path: root/kernel/cred.c
2011-05-27Merge branch 'docs-move' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rdunlap/linux-docs * 'docs-move' of git://git.kernel.org/pub/scm/linux/kernel/git/rdunlap/linux-docs: Create Documentation/security/, move LSM-, credentials-, and keys-related files from Documentation/ to Documentation/security/, add Documentation/security/00-INDEX, and update all occurrences of Documentation/<moved_file> to Documentation/security/<moved_file>.
2011-05-19Create Documentation/security/,Randy Dunlap
2011-05-19Merge branch 'master' into nextJames Morris
Conflicts: include/linux/capability.h Manually resolve merge conflict w/ thanks to Stephen Rothwell. Signed-off-by: James Morris <jmorris@namei.org>
2011-05-13Cache user_ns in struct credSerge E. Hallyn
If !CONFIG_USERNS, have current_user_ns() defined to (&init_user_ns). Get rid of _current_user_ns. This requires nsown_capable() to be defined in capability.c rather than as static inline in capability.h, so do that. Request_key needs init_user_ns defined at current_user_ns if !CONFIG_USERNS, so forward-declare that in cred.h if !CONFIG_USERNS at current_user_ns() define. Compile-tested with and without CONFIG_USERNS. Signed-off-by: Serge E. Hallyn <serge.hallyn@canonical.com> [ This makes a huge performance difference for acl_permission_check(), up to 30%. And that is one of the hottest kernel functions for loads that are pathname-lookup heavy. ] Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-04-04capabilities: delete all CAP_INIT macrosEric Paris
The CAP_INIT macros of INH, BSET, and EFF made sense at one point in time, but now days they aren't helping. Just open code the logic in the init_cred. Signed-off-by: Eric Paris <eparis@redhat.com> Acked-by: David Howells <dhowells@redhat.com> Signed-off-by: James Morris <jmorris@namei.org>
2011-03-23userns: security: make capabilities relative to the user namespaceSerge E. Hallyn
- Introduce ns_capable to test for a capability in a non-default user namespace. - Teach cap_capable to handle capabilities in a non-default user namespace. The motivation is to get to the unprivileged creation of new namespaces. It looks like this gets us 90% of the way there, with only potential uid confusion issues left. I still need to handle getting all caps after creation but otherwise I think I have a good starter patch that achieves all of your goals. Changelog: 11/05/2010: [serge] add apparmor 12/14/2010: [serge] fix capabilities to created user namespaces Without this, if user serge creates a user_ns, he won't have capabilities to the user_ns he created. THis is because we were first checking whether his effective caps had the caps he needed and returning -EPERM if not, and THEN checking whether he was the creator. Reverse those checks. 12/16/2010: [serge] security_real_capable needs ns argument in !security case 01/11/2011: [serge] add task_ns_capable helper 01/11/2011: [serge] add nsown_capable() helper per Bastian Blank suggestion 02/16/2011: [serge] fix a logic bug: the root user is always creator of init_user_ns, but should not always have capabilities to it! Fix the check in cap_capable(). 02/21/2011: Add the required user_ns parameter to security_capable, fixing a compile failure. 02/23/2011: Convert some macros to functions as per akpm comments. Some couldn't be converted because we can't easily forward-declare them (they are inline if !SECURITY, extern if SECURITY). Add a current_user_ns function so we can use it in capability.h without #including cred.h. Move all forward declarations together to the top of the #ifdef __KERNEL__ section, and use kernel-doc format. 02/23/2011: Per dhowells, clean up comment in cap_capable(). 02/23/2011: Per akpm, remove unreachable 'return -EPERM' in cap_capable. (Original written and signed off by Eric; latest, modified version acked by him) [akpm@linux-foundation.org: fix build] [akpm@linux-foundation.org: export current_user_ns() for ecryptfs] [serge.hallyn@canonical.com: remove unneeded extra argument in selinux's task_has_capability] Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: Serge E. Hallyn <serge.hallyn@canonical.com> Acked-by: "Eric W. Biederman" <ebiederm@xmission.com> Acked-by: Daniel Lezcano <daniel.lezcano@free.fr> Acked-by: David Howells <dhowells@redhat.com> Cc: James Morris <jmorris@namei.org> Signed-off-by: Serge E. Hallyn <serge.hallyn@canonical.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-02-16Merge commit 'v2.6.38-rc5' into core/lockingIngo Molnar
Merge reason: pick up upstream fixes. Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-02-07CRED: Fix memory and refcount leaks upon security_prepare_creds() failureTetsuo Handa
In prepare_kernel_cred() since 2.6.29, put_cred(new) is called without assigning new->usage when security_prepare_creds() returned an error. As a result, memory for new and refcount for new->{user,group_info,tgcred} are leaked because put_cred(new) won't call __put_cred() unless old->usage == 1. Fix these leaks by assigning new->usage (and new->subscribers which was added in 2.6.32) before calling security_prepare_creds(). Signed-off-by: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp> Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-02-07CRED: Fix BUG() upon security_cred_alloc_blank() failureTetsuo Handa
In cred_alloc_blank() since 2.6.32, abort_creds(new) is called with new->security == NULL and new->magic == 0 when security_cred_alloc_blank() returns an error. As a result, BUG() will be triggered if SELinux is enabled or CONFIG_DEBUG_CREDENTIALS=y. If CONFIG_DEBUG_CREDENTIALS=y, BUG() is called from __invalid_creds() because cred->magic == 0. Failing that, BUG() is called from selinux_cred_free() because selinux_cred_free() is not expecting cred->security == NULL. This does not affect smack_cred_free(), tomoyo_cred_free() or apparmor_cred_free(). Fix these bugs by (1) Set new->magic before calling security_cred_alloc_blank(). (2) Handle null cred->security in creds_are_invalid() and selinux_cred_free(). Signed-off-by: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp> Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-01-27cred: Replace deprecated spinlock initializationThomas Gleixner
SPIN_LOCK_UNLOCK is deprecated. Use the lockdep capable variant instead. Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2010-10-27signals: move cred_guard_mutex from task_struct to signal_structKOSAKI Motohiro
Oleg Nesterov pointed out we have to prevent multiple-threads-inside-exec itself and we can reuse ->cred_guard_mutex for it. Yes, concurrent execve() has no worth. Let's move ->cred_guard_mutex from task_struct to signal_struct. It naturally prevent multiple-threads-inside-exec. Signed-off-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Reviewed-by: Oleg Nesterov <oleg@redhat.com> Acked-by: Roland McGrath <roland@redhat.com> Acked-by: David Howells <dhowells@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-08-12Add a dummy printk function for the maintenance of unused printksDavid Howells
Add a dummy printk function for the maintenance of unused printks through gcc format checking, and also so that side-effect checking is maintained too. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-07-29CRED: Fix get_task_cred() and task_state() to not resurrect dead credentialsDavid Howells
It's possible for get_task_cred() as it currently stands to 'corrupt' a set of credentials by incrementing their usage count after their replacement by the task being accessed. What happens is that get_task_cred() can race with commit_creds(): TASK_1 TASK_2 RCU_CLEANER -->get_task_cred(TASK_2) rcu_read_lock() __cred = __task_cred(TASK_2) -->commit_creds() old_cred = TASK_2->real_cred TASK_2->real_cred = ... put_cred(old_cred) call_rcu(old_cred) [__cred->usage == 0] get_cred(__cred) [__cred->usage == 1] rcu_read_unlock() -->put_cred_rcu() [__cred->usage == 1] panic() However, since a tasks credentials are generally not changed very often, we can reasonably make use of a loop involving reading the creds pointer and using atomic_inc_not_zero() to attempt to increment it if it hasn't already hit zero. If successful, we can safely return the credentials in the knowledge that, even if the task we're accessing has released them, they haven't gone to the RCU cleanup code. We then change task_state() in procfs to use get_task_cred() rather than calling get_cred() on the result of __task_cred(), as that suffers from the same problem. Without this change, a BUG_ON in __put_cred() or in put_cred_rcu() can be tripped when it is noticed that the usage count is not zero as it ought to be, for example: kernel BUG at kernel/cred.c:168! invalid opcode: 0000 [#1] SMP last sysfs file: /sys/kernel/mm/ksm/run CPU 0 Pid: 2436, comm: master Not tainted 2.6.33.3-85.fc13.x86_64 #1 0HR330/OptiPlex 745 RIP: 0010:[<ffffffff81069881>] [<ffffffff81069881>] __put_cred+0xc/0x45 RSP: 0018:ffff88019e7e9eb8 EFLAGS: 00010202 RAX: 0000000000000001 RBX: ffff880161514480 RCX: 00000000ffffffff RDX: 00000000ffffffff RSI: ffff880140c690c0 RDI: ffff880140c690c0 RBP: ffff88019e7e9eb8 R08: 00000000000000d0 R09: 0000000000000000 R10: 0000000000000001 R11: 0000000000000040 R12: ffff880140c690c0 R13: ffff88019e77aea0 R14: 00007fff336b0a5c R15: 0000000000000001 FS: 00007f12f50d97c0(0000) GS:ffff880007400000(0000) knlGS:0000000000000000 CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033 CR2: 00007f8f461bc000 CR3: 00000001b26ce000 CR4: 00000000000006f0 DR0: 0000000000000000 DR1: 0000000000000000 DR2: 0000000000000000 DR3: 0000000000000000 DR6: 00000000ffff0ff0 DR7: 0000000000000400 Process master (pid: 2436, threadinfo ffff88019e7e8000, task ffff88019e77aea0) Stack: ffff88019e7e9ec8 ffffffff810698cd ffff88019e7e9ef8 ffffffff81069b45 <0> ffff880161514180 ffff880161514480 ffff880161514180 0000000000000000 <0> ffff88019e7e9f28 ffffffff8106aace 0000000000000001 0000000000000246 Call Trace: [<ffffffff810698cd>] put_cred+0x13/0x15 [<ffffffff81069b45>] commit_creds+0x16b/0x175 [<ffffffff8106aace>] set_current_groups+0x47/0x4e [<ffffffff8106ac89>] sys_setgroups+0xf6/0x105 [<ffffffff81009b02>] system_call_fastpath+0x16/0x1b Code: 48 8d 71 ff e8 7e 4e 15 00 85 c0 78 0b 8b 75 ec 48 89 df e8 ef 4a 15 00 48 83 c4 18 5b c9 c3 55 8b 07 8b 07 48 89 e5 85 c0 74 04 <0f> 0b eb fe 65 48 8b 04 25 00 cc 00 00 48 3b b8 58 04 00 00 75 RIP [<ffffffff81069881>] __put_cred+0xc/0x45 RSP <ffff88019e7e9eb8> ---[ end trace df391256a100ebdd ]--- Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Jiri Olsa <jolsa@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-05-27umh: creds: kill subprocess_info->cred logicOleg Nesterov
Now that nobody ever changes subprocess_info->cred we can kill this member and related code. ____call_usermodehelper() always runs in the context of freshly forked kernel thread, it has the proper ->cred copied from its parent kthread, keventd. Signed-off-by: Oleg Nesterov <oleg@redhat.com> Acked-by: Neil Horman <nhorman@tuxdriver.com> Acked-by: David Howells <dhowells@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-05-20Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/security-testing-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/security-testing-2.6: (61 commits) KEYS: Return more accurate error codes LSM: Add __init to fixup function. TOMOYO: Add pathname grouping support. ima: remove ACPI dependency TPM: ACPI/PNP dependency removal security/selinux/ss: Use kstrdup TOMOYO: Use stack memory for pending entry. Revert "ima: remove ACPI dependency" Revert "TPM: ACPI/PNP dependency removal" KEYS: Do preallocation for __key_link() TOMOYO: Use mutex_lock_interruptible. KEYS: Better handling of errors from construct_alloc_key() KEYS: keyring_serialise_link_sem is only needed for keyring->keyring links TOMOYO: Use GFP_NOFS rather than GFP_KERNEL. ima: remove ACPI dependency TPM: ACPI/PNP dependency removal selinux: generalize disabling of execmem for plt-in-heap archs LSM Audit: rename LSM_AUDIT_NO_AUDIT to LSM_AUDIT_DATA_NONE CRED: Holding a spinlock does not imply the holding of RCU read lock SMACK: Don't #include Ext2 headers ...
2010-05-07Merge commit 'v2.6.34-rc6' into sched/coreIngo Molnar
2010-05-06Merge branch 'master' into nextJames Morris
2010-04-22CRED: Fix a race in creds_are_invalid() in credentials debuggingDavid Howells
creds_are_invalid() reads both cred->usage and cred->subscribers and then compares them to make sure the number of processes subscribed to a cred struct never exceeds the refcount of that cred struct. The problem is that this can cause a race with both copy_creds() and exit_creds() as the two counters, whilst they are of atomic_t type, are only atomic with respect to themselves, and not atomic with respect to each other. This means that if creds_are_invalid() can read the values on one CPU whilst they're being modified on another CPU, and so can observe an evolving state in which the subscribers count now is greater than the usage count a moment before. Switching the order in which the counts are read cannot help, so the thing to do is to remove that particular check. I had considered rechecking the values to see if they're in flux if the test fails, but I can't guarantee they won't appear the same, even if they've changed several times in the meantime. Note that this can only happen if CONFIG_DEBUG_CREDENTIALS is enabled. The problem is only likely to occur with multithreaded programs, and can be tested by the tst-eintr1 program from glibc's "make check". The symptoms look like: CRED: Invalid credentials CRED: At include/linux/cred.h:240 CRED: Specified credentials: ffff88003dda5878 [real][eff] CRED: ->magic=43736564, put_addr=(null) CRED: ->usage=766, subscr=766 CRED: ->*uid = { 0,0,0,0 } CRED: ->*gid = { 0,0,0,0 } CRED: ->security is ffff88003d72f538 CRED: ->security {359, 359} ------------[ cut here ]------------ kernel BUG at kernel/cred.c:850! ... RIP: 0010:[<ffffffff81049889>] [<ffffffff81049889>] __invalid_creds+0x4e/0x52 ... Call Trace: [<ffffffff8104a37b>] copy_creds+0x6b/0x23f Note the ->usage=766 and subscr=766. The values appear the same because they've been re-read since the check was made. Reported-by: Roland McGrath <roland@redhat.com> Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: James Morris <jmorris@namei.org>
2010-04-21CRED: Fix double free in prepare_usermodehelper_creds() error handlingDavid Howells
Patch 570b8fb505896e007fd3bb07573ba6640e51851d: Author: Mathieu Desnoyers <mathieu.desnoyers@efficios.com> Date: Tue Mar 30 00:04:00 2010 +0100 Subject: CRED: Fix memory leak in error handling attempts to fix a memory leak in the error handling by making the offending return statement into a jump down to the bottom of the function where a kfree(tgcred) is inserted. This is, however, incorrect, as it does a kfree() after doing put_cred() if security_prepare_creds() fails. That will result in a double free if 'error' is jumped to as put_cred() will also attempt to free the new tgcred record by virtue of it being pointed to by the new cred record. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: James Morris <jmorris@namei.org>
2010-04-15Merge branch 'linus' into sched/coreIngo Molnar
Merge reason: merge the latest fixes, update to -rc4. Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-04-12security: remove dead hook cred_commitEric Paris
Unused hook. Remove. Signed-off-by: Eric Paris <eparis@redhat.com> Signed-off-by: James Morris <jmorris@namei.org>
2010-04-05Merge branch 'master' into export-slabhTejun Heo
2010-04-02sched: Remove remaining USER_SCHED codeLi Zefan
This is left over from commit 7c9414385e ("sched: Remove USER_SCHED"") Signed-off-by: Li Zefan <lizf@cn.fujitsu.com> Acked-by: Dhaval Giani <dhaval.giani@gmail.com> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: David Howells <dhowells@redhat.com> LKML-Reference: <4BA9A05F.7010407@cn.fujitsu.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-03-30CRED: Fix memory leak in error handlingMathieu Desnoyers
Fix a memory leak on an OOM condition in prepare_usermodehelper_creds(). Signed-off-by: Mathieu Desnoyers <mathieu.desnoyers@efficios.com> Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: James Morris <jmorris@namei.org>
2010-02-03kernel/cred.c: use kmem_cache_freeJulia Lawall
Free memory allocated using kmem_cache_zalloc using kmem_cache_free rather than kfree. The semantic patch that makes this change is as follows: (http://coccinelle.lip6.fr/) // <smpl> @@ expression x,E,c; @@ x = \(kmem_cache_alloc\|kmem_cache_zalloc\|kmem_cache_alloc_node\)(c,...) ... when != x = E when != &x ?-kfree(x) +kmem_cache_free(c,x) // </smpl> Signed-off-by: Julia Lawall <julia@diku.dk> Acked-by: David Howells <dhowells@redhat.com> Cc: James Morris <jmorris@namei.org> Cc: Steve Dickson <steved@redhat.com> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: James Morris <jmorris@namei.org>
2009-09-23creds_are_invalid() needs to be exported for use by modules:Randy Dunlap
ERROR: "creds_are_invalid" [fs/cachefiles/cachefiles.ko] undefined! Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Cc: David Howells <dhowells@redhat.com> Cc: James Morris <jmorris@namei.org> Cc: Serge Hallyn <serue@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: James Morris <jmorris@namei.org>
2009-09-23include/linux/cred.h: fix buildAndrew Morton
mips allmodconfig: include/linux/cred.h: In function `creds_are_invalid': include/linux/cred.h:187: error: `PAGE_SIZE' undeclared (first use in this function) include/linux/cred.h:187: error: (Each undeclared identifier is reported only once include/linux/cred.h:187: error: for each function it appears in.) Fixes commit b6dff3ec5e116e3af6f537d4caedcad6b9e5082a Author: David Howells <dhowells@redhat.com> AuthorDate: Fri Nov 14 10:39:16 2008 +1100 Commit: James Morris <jmorris@namei.org> CommitDate: Fri Nov 14 10:39:16 2008 +1100 CRED: Separate task security context from task_struct I think. It's way too large to be inlined anyway. Dunno if this needs an EXPORT_SYMBOL() yet. Cc: David Howells <dhowells@redhat.com> Cc: James Morris <jmorris@namei.org> Cc: Serge Hallyn <serue@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Acked-by: David Howells <dhowells@redhat.com> Signed-off-by: James Morris <jmorris@namei.org>
2009-09-15CRED: Allow put_cred() to cope with a NULL groups listDavid Howells
put_cred() will oops if given a NULL groups list, but that is now possible with the existence of cred_alloc_blank(), as used in keyctl_session_to_parent(). Added in commit: commit ee18d64c1f632043a02e6f5ba5e045bb26a5465f Author: David Howells <dhowells@redhat.com> Date: Wed Sep 2 09:14:21 2009 +0100 KEYS: Add a keyctl to install a process's session keyring on its parent [try #6] Reported-by: Marc Dionne <marc.c.dionne@gmail.com> Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: James Morris <jmorris@namei.org>
2009-09-02KEYS: Add a keyctl to install a process's session keyring on its parent [try #6]David Howells
Add a keyctl to install a process's session keyring onto its parent. This replaces the parent's session keyring. Because the COW credential code does not permit one process to change another process's credentials directly, the change is deferred until userspace next starts executing again. Normally this will be after a wait*() syscall. To support this, three new security hooks have been provided: cred_alloc_blank() to allocate unset security creds, cred_transfer() to fill in the blank security creds and key_session_to_parent() - which asks the LSM if the process may replace its parent's session keyring. The replacement may only happen if the process has the same ownership details as its parent, and the process has LINK permission on the session keyring, and the session keyring is owned by the process, and the LSM permits it. Note that this requires alteration to each architecture's notify_resume path. This has been done for all arches barring blackfin, m68k* and xtensa, all of which need assembly alteration to support TIF_NOTIFY_RESUME. This allows the replacement to be performed at the point the parent process resumes userspace execution. This allows the userspace AFS pioctl emulation to fully emulate newpag() and the VIOCSETTOK and VIOCSETTOK2 pioctls, all of which require the ability to alter the parent process's PAG membership. However, since kAFS doesn't use PAGs per se, but rather dumps the keys into the session keyring, the session keyring of the parent must be replaced if, for example, VIOCSETTOK is passed the newpag flag. This can be tested with the following program: #include <stdio.h> #include <stdlib.h> #include <keyutils.h> #define KEYCTL_SESSION_TO_PARENT 18 #define OSERROR(X, S) do { if ((long)(X) == -1) { perror(S); exit(1); } } while(0) int main(int argc, char **argv) { key_serial_t keyring, key; long ret; keyring = keyctl_join_session_keyring(argv[1]); OSERROR(keyring, "keyctl_join_session_keyring"); key = add_key("user", "a", "b", 1, keyring); OSERROR(key, "add_key"); ret = keyctl(KEYCTL_SESSION_TO_PARENT); OSERROR(ret, "KEYCTL_SESSION_TO_PARENT"); return 0; } Compiled and linked with -lkeyutils, you should see something like: [dhowells@andromeda ~]$ keyctl show Session Keyring -3 --alswrv 4043 4043 keyring: _ses 355907932 --alswrv 4043 -1 \_ keyring: _uid.4043 [dhowells@andromeda ~]$ /tmp/newpag [dhowells@andromeda ~]$ keyctl show Session Keyring -3 --alswrv 4043 4043 keyring: _ses 1055658746 --alswrv 4043 4043 \_ user: a [dhowells@andromeda ~]$ /tmp/newpag hello [dhowells@andromeda ~]$ keyctl show Session Keyring -3 --alswrv 4043 4043 keyring: hello 340417692 --alswrv 4043 4043 \_ user: a Where the test program creates a new session keyring, sticks a user key named 'a' into it and then installs it on its parent. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: James Morris <jmorris@namei.org>
2009-09-02CRED: Add some configurable debugging [try #6]David Howells
Add a config option (CONFIG_DEBUG_CREDENTIALS) to turn on some debug checking for credential management. The additional code keeps track of the number of pointers from task_structs to any given cred struct, and checks to see that this number never exceeds the usage count of the cred struct (which includes all references, not just those from task_structs). Furthermore, if SELinux is enabled, the code also checks that the security pointer in the cred struct is never seen to be invalid. This attempts to catch the bug whereby inode_has_perm() faults in an nfsd kernel thread on seeing cred->security be a NULL pointer (it appears that the credential struct has been previously released): http://www.kerneloops.org/oops.php?number=252883 Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: James Morris <jmorris@namei.org>
2009-05-11CRED: Rename cred_exec_mutex to reflect that it's a guard against ptraceDavid Howells
Rename cred_exec_mutex to reflect that it's a guard against foreign intervention on a process's credential state, such as is made by ptrace(). The attachment of a debugger to a process affects execve()'s calculation of the new credential state - _and_ also setprocattr()'s calculation of that state. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: James Morris <jmorris@namei.org>
2009-01-09Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/security-testing-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/security-testing-2.6: CRED: Fix commit_creds() on a process that has no mm
2009-01-09CRED: Must initialise the new creds in prepare_kernel_cred()David Howells
The newly allocated creds in prepare_kernel_cred() must be initialised before get_uid() and get_group_info() can access them. They should be copied from the old credentials. Reported-by: Steve Dickson <steved@redhat.com> Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Steve Dickson <steved@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-09CRED: Missing put_cred() in prepare_kernel_cred()David Howells
Missing put_cred() in the error handling path of prepare_kernel_cred(). Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Steve Dickson <steved@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-08CRED: Fix commit_creds() on a process that has no mmDavid Howells
Fix commit_creds()'s handling of a process that has no mm (such as one that is calling or has called daemonize()). commit_creds() should check to see if task->mm is not NULL before calling set_dumpable() on it. Reported-by: Jiri Slaby <jirislaby@gmail.com> Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: James Morris <jmorris@namei.org>
2008-11-24User namespaces: set of cleanups (v2)Serge Hallyn
The user_ns is moved from nsproxy to user_struct, so that a struct cred by itself is sufficient to determine access (which it otherwise would not be). Corresponding ecryptfs fixes (by David Howells) are here as well. Fix refcounting. The following rules now apply: 1. The task pins the user struct. 2. The user struct pins its user namespace. 3. The user namespace pins the struct user which created it. User namespaces are cloned during copy_creds(). Unsharing a new user_ns is no longer possible. (We could re-add that, but it'll cause code duplication and doesn't seem useful if PAM doesn't need to clone user namespaces). When a user namespace is created, its first user (uid 0) gets empty keyrings and a clean group_info. This incorporates a previous patch by David Howells. Here is his original patch description: >I suggest adding the attached incremental patch. It makes the following >changes: > > (1) Provides a current_user_ns() macro to wrap accesses to current's user > namespace. > > (2) Fixes eCryptFS. > > (3) Renames create_new_userns() to create_user_ns() to be more consistent > with the other associated functions and because the 'new' in the name is > superfluous. > > (4) Moves the argument and permission checks made for CLONE_NEWUSER to the > beginning of do_fork() so that they're done prior to making any attempts > at allocation. > > (5) Calls create_user_ns() after prepare_creds(), and gives it the new creds > to fill in rather than have it return the new root user. I don't imagine > the new root user being used for anything other than filling in a cred > struct. > > This also permits me to get rid of a get_uid() and a free_uid(), as the > reference the creds were holding on the old user_struct can just be > transferred to the new namespace's creator pointer. > > (6) Makes create_user_ns() reset the UIDs and GIDs of the creds under > preparation rather than doing it in copy_creds(). > >David >Signed-off-by: David Howells <dhowells@redhat.com> Changelog: Oct 20: integrate dhowells comments 1. leave thread_keyring alone 2. use current_user_ns() in set_user() Signed-off-by: Serge Hallyn <serue@us.ibm.com>
2008-11-14CRED: Allow kernel services to override LSM settings for task actionsDavid Howells
Allow kernel services to override LSM settings appropriate to the actions performed by a task by duplicating a set of credentials, modifying it and then using task_struct::cred to point to it when performing operations on behalf of a task. This is used, for example, by CacheFiles which has to transparently access the cache on behalf of a process that thinks it is doing, say, NFS accesses with a potentially inappropriate (with respect to accessing the cache) set of credentials. This patch provides two LSM hooks for modifying a task security record: (*) security_kernel_act_as() which allows modification of the security datum with which a task acts on other objects (most notably files). (*) security_kernel_create_files_as() which allows modification of the security datum that is used to initialise the security data on a file that a task creates. The patch also provides four new credentials handling functions, which wrap the LSM functions: (1) prepare_kernel_cred() Prepare a set of credentials for a kernel service to use, based either on a daemon's credentials or on init_cred. All the keyrings are cleared. (2) set_security_override() Set the LSM security ID in a set of credentials to a specific security context, assuming permission from the LSM policy. (3) set_security_override_from_ctx() As (2), but takes the security context as a string. (4) set_create_files_as() Set the file creation LSM security ID in a set of credentials to be the same as that on a particular inode. Signed-off-by: Casey Schaufler <casey@schaufler-ca.com> [Smack changes] Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: James Morris <jmorris@namei.org>
2008-11-14CRED: Differentiate objective and effective subjective credentials on a taskDavid Howells
Differentiate the objective and real subjective credentials from the effective subjective credentials on a task by introducing a second credentials pointer into the task_struct. task_struct::real_cred then refers to the objective and apparent real subjective credentials of a task, as perceived by the other tasks in the system. task_struct::cred then refers to the effective subjective credentials of a task, as used by that task when it's actually running. These are not visible to the other tasks in the system. __task_cred(task) then refers to the objective/real credentials of the task in question. current_cred() refers to the effective subjective credentials of the current task. prepare_creds() uses the objective creds as a base and commit_creds() changes both pointers in the task_struct (indeed commit_creds() requires them to be the same). override_creds() and revert_creds() change the subjective creds pointer only, and the former returns the old subjective creds. These are used by NFSD, faccessat() and do_coredump(), and will by used by CacheFiles. In SELinux, current_has_perm() is provided as an alternative to task_has_perm(). This uses the effective subjective context of current, whereas task_has_perm() uses the objective/real context of the subject. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: James Morris <jmorris@namei.org>
2008-11-14CRED: DocumentationDavid Howells
Document credentials and the new credentials API. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: James Morris <jmorris@namei.org>
2008-11-14CRED: Make execve() take advantage of copy-on-write credentialsDavid Howells
Make execve() take advantage of copy-on-write credentials, allowing it to set up the credentials in advance, and then commit the whole lot after the point of no return. This patch and the preceding patches have been tested with the LTP SELinux testsuite. This patch makes several logical sets of alteration: (1) execve(). The credential bits from struct linux_binprm are, for the most part, replaced with a single credentials pointer (bprm->cred). This means that all the creds can be calculated in advance and then applied at the point of no return with no possibility of failure. I would like to replace bprm->cap_effective with: cap_isclear(bprm->cap_effective) but this seems impossible due to special behaviour for processes of pid 1 (they always retain their parent's capability masks where normally they'd be changed - see cap_bprm_set_creds()). The following sequence of events now happens: (a) At the start of do_execve, the current task's cred_exec_mutex is locked to prevent PTRACE_ATTACH from obsoleting the calculation of creds that we make. (a) prepare_exec_creds() is then called to make a copy of the current task's credentials and prepare it. This copy is then assigned to bprm->cred. This renders security_bprm_alloc() and security_bprm_free() unnecessary, and so they've been removed. (b) The determination of unsafe execution is now performed immediately after (a) rather than later on in the code. The result is stored in bprm->unsafe for future reference. (c) prepare_binprm() is called, possibly multiple times. (i) This applies the result of set[ug]id binaries to the new creds attached to bprm->cred. Personality bit clearance is recorded, but now deferred on the basis that the exec procedure may yet fail. (ii) This then calls the new security_bprm_set_creds(). This should calculate the new LSM and capability credentials into *bprm->cred. This folds together security_bprm_set() and parts of security_bprm_apply_creds() (these two have been removed). Anything that might fail must be done at this point. (iii) bprm->cred_prepared is set to 1. bprm->cred_prepared is 0 on the first pass of the security calculations, and 1 on all subsequent passes. This allows SELinux in (ii) to base its calculations only on the initial script and not on the interpreter. (d) flush_old_exec() is called to commit the task to execution. This performs the following steps with regard to credentials: (i) Clear pdeath_signal and set dumpable on certain circumstances that may not be covered by commit_creds(). (ii) Clear any bits in current->personality that were deferred from (c.i). (e) install_exec_creds() [compute_creds() as was] is called to install the new credentials. This performs the following steps with regard to credentials: (i) Calls security_bprm_committing_creds() to apply any security requirements, such as flushing unauthorised files in SELinux, that must be done before the credentials are changed. This is made up of bits of security_bprm_apply_creds() and security_bprm_post_apply_creds(), both of which have been removed. This function is not allowed to fail; anything that might fail must have been done in (c.ii). (ii) Calls commit_creds() to apply the new credentials in a single assignment (more or less). Possibly pdeath_signal and dumpable should be part of struct creds. (iii) Unlocks the task's cred_replace_mutex, thus allowing PTRACE_ATTACH to take place. (iv) Clears The bprm->cred pointer as the credentials it was holding are now immutable. (v) Calls security_bprm_committed_creds() to apply any security alterations that must be done after the creds have been changed. SELinux uses this to flush signals and signal handlers. (f) If an error occurs before (d.i), bprm_free() will call abort_creds() to destroy the proposed new credentials and will then unlock cred_replace_mutex. No changes to the credentials will have been made. (2) LSM interface. A number of functions have been changed, added or removed: (*) security_bprm_alloc(), ->bprm_alloc_security() (*) security_bprm_free(), ->bprm_free_security() Removed in favour of preparing new credentials and modifying those. (*) security_bprm_apply_creds(), ->bprm_apply_creds() (*) security_bprm_post_apply_creds(), ->bprm_post_apply_creds() Removed; split between security_bprm_set_creds(), security_bprm_committing_creds() and security_bprm_committed_creds(). (*) security_bprm_set(), ->bprm_set_security() Removed; folded into security_bprm_set_creds(). (*) security_bprm_set_creds(), ->bprm_set_creds() New. The new credentials in bprm->creds should be checked and set up as appropriate. bprm->cred_prepared is 0 on the first call, 1 on the second and subsequent calls. (*) security_bprm_committing_creds(), ->bprm_committing_creds() (*) security_bprm_committed_creds(), ->bprm_committed_creds() New. Apply the security effects of the new credentials. This includes closing unauthorised files in SELinux. This function may not fail. When the former is called, the creds haven't yet been applied to the process; when the latter is called, they have. The former may access bprm->cred, the latter may not. (3) SELinux. SELinux has a number of changes, in addition to those to support the LSM interface changes mentioned above: (a) The bprm_security_struct struct has been removed in favour of using the credentials-under-construction approach. (c) flush_unauthorized_files() now takes a cred pointer and passes it on to inode_has_perm(), file_has_perm() and dentry_open(). Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: James Morris <jmorris@namei.org> Acked-by: Serge Hallyn <serue@us.ibm.com> Signed-off-by: James Morris <jmorris@namei.org>
2008-11-14CRED: Inaugurate COW credentialsDavid Howells
Inaugurate copy-on-write credentials management. This uses RCU to manage the credentials pointer in the task_struct with respect to accesses by other tasks. A process may only modify its own credentials, and so does not need locking to access or modify its own credentials. A mutex (cred_replace_mutex) is added to the task_struct to control the effect of PTRACE_ATTACHED on credential calculations, particularly with respect to execve(). With this patch, the contents of an active credentials struct may not be changed directly; rather a new set of credentials must be prepared, modified and committed using something like the following sequence of events: struct cred *new = prepare_creds(); int ret = blah(new); if (ret < 0) { abort_creds(new); return ret; } return commit_creds(new); There are some exceptions to this rule: the keyrings pointed to by the active credentials may be instantiated - keyrings violate the COW rule as managing COW keyrings is tricky, given that it is possible for a task to directly alter the keys in a keyring in use by another task. To help enforce this, various pointers to sets of credentials, such as those in the task_struct, are declared const. The purpose of this is compile-time discouragement of altering credentials through those pointers. Once a set of credentials has been made public through one of these pointers, it may not be modified, except under special circumstances: (1) Its reference count may incremented and decremented. (2) The keyrings to which it points may be modified, but not replaced. The only safe way to modify anything else is to create a replacement and commit using the functions described in Documentation/credentials.txt (which will be added by a later patch). This patch and the preceding patches have been tested with the LTP SELinux testsuite. This patch makes several logical sets of alteration: (1) execve(). This now prepares and commits credentials in various places in the security code rather than altering the current creds directly. (2) Temporary credential overrides. do_coredump() and sys_faccessat() now prepare their own credentials and temporarily override the ones currently on the acting thread, whilst preventing interference from other threads by holding cred_replace_mutex on the thread being dumped. This will be replaced in a future patch by something that hands down the credentials directly to the functions being called, rather than altering the task's objective credentials. (3) LSM interface. A number of functions have been changed, added or removed: (*) security_capset_check(), ->capset_check() (*) security_capset_set(), ->capset_set() Removed in favour of security_capset(). (*) security_capset(), ->capset() New. This is passed a pointer to the new creds, a pointer to the old creds and the proposed capability sets. It should fill in the new creds or return an error. All pointers, barring the pointer to the new creds, are now const. (*) security_bprm_apply_creds(), ->bprm_apply_creds() Changed; now returns a value, which will cause the process to be killed if it's an error. (*) security_task_alloc(), ->task_alloc_security() Removed in favour of security_prepare_creds(). (*) security_cred_free(), ->cred_free() New. Free security data attached to cred->security. (*) security_prepare_creds(), ->cred_prepare() New. Duplicate any security data attached to cred->security. (*) security_commit_creds(), ->cred_commit() New. Apply any security effects for the upcoming installation of new security by commit_creds(). (*) security_task_post_setuid(), ->task_post_setuid() Removed in favour of security_task_fix_setuid(). (*) security_task_fix_setuid(), ->task_fix_setuid() Fix up the proposed new credentials for setuid(). This is used by cap_set_fix_setuid() to implicitly adjust capabilities in line with setuid() changes. Changes are made to the new credentials, rather than the task itself as in security_task_post_setuid(). (*) security_task_reparent_to_init(), ->task_reparent_to_init() Removed. Instead the task being reparented to init is referred directly to init's credentials. NOTE! This results in the loss of some state: SELinux's osid no longer records the sid of the thread that forked it. (*) security_key_alloc(), ->key_alloc() (*) security_key_permission(), ->key_permission() Changed. These now take cred pointers rather than task pointers to refer to the security context. (4) sys_capset(). This has been simplified and uses less locking. The LSM functions it calls have been merged. (5) reparent_to_kthreadd(). This gives the current thread the same credentials as init by simply using commit_thread() to point that way. (6) __sigqueue_alloc() and switch_uid() __sigqueue_alloc() can't stop the target task from changing its creds beneath it, so this function gets a reference to the currently applicable user_struct which it then passes into the sigqueue struct it returns if successful. switch_uid() is now called from commit_creds(), and possibly should be folded into that. commit_creds() should take care of protecting __sigqueue_alloc(). (7) [sg]et[ug]id() and co and [sg]et_current_groups. The set functions now all use prepare_creds(), commit_creds() and abort_creds() to build and check a new set of credentials before applying it. security_task_set[ug]id() is called inside the prepared section. This guarantees that nothing else will affect the creds until we've finished. The calling of set_dumpable() has been moved into commit_creds(). Much of the functionality of set_user() has been moved into commit_creds(). The get functions all simply access the data directly. (8) security_task_prctl() and cap_task_prctl(). security_task_prctl() has been modified to return -ENOSYS if it doesn't want to handle a function, or otherwise return the return value directly rather than through an argument. Additionally, cap_task_prctl() now prepares a new set of credentials, even if it doesn't end up using it. (9) Keyrings. A number of changes have been made to the keyrings code: (a) switch_uid_keyring(), copy_keys(), exit_keys() and suid_keys() have all been dropped and built in to the credentials functions directly. They may want separating out again later. (b) key_alloc() and search_process_keyrings() now take a cred pointer rather than a task pointer to specify the security context. (c) copy_creds() gives a new thread within the same thread group a new thread keyring if its parent had one, otherwise it discards the thread keyring. (d) The authorisation key now points directly to the credentials to extend the search into rather pointing to the task that carries them. (e) Installing thread, process or session keyrings causes a new set of credentials to be created, even though it's not strictly necessary for process or session keyrings (they're shared). (10) Usermode helper. The usermode helper code now carries a cred struct pointer in its subprocess_info struct instead of a new session keyring pointer. This set of credentials is derived from init_cred and installed on the new process after it has been cloned. call_usermodehelper_setup() allocates the new credentials and call_usermodehelper_freeinfo() discards them if they haven't been used. A special cred function (prepare_usermodeinfo_creds()) is provided specifically for call_usermodehelper_setup() to call. call_usermodehelper_setkeys() adjusts the credentials to sport the supplied keyring as the new session keyring. (11) SELinux. SELinux has a number of changes, in addition to those to support the LSM interface changes mentioned above: (a) selinux_setprocattr() no longer does its check for whether the current ptracer can access processes with the new SID inside the lock that covers getting the ptracer's SID. Whilst this lock ensures that the check is done with the ptracer pinned, the result is only valid until the lock is released, so there's no point doing it inside the lock. (12) is_single_threaded(). This function has been extracted from selinux_setprocattr() and put into a file of its own in the lib/ directory as join_session_keyring() now wants to use it too. The code in SELinux just checked to see whether a task shared mm_structs with other tasks (CLONE_VM), but that isn't good enough. We really want to know if they're part of the same thread group (CLONE_THREAD). (13) nfsd. The NFS server daemon now has to use the COW credentials to set the credentials it is going to use. It really needs to pass the credentials down to the functions it calls, but it can't do that until other patches in this series have been applied. Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: James Morris <jmorris@namei.org> Signed-off-by: James Morris <jmorris@namei.org>
2008-11-14CRED: Separate per-task-group keyrings from signal_structDavid Howells
Separate per-task-group keyrings from signal_struct and dangle their anchor from the cred struct rather than the signal_struct. Signed-off-by: David Howells <dhowells@redhat.com> Reviewed-by: James Morris <jmorris@namei.org> Signed-off-by: James Morris <jmorris@namei.org>
2008-11-14CRED: Detach the credentials from task_structDavid Howells
Detach the credentials from task_struct, duplicating them in copy_process() and releasing them in __put_task_struct(). Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: James Morris <jmorris@namei.org> Acked-by: Serge Hallyn <serue@us.ibm.com> Signed-off-by: James Morris <jmorris@namei.org>
