path: root/kernel/irq
2006-01-08[PATCH] kernel/: small cleanupsAdrian Bunk
This patch contains the following cleanups: - make needlessly global functions static - every file should include the headers containing the prototypes for it's global functions Signed-off-by: Adrian Bunk <bunk@stusta.de> Acked-by: "Paul E. McKenney" <paulmck@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-06[PATCH] Alpha: convert to generic irq framework (generic part)Ivan Kokshaysky
Thanks to Christoph for doing most of the work. This allows automatic SMP IRQ affinity assignment other than default "all interrupts on all CPUs" which is rather expensive. This might be useful if the hardware can be programmed to distribute interrupts among different CPUs, like Alpha does. Signed-off-by: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Cc: Christoph Hellwig <hch@lst.de> Cc: Richard Henderson <rth@twiddle.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-23[PATCH] Check the irq number is within boundsMatthew Wilcox
Most of the functions already check. Do the ones that didn't. Signed-off-by: Matthew Wilcox <matthew@wil.cx> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-07[PATCH] more kernel-doc cleanups, additionsRandy Dunlap
Various core kernel-doc cleanups: - add missing function parameters in ipc, irq/manage, kernel/sys, kernel/sysctl, and mm/slab; - move description to just above function for kernel_restart() Signed-off-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-28Don't call a NULL ack function in the generic IRQ code.Paul Mackerras
Some IRQ controllers don't need an ack function (e.g. OpenPIC on PPC platforms) and for them we'd rather not have the overhead of doing an indirect call to a function that does nothing. Signed-off-by: Paul Mackerras <paulus@samba.org>
2005-09-07[PATCH] CHECK_IRQ_PER_CPU() to avoid dead code in __do_IRQ()Karsten Wiese
IRQ_PER_CPU is not used by all architectures. This patch introduces the macros ARCH_HAS_IRQ_PER_CPU and CHECK_IRQ_PER_CPU() to avoid the generation of dead code in __do_IRQ(). ARCH_HAS_IRQ_PER_CPU is defined by architectures using IRQ_PER_CPU in their include/asm_ARCH/irq.h file. Through grepping the tree I found the following architectures currently use IRQ_PER_CPU: cris, ia64, ppc, ppc64 and parisc. Signed-off-by: Karsten Wiese <annabellesgarden@yahoo.de> Acked-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-07[PATCH] x86/x86_64: deferred handling of writes to /proc/irqxx/smp_affinityAshok Raj
When handling writes to /proc/irq, current code is re-programming rte entries directly. This is not recommended and could potentially cause chipset's to lockup, or cause missing interrupts. CONFIG_IRQ_BALANCE does this correctly, where it re-programs only when the interrupt is pending. The same needs to be done for /proc/irq handling as well. Otherwise user space irq balancers are really not doing the right thing. - Changed pending_irq_balance_cpumask to pending_irq_migrate_cpumask for lack of a generic name. - added move_irq out of IRQ_BALANCE, and added this same to X86_64 - Added new proc handler for write, so we can do deferred write at irq handling time. - Display of /proc/irq/XX/smp_affinity used to display CPU_MASKALL, instead it now shows only active cpu masks, or exactly what was set. - Provided a common move_irq implementation, instead of duplicating when using generic irq framework. Tested on i386/x86_64 and ia64 with CONFIG_PCI_MSI turned on and off. Tested UP builds as well. MSI testing: tbd: I have cards, need to look for a x-over cable, although I did test an earlier version of this patch. Will test in a couple days. Signed-off-by: Ashok Raj <ashok.raj@intel.com> Acked-by: Zwane Mwaikambo <zwane@holomorphy.com> Grudgingly-acked-by: Andi Kleen <ak@muc.de> Signed-off-by: Coywolf Qi Hunt <coywolf@lovecn.org> Signed-off-by: Ashok Raj <ashok.raj@intel.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-28[PATCH] irqpollAlan Cox
Anyone reporting a stuck IRQ should try these options. Its effectiveness varies we've found in the Fedora case. Quite a few systems with misdescribed IRQ routing just work when you use irqpoll. It also fixes up the VIA systems although thats now fixed with the VIA quirk (which we could just make default as its what Redmond OS does but Linus didn't like it historically). A small number of systems have jammed IRQ sources or misdescribes that cause an IRQ that we have no handler registered anywhere for. In those cases it doesn't help. Signed-off-by: Alan Cox <number6@the-village.bc.nu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-28[PATCH] Using msleep() instead of HZLuca Falavigna
Use msleep() in a few places. Signed-off-by: Luca Falavigna <dktrkranz@gmail.com> Acked-by: Ingo Molnar <mingo@elte.hu> Acked-by: Jeff Garzik <jgarzik@pobox.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-24[PATCH] make various thing staticAdrian Bunk
Another rollup of patches which give various symbols static scope Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-21[PATCH] uml: make hw_controller_type->release exist only for archs needing itPaolo 'Blaisorblade' Giarrusso
With Chris Wedgwood <cw@f00f.org> As suggested by Chris, we can make the "just added" method ->release conditional to UML only (better: to archs requesting it, i.e. only UML currently), so that other archs don't get this unneeded crud, and if UML won't need it any more we can kill this. Signed-off-by: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> CC: Ingo Molnar <mingo@redhat.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-21[PATCH] uml: add and use generic hw_controller_type->releasePaolo 'Blaisorblade' Giarrusso
With Chris Wedgwood <cw@f00f.org> Currently UML must explicitly call the UML-specific free_irq_by_irq_and_dev() for each free_irq call it's done. This is needed because ->shutdown and/or ->disable are only called when the last "action" for that irq is removed. Instead, for UML shared IRQs (UML IRQs are very often, if not always, shared), for each dev_id some setup is done, which must be cleared on the release of that fd. For instance, for each open console a new instance (i.e. new dev_id) of the same IRQ is requested(). Exactly, a fd is stored in an array (pollfds), which is after read by a host thread and passed to poll(). Each event registered by poll() triggers an interrupt. So, for each free_irq() we must remove the corresponding host fd from the table, which we do via this -release() method. In this patch we add an appropriate hook for this, and remove all uses of it by pointing the hook to the said procedure; this is safe to do since the said procedure. Also some cosmetic improvements are included. This is heavily based on some work by Chris Wedgwood, which however didn't get the patch merged for something I'd call a "misunderstanding" (the need for this patch wasn't cleanly explained, thus adding the generic hook was felt as undesirable). Signed-off-by: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> CC: Ingo Molnar <mingo@redhat.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-05-28[PATCH] drop note_interrupt() for per-CPU for proper scalingJohn Hawkes
The "unhandled interrupts" catcher, note_interrupt(), increments a global desc->irq_count and grossly damages scaling of very large systems, e.g., >192p ia64 Altix, because of this highly contented cacheline, especially for timer interrupts. 384p is severely crippled, and 512p is unuseable. All calls to note_interrupt() can be disabled by booting with "noirqdebug", but this disables the useful interrupt checking for all interrupts. I propose eliminating note_interrupt() for all per-CPU interrupts. This was the behavior of linux-2.6.10 and earlier, but in 2.6.11 a code restructuring added a call to note_interrupt() for per-CPU interrupts. Besides, note_interrupt() is a bit racy for concurrent CPU calls anyway, as the desc->irq_count++ increment isn't atomic (which, if done, would make scaling even worse). Signed-off-by: John Hawkes <hawkes@sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-05-17[PATCH] spurious interrupt fixZhang, Yanmin
On my IA64 machine, after kernel 2.6.12-rc3 boots, an edge-triggered interrupt (IRQ 46) keeps triggered over and over again. There is no IRQ 46 interrupt action handler. It has lots of impact on performance. Kernel 2.6.10 and its prior versions have no the problem. Basically, kernel 2.6.10 will mask the spurious edge interrupt if the interrupt is triggered for the second time and its status includes IRQ_DISABLE|IRQ_PENDING. Originally, IA64 kernel has its own specific _irq_desc definitions in file arch/ia64/kernel/irq.c. The definition initiates _irq_desc[irq].status to IRQ_DISABLE. Since kernel 2.6.11, it was moved to architecture independent codes, i.e. kernel/irq/handle.c, but kernel/irq/handle.c initiates _irq_desc[irq].status to 0 instead of IRQ_DISABLE. Signed-off-by: Zhang Yanmin <yanmin.zhang@intel.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
