path: root/kernel/irq
2013-07-21genirq: Fix can_request_irq() for IRQs without an actionBen Hutchings
commit 2779db8d37d4b542d9ca2575f5f178dbeaca6c86 upstream. Commit 02725e7471b8 ('genirq: Use irq_get/put functions'), inadvertently changed can_request_irq() to return 0 for IRQs that have no action. This causes pcibios_lookup_irq() to select only IRQs that already have an action with IRQF_SHARED set, or to fail if there are none. Change can_request_irq() to return 1 for IRQs that have no action (if the first two conditions are met). Reported-by: Bjarni Ingi Gislason <bjarniig@rhi.hi.is> Tested-by: Bjarni Ingi Gislason <bjarniig@rhi.hi.is> (against 3.2) Signed-off-by: Ben Hutchings <ben@decadent.org.uk> Cc: 709647@bugs.debian.org Link: http://bugs.debian.org/709647 Link: http://lkml.kernel.org/r/1372383630.23847.40.camel@deadeye.wl.decadent.org.uk Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-02-28genirq: Avoid deadlock in spurious handlingThomas Gleixner
commit e716efde75267eab919cdb2bef5b2cb77f305326 upstream. commit 52553ddf(genirq: fix regression in irqfixup, irqpoll) introduced a potential deadlock by calling the action handler with the irq descriptor lock held. Remove the call and let the handling code run even for an interrupt where only a single action is registered. That matches the goal of the above commit and avoids the deadlock. Document the confusing action = desc->action reload in the handling loop while at it. Reported-and-tested-by: "Wang, Warner" <warner.wang@hp.com> Tested-by: Edward Donovan <edward.donovan@numble.net> Cc: "Wang, Song-Bo (Stoney)" <song-bo.wang@hp.com> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-01-11genirq: Always force thread affinityThomas Gleixner
commit 04aa530ec04f61875b99c12721162e2964e3318c upstream. Sankara reported that the genirq core code fails to adjust the affinity of an interrupt thread in several cases: 1) On request/setup_irq() the call to setup_affinity() happens before the new action is registered, so the new thread is not notified. 2) For secondary shared interrupts nothing notifies the new thread to change its affinity. 3) Interrupts which have the IRQ_NO_BALANCE flag set are not moving the thread either. Fix this by setting the thread affinity flag right on thread creation time. This ensures that under all circumstances the thread moves to the right place. Requires a check in irq_thread_check_affinity for an existing affinity mask (CONFIG_CPU_MASK_OFFSTACK=y) Reported-and-tested-by: Sankara Muthukrishnan <sankara.m@gmail.com> Link: http://lkml.kernel.org/r/alpine.LFD.2.02.1209041738200.2754@ionos Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-08-15random: remove rand_initialize_irq()Theodore Ts'o
commit c5857ccf293968348e5eb4ebedc68074de3dcda6 upstream. With the new interrupt sampling system, we are no longer using the timer_rand_state structure in the irq descriptor, so we can stop initializing it now. [ Merged in fixes from Sedat to find some last missing references to rand_initialize_irq() ] Signed-off-by: "Theodore Ts'o" <tytso@mit.edu> Signed-off-by: Sedat Dilek <sedat.dilek@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-08-15random: make 'add_interrupt_randomness()' do something saneTheodore Ts'o
commit 775f4b297b780601e61787b766f306ed3e1d23eb upstream. We've been moving away from add_interrupt_randomness() for various reasons: it's too expensive to do on every interrupt, and flooding the CPU with interrupts could theoretically cause bogus floods of entropy from a somewhat externally controllable source. This solves both problems by limiting the actual randomness addition to just once a second or after 64 interrupts, whicever comes first. During that time, the interrupt cycle data is buffered up in a per-cpu pool. Also, we make sure the the nonblocking pool used by urandom is initialized before we start feeding the normal input pool. This assures that /dev/urandom is returning unpredictable data as soon as possible. (Based on an original patch by Linus, but significantly modified by tytso.) Tested-by: Eric Wustrow <ewust@umich.edu> Reported-by: Eric Wustrow <ewust@umich.edu> Reported-by: Nadia Heninger <nadiah@cs.ucsd.edu> Reported-by: Zakir Durumeric <zakir@umich.edu> Reported-by: J. Alex Halderman <jhalderm@umich.edu> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-05-15genirq: export handle_edge_irq() and irq_to_desc()Jiri Kosina
Export handle_edge_irq() and irq_to_desc() to modules to allow them to do things such as __irq_set_handler_locked(...., handle_edge_irq); This fixes ERROR: "handle_edge_irq" [drivers/gpio/gpio-pch.ko] undefined! ERROR: "irq_to_desc" [drivers/gpio/gpio-pch.ko] undefined! when gpio-pch is being built as a module. This was introduced by commit df9541a60af0 ("gpio: pch9: Use proper flow type handlers") that added __irq_set_handler_locked(d->irq, handle_edge_irq); but handle_edge_irq() was not exported for modules (and inlined __irq_set_handler_locked() requires irq_to_desc() exported as well) Signed-off-by: Jiri Kosina <jkosina@suse.cz> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-04-23irq: hide debug macros so they don't collide with others.Paul Gortmaker
The file kernel/irq/debug.h temporarily defines P, PS, PD and then undefines them. However these names aren't really "internal" enough, and collide with other more legit users such as the ones in the xtensa arch, causing: In file included from kernel/irq/internals.h:58:0, from kernel/irq/irqdesc.c:18: kernel/irq/debug.h:8:0: warning: "PS" redefined [enabled by default] arch/xtensa/include/asm/regs.h:59:0: note: this is the location of the previous definition Add a handful of underscores to do a better job of hiding these temporary macros. Cc: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2012-04-12irq_domain: fix type mismatch in debugfs output formatGrant Likely
sizeof(void*) returns an unsigned long, but it was being used as a width parameter to a "%-*s" format string which requires an int. On 64 bit platforms this causes a type mismatch: linux/kernel/irq/irqdomain.c:575: warning: field width should have type 'int', but argument 6 has type 'long unsigned int' This change casts the size to an int so printf gets the right data type. Reported-by: Andreas Schwab <schwab@linux-m68k.org> Signed-off-by: Grant Likely <grant.likely@secretlab.ca> Cc: David Daney <david.daney@cavium.com>
2012-04-12irq_domain: Move irq_virq_count into NOMAP revmapGrant Likely
This patch replaces the old global setting of irq_virq_count that is only used by the NOMAP mapping and instead uses a revmap_data property so that the maximum NOMAP allocation can be set per NOMAP irq_domain. There is exactly one user of irq_virq_count in-tree right now: PS3. Also, irq_virq_count is only useful for the NOMAP mapping. So, instead of having a single global irq_virq_count values, this change drops it entirely and added a max_irq argument to irq_domain_add_nomap(). That makes it a property of an individual nomap irq domain instead of a global system settting. Signed-off-by: Grant Likely <grant.likely@secretlab.ca> Tested-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Milton Miller <miltonm@bga.com>
2012-04-11irqdomain: Fix debugfs formattingGrant Likely
This patch fixes the irq_domain_mapping debugfs output to pad pointer values with leading zeros so that pointer values are displayed correctly. Otherwise you get output similar to "0x 5e0000000000000". Also, when the irq_domain is set to 'null' Signed-off-by: Grant Likely <grant.likely@secretlab.ca> Cc: David Daney <david.daney@cavium.com> Cc: Mika Westerberg <mika.westerberg@linux.intel.com>
2012-04-10irq_domain: correct the debugfs file nameMika Westerberg
The actual name of the irq_domain mapping debugfs file is "irq_domain_mapping" not "virq_mapping". Signed-off-by: Mika Westerberg <mika.westerberg@linux.intel.com> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2012-04-10irq/irq_domain: Quit ignoring error returns from irq_alloc_desc_from().David Daney
In commit 4bbdd45a (irq_domain/powerpc: eliminate irq_map; use irq_alloc_desc() instead) code was added that ignores error returns from irq_alloc_desc_from() by (silently) casting the return value to unsigned. The negitive value error return now suddenly looks like a valid irq number. Commits cc79ca69 (irq_domain: Move irq_domain code from powerpc to kernel/irq) and 1bc04f2c (irq_domain: Add support for base irq and hwirq in legacy mappings) move this code to its current location in irqdomain.c The result of all of this is a null pointer dereference OOPS if one of the error cases is hit. The fix: Don't cast away the negativeness of the return value and then check for errors. Signed-off-by: David Daney <david.daney@cavium.com> Acked-by: Rob Herring <rob.herring@calxeda.com> [grant.likely: dropped addition of new 'irq' variable] Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2012-03-30Merge branch 'irq-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull genirq updates from Thomas Gleixner. * 'irq-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: genirq: Adjust irq thread affinity on IRQ_SET_MASK_OK_NOCOPY return value genirq: Respect NUMA node affinity in setup_irq_irq affinity() genirq: Get rid of unneeded force parameter in irq_finalize_oneshot() genirq: Minor readablity improvement in irq_wake_thread()
2012-03-30genirq: Adjust irq thread affinity on IRQ_SET_MASK_OK_NOCOPY return valueJiang Liu
irq_move_masked_irq() checks the return code of chip->irq_set_affinity() only for 0, but IRQ_SET_MASK_OK_NOCOPY is also a valid return code, which is there to avoid a redundant copy of the cpumask. But in case of IRQ_SET_MASK_OK_NOCOPY we not only avoid the redundant copy, we also fail to adjust the thread affinity of an eventually threaded interrupt handler. Handle IRQ_SET_MASK_OK (==0) and IRQ_SET_MASK_OK_NOCOPY(==1) return values correctly by checking the valid return values seperately. Signed-off-by: Jiang Liu <jiang.liu@huawei.com> Cc: Jiang Liu <liuj97@gmail.com> Cc: Keping Chen <chenkeping@huawei.com> Cc: stable@vger.kernel.org Link: http://lkml.kernel.org/r/1333120296-13563-2-git-send-email-jiang.liu@huawei.com Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2012-03-29Merge branch 'for-linus' of git://git.linaro.org/people/rmk/linux-armLinus Torvalds
Pull more ARM updates from Russell King. This got a fair number of conflicts with the <asm/system.h> split, but also with some other sparse-irq and header file include cleanups. They all looked pretty trivial, though. * 'for-linus' of git://git.linaro.org/people/rmk/linux-arm: (59 commits) ARM: fix Kconfig warning for HAVE_BPF_JIT ARM: 7361/1: provide XIP_VIRT_ADDR for no-MMU builds ARM: 7349/1: integrator: convert to sparse irqs ARM: 7259/3: net: JIT compiler for packet filters ARM: 7334/1: add jump label support ARM: 7333/2: jump label: detect %c support for ARM ARM: 7338/1: add support for early console output via semihosting ARM: use set_current_blocked() and block_sigmask() ARM: exec: remove redundant set_fs(USER_DS) ARM: 7332/1: extract out code patch function from kprobes ARM: 7331/1: extract out insn generation code from ftrace ARM: 7330/1: ftrace: use canonical Thumb-2 wide instruction format ARM: 7351/1: ftrace: remove useless memory checks ARM: 7316/1: kexec: EOI active and mask all interrupts in kexec crash path ARM: Versatile Express: add NO_IOPORT ARM: get rid of asm/irq.h in asm/prom.h ARM: 7319/1: Print debug info for SIGBUS in user faults ARM: 7318/1: gic: refactor irq_start assignment ARM: 7317/1: irq: avoid NULL check in for_each_irq_desc loop ARM: 7315/1: perf: add support for the Cortex-A7 PMU ...
2012-03-29irqdomain: Remove powerpc dependency from debugfs fileGrant Likely
The debugfs code is really generic for all platforms. This patch removes the powerpc-specific directory reference and makes it available to all architectures. Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2012-03-29genirq: Respect NUMA node affinity in setup_irq_irq affinity()Prarit Bhargava
We respect node affinity of devices already in the irq descriptor allocation, but we ignore it for the initial interrupt affinity setup, so the interrupt might be routed to a different node. Restrict the default affinity mask to the node on which the irq descriptor is allocated. [ tglx: Massaged changelog ] Signed-off-by: Prarit Bhargava <prarit@redhat.com> Acked-by: Neil Horman <nhorman@tuxdriver.com> Cc: Yinghai Lu <yinghai@kernel.org> Cc: David Rientjes <rientjes@google.com> Link: http://lkml.kernel.org/r/1332788538-17425-1-git-send-email-prarit@redhat.com Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2012-03-29genirq: Get rid of unneeded force parameter in irq_finalize_oneshot()Alexander Gordeev
The only place irq_finalize_oneshot() is called with force parameter set is the threaded handler error exit path. But IRQTF_RUNTHREAD is dropped at this point and irq_wake_thread() is not going to set it again, since PF_EXITING is set for this thread already. So irq_finalize_oneshot() will drop the threads bit in threads_oneshot anyway and hence the force parameter is superfluous. Signed-off-by: Alexander Gordeev <agordeev@redhat.com> Link: http://lkml.kernel.org/r/20120321162234.GP24806@dhcp-26-207.brq.redhat.com Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2012-03-29genirq: Minor readablity improvement in irq_wake_thread()Alexander Gordeev
exit_irq_thread() clears IRQTF_RUNTHREAD flag and drops the thread's bit in desc->threads_oneshot then. The bit must not be set again in between and it does not, since irq_wake_thread() sees PF_EXITING flag first and returns. Due to above the order or checking PF_EXITING and IRQTF_RUNTHREAD flags in irq_wake_thread() is important. This change just makes it more visible in the source code. Signed-off-by: Alexander Gordeev <agordeev@redhat.com> Link: http://lkml.kernel.org/r/20120321162212.GO24806@dhcp-26-207.brq.redhat.com Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2012-03-21Merge tag 'irqdomain-for-linus' of git://git.secretlab.ca/git/linux-2.6Linus Torvalds
Pull irq_domain support for all architectures from Grant Likely: "Generialize powerpc's irq_host as irq_domain This branch takes the PowerPC irq_host infrastructure (reverse mapping from Linux IRQ numbers to hardware irq numbering), generalizes it, renames it to irq_domain, and makes it available to all architectures. Originally the plan has been to create an all-new irq_domain implementation which addresses some of the powerpc shortcomings such as not handling 1:1 mappings well, but doing that proved to be far more difficult and invasive than generalizing the working code and refactoring it in-place. So, this branch rips out the 'new' irq_domain and replaces it with the modified powerpc version (in a fully bisectable way of course). It converts all users over to the new API and makes irq_domain selectable on any architecture. No architecture is forced to enable irq_domain, but the infrastructure is required for doing OpenFirmware style irq translations. It will even work on SPARC even though SPARC has it's own mechanism for translating irqs at boot time. MIPS, microblaze, embedded x86 and c6x are converted too. The resulting irq_domain code is probably still too verbose and can be optimized more, but that can be done incrementally and is a task for follow-on patches." * tag 'irqdomain-for-linus' of git://git.secretlab.ca/git/linux-2.6: (31 commits) dt: fix twl4030 for non-dt compile on x86 mfd: twl-core: Add IRQ_DOMAIN dependency devicetree: Add empty of_platform_populate() for !CONFIG_OF_ADDRESS (sparc) irq_domain: Centralize definition of irq_dispose_mapping() irq_domain/mips: Allow irq_domain on MIPS irq_domain/x86: Convert x86 (embedded) to use common irq_domain ppc-6xx: fix build failure in flipper-pic.c and hlwd-pic.c irq_domain/microblaze: Convert microblaze to use irq_domains irq_domain/powerpc: Replace custom xlate functions with library functions irq_domain/powerpc: constify irq_domain_ops irq_domain/c6x: Use library of xlate functions irq_domain/c6x: constify irq_domain structures irq_domain/c6x: Convert c6x to use generic irq_domain support. irq_domain: constify irq_domain_ops irq_domain: Create common xlate functions that device drivers can use irq_domain: Remove irq_domain_add_simple() irq_domain: Remove 'new' irq_domain in favour of the ppc one mfd: twl-core.c: Fix the number of interrupts managed by twl4030 of/address: add empty static inlines for !CONFIG_OF irq_domain: Add support for base irq and hwirq in legacy mappings ...
2012-03-20Merge branch 'perf-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull perf events changes for v3.4 from Ingo Molnar: - New "hardware based branch profiling" feature both on the kernel and the tooling side, on CPUs that support it. (modern x86 Intel CPUs with the 'LBR' hardware feature currently.) This new feature is basically a sophisticated 'magnifying glass' for branch execution - something that is pretty difficult to extract from regular, function histogram centric profiles. The simplest mode is activated via 'perf record -b', and the result looks like this in perf report: $ perf record -b any_call,u -e cycles:u branchy $ perf report -b --sort=symbol 52.34% [.] main [.] f1 24.04% [.] f1 [.] f3 23.60% [.] f1 [.] f2 0.01% [k] _IO_new_file_xsputn [k] _IO_file_overflow 0.01% [k] _IO_vfprintf_internal [k] _IO_new_file_xsputn 0.01% [k] _IO_vfprintf_internal [k] strchrnul 0.01% [k] __printf [k] _IO_vfprintf_internal 0.01% [k] main [k] __printf This output shows from/to branch columns and shows the highest percentage (from,to) jump combinations - i.e. the most likely taken branches in the system. "branches" can also include function calls and any other synchronous and asynchronous transitions of the instruction pointer that are not 'next instruction' - such as system calls, traps, interrupts, etc. This feature comes with (hopefully intuitive) flat ascii and TUI support in perf report. - Various 'perf annotate' visual improvements for us assembly junkies. It will now recognize function calls in the TUI and by hitting enter you can follow the call (recursively) and back, amongst other improvements. - Multiple threads/processes recording support in perf record, perf stat, perf top - which is activated via a comma-list of PIDs: perf top -p 21483,21485 perf stat -p 21483,21485 -ddd perf record -p 21483,21485 - Support for per UID views, via the --uid paramter to perf top, perf report, etc. For example 'perf top --uid mingo' will only show the tasks that I am running, excluding other users, root, etc. - Jump label restructurings and improvements - this includes the factoring out of the (hopefully much clearer) include/linux/static_key.h generic facility: struct static_key key = STATIC_KEY_INIT_FALSE; ... if (static_key_false(&key)) do unlikely code else do likely code ... static_key_slow_inc(); ... static_key_slow_inc(); ... The static_key_false() branch will be generated into the code with as little impact to the likely code path as possible. the static_key_slow_*() APIs flip the branch via live kernel code patching. This facility can now be used more widely within the kernel to micro-optimize hot branches whose likelihood matches the static-key usage and fast/slow cost patterns. - SW function tracer improvements: perf support and filtering support. - Various hardenings of the perf.data ABI, to make older perf.data's smoother on newer tool versions, to make new features integrate more smoothly, to support cross-endian recording/analyzing workflows better, etc. - Restructuring of the kprobes code, the splitting out of 'optprobes', and a corner case bugfix. - Allow the tracing of kernel console output (printk). - Improvements/fixes to user-space RDPMC support, allowing user-space self-profiling code to extract PMU counts without performing any system calls, while playing nice with the kernel side. - 'perf bench' improvements - ... and lots of internal restructurings, cleanups and fixes that made these features possible. And, as usual this list is incomplete as there were also lots of other improvements * 'perf-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (120 commits) perf report: Fix annotate double quit issue in branch view mode perf report: Remove duplicate annotate choice in branch view mode perf/x86: Prettify pmu config literals perf report: Enable TUI in branch view mode perf report: Auto-detect branch stack sampling mode perf record: Add HEADER_BRANCH_STACK tag perf record: Provide default branch stack sampling mode option perf tools: Make perf able to read files from older ABIs perf tools: Fix ABI compatibility bug in print_event_desc() perf tools: Enable reading of perf.data files from different ABI rev perf: Add ABI reference sizes perf report: Add support for taken branch sampling perf record: Add support for sampling taken branch perf tools: Add code to support PERF_SAMPLE_BRANCH_STACK x86/kprobes: Split out optprobe related code to kprobes-opt.c x86/kprobes: Fix a bug which can modify kernel code permanently x86/kprobes: Fix instruction recovery on optimized path perf: Add callback to flush branch_stack on context switch perf: Disable PERF_SAMPLE_BRANCH_* when not supported perf/x86: Add LBR software filter support for Intel CPUs ...
2012-03-16genirq: Remove paranoid warnons and bogus fixupsThomas Gleixner
Alexander pointed out that the warnons in the regular exit path are bogus and the thread_mask one actually could be triggered when __setup_irq() hands out that thread_mask again after __free_irq() dropped irq_desc->lock. Thinking more about it, neither IRQTF_RUNTHREAD nor the bit in thread_mask can be set as this is the regular exit path. We come here due to: __free_irq() remove action from desc synchronize_irq() kthread_stop() So synchronize_irq() makes sure that the thread finished running and cleaned up both the thread_active count and thread_mask. After that point nothing can set IRQTF_RUNTHREAD on this action. So the warnons and the cleanups are pointless. Reported-by: Alexander Gordeev <agordeev@redhat.com> Cc: Ido Yariv <ido@wizery.com> Link: http://lkml.kernel.org/r/20120315190755.GA6732@dhcp-26-207.brq.redhat.com Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2012-03-14genirq: Flush the irq thread on synchronizationIdo Yariv
The current implementation does not always flush the threaded handler when disabling the irq. In case the irq handler was called, but the threaded handler hasn't started running yet, the interrupt will be flagged as pending, and the handler will not run. This implementation has some issues: First, if the interrupt is a wake source and flagged as pending, the system will not be able to suspend. Second, when quickly disabling and re-enabling the irq, the threaded handler might continue to run after the irq is re-enabled without the irq handler being called first. This might be an unexpected behavior. In addition, it might be counter-intuitive that the threaded handler will not be called even though the irq handler was called and returned IRQ_WAKE_THREAD. Fix this by always waiting for the threaded handler to complete in synchronize_irq(). [ tglx: Massaged comments, added WARN_ONs and the missing IRQTF_RUNTHREAD check in exit_irq_thread() ] Signed-off-by: Ido Yariv <ido@wizery.com> Link: http://lkml.kernel.org/r/1322843052-7166-1-git-send-email-ido@wizery.com Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2012-03-13Merge branch 'linus' into irq/coreThomas Gleixner
Reason: Get upstream fixes integrated before further modifications. Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2012-03-12Merge branch 'perf/urgent' into perf/coreIngo Molnar
Merge reason: We are going to queue up a dependent patch. Signed-off-by: Ingo Molnar <mingo@elte.hu>
2012-03-09genirq: Get rid of unnecessary IRQTF_DIED flagAlexander Gordeev
Currently IRQTF_DIED flag is set when a IRQ thread handler calls do_exit() But also PF_EXITING per process flag gets set when a thread exits. This fix eliminates the duplicate by using PF_EXITING flag. Also, there is a race condition in exit_irq_thread(). In case a thread's bit is cleared in desc->threads_oneshot (and the IRQ line gets unmasked), but before IRQTF_DIED flag is set, a new interrupt might come in and set just cleared bit again, this time forever. This fix throws IRQTF_DIED flag away, eliminating the race as a result. [ tglx: Test THREAD_EXITING first as suggested by Oleg ] Reported-by: Oleg Nesterov <oleg@redhat.com> Signed-off-by: Alexander Gordeev <agordeev@redhat.com> Link: http://lkml.kernel.org/r/20120309135958.GD2114@dhcp-26-207.brq.redhat.com Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2012-03-09genirq: No need to check IRQTF_DIED before stopping a thread handlerAlexander Gordeev
Since 63706172f332fd3f6e7458ebfb35fa6de9c21dc5 kthread_stop() is not afraid of dead kernel threads. So no need to check if a thread is alive before stopping it. These checks still were racy. Reported-by: Oleg Nesterov <oleg@redhat.com> Signed-off-by: Alexander Gordeev <agordeev@redhat.com> Link: http://lkml.kernel.org/r/20120309135939.GC2114@dhcp-26-207.brq.redhat.com Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2012-03-09genirq: Get rid of unnecessary irqaction field in task_structAlexander Gordeev
When a new thread handler is created, an irqaction is passed to it as data. Not only that irqaction is stored in task_struct by the handler for later use, but also a structure associated with the kernel thread keeps this value as long as the thread exists. This fix kicks irqaction out off task_struct. Yes, I introduce new bit field. But it allows not only to eliminate the duplicate, but also shortens size of task_struct. Reported-by: Oleg Nesterov <oleg@redhat.com> Signed-off-by: Alexander Gordeev <agordeev@redhat.com> Link: http://lkml.kernel.org/r/20120309135925.GB2114@dhcp-26-207.brq.redhat.com Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2012-03-09genirq: Fix incorrect check for forced IRQ thread handlerAlexander Gordeev
We do not want a bitwise AND between boolean operands Signed-off-by: Alexander Gordeev <agordeev@redhat.com> Cc: Oleg Nesterov <oleg@redhat.com> Link: http://lkml.kernel.org/r/20120309135912.GA2114@dhcp-26-207.brq.redhat.com Cc: stable@vger.kernel.org Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2012-03-06genirq: Clear action->thread_mask if IRQ_ONESHOT is not setThomas Gleixner
Xommit ac5637611(genirq: Unmask oneshot irqs when thread was not woken) fails to unmask when a !IRQ_ONESHOT threaded handler is handled by handle_level_irq. This happens because thread_mask is or'ed unconditionally in irq_wake_thread(), but for !IRQ_ONESHOT interrupts never cleared. So the check for !desc->thread_active fails and keeps the interrupt disabled. Keep the thread_mask zero for !IRQ_ONESHOT interrupts. Document the thread_mask magic while at it. Reported-and-tested-by: Sven Joachim <svenjoac@gmx.de> Reported-and-tested-by: Stefan Lippers-Hollmann <s.l-h@gmx.de> Cc: stable@vger.kernel.org Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-03-06genirq: Fix long-term regression in genirq irq_set_irq_type() handlingRussell King
In 2008, commit 0c5d1eb77a8be ("genirq: record trigger type") modified the way set_irq_type() handles the 'no trigger' condition. However, this has an adverse effect on PCMCIA support on Intel StrongARM and probably PXA platforms. PCMCIA has several status signals on the socket which can trigger interrupts; some of these status signals depend on the card's mode (whether it is configured in memory or IO mode). For example, cards have a 'Ready/IRQ' signal: in memory mode, this provides an indication to PCMCIA that the card has finished its power up initialization. In IO mode, it provides the device interrupt signal. Other status signals switch between on-board battery status and loud speaker output. In classical PCMCIA implementations, where you have a specific socket controller, the controller provides a method to mask interrupts from the socket, and importantly ignore any state transitions on the pins which correspond with interrupts once masked. This masking prevents unwanted events caused by the removal and application of socket power being forwarded. However, on platforms where there is no socket controller, the PCMCIA status and interrupt signals are routed to standard edge-triggered GPIOs. These GPIOs can be configured to interrupt on rising edge, falling edge, or never. This is where the problems start. Edge triggered interrupts are required to record events while disabled via the usual methods of {free,request,disable,enable}_irq() to prevent problems with dropped interrupts (eg, the 8390 driver uses disable_irq() to defer the delivery of interrupts). As a result, these interfaces can not be used to implement the desired behaviour. The side effect of this is that if the 'Ready/IRQ' GPIO is disabled via disable_irq() on suspend, and enabled via enable_irq() after resume, we will record the state transitions caused by powering events as valid interrupts, and foward them to the card driver, which may attempt to access a card which is not powered up. This leads delays resume while drivers spin in their interrupt handlers, and complaints from drivers before they realize what's happened. Moreover, in the case of the 'Ready/IRQ' signal, this is requested and freed by the card driver itself; the PCMCIA core has no idea whether the interrupt is requested, and, therefore, whether a call to disable_irq() would be valid. (We tried this around 2.4.17 / 2.5.1 kernel era, and ended up throwing it out because of this problem.) Therefore, it was decided back in around 2002 to disable the edge triggering instead, resulting in all state transitions on the GPIO being ignored. That's what we actually need the hardware to do. The commit above changes this behaviour; it explicitly prevents the 'no trigger' state being selected. The reason that request_irq() does not accept the 'no trigger' state is for compatibility with existing drivers which do not provide their desired triggering configuration. The set_irq_type() function is 'new' and not used by non-trigger aware drivers. Therefore, revert this change, and restore previously working platforms back to their former state. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Cc: linux@arm.linux.org.uk Cc: Ingo Molnar <mingo@elte.hu> Cc: stable@vger.kernel.org Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2012-03-05Merge branch 'perf/urgent' into perf/coreIngo Molnar
Conflicts: tools/perf/builtin-record.c tools/perf/builtin-top.c tools/perf/perf.h tools/perf/util/top.h Merge reason: resolve these cherry-picking conflicts. Signed-off-by: Ingo Molnar <mingo@elte.hu>
2012-02-24irq_domain/mips: Allow irq_domain on MIPSGrant Likely
This patch makes IRQ_DOMAIN usable on MIPS. It uses an ugly workaround to preserve current behaviour so that MIPS has time to add irq_domain registration to the irq controller drivers. The workaround will be removed in Linux v3.6 Signed-off-by: Grant Likely <grant.likely@secretlab.ca> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Rob Herring <rob.herring@calxeda.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: linux-mips@linux-mips.org
2012-02-16irq_domain: constify irq_domain_opsGrant Likely
Make irq_domain_ops pointer a constant to make it safer for multiple instances to share the same ops pointer and change the irq_domain code so that it does not modify the ops. v4: Fix mismatched type reference in powerpc code Signed-off-by: Grant Likely <grant.likely@secretlab.ca> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Milton Miller <miltonm@bga.com> Tested-by: Olof Johansson <olof@lixom.net>
2012-02-16irq_domain: Create common xlate functions that device drivers can useGrant Likely
Rather than having each interrupt controller driver creating its own barely unique .xlate function for irq_domain, create a library of translators which any driver can use directly. v5: - Remove irq_domain_xlate_pci(). It was incorrect. Signed-off-by: Grant Likely <grant.likely@secretlab.ca> Cc: Rob Herring <rob.herring@calxeda.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Mark Salter <msalter@redhat.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Milton Miller <miltonm@bga.com> Tested-by: Olof Johansson <olof@lixom.net>
2012-02-16irq_domain: Remove irq_domain_add_simple()Grant Likely
irq_domain_add_simple() was a stop-gap measure until complete irq_domain support was complete. This patch removes the irq_domain_add_simple() interface. This patch also drops the explicit irq_domain initialization performed by the mach-versatile code because the versatile interrupt controller already has irq_domain support built into it. This was a bug that was hanging around quietly for a while, but with the full irq_domain which actually verifies that irq_domain ranges are available it would cause the registration to fail and the system wouldn't boot. v4: Fixed number of irqs in mx5 gpio code v2: Updated to pass in host_data pointer on irq_domain allocation. Signed-off-by: Grant Likely <grant.likely@secretlab.ca> Cc: Rob Herring <rob.herring@calxeda.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Milton Miller <miltonm@bga.com> Cc: Russell King <linux@arm.linux.org.uk> Tested-by: Olof Johansson <olof@lixom.net>
2012-02-16irq_domain: Remove 'new' irq_domain in favour of the ppc oneGrant Likely
This patch removes the simplistic implementation of irq_domains and enables the powerpc infrastructure for all irq_domain users. The powerpc infrastructure includes support for complex mappings between Linux and hardware irq numbers, and can manage allocation of irq_descs. This patch also converts the few users of irq_domain_add()/irq_domain_del() to call irq_domain_add_legacy() instead. v3: Fix bug that set up too many irqs in translation range. v2: Fix removal of irq_alloc_descs() call in gic driver Signed-off-by: Grant Likely <grant.likely@secretlab.ca> Cc: Rob Herring <rob.herring@calxeda.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Milton Miller <miltonm@bga.com> Tested-by: Olof Johansson <olof@lixom.net>
2012-02-16irq_domain: Add support for base irq and hwirq in legacy mappingsGrant Likely
Add support for a legacy mapping where irq = (hwirq - first_hwirq + first_irq) so that a controller driver can allocate a fixed range of irq_descs and use a simple calculation to translate back and forth between linux and hw irq numbers. This is needed to use an irq_domain with many of the ARM interrupt controller drivers that manage their own irq_desc allocations. Ultimately the goal is to migrate those drivers to use the linear revmap, but doing it this way allows each driver to be converted separately which makes the migration path easier. This patch generalizes the IRQ_DOMAIN_MAP_LEGACY method to use (first_irq-first_hwirq) as the offset between hwirq and linux irq number, and adds checks to make sure that the hwirq number does not exceed range assigned to the controller. Signed-off-by: Grant Likely <grant.likely@secretlab.ca> Cc: Rob Herring <rob.herring@calxeda.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Milton Miller <miltonm@bga.com> Tested-by: Olof Johansson <olof@lixom.net>
2012-02-16irq_domain: Replace irq_alloc_host() with revmap-specific initializersGrant Likely
Each revmap type has different arguments for setting up the revmap. This patch splits up the generator functions so that each revmap type can do its own setup and the user doesn't need to keep track of how each revmap type handles the arguments. This patch also adds a host_data argument to the generators. There are cases where the host_data pointer will be needed before the function returns. ie. the legacy map calls the .map callback for each irq before returning. v2: - Add void *host_data argument to irq_domain_add_*() functions - fixed failure to compile - Moved IRQ_DOMAIN_MAP_* defines into irqdomain.c Signed-off-by: Grant Likely <grant.likely@secretlab.ca> Cc: Rob Herring <rob.herring@calxeda.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Milton Miller <miltonm@bga.com> Tested-by: Olof Johansson <olof@lixom.net>
2012-02-16irq_domain: Remove references to old irq_host namesGrant Likely
No functional changes. Replaces non-exported references to 'host' with domain. Does not change any symbol names referenced by other .c files. Signed-off-by: Grant Likely <grant.likely@secretlab.ca> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Milton Miller <miltonm@bga.com> Tested-by: Olof Johansson <olof@lixom.net>
2012-02-16irq_domain: remove NO_IRQ from irq domain codeGrant Likely
zero always means no irq when using irq domains. Get rid of the NO_IRQ references. Signed-off-by: Grant Likely <grant.likely@secretlab.ca> Cc: Rob Herring <rob.herring@calxeda.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Milton Miller <miltonm@bga.com> Tested-by: Olof Johansson <olof@lixom.net>
2012-02-16irq_domain: Move irq_domain code from powerpc to kernel/irqGrant Likely
This patch only moves the code. It doesn't make any changes, and the code is still only compiled for powerpc. Follow-on patches will generalize the code for other architectures. Signed-off-by: Grant Likely <grant.likely@secretlab.ca> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Milton Miller <miltonm@bga.com> Tested-by: Olof Johansson <olof@lixom.net>
2012-02-15genirq: Handle pending irqs in irq_startup()Thomas Gleixner
An interrupt might be pending when irq_startup() is called, but the startup code does not invoke the resend logic. In some cases this prevents the device from issuing another interrupt which renders the device non functional. Call the resend function in irq_startup() to keep things going. Reported-and-tested-by: Russell King <rmk+kernel@arm.linux.org.uk> Cc: stable@vger.kernel.org Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2012-02-15genirq: Unmask oneshot irqs when thread was not wokenThomas Gleixner
When the primary handler of an interrupt which is marked IRQ_ONESHOT returns IRQ_HANDLED or IRQ_NONE, then the interrupt thread is not woken and the unmask logic of the interrupt line is never invoked. This keeps the interrupt masked forever. This was not noticed as most IRQ_ONESHOT users wake the thread unconditionally (usually because they cannot access the underlying device from hard interrupt context). Though this behaviour was nowhere documented and not necessarily intentional. Some drivers can avoid the thread wakeup in certain cases and run into the situation where the interrupt line s kept masked. Handle it gracefully. Reported-and-tested-by: Lothar Wassmann <lw@karo-electronics.de> Cc: stable@vger.kernel.org Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2012-02-14irq_domain: Make irq_domain structure match powerpc's irq_hostGrant Likely
Part of the series to unify the irq remapping mechanisms in the kernel. A follow up patch will copy the powerpc implementation into kernel/irq/irqdomain.c, which will be a lot easier if the structures are identical. Where they differ, I've chose to use the powerpc names since there is a lot more code using those names. Signed-off-by: Grant Likely <grant.likely@secretlab.ca> Cc: Rob Herring <rob.herring@calxeda.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Milton Miller <miltonm@bga.com> Tested-by: Olof Johansson <olof@lixom.net>
2012-02-14irq_domain: Be less verboseGrant Likely
irq_domain printk's too much. Drop some output. Signed-off-by: Grant Likely <grant.likely@secretlab.ca> Cc: Rob Herring <rob.herring@calxeda.com> Cc: Thomas Gleixner <tglx@linutronix.de> Tested-by: Olof Johansson <olof@lixom.net>
2012-02-03tracing/softirq: Move __raise_softirq_irqoff() out of headerSteven Rostedt
The __raise_softirq_irqoff() contains a tracepoint. As tracepoints in headers can cause issues, and not to mention, bloats the kernel when they are in a static inline, it is best to move the function that contains the tracepoint out of the header and into softirq.c. Link: http://lkml.kernel.org/r/20120118120711.GB14863@elte.hu Suggested-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2012-01-25irq: make SPARSE_IRQ an optionally hidden optionRob Herring
On ARM, we don't want SPARSE_IRQ to be a user visible option. Make SPARSE_IRQ visible based on MAY_HAVE_SPARSE_IRQ instead of depending on HAVE_SPARSE_IRQ. With this, SPARSE_IRQ is not visible on C6X and ARM. Signed-off-by: Rob Herring <rob.herring@calxeda.com> Cc: Russell King <linux@arm.linux.org.uk> Cc: Mark Salter <msalter@redhat.com> Cc: Aurelien Jacquiot <a-jacquiot@ti.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Paul Mundt <lethal@linux-sh.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@redhat.com> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: linux-arm-kernel@lists.infradead.org Cc: linux-kernel@vger.kernel.org Cc: linux-c6x-dev@linux-c6x.org Cc: linuxppc-dev@lists.ozlabs.org Cc: linux-sh@vger.kernel.org
2012-01-13module_param: make bool parameters really bool (core code)Rusty Russell
module_param(bool) used to counter-intuitively take an int. In fddd5201 (mid-2009) we allowed bool or int/unsigned int using a messy trick. It's time to remove the int/unsigned int option. For this version it'll simply give a warning, but it'll break next kernel version. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2012-01-08Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (53 commits) Kconfig: acpi: Fix typo in comment. misc latin1 to utf8 conversions devres: Fix a typo in devm_kfree comment btrfs: free-space-cache.c: remove extra semicolon. fat: Spelling s/obsolate/obsolete/g SCSI, pmcraid: Fix spelling error in a pmcraid_err() call tools/power turbostat: update fields in manpage mac80211: drop spelling fix types.h: fix comment spelling for 'architectures' typo fixes: aera -> area, exntension -> extension devices.txt: Fix typo of 'VMware'. sis900: Fix enum typo 'sis900_rx_bufer_status' decompress_bunzip2: remove invalid vi modeline treewide: Fix comment and string typo 'bufer' hyper-v: Update MAINTAINERS treewide: Fix typos in various parts of the kernel, and fix some comments. clockevents: drop unknown Kconfig symbol GENERIC_CLOCKEVENTS_MIGR gpio: Kconfig: drop unknown symbol 'CS5535_GPIO' leds: Kconfig: Fix typo 'D2NET_V2' sound: Kconfig: drop unknown symbol ARCH_CLPS7500 ... Fix up trivial conflicts in arch/powerpc/platforms/40x/Kconfig (some new kconfig additions, close to removed commented-out old ones)
