path: root/kernel/debug
2012-10-21kdb,vt_console: Fix missed data due to pager overrunsJason Wessel
commit 17b572e82032bc246324ce136696656b66d4e3f1 upstream. It is possible to miss data when using the kdb pager. The kdb pager does not pay attention to the maximum column constraint of the screen or serial terminal. This result is not incrementing the shown lines correctly and the pager will print more lines that fit on the screen. Obviously that is less than useful when using a VGA console where you cannot scroll back. The pager will now look at the kdb_buffer string to see how many characters are printed. It might not be perfect considering you can output ASCII that might move the cursor position, but it is a substantially better approximation for viewing dmesg and trace logs. This also means that the vt screen needs to set the kdb COLUMNS variable. Signed-off-by: Jason Wessel <jason.wessel@windriver.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-04-04Merge tag 'for_linus-3.4-rc2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jwessel/kgdb Pull KGDB/KDB regression fixes from Jason Wessel: - Fix a Smatch warning that appeared in the 3.4 merge window - Fix kgdb test suite with SMP for all archs without HW single stepping - Fix kgdb sw breakpoints with CONFIG_DEBUG_RODATA=y limitations on x86 - Fix oops on kgdb test suite with CONFIG_DEBUG_RODATA - Fix kgdb test suite with SMP for all archs with HW single stepping * tag 'for_linus-3.4-rc2' of git://git.kernel.org/pub/scm/linux/kernel/git/jwessel/kgdb: x86,kgdb: Fix DEBUG_RODATA limitation using text_poke() kgdb,debug_core: pass the breakpoint struct instead of address and memory kgdbts: (2 of 2) fix single step awareness to work correctly with SMP kgdbts: (1 of 2) fix single step awareness to work correctly with SMP kgdbts: Fix kernel oops with CONFIG_DEBUG_RODATA kdb: Fix smatch warning on dbg_io_ops->is_console
2012-03-29kgdb,debug_core: pass the breakpoint struct instead of address and memoryJason Wessel
There is extra state information that needs to be exposed in the kgdb_bpt structure for tracking how a breakpoint was installed. The debug_core only uses the the probe_kernel_write() to install breakpoints, but this is not enough for all the archs. Some arch such as x86 need to use text_poke() in order to install a breakpoint into a read only page. Passing the kgdb_bpt structure to kgdb_arch_set_breakpoint() and kgdb_arch_remove_breakpoint() allows other archs to set the type variable which indicates how the breakpoint was installed. Cc: stable@vger.kernel.org # >= 2.6.36 Signed-off-by: Jason Wessel <jason.wessel@windriver.com>
2012-03-29kdb: Fix smatch warning on dbg_io_ops->is_consoleJason Wessel
The Smatch tool warned that the change from commit b8adde8dd (kdb: Avoid using dbg_io_ops until it is initialized) should add another null check later in the kdb_printf(). It is worth noting that the second use of dbg_io_ops->is_console is protected by the KDB_PAGER state variable which would only get set when kdb is fully active and initialized. If we ever encounter changes or defects in the KDB_PAGER state we do not want to crash the kernel in a kdb_printf/printk. CC: Tim Bird <tim.bird@am.sony.com> Reported-by: Dan Carpenter <dan.carpenter@oracle.com> Signed-off-by: Jason Wessel <jason.wessel@windriver.com>
2012-03-28Merge tag 'split-asm_system_h-for-linus-20120328' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/dhowells/linux-asm_system Pull "Disintegrate and delete asm/system.h" from David Howells: "Here are a bunch of patches to disintegrate asm/system.h into a set of separate bits to relieve the problem of circular inclusion dependencies. I've built all the working defconfigs from all the arches that I can and made sure that they don't break. The reason for these patches is that I recently encountered a circular dependency problem that came about when I produced some patches to optimise get_order() by rewriting it to use ilog2(). This uses bitops - and on the SH arch asm/bitops.h drags in asm-generic/get_order.h by a circuituous route involving asm/system.h. The main difficulty seems to be asm/system.h. It holds a number of low level bits with no/few dependencies that are commonly used (eg. memory barriers) and a number of bits with more dependencies that aren't used in many places (eg. switch_to()). These patches break asm/system.h up into the following core pieces: (1) asm/barrier.h Move memory barriers here. This already done for MIPS and Alpha. (2) asm/switch_to.h Move switch_to() and related stuff here. (3) asm/exec.h Move arch_align_stack() here. Other process execution related bits could perhaps go here from asm/processor.h. (4) asm/cmpxchg.h Move xchg() and cmpxchg() here as they're full word atomic ops and frequently used by atomic_xchg() and atomic_cmpxchg(). (5) asm/bug.h Move die() and related bits. (6) asm/auxvec.h Move AT_VECTOR_SIZE_ARCH here. Other arch headers are created as needed on a per-arch basis." Fixed up some conflicts from other header file cleanups and moving code around that has happened in the meantime, so David's testing is somewhat weakened by that. We'll find out anything that got broken and fix it.. * tag 'split-asm_system_h-for-linus-20120328' of git://git.kernel.org/pub/scm/linux/kernel/git/dhowells/linux-asm_system: (38 commits) Delete all instances of asm/system.h Remove all #inclusions of asm/system.h Add #includes needed to permit the removal of asm/system.h Move all declarations of free_initmem() to linux/mm.h Disintegrate asm/system.h for OpenRISC Split arch_align_stack() out from asm-generic/system.h Split the switch_to() wrapper out of asm-generic/system.h Move the asm-generic/system.h xchg() implementation to asm-generic/cmpxchg.h Create asm-generic/barrier.h Make asm-generic/cmpxchg.h #include asm-generic/cmpxchg-local.h Disintegrate asm/system.h for Xtensa Disintegrate asm/system.h for Unicore32 [based on ver #3, changed by gxt] Disintegrate asm/system.h for Tile Disintegrate asm/system.h for Sparc Disintegrate asm/system.h for SH Disintegrate asm/system.h for Score Disintegrate asm/system.h for S390 Disintegrate asm/system.h for PowerPC Disintegrate asm/system.h for PA-RISC Disintegrate asm/system.h for MN10300 ...
2012-03-28Remove all #inclusions of asm/system.hDavid Howells
Remove all #inclusions of asm/system.h preparatory to splitting and killing it. Performed with the following command: perl -p -i -e 's!^#\s*include\s*<asm/system[.]h>.*\n!!' `grep -Irl '^#\s*include\s*<asm/system[.]h>' *` Signed-off-by: David Howells <dhowells@redhat.com>
2012-03-23Merge tag 'for_linus-3.4-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jwessel/kgdb Pull KGDB/KDB updates from Jason Wessel: "Fixes: - Fix KDB keyboard repeat scan codes and leaked keyboard events - Fix kernel crash with kdb_printf() for users who compile new kdb_printf()'s in early code - Return all segment registers to gdb on x86_64 Features: - KDB/KGDB hook the reboot notifier and end user can control if it stops, detaches or does nothing (updated docs as well) - Notify users who use CONFIG_DEBUG_RODATA to use hw breakpoints" * tag 'for_linus-3.4-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/jwessel/kgdb: kdb: Add message about CONFIG_DEBUG_RODATA on failure to install breakpoint kdb: Avoid using dbg_io_ops until it is initialized kgdb,debug_core: add the ability to control the reboot notifier KDB: Fix usability issues relating to the 'enter' key. kgdb,debug-core,gdbstub: Hook the reboot notifier for debugger detach kgdb: Respect that flush op is optional kgdb: x86: Return all segment registers also in 64-bit mode
2012-03-22kdb: Add message about CONFIG_DEBUG_RODATA on failure to install breakpointJason Wessel
On x86, if CONFIG_DEBUG_RODATA is set, one cannot set breakpoints via KDB. Apparently this is a well-known problem, as at least one distribution now ships with both KDB enabled and CONFIG_DEBUG_RODATA=y for security reasons. This patch adds an printk message to the breakpoint failure case, in order to provide suggestions about how to use the debugger. Reported-by: Tim Bird <tim.bird@am.sony.com> Signed-off-by: Jason Wessel <jason.wessel@windriver.com> Acked-by: Tim Bird <tim.bird@am.sony.com>
2012-03-22kdb: Avoid using dbg_io_ops until it is initializedTim Bird
This fixes a bug with setting a breakpoint during kdb initialization (from kdb_cmds). Any call to kdb_printf() before the initialization of the kgdboc serial console driver (which happens much later during bootup than kdb_init), results in kernel panic due to the use of dbg_io_ops before it is initialized. Signed-off-by: Tim Bird <tim.bird@am.sony.com> Signed-off-by: Jason Wessel <jason.wessel@windriver.com>
2012-03-22kgdb,debug_core: add the ability to control the reboot notifierJason Wessel
Sometimes it is desirable to stop the kernel debugger before allowing a system to reboot either with kdb or kgdb. This patch adds the ability to turn the reboot notifier on and off or enter the debugger and stop kernel execution before rebooting. It is possible to change the setting after booting the kernel with the following: echo 1 > /sys/module/debug_core/parameters/kgdbreboot It is also possible to change this setting using kdb / kgdb to manipulate the variable directly. Using KDB: mm kgdbreboot 1 Using gdb: set kgdbreboot=1 Reported-by: Jan Kiszka <jan.kiszka@siemens.com> Signed-off-by: Jason Wessel <jason.wessel@windriver.com>
2012-03-22KDB: Fix usability issues relating to the 'enter' key.Andrei Warkentin
This fixes the following problems: 1) Typematic-repeat of 'enter' gives warning message and leaks make/break if KDB exits. Repeats look something like 0x1c 0x1c .... 0x9c 2) Use of 'keypad enter' gives warning message and leaks the ENTER break/make code out if KDB exits. KP ENTER repeats look someting like 0xe0 0x1c 0xe0 0x1c ... 0xe0 0x9c. 3) Lag on the order of seconds between "break" and "make" when expecting the enter "break" code. Seen under virtualized environments such as VMware ESX. The existing special enter handler tries to glob the enter break code, but this fails if the other (KP) enter was used, or if there was a key repeat. It also fails if you mashed some keys along with enter, and you ended up with a non-enter make or non-enter break code coming after the enter make code. So first, we modify the handler to handle these cases. But performing these actions on every enter is annoying since now you can't hold ENTER down to scroll <more>d messages in KDB. Since this special behaviour is only necessary to handle the exiting KDB ('g' + ENTER) without leaking scancodes to the OS. This cleanup needs to get executed anytime the kdb_main loop exits. Tested on QEMU. Set a bp on atkbd.c to verify no scan code was leaked. Cc: Andrei Warkentin <andreiw@vmware.com> [jason.wessel@windriver.com: move cleanup calls to kdb_main.c] Signed-off-by: Andrei Warkentin <andrey.warkentin@gmail.com> Signed-off-by: Jason Wessel <jason.wessel@windriver.com>
2012-03-22kgdb,debug-core,gdbstub: Hook the reboot notifier for debugger detachJason Wessel
The gdbstub and kdb should get detached if the system is rebooting. Calling gdbstub_exit() will set the proper debug core state and send a message to any debugger that is connected to correctly detach. An attached debugger will receive the exit code from include/linux/reboot.h based on SYS_HALT, SYS_REBOOT, etc... Reported-by: Jan Kiszka <jan.kiszka@siemens.com> Signed-off-by: Jason Wessel <jason.wessel@windriver.com>
2012-03-22kgdb: Respect that flush op is optionalJan Kiszka
Not all kgdb I/O drivers implement a flush operation. Adjust gdbstub_exit accordingly. Signed-off-by: Jan Kiszka <jan.kiszka@siemens.com> Signed-off-by: Jason Wessel <jason.wessel@windriver.com>
2012-03-20kdb: remove the second argument of k[un]map_atomic()Cong Wang
Signed-off-by: Cong Wang <amwang@redhat.com>
2012-01-13module: struct module_ref should contains long fieldsEric Dumazet
module_ref contains two "unsigned int" fields. Thats now too small, since some machines can open more than 2^32 files. Check commit 518de9b39e8 (fs: allow for more than 2^31 files) for reference. We can add an aligned(2 * sizeof(unsigned long)) attribute to force alloc_percpu() allocating module_ref areas in single cache lines. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> CC: Rusty Russell <rusty@rustcorp.com.au> CC: Tejun Heo <tj@kernel.org> CC: Robin Holt <holt@sgi.com> CC: David Miller <davem@davemloft.net> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2011-12-11kdb: Make KDB use the new is_idle_task() APIPaul E. McKenney
Change from direct comparison of ->pid with zero to is_idle_task(). Signed-off-by: Paul E. McKenney <paul.mckenney@linaro.org> Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: Jason Wessel <jason.wessel@windriver.com> Reviewed-by: Josh Triplett <josh@joshtriplett.org>
2011-11-06Merge branch 'modsplit-Oct31_2011' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/paulg/linux * 'modsplit-Oct31_2011' of git://git.kernel.org/pub/scm/linux/kernel/git/paulg/linux: (230 commits) Revert "tracing: Include module.h in define_trace.h" irq: don't put module.h into irq.h for tracking irqgen modules. bluetooth: macroize two small inlines to avoid module.h ip_vs.h: fix implicit use of module_get/module_put from module.h nf_conntrack.h: fix up fallout from implicit moduleparam.h presence include: replace linux/module.h with "struct module" wherever possible include: convert various register fcns to macros to avoid include chaining crypto.h: remove unused crypto_tfm_alg_modname() inline uwb.h: fix implicit use of asm/page.h for PAGE_SIZE pm_runtime.h: explicitly requires notifier.h linux/dmaengine.h: fix implicit use of bitmap.h and asm/page.h miscdevice.h: fix up implicit use of lists and types stop_machine.h: fix implicit use of smp.h for smp_processor_id of: fix implicit use of errno.h in include/linux/of.h of_platform.h: delete needless include <linux/module.h> acpi: remove module.h include from platform/aclinux.h miscdevice.h: delete unnecessary inclusion of module.h device_cgroup.h: delete needless include <linux/module.h> net: sch_generic remove redundant use of <linux/module.h> net: inet_timewait_sock doesnt need <linux/module.h> ... Fix up trivial conflicts (other header files, and removal of the ab3550 mfd driver) in - drivers/media/dvb/frontends/dibx000_common.c - drivers/media/video/{mt9m111.c,ov6650.c} - drivers/mfd/ab3550-core.c - include/linux/dmaengine.h
2011-10-31kgdb: follow rename pack_hex_byte() to hex_byte_pack()Andy Shevchenko
There is no functional change. Signed-off-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com> Acked-by: Jesper Nilsson <jesper.nilsson@axis.com> Cc: David Howells <dhowells@redhat.com> Cc: Koichi Yasutake <yasutake.koichi@jp.panasonic.com> Cc: Jason Wessel <jason.wessel@windriver.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-10-31kernel: Fix files explicitly needing EXPORT_SYMBOL infrastructurePaul Gortmaker
These files were getting <linux/module.h> via an implicit non-obvious path, but we want to crush those out of existence since they cost time during compiles of processing thousands of lines of headers for no reason. Give them the lightweight header that just contains the EXPORT_SYMBOL infrastructure. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2011-08-01Merge branch 'for_linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jwessel/linux-2.6-kgdb * 'for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jwessel/linux-2.6-kgdb: kdb,kgdb: Allow arbitrary kgdb magic knock sequences kdb: Remove all references to DOING_KGDB2 kdb,kgdb: Implement switch and pass buffer from kdb -> gdb kdb: cleanup unused variables missed in the original kdb merge
2011-08-01kdb,kgdb: Allow arbitrary kgdb magic knock sequencesJason Wessel
The first packet that gdb sends when the kernel is in kdb mode seems to change with every release of gdb. Instead of continuing to add many different gdb packets, change kdb to automatically look for any thing that looks like a gdb packet. Example 1 cold start test: echo g > /proc/sysrq-trigger $D#44+ Example 2 cold start test: echo g > /proc/sysrq-trigger $3#33 The second one should re-enter kdb's shell right away and is purely a test. Signed-off-by: Jason Wessel <jason.wessel@windriver.com>
2011-08-01kdb: Remove all references to DOING_KGDB2Jason Wessel
The DOING_KGDB2 was originally a state variable for one of the two ways to automatically transition from kdb to kgdb. Purge all these variables and just use one single state for the transition. Signed-off-by: Jason Wessel <jason.wessel@windriver.com>
2011-08-01kdb,kgdb: Implement switch and pass buffer from kdb -> gdbJason Wessel
When switching from kdb mode to kgdb mode packets were getting lost depending on the size of the fifo queue of the serial chip. When gdb initially connects if it is in kdb mode it should entirely send any character buffer over to the gdbstub when switching connections. Previously kdb was zero'ing out the character buffer and this could lead to gdb failing to connect at all, or a lengthy pause could occur on the initial connect. Signed-off-by: Jason Wessel <jason.wessel@windriver.com>
2011-08-01kdb: cleanup unused variables missed in the original kdb mergeJason Wessel
The BTARGS and BTSYMARG variables do not have any function in the mainline version of kdb. Reported-by: Tim Bird <tim.bird@am.sony.com> Signed-off-by: Jason Wessel <jason.wessel@windriver.com>
2011-07-26atomic: use <linux/atomic.h>Arun Sharma
This allows us to move duplicated code in <asm/atomic.h> (atomic_inc_not_zero() for now) to <linux/atomic.h> Signed-off-by: Arun Sharma <asharma@fb.com> Reviewed-by: Eric Dumazet <eric.dumazet@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: David Miller <davem@davemloft.net> Cc: Eric Dumazet <eric.dumazet@gmail.com> Acked-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-25Merge branch 'for_linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jwessel/linux-2.6-kgdb * 'for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jwessel/linux-2.6-kgdb: kdb: add usage string of 'per_cpu' command kgdb,x86_64: fix compile warning found with sparse kdb: code cleanup to use macro instead of value kgdboc,kgdbts: strlen() doesn't count the terminator
2011-03-25kdb: add usage string of 'per_cpu' commandNamhyung Kim
Signed-off-by: Namhyung Kim <namhyung@gmail.com> Signed-off-by: Jason Wessel <jason.wessel@windriver.com>
2011-03-25kdb: code cleanup to use macro instead of valueJovi Zhang
It's better to use macro KDB_BASE_CMD_MAX instead of 50 Signed-off-by: Jovi Zhang <bookjovi@gmail.com> Signed-off-by: Jason Wessel <jason.wessel@windriver.com>
2011-03-18KGDB: Notify GDB of machine halt, reboot or power offDavid Howells
Notify GDB of the machine halting, rebooting or powering off by sending it an exited command (remote protocol command 'W'). This is done by calling: void gdbstub_exit(int status) from the arch's machine_{halt,restart,power_off}() functions with an appropriate exit status to be reported to GDB. Signed-off-by: David Howells <dhowells@redhat.com>
2010-12-22Merge branch 'master' into for-nextJiri Kosina
Conflicts: MAINTAINERS arch/arm/mach-omap2/pm24xx.c drivers/scsi/bfa/bfa_fcpim.c Needed to update to apply fixes for which the old branch was too outdated.
2010-11-17kdb: fix crash when KDB_BASE_CMD_MAX is exceededJovi Zhang
When the number of dyanmic kdb commands exceeds KDB_BASE_CMD_MAX, the kernel will fault. Signed-off-by: Jovi Zhang <bookjovi@gmail.com> Signed-off-by: Jason Wessel <jason.wessel@windriver.com>
2010-11-17kdb: fix memory leak in kdb_main.cJovi Zhang
Call kfree in the error path as well as the success path in kdb_ll(). Signed-off-by: Jovi Zhang <bookjovi@gmail.com> Signed-off-by: Jason Wessel <jason.wessel@windriver.com>
2010-11-01tree-wide: fix comment/printk typosUwe Kleine-König
"gadget", "through", "command", "maintain", "maintain", "controller", "address", "between", "initiali[zs]e", "instead", "function", "select", "already", "equal", "access", "management", "hierarchy", "registration", "interest", "relative", "memory", "offset", "already", Signed-off-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2010-10-29debug_core,x86,blackfin: Clean up hw debug disable APIDongdong Deng
The kgdb_disable_hw_debug() was an architecture specific function for disabling all hardware breakpoints on a per cpu basis when entering the debug core. This patch will remove the weak function kdbg_disable_hw_debug() and change it into a call back which lives with the rest of hw breakpoint call backs in struct kgdb_arch. Signed-off-by: Dongdong Deng <dongdong.deng@windriver.com> Signed-off-by: Jason Wessel <jason.wessel@windriver.com>
2010-10-29kdb: Fix early debugging crash regressionJason Wessel
The kdb_current legally be equal to NULL in the early boot of the x86 arch. The problem pcan be observed by booting with the kernel arguments: earlyprintk=vga ekgdboc=kbd kgdbwait The kdb shell will oops on entry and recursively fault because it cannot get past the final stage of shell initialization. Signed-off-by: Jason Wessel <jason.wessel@windriver.com>
2010-10-29kdb: fix per_cpu command to remove supress maskJason Wessel
Rusty pointed out that the per_cpu command uses up lots of space on the stack and the cpu supress mask is probably not needed. This patch removes the need for the supress mask as well as fixing up the following problems with the kdb per_cpu command: * The per_cpu command should allow an address as an argument * When you have more data than can be displayed on one screen allow the user to break out of the print loop. Reported-by: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Jason Wessel <jason.wessel@windriver.com>
2010-10-22kdb,debug_core: adjust master cpu switch logic against new debug_core lockingJason Wessel
The kdb shell needs to enforce switching back to the original CPU that took the exception before restoring normal kernel execution. Resuming from a different CPU than what took the original exception will cause problems with spin locks that are freed from the a different processor than had taken the lock. The special logic in dbg_cpu_switch() can go away entirely with because the state of what cpus want to be masters or slaves will remain unchanged between entry and exit of the debug_core exception context. Signed-off-by: Jason Wessel <jason.wessel@windriver.com>
2010-10-22debug_core: refactor locking for master/slave cpusJason Wessel
For quite some time there have been problems with memory barriers and various races with NMI on multi processor systems using the kernel debugger. The algorithm for entering the kernel debug core and resuming kernel execution was racy and had several known edge case problems with attempting to debug something on a heavily loaded system using breakpoints that are hit repeatedly and quickly. The prior "locking" design entry worked as follows: * The atomic counter kgdb_active was used with atomic exchange in order to elect a master cpu out of all the cpus that may have taken a debug exception. * The master cpu increments all elements of passive_cpu_wait[]. * The master cpu issues the round up cpus message. * Each "slave cpu" that enters the debug core increments its own element in cpu_in_kgdb[]. * Each "slave cpu" spins on passive_cpu_wait[] until it becomes 0. * The master cpu debugs the system. The new scheme removes the two arrays of atomic counters and replaces them with 2 single counters. One counter is used to count the number of cpus waiting to become a master cpu (because one or more hit an exception). The second counter is use to indicate how many cpus have entered as slave cpus. The new entry logic works as follows: * One or more cpus enters via kgdb_handle_exception() and increments the masters_in_kgdb. Each cpu attempts to get the spin lock called dbg_master_lock. * The master cpu sets kgdb_active to the current cpu. * The master cpu takes the spinlock dbg_slave_lock. * The master cpu asks to round up all the other cpus. * Each slave cpu that is not already in kgdb_handle_exception() will enter and increment slaves_in_kgdb. Each slave will now spin try_locking on dbg_slave_lock. * The master cpu waits for the sum of masters_in_kgdb and slaves_in_kgdb to be equal to the sum of the online cpus. * The master cpu debugs the system. In the new design the kgdb_active can only be changed while holding dbg_master_lock. Stress testing has not turned up any further entry/exit races that existed in the prior locking design. The prior locking design suffered from atomic variables not being truly atomic (in the capacity as used by kgdb) along with memory barrier races. Signed-off-by: Jason Wessel <jason.wessel@windriver.com> Acked-by: Dongdong Deng <dongdong.deng@windriver.com>
2010-10-22debug_core: disable hw_breakpoints on all cores in kgdb_cpu_enter()Dongdong Deng
The slave cpus do not have the hw breakpoints disabled upon entry to the debug_core and as a result could cause unrecoverable recursive faults on badly placed breakpoints, or get out of sync with the arch specific hw breakpoint operations. This patch addresses the problem by invoking kgdb_disable_hw_debug() earlier in kgdb_enter_cpu for each cpu that enters the debug core. The hw breakpoint dis/enable flow should be: master_debug_cpu slave_debug_cpu \ / kgdb_cpu_enter | kgdb_disable_hw_debug --> uninstall pre-enabled hw_breakpoint | do add/rm dis/enable operates to hw_breakpoints on master_debug_cpu.. | correct_hw_break --> correct/install the enabled hw_breakpoint | leave_kgdb Signed-off-by: Dongdong Deng <dongdong.deng@windriver.com> Signed-off-by: Jason Wessel <jason.wessel@windriver.com>
2010-10-22kdb,kgdb: fix sparse fixupsJason Wessel
Fix the following sparse warnings: kdb_main.c:328:5: warning: symbol 'kdbgetu64arg' was not declared. Should it be static? kgdboc.c:246:12: warning: symbol 'kgdboc_early_init' was not declared. Should it be static? kgdb.c:652:26: warning: incorrect type in argument 1 (different address spaces) kgdb.c:652:26: expected void const *ptr kgdb.c:652:26: got struct perf_event *[noderef] <asn:3>*pev The one in kgdb.c required the (void * __force) because of the return code from register_wide_hw_breakpoint looking like: return (void __percpu __force *)ERR_PTR(err); Signed-off-by: Jason Wessel <jason.wessel@windriver.com>
2010-10-22kdb: Fix oops in kdb_unregisterJason Wessel
Nothing should try to use kdb_commands directly as sometimes it is null. Instead, use the for_each_kdbcmd() iterator. This particular problem dates back to the initial kdb merge (2.6.35), but at that point nothing was dynamically unregistering commands from the kdb shell. Signed-off-by: Jason Wessel <jason.wessel@windriver.com>
2010-10-22kdb: Allow kernel loadable modules to add kdb shell functionsJason Wessel
In order to allow kernel modules to dynamically add a command to the kdb shell the kdb_register, kdb_register_repeat, kdb_unregister, and kdb_printf need to be exported as GPL symbols. Any kernel module that adds a dynamic kdb shell function should only need to include linux/kdb.h. Signed-off-by: Jason Wessel <jason.wessel@windriver.com>
2010-10-22debug_core: stop rcu warnings on kernel resumeJason Wessel
When returning from the kernel debugger reset the rcu jiffies_stall value to prevent the rcu stall detector from sending NMI events which invoke a stack dump for each cpu in the system. Signed-off-by: Jason Wessel <jason.wessel@windriver.com>
2010-10-22debug_core: move all watch dog syncs to a single functionJason Wessel
Move the various clock and watch dog syncs to a single function in advance of adding another sync for the rcu stall detector. Signed-off-by: Jason Wessel <jason.wessel@windriver.com>
2010-09-08Merge branch 'core-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'core-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: gcc-4.6: kernel/*: Fix unused but set warnings mutex: Fix annotations to include it in kernel-locking docbook pid: make setpgid() system call use RCU read-side critical section MAINTAINERS: Add RCU's public git tree
2010-09-05gcc-4.6: kernel/*: Fix unused but set warningsAndi Kleen
No real bugs I believe, just some dead code. Signed-off-by: Andi Kleen <ak@linux.intel.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: andi@firstfloor.org Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-08-28Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input: Input: pxa27x_keypad - remove input_free_device() in pxa27x_keypad_remove() Input: mousedev - fix regression of inverting axes Input: uinput - add devname alias to allow module on-demand load Input: hil_kbd - fix compile error USB: drop tty argument from usb_serial_handle_sysrq_char() Input: sysrq - drop tty argument form handle_sysrq() Input: sysrq - drop tty argument from sysrq ops handlers
2010-08-21Input: sysrq - drop tty argument form handle_sysrq()Dmitry Torokhov
Sysrq operations do not accept tty argument anymore so no need to pass it to us. [Stephen Rothwell <sfr@canb.auug.org.au>: fix build breakage in drm code caused by sysrq using bool but not including linux/types.h] [Sachin Sant <sachinp@in.ibm.com>: fix build breakage in s390 keyboadr driver] Acked-by: Alan Cox <alan@lxorguk.ukuu.org.uk> Acked-by: Jason Wessel <jason.wessel@windriver.com> Acked-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2010-08-19Input: sysrq - drop tty argument from sysrq ops handlersDmitry Torokhov
Noone is using tty argument so let's get rid of it. Acked-by: Alan Cox <alan@lxorguk.ukuu.org.uk> Acked-by: Jason Wessel <jason.wessel@windriver.com> Acked-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
