commit c5857ccf293968348e5eb4ebedc68074de3dcda6 upstream.
With the new interrupt sampling system, we are no longer using the
timer_rand_state structure in the irq descriptor, so we can stop
initializing it now.
[ Merged in fixes from Sedat to find some last missing references to
rand_initialize_irq() ]
Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
Signed-off-by: Sedat Dilek <sedat.dilek@gmail.com>
[PG: in .34 the irqdesc.h content is in irq.h instead.]
Signed-off-by: Willy Tarreau <w@1wt.eu>
commit 775f4b297b780601e61787b766f306ed3e1d23eb upstream.
We've been moving away from add_interrupt_randomness() for various
reasons: it's too expensive to do on every interrupt, and flooding the
CPU with interrupts could theoretically cause bogus floods of entropy
from a somewhat externally controllable source.
This solves both problems by limiting the actual randomness addition
to just once a second or after 64 interrupts, whicever comes first.
During that time, the interrupt cycle data is buffered up in a per-cpu
pool. Also, we make sure the the nonblocking pool used by urandom is
initialized before we start feeding the normal input pool. This
assures that /dev/urandom is returning unpredictable data as soon as
possible.
(Based on an original patch by Linus, but significantly modified by
tytso.)
Tested-by: Eric Wustrow <ewust@umich.edu>
Reported-by: Eric Wustrow <ewust@umich.edu>
Reported-by: Nadia Heninger <nadiah@cs.ucsd.edu>
Reported-by: Zakir Durumeric <zakir@umich.edu>
Reported-by: J. Alex Halderman <jhalderm@umich.edu>.
[PG: minor adjustment required since .34 doesn't have f9e4989eb8
which renames "status" to "random" in kernel/irq/handle.c ]
commit 550acb19269d65f32e9ac4ddb26c2b2070e37f1c upstream.
In irq_wait_for_interrupt(), the should_stop member is verified before
setting the task's state to TASK_INTERRUPTIBLE and calling schedule().
In case kthread_stop sets should_stop and wakes up the process after
should_stop is checked by the irq thread but before the task's state
is changed, the irq thread might never exit:
kthread_stop irq_wait_for_interrupt
... while (!kthread_should_stop()) {
kthread->should_stop = 1;
wake_up_process(k);
wait_for_completion(&kthread->exited);
set_current_state(TASK_INTERRUPTIBLE);
schedule();
Fix this by checking if the thread should stop after modifying the
task's state.
[ tglx: Simplified it a bit ]
Signed-off-by: Ido Yariv <ido@wizery.com>
Link: http://lkml.kernel.org/r/1322740508-22640-1-git-send-email-ido@wizery.com
commit 9bab0b7fbaceec47d32db51cd9e59c82fb071f5a upstream
This adds a mechanism to resume selected IRQs during syscore_resume
instead of dpm_resume_noirq.
Under Xen we need to resume IRQs associated with IPIs early enough
that the resched IPI is unmasked and we can therefore schedule
ourselves out of the stop_machine where the suspend/resume takes
place.
This issue was introduced by 676dc3cf5bc3 "xen: Use IRQF_FORCE_RESUME".
Back ported to 2.6.32 (which lacks syscore support) by calling the relavant
resume function directly from sysdev_resume).
v2: Fixed non-x86 build errors.
Signed-off-by: Ian Campbell <ian.campbell@citrix.com>
Cc: Rafael J. Wysocki <rjw@sisk.pl>
Cc: Jeremy Fitzhardinge <Jeremy.Fitzhardinge@citrix.com>
Cc: xen-devel <xen-devel@lists.xensource.com>
Cc: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
Link: http://lkml.kernel.org/r/1318713254.11016.52.camel@dagon.hellion.org.uk
This reverts commit 0f12a6ad9fa3a03f2bcee36c9cb704821e244c40.
It causes too many build errors and needs to be done properly.
Reported-by: Jiri Slaby <jslaby@suse.cz>
Reported-by: Christoph Biedl <linux-kernel.bfrz@manchmal.in-ulm.de>
Cc: Ian Campbell <ian.campbell@citrix.com>
place.
commit dc5f219e88294b93009eef946251251ffffb6d60 upstream.
Xen needs to reenable interrupts which are marked IRQF_NO_SUSPEND in the
resume path. Add a flag to force the reenabling in the resume code.
Tested-and-acked-by: Ian Campbell <Ian.Campbell@eu.citrix.com>
Signed-off-by: Stefan Bader <stefan.bader@canonical.com>
commit 6d83f94db95cfe65d2a6359cccdf61cf087c2598 upstream.
With CONFIG_SHIRQ_DEBUG=y we call a newly installed interrupt handler
in request_threaded_irq().
The original implementation (commit a304e1b8) called the handler
_BEFORE_ it was installed, but that caused problems with handlers
calling disable_irq_nosync(). See commit 377bf1e4.
It's braindead in the first place to call disable_irq_nosync in shared
handlers, but ....
Moving this call after we installed the handler looks innocent, but it
is very subtle broken on SMP.
Interrupt handlers rely on the fact, that the irq core prevents
reentrancy.
Now this debug call violates that promise because we run the handler
w/o the IRQ_INPROGRESS protection - which we cannot apply here because
that would result in a possibly forever masked interrupt line.
A concurrent real hardware interrupt on a different CPU results in
handler reentrancy and can lead to complete wreckage, which was
unfortunately observed in reality and took a fricking long time to
debug.
Leave the code here for now. We want this debug feature, but that's
not easy to fix. We really should get rid of those
disable_irq_nosync() abusers and remove that function completely.
Cc: Anton Vorontsov <avorontsov@ru.mvista.com>
Cc: Arjan van de Ven <arjan@infradead.org>
commit 685fd0b4ea3f0f1d5385610b0d5b57775a8d5842 upstream.
A small number of users of IRQF_TIMER are using it for the implied no
suspend behaviour on interrupts which are not timer interrupts.
Therefore add a new IRQF_NO_SUSPEND flag, rename IRQF_TIMER to
__IRQF_TIMER and redefine IRQF_TIMER in terms of these new flags.
Cc: Dmitry Torokhov <dmitry.torokhov@gmail.com>
Cc: Grant Likely <grant.likely@secretlab.ca>
Cc: xen-devel@lists.xensource.com
Cc: linux-input@vger.kernel.org
Cc: linuxppc-dev@ozlabs.org
Cc: devicetree-discuss@lists.ozlabs.org
LKML-Reference: <1280398595-29708-1-git-send-email-ian.campbell@citrix.com>
commit 4673247562e39a17e09440fa1400819522ccd446 upstream.
The set_type() function can change the chip implementation when the
trigger mode changes. That might result in using an non-initialized
irq chip when called from __setup_irq() or when called via
set_irq_type() on an already enabled irq.
The set_irq_type() function should not be called on an enabled irq,
but because we forgot to put a check into it, we have a bunch of users
which grew the habit of doing that and it never blew up as the
function is serialized via desc->lock against all users of desc->chip
and they never hit the non-initialized irq chip issue.
The easy fix for the __setup_irq() issue would be to move the
irq_chip_set_defaults(desc->chip) call after the trigger setting to
make sure that a chip change is covered.
But as we have already users, which do the type setting after
request_irq(), the safe fix for now is to call irq_chip_set_defaults()
from __irq_set_trigger() when desc->set_type() changed the irq chip.
It needs a deeper analysis whether we should refuse to change the chip
on an already enabled irq, but that'd be a large scale change to fix
all the existing users. So that's neither stable nor 2.6.35 material.
Reported-by: Esben Haabendal <eha@doredevelopment.dk>
Cc: linuxppc-dev <linuxppc-dev@ozlabs.org>
commit 753649dbc49345a73a2454c770a3f2d54d11aec6 upstream.
Network folks reported that directing all MSI-X vectors of their multi
queue NICs to a single core can cause interrupt stack overflows when
enough interrupts fire at the same time.
This is caused by the fact that we run interrupt handlers by default
with interrupts enabled unless the driver reuqests the interrupt with
the IRQF_DISABLED set. The NIC handlers do not set this flag, so
simultaneous interrupts can nest unlimited and cause the stack
overflow.
The only safe counter measure is to run the interrupt handlers with
interrupts disabled. We can't switch to this mode in general right
now, but it is safe to do so for MSI interrupts.
Force IRQF_DISABLED for MSI interrupt handlers.
Cc: Linus Torvalds <torvalds@osdl.org>
Cc: Alan Cox <alan@lxorguk.ukuu.org.uk>
Cc: Greg Kroah-Hartman <gregkh@suse.de>
Cc: Arnaldo Carvalho de Melo <acme@redhat.com>
commit ced5b697a76d325e7a7ac7d382dbbb632c765093 upstream.
Keep chip_data in create_irq_nr and destroy_irq.
When two drivers are setting up MSI-X at the same time via
pci_enable_msix() there is a race. See this dmesg excerpt:
[ 85.170610] ixgbe 0000:02:00.1: irq 97 for MSI/MSI-X
[ 85.170611] alloc irq_desc for 99 on node -1
[ 85.170613] igb 0000:08:00.1: irq 98 for MSI/MSI-X
[ 85.170614] alloc kstat_irqs on node -1
[ 85.170616] alloc irq_2_iommu on node -1
[ 85.170617] alloc irq_desc for 100 on node -1
[ 85.170619] alloc kstat_irqs on node -1
[ 85.170621] alloc irq_2_iommu on node -1
[ 85.170625] ixgbe 0000:02:00.1: irq 99 for MSI/MSI-X
[ 85.170626] alloc irq_desc for 101 on node -1
[ 85.170628] igb 0000:08:00.1: irq 100 for MSI/MSI-X
[ 85.170630] alloc kstat_irqs on node -1
[ 85.170631] alloc irq_2_iommu on node -1
[ 85.170635] alloc irq_desc for 102 on node -1
[ 85.170636] alloc kstat_irqs on node -1
[ 85.170639] alloc irq_2_iommu on node -1
[ 85.170646] BUG: unable to handle kernel NULL pointer dereference
at 0000000000000088
As you can see igb and ixgbe are both alternating on create_irq_nr()
via pci_enable_msix() in their probe function.
ixgbe: While looping through irq_desc_ptrs[] via create_irq_nr() ixgbe
choses irq_desc_ptrs[102] and exits the loop, drops vector_lock and
calls dynamic_irq_init. Then it sets irq_desc_ptrs[102]->chip_data =
NULL via dynamic_irq_init().
igb: Grabs the vector_lock now and starts looping over irq_desc_ptrs[]
via create_irq_nr(). It gets to irq_desc_ptrs[102] and does this:
cfg_new = irq_desc_ptrs[102]->chip_data;
if (cfg_new->vector != 0)
continue;
This hits the NULL deref.
Another possible race exists via pci_disable_msix() in a driver or in
the number of error paths that call free_msi_irqs():
destroy_irq()
dynamic_irq_cleanup() which sets desc->chip_data = NULL
...race window...
desc->chip_data = cfg;
Remove the save and restore code for cfg in create_irq_nr() and
destroy_irq() and take the desc->lock when checking the irq_cfg.
Reported-and-analyzed-by: Brandon Philips <bphilips@suse.de>
Signed-off-by: Yinghai Lu <yinghai@kernel.org>
LKML-Reference: <1265793639-15071-3-git-send-email-yinghai@kernel.org>
Signed-off-by: Brandon Phililps <bphilips@suse.de>
Signed-off-by: H. Peter Anvin <hpa@zytor.com>
Prarit reported:
[ INFO: inconsistent lock state ]
2.6.32-rc5 #1
inconsistent {IN-HARDIRQ-W} -> {HARDIRQ-ON-W} usage.
swapper/0 [HC0[0]:SC1[1]:HE1:SE0] takes:
(&irq_desc_lock_class){?.-...}, at: [<ffffffff810c264e>] try_one_irq+0x32/0x138
{IN-HARDIRQ-W} state was registered at:
[<ffffffff81095160>] __lock_acquire+0x2fc/0xd5d
[<ffffffff81095cb4>] lock_acquire+0xf3/0x12d
[<ffffffff814cdadd>] _spin_lock+0x40/0x89
[<ffffffff810c3389>] handle_level_irq+0x30/0x105
[<ffffffff81014e0e>] handle_irq+0x95/0xb7
[<ffffffff810141bd>] do_IRQ+0x6a/0xe0
[<ffffffff81012813>] ret_from_intr+0x0/0x16
irq event stamp: 195096
hardirqs last enabled at (195096): [<ffffffff814cd7f7>] _spin_unlock_irq+0x3a/0x5c
hardirqs last disabled at (195095): [<ffffffff814cdbdd>] _spin_lock_irq+0x29/0x95
softirqs last enabled at (195088): [<ffffffff81068c92>] __do_softirq+0x1c1/0x1ef
softirqs last disabled at (195093): [<ffffffff8101304c>] call_softirq+0x1c/0x30
1 lock held by swapper/0:
#0: (kernel/irq/spurious.c:21){+.-...}, at: [<ffffffff81070cf2>]
run_timer_softirq+0x1a9/0x315
stack backtrace:
Pid: 0, comm: swapper Not tainted 2.6.32-rc5 #1
Call Trace:
<IRQ> [<ffffffff81093e94>] valid_state+0x187/0x1ae
[<ffffffff81093fe4>] mark_lock+0x129/0x253
[<ffffffff810951d4>] __lock_acquire+0x370/0xd5d
[<ffffffff810c2795>] poll_all_shared_irqs+0x41/0x6d
[<ffffffff810c27dd>] poll_spurious_irqs+0x1c/0x49
[<ffffffff81070d82>] run_timer_softirq+0x239/0x315
[<ffffffff81068bd3>] __do_softirq+0x102/0x1ef
[<ffffffff81014b65>] do_softirq+0x59/0xca
[<ffffffff810686ad>] irq_exit+0x58/0xae
[<ffffffff81029b84>] smp_apic_timer_interrupt+0x94/0xba
[<ffffffff81012a33>] apic_timer_interrupt+0x13/0x20
The reason is that try_one_irq() is called from hardirq context with
interrupts disabled and from softirq context (poll_all_shared_irqs())
with interrupts enabled.
Disable interrupts before calling it from poll_all_shared_irqs().
Reported-and-tested-by: Prarit Bhargava <prarit@redhat.com>
Signed-off-by: Yong Zhang <yong.zhang0@gmail.com>
LKML-Reference: <1257563773-4620-1-git-send-email-yong.zhang0@gmail.com>
After m68k's task_thread_info() doesn't refer to current,
it's possible to remove sched.h from interrupt.h and not break m68k!
Many thanks to Heiko Carstens for allowing this.
* 'irq-threaded-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
genirq: Do not mask oneshot edge type interrupts
genirq: Support nested threaded irq handling
genirq: Add buslock support
genirq: Add oneshot support
when there is no ram on node 0.
Cc: Jesse Barnes <jbarnes@virtuousgeek.org>
LKML-Reference: <4A95C32D.5040605@kernel.org>
Masking oneshot edge type interrupts is wrong as we might lose an
interrupt which is issued when the threaded handler is handling the
device. We can keep the irq unmasked safely as with edge type
interrupts there is no danger of interrupt floods. If the threaded
handler has not yet finished then IRQTF_RUNTHREAD is set which will
keep the handler thread active.
Debugged and verified in preempt-rt.
Merge reason: move from an -rc2 base to -rc7.
The wake_up_process() of the new irq thread in __setup_irq() is too
early as the irqaction is not yet fully initialized especially
action->irq is not yet set. The interrupt thread might dereference the
wrong irq descriptor.
Move the wakeup after the action is installed and action->irq has been
set.
Reported-by: Michael Buesch <mb@bu3sch.de>
Tested-by: Michael Buesch <mb@bu3sch.de>
Interrupt chips which are behind a slow bus (i2c, spi ...) and
demultiplex other interrupt sources need to run their interrupt
handler in a thread.
The demultiplexed interrupt handlers need to run in thread context as
well and need to finish before the demux handler thread can reenable
the interrupt line. So the easiest way is to run the sub device
handlers in the context of the demultiplexing handler thread.
To avoid that a separate thread is created for the subdevices the
function set_nested_irq_thread() is provided which sets the
IRQ_NESTED_THREAD flag in the interrupt descriptor.
A driver which calls request_threaded_irq() must not be aware of the
fact that the threaded handler is called in the context of the
demultiplexing handler thread. The setup code checks the
IRQ_NESTED_THREAD flag which was set from the irq chip setup code and
does not setup a separate thread for the interrupt. The primary
function which is provided by the device driver is replaced by an
internal dummy function which warns when it is called.
For the demultiplexing handler a helper function handle_nested_irq()
is provided which calls the demux interrupt thread function in the
context of the caller and does the proper interrupt accounting and
takes the interrupt disabled status of the demultiplexed subdevice
into account.
Cc: Mark Brown <broonie@opensource.wolfsonmicro.com>
Cc: Trilok Soni <soni.trilok@gmail.com>
Cc: Pavel Machek <pavel@ucw.cz>
Cc: Brian Swetland <swetland@google.com>
Cc: Joonyoung Shim <jy0922.shim@samsung.com>
Cc: m.szyprowski@samsung.com
Cc: t.fujak@samsung.com
Cc: kyungmin.park@samsung.com,
Cc: David Brownell <david-b@pacbell.net>
Cc: Daniel Ribeiro <drwyrm@gmail.com>
Cc: arve@android.com
Cc: Barry Song <21cnbao@gmail.com>
Some interrupt chips are connected to a "slow" bus (i2c, spi ...). The
bus access needs to sleep and therefor cannot be called in atomic
contexts.
Some of the generic interrupt management functions like disable_irq(),
enable_irq() ... call interrupt chip functions with the irq_desc->lock
held and interrupts disabled. This does not work for such devices.
Provide a separate synchronization mechanism for such interrupt
chips. The irq_chip structure is extended by two optional functions
(bus_lock and bus_sync_and_unlock).
The idea is to serialize the bus access for those operations in the
core code so that drivers which are behind that bus operated interrupt
controller do not have to worry about it and just can use the normal
interfaces. To achieve this we add two function pointers to the
irq_chip: bus_lock and bus_sync_unlock.
bus_lock() is called to serialize access to the interrupt controller
bus.
Now the core code can issue chip->mask/unmask ... commands without
changing the fast path code at all. The chip implementation merily
stores that information in a chip private data structure and
returns. No bus interaction as these functions are called from atomic
context.
After that bus_sync_unlock() is called outside the atomic context. Now
the chip implementation issues the bus commands, waits for completion
and unlocks the interrupt controller bus.
The irq_chip implementation as pseudo code:
struct irq_chip_data {
struct mutex mutex;
unsigned int irq_offset;
unsigned long mask;
unsigned long mask_status;
static void bus_lock(unsigned int irq)
struct irq_chip_data *data = get_irq_desc_chip_data(irq);
mutex_lock(&data->mutex);
static void mask(unsigned int irq)
irq -= data->irq_offset;
data->mask |= (1 << irq);
static void unmask(unsigned int irq)
data->mask &= ~(1 << irq);
static void bus_sync_unlock(unsigned int irq)
if (data->mask != data->mask_status) {
do_bus_magic_to_set_mask(data->mask);
data->mask_status = data->mask;
mutex_unlock(&data->mutex);
The device drivers can use request_threaded_irq, free_irq, disable_irq
and enable_irq as usual with the only restriction that the calls need
to come from non atomic context.
For threaded interrupt handlers we expect the hard interrupt handler
part to mask the interrupt on the originating device. The interrupt
line itself is reenabled after the hard interrupt handler has
executed.
This requires access to the originating device from hard interrupt
context which is not always possible. There are devices which can only
be accessed via a bus (i2c, spi, ...). The bus access requires thread
context. For such devices we need to keep the interrupt line masked
until the threaded handler has executed.
Add a new flag IRQF_ONESHOT which allows drivers to request that the
interrupt is not unmasked after the hard interrupt context handler has
been executed and the thread has been woken. The interrupt line is
unmasked after the thread handler function has been executed.
Note that for now IRQF_ONESHOT cannot be used with IRQF_SHARED to
avoid complex accounting mechanisms.
For oneshot interrupts the primary handler simply returns
IRQ_WAKE_THREAD and does nothing else. A generic implementation
irq_default_primary_handler() is provided to avoid useless copies all
over the place. It is automatically installed when
request_threaded_irq() is called with handler=NULL and
thread_fn!=NULL.
free_irq() can remove an irqaction while the corresponding interrupt
is in progress, but free_irq() sets action->thread to NULL
unconditionally, which might lead to a NULL pointer dereference in
handle_IRQ_event() when the hard interrupt context tries to wake up
the handler thread.
Prevent this by moving the thread stop after synchronize_irq(). No
need to set action->thread to NULL either as action is going to be
freed anyway.
This fixes a boot crash reported against preempt-rt which uses the
mainline irq threads code to implement full irq threading.
[ tglx: removed local irqthread variable ]
This takes care of the following entry from Dan's list:
kernel/irq/resend.c +73 check_irq_resend(17) warning: variable derefenced before check 'desc->chip'
Reported-by: Dan Carpenter <error27@gmail.com>
Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
Cc: Jonathan Corbet <corbet@lwn.net>
Cc: Eugene Teo <eteo@redhat.com>
Cc: Julia Lawall <julia@diku.dk>
LKML-Reference: <200908062146.03638.bzolnier@gmail.com>
Don't move it if target node is -1.
LKML-Reference: <4A785B5D.4070702@kernel.org>
It's wrong (the parm takes no arguments) and compile-time wiped
away anyway (due to !MODULE).
Signed-off-by: Jiri Slaby <jirislaby@gmail.com>
LKML-Reference: <1248991326-26267-1-git-send-email-jirislaby@gmail.com>
Since genirq: Delegate irq affinity setting to the irq thread
(591d2fb02ea80472d846c0b8507007806bdd69cc) compilation with
CONFIG_SMP=n fails with following error:
/usr/src/linux-2.6/kernel/irq/manage.c:
In function 'irq_thread_check_affinity':
/usr/src/linux-2.6/kernel/irq/manage.c:475:
error: 'struct irq_desc' has no member named 'affinity'
make[4]: *** [kernel/irq/manage.o] Error 1
That commit adds a new function irq_thread_check_affinity() which
uses struct irq_desc.affinity which is only available for CONFIG_SMP=y.
Move that function under #ifdef CONFIG_SMP.
[ tglx@brownpaperbag: compile and boot tested on UP and SMP ]
Signed-off-by: Bruno Premont <bonbons@linux-vserver.org>
LKML-Reference: <20090722222232.2eb3e1c4@neptune.home>
irq_set_thread_affinity() calls set_cpus_allowed_ptr() which might
sleep, but irq_set_thread_affinity() is called with desc->lock held
and can be called from hard interrupt context as well. The code has
another bug as it does not hold a ref on the task struct as required
by set_cpus_allowed_ptr().
Just set the IRQTF_AFFINITY bit in action->thread_flags. The next time
the thread runs it migrates itself. Solves all of the above problems
nicely.
Add kerneldoc to irq_set_thread_affinity() while at it.
LKML-Reference: <new-submission>
The kerneldoc comment describing suspend_device_irqs() is currently
misleading, because generally the function doesn't really disable
interrupt lines at the chip level. Replace it with a more accurate
one.
LKML-Reference: <200907050022.35117.rjw@sisk.pl>
* 'irq-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
genirq, irq.h: Fix kernel-doc warnings
genirq: fix comment to say IRQ_WAKE_THREAD
Ingo had
[ 0.000000] ------------[ cut here ]------------
[ 0.000000] WARNING: at mm/bootmem.c:537 alloc_arch_preferred_bootmem+0x2b/0x71()
[ 0.000000] Hardware name: System Product Name
[ 0.000000] Modules linked in:
[ 0.000000] Pid: 0, comm: swapper Tainted: G W 2.6.30-tip-03087-g0bb2618-dirty #52506
[ 0.000000] Call Trace:
[ 0.000000] [<81032588>] warn_slowpath_common+0x60/0x90
[ 0.000000] [<810325c5>] warn_slowpath_null+0xd/0x10
[ 0.000000] [<819d1bc0>] alloc_arch_preferred_bootmem+0x2b/0x71
[ 0.000000] [<819d1c31>] ___alloc_bootmem_nopanic+0x2b/0x9a
[ 0.000000] [<81050a0a>] ? lock_release+0xac/0xb2
[ 0.000000] [<819d1d4c>] ___alloc_bootmem+0xe/0x2d
[ 0.000000] [<819d1e9f>] __alloc_bootmem+0xa/0xc
[ 0.000000] [<819d7c63>] alloc_bootmem_cpumask_var+0x21/0x26
[ 0.000000] [<819d0cc8>] early_irq_init+0x15/0x10d
[ 0.000000] [<819bb75a>] start_kernel+0x167/0x326
[ 0.000000] [<819bb06b>] __init_begin+0x6b/0x70
[ 0.000000] ---[ end trace 4eaa2a86a8e2da23 ]---
[ 0.000000] NR_IRQS:2304 nr_irqs:424
[ 0.000000] CPU 0 irqstacks, hard=821e6000 soft=821e7000
we need to update init_irq_default_affinity
Signed-off-by: Pekka Enberg <penberg@cs.helsinki.fi>
Fixes the following problem:
[ 0.000000] Experimental hierarchical RCU init done.
[ 0.000000] NR_IRQS:4352 nr_irqs:256
[ 0.000000] WARNING: at mm/bootmem.c:537 alloc_arch_preferred_bootmem+0x40/0x7e()
[ 0.000000] Hardware name: To Be Filled By O.E.M.
[ 0.000000] Pid: 0, comm: swapper Not tainted 2.6.30-tip-02161-g7a74539-dirty #59709
[ 0.000000] [<ffffffff823f8c8e>] ? alloc_arch_preferred_bootmem+0x40/0x7e
[ 0.000000] [<ffffffff81067168>] warn_slowpath_common+0x88/0xcb
[ 0.000000] [<ffffffff810671d2>] warn_slowpath_null+0x27/0x3d
[ 0.000000] [<ffffffff823f8c8e>] alloc_arch_preferred_bootmem+0x40/0x7e
[ 0.000000] [<ffffffff823f9307>] ___alloc_bootmem_nopanic+0x4e/0xec
[ 0.000000] [<ffffffff823f93c5>] ___alloc_bootmem+0x20/0x61
[ 0.000000] [<ffffffff823f962e>] __alloc_bootmem+0x1e/0x34
[ 0.000000] [<ffffffff823f757c>] early_irq_init+0x6d/0x118
[ 0.000000] [<ffffffff823e0140>] ? early_idt_handler+0x0/0x71
[ 0.000000] [<ffffffff823e0cf7>] start_kernel+0x192/0x394
[ 0.000000] [<ffffffff823e02ad>] x86_64_start_reservations+0xb4/0xcf
[ 0.000000] [<ffffffff823e0000>] ? __init_begin+0x0/0x140
[ 0.000000] [<ffffffff823e0420>] x86_64_start_kernel+0x158/0x17b
[ 0.000000] ---[ end trace a7919e7f17c0a725 ]---
[ 0.000000] Fast TSC calibration using PIT
[ 0.000000] Detected 2002.510 MHz processor.
[ 0.004000] Console: colour VGA+ 80x25
Reported-by: Ingo Molnar <mingo@elte.hu>
Don't hardcode to node zero for early boot IRQ setup memory allocations.
[ penberg@cs.helsinki.fi: minor cleanups ]
* 'tracing-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (244 commits)
Revert "x86, bts: reenable ptrace branch trace support"
tracing: do not translate event helper macros in print format
ftrace/documentation: fix typo in function grapher name
tracing/events: convert block trace points to TRACE_EVENT(), fix !CONFIG_BLOCK
tracing: add protection around module events unload
tracing: add trace_seq_vprint interface
tracing: fix the block trace points print size
ring-buffer: fix ret in rb_add_time_stamp
ring-buffer: pass in lockdep class key for reader_lock
tracing: add annotation to what type of stack trace is recorded
tracing: fix multiple use of __print_flags and __print_symbolic
tracing/events: fix output format of user stack
tracing/events: fix output format of kernel stack
tracing/trace_stack: fix the number of entries in the header
ring-buffer: discard timestamps that are at the start of the buffer
ring-buffer: try to discard unneeded timestamps
ring-buffer: fix bug in ring_buffer_discard_commit
ftrace: do not profile functions when disabled
tracing: make trace pipe recognize latency format flag
Presently non-legacy IRQs have their irq_desc allocated with
kzalloc_node(). This assumes that all callers of irq_to_desc_node_alloc()
will be sufficiently late in the boot process that kmalloc is available.
While porting sparseirq support to sh this blew up immediately, as at the
time that we register the CPU's interrupt vector map only bootmem is
available. Check slab_is_available() to work out which path to use.
[ Impact: fix SH early boot crash with sparseirq enabled ]
Signed-off-by: Paul Mundt <lethal@linux-sh.org>
Acked-by: Yinghai Lu <yinghai@kernel.org>
LKML-Reference: <20090522014008.GA2806@linux-sh.org>
Trying to implement a driver to use threaded irqs, I was confused when the
return value to use that was described in the comment above
request_threaded_irq was not defined.
Turns out that the enum is IRQ_WAKE_THREAD where as the comment said
IRQ_THREAD_WAKE.
[Impact: do not confuse developers with wrong comments ]
LKML-Reference: <alpine.DEB.2.00.0905121431020.13338@gandalf.stny.rr.com>
Merge reason: both topics modify the APIC code but were able to do it in
parallel so far. An upcoming patch generates a conflict so
merge them to avoid the conflict.
Merge reason: tracing/core was on a .30-rc1 base and was missing out on
on a handful of tracing fixes present in .30-rc5-almost.
move_irq_desc() will try to move irq_desc to the home node if
the allocated one is not correct, in create_irq_nr().
( This can happen on devices that are on different nodes that
are using MSI, when drivers are loaded and unloaded randomly. )
v2: fix non-smp build
v3: add NUMA_IRQ_DESC to eliminate #ifdefs
[ Impact: improve irq descriptor locality on NUMA systems ]
Cc: Suresh Siddha <suresh.b.siddha@intel.com>
Cc: "Eric W. Biederman" <ebiederm@xmission.com>
LKML-Reference: <49F95EAE.2050903@kernel.org>
This reverts commit 044d408409cc4e1bc75c886e27ca85c270db104c.
The commit added a warning when handle_IRQ_event() is called outside
of hard interrupt context. This breaks the generic tasklet based
interrupt resend mechanism which is used when the hardware has no way
to retrigger the interrupt. So we get a warning for a use case which
is correct and worked for years. Remove it.
"tracing: create automated trace defines" causes this compile error on s390,
as reported by Sachin Sant against linux-next:
kernel/built-in.o: In function `__do_softirq':
(.text+0x1c680): undefined reference to `__tracepoint_softirq_entry'
This happens because the definitions of the softirq tracepoints were moved
from kernel/softirq.c to kernel/irq/handle.c. Since s390 doesn't support
generic hardirqs handle.c doesn't get compiled and the definitions are
missing.
So move the tracepoints to softirq.c again.
[ Impact: fix build failure on s390 ]
Reported-by: Sachin Sant <sachinp@in.ibm.com>
Cc: fweisbec@gmail.com
LKML-Reference: <20090429135139.5fac79b8@osiris.boeblingen.de.ibm.com>
This simplifies the node awareness of the code. All our allocators
only deal with a NUMA node ID locality not with CPU ids anyway - so
there's no need to maintain (and transform) a CPU id all across the
IRq layer.
v2: keep move_irq_desc related
[ Impact: cleanup, prepare IRQ code to be NUMA-aware ]
LKML-Reference: <49F65536.2020300@kernel.org>
irq_set_affinity() and move_masked_irq() try to assign affinity
before calling chip set_affinity(). Some archs are assigning it
in ->set_affinity() again.
We do something like:
cpumask_cpy(desc->affinity, mask);
desc->chip->set_affinity(mask);
But in the failure path, affinity should not be touched - otherwise
we'll end up with a different affinity mask despite the failure to
migrate the IRQ.
So try to update the afffinity only if set_affinity returns with 0.
Also call irq_set_thread_affinity accordingly.
v2: update after "irq, x86: Remove IRQ_DISABLED check in process context IRQ move"
v3: according to Ingo, change set_affinity() in irq_chip should return int.
v4: update comments by removing moving irq_desc code.
[ Impact: fix /proc/irq/*/smp_affinity setting corner case bug ]
LKML-Reference: <49F65509.60307@kernel.org>
The original feature of migrating irq_desc dynamic was too fragile
and was causing problems: it caused crashes on systems with lots of
cards with MSI-X when user-space irq-balancer was enabled.
We now have new patches that create irq_desc according to device
numa node. This patch removes the leftover bits of the dynamic balancer.
[ Impact: remove dead code ]
LKML-Reference: <49F654AF.8000808@kernel.org>
CPUMASKS_OFFSTACK is not defined anywhere (it is CPUMASK_OFFSTACK).
It is a typo and init_allocate_desc_masks() is called before it set
affinity to all cpus...
Split init_alloc_desc_masks() into all_desc_masks() and init_desc_masks().
Also use CPUMASK_OFFSTACK in alloc_desc_masks().
[ Impact: fix smp_affinity copying/setup when moving irq_desc between CPUs ]
Acked-by: Rusty Russell <rusty@rustcorp.com.au>
LKML-Reference: <49F6546E.3040406@kernel.org>
Impact: clean up
Create a sub directory in include/trace called events to keep the
trace point headers in their own separate directory. Only headers that
declare trace points should be defined in this directory.
Cc: Neil Horman <nhorman@tuxdriver.com>
Cc: Zhao Lei <zhaolei@cn.fujitsu.com>
Cc: Eduard - Gabriel Munteanu <eduard.munteanu@linux360.ro>
Cc: Pekka Enberg <penberg@cs.helsinki.fi>
This patch lowers the number of places a developer must modify to add
new tracepoints. The current method to add a new tracepoint
into an existing system is to write the trace point macro in the
trace header with one of the macros TRACE_EVENT, TRACE_FORMAT or
DECLARE_TRACE, then they must add the same named item into the C file
with the macro DEFINE_TRACE(name) and then add the trace point.
This change cuts out the needing to add the DEFINE_TRACE(name).
Every file that uses the tracepoint must still include the trace/<type>.h
file, but the one C file must also add a define before the including
of that file.
#define CREATE_TRACE_POINTS
#include <trace/mytrace.h>
This will cause the trace/mytrace.h file to also produce the C code
necessary to implement the trace point.
Note, if more than one trace/<type>.h is used to create the C code
it is best to list them all together.
#include <trace/foo.h>
#include <trace/bar.h>
#include <trace/fido.h>
Thanks to Mathieu Desnoyers and Christoph Hellwig for coming up with
the cleaner solution of the define above the includes over my first
design to have the C code include a "special" header.
This patch converts sched, irq and lockdep and skb to use this new
method.
As discussed in the thread here:
http://marc.info/?l=linux-kernel&m=123964468521142&w=2
Eric W. Biederman observed:
> It looks like some additional bugs have slipped in since last I looked.
> set_irq_affinity does this:
> ifdef CONFIG_GENERIC_PENDING_IRQ
> if (desc->status & IRQ_MOVE_PCNTXT || desc->status & IRQ_DISABLED) {
> cpumask_copy(desc->affinity, cpumask);
> desc->chip->set_affinity(irq, cpumask);
> } else {
> desc->status |= IRQ_MOVE_PENDING;
> cpumask_copy(desc->pending_mask, cpumask);
> #else
> That IRQ_DISABLED case is a software state and as such it has nothing to
> do with how safe it is to move an irq in process context.
> The only reason we migrate MSIs in interrupt context today is that there
> wasn't infrastructure for support migration both in interrupt context
> and outside of it.
Yes. The idea here was to force the MSI migration to happen in process
context. One of the patches in the series did
disable_irq(dev->irq);
irq_set_affinity(dev->irq, cpumask_of(dev->cpu));
enable_irq(dev->irq);
with the above patch adding irq/manage code check for interrupt disabled
and moving the interrupt in process context.
IIRC, there was no IRQ_MOVE_PCNTXT when we were developing this HPET
code and we ended up having this ugly hack. IRQ_MOVE_PCNTXT was there
when we eventually submitted the patch upstream. But, looks like I did a
blind rebasing instead of using IRQ_MOVE_PCNTXT in hpet MSI code.
Below patch fixes this. i.e., revert commit 932775a4ab622e3c99bd59f14cc
and add PCNTXT to HPET MSI setup. Also removes copying of desc->affinity
in generic code as set_affinity routines are doing it internally.
Reported-by: "Eric W. Biederman" <ebiederm@xmission.com>
Signed-off-by: Venkatesh Pallipadi <venkatesh.pallipadi@intel.com>
Acked-by: "Eric W. Biederman" <ebiederm@xmission.com>
Cc: "Li Shaohua" <shaohua.li@intel.com>
Cc: Gary Hade <garyhade@us.ibm.com>
Cc: "lcm@us.ibm.com" <lcm@us.ibm.com>
Cc: suresh.b.siddha@intel.com
LKML-Reference: <20090413222058.GB8211@linux-os.sc.intel.com>
'timers-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip
* 'core-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
printk: fix wrong format string iter for printk
futex: comment requeue key reference semantics
irq: fix cpumask memory leak on offstack cpumask kernels
* 'timers-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
posix-timers: fix RLIMIT_CPU && setitimer(CPUCLOCK_PROF)
posix-timers: fix RLIMIT_CPU && fork()
timers: add missing kernel-doc
include/linux/irq.h
kernel/irq/handle.c
