path: root/kernel/irq
2012-01-13module_param: make bool parameters really bool (core code)Rusty Russell
module_param(bool) used to counter-intuitively take an int. In fddd5201 (mid-2009) we allowed bool or int/unsigned int using a messy trick. It's time to remove the int/unsigned int option. For this version it'll simply give a warning, but it'll break next kernel version. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2012-01-08Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (53 commits) Kconfig: acpi: Fix typo in comment. misc latin1 to utf8 conversions devres: Fix a typo in devm_kfree comment btrfs: free-space-cache.c: remove extra semicolon. fat: Spelling s/obsolate/obsolete/g SCSI, pmcraid: Fix spelling error in a pmcraid_err() call tools/power turbostat: update fields in manpage mac80211: drop spelling fix types.h: fix comment spelling for 'architectures' typo fixes: aera -> area, exntension -> extension devices.txt: Fix typo of 'VMware'. sis900: Fix enum typo 'sis900_rx_bufer_status' decompress_bunzip2: remove invalid vi modeline treewide: Fix comment and string typo 'bufer' hyper-v: Update MAINTAINERS treewide: Fix typos in various parts of the kernel, and fix some comments. clockevents: drop unknown Kconfig symbol GENERIC_CLOCKEVENTS_MIGR gpio: Kconfig: drop unknown symbol 'CS5535_GPIO' leds: Kconfig: Fix typo 'D2NET_V2' sound: Kconfig: drop unknown symbol ARCH_CLPS7500 ... Fix up trivial conflicts in arch/powerpc/platforms/40x/Kconfig (some new kconfig additions, close to removed commented-out old ones)
2012-01-07Merge tag 'devicetree-for-linus' of git://git.secretlab.ca/git/linux-2.6Linus Torvalds
devicetree/next changes queued for v3.3 merge window * tag 'devicetree-for-linus-20120104' of git://git.secretlab.ca/git/linux-2.6: ARM: prom.h: Fix build error by removing unneeded header file irq: check domain hwirq range for DT translate dt: add empty of_get_node/of_put_node functions of/pdt: fix section mismatch warning i2c-designware: add OF binding support dt/i2c: Enumerate some of the known trivial i2c devices dt: reform for_each_property to for_each_property_of_node ARM/of: allow *machine_desc.dt_compat to be const of/base: Take NULL string into account for property with multiple strings OF/device-tree: Add some entries to vendor-prefixes.txt Fix up trivial add-add conflicts in include/linux/of.h
2012-01-05Merge branch 'devel-stable' into for-linusRussell King
Conflicts: arch/arm/kernel/setup.c arch/arm/mach-shmobile/board-kota2.c
2011-12-28irq: check domain hwirq range for DT translateRob Herring
A DT node may have more than 1 domain associated with it, so make sure the hwirq number is within range when doing DT translation. Signed-off-by: Rob Herring <rob.herring@calxeda.com> Acked-by: Grant Likely <grant.likely@secretlab.ca> Acked-by: Shawn Guo <shawn.guo@linaro.org> Cc: Thomas Gleixner <tglx@linutronix.de>
2011-12-23ARM: 7235/1: irqdomain: export irq_domain_simple_ops for !CONFIG_OFJamie Iles
irqdomain support is used in interrupt controller drivers that may not have device tree support but only need the basic HW->Linux irq translation. Rather than having each of these implement their own IRQ domain, allow them to use the simple ops. Acked-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: Rob Herring <robherring2@gmail.com> Cc: Grant Likely <grant.likely@secretlab.ca> Signed-off-by: Jamie Iles <jamie@jamieiles.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-12-02genirq: Fix race condition when stopping the irq threadIdo Yariv
In irq_wait_for_interrupt(), the should_stop member is verified before setting the task's state to TASK_INTERRUPTIBLE and calling schedule(). In case kthread_stop sets should_stop and wakes up the process after should_stop is checked by the irq thread but before the task's state is changed, the irq thread might never exit: kthread_stop irq_wait_for_interrupt ------------ ---------------------- ... ... while (!kthread_should_stop()) { kthread->should_stop = 1; wake_up_process(k); wait_for_completion(&kthread->exited); ... set_current_state(TASK_INTERRUPTIBLE); ... schedule(); } Fix this by checking if the thread should stop after modifying the task's state. [ tglx: Simplified it a bit ] Signed-off-by: Ido Yariv <ido@wizery.com> Link: http://lkml.kernel.org/r/1322740508-22640-1-git-send-email-ido@wizery.com Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: stable@kernel.org
2011-11-28Merge branch 'irq-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip * 'irq-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: genirq: Don't allow per cpu interrupts to be suspended
2011-11-28genirq: fix regression in irqfixup, irqpollEdward Donovan
Commit fa27271bc8d2("genirq: Fixup poll handling") introduced a regression that broke irqfixup/irqpoll for some hardware configurations. Amidst reorganizing 'try_one_irq', that patch removed a test that checked for 'action->handler' returning IRQ_HANDLED, before acting on the interrupt. Restoring this test back returns the functionality lost since 2.6.39. In the current set of tests, after 'action' is set, it must precede '!action->next' to take effect. With this and my previous patch to irq/spurious.c, c75d720fca8a, all IRQ regressions that I have encountered are fixed. Signed-off-by: Edward Donovan <edward.donovan@numble.net> Reported-and-tested-by: Rogério Brito <rbrito@ime.usp.br> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: stable@kernel.org (2.6.39+) Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-11-17genirq: Don't allow per cpu interrupts to be suspendedMarc Zyngier
The power management functions related to interrupts do not know (yet) about per-cpu interrupts and end up calling the wrong low-level methods to enable/disable interrupts. This leads to all kind of interesting issues (action taken on one CPU only, updating a refcount which is not used otherwise...). The workaround for the time being is simply to flag these interrupts with IRQF_NO_SUSPEND. At least on ARM, these interrupts are actually dealt with at the architecture level. Reported-by: Santosh Shilimkar <santosh.shilimkar@ti.com> Tested-by: Santosh Shilimkar <santosh.shilimkar@ti.com> Signed-off-by: Marc Zyngier <marc.zyngier@arm.com> Cc: linux-arm-kernel@lists.infradead.org Link: http://lkml.kernel.org/r/1321446459-31409-1-git-send-email-marc.zyngier@arm.com Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2011-11-17Merge branch 'irq-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip * 'irq-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: genirq: Fix irqfixup, irqpoll regression
2011-11-13Merge branch 'master' into for-nextJiri Kosina
Sync with Linus tree to have 157550ff ("mtd: add GPMI-NAND driver in the config and Makefile") as I have patch depending on that one.
2011-11-06Merge branch 'modsplit-Oct31_2011' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/paulg/linux * 'modsplit-Oct31_2011' of git://git.kernel.org/pub/scm/linux/kernel/git/paulg/linux: (230 commits) Revert "tracing: Include module.h in define_trace.h" irq: don't put module.h into irq.h for tracking irqgen modules. bluetooth: macroize two small inlines to avoid module.h ip_vs.h: fix implicit use of module_get/module_put from module.h nf_conntrack.h: fix up fallout from implicit moduleparam.h presence include: replace linux/module.h with "struct module" wherever possible include: convert various register fcns to macros to avoid include chaining crypto.h: remove unused crypto_tfm_alg_modname() inline uwb.h: fix implicit use of asm/page.h for PAGE_SIZE pm_runtime.h: explicitly requires notifier.h linux/dmaengine.h: fix implicit use of bitmap.h and asm/page.h miscdevice.h: fix up implicit use of lists and types stop_machine.h: fix implicit use of smp.h for smp_processor_id of: fix implicit use of errno.h in include/linux/of.h of_platform.h: delete needless include <linux/module.h> acpi: remove module.h include from platform/aclinux.h miscdevice.h: delete unnecessary inclusion of module.h device_cgroup.h: delete needless include <linux/module.h> net: sch_generic remove redundant use of <linux/module.h> net: inet_timewait_sock doesnt need <linux/module.h> ... Fix up trivial conflicts (other header files, and removal of the ab3550 mfd driver) in - drivers/media/dvb/frontends/dibx000_common.c - drivers/media/video/{mt9m111.c,ov6650.c} - drivers/mfd/ab3550-core.c - include/linux/dmaengine.h
2011-11-03genirq: Fix irqfixup, irqpoll regressionEdward Donovan
commit d05c65fff0 ("genirq: spurious: Run only one poller at a time") introduced a regression, leaving the boot options 'irqfixup' and 'irqpoll' non-functional. The patch placed tests in each function, to exit if the function is already running. The test in 'misrouted_irq' exited when it should have proceeded, effectively disabling 'misrouted_irq' and 'poll_spurious_irqs'. The check for an already running poller needs to be "!= 1" not "== 1" as "1" is the value when the first poller starts running. Signed-off-by: Edward Donovan <edward.donovan@numble.net> Cc: maciej.rutecki@gmail.com Link: http://lkml.kernel.org/r/1320175784-6745-1-git-send-email-edward.donovan@numble.net Cc: stable@vger.kernel.org # >= 2.6.39 Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2011-11-01Merge branch 'next/dt' of git://git.linaro.org/people/arnd/arm-socLinus Torvalds
* 'next/dt' of git://git.linaro.org/people/arnd/arm-soc: ARM: gic: use module.h instead of export.h ARM: gic: fix irq_alloc_descs handling for sparse irq ARM: gic: add OF based initialization ARM: gic: add irq_domain support irq: support domains with non-zero hwirq base of/irq: introduce of_irq_init ARM: at91: add at91sam9g20 and Calao USB A9G20 DT support ARM: at91: dt: at91sam9g45 family and board device tree files arm/mx5: add device tree support for imx51 babbage arm/mx5: add device tree support for imx53 boards ARM: msm: Add devicetree support for msm8660-surf msm_serial: Add devicetree support msm_serial: Use relative resources for iomem Fix up conflicts in arch/arm/mach-at91/{at91sam9260.c,at91sam9g45.c}
2011-10-31irq: don't put module.h into irq.h for tracking irqgen modules.Paul Gortmaker
Recent commit "irq: Track the owner of irq descriptor" in commit ID b6873807a7143b7 placed module.h into linux/irq.h but we are trying to limit module.h inclusion to just C files that really need it, due to its size and number of children includes. This targets just reversing that include. Add in the basic "struct module" since that is all we really need to ensure things compile. In theory, b687380 should have added the module.h include to the irqdesc.h header as well, but the implicit module.h everywhere presence masked this from showing up. So give it the "struct module" as well. As for the C files, irqdesc.c is only using THIS_MODULE, so it does not need module.h - give it export.h instead. The C file irq/manage.c is now (as of b687380) using try_module_get and module_put and so it needs module.h (which it already has). Also convert the irq_alloc_descs variants to macros, since all they really do is is call the __irq_alloc_descs primitive. This avoids including export.h and no debug info is lost. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2011-10-31kernel: Fix files explicitly needing EXPORT_SYMBOL infrastructurePaul Gortmaker
These files were getting <linux/module.h> via an implicit non-obvious path, but we want to crush those out of existence since they cost time during compiles of processing thousands of lines of headers for no reason. Give them the lightweight header that just contains the EXPORT_SYMBOL infrastructure. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2011-10-31irq: support domains with non-zero hwirq baseRob Herring
Interrupt controllers can have non-zero starting value for h/w irq numbers. Adding support in irq_domain allows the domain hwirq numbering to match the interrupt controllers' numbering. As this makes looping over irqs for a domain more complicated, add loop iterators to iterate over all hwirqs and irqs for a domain. Signed-off-by: Rob Herring <rob.herring@calxeda.com> Reviewed-by: Jamie Iles <jamie@jamieiles.com> Tested-by: Thomas Abraham <thomas.abraham@linaro.org> Acked-by: Grant Likely <grant.likely@secretlab.ca> Acked-by: Thomas Gleixner <tglx@linutronix.de>
2011-10-29irq: Fix comment typo ist->isJavi Merino
Signed-off-by: Javi Merino <javi.merino@arm.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2011-10-29Merge branch 'gpio/next' of git://git.secretlab.ca/git/linux-2.6Linus Torvalds
* 'gpio/next' of git://git.secretlab.ca/git/linux-2.6: h8300: Move gpio.h to gpio-internal.h gpio: pl061: add DT binding support gpio: fix build error in include/asm-generic/gpio.h gpiolib: Ensure struct gpio is always defined irq: Add EXPORT_SYMBOL_GPL to function of irq generic-chip gpio-ml-ioh: Use NUMA_NO_NODE not GFP_KERNEL gpio-pch: Use NUMA_NO_NODE not GFP_KERNEL gpio: langwell: ensure alternate function is cleared gpio-pch: Support interrupt function gpio-pch: Save register value in suspend() gpio-pch: modify gpio_nums and mask gpio-pch: support ML7223 IOH n-Bus gpio-pch: add spinlock in suspend/resume processing gpio-pch: Delete invalid "restore" code in suspend() gpio-ml-ioh: Fix suspend/resume issue gpio-ml-ioh: Support interrupt function gpio-ml-ioh: Delete unnecessary code gpio/mxc: add chained_irq_enter/exit() to mx3_gpio_irq_handler() gpio/nomadik: use genirq core to track enablement gpio/nomadik: disable clocks when unused
2011-10-26Merge branch 'irq-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip * 'irq-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: genirq: Add IRQF_RESUME_EARLY and resume such IRQs earlier genirq: Fix fatfinered fixup really genirq: percpu: allow interrupt type to be set at enable time genirq: Add support for per-cpu dev_id interrupts genirq: Add IRQCHIP_SKIP_SET_WAKE flag
2011-10-24Merge remote-tracking branch 'rmk/devel-stable' into HEADRob Herring
2011-10-24irq: Add EXPORT_SYMBOL_GPL to function of irq generic-chipNobuhiro Iwamatsu
Some functions of irq generic-chip is undefined, because EXPORT_SYMBOL_GPL is not set to these. ERROR: "irq_setup_generic_chip" [drivers/gpio/gpio-pch.ko] undefined! ERROR: "irq_alloc_generic_chip" [drivers/gpio/gpio-pch.ko] undefined! ERROR: "irq_setup_generic_chip" [drivers/gpio/gpio-ml-ioh.ko] undefined! ERROR: "irq_alloc_generic_chip" [drivers/gpio/gpio-ml-ioh.ko] undefined! This is revised that EXPORT_SYMBOL_GPL can be added and referred to in functions. Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com> Acked-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2011-10-17genirq: Add IRQF_RESUME_EARLY and resume such IRQs earlierIan Campbell
This adds a mechanism to resume selected IRQs during syscore_resume instead of dpm_resume_noirq. Under Xen we need to resume IRQs associated with IPIs early enough that the resched IPI is unmasked and we can therefore schedule ourselves out of the stop_machine where the suspend/resume takes place. This issue was introduced by 676dc3cf5bc3 "xen: Use IRQF_FORCE_RESUME". Signed-off-by: Ian Campbell <ian.campbell@citrix.com> Cc: Rafael J. Wysocki <rjw@sisk.pl> Cc: Jeremy Fitzhardinge <Jeremy.Fitzhardinge@citrix.com> Cc: xen-devel <xen-devel@lists.xensource.com> Cc: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Link: http://lkml.kernel.org/r/1318713254.11016.52.camel@dagon.hellion.org.uk Cc: stable@kernel.org (at least to 2.6.32.y) Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2011-10-04genirq: Fix fatfinered fixup reallyThomas Gleixner
Putting the argument inside the quote does not really help. Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2011-10-03genirq: percpu: allow interrupt type to be set at enable timeMarc Zyngier
As request_percpu_irq() doesn't allow for a percpu interrupt to have its type configured (it is generally impossible to configure it on all CPUs at once), add a 'type' argument to enable_percpu_irq(). This allows some low-level, board specific init code to be switched to a generic API. [ tglx: Added WARN_ON argument ] Signed-off-by: Marc Zyngier <marc.zyngier@arm.com> Cc: Abhijeet Dharmapurikar <adharmap@codeaurora.org> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2011-10-03genirq: Add support for per-cpu dev_id interruptsMarc Zyngier
The ARM GIC interrupt controller offers per CPU interrupts (PPIs), which are usually used to connect local timers to each core. Each CPU has its own private interface to the GIC, and only sees the PPIs that are directly connect to it. While these timers are separate devices and have a separate interrupt line to a core, they all use the same IRQ number. For these devices, request_irq() is not the right API as it assumes that an IRQ number is visible by a number of CPUs (through the affinity setting), but makes it very awkward to express that an IRQ number can be handled by all CPUs, and yet be a different interrupt line on each CPU, requiring a different dev_id cookie to be passed back to the handler. The *_percpu_irq() functions is designed to overcome these limitations, by providing a per-cpu dev_id vector: int request_percpu_irq(unsigned int irq, irq_handler_t handler, const char *devname, void __percpu *percpu_dev_id); void free_percpu_irq(unsigned int, void __percpu *); int setup_percpu_irq(unsigned int irq, struct irqaction *new); void remove_percpu_irq(unsigned int irq, struct irqaction *act); void enable_percpu_irq(unsigned int irq); void disable_percpu_irq(unsigned int irq); The API has a number of limitations: - no interrupt sharing - no threading - common handler across all the CPUs Once the interrupt is requested using setup_percpu_irq() or request_percpu_irq(), it must be enabled by each core that wishes its local interrupt to be delivered. Based on an initial patch by Thomas Gleixner. Signed-off-by: Marc Zyngier <marc.zyngier@arm.com> Cc: linux-arm-kernel@lists.infradead.org Link: http://lkml.kernel.org/r/1316793788-14500-2-git-send-email-marc.zyngier@arm.com Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2011-09-20irq: Fix check for already initialized irq_domain in irq_domain_addRob Herring
The sanity check in irq_domain_add() tests desc->irq_data != NULL or irq_data->domain != NULL. This prevents adding an irq_domain to a irq descriptor when irq_data exists, which true when the irq descriptor exists. This went unnoticed so far as the simple domain code did not enter this code path because domain->nr_irqs is always 0 for the simple domains. Split the check for irq_data == NULL out and have a separate warning for it. [ tglx: Made the check for irq_data == NULL separate ] Signed-off-by: Rob Herring <rob.herring@calxeda.com> Cc: Grant Likely <grant.likely@secretlab.ca> Cc: marc.zyngier@arm.com Cc: thomas.abraham@linaro.org Cc: jamie@jamieiles.com Cc: b-cousson@ti.com Cc: shawn.guo@linaro.org Cc: linux-arm-kernel@lists.infradead.org Cc: devicetree-discuss@lists.ozlabs.org Link: http://lkml.kernel.org/r/1316017900-19918-3-git-send-email-robherring2@gmail.com Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2011-09-12genirq: Add IRQCHIP_SKIP_SET_WAKE flagSantosh Shilimkar
Some irq chips need the irq_set_wake() functionality, but do not require a irq_set_wake() callback. Instead of forcing an empty callback to be implemented add a flag which notes this fact. Check for the flag in set_irq_wake_real() and return success when set. Signed-off-by: Santosh Shilimkar <santosh.shilimkar@ti.com> Cc: Thomas Gleixner <tglx@linutronix.de>
2011-09-12genirq: Make irq_shutdown() symmetric vs. irq_startup againGeert Uytterhoeven
If an irq_chip provides .irq_shutdown(), but neither of .irq_disable() or .irq_mask(), free_irq() crashes when jumping to NULL. Fix this by only trying .irq_disable() and .irq_mask() if there's no .irq_shutdown() provided. This revives the symmetry with irq_startup(), which tries .irq_startup(), .irq_enable(), and irq_unmask(), and makes it consistent with the comment for irq_chip.irq_shutdown() in <linux/irq.h>, which says: * @irq_shutdown: shut down the interrupt (defaults to ->disable if NULL) This is also how __free_irq() behaved before the big overhaul, cfr. e.g. 3b56f0585fd4c02d047dc406668cb40159b2d340 ("genirq: Remove bogus conditional"), where the core interrupt code always overrode .irq_shutdown() to .irq_disable() if .irq_shutdown() was NULL. Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Cc: linux-m68k@lists.linux-m68k.org Link: http://lkml.kernel.org/r/1315742394-16036-2-git-send-email-geert@linux-m68k.org Cc: stable@kernel.org Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2011-08-23Revert "irq: Always set IRQF_ONESHOT if no primary handler is specified"Linus Torvalds
This reverts commit f3637a5f2e2eb391ff5757bc83fb5de8f9726464. It turns out that this breaks several drivers, one example being OMAP boards which use the on-board OMAP UARTs and the omap-serial driver that will not boot to userspace after the commit. Paul Walmsley reports that enabling CONFIG_DEBUG_SHIRQ reveals 'IRQ handler type mismatch' errors: IRQ handler type mismatch for IRQ 74 current handler: serial idle ... and the reason is that setting IRQF_ONESHOT will now result in those interrupt handlers having different IRQF flags, and thus being unsharable. So the commit log in the reverted commit: "Since it is required for those users and there is no difference for others it makes sense to add this flag unconditionally." is simply not true: there may not be any difference from a "actions at irq time", but there is a *big* difference wrt this flag testing irq management (see __setup_irq() in kernel/irq/manage.c). One solution may be to stop verifying IRQF_ONESHOT in __setup_irq(), but right now the safe course of action is to revert the change. Let's revisit this in a later merge window. Reported-by: Paul Walmsley <paul@pwsan.com> Cc: Sebastian Andrzej Siewior <bigeasy@linutronix.de> Requested-by: Alan Cox <alan@lxorguk.ukuu.org.uk> Acked-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-08-18irqdesc: fix new kernel-doc warningRandy Dunlap
Fix kernel-doc warning in irqdesc.c: Warning(kernel/irq/irqdesc.c:353): No description found for parameter 'owner' Signed-off-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-08-17Merge branch 'irq-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'irq-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: irq: Track the owner of irq descriptor irq: Always set IRQF_ONESHOT if no primary handler is specified genirq: Fix wrong bit operation
2011-07-28Merge branch 'imx/dt' into next/dtArnd Bergmann
2011-07-28irq: Track the owner of irq descriptorSebastian Andrzej Siewior
Interrupt descriptors can be allocated from modules. The interrupts are used by other modules, but we have no refcount on the module which provides the interrupts and there is no way to establish one on the device level as the interrupt using module is agnostic to the fact that the interrupt is provided by a module rather than by some builtin interrupt controller. To prevent removal of the interrupt providing module, we can track the owner of the interrupt descriptor, which also provides the relevant irq chip functions in the irq descriptor. request/setup_irq() can now acquire a refcount on the owner module to prevent unloading. free_irq() drops the refcount. Signed-off-by: Sebastian Andrzej Siewior <sebastian@breakpoint.cc> Link: http://lkml.kernel.org/r/20110711101731.GA13804@Chamillionaire.breakpoint.cc Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2011-07-28irq: Always set IRQF_ONESHOT if no primary handler is specifiedSebastian Andrzej Siewior
If no primary handler is specified then a default one is assigned which always returns IRQ_WAKE_THREAD. This handler requires the IRQF_ONESHOT flag on LEVEL / EIO typed irqs because the source of interrupt is not disabled. Since it is required for those users and there is no difference for others it makes sense to add this flag unconditionally. Signed-off-by: Sebastian Andrzej Siewior <bigeasy@linutronix.de> Link: http://lkml.kernel.org/r/1310070737-18514-1-git-send-email-bigeasy@linutronix.de Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2011-07-28dt/irq: add irq_domain_generate_simple() helperGrant Likely
irq_domain_generate_simple() is an easy way to generate an irq translation domain for simple irq controllers. It assumes a flat 1:1 mapping from hardware irq number to an offset of the first linux irq number assigned to the controller Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2011-07-28irq: add irq_domain translation infrastructureGrant Likely
This patch adds irq_domain infrastructure for translating from hardware irq numbers to linux irqs. This is particularly important for architectures adding device tree support because the current implementation (excluding PowerPC and SPARC) cannot handle translation for more than a single interrupt controller. irq_domain supports device tree translation for any number of interrupt controllers. This patch converts x86, Microblaze, ARM and MIPS to use irq_domain for device tree irq translation. x86 is untested beyond compiling it, irq_domain is enabled for MIPS and Microblaze, but the old behaviour is preserved until the core code is modified to actually register an irq_domain yet. On ARM it works and is required for much of the new ARM device tree board support. PowerPC has /not/ been converted to use this new infrastructure. It is still missing some features before it can replace the virq infrastructure already in powerpc (see documentation on irq_domain_map/unmap for details). Followup patches will add the missing pieces and migrate PowerPC to use irq_domain. SPARC has its own method of managing interrupts from the device tree and is unaffected by this change. Acked-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2011-07-26genirq: Fix wrong bit operationjhbird.choi@samsung.com
(!msk & 0x01) should be !(msk & 0x01) Signed-off-by: Jonghwan Choi <jhbird.choi@samsung.com> Link: http://lkml.kernel.org/r/1311229754-6003-1-git-send-email-jhbird.choi@samsung.com Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: stable@kernel.org
2011-07-25devres: fix possible use after freeMaxin B John
devres uses the pointer value as key after it's freed, which is safe but triggers spurious use-after-free warnings on some static analysis tools. Rearrange code to avoid such warnings. Signed-off-by: Maxin B. John <maxin.john@gmail.com> Reviewed-by: Rolf Eike Beer <eike-kernel@sf-tec.de> Acked-by: Tejun Heo <tj@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-07genirq: replace irq_gc_ack() with {set,clr}_bit variants (fwd)Simon Guinot
This fixes a regression introduced by e59347a "arm: orion: Use generic irq chip". Depending on the device, interrupts acknowledgement is done by setting or by clearing a dedicated register. Replace irq_gc_ack() with some {set,clr}_bit variants allows to handle both cases. Note that this patch affects the following SoCs: Davinci, Samsung and Orion. Except for this last, the change is minor: irq_gc_ack() is just renamed into irq_gc_ack_set_bit(). For the Orion SoCs, the edge GPIO interrupts support is currently broken. irq_gc_ack() try to acknowledge a such interrupt by setting the corresponding cause register bit. The Orion GPIO device expect the opposite. To fix this issue, the irq_gc_ack_clr_bit() variant is used. Tested on Network Space v2. Reported-by: Joey Oravec <joravec@drewtech.com> Signed-off-by: Simon Guinot <sguinot@lacie.com> Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2011-06-10genirq: Prevent potential NULL dereference in irq_set_irq_wake()Jesper Juhl
In kernel/irq/manage.c::irq_set_irq_wake() we call irq_get_desc_buslock() which may return NULL, but the code dereferences the result unconditionally. irq_set_irq_wake() has lots of callers - I checked a few and I couldn't find anything that guarantees that they won't call it with some input that will cause irq_get_desc_buslock() to return NULL, so I think it's a good thing to test and -EINVAL was the most sane error code in this situation that I could think of. Not all callers test the return value of irq_set_irq_wake(), but those that do take != 0 to mean error as far as I can see, so they should be fine. I guess those that don't test actually should, but that's a different issue. Signed-off-by: Jesper Juhl <jj@chaosbits.net> Link: http://lkml.kernel.org/r/alpine.LNX.2.00.1106092300360.17868@swampdragon.chaosbits.net Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2011-06-03genirq: Ensure we locate the passed IRQ in irq_alloc_descs()Mark Brown
When irq_alloc_descs() is called with no base IRQ specified then it will search for a range of IRQs starting from a specified base address. In the case where an IRQ is specified it still does this search in order to ensure that none of the requested range is already allocated and it still uses the from parameter to specify the base for the search. This means that in the case where a base is specified but from is zero (which is reasonable as any IRQ number is in the range specified by a zero from) the function will get confused and try to allocate the first suitably sized block of free IRQs it finds. Instead use a specified IRQ as the base address for the search, and insist that any from that is specified can support that IRQ. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Link: http://lkml.kernel.org/r/1307037313-15733-1-git-send-email-broonie@opensource.wolfsonmicro.com Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2011-06-03genirq: Fix descriptor init on non-sparse IRQsLinus Walleij
The genirq changes are initializing descriptors for sparse IRQs quite differently from how non-sparse (stacked?) IRQs are initialized, with the effect that on my platform all IRQs are default-disabled on sparse IRQs and default-enabled if non-sparse IRQs are used, crashing some GPIO driver. Fix this by refactoring the non-sparse IRQs to use the same descriptor init function as the sparse IRQs. Signed-off: Linus Walleij <linus.walleij@linaro.org> Link: http://lkml.kernel.org/r/1306858479-16622-1-git-send-email-linus.walleij@stericsson.com Cc: stable@kernel.org # 2.6.39 Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2011-06-03irq: Handle spurios irq detection for threaded irqsSebastian Andrzej Siewior
The detection of spurios interrupts is currently limited to first level handler. In force-threaded mode we never notice if the threaded irq does not feel responsible. This patch catches the return value of the threaded handler and forwards it to the spurious detector. If the primary handler returns only IRQ_WAKE_THREAD then the spourious detector ignores it because it gets called again from the threaded handler. [ tglx: Report the erroneous return value early and bail out ] Signed-off-by: Sebastian Andrzej Siewior <sebastian@breakpoint.cc> Link: http://lkml.kernel.org/r/1306824972-27067-2-git-send-email-sebastian@breakpoint.cc Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2011-06-03genirq: Print threaded handler in spurious debug outputSebastian Andrzej Siewior
In forced threaded mode (or with an explicit threaded handler) we only see the primary handler, but not the threaded handler. Signed-off-by: Sebastian Andrzej Siewior <sebastian@breakpoint.cc> Link: http://lkml.kernel.org/r/1306824972-27067-1-git-send-email-sebastian@breakpoint.cc Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2011-05-26irq: Remove smp_affinity_list when unregister irq procYinghai Lu
commit 4b06042(bitmap, irq: add smp_affinity_list interface to /proc/irq) causes the following warning: [ 274.239500] WARNING: at fs/proc/generic.c:850 remove_proc_entry+0x24c/0x27a() [ 274.251761] remove_proc_entry: removing non-empty directory 'irq/184', leaking at least 'smp_affinity_list' Remove the new file in the exit path. Signed-off-by: Yinghai Lu <yinghai@kernel.org> Cc: Mike Travis <travis@sgi.com> Link: http://lkml.kernel.org/r/4DDDE094.6050505@kernel.org Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2011-05-25bitmap, irq: add smp_affinity_list interface to /proc/irqMike Travis
Manually adjusting the smp_affinity for IRQ's becomes unwieldy when the cpu count is large. Setting smp affinity to cpus 256 to 263 would be: echo 000000ff,00000000,00000000,00000000,00000000,00000000,00000000,00000000 > smp_affinity instead of: echo 256-263 > smp_affinity_list Think about what it looks like for cpus around say, 4088 to 4095. We already have many alternate "list" interfaces: /sys/devices/system/cpu/cpuX/indexY/shared_cpu_list /sys/devices/system/cpu/cpuX/topology/thread_siblings_list /sys/devices/system/cpu/cpuX/topology/core_siblings_list /sys/devices/system/node/nodeX/cpulist /sys/devices/pci***/***/local_cpulist Add a companion interface, smp_affinity_list to use cpu lists instead of cpu maps. This conforms to other companion interfaces where both a map and a list interface exists. This required adding a bitmap_parselist_user() function in a manner similar to the bitmap_parse_user() function. [akpm@linux-foundation.org: make __bitmap_parselist() static] Signed-off-by: Mike Travis <travis@sgi.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Jack Steiner <steiner@sgi.com> Cc: Lee Schermerhorn <lee.schermerhorn@hp.com> Cc: Andy Shevchenko <andy.shevchenko@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-19Merge branch 'irq-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'irq-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: irq: Export functions to allow modular irq drivers genirq: Uninline and sanity check generic_handle_irq() genirq: Remove pointless ifdefs genirq: Make generic irq chip depend on CONFIG_GENERIC_IRQ_CHIP genirq: Add chip suspend and resume callbacks genirq: Implement a generic interrupt chip genirq: Support per-IRQ thread disabling. genirq: irq_desc: Document preflow_handler and affinity_hint genirq: Update DocBook comments genirq: Forgotten updates/deletions after removal of compat code
2011-05-18irq: Export functions to allow modular irq driversJonathan Cameron
Export handle_simple_irq, irq_modify_status, irq_alloc_descs, irq_free_descs and generic_handle_irq to allow their usage in modules. First user is IIO, which wants to be built modular, but needs to be able to create irq chips, allocate and configure interrupt descriptors and handle demultiplexing interrupts. [ tglx: Moved the uninlinig of generic_handle_irq to a separate patch ] Signed-off-by: Jonathan Cameron <jic23@cam.ac.uk> Link: http://lkml.kernel.org/r/%3C1305711544-505-1-git-send-email-jic23%40cam.ac.uk%3E Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
