path: root/kernel/fork.c
2012-06-10mm/fork: fix overflow in vma length when copying mmap on cloneSiddhesh Poyarekar
commit 7edc8b0ac16cbaed7cb4ea4c6b95ce98d2997e84 upstream. The vma length in dup_mmap is calculated and stored in a unsigned int, which is insufficient and hence overflows for very large maps (beyond 16TB). The following program demonstrates this: #include <stdio.h> #include <unistd.h> #include <sys/mman.h> #define GIG 1024 * 1024 * 1024L #define EXTENT 16393 int main(void) { int i, r; void *m; char buf[1024]; for (i = 0; i < EXTENT; i++) { m = mmap(NULL, (size_t) 1 * 1024 * 1024 * 1024L, PROT_READ | PROT_WRITE, MAP_PRIVATE | MAP_ANONYMOUS, 0, 0); if (m == (void *)-1) printf("MMAP Failed: %d\n", m); else printf("%d : MMAP returned %p\n", i, m); r = fork(); if (r == 0) { printf("%d: successed\n", i); return 0; } else if (r < 0) printf("FORK Failed: %d\n", r); else if (r > 0) wait(NULL); } return 0; } Increase the storage size of the result to unsigned long, which is sufficient for storing the difference between addresses. Signed-off-by: Siddhesh Poyarekar <siddhesh.poyarekar@gmail.com> Cc: Tejun Heo <tj@kernel.org> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Jens Axboe <axboe@kernel.dk> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Acked-by: Hugh Dickins <hughd@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-05-10namespaces, pid_ns: fix leakage on fork() failureMike Galbraith
Fork() failure post namespace creation for a child cloned with CLONE_NEWPID leaks pid_namespace/mnt_cache due to proc being mounted during creation, but not unmounted during cleanup. Call pid_ns_release_proc() during cleanup. Signed-off-by: Mike Galbraith <efault@gmx.de> Acked-by: Oleg Nesterov <oleg@redhat.com> Reviewed-by: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Pavel Emelyanov <xemul@parallels.com> Cc: Cyrill Gorcunov <gorcunov@openvz.org> Cc: Louis Rilling <louis.rilling@kerlabs.com> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-03-23prctl: add PR_{SET,GET}_CHILD_SUBREAPER to allow simple process supervisionLennart Poettering
Userspace service managers/supervisors need to track their started services. Many services daemonize by double-forking and get implicitly re-parented to PID 1. The service manager will no longer be able to receive the SIGCHLD signals for them, and is no longer in charge of reaping the children with wait(). All information about the children is lost at the moment PID 1 cleans up the re-parented processes. With this prctl, a service manager process can mark itself as a sort of 'sub-init', able to stay as the parent for all orphaned processes created by the started services. All SIGCHLD signals will be delivered to the service manager. Receiving SIGCHLD and doing wait() is in cases of a service-manager much preferred over any possible asynchronous notification about specific PIDs, because the service manager has full access to the child process data in /proc and the PID can not be re-used until the wait(), the service-manager itself is in charge of, has happened. As a side effect, the relevant parent PID information does not get lost by a double-fork, which results in a more elaborate process tree and 'ps' output: before: # ps afx 253 ? Ss 0:00 /bin/dbus-daemon --system --nofork 294 ? Sl 0:00 /usr/libexec/polkit-1/polkitd 328 ? S 0:00 /usr/sbin/modem-manager 608 ? Sl 0:00 /usr/libexec/colord 658 ? Sl 0:00 /usr/libexec/upowerd 819 ? Sl 0:00 /usr/libexec/imsettings-daemon 916 ? Sl 0:00 /usr/libexec/udisks-daemon 917 ? S 0:00 \_ udisks-daemon: not polling any devices after: # ps afx 294 ? Ss 0:00 /bin/dbus-daemon --system --nofork 426 ? Sl 0:00 \_ /usr/libexec/polkit-1/polkitd 449 ? S 0:00 \_ /usr/sbin/modem-manager 635 ? Sl 0:00 \_ /usr/libexec/colord 705 ? Sl 0:00 \_ /usr/libexec/upowerd 959 ? Sl 0:00 \_ /usr/libexec/udisks-daemon 960 ? S 0:00 | \_ udisks-daemon: not polling any devices 977 ? Sl 0:00 \_ /usr/libexec/packagekitd This prctl is orthogonal to PID namespaces. PID namespaces are isolated from each other, while a service management process usually requires the services to live in the same namespace, to be able to talk to each other. Users of this will be the systemd per-user instance, which provides init-like functionality for the user's login session and D-Bus, which activates bus services on-demand. Both need init-like capabilities to be able to properly keep track of the services they start. Many thanks to Oleg for several rounds of review and insights. [akpm@linux-foundation.org: fix comment layout and spelling] [akpm@linux-foundation.org: add lengthy code comment from Oleg] Reviewed-by: Oleg Nesterov <oleg@redhat.com> Signed-off-by: Lennart Poettering <lennart@poettering.net> Signed-off-by: Kay Sievers <kay.sievers@vrfy.org> Acked-by: Valdis Kletnieks <Valdis.Kletnieks@vt.edu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-03-22Merge branch 'akpm' (Andrew's patch-bomb)Linus Torvalds
Merge first batch of patches from Andrew Morton: "A few misc things and all the MM queue" * emailed from Andrew Morton <akpm@linux-foundation.org>: (92 commits) memcg: avoid THP split in task migration thp: add HPAGE_PMD_* definitions for !CONFIG_TRANSPARENT_HUGEPAGE memcg: clean up existing move charge code mm/memcontrol.c: remove unnecessary 'break' in mem_cgroup_read() mm/memcontrol.c: remove redundant BUG_ON() in mem_cgroup_usage_unregister_event() mm/memcontrol.c: s/stealed/stolen/ memcg: fix performance of mem_cgroup_begin_update_page_stat() memcg: remove PCG_FILE_MAPPED memcg: use new logic for page stat accounting memcg: remove PCG_MOVE_LOCK flag from page_cgroup memcg: simplify move_account() check memcg: remove EXPORT_SYMBOL(mem_cgroup_update_page_stat) memcg: kill dead prev_priority stubs memcg: remove PCG_CACHE page_cgroup flag memcg: let css_get_next() rely upon rcu_read_lock() cgroup: revert ss_id_lock to spinlock idr: make idr_get_next() good for rcu_read_lock() memcg: remove unnecessary thp check in page stat accounting memcg: remove redundant returns memcg: enum lru_list lru ...
2012-03-21cpuset: mm: reduce large amounts of memory barrier related damage v3Mel Gorman
Commit c0ff7453bb5c ("cpuset,mm: fix no node to alloc memory when changing cpuset's mems") wins a super prize for the largest number of memory barriers entered into fast paths for one commit. [get|put]_mems_allowed is incredibly heavy with pairs of full memory barriers inserted into a number of hot paths. This was detected while investigating at large page allocator slowdown introduced some time after 2.6.32. The largest portion of this overhead was shown by oprofile to be at an mfence introduced by this commit into the page allocator hot path. For extra style points, the commit introduced the use of yield() in an implementation of what looks like a spinning mutex. This patch replaces the full memory barriers on both read and write sides with a sequence counter with just read barriers on the fast path side. This is much cheaper on some architectures, including x86. The main bulk of the patch is the retry logic if the nodemask changes in a manner that can cause a false failure. While updating the nodemask, a check is made to see if a false failure is a risk. If it is, the sequence number gets bumped and parallel allocators will briefly stall while the nodemask update takes place. In a page fault test microbenchmark, oprofile samples from __alloc_pages_nodemask went from 4.53% of all samples to 1.15%. The actual results were 3.3.0-rc3 3.3.0-rc3 rc3-vanilla nobarrier-v2r1 Clients 1 UserTime 0.07 ( 0.00%) 0.08 (-14.19%) Clients 2 UserTime 0.07 ( 0.00%) 0.07 ( 2.72%) Clients 4 UserTime 0.08 ( 0.00%) 0.07 ( 3.29%) Clients 1 SysTime 0.70 ( 0.00%) 0.65 ( 6.65%) Clients 2 SysTime 0.85 ( 0.00%) 0.82 ( 3.65%) Clients 4 SysTime 1.41 ( 0.00%) 1.41 ( 0.32%) Clients 1 WallTime 0.77 ( 0.00%) 0.74 ( 4.19%) Clients 2 WallTime 0.47 ( 0.00%) 0.45 ( 3.73%) Clients 4 WallTime 0.38 ( 0.00%) 0.37 ( 1.58%) Clients 1 Flt/sec/cpu 497620.28 ( 0.00%) 520294.53 ( 4.56%) Clients 2 Flt/sec/cpu 414639.05 ( 0.00%) 429882.01 ( 3.68%) Clients 4 Flt/sec/cpu 257959.16 ( 0.00%) 258761.48 ( 0.31%) Clients 1 Flt/sec 495161.39 ( 0.00%) 517292.87 ( 4.47%) Clients 2 Flt/sec 820325.95 ( 0.00%) 850289.77 ( 3.65%) Clients 4 Flt/sec 1020068.93 ( 0.00%) 1022674.06 ( 0.26%) MMTests Statistics: duration Sys Time Running Test (seconds) 135.68 132.17 User+Sys Time Running Test (seconds) 164.2 160.13 Total Elapsed Time (seconds) 123.46 120.87 The overall improvement is small but the System CPU time is much improved and roughly in correlation to what oprofile reported (these performance figures are without profiling so skew is expected). The actual number of page faults is noticeably improved. For benchmarks like kernel builds, the overall benefit is marginal but the system CPU time is slightly reduced. To test the actual bug the commit fixed I opened two terminals. The first ran within a cpuset and continually ran a small program that faulted 100M of anonymous data. In a second window, the nodemask of the cpuset was continually randomised in a loop. Without the commit, the program would fail every so often (usually within 10 seconds) and obviously with the commit everything worked fine. With this patch applied, it also worked fine so the fix should be functionally equivalent. Signed-off-by: Mel Gorman <mgorman@suse.de> Cc: Miao Xie <miaox@cn.fujitsu.com> Cc: David Rientjes <rientjes@google.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Christoph Lameter <cl@linux.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-03-21mm: add rss counters consistency checkKonstantin Khlebnikov
Warn about non-zero rss counters at final mmdrop. This check will prevent reoccurences of bugs such as that fixed in "mm: fix rss count leakage during migration". I didn't hide this check under CONFIG_VM_DEBUG because it rather small and rss counters cover whole page-table management, so this is a good invariant. Signed-off-by: Konstantin Khlebnikov <khlebnikov@openvz.org> Cc: Hugh Dickins <hughd@google.com> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-03-21Merge branch 'next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security Pull security subsystem updates for 3.4 from James Morris: "The main addition here is the new Yama security module from Kees Cook, which was discussed at the Linux Security Summit last year. Its purpose is to collect miscellaneous DAC security enhancements in one place. This also marks a departure in policy for LSM modules, which were previously limited to being standalone access control systems. Chromium OS is using Yama, and I believe there are plans for Ubuntu, at least. This patchset also includes maintenance updates for AppArmor, TOMOYO and others." Fix trivial conflict in <net/sock.h> due to the jumo_label->static_key rename. * 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security: (38 commits) AppArmor: Fix location of const qualifier on generated string tables TOMOYO: Return error if fails to delete a domain AppArmor: add const qualifiers to string arrays AppArmor: Add ability to load extended policy TOMOYO: Return appropriate value to poll(). AppArmor: Move path failure information into aa_get_name and rename AppArmor: Update dfa matching routines. AppArmor: Minor cleanup of d_namespace_path to consolidate error handling AppArmor: Retrieve the dentry_path for error reporting when path lookup fails AppArmor: Add const qualifiers to generated string tables AppArmor: Fix oops in policy unpack auditing AppArmor: Fix error returned when a path lookup is disconnected KEYS: testing wrong bit for KEY_FLAG_REVOKED TOMOYO: Fix mount flags checking order. security: fix ima kconfig warning AppArmor: Fix the error case for chroot relative path name lookup AppArmor: fix mapping of META_READ to audit and quiet flags AppArmor: Fix underflow in xindex calculation AppArmor: Fix dropping of allowed operations that are force audited AppArmor: Add mising end of structure test to caps unpacking ...
2012-03-20CLONE_PARENT shouldn't allow to set ->exit_signalOleg Nesterov
The child must not control its ->exit_signal, it is the parent who decides which signal the child should use for notification. This means that CLONE_PARENT should not use "clone_flags & CSIGNAL", the forking task is the sibling of the new process and their parent doesn't control exit_signal in this case. This patch uses ->exit_signal of the forking process, but perhaps we should simply use SIGCHLD. We read group_leader->exit_signal lockless, this can race with the ORIGINAL_SIGNAL -> SIGCHLD transition, but this is fine. Potentially this change allows to kill self_exec_id/parent_exec_id. Signed-off-by: Oleg Nesterov <oleg@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-03-05vfork: kill PF_STARTINGOleg Nesterov
Previously it was (ab)used by utrace. Then it was wrongly used by the scheduler code. Currently it is not used, kill it before it finds the new erroneous user. Signed-off-by: Oleg Nesterov <oleg@redhat.com> Acked-by: Tejun Heo <tj@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-03-05coredump_wait: don't call complete_vfork_done()Oleg Nesterov
Now that CLONE_VFORK is killable, coredump_wait() no longer needs complete_vfork_done(). zap_threads() should find and kill all tasks with the same ->mm, this includes our parent if ->vfork_done is set. mm_release() becomes the only caller, unexport complete_vfork_done(). Signed-off-by: Oleg Nesterov <oleg@redhat.com> Acked-by: Tejun Heo <tj@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-03-05vfork: make it killableOleg Nesterov
Make vfork() killable. Change do_fork(CLONE_VFORK) to do wait_for_completion_killable(). If it fails we do not return to the user-mode and never touch the memory shared with our child. However, in this case we should clear child->vfork_done before return, we use task_lock() in do_fork()->wait_for_vfork_done() and complete_vfork_done() to serialize with each other. Note: now that we use task_lock() we don't really need completion, we could turn task->vfork_done into "task_struct *wake_up_me" but this needs some complications. NOTE: this and the next patches do not affect in-kernel users of CLONE_VFORK, kernel threads run with all signals ignored including SIGKILL/SIGSTOP. However this is obviously the user-visible change. Not only a fatal signal can kill the vforking parent, a sub-thread can do execve or exit_group() and kill the thread sleeping in vfork(). Signed-off-by: Oleg Nesterov <oleg@redhat.com> Acked-by: Tejun Heo <tj@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-03-05vfork: introduce complete_vfork_done()Oleg Nesterov
No functional changes. Move the clear-and-complete-vfork_done code into the new trivial helper, complete_vfork_done(). Signed-off-by: Oleg Nesterov <oleg@redhat.com> Acked-by: Tejun Heo <tj@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-02-24epoll: introduce POLLFREE to flush ->signalfd_wqh before kfree()Oleg Nesterov
This patch is intentionally incomplete to simplify the review. It ignores ep_unregister_pollwait() which plays with the same wqh. See the next change. epoll assumes that the EPOLL_CTL_ADD'ed file controls everything f_op->poll() needs. In particular it assumes that the wait queue can't go away until eventpoll_release(). This is not true in case of signalfd, the task which does EPOLL_CTL_ADD uses its ->sighand which is not connected to the file. This patch adds the special event, POLLFREE, currently only for epoll. It expects that init_poll_funcptr()'ed hook should do the necessary cleanup. Perhaps it should be defined as EPOLLFREE in eventpoll. __cleanup_sighand() is changed to do wake_up_poll(POLLFREE) if ->signalfd_wqh is not empty, we add the new signalfd_cleanup() helper. ep_poll_callback(POLLFREE) simply does list_del_init(task_list). This make this poll entry inconsistent, but we don't care. If you share epoll fd which contains our sigfd with another process you should blame yourself. signalfd is "really special". I simply do not know how we can define the "right" semantics if it used with epoll. The main problem is, epoll calls signalfd_poll() once to establish the connection with the wait queue, after that signalfd_poll(NULL) returns the different/inconsistent results depending on who does EPOLL_CTL_MOD/signalfd_read/etc. IOW: apart from sigmask, signalfd has nothing to do with the file, it works with the current thread. In short: this patch is the hack which tries to fix the symptoms. It also assumes that nobody can take tasklist_lock under epoll locks, this seems to be true. Note: - we do not have wake_up_all_poll() but wake_up_poll() is fine, poll/epoll doesn't use WQ_FLAG_EXCLUSIVE. - signalfd_cleanup() uses POLLHUP along with POLLFREE, we need a couple of simple changes in eventpoll.c to make sure it can't be "lost". Reported-by: Maxime Bizon <mbizon@freebox.fr> Cc: <stable@kernel.org> Signed-off-by: Oleg Nesterov <oleg@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-02-14mm: collapse security_vm_enough_memory() variants into a single functionAl Viro
Collapse security_vm_enough_memory() variants into a single function. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: James Morris <jmorris@namei.org>
2012-02-11Merge branch 'for-linus' of git://git.kernel.dk/linux-blockLinus Torvalds
Says Jens: "Time to push off some of the pending items. I really wanted to wait until we had the regression nailed, but alas it's not quite there yet. But I'm very confident that it's "just" a missing expire on exit, so fix from Tejun should be fairly trivial. I'm headed out for a week on the slopes. - Killing the barrier part of mtip32xx. It doesn't really support barriers, and it doesn't need them (writes are fully ordered). - A few fixes from Dan Carpenter, preventing overflows of integer multiplication. - A fixup for loop, fixing a previous commit that didn't quite solve the partial read problem from Dave Young. - A bio integer overflow fix from Kent Overstreet. - Improvement/fix of the door "keep locked" part of the cdrom shared code from Paolo Benzini. - A few cfq fixes from Shaohua Li. - A fix for bsg sysfs warning when removing a file it did not create from Stanislaw Gruszka. - Two fixes for floppy from Vivek, preventing a crash. - A few block core fixes from Tejun. One killing the over-optimized ioc exit path, cleaning that up nicely. Two others fixing an oops on elevator switch, due to calling into the scheduler merge check code without holding the queue lock." * 'for-linus' of git://git.kernel.dk/linux-block: block: fix lockdep warning on io_context release put_io_context() relay: prevent integer overflow in relay_open() loop: zero fill bio instead of return -EIO for partial read bio: don't overflow in bio_get_nr_vecs() floppy: Fix a crash during rmmod floppy: Cleanup disk->queue before caling put_disk() if add_disk() was never called cdrom: move shared static to cdrom_device_info bsg: fix sysfs link remove warning block: don't call elevator callbacks for plug merges block: separate out blk_rq_merge_ok() and blk_try_merge() from elevator functions mtip32xx: removed the irrelevant argument of mtip_hw_submit_io() and the unused member of struct driver_data block: strip out locking optimization in put_io_context() cdrom: use copy_to_user() without the underscores block: fix ioc locking warning block: fix NULL icq_cache reference block,cfq: change code order
2012-02-10security: create task_free security callbackKees Cook
The current LSM interface to cred_free is not sufficient for allowing an LSM to track the life and death of a task. This patch adds the task_free hook so that an LSM can clean up resources on task death. Signed-off-by: Kees Cook <keescook@chromium.org> Signed-off-by: James Morris <jmorris@namei.org>
2012-02-07block: strip out locking optimization in put_io_context()Tejun Heo
put_io_context() performed a complex trylock dancing to avoid deferring ioc release to workqueue. It was also broken on UP because trylock was always assumed to succeed which resulted in unbalanced preemption count. While there are ways to fix the UP breakage, even the most pathological microbench (forced ioc allocation and tight fork/exit loop) fails to show any appreciable performance benefit of the optimization. Strip it out. If there turns out to be workloads which are affected by this change, simpler optimization from the discussion thread can be applied later. Signed-off-by: Tejun Heo <tj@kernel.org> LKML-Reference: <1328514611.21268.66.camel@sli10-conroe> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2012-02-02Fix race in process_vm_rw_coreChristopher Yeoh
This fixes the race in process_vm_core found by Oleg (see http://article.gmane.org/gmane.linux.kernel/1235667/ for details). This has been updated since I last sent it as the creation of the new mm_access() function did almost exactly the same thing as parts of the previous version of this patch did. In order to use mm_access() even when /proc isn't enabled, we move it to kernel/fork.c where other related process mm access functions already are. Signed-off-by: Chris Yeoh <yeohc@au1.ibm.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-01-17Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/audit * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/audit: (29 commits) audit: no leading space in audit_log_d_path prefix audit: treat s_id as an untrusted string audit: fix signedness bug in audit_log_execve_info() audit: comparison on interprocess fields audit: implement all object interfield comparisons audit: allow interfield comparison between gid and ogid audit: complex interfield comparison helper audit: allow interfield comparison in audit rules Kernel: Audit Support For The ARM Platform audit: do not call audit_getname on error audit: only allow tasks to set their loginuid if it is -1 audit: remove task argument to audit_set_loginuid audit: allow audit matching on inode gid audit: allow matching on obj_uid audit: remove audit_finish_fork as it can't be called audit: reject entry,always rules audit: inline audit_free to simplify the look of generic code audit: drop audit_set_macxattr as it doesn't do anything audit: inline checks for not needing to collect aux records audit: drop some potentially inadvisable likely notations ... Use evil merge to fix up grammar mistakes in Kconfig file. Bad speling and horrible grammar (and copious swearing) is to be expected, but let's keep it to commit messages and comments, rather than expose it to users in config help texts or printouts.
2012-01-17audit: remove audit_finish_fork as it can't be calledEric Paris
Audit entry,always rules are not allowed and are automatically changed in exit,always rules in userspace. The kernel refuses to load such rules. Thus a task in the middle of a syscall (and thus in audit_finish_fork()) can only be in one of two states: AUDIT_BUILD_CONTEXT or AUDIT_DISABLED. Since the current task cannot be in AUDIT_RECORD_CONTEXT we aren't every going to actually use the code in audit_finish_fork() since it will return without doing anything. Thus drop the code. Signed-off-by: Eric Paris <eparis@redhat.com>
2012-01-15Merge branch 'for-3.3/core' of git://git.kernel.dk/linux-blockLinus Torvalds
* 'for-3.3/core' of git://git.kernel.dk/linux-block: (37 commits) Revert "block: recursive merge requests" block: Stop using macro stubs for the bio data integrity calls blockdev: convert some macros to static inlines fs: remove unneeded plug in mpage_readpages() block: Add BLKROTATIONAL ioctl block: Introduce blk_set_stacking_limits function block: remove WARN_ON_ONCE() in exit_io_context() block: an exiting task should be allowed to create io_context block: ioc_cgroup_changed() needs to be exported block: recursive merge requests block, cfq: fix empty queue crash caused by request merge block, cfq: move icq creation and rq->elv.icq association to block core block, cfq: restructure io_cq creation path for io_context interface cleanup block, cfq: move io_cq exit/release to blk-ioc.c block, cfq: move icq cache management to block core block, cfq: move io_cq lookup to blk-ioc.c block, cfq: move cfqd->icq_list to request_queue and add request->elv.icq block, cfq: reorganize cfq_io_context into generic and cfq specific parts block: remove elevator_queue->ops block: reorder elevator switch sequence ... Fix up conflicts in: - block/blk-cgroup.c Switch from can_attach_task to can_attach - block/cfq-iosched.c conflict with now removed cic index changes (we now use q->id instead)
2012-01-10Merge branch 'writeback-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/wfg/linux * 'writeback-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/wfg/linux: writeback: move MIN_WRITEBACK_PAGES to fs-writeback.c writeback: balanced_rate cannot exceed write bandwidth writeback: do strict bdi dirty_exceeded writeback: avoid tiny dirty poll intervals writeback: max, min and target dirty pause time writeback: dirty ratelimit - think time compensation btrfs: fix dirtied pages accounting on sub-page writes writeback: fix dirtied pages accounting on redirty writeback: fix dirtied pages accounting on sub-page writes writeback: charge leaked page dirties to active tasks writeback: Include all dirty inodes in background writeback
2012-01-10tracepoint: add tracepoints for debugging oom_score_adjKAMEZAWA Hiroyuki
oom_score_adj is used for guarding processes from OOM-Killer. One of problem is that it's inherited at fork(). When a daemon set oom_score_adj and make children, it's hard to know where the value is set. This patch adds some tracepoints useful for debugging. This patch adds 3 trace points. - creating new task - renaming a task (exec) - set oom_score_adj To debug, users need to enable some trace pointer. Maybe filtering is useful as # EVENT=/sys/kernel/debug/tracing/events/task/ # echo "oom_score_adj != 0" > $EVENT/task_newtask/filter # echo "oom_score_adj != 0" > $EVENT/task_rename/filter # echo 1 > $EVENT/enable # EVENT=/sys/kernel/debug/tracing/events/oom/ # echo 1 > $EVENT/enable output will be like this. # grep oom /sys/kernel/debug/tracing/trace bash-7699 [007] d..3 5140.744510: oom_score_adj_update: pid=7699 comm=bash oom_score_adj=-1000 bash-7699 [007] ...1 5151.818022: task_newtask: pid=7729 comm=bash clone_flags=1200011 oom_score_adj=-1000 ls-7729 [003] ...2 5151.818504: task_rename: pid=7729 oldcomm=bash newcomm=ls oom_score_adj=-1000 bash-7699 [002] ...1 5175.701468: task_newtask: pid=7730 comm=bash clone_flags=1200011 oom_score_adj=-1000 grep-7730 [007] ...2 5175.701993: task_rename: pid=7730 oldcomm=bash newcomm=grep oom_score_adj=-1000 Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Acked-by: David Rientjes <rientjes@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-01-09Merge branch 'for-3.3' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tj/cgroup * 'for-3.3' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/cgroup: (21 commits) cgroup: fix to allow mounting a hierarchy by name cgroup: move assignement out of condition in cgroup_attach_proc() cgroup: Remove task_lock() from cgroup_post_fork() cgroup: add sparse annotation to cgroup_iter_start() and cgroup_iter_end() cgroup: mark cgroup_rmdir_waitq and cgroup_attach_proc() as static cgroup: only need to check oldcgrp==newgrp once cgroup: remove redundant get/put of task struct cgroup: remove redundant get/put of old css_set from migrate cgroup: Remove unnecessary task_lock before fetching css_set on migration cgroup: Drop task_lock(parent) on cgroup_fork() cgroups: remove redundant get/put of css_set from css_set_check_fetched() resource cgroups: remove bogus cast cgroup: kill subsys->can_attach_task(), pre_attach() and attach_task() cgroup, cpuset: don't use ss->pre_attach() cgroup: don't use subsys->can_attach_task() or ->attach_task() cgroup: introduce cgroup_taskset and use it in subsys->can_attach(), cancel_attach() and attach() cgroup: improve old cgroup handling in cgroup_attach_proc() cgroup: always lock threadgroup during migration threadgroup: extend threadgroup_lock() to cover exit and exec threadgroup: rename signal->threadgroup_fork_lock to ->group_rwsem ... Fix up conflict in kernel/cgroup.c due to commit e0197aae59e5: "cgroups: fix a css_set not found bug in cgroup_attach_proc" that already mentioned that the bug is fixed (differently) in Tejun's cgroup patchset. This one, in other words.
2012-01-08Merge branch 'pm-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm * 'pm-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm: (76 commits) PM / Hibernate: Implement compat_ioctl for /dev/snapshot PM / Freezer: fix return value of freezable_schedule_timeout_killable() PM / shmobile: Allow the A4R domain to be turned off at run time PM / input / touchscreen: Make st1232 use device PM QoS constraints PM / QoS: Introduce dev_pm_qos_add_ancestor_request() PM / shmobile: Remove the stay_on flag from SH7372's PM domains PM / shmobile: Don't include SH7372's INTCS in syscore suspend/resume PM / shmobile: Add support for the sh7372 A4S power domain / sleep mode PM: Drop generic_subsys_pm_ops PM / Sleep: Remove forward-only callbacks from AMBA bus type PM / Sleep: Remove forward-only callbacks from platform bus type PM: Run the driver callback directly if the subsystem one is not there PM / Sleep: Make pm_op() and pm_noirq_op() return callback pointers PM/Devfreq: Add Exynos4-bus device DVFS driver for Exynos4210/4212/4412. PM / Sleep: Merge internal functions in generic_ops.c PM / Sleep: Simplify generic system suspend callbacks PM / Hibernate: Remove deprecated hibernation snapshot ioctls PM / Sleep: Fix freezer failures due to racy usermodehelper_is_disabled() ARM: S3C64XX: Implement basic power domain support PM / shmobile: Use common always on power domain governor ... Fix up trivial conflict in fs/xfs/xfs_buf.c due to removal of unused XBT_FORCE_SLEEP bit
2011-12-18writeback: dirty ratelimit - think time compensationWu Fengguang
Compensate the task's think time when computing the final pause time, so that ->dirty_ratelimit can be executed accurately. think time := time spend outside of balance_dirty_pages() In the rare case that the task slept longer than the 200ms period time (result in negative pause time), the sleep time will be compensated in the following periods, too, if it's less than 1 second. Accumulated errors are carefully avoided as long as the max pause area is not hitted. Pseudo code: period = pages_dirtied / task_ratelimit; think = jiffies - dirty_paused_when; pause = period - think; 1) normal case: period > think pause = period - think dirty_paused_when = jiffies + pause nr_dirtied = 0 period time |===============================>| think time pause time |===============>|==============>| ------|----------------|---------------|------------------------ dirty_paused_when jiffies 2) no pause case: period <= think don't pause; reduce future pause time by: dirty_paused_when += period nr_dirtied = 0 period time |===============================>| think time |===================================================>| ------|--------------------------------+-------------------|---- dirty_paused_when jiffies Acked-by: Jan Kara <jack@suse.cz> Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Wu Fengguang <fengguang.wu@intel.com>
2011-12-15[S390] cputime: add sparse checking and cleanupMartin Schwidefsky
Make cputime_t and cputime64_t nocast to enable sparse checking to detect incorrect use of cputime. Drop the cputime macros for simple scalar operations. The conversion macros are still needed. Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2011-12-14block, cfq: unlink cfq_io_context's immediatelyTejun Heo
cic is association between io_context and request_queue. A cic is linked from both ioc and q and should be destroyed when either one goes away. As ioc and q both have their own locks, locking becomes a bit complex - both orders work for removal from one but not from the other. Currently, cfq tries to circumvent this locking order issue with RCU. ioc->lock nests inside queue_lock but the radix tree and cic's are also protected by RCU allowing either side to walk their lists without grabbing lock. This rather unconventional use of RCU quickly devolves into extremely fragile convolution. e.g. The following is from cfqd going away too soon after ioc and q exits raced. general protection fault: 0000 [#1] PREEMPT SMP CPU 2 Modules linked in: [ 88.503444] Pid: 599, comm: hexdump Not tainted 3.1.0-rc10-work+ #158 Bochs Bochs RIP: 0010:[<ffffffff81397628>] [<ffffffff81397628>] cfq_exit_single_io_context+0x58/0xf0 ... Call Trace: [<ffffffff81395a4a>] call_for_each_cic+0x5a/0x90 [<ffffffff81395ab5>] cfq_exit_io_context+0x15/0x20 [<ffffffff81389130>] exit_io_context+0x100/0x140 [<ffffffff81098a29>] do_exit+0x579/0x850 [<ffffffff81098d5b>] do_group_exit+0x5b/0xd0 [<ffffffff81098de7>] sys_exit_group+0x17/0x20 [<ffffffff81b02f2b>] system_call_fastpath+0x16/0x1b The only real hot path here is cic lookup during request initialization and avoiding extra locking requires very confined use of RCU. This patch makes cic removal from both ioc and request_queue perform double-locking and unlink immediately. * From q side, the change is almost trivial as ioc->lock nests inside queue_lock. It just needs to grab each ioc->lock as it walks cic_list and unlink it. * From ioc side, it's a bit more difficult because of inversed lock order. ioc needs its lock to walk its cic_list but can't grab the matching queue_lock and needs to perform unlock-relock dancing. Unlinking is now wholly done from put_io_context() and fast path is optimized by using the queue_lock the caller already holds, which is by far the most common case. If the ioc accessed multiple devices, it tries with trylock. In unlikely cases of fast path failure, it falls back to full double-locking dance from workqueue. Double-locking isn't the prettiest thing in the world but it's *far* simpler and more understandable than RCU trick without adding any meaningful overhead. This still leaves a lot of now unnecessary RCU logics. Future patches will trim them. -v2: Vivek pointed out that cic->q was being dereferenced after cic->release() was called. Updated to use local variable @this_q instead. Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Vivek Goyal <vgoyal@redhat.com> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2011-12-14block: make ioc get/put interface more conventional and fix race on alloctionTejun Heo
Ignoring copy_io() during fork, io_context can be allocated from two places - current_io_context() and set_task_ioprio(). The former is always called from local task while the latter can be called from different task. The synchornization between them are peculiar and dubious. * current_io_context() doesn't grab task_lock() and assumes that if it saw %NULL ->io_context, it would stay that way until allocation and assignment is complete. It has smp_wmb() between alloc/init and assignment. * set_task_ioprio() grabs task_lock() for assignment and does smp_read_barrier_depends() between "ioc = task->io_context" and "if (ioc)". Unfortunately, this doesn't achieve anything - the latter is not a dependent load of the former. ie, if ioc itself were being dereferenced "ioc->xxx", it would mean something (not sure what tho) but as the code currently stands, the dependent read barrier is noop. As only one of the the two test-assignment sequences is task_lock() protected, the task_lock() can't do much about race between the two. Nothing prevents current_io_context() and set_task_ioprio() allocating its own ioc for the same task and overwriting the other's. Also, set_task_ioprio() can race with exiting task and create a new ioc after exit_io_context() is finished. ioc get/put doesn't have any reason to be complex. The only hot path is accessing the existing ioc of %current, which is simple to achieve given that ->io_context is never destroyed as long as the task is alive. All other paths can happily go through task_lock() like all other task sub structures without impacting anything. This patch updates ioc get/put so that it becomes more conventional. * alloc_io_context() is replaced with get_task_io_context(). This is the only interface which can acquire access to ioc of another task. On return, the caller has an explicit reference to the object which should be put using put_io_context() afterwards. * The functionality of current_io_context() remains the same but when creating a new ioc, it shares the code path with get_task_io_context() and always goes through task_lock(). * get_io_context() now means incrementing ref on an ioc which the caller already has access to (be that an explicit refcnt or implicit %current one). * PF_EXITING inhibits creation of new io_context and once exit_io_context() is finished, it's guaranteed that both ioc acquisition functions return %NULL. * All users are updated. Most are trivial but smp_read_barrier_depends() removal from cfq_get_io_context() needs a bit of explanation. I suppose the original intention was to ensure ioc->ioprio is visible when set_task_ioprio() allocates new io_context and installs it; however, this wouldn't have worked because set_task_ioprio() doesn't have wmb between init and install. There are other problems with this which will be fixed in another patch. * While at it, use NUMA_NO_NODE instead of -1 for wildcard node specification. -v2: Vivek spotted contamination from debug patch. Removed. Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Vivek Goyal <vgoyal@redhat.com> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2011-12-12threadgroup: rename signal->threadgroup_fork_lock to ->group_rwsemTejun Heo
Make the following renames to prepare for extension of threadgroup locking. * s/signal->threadgroup_fork_lock/signal->group_rwsem/ * s/threadgroup_fork_read_lock()/threadgroup_change_begin()/ * s/threadgroup_fork_read_unlock()/threadgroup_change_end()/ * s/threadgroup_fork_write_lock()/threadgroup_lock()/ * s/threadgroup_fork_write_unlock()/threadgroup_unlock()/ This patch doesn't cause any behavior change. -v2: Rename threadgroup_change_done() to threadgroup_change_end() per KAMEZAWA's suggestion. Signed-off-by: Tejun Heo <tj@kernel.org> Reviewed-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Acked-by: Li Zefan <lizf@cn.fujitsu.com> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Paul Menage <paul@paulmenage.org>
2011-11-23Merge branch 'pm-freezer' of ↵Rafael J. Wysocki
git://git.kernel.org/pub/scm/linux/kernel/git/tj/misc into pm-freezer * 'pm-freezer' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/misc: (24 commits) freezer: fix wait_event_freezable/__thaw_task races freezer: kill unused set_freezable_with_signal() dmatest: don't use set_freezable_with_signal() usb_storage: don't use set_freezable_with_signal() freezer: remove unused @sig_only from freeze_task() freezer: use lock_task_sighand() in fake_signal_wake_up() freezer: restructure __refrigerator() freezer: fix set_freezable[_with_signal]() race freezer: remove should_send_signal() and update frozen() freezer: remove now unused TIF_FREEZE freezer: make freezing() test freeze conditions in effect instead of TIF_FREEZE cgroup_freezer: prepare for removal of TIF_FREEZE freezer: clean up freeze_processes() failure path freezer: kill PF_FREEZING freezer: test freezable conditions while holding freezer_lock freezer: make freezing indicate freeze condition in effect freezer: use dedicated lock instead of task_lock() + memory barrier freezer: don't distinguish nosig tasks on thaw freezer: remove racy clear_freeze_flag() and set PF_NOFREEZE on dead tasks freezer: rename thaw_process() to __thaw_task() and simplify the implementation ...
2011-11-21freezer: make freezing() test freeze conditions in effect instead of TIF_FREEZETejun Heo
Using TIF_FREEZE for freezing worked when there was only single freezing condition (the PM one); however, now there is also the cgroup_freezer and single bit flag is getting clumsy. thaw_processes() is already testing whether cgroup freezing in in effect to avoid thawing tasks which were frozen by both PM and cgroup freezers. This is racy (nothing prevents race against cgroup freezing) and fragile. A much simpler way is to test actual freeze conditions from freezing() - ie. directly test whether PM or cgroup freezing is in effect. This patch adds variables to indicate whether and what type of freezing conditions are in effect and reimplements freezing() such that it directly tests whether any of the two freezing conditions is active and the task should freeze. On fast path, freezing() is still very cheap - it only tests system_freezing_cnt. This makes the clumsy dancing aroung TIF_FREEZE unnecessary and freeze/thaw operations more usual - updating state variables for the new state and nudging target tasks so that they notice the new state and comply. As long as the nudging happens after state update, it's race-free. * This allows use of freezing() in freeze_task(). Replace the open coded tests with freezing(). * p != current test is added to warning printing conditions in try_to_freeze_tasks() failure path. This is necessary as freezing() is now true for the task which initiated freezing too. -v2: Oleg pointed out that re-freezing FROZEN cgroup could increment system_freezing_cnt. Fixed. Signed-off-by: Tejun Heo <tj@kernel.org> Acked-by: Paul Menage <paul@paulmenage.org> (for the cgroup portions)
2011-11-17writeback: remove vm_dirties and task->dirtiesWu Fengguang
They are not used any more. Signed-off-by: Wu Fengguang <fengguang.wu@intel.com>
2011-11-06Merge branch 'writeback-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/wfg/linux * 'writeback-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/wfg/linux: writeback: Add a 'reason' to wb_writeback_work writeback: send work item to queue_io, move_expired_inodes writeback: trace event balance_dirty_pages writeback: trace event bdi_dirty_ratelimit writeback: fix ppc compile warnings on do_div(long long, unsigned long) writeback: per-bdi background threshold writeback: dirty position control - bdi reserve area writeback: control dirty pause time writeback: limit max dirty pause time writeback: IO-less balance_dirty_pages() writeback: per task dirty rate limit writeback: stabilize bdi->dirty_ratelimit writeback: dirty rate control writeback: add bg_threshold parameter to __bdi_update_bandwidth() writeback: dirty position control writeback: account per-bdi accumulated dirtied pages
2011-10-31oom: remove oom_disable_countDavid Rientjes
This removes mm->oom_disable_count entirely since it's unnecessary and currently buggy. The counter was intended to be per-process but it's currently decremented in the exit path for each thread that exits, causing it to underflow. The count was originally intended to prevent oom killing threads that share memory with threads that cannot be killed since it doesn't lead to future memory freeing. The counter could be fixed to represent all threads sharing the same mm, but it's better to remove the count since: - it is possible that the OOM_DISABLE thread sharing memory with the victim is waiting on that thread to exit and will actually cause future memory freeing, and - there is no guarantee that a thread is disabled from oom killing just because another thread sharing its mm is oom disabled. Signed-off-by: David Rientjes <rientjes@google.com> Reported-by: Oleg Nesterov <oleg@redhat.com> Reviewed-by: Oleg Nesterov <oleg@redhat.com> Cc: Ying Han <yinghan@google.com> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-10-03writeback: per task dirty rate limitWu Fengguang
Add two fields to task_struct. 1) account dirtied pages in the individual tasks, for accuracy 2) per-task balance_dirty_pages() call intervals, for flexibility The balance_dirty_pages() call interval (ie. nr_dirtied_pause) will scale near-sqrt to the safety gap between dirty pages and threshold. The main problem of per-task nr_dirtied is, if 1k+ tasks start dirtying pages at exactly the same time, each task will be assigned a large initial nr_dirtied_pause, so that the dirty threshold will be exceeded long before each task reached its nr_dirtied_pause and hence call balance_dirty_pages(). The solution is to watch for the number of pages dirtied on each CPU in between the calls into balance_dirty_pages(). If it exceeds ratelimit_pages (3% dirty threshold), force call balance_dirty_pages() for a chance to set bdi->dirty_exceeded. In normal situations, this safeguarding condition is not expected to trigger at all. On the sqrt in dirty_poll_interval(): It will serve as an initial guess when dirty pages are still in the freerun area. When dirty pages are floating inside the dirty control scope [freerun, limit], a followup patch will use some refined dirty poll interval to get the desired pause time. thresh-dirty (MB) sqrt 1 16 2 22 4 32 8 45 16 64 32 90 64 128 128 181 256 256 512 362 1024 512 The above table means, given 1MB (or 1GB) gap and the dd tasks polling balance_dirty_pages() on every 16 (or 512) pages, the dirty limit won't be exceeded as long as there are less than 16 (or 512) concurrent dd's. So sqrt naturally leads to less overheads and more safe concurrent tasks for large memory servers, which have large (thresh-freerun) gaps. peter: keep the per-CPU ratelimit for safeguarding the 1k+ tasks case CC: Peter Zijlstra <a.p.zijlstra@chello.nl> Reviewed-by: Andrea Righi <andrea@betterlinux.com> Signed-off-by: Wu Fengguang <fengguang.wu@intel.com>
2011-08-11move RLIMIT_NPROC check from set_user() to do_execve_common()Vasiliy Kulikov
The patch http://lkml.org/lkml/2003/7/13/226 introduced an RLIMIT_NPROC check in set_user() to check for NPROC exceeding via setuid() and similar functions. Before the check there was a possibility to greatly exceed the allowed number of processes by an unprivileged user if the program relied on rlimit only. But the check created new security threat: many poorly written programs simply don't check setuid() return code and believe it cannot fail if executed with root privileges. So, the check is removed in this patch because of too often privilege escalations related to buggy programs. The NPROC can still be enforced in the common code flow of daemons spawning user processes. Most of daemons do fork()+setuid()+execve(). The check introduced in execve() (1) enforces the same limit as in setuid() and (2) doesn't create similar security issues. Neil Brown suggested to track what specific process has exceeded the limit by setting PF_NPROC_EXCEEDED process flag. With the change only this process would fail on execve(), and other processes' execve() behaviour is not changed. Solar Designer suggested to re-check whether NPROC limit is still exceeded at the moment of execve(). If the process was sleeping for days between set*uid() and execve(), and the NPROC counter step down under the limit, the defered execve() failure because NPROC limit was exceeded days ago would be unexpected. If the limit is not exceeded anymore, we clear the flag on successful calls to execve() and fork(). The flag is also cleared on successful calls to set_user() as the limit was exceeded for the previous user, not the current one. Similar check was introduced in -ow patches (without the process flag). v3 - clear PF_NPROC_EXCEEDED on successful calls to set_user(). Reviewed-by: James Morris <jmorris@namei.org> Signed-off-by: Vasiliy Kulikov <segoon@openwall.com> Acked-by: NeilBrown <neilb@suse.de> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-26kernel/fork.c: fix a few coding style issuesDaniel Rebelo de Oliveira
Signed-off-by: Daniel Rebelo de Oliveira <psykon@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-26cpusets: randomize node rotor used in cpuset_mem_spread_node()Michal Hocko
[ This patch has already been accepted as commit 0ac0c0d0f837 but later reverted (commit 35926ff5fba8) because it itroduced arch specific __node_random which was defined only for x86 code so it broke other archs. This is a followup without any arch specific code. Other than that there are no functional changes.] Some workloads that create a large number of small files tend to assign too many pages to node 0 (multi-node systems). Part of the reason is that the rotor (in cpuset_mem_spread_node()) used to assign nodes starts at node 0 for newly created tasks. This patch changes the rotor to be initialized to a random node number of the cpuset. [akpm@linux-foundation.org: fix layout] [Lee.Schermerhorn@hp.com: Define stub numa_random() for !NUMA configuration] [mhocko@suse.cz: Make it arch independent] [akpm@linux-foundation.org: fix CONFIG_NUMA=y, MAX_NUMNODES>1 build] Signed-off-by: Jack Steiner <steiner@sgi.com> Signed-off-by: Lee Schermerhorn <lee.schermerhorn@hp.com> Signed-off-by: Michal Hocko <mhocko@suse.cz> Reviewed-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Christoph Lameter <cl@linux-foundation.org> Cc: Pekka Enberg <penberg@cs.helsinki.fi> Cc: Paul Menage <menage@google.com> Cc: Jack Steiner <steiner@sgi.com> Cc: Robin Holt <holt@sgi.com> Cc: David Rientjes <rientjes@google.com> Cc: Christoph Lameter <cl@linux-foundation.org> Cc: David Rientjes <rientjes@google.com> Cc: Jack Steiner <steiner@sgi.com> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Lee Schermerhorn <lee.schermerhorn@hp.com> Cc: Michal Hocko <mhocko@suse.cz> Cc: Paul Menage <menage@google.com> Cc: Pekka Enberg <penberg@cs.helsinki.fi> Cc: Robin Holt <holt@sgi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-25Merge branch 'for-3.1/core' of git://git.kernel.dk/linux-blockLinus Torvalds
* 'for-3.1/core' of git://git.kernel.dk/linux-block: (24 commits) block: strict rq_affinity backing-dev: use synchronize_rcu_expedited instead of synchronize_rcu block: fix patch import error in max_discard_sectors check block: reorder request_queue to remove 64 bit alignment padding CFQ: add think time check for group CFQ: add think time check for service tree CFQ: move think time check variables to a separate struct fixlet: Remove fs_excl from struct task. cfq: Remove special treatment for metadata rqs. block: document blk_plug list access block: avoid building too big plug list compat_ioctl: fix make headers_check regression block: eliminate potential for infinite loop in blkdev_issue_discard compat_ioctl: fix warning caused by qemu block: flush MEDIA_CHANGE from drivers on close(2) blk-throttle: Make total_nr_queued unsigned block: Add __attribute__((format(printf...) and fix fallout fs/partitions/check.c: make local symbols static block:remove some spare spaces in genhd.c block:fix the comment error in blkdev.h ...
2011-07-22Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6: (107 commits) vfs: use ERR_CAST for err-ptr tossing in lookup_instantiate_filp isofs: Remove global fs lock jffs2: fix IN_DELETE_SELF on overwriting rename() killing a directory fix IN_DELETE_SELF on overwriting rename() on ramfs et.al. mm/truncate.c: fix build for CONFIG_BLOCK not enabled fs:update the NOTE of the file_operations structure Remove dead code in dget_parent() AFS: Fix silly characters in a comment switch d_add_ci() to d_splice_alias() in "found negative" case as well simplify gfs2_lookup() jfs_lookup(): don't bother with . or .. get rid of useless dget_parent() in btrfs rename() and link() get rid of useless dget_parent() in fs/btrfs/ioctl.c fs: push i_mutex and filemap_write_and_wait down into ->fsync() handlers drivers: fix up various ->llseek() implementations fs: handle SEEK_HOLE/SEEK_DATA properly in all fs's that define their own llseek Ext4: handle SEEK_HOLE/SEEK_DATA generically Btrfs: implement our own ->llseek fs: add SEEK_HOLE and SEEK_DATA flags reiserfs: make reiserfs default to barrier=flush ... Fix up trivial conflicts in fs/xfs/linux-2.6/xfs_super.c due to the new shrinker callout for the inode cache, that clashed with the xfs code to start the periodic workers later.
2011-07-22Merge branch 'core-locking-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'core-locking-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: lockdep: Fix lockdep_no_validate against IRQ states mutex: Make mutex_destroy() an inline function plist: Remove the need to supply locks to plist heads lockup detector: Fix reference to the non-existent CONFIG_DETECT_SOFTLOCKUP option
2011-07-20make sure that nsproxy_cache is initialized early enoughAl Viro
2011-07-17ptrace: mv send-SIGSTOP from do_fork() to ptrace_init_task()Oleg Nesterov
If the new child is traced, do_fork() adds the pending SIGSTOP. It assumes that either it is traced because of auto-attach or the tracer attached later, in both cases sigaddset/set_thread_flag is correct even if SIGSTOP is already pending. Now that we have PTRACE_SEIZE this is no longer right in the latter case. If the tracer does PTRACE_SEIZE after copy_process() makes the child visible the queued SIGSTOP is wrong. We could check PT_SEIZED bit and change ptrace_attach() to set both PT_PTRACED and PT_SEIZED bits simultaneously but see the next patch, we need to know whether this child was auto-attached or not anyway. So this patch simply moves this code to ptrace_init_task(), this way we can never race with ptrace_attach(). Signed-off-by: Oleg Nesterov <oleg@redhat.com> Acked-by: Tejun Heo <tj@kernel.org>
2011-07-12fixlet: Remove fs_excl from struct task.Justin TerAvest
fs_excl is a poor man's priority inheritance for filesystems to hint to the block layer that an operation is important. It was never clearly specified, not widely adopted, and will not prevent starvation in many cases (like across cgroups). fs_excl was introduced with the time sliced CFQ IO scheduler, to indicate when a process held FS exclusive resources and thus needed a boost. It doesn't cover all file systems, and it was never fully complete. Lets kill it. Signed-off-by: Justin TerAvest <teravest@google.com> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2011-07-08plist: Remove the need to supply locks to plist headsDima Zavin
This was legacy code brought over from the RT tree and is no longer necessary. Signed-off-by: Dima Zavin <dima@android.com> Acked-by: Thomas Gleixner <tglx@linutronix.de> Cc: Daniel Walker <dwalker@codeaurora.org> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Andi Kleen <andi@firstfloor.org> Cc: Lai Jiangshan <laijs@cn.fujitsu.com> Link: http://lkml.kernel.org/r/1310084879-10351-2-git-send-email-dima@android.com Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-06-22ptrace: kill clone/exec tracehooksTejun Heo
At this point, tracehooks aren't useful to mainline kernel and mostly just add an extra layer of obfuscation. Although they have comments, without actual in-kernel users, it is difficult to tell what are their assumptions and they're actually trying to achieve. To mainline kernel, they just aren't worth keeping around. This patch kills the following clone and exec related tracehooks. tracehook_prepare_clone() tracehook_finish_clone() tracehook_report_clone() tracehook_report_clone_complete() tracehook_unsafe_exec() The changes are mostly trivial - logic is moved to the caller and comments are merged and adjusted appropriately. The only exception is in check_unsafe_exec() where LSM_UNSAFE_PTRACE* are OR'd to bprm->unsafe instead of setting it, which produces the same result as the field is always zero on entry. It also tests p->ptrace instead of (p->ptrace & PT_PTRACED) for consistency, which also gives the same result. This doesn't introduce any behavior change. Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Christoph Hellwig <hch@infradead.org> Signed-off-by: Oleg Nesterov <oleg@redhat.com>
2011-06-22ptrace: kill trivial tracehooksTejun Heo
At this point, tracehooks aren't useful to mainline kernel and mostly just add an extra layer of obfuscation. Although they have comments, without actual in-kernel users, it is difficult to tell what are their assumptions and they're actually trying to achieve. To mainline kernel, they just aren't worth keeping around. This patch kills the following trivial tracehooks. * Ones testing whether task is ptraced. Replace with ->ptrace test. tracehook_expect_breakpoints() tracehook_consider_ignored_signal() tracehook_consider_fatal_signal() * ptrace_event() wrappers. Call directly. tracehook_report_exec() tracehook_report_exit() tracehook_report_vfork_done() * ptrace_release_task() wrapper. Call directly. tracehook_finish_release_task() * noop tracehook_prepare_release_task() tracehook_report_death() This doesn't introduce any behavior change. Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Christoph Hellwig <hch@infradead.org> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Oleg Nesterov <oleg@redhat.com>
2011-05-29mm: Fix boot crash in mm_alloc()Linus Torvalds
Thomas Gleixner reports that we now have a boot crash triggered by CONFIG_CPUMASK_OFFSTACK=y: BUG: unable to handle kernel NULL pointer dereference at (null) IP: [<c11ae035>] find_next_bit+0x55/0xb0 Call Trace: [<c11addda>] cpumask_any_but+0x2a/0x70 [<c102396b>] flush_tlb_mm+0x2b/0x80 [<c1022705>] pud_populate+0x35/0x50 [<c10227ba>] pgd_alloc+0x9a/0xf0 [<c103a3fc>] mm_init+0xec/0x120 [<c103a7a3>] mm_alloc+0x53/0xd0 which was introduced by commit de03c72cfce5 ("mm: convert mm->cpu_vm_cpumask into cpumask_var_t"), and is due to wrong ordering of mm_init() vs mm_init_cpumask Thomas wrote a patch to just fix the ordering of initialization, but I hate the new double allocation in the fork path, so I ended up instead doing some more radical surgery to clean it all up. Reported-by: Thomas Gleixner <tglx@linutronix.de> Reported-by: Ingo Molnar <mingo@elte.hu> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-26mm: extract exe_file handling from procfsJiri Slaby
Setup and cleanup of mm_struct->exe_file is currently done in fs/proc/. This was because exe_file was needed only for /proc/<pid>/exe. Since we will need the exe_file functionality also for core dumps (so core name can contain full binary path), built this functionality always into the kernel. To achieve that move that out of proc FS to the kernel/ where in fact it should belong. By doing that we can make dup_mm_exe_file static. Also we can drop linux/proc_fs.h inclusion in fs/exec.c and kernel/fork.c. Signed-off-by: Jiri Slaby <jslaby@suse.cz> Cc: Alexander Viro <viro@zeniv.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
