commit bdcf0a423ea1c40bbb40e7ee483b50fc8aa3d758 upstream.
In testing, we found that nfsd threads may call set_groups in parallel
for the same entry cached in auth.unix.gid, racing in the call of
groups_sort, corrupting the groups for that entry and leading to
permission denials for the client.
This patch:
- Make groups_sort globally visible.
- Move the call to groups_sort to the modifiers of group_info
- Remove the call to groups_sort from set_groups
Link: http://lkml.kernel.org/r/20171211151420.18655-1-thiago.becker@gmail.com
Signed-off-by: Thiago Rafael Becker <thiago.becker@gmail.com>
Reviewed-by: Matthew Wilcox <mawilcox@microsoft.com>
Reviewed-by: NeilBrown <neilb@suse.com>
Acked-by: "J. Bruce Fields" <bfields@fieldses.org>
Philippe Ombredanne.
How this work was done:
the use cases:
lines of source
lines).
identifiers to apply.
COPYING file license applied.
GPL-2.0 11139
the concluded license(s).
in time.
they are related.
in about 15000 files.
correct identifier.
version early this week with:
license ids and scores
generate the patches.
setgroups is not exactly a hot path, so we might as well use the library
function instead of open-coding the sorting. Saves ~150 bytes.
Link: http://lkml.kernel.org/r/1497301378-22739-1-git-send-email-linux@rasmusvillemoes.dk
Signed-off-by: Rasmus Villemoes <linux@rasmusvillemoes.dk>
Cc: Matthew Wilcox <mawilcox@microsoft.com>
Cc: Michal Hocko <mhocko@suse.com>
Cc: Alexey Dobriyan <adobriyan@gmail.com>
__vmalloc* allows users to provide gfp flags for the underlying
allocation. This API is quite popular
$ git grep "=[[:space:]]__vmalloc\|return[[:space:]]*__vmalloc" | wc -l
77
The only problem is that many people are not aware that they really want
to give __GFP_HIGHMEM along with other flags because there is really no
reason to consume precious lowmemory on CONFIG_HIGHMEM systems for pages
which are mapped to the kernel vmalloc space. About half of users don't
use this flag, though. This signals that we make the API unnecessarily
too complex.
This patch simply uses __GFP_HIGHMEM implicitly when allocating pages to
be mapped to the vmalloc space. Current users which add __GFP_HIGHMEM
are simplified and drop the flag.
Link: http://lkml.kernel.org/r/20170307141020.29107-1-mhocko@kernel.org
Signed-off-by: Michal Hocko <mhocko@suse.com>
Cc: Cristopher Lameter <cl@linux.com>
This was entirely automated, using the script by Al:
PATT='^[[:blank:]]*#[[:blank:]]*include[[:blank:]]*<asm/uaccess.h>'
sed -i -e "s!$PATT!#include <linux/uaccess.h>!" \
$(git grep -l "$PATT"|grep -v ^include/linux/uaccess.h)
to do the replacement at the end of the merge window.
Requested-by: Al Viro <viro@zeniv.linux.org.uk>
Current supplementary groups code can massively overallocate memory and
is implemented in a way so that access to individual gid is done via 2D
array.
If number of gids is <= 32, memory allocation is more or less tolerable
(140/148 bytes). But if it is not, code allocates full page (!)
regardless and, what's even more fun, doesn't reuse small 32-entry
array.
2D array means dependent shifts, loads and LEAs without possibility to
optimize them (gid is never known at compile time).
All of the above is unnecessary. Switch to the usual
trailing-zero-len-array scheme. Memory is allocated with
kmalloc/vmalloc() and only as much as needed. Accesses become simpler
(LEA 8(gi,idx,4) or even without displacement).
Maximum number of gids is 65536 which translates to 256KB+8 bytes. I
think kernel can handle such allocation.
On my usual desktop system with whole 9 (nine) aux groups, struct
group_info shrinks from 148 bytes to 44 bytes, yay!
Nice side effects:
- "gi->gid[i]" is shorter than "GROUP_AT(gi, i)", less typing,
- fix little mess in net/ipv4/ping.c
should have been using GROUP_AT macro but this point becomes moot,
- aux group allocation is persistent and should be accounted as such.
Link: http://lkml.kernel.org/r/20160817201927.GA2096@p183.telecom.by
Cc: Vasily Kulikov <segoon@openwall.com>
There are a lot of embedded systems that run most or all of their
functionality in init, running as root:root. For these systems,
supporting multiple users is not necessary.
This patch adds a new symbol, CONFIG_MULTIUSER, that makes support for
non-root users, non-root groups, and capabilities optional. It is enabled
under CONFIG_EXPERT menu.
When this symbol is not defined, UID and GID are zero in any possible case
and processes always have all capabilities.
The following syscalls are compiled out: setuid, setregid, setgid,
setreuid, setresuid, getresuid, setresgid, getresgid, setgroups,
getgroups, setfsuid, setfsgid, capget, capset.
Also, groups.c is compiled out completely.
In kernel/capability.c, capable function was moved in order to avoid
adding two ifdef blocks.
This change saves about 25 KB on a defconfig build. The most minimal
kernels have total text sizes in the high hundreds of kB rather than
low MB. (The 25k goes down a bit with allnoconfig, but not that much.
The kernel was booted in Qemu. All the common functionalities work.
Adding users/groups is not possible, failing with -ENOSYS.
Bloat-o-meter output:
add/remove: 7/87 grow/shrink: 19/397 up/down: 1675/-26325 (-24650)
Signed-off-by: Iulia Manda <iulia.manda21@gmail.com>
Reviewed-by: Josh Triplett <josh@joshtriplett.org>
Acked-by: Geert Uytterhoeven <geert@linux-m68k.org>
Tested-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com>
Reviewed-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com>
setgroups is unique in not needing a valid mapping before it can be called,
in the case of setgroups(0, NULL) which drops all supplemental groups.
The design of the user namespace assumes that CAP_SETGID can not actually
be used until a gid mapping is established. Therefore add a helper function
to see if the user namespace gid mapping has been established and call
that function in the setgroups permission check.
This is part of the fix for CVE-2014-8989, being able to drop groups
without privilege using user namespaces.
Cc: stable@vger.kernel.org
Reviewed-by: Andy Lutomirski <luto@amacapital.net>
Today there are 3 instances of setgroups and due to an oversight their
permission checking has diverged. Add a common function so that
they may all share the same permission checking code.
This corrects the current oversight in the current permission checks
and adds a helper to avoid this in the future.
A user namespace security fix will update this new helper, shortly.
After commit 6307f8fee295 ("security: remove dead hook task_setgroups"),
set_groups will always return zero, so we could just remove return value
of set_groups.
This patch reduces code size, and simplfies code to use set_groups,
because we don't need to check its return value any more.
[akpm@linux-foundation.org: remove obsolete claims from set_groups() comment]
Signed-off-by: Wang YanQing <udknight@gmail.com>
Cc: "Eric W. Biederman" <ebiederm@xmission.com>
Cc: Serge Hallyn <serge.hallyn@canonical.com>
Cc: Eric Paris <eparis@redhat.com>
nsown_capable is a special case of ns_capable essentially for just CAP_SETUID and
CAP_SETGID. For the existing users it doesn't noticably simplify things and
from the suggested patches I have seen it encourages people to do the wrong
thing. So remove nsown_capable.
Acked-by: Serge Hallyn <serge.hallyn@canonical.com>
As a first step to converting struct cred to be all kuid_t and kgid_t
values convert the group values stored in group_info to always be
kgid_t values. Unless user namespaces are used this change should
have no effect.
The changed files were only including linux/module.h for the
EXPORT_SYMBOL infrastructure, and nothing else. Revector them
onto the isolated export header for faster compile times.
Nothing to see here but a whole lot of instances of:
-#include <linux/module.h>
+#include <linux/export.h>
This commit is only changing the kernel dir; next targets
will probably be mm, fs, the arch dirs, etc.
CAP_IPC_OWNER and CAP_IPC_LOCK can be checked against current_user_ns(),
because the resource comes from current's own ipc namespace.
setuid/setgid are to uids in own namespace, so again checks can be against
current_user_ns().
Changelog:
Jan 11: Use task_ns_capable() in place of sched_capable().
Jan 11: Use nsown_capable() as suggested by Bastian Blank.
Jan 11: Clarify (hopefully) some logic in futex and sched.c
Feb 15: use ns_capable for ipc, not nsown_capable
Feb 23: let copy_ipcs handle setting ipc_ns->user_ns
Feb 23: pass ns down rather than taking it from current
Signed-off-by: Serge E. Hallyn <serge.hallyn@canonical.com>
Acked-by: "Eric W. Biederman" <ebiederm@xmission.com>
Acked-by: Daniel Lezcano <daniel.lezcano@free.fr>
gid_t is a unsigned int. If group_info contains a gid greater than
MAX_INT, groups_search() function may look on the wrong side of the search
tree.
This solves some unfair "permission denied" problems.
Signed-off-by: Jerome Marchand <jmarchan@redhat.com>
Cc: <stable@kernel.org>
Unused hook. Remove.
Signed-off-by: Eric Paris <eparis@redhat.com>
Signed-off-by: James Morris <jmorris@namei.org>
Move supplementary groups implementation to kernel/groups.c .
kernel/sys.c already accumulated quite a few random stuff.
Do strictly copy/paste + add required headers to compile. Compile-tested
on many configs and archs.
