path: root/kernel/fork.c
2008-07-28mmu-notifiers: coreAndrea Arcangeli
With KVM/GFP/XPMEM there isn't just the primary CPU MMU pointing to pages. There are secondary MMUs (with secondary sptes and secondary tlbs) too. sptes in the kvm case are shadow pagetables, but when I say spte in mmu-notifier context, I mean "secondary pte". In GRU case there's no actual secondary pte and there's only a secondary tlb because the GRU secondary MMU has no knowledge about sptes and every secondary tlb miss event in the MMU always generates a page fault that has to be resolved by the CPU (this is not the case of KVM where the a secondary tlb miss will walk sptes in hardware and it will refill the secondary tlb transparently to software if the corresponding spte is present). The same way zap_page_range has to invalidate the pte before freeing the page, the spte (and secondary tlb) must also be invalidated before any page is freed and reused. Currently we take a page_count pin on every page mapped by sptes, but that means the pages can't be swapped whenever they're mapped by any spte because they're part of the guest working set. Furthermore a spte unmap event can immediately lead to a page to be freed when the pin is released (so requiring the same complex and relatively slow tlb_gather smp safe logic we have in zap_page_range and that can be avoided completely if the spte unmap event doesn't require an unpin of the page previously mapped in the secondary MMU). The mmu notifiers allow kvm/GRU/XPMEM to attach to the tsk->mm and know when the VM is swapping or freeing or doing anything on the primary MMU so that the secondary MMU code can drop sptes before the pages are freed, avoiding all page pinning and allowing 100% reliable swapping of guest physical address space. Furthermore it avoids the code that teardown the mappings of the secondary MMU, to implement a logic like tlb_gather in zap_page_range that would require many IPI to flush other cpu tlbs, for each fixed number of spte unmapped. To make an example: if what happens on the primary MMU is a protection downgrade (from writeable to wrprotect) the secondary MMU mappings will be invalidated, and the next secondary-mmu-page-fault will call get_user_pages and trigger a do_wp_page through get_user_pages if it called get_user_pages with write=1, and it'll re-establishing an updated spte or secondary-tlb-mapping on the copied page. Or it will setup a readonly spte or readonly tlb mapping if it's a guest-read, if it calls get_user_pages with write=0. This is just an example. This allows to map any page pointed by any pte (and in turn visible in the primary CPU MMU), into a secondary MMU (be it a pure tlb like GRU, or an full MMU with both sptes and secondary-tlb like the shadow-pagetable layer with kvm), or a remote DMA in software like XPMEM (hence needing of schedule in XPMEM code to send the invalidate to the remote node, while no need to schedule in kvm/gru as it's an immediate event like invalidating primary-mmu pte). At least for KVM without this patch it's impossible to swap guests reliably. And having this feature and removing the page pin allows several other optimizations that simplify life considerably. Dependencies: 1) mm_take_all_locks() to register the mmu notifier when the whole VM isn't doing anything with "mm". This allows mmu notifier users to keep track if the VM is in the middle of the invalidate_range_begin/end critical section with an atomic counter incraese in range_begin and decreased in range_end. No secondary MMU page fault is allowed to map any spte or secondary tlb reference, while the VM is in the middle of range_begin/end as any page returned by get_user_pages in that critical section could later immediately be freed without any further ->invalidate_page notification (invalidate_range_begin/end works on ranges and ->invalidate_page isn't called immediately before freeing the page). To stop all page freeing and pagetable overwrites the mmap_sem must be taken in write mode and all other anon_vma/i_mmap locks must be taken too. 2) It'd be a waste to add branches in the VM if nobody could possibly run KVM/GRU/XPMEM on the kernel, so mmu notifiers will only enabled if CONFIG_KVM=m/y. In the current kernel kvm won't yet take advantage of mmu notifiers, but this already allows to compile a KVM external module against a kernel with mmu notifiers enabled and from the next pull from kvm.git we'll start using them. And GRU/XPMEM will also be able to continue the development by enabling KVM=m in their config, until they submit all GRU/XPMEM GPLv2 code to the mainline kernel. Then they can also enable MMU_NOTIFIERS in the same way KVM does it (even if KVM=n). This guarantees nobody selects MMU_NOTIFIER=y if KVM and GRU and XPMEM are all =n. The mmu_notifier_register call can fail because mm_take_all_locks may be interrupted by a signal and return -EINTR. Because mmu_notifier_reigster is used when a driver startup, a failure can be gracefully handled. Here an example of the change applied to kvm to register the mmu notifiers. Usually when a driver startups other allocations are required anyway and -ENOMEM failure paths exists already. struct kvm *kvm_arch_create_vm(void) { struct kvm *kvm = kzalloc(sizeof(struct kvm), GFP_KERNEL); + int err; if (!kvm) return ERR_PTR(-ENOMEM); INIT_LIST_HEAD(&kvm->arch.active_mmu_pages); + kvm->arch.mmu_notifier.ops = &kvm_mmu_notifier_ops; + err = mmu_notifier_register(&kvm->arch.mmu_notifier, current->mm); + if (err) { + kfree(kvm); + return ERR_PTR(err); + } + return kvm; } mmu_notifier_unregister returns void and it's reliable. The patch also adds a few needed but missing includes that would prevent kernel to compile after these changes on non-x86 archs (x86 didn't need them by luck). [akpm@linux-foundation.org: coding-style fixes] [akpm@linux-foundation.org: fix mm/filemap_xip.c build] [akpm@linux-foundation.org: fix mm/mmu_notifier.c build] Signed-off-by: Andrea Arcangeli <andrea@qumranet.com> Signed-off-by: Nick Piggin <npiggin@suse.de> Signed-off-by: Christoph Lameter <cl@linux-foundation.org> Cc: Jack Steiner <steiner@sgi.com> Cc: Robin Holt <holt@sgi.com> Cc: Nick Piggin <npiggin@suse.de> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Kanoj Sarcar <kanojsarcar@yahoo.com> Cc: Roland Dreier <rdreier@cisco.com> Cc: Steve Wise <swise@opengridcomputing.com> Cc: Avi Kivity <avi@qumranet.com> Cc: Hugh Dickins <hugh@veritas.com> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: Anthony Liguori <aliguori@us.ibm.com> Cc: Chris Wright <chrisw@redhat.com> Cc: Marcelo Tosatti <marcelo@kvack.org> Cc: Eric Dumazet <dada1@cosmosbay.com> Cc: "Paul E. McKenney" <paulmck@us.ibm.com> Cc: Izik Eidus <izike@qumranet.com> Cc: Anthony Liguori <aliguori@us.ibm.com> Cc: Rik van Riel <riel@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-27task IO accounting: improve code readabilityAndrea Righi
Put all i/o statistics in struct proc_io_accounting and use inline functions to initialize and increment statistics, removing a lot of single variable assignments. This also reduces the kernel size as following (with CONFIG_TASK_XACCT=y and CONFIG_TASK_IO_ACCOUNTING=y). text data bss dec hex filename 11651 0 0 11651 2d83 kernel/exit.o.before 11619 0 0 11619 2d63 kernel/exit.o.after 10886 132 136 11154 2b92 kernel/fork.o.before 10758 132 136 11026 2b12 kernel/fork.o.after 3082029 807968 4818600 8708597 84e1f5 vmlinux.o.before 3081869 807968 4818600 8708437 84e155 vmlinux.o.after Signed-off-by: Andrea Righi <righi.andrea@gmail.com> Acked-by: Oleg Nesterov <oleg@tv-sign.ru> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-26[PATCH] kill altrootAl Viro
long overdue... Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2008-07-26tracehook: vfork-doneRoland McGrath
This moves the PTRACE_EVENT_VFORK_DONE tracing into a tracehook.h inline, tracehook_report_vfork_done(). The change has no effect, just clean-up. Signed-off-by: Roland McGrath <roland@redhat.com> Cc: Oleg Nesterov <oleg@tv-sign.ru> Reviewed-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-26tracehook: cloneRoland McGrath
This moves all the ptrace initialization and tracing logic for task creation into tracehook.h and ptrace.h inlines. It reorganizes the code slightly, but should not change any behavior. There are four tracehook entry points, at each important stage of task creation. This keeps the interface from the core fork.c code fairly clean, while supporting the complex setup required for ptrace or something like it. Signed-off-by: Roland McGrath <roland@redhat.com> Cc: Oleg Nesterov <oleg@tv-sign.ru> Reviewed-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-26SL*B: drop kmem cache argument from constructorAlexey Dobriyan
Kmem cache passed to constructor is only needed for constructors that are themselves multiplexeres. Nobody uses this "feature", nor does anybody uses passed kmem cache in non-trivial way, so pass only pointer to object. Non-trivial places are: arch/powerpc/mm/init_64.c arch/powerpc/mm/hugetlbpage.c This is flag day, yes. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Acked-by: Pekka Enberg <penberg@cs.helsinki.fi> Acked-by: Christoph Lameter <cl@linux-foundation.org> Cc: Jon Tollefson <kniht@linux.vnet.ibm.com> Cc: Nick Piggin <nickpiggin@yahoo.com.au> Cc: Matt Mackall <mpm@selenic.com> [akpm@linux-foundation.org: fix arch/powerpc/mm/hugetlbpage.c] [akpm@linux-foundation.org: fix mm/slab.c] [akpm@linux-foundation.org: fix ubifs] Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-25task IO accounting: provide distinct tgid/tid I/O statisticsAndrea Righi
Report per-thread I/O statistics in /proc/pid/task/tid/io and aggregate parent I/O statistics in /proc/pid/io. This approach follows the same model used to account per-process and per-thread CPU times. As a practial application, this allows for example to quickly find the top I/O consumer when a process spawns many child threads that perform the actual I/O work, because the aggregated I/O statistics can always be found in /proc/pid/io. [ Oleg Nesterov points out that we should check that the task is still alive before we iterate over the threads, but also says that we can do that fixup on top of this later. - Linus ] Acked-by: Balbir Singh <balbir@linux.vnet.ibm.com> Signed-off-by: Andrea Righi <righi.andrea@gmail.com> Cc: Matt Heaton <matt@hostmonster.com> Cc: Shailabh Nagar <nagar@watson.ibm.com> Acked-by-with-comments: Oleg Nesterov <oleg@tv-sign.ru> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-25coredump: move mm->core_waiters into struct core_stateOleg Nesterov
Move mm->core_waiters into "struct core_state" allocated on stack. This shrinks mm_struct a little bit and allows further changes. This patch mostly does s/core_waiters/core_state. The only essential change is that coredump_wait() must clear mm->core_state before return. The coredump_wait()'s path is uglified and .text grows by 30 bytes, this is fixed by the next patch. Signed-off-by: Oleg Nesterov <oleg@tv-sign.ru> Cc: Roland McGrath <roland@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-25kill PF_BORROWED_MM in favour of PF_KTHREADOleg Nesterov
Kill PF_BORROWED_MM. Change use_mm/unuse_mm to not play with ->flags, and do s/PF_BORROWED_MM/PF_KTHREAD/ for a couple of other users. No functional changes yet. But this allows us to do further fixes/cleanups. oom_kill/ptrace/etc often check "p->mm != NULL" to filter out the kthreads, this is wrong because of use_mm(). The problem with PF_BORROWED_MM is that we need task_lock() to avoid races. With this patch we can check PF_KTHREAD directly, or use a simple lockless helper: /* The result must not be dereferenced !!! */ struct mm_struct *__get_task_mm(struct task_struct *tsk) { if (tsk->flags & PF_KTHREAD) return NULL; return tsk->mm; } Note also ecard_task(). It runs with ->mm != NULL, but it's the kernel thread without PF_BORROWED_MM. Signed-off-by: Oleg Nesterov <oleg@tv-sign.ru> Cc: Roland McGrath <roland@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-25cgroup_clone: use pid of newly created task for new cgroupSerge E. Hallyn
cgroup_clone creates a new cgroup with the pid of the task. This works correctly for unshare, but for clone cgroup_clone is called from copy_namespaces inside copy_process, which happens before the new pid is created. As a result, the new cgroup was created with current's pid. This patch: 1. Moves the call inside copy_process to after the new pid is created 2. Passes the struct pid into ns_cgroup_clone (as it is not yet attached to the task) 3. Passes a name from ns_cgroup_clone() into cgroup_clone() so as to keep cgroup_clone() itself simpler 4. Uses pid_vnr() to get the process id value, so that the pid used to name the new cgroup is always the pid as it would be known to the task which did the cloning or unsharing. I think that is the most intuitive thing to do. This way, task t1 does clone(CLONE_NEWPID) to get t2, which does clone(CLONE_NEWPID) to get t3, then the cgroup for t3 will be named for the pid by which t2 knows t3. (Thanks to Dan Smith for finding the main bug) Changelog: June 11: Incorporate Paul Menage's feedback: don't pass NULL to ns_cgroup_clone from unshare, and reduce patch size by using 'nodename' in cgroup_clone. June 10: Original version [akpm@linux-foundation.org: build fix] [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Serge Hallyn <serge@us.ibm.com> Acked-by: Paul Menage <menage@google.com> Tested-by: Dan Smith <danms@us.ibm.com> Cc: Balbir Singh <balbir@in.ibm.com> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-25clean up duplicated alloc/free_thread_infoFUJITA Tomonori
We duplicate alloc/free_thread_info defines on many platforms (the majority uses __get_free_pages/free_pages). This patch defines common defines and removes these duplicated defines. __HAVE_ARCH_THREAD_INFO_ALLOCATOR is introduced for platforms that do something different. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Acked-by: Russell King <rmk+kernel@arm.linux.org.uk> Cc: Pekka Enberg <penberg@cs.helsinki.fi> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-24hugetlb: reserve huge pages for reliable MAP_PRIVATE hugetlbfs mappings ↵Mel Gorman
until fork() This patch reserves huge pages at mmap() time for MAP_PRIVATE mappings in a similar manner to the reservations taken for MAP_SHARED mappings. The reserve count is accounted both globally and on a per-VMA basis for private mappings. This guarantees that a process that successfully calls mmap() will successfully fault all pages in the future unless fork() is called. The characteristics of private mappings of hugetlbfs files behaviour after this patch are; 1. The process calling mmap() is guaranteed to succeed all future faults until it forks(). 2. On fork(), the parent may die due to SIGKILL on writes to the private mapping if enough pages are not available for the COW. For reasonably reliable behaviour in the face of a small huge page pool, children of hugepage-aware processes should not reference the mappings; such as might occur when fork()ing to exec(). 3. On fork(), the child VMAs inherit no reserves. Reads on pages already faulted by the parent will succeed. Successful writes will depend on enough huge pages being free in the pool. 4. Quotas of the hugetlbfs mount are checked at reserve time for the mapper and at fault time otherwise. Before this patch, all reads or writes in the child potentially needs page allocations that can later lead to the death of the parent. This applies to reads and writes of uninstantiated pages as well as COW. After the patch it is only a write to an instantiated page that causes problems. Signed-off-by: Mel Gorman <mel@csn.ul.ie> Acked-by: Adam Litke <agl@us.ibm.com> Cc: Andy Whitcroft <apw@shadowen.org> Cc: William Lee Irwin III <wli@holomorphy.com> Cc: Hugh Dickins <hugh@veritas.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-16ptrace children revampRoland McGrath
ptrace no longer fiddles with the children/sibling links, and the old ptrace_children list is gone. Now ptrace, whether of one's own children or another's via PTRACE_ATTACH, just uses the new ptraced list instead. There should be no user-visible difference that matters. The only change is the order in which do_wait() sees multiple stopped children and stopped ptrace attachees. Since wait_task_stopped() was changed earlier so it no longer reorders the children list, we already know this won't cause any new problems. Signed-off-by: Roland McGrath <roland@redhat.com>
2008-07-14Merge branch 'core/locking' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'core/locking' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: lockdep: fix kernel/fork.c warning lockdep: fix ftrace irq tracing false positive lockdep: remove duplicate definition of STATIC_LOCKDEP_MAP_INIT lockdep: add lock_class information to lock_chain and output it lockdep: add lock_class information to lock_chain and output it lockdep: output lock_class key instead of address for forward dependency output __mutex_lock_common: use signal_pending_state() mutex-debug: check mutex magic before owner Fixed up conflict in kernel/fork.c manually
2008-07-14Merge branch 'tracing/for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'tracing/for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (228 commits) ftrace: build fix for ftraced_suspend ftrace: separate out the function enabled variable ftrace: add ftrace_kill_atomic ftrace: use current CPU for function startup ftrace: start wakeup tracing after setting function tracer ftrace: check proper config for preempt type ftrace: trace schedule ftrace: define function trace nop ftrace: move sched_switch enable after markers ftrace: prevent ftrace modifications while being kprobe'd, v2 fix "ftrace: store mcount address in rec->ip" mmiotrace broken in linux-next (8-bit writes only) ftrace: avoid modifying kprobe'd records ftrace: freeze kprobe'd records kprobes: enable clean usage of get_kprobe ftrace: store mcount address in rec->ip ftrace: build fix with gcc 4.3 namespacecheck: fixes ftrace: fix "notrace" filtering priority ftrace: fix printout ...
2008-07-14lockdep: fix kernel/fork.c warningIngo Molnar
fix: [ 0.184011] ------------[ cut here ]------------ [ 0.188011] WARNING: at kernel/fork.c:918 copy_process+0x1c0/0x1084() [ 0.192011] Pid: 0, comm: swapper Not tainted 2.6.26-tip-00351-g01d4a50-dirty #14521 [ 0.196011] [<c0135d48>] warn_on_slowpath+0x3c/0x60 [ 0.200012] [<c016f805>] ? __alloc_pages_internal+0x92/0x36b [ 0.208012] [<c033de5e>] ? __spin_lock_init+0x24/0x4a [ 0.212012] [<c01347e3>] copy_process+0x1c0/0x1084 [ 0.216013] [<c013575f>] do_fork+0xb8/0x1ad [ 0.220013] [<c034f75e>] ? acpi_os_release_lock+0x8/0xa [ 0.228013] [<c034ff7a>] ? acpi_os_vprintf+0x20/0x24 [ 0.232014] [<c01129ee>] kernel_thread+0x75/0x7d [ 0.236014] [<c0a491eb>] ? kernel_init+0x0/0x24a [ 0.240014] [<c0a491eb>] ? kernel_init+0x0/0x24a [ 0.244014] [<c01151b0>] ? kernel_thread_helper+0x0/0x10 [ 0.252015] [<c06c6ac0>] rest_init+0x14/0x50 [ 0.256015] [<c0a498ce>] start_kernel+0x2b9/0x2c0 [ 0.260015] [<c0a4904f>] __init_begin+0x4f/0x57 [ 0.264016] ======================= [ 0.268016] ---[ end trace 4eaa2a86a8e2da22 ]--- [ 0.272016] enabled ExtINT on CPU#0 which occurs if CONFIG_TRACE_IRQFLAGS=y, CONFIG_DEBUG_LOCKDEP=y, but CONFIG_PROVE_LOCKING is disabled. Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-07-03block: blkdev.h cleanup, move iocontext stuff to iocontext.hJens Axboe
2008-05-23ftrace: trace irq disabled critical timingsSteven Rostedt
This patch adds latency tracing for critical timings (how long interrupts are disabled for). "irqsoff" is added to /debugfs/tracing/available_tracers Note: tracing_max_latency also holds the max latency for irqsoff (in usecs). (default to large number so one must start latency tracing) tracing_thresh threshold (in usecs) to always print out if irqs off is detected to be longer than stated here. If irq_thresh is non-zero, then max_irq_latency is ignored. Here's an example of a trace with ftrace_enabled = 0 ======= preemption latency trace v1.1.5 on 2.6.24-rc7 Signed-off-by: Ingo Molnar <mingo@elte.hu> -------------------------------------------------------------------- latency: 100 us, #3/3, CPU#1 | (M:rt VP:0, KP:0, SP:0 HP:0 #P:2) ----------------- | task: swapper-0 (uid:0 nice:0 policy:0 rt_prio:0) ----------------- => started at: _spin_lock_irqsave+0x2a/0xb7 => ended at: _spin_unlock_irqrestore+0x32/0x5f _------=> CPU# / _-----=> irqs-off | / _----=> need-resched || / _---=> hardirq/softirq ||| / _--=> preempt-depth |||| / ||||| delay cmd pid ||||| time | caller \ / ||||| \ | / swapper-0 1d.s3 0us+: _spin_lock_irqsave+0x2a/0xb7 (e1000_update_stats+0x47/0x64c [e1000]) swapper-0 1d.s3 100us : _spin_unlock_irqrestore+0x32/0x5f (e1000_update_stats+0x641/0x64c [e1000]) swapper-0 1d.s3 100us : trace_hardirqs_on_caller+0x75/0x89 (_spin_unlock_irqrestore+0x32/0x5f) vim:ft=help ======= And this is a trace with ftrace_enabled == 1 ======= preemption latency trace v1.1.5 on 2.6.24-rc7 -------------------------------------------------------------------- latency: 102 us, #12/12, CPU#1 | (M:rt VP:0, KP:0, SP:0 HP:0 #P:2) ----------------- | task: swapper-0 (uid:0 nice:0 policy:0 rt_prio:0) ----------------- => started at: _spin_lock_irqsave+0x2a/0xb7 => ended at: _spin_unlock_irqrestore+0x32/0x5f _------=> CPU# / _-----=> irqs-off | / _----=> need-resched || / _---=> hardirq/softirq ||| / _--=> preempt-depth |||| / ||||| delay cmd pid ||||| time | caller \ / ||||| \ | / swapper-0 1dNs3 0us+: _spin_lock_irqsave+0x2a/0xb7 (e1000_update_stats+0x47/0x64c [e1000]) swapper-0 1dNs3 46us : e1000_read_phy_reg+0x16/0x225 [e1000] (e1000_update_stats+0x5e2/0x64c [e1000]) swapper-0 1dNs3 46us : e1000_swfw_sync_acquire+0x10/0x99 [e1000] (e1000_read_phy_reg+0x49/0x225 [e1000]) swapper-0 1dNs3 46us : e1000_get_hw_eeprom_semaphore+0x12/0xa6 [e1000] (e1000_swfw_sync_acquire+0x36/0x99 [e1000]) swapper-0 1dNs3 47us : __const_udelay+0x9/0x47 (e1000_read_phy_reg+0x116/0x225 [e1000]) swapper-0 1dNs3 47us+: __delay+0x9/0x50 (__const_udelay+0x45/0x47) swapper-0 1dNs3 97us : preempt_schedule+0xc/0x84 (__delay+0x4e/0x50) swapper-0 1dNs3 98us : e1000_swfw_sync_release+0xc/0x55 [e1000] (e1000_read_phy_reg+0x211/0x225 [e1000]) swapper-0 1dNs3 99us+: e1000_put_hw_eeprom_semaphore+0x9/0x35 [e1000] (e1000_swfw_sync_release+0x50/0x55 [e1000]) swapper-0 1dNs3 101us : _spin_unlock_irqrestore+0xe/0x5f (e1000_update_stats+0x641/0x64c [e1000]) swapper-0 1dNs3 102us : _spin_unlock_irqrestore+0x32/0x5f (e1000_update_stats+0x641/0x64c [e1000]) swapper-0 1dNs3 102us : trace_hardirqs_on_caller+0x75/0x89 (_spin_unlock_irqrestore+0x32/0x5f) vim:ft=help ======= Signed-off-by: Steven Rostedt <srostedt@redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-05-16[PATCH] dup_fd() fixes, part 1Al Viro
Move the sucker to fs/file.c in preparation to the rest Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2008-05-01[PATCH] split linux/file.hAl Viro
Initial splitoff of the low-level stuff; taken to fdtable.h Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2008-04-30signals: microoptimize the usage of ->curr_targetOleg Nesterov
Suggested by Roland McGrath. Initialize signal->curr_target in copy_signal(). This way ->curr_target is never == NULL, we can kill the check in __group_complete_signal's hot path. Signed-off-by: Oleg Nesterov <oleg@tv-sign.ru> Cc: Roland McGrath <roland@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-29procfs task exe symlinkMatt Helsley
The kernel implements readlink of /proc/pid/exe by getting the file from the first executable VMA. Then the path to the file is reconstructed and reported as the result. Because of the VMA walk the code is slightly different on nommu systems. This patch avoids separate /proc/pid/exe code on nommu systems. Instead of walking the VMAs to find the first executable file-backed VMA we store a reference to the exec'd file in the mm_struct. That reference would prevent the filesystem holding the executable file from being unmounted even after unmapping the VMAs. So we track the number of VM_EXECUTABLE VMAs and drop the new reference when the last one is unmapped. This avoids pinning the mounted filesystem. [akpm@linux-foundation.org: improve comments] [yamamoto@valinux.co.jp: fix dup_mmap] Signed-off-by: Matt Helsley <matthltc@us.ibm.com> Cc: Oleg Nesterov <oleg@tv-sign.ru> Cc: David Howells <dhowells@redhat.com> Cc:"Eric W. Biederman" <ebiederm@xmission.com> Cc: Christoph Hellwig <hch@lst.de> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Hugh Dickins <hugh@veritas.com> Signed-off-by: YAMAMOTO Takashi <yamamoto@valinux.co.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-29ipc: sysvsem: force unshare(CLONE_SYSVSEM) when CLONE_NEWIPCManfred Spraul
sys_unshare(CLONE_NEWIPC) doesn't handle the undo lists properly, this can cause a kernel memory corruption. CLONE_NEWIPC must detach from the existing undo lists. Fix, part 2: perform an implicit CLONE_SYSVSEM in CLONE_NEWIPC. CLONE_NEWIPC creates a new IPC namespace, the task cannot access the existing semaphore arrays after the unshare syscall. Thus the task can/must detach from the existing undo list entries, too. This fixes the kernel corruption, because it makes it impossible that undo records from two different namespaces are in sysvsem.undo_list. Signed-off-by: Manfred Spraul <manfred@colorfullife.com> Signed-off-by: Serge E. Hallyn <serue@us.ibm.com> Acked-by: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Pavel Emelyanov <xemul@openvz.org> Cc: Michael Kerrisk <mtk.manpages@googlemail.com> Cc: Pierre Peiffer <peifferp@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-29ipc: sysvsem: implement sys_unshare(CLONE_SYSVSEM)Manfred Spraul
sys_unshare(CLONE_NEWIPC) doesn't handle the undo lists properly, this can cause a kernel memory corruption. CLONE_NEWIPC must detach from the existing undo lists. Fix, part 1: add support for sys_unshare(CLONE_SYSVSEM) The original reason to not support it was the potential (inevitable?) confusion due to the fact that sys_unshare(CLONE_SYSVSEM) has the inverse meaning of clone(CLONE_SYSVSEM). Our two most reasonable options then appear to be (1) fully support CLONE_SYSVSEM, or (2) continue to refuse explicit CLONE_SYSVSEM, but always do it anyway on unshare(CLONE_SYSVSEM). This patch does (1). Changelog: Apr 16: SEH: switch to Manfred's alternative patch which removes the unshare_semundo() function which always refused CLONE_SYSVSEM. Signed-off-by: Manfred Spraul <manfred@colorfullife.com> Signed-off-by: Serge E. Hallyn <serue@us.ibm.com> Acked-by: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Pavel Emelyanov <xemul@openvz.org> Cc: Michael Kerrisk <mtk.manpages@googlemail.com> Cc: Pierre Peiffer <peifferp@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-29cgroups: add an owner to the mm_structBalbir Singh
Remove the mem_cgroup member from mm_struct and instead adds an owner. This approach was suggested by Paul Menage. The advantage of this approach is that, once the mm->owner is known, using the subsystem id, the cgroup can be determined. It also allows several control groups that are virtually grouped by mm_struct, to exist independent of the memory controller i.e., without adding mem_cgroup's for each controller, to mm_struct. A new config option CONFIG_MM_OWNER is added and the memory resource controller selects this config option. This patch also adds cgroup callbacks to notify subsystems when mm->owner changes. The mm_cgroup_changed callback is called with the task_lock() of the new task held and is called just prior to changing the mm->owner. I am indebted to Paul Menage for the several reviews of this patchset and helping me make it lighter and simpler. This patch was tested on a powerpc box, it was compiled with both the MM_OWNER config turned on and off. After the thread group leader exits, it's moved to init_css_state by cgroup_exit(), thus all future charges from runnings threads would be redirected to the init_css_set's subsystem. Signed-off-by: Balbir Singh <balbir@linux.vnet.ibm.com> Cc: Pavel Emelianov <xemul@openvz.org> Cc: Hugh Dickins <hugh@veritas.com> Cc: Sudhir Kumar <skumar@linux.vnet.ibm.com> Cc: YAMAMOTO Takashi <yamamoto@valinux.co.jp> Cc: Hirokazu Takahashi <taka@valinux.co.jp> Cc: David Rientjes <rientjes@google.com>, Cc: Balbir Singh <balbir@linux.vnet.ibm.com> Acked-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Acked-by: Pekka Enberg <penberg@cs.helsinki.fi> Reviewed-by: Paul Menage <menage@google.com> Cc: Oleg Nesterov <oleg@tv-sign.ru> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-28mempolicy: rename mpol_copy to mpol_dupLee Schermerhorn
This patch renames mpol_copy() to mpol_dup() because, well, that's what it does. Like, e.g., strdup() for strings, mpol_dup() takes a pointer to an existing mempolicy, allocates a new one and copies the contents. In a later patch, I want to use the name mpol_copy() to copy the contents from one mempolicy to another like, e.g., strcpy() does for strings. Signed-off-by: Lee Schermerhorn <lee.schermerhorn@hp.com> Cc: Christoph Lameter <clameter@sgi.com> Cc: David Rientjes <rientjes@google.com> Cc: Mel Gorman <mel@csn.ul.ie> Cc: Andi Kleen <ak@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-28mempolicy: rename mpol_free to mpol_putLee Schermerhorn
This is a change that was requested some time ago by Mel Gorman. Makes sense to me, so here it is. Note: I retain the name "mpol_free_shared_policy()" because it actually does free the shared_policy, which is NOT a reference counted object. However, ... The mempolicy object[s] referenced by the shared_policy are reference counted, so mpol_put() is used to release the reference held by the shared_policy. The mempolicy might not be freed at this time, because some task attached to the shared object associated with the shared policy may be in the process of allocating a page based on the mempolicy. In that case, the task performing the allocation will hold a reference on the mempolicy, obtained via mpol_shared_policy_lookup(). The mempolicy will be freed when all tasks holding such a reference have called mpol_put() for the mempolicy. Signed-off-by: Lee Schermerhorn <lee.schermerhorn@hp.com> Cc: Christoph Lameter <clameter@sgi.com> Cc: David Rientjes <rientjes@google.com> Cc: Mel Gorman <mel@csn.ul.ie> Cc: Andi Kleen <ak@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-27s390: KVM preparation: provide hook to enable pgstes in user pagetableCarsten Otte
The SIE instruction on s390 uses the 2nd half of the page table page to virtualize the storage keys of a guest. This patch offers the s390_enable_sie function, which reorganizes the page tables of a single-threaded process to reserve space in the page table: s390_enable_sie makes sure that the process is single threaded and then uses dup_mm to create a new mm with reorganized page tables. The old mm is freed and the process has now a page status extended field after every page table. Code that wants to exploit pgstes should SELECT CONFIG_PGSTE. This patch has a small common code hit, namely making dup_mm non-static. Edit (Carsten): I've modified Martin's patch, following Jeremy Fitzhardinge's review feedback. Now we do have the prototype for dup_mm in include/linux/sched.h. Following Martin's suggestion, s390_enable_sie() does now call task_lock() to prevent race against ptrace modification of mm_users. Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Carsten Otte <cotte@de.ibm.com> Acked-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Avi Kivity <avi@qumranet.com>
2008-04-26Fix uninitialized 'copy' in unshare_filesAl Viro
Arrgghhh... Sorry about that, I'd been sure I'd folded that one, but it actually got lost. Please apply - that breaks execve(). Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Tested-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-25[PATCH] sanitize unshare_files/reset_files_structAl Viro
* let unshare_files() give caller the displaced files_struct * don't bother with grabbing reference only to drop it in the caller if it hadn't been shared in the first place * in that form unshare_files() is trivially implemented via unshare_fd(), so we eliminate the duplicate logics in fork.c * reset_files_struct() is not just only called for current; it will break the system if somebody ever calls it for anything else (we can't modify ->files of somebody else). Lose the task_struct * argument. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2008-04-25[PATCH] sanitize handling of shared descriptor tables in failing execve()Al Viro
* unshare_files() can fail; doing it after irreversible actions is wrong and de_thread() is certainly irreversible. * since we do it unconditionally anyway, we might as well do it in do_execve() and save ourselves the PITA in binfmt handlers, etc. * while we are at it, binfmt_som actually leaked files_struct on failure. As a side benefit, unshare_files(), put_files_struct() and reset_files_struct() become unexported. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2008-04-25[PATCH] close race in unshare_files()Al Viro
updating current->files requires task_lock Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2008-04-19x86: fpu xstate split fixSuresh Siddha
2008-04-19x86, fpu: split FPU state from task struct - v5Suresh Siddha
Split the FPU save area from the task struct. This allows easy migration of FPU context, and it's generally cleaner. It also allows the following two optimizations: 1) only allocate when the application actually uses FPU, so in the first lazy FPU trap. This could save memory for non-fpu using apps. Next patch does this lazy allocation. 2) allocate the right size for the actual cpu rather than 512 bytes always. Patches enabling xsave/xrstor support (coming shortly) will take advantage of this. Signed-off-by: Suresh Siddha <suresh.b.siddha@intel.com> Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-03-28memcgroup: fix spurious EBUSY on memory cgroup removalYAMAMOTO Takashi
Call mm_free_cgroup earlier. Otherwise a reference due to lazy mm switching can prevent cgroup removal. Signed-off-by: YAMAMOTO Takashi <yamamoto@valinux.co.jp> Acked-by: Balbir Singh <balbir@linux.vnet.ibm.com> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Paul Menage <menage@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-14Use struct path in fs_structJan Blunck
* Use struct path in fs_struct. Signed-off-by: Andreas Gruenbacher <agruen@suse.de> Signed-off-by: Jan Blunck <jblunck@suse.de> Acked-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-08kernel: remove fastcall in kernel/*Harvey Harrison
[akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Acked-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-08Pidns: make full use of xxx_vnr() callsPavel Emelyanov
Some time ago the xxx_vnr() calls (e.g. pid_vnr or find_task_by_vpid) were _all_ converted to operate on the current pid namespace. After this each call like xxx_nr_ns(foo, current->nsproxy->pid_ns) is nothing but a xxx_vnr(foo) one. Switch all the xxx_nr_ns() callers to use the xxx_vnr() calls where appropriate. Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Reviewed-by: Oleg Nesterov <oleg@tv-sign.ru> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Balbir Singh <balbir@in.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-08ITIMER_REAL: convert to use struct pidOleg Nesterov
signal_struct->tsk points to the ->group_leader and thus we have the nasty code in de_thread() which has to change it and restart ->real_timer if the leader is changed. Use "struct pid *leader_pid" instead. This also allows us to kill now unneeded send_group_sig_info(). Signed-off-by: Oleg Nesterov <oleg@tv-sign.ru> Acked-by: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Davide Libenzi <davidel@xmailserver.org> Cc: Pavel Emelyanov <xemul@openvz.org> Acked-by: Roland McGrath <roland@redhat.com> Acked-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-07Memory controller: accounting setupPavel Emelianov
Basic setup routines, the mm_struct has a pointer to the cgroup that it belongs to and the the page has a page_cgroup associated with it. Signed-off-by: Pavel Emelianov <xemul@openvz.org> Signed-off-by: Balbir Singh <balbir@linux.vnet.ibm.com> Cc: Paul Menage <menage@google.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Nick Piggin <nickpiggin@yahoo.com.au> Cc: Kirill Korotaev <dev@sw.ru> Cc: Herbert Poetzl <herbert@13thfloor.at> Cc: David Rientjes <rientjes@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-06idle_regs() must be __cpuinitAdrian Bunk
Fix the following section mismatch with CONFIG_HOTPLUG=n, CONFIG_HOTPLUG_CPU=y: WARNING: vmlinux.o(.text+0x399a6): Section mismatch: reference to .init.text.5:idle_regs (between 'fork_idle' and 'get_task_mm') Signed-off-by: Adrian Bunk <bunk@kernel.org> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: "Luck, Tony" <tony.luck@intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-06use __set_task_state() for TRACED/STOPPED tasksOleg Nesterov
1. It is much easier to grep for ->state change if __set_task_state() is used instead of the direct assignment. 2. ptrace_stop() and handle_group_stop() use set_task_state() which adds the unneeded mb() (btw even if we use mb() it is still possible that do_wait() sees the new ->state but not ->exit_code, but this is ok). Signed-off-by: Oleg Nesterov <oleg@tv-sign.ru> Acked-by: Roland McGrath <roland@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-05capabilities: introduce per-process capability bounding setSerge E. Hallyn
The capability bounding set is a set beyond which capabilities cannot grow. Currently cap_bset is per-system. It can be manipulated through sysctl, but only init can add capabilities. Root can remove capabilities. By default it includes all caps except CAP_SETPCAP. This patch makes the bounding set per-process when file capabilities are enabled. It is inherited at fork from parent. Noone can add elements, CAP_SETPCAP is required to remove them. One example use of this is to start a safer container. For instance, until device namespaces or per-container device whitelists are introduced, it is best to take CAP_MKNOD away from a container. The bounding set will not affect pP and pE immediately. It will only affect pP' and pE' after subsequent exec()s. It also does not affect pI, and exec() does not constrain pI'. So to really start a shell with no way of regain CAP_MKNOD, you would do prctl(PR_CAPBSET_DROP, CAP_MKNOD); cap_t cap = cap_get_proc(); cap_value_t caparray[1]; caparray[0] = CAP_MKNOD; cap_set_flag(cap, CAP_INHERITABLE, 1, caparray, CAP_DROP); cap_set_proc(cap); cap_free(cap); The following test program will get and set the bounding set (but not pI). For instance ./bset get (lists capabilities in bset) ./bset drop cap_net_raw (starts shell with new bset) (use capset, setuid binary, or binary with file capabilities to try to increase caps) ************************************************************ cap_bound.c ************************************************************ #include <sys/prctl.h> #include <linux/capability.h> #include <sys/types.h> #include <unistd.h> #include <stdio.h> #include <stdlib.h> #include <string.h> #ifndef PR_CAPBSET_READ #define PR_CAPBSET_READ 23 #endif #ifndef PR_CAPBSET_DROP #define PR_CAPBSET_DROP 24 #endif int usage(char *me) { printf("Usage: %s get\n", me); printf(" %s drop <capability>\n", me); return 1; } #define numcaps 32 char *captable[numcaps] = { "cap_chown", "cap_dac_override", "cap_dac_read_search", "cap_fowner", "cap_fsetid", "cap_kill", "cap_setgid", "cap_setuid", "cap_setpcap", "cap_linux_immutable", "cap_net_bind_service", "cap_net_broadcast", "cap_net_admin", "cap_net_raw", "cap_ipc_lock", "cap_ipc_owner", "cap_sys_module", "cap_sys_rawio", "cap_sys_chroot", "cap_sys_ptrace", "cap_sys_pacct", "cap_sys_admin", "cap_sys_boot", "cap_sys_nice", "cap_sys_resource", "cap_sys_time", "cap_sys_tty_config", "cap_mknod", "cap_lease", "cap_audit_write", "cap_audit_control", "cap_setfcap" }; int getbcap(void) { int comma=0; unsigned long i; int ret; printf("i know of %d capabilities\n", numcaps); printf("capability bounding set:"); for (i=0; i<numcaps; i++) { ret = prctl(PR_CAPBSET_READ, i); if (ret < 0) perror("prctl"); else if (ret==1) printf("%s%s", (comma++) ? ", " : " ", captable[i]); } printf("\n"); return 0; } int capdrop(char *str) { unsigned long i; int found=0; for (i=0; i<numcaps; i++) { if (strcmp(captable[i], str) == 0) { found=1; break; } } if (!found) return 1; if (prctl(PR_CAPBSET_DROP, i)) { perror("prctl"); return 1; } return 0; } int main(int argc, char *argv[]) { if (argc<2) return usage(argv[0]); if (strcmp(argv[1], "get")==0) return getbcap(); if (strcmp(argv[1], "drop")!=0 || argc<3) return usage(argv[0]); if (capdrop(argv[2])) { printf("unknown capability\n"); return 1; } return execl("/bin/bash", "/bin/bash", NULL); } ************************************************************ [serue@us.ibm.com: fix typo] Signed-off-by: Serge E. Hallyn <serue@us.ibm.com> Signed-off-by: Andrew G. Morgan <morgan@kernel.org> Cc: Stephen Smalley <sds@tycho.nsa.gov> Cc: James Morris <jmorris@namei.org> Cc: Chris Wright <chrisw@sous-sol.org> Cc: Casey Schaufler <casey@schaufler-ca.com>a Signed-off-by: "Serge E. Hallyn" <serue@us.ibm.com> Tested-by: Jiri Slaby <jirislaby@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-05add mm argument to pte/pmd/pud/pgd_freeBenjamin Herrenschmidt
(with Martin Schwidefsky <schwidefsky@de.ibm.com>) The pgd/pud/pmd/pte page table allocation functions get a mm_struct pointer as first argument. The free functions do not get the mm_struct argument. This is 1) asymmetrical and 2) to do mm related page table allocations the mm argument is needed on the free function as well. [kamalesh@linux.vnet.ibm.com: i386 fix] [akpm@linux-foundation.org: coding-syle fixes] Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Kamalesh Babulal <kamalesh@linux.vnet.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-05clone: prepare to recycle CLONE_STOPPEDAndrew Morton
Ulrich says that we never used this clone flags and that nothing should be using it. As we're down to only a single bit left in clone's flags argument, let's add a warning to check that no userspace is actually using it. Hopefully we will be able to recycle it. Roland said: CLONE_STOPPED was previously used by some NTPL versions when under thread_db (i.e. only when being actively debugged by gdb), but not for a long time now, and it never worked reliably when it was used. Removing it seems fine to me. [akpm@linux-foundation.org: it looks like CLONE_DETACHED is being used] Cc: Ulrich Drepper <drepper@redhat.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Roland McGrath <roland@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-01-30KVM: Disallow fork() and similar games when using a VMAvi Kivity
We don't want the meaning of guest userspace changing under our feet. Signed-off-by: Avi Kivity <avi@qumranet.com>
2008-01-28kernel: add CLONE_IO to specifically request sharing of IO contextsJens Axboe
syslets (or other threads/processes that want io context sharing) can set this to enforce sharing of io context. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-01-28io context sharing: preliminary supportJens Axboe
Detach task state from ioc, instead keep track of how many processes are accessing the ioc. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-01-28ioprio: move io priority from task_struct to io_contextJens Axboe
This is where it belongs and then it doesn't take up space for a process that doesn't do IO. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-01-25sched: latencytop supportArjan van de Ven
LatencyTOP kernel infrastructure; it measures latencies in the scheduler and tracks it system wide and per process. Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
