path: root/kernel/freezer.c
2010-12-24Freezer: Fix a race during freezing of TASK_STOPPED tasksTejun Heo
After calling freeze_task(), try_to_freeze_tasks() see whether the task is stopped or traced and if so, considers it to be frozen; however, nothing guarantees that either the task being frozen sees TIF_FREEZE or the freezer sees TASK_STOPPED -> TASK_RUNNING transition. The task being frozen may wake up and not see TIF_FREEZE while the freezer fails to notice the transition and believes the task is still stopped. This patch fixes the race by making freeze_task() always go through fake_signal_wake_up() for applicable tasks. The function goes through the target task's scheduler lock and thus guarantees that either the target sees TIF_FREEZE or try_to_freeze_task() sees TASK_RUNNING. Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl>
2009-07-18sched: fix nr_uninterruptible accounting of frozen tasks reallyThomas Gleixner
commit e3c8ca8336 (sched: do not count frozen tasks toward load) broke the nr_uninterruptible accounting on freeze/thaw. On freeze the task is excluded from accounting with a check for (task->flags & PF_FROZEN), but that flag is cleared before the task is thawed. So while we prevent that the task with state TASK_UNINTERRUPTIBLE is accounted to nr_uninterruptible on freeze we decrement nr_uninterruptible on thaw. Use a separate flag which is handled by the freezing task itself. Set it before calling the scheduler with TASK_UNINTERRUPTIBLE state and clear it after we return from frozen state. Cc: <stable@kernel.org> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-10-30freezer_cg: use thaw_process() in unfreeze_cgroup()Li Zefan
Don't duplicate the implementation of thaw_process(). [akpm@linux-foundation.org: make __thaw_process() static] Signed-off-by: Li Zefan <lizf@cn.fujitsu.com> Cc: Cedric Le Goater <clg@fr.ibm.com> Acked-by: Matt Helsley <matthltc@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-20container freezer: implement freezer cgroup subsystemMatt Helsley
This patch implements a new freezer subsystem in the control groups framework. It provides a way to stop and resume execution of all tasks in a cgroup by writing in the cgroup filesystem. The freezer subsystem in the container filesystem defines a file named freezer.state. Writing "FROZEN" to the state file will freeze all tasks in the cgroup. Subsequently writing "RUNNING" will unfreeze the tasks in the cgroup. Reading will return the current state. * Examples of usage : # mkdir /containers/freezer # mount -t cgroup -ofreezer freezer /containers # mkdir /containers/0 # echo $some_pid > /containers/0/tasks to get status of the freezer subsystem : # cat /containers/0/freezer.state RUNNING to freeze all tasks in the container : # echo FROZEN > /containers/0/freezer.state # cat /containers/0/freezer.state FREEZING # cat /containers/0/freezer.state FROZEN to unfreeze all tasks in the container : # echo RUNNING > /containers/0/freezer.state # cat /containers/0/freezer.state RUNNING This is the basic mechanism which should do the right thing for user space task in a simple scenario. It's important to note that freezing can be incomplete. In that case we return EBUSY. This means that some tasks in the cgroup are busy doing something that prevents us from completely freezing the cgroup at this time. After EBUSY, the cgroup will remain partially frozen -- reflected by freezer.state reporting "FREEZING" when read. The state will remain "FREEZING" until one of these things happens: 1) Userspace cancels the freezing operation by writing "RUNNING" to the freezer.state file 2) Userspace retries the freezing operation by writing "FROZEN" to the freezer.state file (writing "FREEZING" is not legal and returns EIO) 3) The tasks that blocked the cgroup from entering the "FROZEN" state disappear from the cgroup's set of tasks. [akpm@linux-foundation.org: coding-style fixes] [akpm@linux-foundation.org: export thaw_process] Signed-off-by: Cedric Le Goater <clg@fr.ibm.com> Signed-off-by: Matt Helsley <matthltc@us.ibm.com> Acked-by: Serge E. Hallyn <serue@us.ibm.com> Tested-by: Matt Helsley <matthltc@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-20container freezer: make refrigerator always availableMatt Helsley
Now that the TIF_FREEZE flag is available in all architectures, extract the refrigerator() and freeze_task() from kernel/power/process.c and make it available to all. The refrigerator() can now be used in a control group subsystem implementing a control group freezer. Signed-off-by: Cedric Le Goater <clg@fr.ibm.com> Signed-off-by: Matt Helsley <matthltc@us.ibm.com> Acked-by: Serge E. Hallyn <serue@us.ibm.com> Tested-by: Matt Helsley <matthltc@us.ibm.com> Cc: "Rafael J. Wysocki" <rjw@sisk.pl> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
