commit 0c96c5979a522c3323c30a078a70120e29b5bdbc upstream
The scheduler hrtimer bits in 2.6.25 introduced a circular lock
dependency in a rare code path:
[ INFO: possible circular locking dependency detected ]
2.6.25-sched-devel.git-x86-latest.git #19
X/2980 is trying to acquire lock:
(&rq->rq_lock_key#2){++..}, at: [<ffffffff80230146>] task_rq_lock+0x56/0xa0
but task is already holding lock:
(&cpu_base->lock){++..}, at: [<ffffffff80257ae1>] lock_hrtimer_base+0x31/0x60
which lock already depends on the new lock.
The scenario which leads to this is:
posix-timer signal is delivered
-> posix-timer is rearmed
timer is already expired in hrtimer_enqueue()
-> softirq is raised
To prevent this we need to move the raise of the softirq out of the
base->lock protected code path.
Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl>
commit d7b41a24bfb5d7fa02f7b49be1293d468814e424 upstream
When using hrtimer with timer->cb_mode == HRTIMER_CB_SOFTIRQ
in some cases the clockevent is not programmed.
This happens, if:
- a timer is rearmed while it's state is HRTIMER_STATE_CALLBACK
- hrtimer_reprogram() returns -ETIME, when it is called after
CALLBACK is finished. This occurs if the new timer->expires
is in the past when CALLBACK is done.
In this case, the timer needs to be removed from the tree and put
onto the pending list again.
The patch is against 2.6.22.5, but AFAICS, it is relevant
for 2.6.25 also (in run_hrtimer_pending()).
Signed-off-by: Bodo Stroesser <bstroesser@fujitsu-siemens.com>
A CLOCK_REALTIME timer, which has an absolute expiry time less than
the clock realtime offset calls with a negative delta into the clock
events code and triggers the WARN_ON() there.
This is a false positive and needs to be prevented. Check the result
of timer->expires - timer->base->offset right away and return -ETIME
right away.
Thanks to Frans Pop, who reported the problem and tested the fixes.
Tested-by: Frans Pop <elendil@planet.nl>
Various user space callers ask for relative timeouts. While we fixed
that overflow issue in hrtimer_start(), the sites which convert
relative user space values to absolute timeouts themself were uncovered.
Instead of putting overflow checks into each place add a function
which does the sanity checking and convert all affected callers to use
it.
hrtimer_nanosleep_restart() clears/restores restart_block->fn. This is
pointless and complicates its usage. Note that if sys_restart_syscall()
doesn't actually happen, we have a bogus "pending" restart->fn anyway,
this is harmless.
Signed-off-by: Oleg Nesterov <oleg@tv-sign.ru>
Cc: Alexey Dobriyan <adobriyan@sw.ru>
Cc: Pavel Emelyanov <xemul@sw.ru>
Cc: Toyo Abe <toyoa@mvista.com>
Spotted by Pavel Emelyanov and Alexey Dobriyan.
hrtimer_nanosleep() sets restart_block->arg1 = rmtp, but this rmtp points to
the local variable which lives in the caller's stack frame. This means that
if sys_restart_syscall() actually happens and it is interrupted as well, we
don't update the user-space variable, but write into the already dead stack
frame.
Introduced by commit 04c227140fed77587432667a574b14736a06dd7f
hrtimer: Rework hrtimer_nanosleep to make sys_compat_nanosleep easier
Change the callers to pass "__user *rmtp" to hrtimer_nanosleep(), and change
hrtimer_nanosleep() to use copy_to_user() to actually update *rmtp.
Small problem remains. man 2 nanosleep states that *rtmp should be written if
nanosleep() was interrupted (it says nothing whether it is OK to update *rmtp
if nanosleep returns 0), but (with or without this patch) we can dirty *rem
even if nanosleep() returns 0.
NOTE: this patch doesn't change compat_sys_nanosleep(), because it has other
bugs. Fixed by the next patch.
Cc: Michael Kerrisk <mtk.manpages@googlemail.com>
include/linux/hrtimer.h | 2 -
kernel/hrtimer.c | 51 +++++++++++++++++++++++++-----------------------
kernel/posix-timers.c | 14 +------------
3 files changed, 30 insertions(+), 37 deletions(-)
This is the new timerfd API as it is implemented by the following patch:
int timerfd_create(int clockid, int flags);
int timerfd_settime(int ufd, int flags,
const struct itimerspec *utmr,
struct itimerspec *otmr);
int timerfd_gettime(int ufd, struct itimerspec *otmr);
The timerfd_create() API creates an un-programmed timerfd fd. The "clockid"
parameter can be either CLOCK_MONOTONIC or CLOCK_REALTIME.
The timerfd_settime() API give new settings by the timerfd fd, by optionally
retrieving the previous expiration time (in case the "otmr" parameter is not
NULL).
The time value specified in "utmr" is absolute, if the TFD_TIMER_ABSTIME bit
is set in the "flags" parameter. Otherwise it's a relative time.
The timerfd_gettime() API returns the next expiration time of the timer, or
{0, 0} if the timerfd has not been set yet.
Like the previous timerfd API implementation, read(2) and poll(2) are
supported (with the same interface). Here's a simple test program I used to
exercise the new timerfd APIs:
http://www.xmailserver.org/timerfd-test2.c
[akpm@linux-foundation.org: coding-style cleanups]
[akpm@linux-foundation.org: fix ia64 build]
[akpm@linux-foundation.org: fix m68k build]
[akpm@linux-foundation.org: fix mips build]
[akpm@linux-foundation.org: fix alpha, arm, blackfin, cris, m68k, s390, sparc and sparc64 builds]
[heiko.carstens@de.ibm.com: fix s390]
[akpm@linux-foundation.org: fix powerpc build]
[akpm@linux-foundation.org: fix sparc64 more]
Signed-off-by: Davide Libenzi <davidel@xmailserver.org>
Cc: Michael Kerrisk <mtk-manpages@gmx.net>
Cc: Davide Libenzi <davidel@xmailserver.org>
Cc: Michael Kerrisk <mtk.manpages@gmail.com>
this patch:
commit 37bb6cb4097e29ffee970065b74499cbf10603a3
Author: Peter Zijlstra <a.p.zijlstra@chello.nl>
Date: Fri Jan 25 21:08:32 2008 +0100
hrtimer: unlock hrtimer_wakeup
Broke hrtimer_init_sleeper() users. It forgot to fix up the futex
caller of this function to detect the failed queueing and messed up
the do_nanosleep() caller in that it could leak a TASK_INTERRUPTIBLE
state.
hrtimer_wakeup creates a
base->lock
rq->lock
lock dependancy. Avoid this by switching to HRTIMER_CB_IRQSAFE_NO_SOFTIRQ
which doesn't hold base->lock.
This fully untangles hrtimer locks from the scheduler locks, and allows
hrtimer usage in the scheduler proper.
Currently all highres=off timers are run from softirq context, but
HRTIMER_CB_IRQSAFE_NO_SOFTIRQ timers expect to run from irq context.
Fix this up by splitting it similar to the highres=on case.
In order to more easily allow for the scheduler to use timers, clean up
the locking a bit.
Fix section mismatch in hrtimer.c:
WARNING: vmlinux.o(.text+0x50c61): Section mismatch: reference to .init.text: (between 'hrtimer_cpu_notify' and 'down_read_trylock')
Noticed by Johannes Berg and confirmed by Sam Ravnborg.
Signed-off-by: Linus Torvalds <torvalds@akpm@linux-foundation.org>
Relative hrtimers with a large timeout value might end up as negative
timer values, when the current time is added in hrtimer_start().
This in turn is causing the clockevents_set_next() function to set an
huge timeout and sleep for quite a long time when we have a clock
source which is capable of long sleeps like HPET. With PIT this almost
goes unnoticed as the maximum delta is ~27ms. The non-hrt/nohz code
sorts this out in the next timer interrupt, so we never noticed that
problem which has been there since the first day of hrtimers.
This bug became more apparent in 2.6.24 which activates HPET on more
hardware.
Change the hrtimer printk "Switched to high resolution mode .." to
be KERN_DEBUG, rather than KERN_INFO. If users need to see this they
can pass "loglevel" or "debug" on the command line, or check dmesg.
Signed-off-by: Michael Ellerman <michael@ellerman.id.au>
kernel/hrtimer.c | 2 +-
1 file changed, 1 insertion(+), 1 deletion(-)
Signed-off-by: Uwe Kleine-König <ukleinek@informatik.uni-freiburg.de>
Signed-off-by: Adrian Bunk <bunk@kernel.org>
Fix the various misspellings of "system", controller", "interrupt" and
"[un]necessary".
Signed-off-by: Robert P. J. Day <rpjday@mindspring.com>
Pull the copy_to_user out of hrtimer_nanosleep and into the callers
(common_nsleep, sys_nanosleep) in preparation for converting
compat_sys_nanosleep to use hrtimers.
First user will be the DCCP transport networking protocol.
Signed-off-by: Arnaldo Carvalho de Melo <acme@ghostprotocols.net>
This avoids xtime lag seen with dynticks, because while 'xtime' itself
is still not updated often, we keep a 'xtime_cache' variable around that
contains the approximate real-time that _is_ updated each time we do a
'update_wall_time()', and is thus never off by more than one tick.
IOW, this restores the original semantics for 'xtime' users, as long as
you use the proper abstraction functions (ie 'current_kernel_time()' or
'get_seconds()' depending on whether you want a timespec or just the
seconds field).
[ Updated Patch. As penance for my sins I've also yanked another #ifdef
that was added to avoid the xtime lag w/ hrtimers. ]
Signed-off-by: John Stultz <johnstul@us.ibm.com>
This avoids use of the kernel-internal "xtime" variable directly outside
of the actual time-related functions. Instead, use the helper functions
that we already have available to us.
This doesn't actually change any behaviour, but this will allow us to
fix the fact that "xtime" isn't updated very often with CONFIG_NO_HZ
(because much of the realtime information is maintained as separate
offsets to 'xtime'), which has caused interfaces that use xtime directly
to get a time that is out of sync with the real-time clock by up to a
third of a second or so.
Speedup hrtimer_enqueue by evaluating the rbtree insertion result.
Cc: john stultz <johnstul@us.ibm.com>
Add some more debug information to the hrtimer and clock events code.
All of the clockevent notifiers expect a pointer to
an "unsigned int" cpu argument, but hrtimer_cpu_notify()
passes in a pointer to a long.
[ Discussed with and ok by Thomas Gleixner ]
Since nonboot CPUs are now disabled after tasks and devices have been
frozen and the CPU hotplug infrastructure is used for this purpose, we need
special CPU hotplug notifications that will help the CPU-hotplug-aware
subsystems distinguish normal CPU hotplug events from CPU hotplug events
related to a system-wide suspend or resume operation in progress. This
patch introduces such notifications and causes them to be used during
suspend and resume transitions. It also changes all of the
CPU-hotplug-aware subsystems to take these notifications into consideration
(for now they are handled in the same way as the corresponding "normal"
ones).
[oleg@tv-sign.ru: cleanups]
Cc: Gautham R Shenoy <ego@in.ibm.com>
Cc: Pavel Machek <pavel@ucw.cz>
Other symbols of the hrtimers API are already exported.
Signed-off-by: Stas Sergeev <stsp@aknet.ru>
Fix miscellaneous networking compilation errors.
(*) Export ktime_add_ns() for modules.
(*) wext_proc_init() should have an ANSI declaration.
Get rid of the manual clock source selection mess and use ktime. Also
use a scalar representation, which allows to clean up pkt_sched.h a bit
more and results in less ktime_to_ns() calls in most cases.
The PSCHED_US2JIFFIE/PSCHED_JIFFIE2US macros are implemented quite
inefficient by this patch, following patches will convert all qdiscs
to hrtimers and get rid of them entirely.
Soeren Sonnenburg reported that upon resume he is getting
this backtrace:
[<c0119637>] smp_apic_timer_interrupt+0x57/0x90
[<c0142d30>] retrigger_next_event+0x0/0xb0
[<c0104d30>] apic_timer_interrupt+0x28/0x30
[<c0140068>] __kfifo_put+0x8/0x90
[<c0130fe5>] on_each_cpu+0x35/0x60
[<c0143538>] clock_was_set+0x18/0x20
[<c0135cdc>] timekeeping_resume+0x7c/0xa0
[<c02aabe1>] __sysdev_resume+0x11/0x80
[<c02ab0c7>] sysdev_resume+0x47/0x80
[<c02b0b05>] device_power_up+0x5/0x10
it turns out that on resume we mistakenly re-enable interrupts too
early. Do the timer retrigger only on the current CPU.
Acked-by: Soeren Sonnenburg <kernel@nn7.de>
hrtimer_start() incorrectly set the 'reprogram' flag to enqueue_hrtimer(),
which should only be 1 if the hrtimer is queued to the current CPU.
Doing otherwise could result in a reprogramming of the current CPU's
clockevents device, with a timer that is not queued to it - resulting in a
bogus next expiry value.
Cc: Michal Piotrowski <michal.k.k.piotrowski@gmail.com>
commit f4304ab21513b834c8fe3403927c60c2b81a72d7 (HZ free NTP) moved the
access to wall_to_monotonic in hrtimer_get_softirq_time() out of the
xtime_lock protection.
Move it back into the seq_lock section.
Acked-by: John Stultz <johnstul@us.ibm.com>
hrtimer_forward() does not check for the possible overflow of
timer->expires. This can happen on 64 bit machines with large interval
values and results currently in an endless loop in the softirq because the
expiry value becomes negative and therefor the timer is expired all the
time.
Check for this condition and set the expiry value to the max. expiry time
in the future. The fix should be applied to stable kernel series as well.
Cc: <stable@kernel.org>
The TIMER_SOFTIRQ runs the hrtimers during bootup until a usable
clocksource and clock event sources are registered. The switch to high
resolution mode happens inside of the TIMER_SOFTIRQ, but runs the softirq
afterwards. That way the tick emulation timer, which was set up in the
switch to highres might be executed in the softirq context, which is a BUG.
The rbtree has not to be touched by the softirq after the highres switch.
This BUG was observed by Andres Salomon, who provided the information to
debug it.
Return early from the softirq, when the switch was sucessful.
[dilinger@debian.org: add debug warning]
[akpm@linux-foundation.org: make debug warning compile]
Cc: Andres Salomon <dilinger@debian.org>
Signed-off-by: Andres Salomon <dilinger@debian.org>
Doing something like this on a two cpu system
# echo 0 > /sys/devices/system/cpu/cpu0/online
# echo 1 > /sys/devices/system/cpu/cpu0/online
# echo 0 > /sys/devices/system/cpu/cpu1/online
will give me this:
2.6.21-rc2-g562aa1d4-dirty #7
bash/1282 is trying to acquire lock:
(&cpu_base->lock_key){.+..}, at: [<000000000005f17e>] hrtimer_cpu_notify+0xc6/0x240
(&cpu_base->lock_key#2){.+..}, at: [<000000000005f174>] hrtimer_cpu_notify+0xbc/0x240
This happens because we have the following code in kernel/hrtimer.c:
migrate_hrtimers(int cpu)
old_base = &per_cpu(hrtimer_bases, cpu);
new_base = &get_cpu_var(hrtimer_bases);
spin_lock(&new_base->lock);
spin_lock(&old_base->lock);
Which means the spinlocks are taken in an order which depends on which cpu
gets shut down from which other cpu. Therefore lockdep complains that there
might be an ABBA deadlock. Since migrate_hrtimers() gets only called on
cpu hotplug it's safe to assume that it isn't executed concurrently on a
The same problem exists in kernel/timer.c: migrate_timers().
As pointed out by Christian Borntraeger one possible solution to avoid
the locking order complaints would be to make sure that the locks are
always taken in the same order. E.g. by taking the lock of the cpu with
the lower number first.
To achieve this we introduce two new spinlock functions double_spin_lock
and double_spin_unlock which lock or unlock two locks in a given order.
Cc: Roman Zippel <zippel@linux-m68k.org>
Cc: John Stultz <johnstul@us.ibm.com>
Cc: Christian Borntraeger <cborntra@de.ibm.com>
Add /proc/timer_stats support: debugging feature to profile timer expiration.
Both the starting site, process/PID and the expiration function is captured.
This allows the quick identification of timer event sources in a system.
Sample output:
# echo 1 > /proc/timer_stats
# cat /proc/timer_stats
Timer Stats Version: v0.1
Sample period: 4.010 s
24, 0 swapper hrtimer_stop_sched_tick (hrtimer_sched_tick)
11, 0 swapper sk_reset_timer (tcp_delack_timer)
6, 0 swapper hrtimer_stop_sched_tick (hrtimer_sched_tick)
2, 1 swapper queue_delayed_work_on (delayed_work_timer_fn)
17, 0 swapper hrtimer_restart_sched_tick (hrtimer_sched_tick)
4, 2050 pcscd do_nanosleep (hrtimer_wakeup)
5, 4179 sshd sk_reset_timer (tcp_write_timer)
4, 2248 yum-updatesd schedule_timeout (process_timeout)
18, 0 swapper hrtimer_restart_sched_tick (hrtimer_sched_tick)
3, 0 swapper sk_reset_timer (tcp_delack_timer)
1, 1 swapper neigh_table_init_no_netlink (neigh_periodic_timer)
2, 1 swapper e1000_up (e1000_watchdog)
1, 1 init schedule_timeout (process_timeout)
100 total events, 25.24 events/sec
[ cleanups and hrtimers support from Thomas Gleixner <tglx@linutronix.de> ]
[bunk@stusta.de: nr_entries can become static]
Cc: Andi Kleen <ak@suse.de>
Implement high resolution timers on top of the hrtimers infrastructure and the
clockevents / tick-management framework. This provides accurate timers for
all hrtimer subsystem users.
With Ingo Molnar <mingo@elte.hu>
Add functions to provide dynamic ticks and high resolution timers. The code
which keeps track of jiffies and handles the long idle periods is shared
between tick based and high resolution timer based dynticks. The dyntick
functionality can be disabled on the kernel commandline. Provide also the
infrastructure to support high resolution timers.
Architectures register their clock event devices, in the clock events core.
Users of the clockevents core can get clock event devices for their use. The
clockevents core code provides notification mechanisms for various clock
related management events.
This allows to control the clock event devices without the architectures
having to worry about the details of function assignment. This is also a
preliminary for high resolution timers and dynamic ticks to allow the core
code to control the clock functionality without intrusive changes to the
architecture code.
[Fixes-by: Ingo Molnar <mingo@elte.hu>]
Reintroduce ktimers feature "optimized away" by the ktimers review process:
remove the curr_timer pointer from the cpu-base and use the hrtimer state.
No functional changes.
multiple hrtimer states to enable the running of hrtimers without holding the
cpu-base-lock.
(The "optimized" rbtree hack carried only 2 states worth of information and we
need 4 for high resolution timers and dynamic ticks.)
Build-fixes-from: Andrew Morton <akpm@osdl.org>
Improve kernel/hrtimers.c locking: use a per-CPU base with a lock to control
locking of all clocks belonging to a CPU. This simplifies code that needs to
lock all clocks at once. This makes life easier for high-res timers and
dyntick.
[ optimization change from Andrew Morton <akpm@osdl.org> ]
- hrtimers did not use the hrtimer_restart enum and relied on the implict
int representation. Fix the prototypes and the functions using the enums.
- Use seperate name spaces for the enumerations
- Convert hrtimer_restart macro to inline function
- Add comments
[akpm@osdl.org: fix input driver]
Cc: Dmitry Torokhov <dtor@mail.ru>
For CONFIG_NO_HZ we need to calculate the next timer wheel event based on a
given jiffie value. Extend the existing code to allow the extra 'now'
argument. Provide a compability function for the existing implementations to
call the function with now == jiffies. (This also solves the racyness of the
original code vs. jiffies changing during the iteration.)
No functional changes to existing users of this infrastructure.
[ remove WARN_ON() that triggered on s390, by Carsten Otte <cotte@de.ibm.com> ]
[ made new helper static, Adrian Bunk <bunk@stusta.de> ]
Persistent clock support: do proper timekeeping across suspend/resume.
[bunk@stusta.de: cleanup]
Cc: Adrian Bunk <bunk@stusta.de>
Distangle the NTP update from HZ. This is necessary for dynamic tick enabled
kernels.
A variety of (mostly) innocuous fixes to the embedded kernel-doc content in
source files, including:
* make multi-line initial descriptions single line
* denote some function names, constants and structs as such
* change erroneous opening '/*' to '/**' in a few places
* reword some text for clarity
Cc: "Randy.Dunlap" <rdunlap@xenotime.net>
time in compatibility mode
The clock_nanosleep() function does not return the time remaining when the
sleep is interrupted by a signal.
This patch creates a new call out, compat_clock_nanosleep_restart(), which
handles returning the remaining time after a sleep is interrupted. This
patch revives clock_nanosleep_restart(). It is now accessed via the new
call out. The compat_clock_nanosleep_restart() is used for compatibility
access.
Since this is implemented in compatibility mode the normal path is
virtually unaffected - no real performance impact.
Signed-off-by: Toyo Abe <toyoa@mvista.com>
Cc: Roland McGrath <roland@redhat.com>
The percpu variable is used incorrectly in switch_hrtimer_base().
Signed-off-by: Jan Blunck <jblunck@suse.de>
Few of the callback functions and notifier blocks that are associated with cpu
notifications incorrectly have __devinit and __devinitdata. They should be
__cpuinit and __cpuinitdata instead.
It makes no functional difference but wastes text area when CONFIG_HOTPLUG is
enabled and CONFIG_HOTPLUG_CPU is not.
This patch fixes all those instances.
Signed-off-by: Chandra Seetharaman <sekharan@us.ibm.com>
Cc: Ashok Raj <ashok.raj@intel.com>
cleanup: remove task_t and convert all the uses to struct task_struct. I
introduced it for the scheduler anno and it was a mistake.
Conversion was mostly scripted, the result was reviewed and all
secondary whitespace and style impact (if any) was fixed up by hand.
Teach special (recursive) locking code to the lock validator. Has no effect
on non-lockdep kernels.
Signed-off-by: Arjan van de Ven <arjan@linux.intel.com>
