path: root/kernel/events/ring_buffer.c
2013-05-01perf: Fix vmalloc ring buffer pages handlingJiri Olsa
If we allocate perf ring buffer with the size of single (user) page, we will get memory corruption when releasing itin rb_free_work function (for CONFIG_PERF_USE_VMALLOC option). For single page sized ring buffer the page_order is -1 (because nr_pages is 0). This needs to be recognized in the rb_free_work function to release proper amount of pages. Adding data_page_nr function that returns number of allocated data pages. Customizing the rest of the code to use it. Reported-by: Jan Stancek <jstancek@redhat.com> Original-patch-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Corey Ashford <cjashfor@linux.vnet.ibm.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: Jiri Olsa <jolsa@redhat.com> Link: http://lkml.kernel.org/r/20130319143509.GA1128@krava.brq.redhat.com Signed-off-by: Ingo Molnar <mingo@kernel.org>
2013-03-21perf: Fix ring_buffer perf_output_space() boundary calculationStephane Eranian
This patch fixes a flaw in perf_output_space(). In case the size of the space needed is bigger than the actual buffer size, there may be situations where the function would return true (i.e., there is space) when it should not. head > offset due to rounding of the masking logic. The problem can be tested by activating BTS on Intel processors. A BTS record can be as big as 16 pages. The following command fails: $ perf record -m 4 -c 1 -e branches:u my_test_program You will get a buffer corruption with this. Perf report won't be able to parse the perf.data. The fix is to first check that the requested space is smaller than the buffer size. If so, then the masking logic will work fine. If not, then there is no chance the record can be saved and it will be gracefully handled by upper code layers. [ In v2, we also make the logic for the writable more explicit by renaming it to rb->overwrite because it tells whether or not the buffer can overwrite its tail (suggested by PeterZ). ] Signed-off-by: Stephane Eranian <eranian@google.com> Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: peterz@infradead.org Cc: jolsa@redhat.com Cc: fweisbec@gmail.com Link: http://lkml.kernel.org/r/20130318133327.GA3056@quad Signed-off-by: Ingo Molnar <mingo@kernel.org>
2012-08-10perf: Add perf_output_skip function to skip bytes in sampleJiri Olsa
Introducing perf_output_skip function to be able to skip data within the perf ring buffer. When writing data into perf ring buffer we first reserve needed place in ring buffer and then copy the actual data. There's a possibility we won't be able to fill all the reserved size with data, so we need a way to skip the remaining bytes. This is going to be useful when storing the user stack dump, where we might end up with less data than we originally requested. Signed-off-by: Jiri Olsa <jolsa@redhat.com> Acked-by: Frederic Weisbecker <fweisbec@gmail.com> Cc: "Frank Ch. Eigler" <fche@redhat.com> Cc: Arun Sharma <asharma@fb.com> Cc: Benjamin Redelings <benjamin.redelings@nescent.org> Cc: Corey Ashford <cjashfor@linux.vnet.ibm.com> Cc: Cyrill Gorcunov <gorcunov@openvz.org> Cc: Frank Ch. Eigler <fche@redhat.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Robert Richter <robert.richter@amd.com> Cc: Stephane Eranian <eranian@google.com> Cc: Tom Zanussi <tzanussi@gmail.com> Cc: Ulrich Drepper <drepper@gmail.com> Link: http://lkml.kernel.org/r/1344345647-11536-5-git-send-email-jolsa@redhat.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2012-08-10perf: Factor __output_copy to be usable with specific copy functionFrederic Weisbecker
Adding a generic way to use __output_copy function with specific copy function via DEFINE_PERF_OUTPUT_COPY macro. Using this to add new __output_copy_user function, that provides output copy from user pointers. For x86 the copy_from_user_nmi function is used and __copy_from_user_inatomic for the rest of the architectures. This new function will be used in user stack dump on sample, coming in next patches. Signed-off-by: Jiri Olsa <jolsa@redhat.com> Cc: "Frank Ch. Eigler" <fche@redhat.com> Cc: Arun Sharma <asharma@fb.com> Cc: Benjamin Redelings <benjamin.redelings@nescent.org> Cc: Corey Ashford <cjashfor@linux.vnet.ibm.com> Cc: Cyrill Gorcunov <gorcunov@openvz.org> Cc: Frank Ch. Eigler <fche@redhat.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Robert Richter <robert.richter@amd.com> Cc: Stephane Eranian <eranian@google.com> Cc: Tom Zanussi <tzanussi@gmail.com> Cc: Ulrich Drepper <drepper@gmail.com> Link: http://lkml.kernel.org/r/1344345647-11536-4-git-send-email-jolsa@redhat.com Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2012-01-08Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (53 commits) Kconfig: acpi: Fix typo in comment. misc latin1 to utf8 conversions devres: Fix a typo in devm_kfree comment btrfs: free-space-cache.c: remove extra semicolon. fat: Spelling s/obsolate/obsolete/g SCSI, pmcraid: Fix spelling error in a pmcraid_err() call tools/power turbostat: update fields in manpage mac80211: drop spelling fix types.h: fix comment spelling for 'architectures' typo fixes: aera -> area, exntension -> extension devices.txt: Fix typo of 'VMware'. sis900: Fix enum typo 'sis900_rx_bufer_status' decompress_bunzip2: remove invalid vi modeline treewide: Fix comment and string typo 'bufer' hyper-v: Update MAINTAINERS treewide: Fix typos in various parts of the kernel, and fix some comments. clockevents: drop unknown Kconfig symbol GENERIC_CLOCKEVENTS_MIGR gpio: Kconfig: drop unknown symbol 'CS5535_GPIO' leds: Kconfig: Fix typo 'D2NET_V2' sound: Kconfig: drop unknown symbol ARCH_CLPS7500 ... Fix up trivial conflicts in arch/powerpc/platforms/40x/Kconfig (some new kconfig additions, close to removed commented-out old ones)
2012-01-02misc latin1 to utf8 conversionsAl Viro
Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2011-12-05perf: Fix loss of notification with multi-eventPeter Zijlstra
When you do: $ perf record -e cycles,cycles,cycles noploop 10 You expect about 10,000 samples for each event, i.e., 10s at 1000samples/sec. However, this is not what's happening. You get much fewer samples, maybe 3700 samples/event: $ perf report -D | tail -15 Aggregated stats: TOTAL events: 10998 MMAP events: 66 COMM events: 2 SAMPLE events: 10930 cycles stats: TOTAL events: 3644 SAMPLE events: 3644 cycles stats: TOTAL events: 3642 SAMPLE events: 3642 cycles stats: TOTAL events: 3644 SAMPLE events: 3644 On a Intel Nehalem or even AMD64, there are 4 counters capable of measuring cycles, so there is plenty of space to measure those events without multiplexing (even with the NMI watchdog active). And even with multiplexing, we'd expect roughly the same number of samples per event. The root of the problem was that when the event that caused the buffer to become full was not the first event passed on the cmdline, the user notification would get lost. The notification was sent to the file descriptor of the overflowed event but the perf tool was not polling on it. The perf tool aggregates all samples into a single buffer, i.e., the buffer of the first event. Consequently, it assumes notifications for any event will come via that descriptor. The seemingly straight forward solution of moving the waitq into the ringbuffer object doesn't work because of life-time issues. One could perf_event_set_output() on a fd that you're also blocking on and cause the old rb object to be freed while its waitq would still be referenced by the blocked thread -> FAIL. Therefore link all events to the ringbuffer and broadcast the wakeup from the ringbuffer object to all possible events that could be waited upon. This is rather ugly, and we're open to better solutions but it works for now. Reported-by: Stephane Eranian <eranian@google.com> Finished-by: Stephane Eranian <eranian@google.com> Reviewed-by: Stephane Eranian <eranian@google.com> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Link: http://lkml.kernel.org/r/20111126014731.GA7030@quad Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-07-01perf: Remove the perf_output_begin(.sample) argumentPeter Zijlstra
Since only samples call perf_output_sample() its much saner (and more correct) to put the sample logic in there than in the perf_output_begin()/perf_output_end() pair. Saves a useless argument, reduces conditionals and shrinks struct perf_output_handle, win! Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Link: http://lkml.kernel.org/n/tip-2crpvsx3cqu67q3zqjbnlpsc@git.kernel.org Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-07-01perf: Remove the nmi parameter from the swevent and overflow interfacePeter Zijlstra
The nmi parameter indicated if we could do wakeups from the current context, if not, we would set some state and self-IPI and let the resulting interrupt do the wakeup. For the various event classes: - hardware: nmi=0; PMI is in fact an NMI or we run irq_work_run from the PMI-tail (ARM etc.) - tracepoint: nmi=0; since tracepoint could be from NMI context. - software: nmi=[0,1]; some, like the schedule thing cannot perform wakeups, and hence need 0. As one can see, there is very little nmi=1 usage, and the down-side of not using it is that on some platforms some software events can have a jiffy delay in wakeup (when arch_irq_work_raise isn't implemented). The up-side however is that we can remove the nmi parameter and save a bunch of conditionals in fast paths. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Michael Cree <mcree@orcon.net.nz> Cc: Will Deacon <will.deacon@arm.com> Cc: Deng-Cheng Zhu <dengcheng.zhu@gmail.com> Cc: Anton Blanchard <anton@samba.org> Cc: Eric B Munson <emunson@mgebm.net> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Paul Mundt <lethal@linux-sh.org> Cc: David S. Miller <davem@davemloft.net> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Jason Wessel <jason.wessel@windriver.com> Cc: Don Zickus <dzickus@redhat.com> Link: http://lkml.kernel.org/n/tip-agjev8eu666tvknpb3iaj0fg@git.kernel.org Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-07-01perf_events: Fix perf buffer watermark settingVince Weaver
Since 2.6.36 (specifically commit d57e34fdd60b ("perf: Simplify the ring-buffer logic: make perf_buffer_alloc() do everything needed"), the perf_buffer_init_code() has been mis-setting the buffer watermark if perf_event_attr.wakeup_events has a non-zero value. This is because perf_event_attr.wakeup_events is a union with perf_event_attr.wakeup_watermark. This commit re-enables the check for perf_event_attr.watermark being set before continuing with setting a non-default watermark. This bug is most noticable when you are trying to use PERF_IOC_REFRESH with a value larger than one and perf_event_attr.wakeup_events is set to one. In this case the buffer watermark will be set to 1 and you will get extraneous POLL_IN overflows rather than POLL_HUP as expected. [ avoid using attr.wakeup_events when attr.watermark is set ] Signed-off-by: Vince Weaver <vweaver1@eecs.utk.edu> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: <stable@kernel.org> Link: http://lkml.kernel.org/r/alpine.DEB.2.00.1106011506390.5384@cl320.eecs.utk.edu Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-06-09perf: Split up buffer handling from core codeFrederic Weisbecker
And create the internal perf events header. v2: Keep an internal inlined perf_output_copy() Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com> Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Borislav Petkov <bp@alien8.de> Cc: Stephane Eranian <eranian@google.com> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Steven Rostedt <rostedt@goodmis.org> Link: http://lkml.kernel.org/r/1305827704-5607-1-git-send-email-fweisbec@gmail.com [ v3: use clearer 'ring_buffer' and 'rb' naming ] Signed-off-by: Ingo Molnar <mingo@elte.hu>
