path: root/kernel/groups.c
2018-01-10kernel: make groups_sort calling a responsibility group_info allocatorsThiago Rafael Becker
commit bdcf0a423ea1c40bbb40e7ee483b50fc8aa3d758 upstream. In testing, we found that nfsd threads may call set_groups in parallel for the same entry cached in auth.unix.gid, racing in the call of groups_sort, corrupting the groups for that entry and leading to permission denials for the client. This patch: - Make groups_sort globally visible. - Move the call to groups_sort to the modifiers of group_info - Remove the call to groups_sort from set_groups Link: http://lkml.kernel.org/r/20171211151420.18655-1-thiago.becker@gmail.com Signed-off-by: Thiago Rafael Becker <thiago.becker@gmail.com> Reviewed-by: Matthew Wilcox <mawilcox@microsoft.com> Reviewed-by: NeilBrown <neilb@suse.com> Acked-by: "J. Bruce Fields" <bfields@fieldses.org> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-04-15kernel: conditionally support non-root users, groups and capabilitiesIulia Manda
There are a lot of embedded systems that run most or all of their functionality in init, running as root:root. For these systems, supporting multiple users is not necessary. This patch adds a new symbol, CONFIG_MULTIUSER, that makes support for non-root users, non-root groups, and capabilities optional. It is enabled under CONFIG_EXPERT menu. When this symbol is not defined, UID and GID are zero in any possible case and processes always have all capabilities. The following syscalls are compiled out: setuid, setregid, setgid, setreuid, setresuid, getresuid, setresgid, getresgid, setgroups, getgroups, setfsuid, setfsgid, capget, capset. Also, groups.c is compiled out completely. In kernel/capability.c, capable function was moved in order to avoid adding two ifdef blocks. This change saves about 25 KB on a defconfig build. The most minimal kernels have total text sizes in the high hundreds of kB rather than low MB. (The 25k goes down a bit with allnoconfig, but not that much. The kernel was booted in Qemu. All the common functionalities work. Adding users/groups is not possible, failing with -ENOSYS. Bloat-o-meter output: add/remove: 7/87 grow/shrink: 19/397 up/down: 1675/-26325 (-24650) [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Iulia Manda <iulia.manda21@gmail.com> Reviewed-by: Josh Triplett <josh@joshtriplett.org> Acked-by: Geert Uytterhoeven <geert@linux-m68k.org> Tested-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Reviewed-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-12-09userns: Don't allow setgroups until a gid mapping has been setablishedEric W. Biederman
setgroups is unique in not needing a valid mapping before it can be called, in the case of setgroups(0, NULL) which drops all supplemental groups. The design of the user namespace assumes that CAP_SETGID can not actually be used until a gid mapping is established. Therefore add a helper function to see if the user namespace gid mapping has been established and call that function in the setgroups permission check. This is part of the fix for CVE-2014-8989, being able to drop groups without privilege using user namespaces. Cc: stable@vger.kernel.org Reviewed-by: Andy Lutomirski <luto@amacapital.net> Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com>
2014-12-05groups: Consolidate the setgroups permission checksEric W. Biederman
Today there are 3 instances of setgroups and due to an oversight their permission checking has diverged. Add a common function so that they may all share the same permission checking code. This corrects the current oversight in the current permission checks and adds a helper to avoid this in the future. A user namespace security fix will update this new helper, shortly. Cc: stable@vger.kernel.org Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com>
2014-04-03kernel/groups.c: remove return value of set_groupsWang YanQing
After commit 6307f8fee295 ("security: remove dead hook task_setgroups"), set_groups will always return zero, so we could just remove return value of set_groups. This patch reduces code size, and simplfies code to use set_groups, because we don't need to check its return value any more. [akpm@linux-foundation.org: remove obsolete claims from set_groups() comment] Signed-off-by: Wang YanQing <udknight@gmail.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Serge Hallyn <serge.hallyn@canonical.com> Cc: Eric Paris <eparis@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-08-30userns: Kill nsown_capable it makes the wrong thing easyEric W. Biederman
nsown_capable is a special case of ns_capable essentially for just CAP_SETUID and CAP_SETGID. For the existing users it doesn't noticably simplify things and from the suggested patches I have seen it encourages people to do the wrong thing. So remove nsown_capable. Acked-by: Serge Hallyn <serge.hallyn@canonical.com> Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com>
2012-05-03userns: Convert in_group_p and in_egroup_p to use kgid_tEric W. Biederman
Acked-by: Serge Hallyn <serge.hallyn@canonical.com> Signed-off-by: Eric W. Biederman <ebiederm@xmission.com>
2012-05-03userns: Convert group_info values from gid_t to kgid_t.Eric W. Biederman
As a first step to converting struct cred to be all kuid_t and kgid_t values convert the group values stored in group_info to always be kgid_t values. Unless user namespaces are used this change should have no effect. Acked-by: Serge Hallyn <serge.hallyn@canonical.com> Signed-off-by: Eric W. Biederman <ebiederm@xmission.com>
2011-10-31kernel: Map most files to use export.h instead of module.hPaul Gortmaker
The changed files were only including linux/module.h for the EXPORT_SYMBOL infrastructure, and nothing else. Revector them onto the isolated export header for faster compile times. Nothing to see here but a whole lot of instances of: -#include <linux/module.h> +#include <linux/export.h> This commit is only changing the kernel dir; next targets will probably be mm, fs, the arch dirs, etc. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2011-03-23userns: user namespaces: convert several capable() callsSerge E. Hallyn
CAP_IPC_OWNER and CAP_IPC_LOCK can be checked against current_user_ns(), because the resource comes from current's own ipc namespace. setuid/setgid are to uids in own namespace, so again checks can be against current_user_ns(). Changelog: Jan 11: Use task_ns_capable() in place of sched_capable(). Jan 11: Use nsown_capable() as suggested by Bastian Blank. Jan 11: Clarify (hopefully) some logic in futex and sched.c Feb 15: use ns_capable for ipc, not nsown_capable Feb 23: let copy_ipcs handle setting ipc_ns->user_ns Feb 23: pass ns down rather than taking it from current [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Serge E. Hallyn <serge.hallyn@canonical.com> Acked-by: "Eric W. Biederman" <ebiederm@xmission.com> Acked-by: Daniel Lezcano <daniel.lezcano@free.fr> Acked-by: David Howells <dhowells@redhat.com> Cc: James Morris <jmorris@namei.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-09-09kernel/groups.c: fix integer overflow in groups_searchJerome Marchand
gid_t is a unsigned int. If group_info contains a gid greater than MAX_INT, groups_search() function may look on the wrong side of the search tree. This solves some unfair "permission denied" problems. Signed-off-by: Jerome Marchand <jmarchan@redhat.com> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-04-12security: remove dead hook task_setgroupsEric Paris
Unused hook. Remove. Signed-off-by: Eric Paris <eparis@redhat.com> Signed-off-by: James Morris <jmorris@namei.org>
2009-06-16groups: move code to kernel/groups.cAlexey Dobriyan
Move supplementary groups implementation to kernel/groups.c . kernel/sys.c already accumulated quite a few random stuff. Do strictly copy/paste + add required headers to compile. Compile-tested on many configs and archs. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
