path: root/kernel/exit.c
2005-11-13[PATCH] m68k: introduce task_thread_infoAl Viro
new helper - task_thread_info(task). On platforms that have thread_info allocated separately (i.e. in default case) it simply returns task->thread_info. m68k wants (and for good reasons) to embed its thread_info into task_struct. So it will (in later patch) have task_thread_info() of its own. For now we just add a macro for generic case and convert existing instances of its body in core kernel to uses of new macro. Obviously safe - all normal architectures get the same preprocessor output they used to get. Signed-off-by: Al Viro <viro@parcelfarce.linux.theplanet.co.uk> Signed-off-by: Roman Zippel <zippel@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-07[PATCH] Process Events ConnectorMatt Helsley
This patch adds a connector that reports fork, exec, id change, and exit events for all processes to userspace. It replaces the fork_advisor patch that ELSA is currently using. Applications that may find these events useful include accounting/auditing (e.g. ELSA), system activity monitoring (e.g. top), security, and resource management (e.g. CKRM). Signed-off-by: Matt Helsley <matthltc@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-30[PATCH] remove hardcoded SEND_SIG_xxx constantsOleg Nesterov
This patch replaces hardcoded SEND_SIG_xxx constants with their symbolic names. No changes in affected .o files. Signed-off-by: Oleg Nesterov <oleg@tv-sign.ru> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-30[PATCH] wait4 PTRACE_ATTACH race fixRoland McGrath
Back about a year ago when I last fiddled heavily with the do_wait code, I was thinking too hard about the wrong thing and I now think I introduced a bug whose inverse thought I was fixing. Apparently noone was looking too hard over much shoulder, so as to cite my bogus reasoning at the time. In the race condition when PTRACE_ATTACH is about to steal a child and then the child hits a tracing event (what my_ptrace_child checks for), the real parent does need to set its flag noting it has some eligible live children. Otherwise a spurious ECHILD error is possible, since the child in question is not yet on the ptrace_children list. Signed-off-by: Roland McGrath <roland@redhat.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-30[PATCH] PF_DEAD cleanupCoywolf Qi Hunt
The PF_DEAD setting doesn't belong to exit_notify(), move it to a proper place. Signed-off-by: Coywolf Qi Hunt <qiyong@fc-cn.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-29[PATCH] mm: update_hiwaters just in timeHugh Dickins
update_mem_hiwater has attracted various criticisms, in particular from those concerned with mm scalability. Originally it was called whenever rss or total_vm got raised. Then many of those callsites were replaced by a timer tick call from account_system_time. Now Frank van Maarseveen reports that to be found inadequate. How about this? Works for Frank. Replace update_mem_hiwater, a poor combination of two unrelated ops, by macros update_hiwater_rss and update_hiwater_vm. Don't attempt to keep mm->hiwater_rss up to date at timer tick, nor every time we raise rss (usually by 1): those are hot paths. Do the opposite, update only when about to lower rss (usually by many), or just before final accounting in do_exit. Handle mm->hiwater_vm in the same way, though it's much less of an issue. Demand that whoever collects these hiwater statistics do the work of taking the maximum with rss or total_vm. And there has been no collector of these hiwater statistics in the tree. The new convention needs an example, so match Frank's usage by adding a VmPeak line above VmSize to /proc/<pid>/status, and also a VmHWM line above VmRSS (High-Water-Mark or High-Water-Memory). There was a particular anomaly during mremap move, that hiwater_vm might be captured too high. A fleeting such anomaly remains, but it's quickly corrected now, whereas before it would stick. What locking? None: if the app is racy then these statistics will be racy, it's not worth any overhead to make them exact. But whenever it suits, hiwater_vm is updated under exclusive mmap_sem, and hiwater_rss under page_table_lock (for now) or with preemption disabled (later on): without going to any trouble, minimize the time between reading current values and updating, to minimize those occasions when a racing thread bumps a count up and back down in between. Signed-off-by: Hugh Dickins <hugh@veritas.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-27Revert "remove false BUG_ON() from run_posix_cpu_timers()"Linus Torvalds
This reverts commit 3de463c7d9d58f8cf3395268230cb20a4c15bffa. Roland has another patch that allows us to leave the BUG_ON() in place by just making sure that the condition it tests for really is always true. That goes in next. Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-24[PATCH] posix-timers: remove false BUG_ON() from run_posix_cpu_timers()Oleg Nesterov
do_exit() clears ->it_##clock##_expires, but nothing prevents another cpu to attach the timer to exiting process after that. After exit_notify() does 'write_unlock_irq(&tasklist_lock)' and before do_exit() calls 'schedule() local timer interrupt can find tsk->exit_state != 0. If that state was EXIT_DEAD (or another cpu does sys_wait4) interrupted task has ->signal == NULL. At this moment exiting task has no pending cpu timers, they were cleaned up in __exit_signal()->posix_cpu_timers_exit{,_group}(), so we can just return from irq. Signed-off-by: Oleg Nesterov <oleg@tv-sign.ru> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-21[PATCH] Call exit_itimers from do_exit, not __exit_signalRoland McGrath
When I originally moved exit_itimers into __exit_signal, that was the only place where we could reliably know it was the last thread in the group dying, without races. Since then we've gotten the signal_struct.live counter, and do_exit can reliably do group-wide cleanup work. This patch moves the call to do_exit, where it's made without locks. This avoids the deadlock issues that the old __exit_signal code's comment talks about, and the one that Oleg found recently with process CPU timers. [ This replaces e03d13e985d48ac4885382c9e3b1510c78bd047f, which is why it was just reverted. ] Signed-off-by: Roland McGrath <roland@redhat.com> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-01Fix inequality comparison against "task->state"Linus Torvalds
We should always use bitmask ops, rather than depend on some ordering of the different states. With the TASK_NONINTERACTIVE flag, the inequality doesn't really work. Oleg Nesterov argues (likely correctly) that this test is unnecessary in the first place. However, the minimal fix for now is to at least make it work in the presense of TASK_NONINTERACTIVE. Waiting for consensus from Roland & co on potential bigger cleanups. Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-17[PATCH] files: fix preemption issuesDipankar Sarma
With the new fdtable locking rules, you have to protect fdtable with either ->file_lock or rcu_read_lock/unlock(). There are some places where we aren't doing either. This patch fixes those places. Signed-off-by: Dipankar Sarma <dipankar@in.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-09[PATCH] files: files struct with RCUDipankar Sarma
Patch to eliminate struct files_struct.file_lock spinlock on the reader side and use rcu refcounting rcuref_xxx api for the f_count refcounter. The updates to the fdtable are done by allocating a new fdtable structure and setting files->fdt to point to the new structure. The fdtable structure is protected by RCU thereby allowing lock-free lookup. For fd arrays/sets that are vmalloced, we use keventd to free them since RCU callbacks can't sleep. A global list of fdtable to be freed is not scalable, so we use a per-cpu list. If keventd is already handling the current cpu's work, we use a timer to defer queueing of that work. Since the last publication, this patch has been re-written to avoid using explicit memory barriers and use rcu_assign_pointer(), rcu_dereference() premitives instead. This required that the fd information is kept in a separate structure (fdtable) and updated atomically. Signed-off-by: Dipankar Sarma <dipankar@in.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-09[PATCH] files: break up files structDipankar Sarma
In order for the RCU to work, the file table array, sets and their sizes must be updated atomically. Instead of ensuring this through too many memory barriers, we put the arrays and their sizes in a separate structure. This patch takes the first step of putting the file table elements in a separate structure fdtable that is embedded withing files_struct. It also changes all the users to refer to the file table using files_fdtable() macro. Subsequent applciation of RCU becomes easier after this. Signed-off-by: Dipankar Sarma <dipankar@in.ibm.com> Signed-Off-By: David Howells <dhowells@redhat.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-08-04[PATCH] revert "timer exit cleanup"Andrew Morton
Revert this June 17 patch: it broke persistence of timers across execve(). Cc: Roland McGrath <roland@redhat.com> Cc: george anzinger <george@mvista.com> Cc: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-27[PATCH] Update cfq io scheduler to time sliced designJens Axboe
This updates the CFQ io scheduler to the new time sliced design (cfq v3). It provides full process fairness, while giving excellent aggregate system throughput even for many competing processes. It supports io priorities, either inherited from the cpu nice value or set directly with the ioprio_get/set syscalls. The latter closely mimic set/getpriority. This import is based on my latest from -mm. Signed-off-by: Jens Axboe <axboe@suse.de> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-23[PATCH] Optimize sys_times for a single thread processChristoph Lameter
Avoid taking the tasklist_lock in sys_times if the process is single threaded. In a NUMA system taking the tasklist_lock may cause a bouncing cacheline if multiple independent processes continually call sys_times to measure their performance. Signed-off-by: Christoph Lameter <christoph@lameter.com> Signed-off-by: Shai Fultheim <shai@scalex86.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-23[PATCH] avoid resursive oopsesAlexander Nyberg
Prevent recursive faults in do_exit() by leaving the task alone and wait for reboot. This may allow a more graceful shutdown and possibly save the original oops. Signed-off-by: Alexander Nyberg <alexn@telia.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-17[PATCH] timer exit cleanupIngo Molnar
Do all timer zapping in exit_itimers. Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-05-03[patch] MCA recovery module undefined symbol fixRuss Anderson
The patch "MCA recovery improvements" added do_exit to mca_drv.c. That's fine when the mca recovery code is built in the kernel (CONFIG_IA64_MCA_RECOVERY=y) but breaks building the mca recovery code as a module (CONFIG_IA64_MCA_RECOVERY=m). Most users are currently building this as a module, as loading and unloading the module provides a very convenient way to turn on/off error recovery. This patch exports do_exit, so mca_drv.c can build as a module. Signed-off-by: Russ Anderson (rja@sgi.com) Signed-off-by: Tony Luck <tony.luck@intel.com>
2005-05-01[PATCH] make lots of things staticAdrian Bunk
Another large rollup of various patches from Adrian which make things static where they were needlessly exported. Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-05-01[PATCH] DocBook: changes and extensions to the kernel documentationPavel Pisa
I have recompiled Linux kernel 2.6.11.5 documentation for me and our university students again. The documentation could be extended for more sources which are equipped by structured comments for recent 2.6 kernels. I have tried to proceed with that task. I have done that more times from 2.6.0 time and it gets boring to do same changes again and again. Linux kernel compiles after changes for i386 and ARM targets. I have added references to some more files into kernel-api book, I have added some section names as well. So please, check that changes do not break something and that categories are not too much skewed. I have changed kernel-doc to accept "fastcall" and "asmlinkage" words reserved by kernel convention. Most of the other changes are modifications in the comments to make kernel-doc happy, accept some parameters description and do not bail out on errors. Changed <pid> to @pid in the description, moved some #ifdef before comments to correct function to comments bindings, etc. You can see result of the modified documentation build at http://cmp.felk.cvut.cz/~pisa/linux/lkdb-2.6.11.tar.gz Some more sources are ready to be included into kernel-doc generated documentation. Sources has been added into kernel-api for now. Some more section names added and probably some more chaos introduced as result of quick cleanup work. Signed-off-by: Pavel Pisa <pisa@cmp.felk.cvut.cz> Signed-off-by: Martin Waitz <tali@admingilde.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-05-01[PATCH] convert that currently tests _NSIG directly to use valid_signal()Jesper Juhl
Convert most of the current code that uses _NSIG directly to instead use valid_signal(). This avoids gcc -W warnings and off-by-one errors. Signed-off-by: Jesper Juhl <juhl-lkml@dif.dk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-04-29Remove bogus BUG() in kernel/exit.cLinus Torvalds
It's old sanity checking that may have been useful for debugging, but is just bogus these days. Noticed by Mattia Belletti.
2005-04-16[PATCH] reparent_to_init cleanupCoywolf Qi Hunt
This patch hides reparent_to_init(). reparent_to_init() should only be called by daemonize(). Signed-off-by: Coywolf Qi Hunt <coywolf@lovecn.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
