other things, mechanisms which depend on get_online_cpus() can be used from cgroup callbacks. In general, we want to keep cgroup_mutex the outermost lock to minimize locking interactions among different controllers. Convert cpuset_handle_hotplug() to cpuset_hotplug_workfn() and schedule it from the hotplug notifications. As the function can already handle multiple mixed events without any input, converting it to a work function is mostly trivial; however, one complication is that cpuset_update_active_cpus() needs to update sched domains synchronously to reflect an offlined cpu to avoid confusing the scheduler. This is worked around by falling back to the the default single sched domain synchronously before scheduling the actual hotplug work. This makes sched domain rebuilt twice per CPU hotplug event but the operation isn't that heavy and a lot of the second operation would be noop for systems w/ single sched domain, which is the common case. This decouples cpuset hotplug handling from the notification callbacks and there can be an arbitrary delay between the actual event and updates to cpusets. Scheduler and mm can handle it fine but moving tasks out of an empty cpuset may race against writes to the cpuset restoring execution resources which can lead to confusing behavior. Flush hotplug work item from cpuset_write_resmask() to avoid such confusions. v2: Synchronous sched domain rebuilding using the fallback sched domain added. This fixes various issues caused by confused scheduler putting tasks on a dead CPU, including the one reported by Li Zefan. Signed-off-by: Tejun Heo <tj@kernel.org> Acked-by: Li Zefan <lizefan@huawei.com>
2013-01-07cpuset: reorganize CPU / memory hotplug handlingTejun Heo
Reorganize hotplug path to prepare for async hotplug handling. * Both CPU and memory hotplug handlings are collected into a single function - cpuset_handle_hotplug(). It doesn't take any argument but compares the current setttings of top_cpuset against what's actually available to determine what happened. This function directly updates top_cpuset. If there are CPUs or memory nodes which are taken down, cpuset_propagate_hotplug() in invoked on all !root cpusets. * cpuset_propagate_hotplug() is responsible for updating the specified cpuset so that it doesn't include any resource which isn't available to top_cpuset. If no CPU or memory is left after update, all tasks are moved to the nearest ancestor with both resources. * update_tasks_cpumask() and update_tasks_nodemask() are now always called after cpus or mems masks are updated even if the cpuset doesn't have any task. This is for brevity and not expected to have any measureable effect. * cpu_active_mask and N_HIGH_MEMORY are read exactly once per cpuset_handle_hotplug() invocation, all cpusets share the same view of what resources are available, and cpuset_handle_hotplug() can handle multiple resources going up and down. These properties will allow async operation. The reorganization, while drastic, is equivalent and shouldn't cause any behavior difference. This will enable making hotplug handling async and remove get_online_cpus() -> cgroup_mutex nesting. Signed-off-by: Tejun Heo <tj@kernel.org> Acked-by: Li Zefan <lizefan@huawei.com>
2013-01-07cpuset: cleanup cpuset[_can]_attach()Tejun Heo
cpuset_can_attach() prepare global variables cpus_attach and cpuset_attach_nodemask_{to|from} which are used by cpuset_attach(). There is no reason to prepare in cpuset_can_attach(). The same information can be accessed from cpuset_attach(). Move the prepartion logic from cpuset_can_attach() to cpuset_attach() and make the global variables static ones inside cpuset_attach(). With this change, there's no reason to keep cpuset_attach_nodemask_{from|to} global. Move them inside cpuset_attach(). Unfortunately, we need to keep cpus_attach global as it can't be allocated from cpuset_attach(). v2: cpus_attach not converted to cpumask_t as per Li Zefan and Rusty Russell. Signed-off-by: Tejun Heo <tj@kernel.org> Acked-by: Li Zefan <lizefan@huawei.com> Cc: Rusty Russell <rusty@rustcorp.com.au>
2013-01-07cpuset: introduce cpuset_for_each_child()Tejun Heo
Instead of iterating cgroup->children directly, introduce and use cpuset_for_each_child() which wraps cgroup_for_each_child() and performs online check. As it uses the generic iterator, it requires RCU read locking too. As cpuset is currently protected by cgroup_mutex, non-online cpusets aren't visible to all the iterations and this patch currently doesn't make any functional difference. This will be used to de-couple cpuset locking from cgroup core. Signed-off-by: Tejun Heo <tj@kernel.org> Acked-by: Li Zefan <lizefan@huawei.com>
2013-01-07cpuset: introduce CS_ONLINETejun Heo
Add CS_ONLINE which is set from css_online() and cleared from css_offline(). This will enable using generic cgroup iterator while allowing decoupling cpuset from cgroup internal locking. Signed-off-by: Tejun Heo <tj@kernel.org> Acked-by: Li Zefan <lizefan@huawei.com>
2013-01-07cpuset: introduce ->css_on/offline()Tejun Heo
Add cpuset_css_on/offline() and rearrange css init/exit such that, * Allocation and clearing to the default values happen in css_alloc(). Allocation now uses kzalloc(). * Config inheritance and registration happen in css_online(). * css_offline() undoes what css_online() did. * css_free() frees. This doesn't introduce any visible behavior changes. This will help cleaning up locking. Signed-off-by: Tejun Heo <tj@kernel.org> Acked-by: Li Zefan <lizefan@huawei.com>
2013-01-07cpuset: remove fast exit path from remove_tasks_in_empty_cpuset()Tejun Heo
The function isn't that hot, the overhead of missing the fast exit is low, the test itself depends heavily on cgroup internals, and it's gonna be a hindrance when trying to decouple cpuset locking from cgroup core. Remove the fast exit path. Signed-off-by: Tejun Heo <tj@kernel.org> Acked-by: Li Zefan <lizefan@huawei.com>
2013-01-07cpuset: remove unused cpuset_unlock()Tejun Heo
2012-12-12cpuset: use N_MEMORY instead N_HIGH_MEMORYLai Jiangshan
N_HIGH_MEMORY stands for the nodes that has normal or high memory. N_MEMORY stands for the nodes that has any memory. The code here need to handle with the nodes which have memory, we should use N_MEMORY instead. Signed-off-by: Lai Jiangshan <laijs@cn.fujitsu.com> Acked-by: Hillf Danton <dhillf@gmail.com> Signed-off-by: Wen Congyang <wency@cn.fujitsu.com> Cc: Christoph Lameter <cl@linux.com> Cc: Lin Feng <linfeng@cn.fujitsu.com> Cc: David Rientjes <rientjes@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-11-19cgroup, cpuset: remove cgroup_subsys->post_clone()Tejun Heo
Currently CGRP_CPUSET_CLONE_CHILDREN triggers ->post_clone(). Now that clone_children is cpuset specific, there's no reason to have this rather odd option activation mechanism in cgroup core. cpuset can check the flag from its ->css_allocate() and take the necessary action. Move cpuset_post_clone() logic to the end of cpuset_css_alloc() and remove cgroup_subsys->post_clone(). Loosely based on Glauber's "generalize post_clone into post_create" patch. Signed-off-by: Tejun Heo <tj@kernel.org> Original-patch-by: Glauber Costa <glommer@parallels.com> Original-patch: <1351686554-22592-2-git-send-email-glommer@parallels.com> Acked-by: Serge E. Hallyn <serge.hallyn@ubuntu.com> Acked-by: Li Zefan <lizefan@huawei.com> Cc: Glauber Costa <glommer@parallels.com>
2012-11-19cgroup: rename ->create/post_create/pre_destroy/destroy() to ↵Tejun Heo
->css_alloc/online/offline/free() Rename cgroup_subsys css lifetime related callbacks to better describe what their roles are. Also, update documentation. Signed-off-by: Tejun Heo <tj@kernel.org> Acked-by: Li Zefan <lizefan@huawei.com>
2012-07-24cpusets: Remove/update outdated commentsSrivatsa S. Bhat
cpuset_track_online_cpus() is no longer present. So remove the outdated comment and replace it with reference to cpuset_update_active_cpus() which is its equivalent. Also, we don't lack memory hot-unplug anymore. And David Rientjes pointed out how it is dealt with. So update that comment as well. Signed-off-by: Srivatsa S. Bhat <srivatsa.bhat@linux.vnet.ibm.com> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Thomas Gleixner <tglx@linutronix.de> Link: http://lkml.kernel.org/r/20120524141700.3692.98192.stgit@srivatsabhat.in.ibm.com Signed-off-by: Ingo Molnar <mingo@kernel.org>
2012-07-24cpusets, hotplug: Restructure functions that are invoked during hotplugSrivatsa S. Bhat
Separate out the cpuset related handling for CPU/Memory online/offline. This also helps us exploit the most obvious and basic level of optimization that any notification mechanism (CPU/Mem online/offline) has to offer us: "We *know* why we have been invoked. So stop pretending that we are lost, and do only the necessary amount of processing!". And while at it, rename scan_for_empty_cpusets() to scan_cpusets_upon_hotplug(), which is more appropriate considering how it is restructured. Signed-off-by: Srivatsa S. Bhat <srivatsa.bhat@linux.vnet.ibm.com> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Thomas Gleixner <tglx@linutronix.de> Link: http://lkml.kernel.org/r/20120524141650.3692.48637.stgit@srivatsabhat.in.ibm.com Signed-off-by: Ingo Molnar <mingo@kernel.org>
2012-07-24cpusets, hotplug: Implement cpuset tree traversal in a helper functionSrivatsa S. Bhat
At present, the functions that deal with cpusets during CPU/Mem hotplug are quite messy, since a lot of the functionality is mixed up without clear separation. And this takes a toll on optimization as well. For example, the function cpuset_update_active_cpus() is called on both CPU offline and CPU online events; and it invokes scan_for_empty_cpusets(), which makes sense only for CPU offline events. And hence, the current code ends up unnecessarily traversing the cpuset tree during CPU online also. As a first step towards cleaning up those functions, encapsulate the cpuset tree traversal in a helper function, so as to facilitate upcoming changes. Signed-off-by: Srivatsa S. Bhat <srivatsa.bhat@linux.vnet.ibm.com> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Thomas Gleixner <tglx@linutronix.de> Link: http://lkml.kernel.org/r/20120524141635.3692.893.stgit@srivatsabhat.in.ibm.com Signed-off-by: Ingo Molnar <mingo@kernel.org>
2012-07-24CPU hotplug, cpusets, suspend: Don't modify cpusets during suspend/resumeSrivatsa S. Bhat
In the event of CPU hotplug, the kernel modifies the cpusets' cpus_allowed masks as and when necessary to ensure that the tasks belonging to the cpusets have some place (online CPUs) to run on. And regular CPU hotplug is destructive in the sense that the kernel doesn't remember the original cpuset configurations set by the user, across hotplug operations. However, suspend/resume (which uses CPU hotplug) is a special case in which the kernel has the responsibility to restore the system (during resume), to exactly the same state it was in before suspend. In order to achieve that, do the following: 1. Don't modify cpusets during suspend/resume. At all. In particular, don't move the tasks from one cpuset to another, and don't modify any cpuset's cpus_allowed mask. So, simply ignore cpusets during the CPU hotplug operations that are carried out in the suspend/resume path. 2. However, cpusets and sched domains are related. We just want to avoid altering cpusets alone. So, to keep the sched domains updated, build a single sched domain (containing all active cpus) during each of the CPU hotplug operations carried out in s/r path, effectively ignoring the cpusets' cpus_allowed masks. (Since userspace is frozen while doing all this, it will go unnoticed.) 3. During the last CPU online operation during resume, build the sched domains by looking up the (unaltered) cpusets' cpus_allowed masks. That will bring back the system to the same original state as it was in before suspend. Ultimately, this will not only solve the cpuset problem related to suspend resume (ie., restores the cpusets to exactly what it was before suspend, by not touching it at all) but also speeds up suspend/resume because we avoid running cpuset update code for every CPU being offlined/onlined. Signed-off-by: Srivatsa S. Bhat <srivatsa.bhat@linux.vnet.ibm.com> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Thomas Gleixner <tglx@linutronix.de> Link: http://lkml.kernel.org/r/20120524141611.3692.20155.stgit@srivatsabhat.in.ibm.com Signed-off-by: Ingo Molnar <mingo@kernel.org>
2012-05-22Merge branch 'for-3.5' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tj/cgroup Pull cgroup updates from Tejun Heo: "cgroup file type addition / removal is updated so that file types are added and removed instead of individual files so that dynamic file type addition / removal can be implemented by cgroup and used by controllers. blkio controller changes which will come through block tree are dependent on this. Other changes include res_counter cleanup and disallowing kthread / PF_THREAD_BOUND threads to be attached to non-root cgroups. There's a reported bug with the file type addition / removal handling which can lead to oops on cgroup umount. The issue is being looked into. It shouldn't cause problems for most setups and isn't a security concern." Fix up trivial conflict in Documentation/feature-removal-schedule.txt * 'for-3.5' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/cgroup: (21 commits) res_counter: Account max_usage when calling res_counter_charge_nofail() res_counter: Merge res_counter_charge and res_counter_charge_nofail cgroups: disallow attaching kthreadd or PF_THREAD_BOUND threads cgroup: remove cgroup_subsys->populate() cgroup: get rid of populate for memcg cgroup: pass struct mem_cgroup instead of struct cgroup to socket memcg cgroup: make css->refcnt clearing on cgroup removal optional cgroup: use negative bias on css->refcnt to block css_tryget() cgroup: implement cgroup_rm_cftypes() cgroup: introduce struct cfent cgroup: relocate __d_cgrp() and __d_cft() cgroup: remove cgroup_add_file[s]() cgroup: convert memcg controller to the new cftype interface memcg: always create memsw files if CONFIG_CGROUP_MEM_RES_CTLR_SWAP cgroup: convert all non-memcg controllers to the new cftype interface cgroup: relocate cftype and cgroup_subsys definitions in controllers cgroup: merge cft_release_agent cftype array into the base files array cgroup: implement cgroup_add_cftypes() and friends cgroup: build list of all cgroups under a given cgroupfs_root cgroup: move cgroup_clear_directory() call out of cgroup_populate_dir() ...
2012-04-02Merge tag 'for-linus' of git://github.com/rustyrussell/linuxLinus Torvalds
Pull cpumask cleanups from Rusty Russell: "(Somehow forgot to send this out; it's been sitting in linux-next, and if you don't want it, it can sit there another cycle)" I'm a sucker for things that actually delete lines of code. Fix up trivial conflict in arch/arm/kernel/kprobes.c, where Rusty fixed a user of &cpu_online_map to be cpu_online_mask, but that code got deleted by commit b21d55e98ac2 ("ARM: 7332/1: extract out code patch function from kprobes"). * tag 'for-linus' of git://github.com/rustyrussell/linux: cpumask: remove old cpu_*_map. documentation: remove references to cpu_*_map. drivers/cpufreq/db8500-cpufreq: remove references to cpu_*_map. remove references to cpu_*_map in arch/
2012-04-01cgroup: convert all non-memcg controllers to the new cftype interfaceTejun Heo
Convert debug, freezer, cpuset, cpu_cgroup, cpuacct, net_prio, blkio, net_cls and device controllers to use the new cftype based interface. Termination entry is added to cftype arrays and populate callbacks are replaced with cgroup_subsys->base_cftypes initializations. This is functionally identical transformation. There shouldn't be any visible behavior change. memcg is rather special and will be converted separately. Signed-off-by: Tejun Heo <tj@kernel.org> Acked-by: Li Zefan <lizf@cn.fujitsu.com> Cc: Paul Menage <paul@paulmenage.org> Cc: Ingo Molnar <mingo@elte.hu> Cc: Peter Zijlstra <peterz@infradead.org> Cc: "David S. Miller" <davem@davemloft.net> Cc: Vivek Goyal <vgoyal@redhat.com>
2012-03-29Merge branch 'sched-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull scheduler fixes from Ingo Molnar. * 'sched-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: cpusets: Remove an unused variable sched/rt: Improve pick_next_highest_task_rt() sched: Fix select_fallback_rq() vs cpu_active/cpu_online sched/x86/smp: Do not enable IRQs over calibrate_delay() sched: Fix compiler warning about declared inline after use MAINTAINERS: Update email address for SCHEDULER and PERF EVENTS
2012-03-29documentation: remove references to cpu_*_map.Rusty Russell
This has been obsolescent for a while, fix documentation and misc comments. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2012-03-28cpusets: Remove an unused variableDan Carpenter
We don't use "cpu" any more after 2baab4e904 "sched: Fix select_fallback_rq() vs cpu_active/cpu_online". Signed-off-by: Dan Carpenter <dan.carpenter@oracle.com> Cc: Paul Menage <paul@paulmenage.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Link: http://lkml.kernel.org/r/20120328104608.GD29022@elgon.mountain Signed-off-by: Ingo Molnar <mingo@kernel.org>
2012-03-27sched: Fix select_fallback_rq() vs cpu_active/cpu_onlinePeter Zijlstra
Commit 5fbd036b55 ("sched: Cleanup cpu_active madness"), which was supposed to finally sort the cpu_active mess, instead uncovered more. Since CPU_STARTING is ran before setting the cpu online, there's a (small) window where the cpu has active,!online. If during this time there's a wakeup of a task that used to reside on that cpu select_task_rq() will use select_fallback_rq() to compute an alternative cpu to run on since we find !online. select_fallback_rq() however will compute the new cpu against cpu_active, this means that it can return the same cpu it started out with, the !online one, since that cpu is in fact marked active. This results in us trying to scheduling a task on an offline cpu and triggering a WARN in the IPI code. The solution proposed by Chuansheng Liu of setting cpu_active in set_cpu_online() is buggy, firstly not all archs actually use set_cpu_online(), secondly, not all archs call set_cpu_online() with IRQs disabled, this means we would introduce either the same race or the race from fd8a7de17 ("x86: cpu-hotplug: Prevent softirq wakeup on wrong CPU") -- albeit much narrower. [ By setting online first and active later we have a window of online,!active, fresh and bound kthreads have task_cpu() of 0 and since cpu0 isn't in tsk_cpus_allowed() we end up in select_fallback_rq() which excludes !active, resulting in a reset of ->cpus_allowed and the thread running all over the place. ] The solution is to re-work select_fallback_rq() to require active _and_ online. This makes the active,!online case work as expected, OTOH archs running CPU_STARTING after setting online are now vulnerable to the issue from fd8a7de17 -- these are alpha and blackfin. Reported-by: Chuansheng Liu <chuansheng.liu@intel.com> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Mike Frysinger <vapier@gentoo.org> Cc: linux-alpha@vger.kernel.org Link: http://lkml.kernel.org/n/tip-hubqk1i10o4dpvlm06gq7v6j@git.kernel.org Signed-off-by: Ingo Molnar <mingo@kernel.org>
