path: root/kernel/events
2011-08-04perf: Fix software event overflowPeter Zijlstra
The below patch is for -stable only, upstream has a much larger patch that contains the below hunk in commit a8b0ca17b80e92faab46ee7179ba9e99ccb61233 Vince found that under certain circumstances software event overflows go wrong and deadlock. Avoid trying to delete a timer from the timer callback. Reported-by: Vince Weaver <vweaver1@eecs.utk.edu> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-06-04Merge branch 'perf/urgent' of ↵Ingo Molnar
git://git.kernel.org/pub/scm/linux/kernel/git/acme/linux into perf/urgent
2011-05-31perf, cgroups: Fix up for new APIPeter Zijlstra
Ben changed the cgroup API in commit f780bdb7c1c (cgroups: add per-thread subsystem callbacks) in an incompatible way, but forgot to convert the perf cgroup bits. Avoid compile warnings and runtime splats and convert perf too ;-) Acked-by: Ben Blum <bblum@andrew.cmu.edu> Cc: Stephane Eranian <eranian@google.com> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Link: http://lkml.kernel.org/r/1306767651.1200.2990.camel@twins Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-05-28perf: Fix SIGIO handlingPeter Zijlstra
Vince noticed that unless we mmap() a buffer, SIGIO gets lost. So explicitly push the wakeup (including signals) when requested. Reported-by: Vince Weaver <vweaver1@eecs.utk.edu> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: <stable@kernel.org> Link: http://lkml.kernel.org/n/tip-2euus3f3x3dyvdk52cjxw8zu@git.kernel.org Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-05-19Merge branch 'core-rcu-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'core-rcu-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (78 commits) Revert "rcu: Decrease memory-barrier usage based on semi-formal proof" net,rcu: convert call_rcu(prl_entry_destroy_rcu) to kfree batman,rcu: convert call_rcu(softif_neigh_free_rcu) to kfree_rcu batman,rcu: convert call_rcu(neigh_node_free_rcu) to kfree() batman,rcu: convert call_rcu(gw_node_free_rcu) to kfree_rcu net,rcu: convert call_rcu(kfree_tid_tx) to kfree_rcu() net,rcu: convert call_rcu(xt_osf_finger_free_rcu) to kfree_rcu() net/mac80211,rcu: convert call_rcu(work_free_rcu) to kfree_rcu() net,rcu: convert call_rcu(wq_free_rcu) to kfree_rcu() net,rcu: convert call_rcu(phonet_device_rcu_free) to kfree_rcu() perf,rcu: convert call_rcu(swevent_hlist_release_rcu) to kfree_rcu() perf,rcu: convert call_rcu(free_ctx) to kfree_rcu() net,rcu: convert call_rcu(__nf_ct_ext_free_rcu) to kfree_rcu() net,rcu: convert call_rcu(net_generic_release) to kfree_rcu() net,rcu: convert call_rcu(netlbl_unlhsh_free_addr6) to kfree_rcu() net,rcu: convert call_rcu(netlbl_unlhsh_free_addr4) to kfree_rcu() security,rcu: convert call_rcu(sel_netif_free) to kfree_rcu() net,rcu: convert call_rcu(xps_dev_maps_release) to kfree_rcu() net,rcu: convert call_rcu(xps_map_release) to kfree_rcu() net,rcu: convert call_rcu(rps_map_release) to kfree_rcu() ...
2011-05-04perf events: Clean up definitions and initializers, update copyrightsIngo Molnar
Fix a few inconsistent style bits that were added over the past few months. Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Link: http://lkml.kernel.org/n/tip-yv4hwf9yhnzoada8pcpb3a97@git.kernel.org Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-05-03hw breakpoints: Move to kernel/events/Borislav Petkov
As part of the events sybsystem unification, relocate hw_breakpoint.c into its new destination. Cc: Frederic Weisbecker <fweisbec@gmail.com> Signed-off-by: Borislav Petkov <borislav.petkov@amd.com>
2011-05-03perf: Start the restructuringBorislav Petkov
mv kernel/perf_event.c -> kernel/events/core.c. From there, all further sensible splitting can happen. The idea is that due to perf_event.c becoming pretty sizable and with the advent of the marriage with ftrace, splitting functionality into its logical parts should help speeding up the unification and to manage the complexity of the subsystem. Signed-off-by: Borislav Petkov <borislav.petkov@amd.com>
