No need to assign ret in each case and break. Simply return the result
of the handler function directly.
Cc: Darren Hart <dvhart@linux.intel.com>
Signed-off-by: Huang Shijie <b32955@freescale.com>
Change a single occurrence of "unlcoked" into "unlocked".
Signed-off-by: Bart Van Assche <bvanassche@acm.org>
Cc: Darren Hart <dvhltc@us.ibm.com>
The variables here are really not used uninitialized.
kernel/futex.c: In function 'fixup_pi_state_owner.clone.17':
kernel/futex.c:1582:6: warning: 'curval' may be used uninitialized in this function
kernel/futex.c: In function 'handle_futex_death':
kernel/futex.c:2486:6: warning: 'nval' may be used uninitialized in this function
kernel/futex.c: In function 'do_futex':
kernel/futex.c:863:11: warning: 'curval' may be used uninitialized in this function
kernel/futex.c:828:6: note: 'curval' was declared here
kernel/futex.c:898:5: warning: 'oldval' may be used uninitialized in this function
kernel/futex.c:890:6: note: 'oldval' was declared here
Signed-off-by: Vitaliy Ivanov <vitalivanov@gmail.com>
Acked-by: Darren Hart <dvhart@linux.intel.com>
This was legacy code brought over from the RT tree and
is no longer necessary.
Signed-off-by: Dima Zavin <dima@android.com>
Cc: Daniel Walker <dwalker@codeaurora.org>
Cc: Lai Jiangshan <laijs@cn.fujitsu.com>
Link: http://lkml.kernel.org/r/1310084879-10351-2-git-send-email-dima@android.com
commit bdbb776f882f5ad431aa1e694c69c1c3d6a4a5b8 upstream.
It was possible to extract the robust list head address from a setuid
process if it had used set_robust_list(), allowing an ASLR info leak. This
changes the permission checks to be the same as those used for similar
info that comes out of /proc.
Running a setuid program that uses robust futexes would have had:
cred->euid != pcred->euid
cred->euid == pcred->uid
so the old permissions check would allow it. I'm not aware of any setuid
programs that use robust futexes, so this is just a preventative measure.
(This patch is based on changes from grsecurity.)
Cc: Jiri Kosina <jkosina@suse.cz>
Cc: Eric W. Biederman <ebiederm@xmission.com>
Cc: Serge E. Hallyn <serge.hallyn@canonical.com>
Cc: kernel-hardening@lists.openwall.com
Cc: spender@grsecurity.net
Link: http://lkml.kernel.org/r/20120319231253.GA20893@www.outflux.net
commit 59263b513c11398cd66a52d4c5b2b118ce1e0359 upstream.
Some of the newer futex PI opcodes do not check the cmpxchg enabled
variable and call unconditionally into the handling functions. Cover
all PI opcodes in a separate check.
commit e6780f7243eddb133cc20ec37fa69317c218b709 upstream.
It was found (by Sasha) that if you use a futex located in the gate
area we get stuck in an uninterruptible infinite loop, much like the
ZERO_PAGE issue.
While looking at this problem, PeterZ realized you'll get into similar
trouble when hitting any install_special_pages() mapping. And are there
still drivers setting up their own special mmaps without page->mapping,
and without special VM or pte flags to make get_user_pages fail?
In most cases, if page->mapping is NULL, we do not need to retry at all:
Linus points out that even /proc/sys/vm/drop_caches poses no problem,
because it ends up using remove_mapping(), which takes care not to
interfere when the page reference count is raised.
But there is still one case which does need a retry: if memory pressure
called shmem_writepage in between get_user_pages_fast dropping page
table lock and our acquiring page lock, then the page gets switched from
filecache to swapcache (and ->mapping set to NULL) whatever the refcount.
Fault it back in to get the page->mapping needed for key->shared.inode.
Reported-by: Sasha Levin <levinsasha928@gmail.com>
commit 9ea71503a8ed9184d2d0b8ccc4d269d05f7940ae upstream.
commit 7485d0d3758e8e6491a5c9468114e74dc050785d (futexes: Remove rw
parameter from get_futex_key()) in 2.6.33 fixed two problems: First, It
prevented a loop when encountering a ZERO_PAGE. Second, it fixed RW
MAP_PRIVATE futex operations by forcing the COW to occur by
unconditionally performing a write access get_user_pages_fast() to get
the page. The commit also introduced a user-mode regression in that it
broke futex operations on read-only memory maps. For example, this
breaks workloads that have one or more reader processes doing a
FUTEX_WAIT on a futex within a read only shared file mapping, and a
writer processes that has a writable mapping issuing the FUTEX_WAKE.
This fixes the regression for valid futex operations on RO mappings by
trying a RO get_user_pages_fast() when the RW get_user_pages_fast()
fails. This change makes it necessary to also check for invalid use
cases, such as anonymous RO mappings (which can never change) and the
ZERO_PAGE which the commit referenced above was written to address.
This patch does restore the original behavior with RO MAP_PRIVATE
mappings, which have inherent user-mode usage problems and don't really
make sense. With this patch performing a FUTEX_WAIT within a RO
MAP_PRIVATE mapping will be successfully woken provided another process
updates the region of the underlying mapped file. However, the mmap()
man page states that for a MAP_PRIVATE mapping:
It is unspecified whether changes made to the file after
the mmap() call are visible in the mapped region.
So user-mode users attempting to use futex operations on RO MAP_PRIVATE
mappings are depending on unspecified behavior. Additionally a
RO MAP_PRIVATE mapping could fail to wake up in the following case.
Thread-A: call futex(FUTEX_WAIT, memory-region-A).
get_futex_key() return inode based key.
sleep on the key
Thread-B: call mprotect(PROT_READ|PROT_WRITE, memory-region-A)
Thread-B: write memory-region-A.
COW happen. This process's memory-region-A become related
to new COWed private (ie PageAnon=1) page.
Thread-B: call futex(FUETX_WAKE, memory-region-A).
get_futex_key() return mm based key.
IOW, we fail to wake up Thread-A.
Once again doing something like this is just silly and users who do
something like this get what they deserve.
While RO MAP_PRIVATE mappings are nonsensical, checking for a private
mapping requires walking the vmas and was deemed too costly to avoid a
userspace hang.
This Patch is based on Peter Zijlstra's initial patch with modifications to
only allow RO mappings for futex operations that need VERIFY_READ access.
Reported-by: David Oliver <david@rgmadvisors.com>
Signed-off-by: Shawn Bohrer <sbohrer@rgmadvisors.com>
Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl>
Signed-off-by: Darren Hart <dvhart@linux.intel.com>
Cc: peterz@infradead.org
Cc: eric.dumazet@gmail.com
Cc: zvonler@rgmadvisors.com
Cc: hughd@google.com
Link: http://lkml.kernel.org/r/1309450892-30676-1-git-send-email-sbohrer@rgmadvisors.com
commit 2efaca927f5cd7ecd0f1554b8f9b6a9a2c329c03 upstream.
I haven't reproduced it myself but the fail scenario is that on such
machines (notably ARM and some embedded powerpc), if you manage to hit
that futex path on a writable page whose dirty bit has gone from the PTE,
you'll livelock inside the kernel from what I can tell.
It will go in a loop of trying the atomic access, failing, trying gup to
"fix it up", getting succcess from gup, go back to the atomic access,
failing again because dirty wasn't fixed etc...
So I think you essentially hang in the kernel.
The scenario is probably rare'ish because affected architecture are
embedded and tend to not swap much (if at all) so we probably rarely hit
the case where dirty is missing or young is missing, but I think Shan has
a piece of SW that can reliably reproduce it using a shared writable
mapping & fork or something like that.
On archs who use SW tracking of dirty & young, a page without dirty is
effectively mapped read-only and a page without young unaccessible in the
PTE.
Additionally, some architectures might lazily flush the TLB when relaxing
write protection (by doing only a local flush), and expect a fault to
invalidate the stale entry if it's still present on another processor.
The futex code assumes that if the "in_atomic()" access -EFAULT's, it can
"fix it up" by causing get_user_pages() which would then be equivalent to
taking the fault.
However that isn't the case. get_user_pages() will not call
handle_mm_fault() in the case where the PTE seems to have the right
permissions, regardless of the dirty and young state. It will eventually
update those bits ... in the struct page, but not in the PTE.
Additionally, it will not handle the lazy TLB flushing that can be
required by some architectures in the fault case.
Basically, gup is the wrong interface for the job. The patch provides a
more appropriate one which boils down to just calling handle_mm_fault()
since what we are trying to do is simulate a real page fault.
The futex code currently attempts to write to user memory within a
pagefault disabled section, and if that fails, tries to fix it up using
get_user_pages().
This doesn't work on archs where the dirty and young bits are maintained
by software, since they will gate access permission in the TLB, and will
not be updated by gup().
In addition, there's an expectation on some archs that a spurious write
fault triggers a local TLB flush, and that is missing from the picture as
well.
I decided that adding those "features" to gup() would be too much for this
already too complex function, and instead added a new simpler
fixup_user_fault() which is essentially a wrapper around handle_mm_fault()
which the futex code can call.
[akpm@linux-foundation.org: fix some nits Darren saw, fiddle comment layout]
Reported-by: Shan Hai <haishan.bai@gmail.com>
Tested-by: Shan Hai <haishan.bai@gmail.com>
Cc: David Laight <David.Laight@ACULAB.COM>
Cc: Darren Hart <darren.hart@intel.com>
The FLAGS_HAS_TIMEOUT flag was not getting set, causing the restart_block to
restart futex_wait() without a timeout after a signal.
Commit b41277dc7a18ee332d in 2.6.38 introduced the regression by accidentally
removing the the FLAGS_HAS_TIMEOUT assignment from futex_wait() during the setup
of the restart block. Restore the originaly behavior.
Fixes: https://bugzilla.kernel.org/show_bug.cgi?id=32922
Reported-by: Tim Smith <tsmith201104@yahoo.com>
Reported-by: Torsten Hilbrich <torsten.hilbrich@secunet.com>
Cc: John Kacur <jkacur@redhat.com>
Cc: stable@kernel.org
Link: http://lkml.kernel.org/r/%3Cdaac0eb3af607f72b9a4d3126b2ba8fb5ed3b883.1302820917.git.dvhart%40linux.intel.com%3E
* 'core-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
futex: Fix WARN_ON() test for UP
WARN_ON_SMP(): Allow use in if() statements on UP
x86, dumpstack: Use %pB format specifier for stack trace
vsprintf: Introduce %pB format specifier
lockdep: Remove unused 'factor' variable from lockdep_stats_show()
An update of the futex code had a
WARN_ON(!spin_is_locked(q->lock_ptr))
But on UP, spin_is_locked() is always false, and will
trigger this warning, and even worse, it will exit the function
without doing the necessary work.
Converting this to a WARN_ON_SMP() fixes the problem.
Reported-by: Richard Weinberger <richard@nod.at>
Tested-by: Richard Weinberger <richard@nod.at>
Acked-by: Peter Zijlstra <peterz@infradead.org>
LKML-Reference: <20110317192208.682654502@goodmis.org>
CAP_IPC_OWNER and CAP_IPC_LOCK can be checked against current_user_ns(),
because the resource comes from current's own ipc namespace.
setuid/setgid are to uids in own namespace, so again checks can be against
current_user_ns().
Changelog:
Jan 11: Use task_ns_capable() in place of sched_capable().
Jan 11: Use nsown_capable() as suggested by Bastian Blank.
Jan 11: Clarify (hopefully) some logic in futex and sched.c
Feb 15: use ns_capable for ipc, not nsown_capable
Feb 23: let copy_ipcs handle setting ipc_ns->user_ns
Feb 23: pass ns down rather than taking it from current
Signed-off-by: Serge E. Hallyn <serge.hallyn@canonical.com>
Acked-by: "Eric W. Biederman" <ebiederm@xmission.com>
Acked-by: Daniel Lezcano <daniel.lezcano@free.fr>
* 'core-locking-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
rtmutex: tester: Remove the remaining BKL leftovers
lockdep/timers: Explain in detail the locking problems del_timer_sync() may cause
rtmutex: Simplify PI algorithm and make highest prio task get lock
rwsem: Remove redundant asmregparm annotation
rwsem: Move duplicate function prototypes to linux/rwsem.h
rwsem: Unify the duplicate rwsem_is_locked() inlines
rwsem: Move duplicate init macros and functions to linux/rwsem.h
rwsem: Move duplicate struct rwsem declaration to linux/rwsem.h
x86: Cleanup rwsem_count_t typedef
rwsem: Cleanup includes
locking: Remove deprecated lock initializers
cred: Replace deprecated spinlock initialization
kthread: Replace deprecated spinlock initialization
xtensa: Replace deprecated spinlock initialization
um: Replace deprecated spinlock initialization
sparc: Replace deprecated spinlock initialization
mips: Replace deprecated spinlock initialization
cris: Replace deprecated spinlock initialization
alpha: Replace deprecated spinlock initialization
rtmutex-tester: Remove BKL tests
handle_futex_death() uses futex_atomic_cmpxchg_inatomic() without
disabling page faults. That's ok, but totally non obvious.
We don't hold locks so we actually can and want to fault here, because
the get_user() before futex_atomic_cmpxchg_inatomic() does not
guarantee a R/W mapping.
We could just add a big fat comment to explain this, but actually
changing the code so that the functionality is entirely clear is
better.
Use the helper function which disables page faults around the
futex_atomic_cmpxchg_inatomic() and handle a fault with a call to
fault_in_user_writeable() as all other places in the futex code do as
well.
Pointed-out-by: Linus Torvalds <torvalds@linux-foundation.org>
Acked-by: Darren Hart <darren@dvhart.com>
Cc: Michel Lespinasse <walken@google.com>
Cc: Matt Turner <mattst88@gmail.com>
Cc: "James E.J. Bottomley" <jejb@parisc-linux.org>
Cc: Chris Metcalf <cmetcalf@tilera.com>
LKML-Reference: <alpine.LFD.2.00.1103141126590.2787@localhost6.localdomain6>
git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-2.6-rt into core/futexes
futex,plist: Pass the real head of the priority list to plist_del()
futex,plist: Remove debug lock assignment from plist_node
plist: Shrink struct plist_head
plist: Add priority list test
The original code uses &plist_node->plist as the fake head of
the priority list for plist_del(), these debug locks in
the fake head are needed for CONFIG_DEBUG_PI_LIST.
But now we always pass the real head to plist_del(), the debug locks
in plist_node will not be used, so we remove these assignments.
Signed-off-by: Lai Jiangshan <laijs@cn.fujitsu.com>
LKML-Reference: <4D10797E.7040803@cn.fujitsu.com>
Some plist_del()s in kernel/futex.c are passed a faked head of the
priority list.
It does not fail because the current code does not require the real head
in plist_del(). The current code of plist_del() just uses the head for checking,
so it will not cause a bad result even when we use a faked head.
But it is undocumented usage:
* plist_del - Remove a @node from plist.
* @node: &struct plist_node pointer - entry to be removed
* @head: &struct plist_head pointer - list head
The document says that the @head is the "list head" head of the priority list.
In futex code, several places use "plist_del(&q->list, &q->list.plist);",
they pass a fake head. We need to fix them all.
Thanks to Darren Hart for many suggestions.
LKML-Reference: <4D11984A.5030203@cn.fujitsu.com>
The cmpxchg_futex_value_locked API was funny in that it returned either
the original, user-exposed futex value OR an error code such as -EFAULT.
This was confusing at best, and could be a source of livelocks in places
that retry the cmpxchg_futex_value_locked after trying to fix the issue
by running fault_in_user_writeable().
This change makes the cmpxchg_futex_value_locked API more similar to the
get_futex_value_locked one, returning an error code and updating the
original value through a reference argument.
Signed-off-by: Michel Lespinasse <walken@google.com>
Acked-by: Chris Metcalf <cmetcalf@tilera.com> [tile]
Acked-by: Tony Luck <tony.luck@intel.com> [ia64]
Tested-by: Michal Simek <monstr@monstr.eu> [microblaze]
Acked-by: David Howells <dhowells@redhat.com> [frv]
Cc: Darren Hart <darren@dvhart.com>
LKML-Reference: <20110311024851.GC26122@google.com>
The result is not going to change under us, so no need to reevaluate
this over and over. Seems to be a leftover from the mechanical mass
conversion of task->pid to task_pid_vnr(tsk).
Reviving a cleanup I had done about a year ago as part of a larger
futex_set_wait proposal. Over the years, the locking of the hashed
futex queue got improved, so that some of the "rare but normal" race
conditions described in comments can't actually happen anymore.
LKML-Reference: <20110307020750.GA31188@google.com>
In current rtmutex, the pending owner may be boosted by the tasks
in the rtmutex's waitlist when the pending owner is deboosted
or a task in the waitlist is boosted. This boosting is unrelated,
because the pending owner does not really take the rtmutex.
It is not reasonable.
Example.
time1:
A(high prio) onwers the rtmutex.
B(mid prio) and C (low prio) in the waitlist.
time2
A release the lock, B becomes the pending owner
A(or other high prio task) continues to run. B's prio is lower
than A, so B is just queued at the runqueue.
time3
A or other high prio task sleeps, but we have passed some time
The B and C's prio are changed in the period (time2 ~ time3)
due to boosting or deboosting. Now C has the priority higher
than B. ***Is it reasonable that C has to boost B and help B to
get the rtmutex?
NO!! I think, it is unrelated/unneed boosting before B really
owns the rtmutex. We should give C a chance to beat B and
win the rtmutex.
This is the motivation of this patch. This patch *ensures*
only the top waiter or higher priority task can take the lock.
How?
1) we don't dequeue the top waiter when unlock, if the top waiter
is changed, the old top waiter will fail and go to sleep again.
2) when requiring lock, it will get the lock when the lock is not taken and:
there is no waiter OR higher priority than waiters OR it is top waiter.
3) In any time, the top waiter is changed, the top waiter will be woken up.
The algorithm is much simpler than before, no pending owner, no
boosting for pending owner.
Other advantage of this patch:
1) The states of a rtmutex are reduced a half, easier to read the code.
2) the codes become shorter.
3) top waiter is not dequeued until it really take the lock:
they will retain FIFO when it is stolen.
Not advantage nor disadvantage
1) Even we may wakeup multiple waiters(any time when top waiter changed),
we hardly cause "thundering herd",
the number of wokenup task is likely 1 or very little.
2) two APIs are changed.
rt_mutex_owner() will not return pending owner, it will return NULL when
the top waiter is going to take the lock.
rt_mutex_next_owner() always return the top waiter.
will not return NULL if we have waiters
because the top waiter is not dequeued.
I have fixed the code that use these APIs.
need updated after this patch is accepted
1) Document/*
2) the testcase scripts/rt-tester/t4-l2-pi-deboost.tst
LKML-Reference: <4D3012D5.4060709@cn.fujitsu.com>
Reviewed-by: Steven Rostedt <rostedt@goodmis.org>
'timers-fixes-for-linus' and 'perf-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip
rcu: avoid pointless blocked-task warnings
rcu: demote SRCU_SYNCHRONIZE_DELAY from kernel-parameter status
rtmutex: Fix comment about why new_owner can be NULL in wake_futex_pi()
* 'x86-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
x86, olpc: Add missing Kconfig dependencies
x86, mrst: Set correct APB timer IRQ affinity for secondary cpu
x86: tsc: Fix calibration refinement conditionals to avoid divide by zero
x86, ia64, acpi: Clean up x86-ism in drivers/acpi/numa.c
* 'timers-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
timekeeping: Make local variables static
time: Rename misnamed minsec argument of clocks_calc_mult_shift()
* 'perf-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
tracing: Remove syscall_exit_fields
tracing: Only process module tracepoints once
perf record: Add "nodelay" mode, disabled by default
perf sched: Fix list of events, dropping unsupported ':r' modifier
Revert "perf tools: Emit clearer message for sys_perf_event_open ENOENT return"
perf top: Fix annotate segv
perf evsel: Fix order of event list deletion
Futex code is smarter than most other gup_fast O_DIRECT code and knows
about the compound internals. However now doing a put_page(head_page)
will not release the pin on the tail page taken by gup-fast, leading to
all sort of refcounting bugchecks. Getting a stable head_page is a little
tricky.
page_head = page is there because if this is not a tail page it's also the
page_head. Only in case this is a tail page, compound_head is called,
otherwise it's guaranteed unnecessary. And if it's a tail page
compound_head has to run atomically inside irq disabled section
__get_user_pages_fast before returning. Otherwise ->first_page won't be a
stable pointer.
Disableing irq before __get_user_page_fast and releasing irq after running
compound_head is needed because if __get_user_page_fast returns == 1, it
means the huge pmd is established and cannot go away from under us.
pmdp_splitting_flush_notify in __split_huge_page_splitting will have to
wait for local_irq_enable before the IPI delivery can return. This means
__split_huge_page_refcount can't be running from under us, and in turn
when we run compound_head(page) we're not reading a dangling pointer from
tailpage->first_page. Then after we get to stable head page, we are
always safe to call compound_lock and after taking the compound lock on
head page we can finally re-check if the page returned by gup-fast is
still a tail page. in which case we're set and we didn't need to split
the hugepage in order to take a futex on it.
Signed-off-by: Andrea Arcangeli <aarcange@redhat.com>
Acked-by: Mel Gorman <mel@csn.ul.ie>
The comment about why rt_mutex_next_owner() can return NULL in
wake_futex_pi() is not the normal case.
Tracing the cause of why this occurs is more likely that waiter
simply timedout. But because it originally caused contention with
the futex, the owner will go into the kernel when it unlocks
the lock. Then it will hit this code path and
rt_mutex_next_owner() will return NULL.
The futex_q struct has grown considerably over the last couple years. I
believe it now merits a static initializer to avoid uninitialized data
errors (having spent more time than I care to admit debugging an uninitialized
q.bitset in an experimental new op code).
With the key initializer built in, several of the FUTEX_KEY_INIT calls can
be removed.
V2: use a static variable instead of an init macro.
use a C99 initializer and don't rely on variable ordering in the struct.
V3: make futex_q_init const
LKML-Reference: <1289252428-18383-1-git-send-email-dvhart@linux.intel.com>
In the early days we passed the mmap sem around. That became the
"int fshared" with the fast gup improvements. Then we added
"int clockrt" in places. This patch unifies these options as "flags".
[ tglx: Split out the stale fshared cleanup ]
LKML-Reference: <1289250609-16304-1-git-send-email-dvhart@linux.intel.com>
The fast GUP changes stopped using the fshared flag in
put_futex_keys(), but we kept the interface the same.
Cleanup all stale users.
This patch is split out from Darren Harts combo patch which also
combines various flags. This way the changes are clearly separated.
Since commit 1dcc41bb (futex: Change 3rd arg of fetch_robust_entry()
to unsigned int*) some gcc versions decided to emit the following
warning:
kernel/futex.c: In function ‘exit_robust_list’:
kernel/futex.c:2492: warning: ‘next_pi’ may be used uninitialized in this function
The commit did not introduce the warning as gcc should have warned
before that commit as well. It's just gcc being silly.
The code path really can't result in next_pi being unitialized (or
should not), but let's keep the build clean. Annotate next_pi as an
uninitialized_var.
[ tglx: Addressed the same issue in futex_compat.c and massaged the
changelog ]
Tested-by: Matt Fleming <matt@console-pimps.org>
Tested-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de>
LKML-Reference: <1288897200-13008-1-git-send-email-dvhart@linux.intel.com>
Clones an existing reference to inode; caller must already hold one.
* 'futexes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
futex: Fix kernel-doc notation & typos
futex: Add lock context annotations
futex: Mark restart_block.futex.uaddr[2] __user
futex: Change 3rd arg of fetch_robust_entry() to unsigned int*
futex_wait() is leaking key references due to futex_wait_setup()
acquiring an additional reference via the queue_lock() routine. The
nested key ref-counting has been masking bugs and complicating code
analysis. queue_lock() is only called with a previously ref-counted
key, so remove the additional ref-counting from the queue_(un)lock()
functions.
Also futex_wait_requeue_pi() drops one key reference too many in
unqueue_me_pi(). Remove the key reference handling from
unqueue_me_pi(). This was paired with a queue_lock() in
futex_lock_pi(), so the count remains unchanged.
Document remaining nested key ref-counting sites.
Reported-and-tested-by: Matthieu Fertré<matthieu.fertre@kerlabs.com>
Reported-by: Louis Rilling<louis.rilling@kerlabs.com>
LKML-Reference: <4CBB17A8.70401@linux.intel.com>
Convert futex_requeue() function parameters to use @name
kernel-doc notation and add @fshared & @cmpval to prevent
kernel-doc warnings.
Add @list to struct futex_q.
Fix a few typos.
Acked-by: Rusty Russell <rusty@rustcorp.com.au>
LKML-Reference: <20101013110234.89b06043.randy.dunlap@oracle.com>
queue_lock/unlock/me() and unqueue_me_pi() grab/release spinlocks
but are missing proper annotations. Add them.
Signed-off-by: Namhyung Kim <namhyung@gmail.com>
LKML-Reference: <1284468228-8723-3-git-send-email-namhyung@gmail.com>
@uaddr and @uaddr2 fields in restart_block.futex are user
pointers. Add __user and remove unnecessary casts.
LKML-Reference: <1284468228-8723-2-git-send-email-namhyung@gmail.com>
Sparse complains:
kernel/futex.c:2495:59: warning: incorrect type in argument 3 (different signedness)
Make 3rd argument of fetch_robust_entry() 'unsigned int'.
LKML-Reference: <1284468228-8723-1-git-send-email-namhyung@gmail.com>
futex_find_get_task is currently used (through lookup_pi_state) from two
contexts, futex_requeue and futex_lock_pi_atomic. None of the paths
looks it needs the credentials check, though. Different (e)uids
shouldn't matter at all because the only thing that is important for
shared futex is the accessibility of the shared memory.
The credentail check results in glibc assert failure or process hang (if
glibc is compiled without assert support) for shared robust pthread
mutex with priority inheritance if a process tries to lock already held
lock owned by a process with a different euid:
pthread_mutex_lock.c:312: __pthread_mutex_lock_full: Assertion `(-(e)) != 3 || !robust' failed.
The problem is that futex_lock_pi_atomic which is called when we try to
lock already held lock checks the current holder (tid is stored in the
futex value) to get the PI state. It uses lookup_pi_state which in turn
gets task struct from futex_find_get_task. ESRCH is returned either
when the task is not found or if credentials check fails.
futex_lock_pi_atomic simply returns if it gets ESRCH. glibc code,
however, doesn't expect that robust lock returns with ESRCH because it
should get either success or owner died.
Acked-by: Darren Hart <dvhltc@us.ibm.com>
Cc: Nick Piggin <npiggin@suse.de>
Cc: Alexey Kuznetsov <kuznet@ms2.inr.ac.ru>
The WARN_ON in lookup_pi_state which complains about a mismatch
between pi_state->owner->pid and the pid which we retrieved from the
user space futex is completely bogus.
The code just emits the warning and then continues despite the fact
that it detected an inconsistent state of the futex. A conveniant way
for user space to spam the syslog.
Replace the WARN_ON by a consistency check. If the values do not match
return -EINVAL and let user space deal with the mess it created.
This also fixes the missing task_pid_vnr() when we compare the
pi_state->owner pid with the futex value.
Reported-by: Jermome Marchand <jmarchan@redhat.com>
Cc: <stable@kernel.org>
If the owner of a PI futex dies we fix up the pi_state and set
pi_state->owner to NULL. When a malicious or just sloppy programmed
user space application sets the futex value to 0 e.g. by calling
pthread_mutex_init(), then the futex can be acquired again. A new
waiter manages to enqueue itself on the pi_state w/o damage, but on
unlock the kernel dereferences pi_state->owner and oopses.
Prevent this by checking pi_state->owner in the unlock path. If
pi_state->owner is not current we know that user space manipulated the
futex value. Ignore the mess and return -EINVAL.
This catches the above case and also the case where a task hijacks the
futex by setting the tid value and then tries to unlock it.
This fixes a futex key reference count bug in futex_lock_pi(),
where a key's reference count is incremented twice but decremented
only once, causing the backing object to not be released.
If the futex is created in a temporary file in an ext3 file system,
this bug causes the file's inode to become an "undead" orphan,
which causes an oops from a BUG_ON() in ext3_put_super() when the
file system is unmounted. glibc's test suite is known to trigger this,
see <http://bugzilla.kernel.org/show_bug.cgi?id=14256>.
The bug is a regression from 2.6.28-git3, namely Peter Zijlstra's
38d47c1b7075bd7ec3881141bb3629da58f88dab "[PATCH] futex: rely on
get_user_pages() for shared futexes". That commit made get_futex_key()
also increment the reference count of the futex key, and updated its
callers to decrement the key's reference count before returning.
Unfortunately the normal exit path in futex_lock_pi() wasn't corrected:
the reference count is incremented by get_futex_key() and queue_lock(),
but the normal exit path only decrements once, via unqueue_me_pi().
The fix is to put_futex_key() after unqueue_me_pi(), since 2.6.31
this is easily done by 'goto out_put_key' rather than 'goto out'.
Signed-off-by: Mikael Pettersson <mikpe@it.uu.se>
Currently, futexes have two problem:
A) The current futex code doesn't handle private file mappings properly.
get_futex_key() uses PageAnon() to distinguish file and
anon, which can cause the following bad scenario:
1) thread-A call futex(private-mapping, FUTEX_WAIT), it
sleeps on file mapping object.
2) thread-B writes a variable and it makes it cow.
3) thread-B calls futex(private-mapping, FUTEX_WAKE), it
wakes up blocked thread on the anonymous page. (but it's nothing)
B) Current futex code doesn't handle zero page properly.
Read mode get_user_pages() can return zero page, but current
futex code doesn't handle it at all. Then, zero page makes
infinite loop internally.
The solution is to use write mode get_user_page() always for
page lookup. It prevents the lookup of both file page of private
mappings and zero page.
Performance concerns:
Probaly very little, because glibc always initialize variables
for futex before to call futex(). It means glibc users never see
the overhead of this patch.
Compatibility concerns:
This patch has few compatibility issues. After this patch,
FUTEX_WAIT require writable access to futex variables (read-only
mappings makes EFAULT). But practically it's not a problem,
glibc always initalizes variables for futexes explicitly - nobody
uses read-only mappings.
Reported-by: Hugh Dickins <hugh.dickins@tiscali.co.uk>
Cc: Ulrich Drepper <drepper@gmail.com>
LKML-Reference: <20100105162633.45A2.A69D9226@jp.fujitsu.com>
Convert locks which cannot be sleeping locks in preempt-rt to
raw_spinlocks.
raw_spinlocks.
plists are used with spinlocks and raw_spinlocks. Change the plist
debugging to handle both types.
get_user_pages() must be called with mmap_sem held.
Cc: Andrew Morton <akpm@linuxfoundation.org>
LKML-Reference: <20091208121942.GA21298@basil.fritz.box>
The requeue_pi path doesn't use unqueue_me() (and the racy lock_ptr ==
NULL test) nor does it use the wake_list of futex_wake() which where
the reason for commit 41890f2 (futex: Handle spurious wake up)
See debugging discussing on LKML Message-ID: <4AD4080C.20703@us.ibm.com>
The changes in this fix to the wait_requeue_pi path were considered to
be a likely unecessary, but harmless safety net. But it turns out that
due to the fact that for unknown $@#!*( reasons EWOULDBLOCK is defined
as EAGAIN we built an endless loop in the code path which returns
correctly EWOULDBLOCK.
Spurious wakeups in wait_requeue_pi code path are unlikely so we do
the easy solution and return EWOULDBLOCK^WEAGAIN to user space and let
it deal with the spurious wakeup.
Cc: John Stultz <johnstul@linux.vnet.ibm.com>
Cc: Dinakar Guniguntala <dino@in.ibm.com>
LKML-Reference: <4AE23C74.1090502@us.ibm.com>
When requeuing tasks from one futex to another, the reference held
by the requeued task to the original futex location needs to be
dropped eventually.
Dropping the reference may ultimately lead to a call to
"iput_final" and subsequently call into filesystem- specific code -
which may be non-atomic.
It is therefore safer to defer this drop operation until after the
futex_hash_bucket spinlock has been dropped.
Originally-From: Helge Bahmann <hcb@chaoticmind.net>
Signed-off-by: Darren Hart <dvhltc@us.ibm.com>
Cc: Sven-Thorsten Dietrich <sdietrich@novell.com>
LKML-Reference: <4AD7A298.5040802@us.ibm.com>
If userspace tries to perform a requeue_pi on a non-requeue_pi waiter,
it will find the futex_q->requeue_pi_key to be NULL and OOPS.
Check for NULL in match_futex() instead of doing explicit NULL pointer
checks on all call sites. While match_futex(NULL, NULL) returning
false is a little odd, it's still correct as we expect valid key
references.
CC: Eric Dumazet <eric.dumazet@gmail.com>
CC: Dinakar Guniguntala <dino@in.ibm.com>
CC: John Stultz <johnstul@us.ibm.com>
LKML-Reference: <4AD60687.10306@us.ibm.com>
The futex code does not handle spurious wake up in futex_wait and
futex_wait_requeue_pi.
The code assumes that any wake up which was not caused by futex_wake /
requeue or by a timeout was caused by a signal wake up and returns one
of the syscall restart error codes.
In case of a spurious wake up the signal delivery code which deals
with the restart error codes is not invoked and we return that error
code to user space. That causes applications which actually check the
return codes to fail. Blaise reported that on preempt-rt a python test
program run into a exception trap. -rt exposed that due to a built in
spurious wake up accelerator :)
Solve this by checking signal_pending(current) in the wake up path and
handle the spurious wake up case w/o returning to user space.
Reported-by: Blaise Gassend <blaise@willowgarage.com>
Debugged-by: Darren Hart <dvhltc@us.ibm.com>
LKML-Reference: <new-submission>
futex: fix requeue_pi key imbalance
futex: Fix typo in FUTEX_WAIT/WAKE_BITSET_PRIVATE definitions
rcu: Place root rcu_node structure in separate lockdep class
rcu: Make hot-unplugged CPU relinquish its own RCU callbacks
rcu: Move rcu_barrier() to rcutree
futex: Move exit_pi_state() call to release_mm()
futex: Nullify robust lists after cleanup
futex: Fix locking imbalance
panic: Fix panic message visibility by calling bust_spinlocks(0) before dying
rcu: Replace the rcu_barrier enum with pointer to call_rcu*() function
rcu: Clean up code based on review feedback from Josh Triplett, part 4
rcu: Clean up code based on review feedback from Josh Triplett, part 3
rcu: Fix rcu_lock_map build failure on CONFIG_PROVE_LOCKING=y
rcu: Clean up code to address Ingo's checkpatch feedback
rcu: Clean up code based on review feedback from Josh Triplett, part 2
