path: root/kernel/irq
2011-02-02genirq: Prevent irq storm on migrationThomas Gleixner
move_native_irq() masks and unmasks the interrupt line unconditionally, but the interrupt line might be masked due to a threaded oneshot handler in progress. Unmasking the line in that case can lead to interrupt storms. Observed on PREEMPT_RT. Originally-from: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: stable@kernel.org
2011-01-21genirq: Remove __do_IRQThomas Gleixner
All architectures are finally converted. Remove the cruft. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Richard Henderson <rth@twiddle.net> Cc: Mike Frysinger <vapier@gentoo.org> Cc: David Howells <dhowells@redhat.com> Cc: Tony Luck <tony.luck@intel.com> Cc: Greg Ungerer <gerg@uclinux.org> Cc: Michal Simek <monstr@monstr.eu> Acked-by: David Howells <dhowells@redhat.com> Cc: Kyle McMartin <kyle@mcmartin.ca> Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Chen Liqin <liqin.chen@sunplusct.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: Chris Metcalf <cmetcalf@tilera.com> Cc: Jeff Dike <jdike@addtoit.com>
2011-01-13irq: use per_cpu kstat_irqsEric Dumazet
Use modern per_cpu API to increment {soft|hard}irq counters, and use per_cpu allocation for (struct irq_desc)->kstats_irq instead of an array. This gives better SMP/NUMA locality and saves few instructions per irq. With small nr_cpuids values (8 for example), kstats_irq was a small array (less than L1_CACHE_BYTES), potentially source of false sharing. In the !CONFIG_SPARSE_IRQ case, remove the huge, NUMA/cache unfriendly kstat_irqs_all[NR_IRQS][NR_CPUS] array. Note: we still populate kstats_irq for all possible irqs in early_irq_init(). We probably could use on-demand allocations. (Code included in alloc_descs()). Problem is not all IRQS are used with a prior alloc_descs() call. kstat_irqs_this_cpu() is not used anymore, remove it. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Reviewed-by: Christoph Lameter <cl@linux.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Andi Kleen <andi@firstfloor.org> Cc: Tejun Heo <tj@kernel.org> Cc: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-01-07sched: Constify function scope static struct sched_param usagePeter Zijlstra
Function-scope statics are discouraged because they are easily overlooked and can cause subtle bugs/races due to their global (non-SMP safe) nature. Linus noticed that we did this for sched_param - at minimum make the const. Suggested-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> LKML-Reference: Message-ID: <AANLkTinotRxScOHEb0HgFgSpGPkq_6jKTv5CfvnQM=ee@mail.gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-12-08Merge branch 'linus' into sched/coreIngo Molnar
Merge reason: we want to queue up dependent cleanup Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-12-01genirq: Fix incorrect proc spurious outputKenji Kaneshige
Since commit a1afb637(switch /proc/irq/*/spurious to seq_file) all /proc/irq/XX/spurious files show the information of irq 0. Current irq_spurious_proc_open() passes on NULL as the 3rd argument, which is used as an IRQ number in irq_spurious_proc_show(), to the single_open(). Because of this, all the /proc/irq/XX/spurious file shows IRQ 0 information regardless of the IRQ number. To fix the problem, irq_spurious_proc_open() must pass on the appropreate data (IRQ number) to single_open(). Signed-off-by: Kenji Kaneshige <kaneshige.kenji@jp.fujitsu.com> Reviewed-by: Yong Zhang <yong.zhang0@gmail.com> LKML-Reference: <4CF4B778.90604@jp.fujitsu.com> Cc: stable@kernel.org [2.6.33+] Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2010-11-18Merge commit 'v2.6.37-rc2' into sched/coreIngo Molnar
Merge reason: Move to a .37-rc base. Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-10-31Merge branches 'irq-core-for-linus' and 'core-locking-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'irq-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: genirq: Fix up irq_node() for irq_data changes. genirq: Add single IRQ reservation helper genirq: Warn if enable_irq is called before irq is set up * 'core-locking-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: semaphore: Remove mutex emulation staging: Final semaphore cleanup jbd2: Convert jbd2_slab_create_sem to mutex hpfs: Convert sbi->hpfs_creation_de to mutex Fix up trivial change/delete conflicts with deleted 'dream' drivers (drivers/staging/dream/camera/{mt9d112.c,mt9p012_fox.c,mt9t013.c,s5k3e2fx.c})
2010-10-27/proc/stat: fix scalability of irq sum of all cpuKAMEZAWA Hiroyuki
In /proc/stat, the number of per-IRQ event is shown by making a sum each irq's events on all cpus. But we can make use of kstat_irqs(). kstat_irqs() do the same calculation, If !CONFIG_GENERIC_HARDIRQ, it's not a big cost. (Both of the number of cpus and irqs are small.) If a system is very big and CONFIG_GENERIC_HARDIRQ, it does for_each_irq() for_each_cpu() - look up a radix tree - read desc->irq_stat[cpu] This seems not efficient. This patch adds kstat_irqs() for CONFIG_GENRIC_HARDIRQ and change the calculation as for_each_irq() look up radix tree for_each_cpu() - read desc->irq_stat[cpu] This reduces cost. A test on (4096cpusp, 256 nodes, 4592 irqs) host (by Jack Steiner) %time cat /proc/stat > /dev/null Before Patch: 2.459 sec After Patch : .561 sec [akpm@linux-foundation.org: unexport kstat_irqs, coding-style tweaks] [akpm@linux-foundation.org: fix unused variable 'per_irq_sum'] Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Tested-by: Jack Steiner <steiner@sgi.com> Acked-by: Jack Steiner <steiner@sgi.com> Cc: Yinghai Lu <yinghai@kernel.org> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-23sched: Make sched_param argument static in sched_setscheduler() callersKOSAKI Motohiro
Andrew Morton pointed out almost all sched_setscheduler() callers are using fixed parameters and can be converted to static. It reduces runtime memory use a little. Signed-off-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Reported-by: Andrew Morton <akpm@linux-foundation.org> Acked-by: James Morris <jmorris@namei.org> Cc: Ingo Molnar <mingo@elte.hu> Cc: Steven Rostedt <rostedt@goodmis.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-10-22genirq: Warn if enable_irq is called before irq is set upThomas Gleixner
The recent changes in the genirq core unearthed a bug in arch/um which called enable_irq() before the interrupt was set up. Warn and return instead of crashing the machine with a NULL pointer dereference. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Richard Weinberger <richard@nod.at>
2010-10-12genirq: Fix CONFIG_GENIRQ_NO_DEPRECATED=y buildThomas Gleixner
This option can be set to verify the full conversion to the new chip functions. Fix the fallout of the patch rework, so the core code compiles and works with it. Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2010-10-12genirq: Switch sparse_irq allocator to GFP_KERNELThomas Gleixner
The allocator functions are now called outside of preempt disabled regions. Switch to GFP_KERNEL. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Reviewed-by: Ingo Molnar <mingo@elte.hu>
2010-10-12genirq: Make sparse_lock a mutexThomas Gleixner
No callers from atomic regions. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Reviewed-by: Ingo Molnar <mingo@elte.hu>
2010-10-12genirq: Remove the now unused sparse irq leftoversThomas Gleixner
The move_irq_desc() function was only used due to the problem that the allocator did not free the old descriptors. So the descriptors had to be moved in create_irq_nr(). That's history. The code would have never been able to move active interrupt descriptors on affinity settings. That can be done in a completely different way w/o all this horror. Remove all of it. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Reviewed-by: Ingo Molnar <mingo@elte.hu>
2010-10-12genirq: Sanitize dynamic irq handlingThomas Gleixner
Use the cleanup functions of the dynamic allocator. No need to have separate implementations. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Reviewed-by: Ingo Molnar <mingo@elte.hu>
2010-10-12genirq: Remove arch_init_chip_data()Thomas Gleixner
This function should have not been there in the first place. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Reviewed-by: Ingo Molnar <mingo@elte.hu>
2010-10-12genirq: Query arch for number of early descriptorsThomas Gleixner
sparse irq sets up NR_IRQS_LEGACY irq descriptors and archs then go ahead and allocate more. Use the unused return value of arch_probe_nr_irqs() to let the architecture return the number of early allocations. Fix up all users. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Reviewed-by: Ingo Molnar <mingo@elte.hu>
2010-10-12genirq: Use sane sparse allocatorThomas Gleixner
Make irq_to_desc_alloc_node() a wrapper around the new allocator. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Reviewed-by: Ingo Molnar <mingo@elte.hu>
2010-10-12genirq: Implement irq reservationThomas Gleixner
Mark a range of interrupts as allocated. In the SPARSE_IRQ=n case we need this to update the bitmap for the legacy irqs so the enumerator via irq_get_next_irq() works. Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2010-10-12genirq: Implement sane enumerationThomas Gleixner
Use the allocator bitmap to lookup active interrupts. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Reviewed-by: Ingo Molnar <mingo@elte.hu>
2010-10-12genirq: Prepare proc for real sparse irq supportThomas Gleixner
/proc/irq never removes any entries, but when irq descriptors can be freed for real this is necessary. Otherwise we'd reference a freed descriptor in /proc/irq/N Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Reviewed-by: Ingo Molnar <mingo@elte.hu>
2010-10-12genirq: Implement a sane sparse_irq allocatorThomas Gleixner
The current sparse_irq allocator has several short comings due to failures in the design or the lack of it: - Requires iteration over the number of active irqs to find a free slot (Some architectures have grown their own workarounds for this) - Removal of entries is not possible - Racy between create_irq_nr and destroy_irq (plugged by horrible callbacks) - Migration of active irq descriptors is not possible - No bulk allocation of irq ranges - Sprinkeled irq_desc references all over the place outside of kernel/irq/ (The previous chip functions series is addressing this issue) Implement a sane allocator which fixes the above short comings (though migration of active descriptors needs a full tree wide cleanup of the direct and mostly unlocked access to irq_desc). The new allocator still uses a radix_tree, but uses a bitmap for keeping track of allocated irq numbers. That allows: - Fast lookup of a free slot - Allows the removal of descriptors - Prevents the create/destroy race - Bulk allocation of consecutive irq ranges - Basic design is ready for migration of life descriptors after further cleanups The bitmap is also used in the SPARSE_IRQ=n case for lookup and raceless (de)allocation of irq numbers. So it removes the requirement for looping through the descriptor array to find slots. Right now it uses sparse_irq_lock to protect the bitmap and the radix tree, but after cleaning up all users we should be able convert that to a mutex and to switch the radix_tree and decriptor allocations to GFP_KERNEL. [ Folded in a bugfix from Yinghai Lu ] Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Reviewed-by: Ingo Molnar <mingo@elte.hu>
2010-10-12genirq: Provide default irq init flagsThomas Gleixner
Arch code sets it's own irq_desc.status flags right after boot and for dynamically allocated interrupts. That might involve iterating over a huge array. Allow ARCH_IRQ_INIT_FLAGS to set separate flags aside of IRQ_DISABLED which is the default. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Reviewed-by: Ingo Molnar <mingo@elte.hu>
2010-10-12genirq: Remove export of kstat_irqs_cpuThomas Gleixner
The statistics accessor is only used by proc/stats and show_interrupts(). Both are compiled in. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Reviewed-by: Ingo Molnar <mingo@elte.hu>
2010-10-12genirq: Remove early_init_irq_lock_class()Thomas Gleixner
early_init_irq_lock_class() is called way before anything touches the irq descriptors. In case of SPARSE_IRQ=y this is a NOP operation because the radix tree is empty at this point. For the SPARSE_IRQ=n case it's sufficient to set the lock class in early_init_irq(). Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Reviewed-by: Ingo Molnar <mingo@elte.hu>
2010-10-12genirq: Distangle kernel/irq/handle.cThomas Gleixner
kernel/irq/handle.c has become a dumpground for random code in random order. Split out the irq descriptor management and the dummy irq_chip implementation into separate files. Cleanup the include maze while at it. No code change. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Reviewed-by: Ingo Molnar <mingo@elte.hu>
2010-10-12genirq: Sanitize irq_data accessorsThomas Gleixner
Get the data structure from the core and provide inline wrappers to access the irq_data members. Provide accessor inlines for irq_data as well. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Reviewed-by: Ingo Molnar <mingo@elte.hu>
2010-10-12genirq: Provide status modifierThomas Gleixner
Provide a irq_desc.status modifier function to cleanup the direct access to irq_desc in arch and driver code. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Reviewed-by: Ingo Molnar <mingo@elte.hu>
2010-10-12genirq: Distangle irq.hThomas Gleixner
Move irq_desc and internal functions out of irq.h Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Reviewed-by: Ingo Molnar <mingo@elte.hu>
2010-10-04genirq: Provide config option to disable deprecated codeThomas Gleixner
This option covers now the old chip functions and the irq_desc data fields which are moving to struct irq_data. More stuff will follow. Pretty handy for testing a conversion, whether something broke or not. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Reviewed-by: Ingo Molnar <mingo@elte.hu>
2010-10-04genirq: Provide compat handling for chip->retrigger()Thomas Gleixner
Wrap the old chip function retrigger() until the migration is complete and the old chip functions are removed. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Peter Zijlstra <peterz@infradead.org> LKML-Reference: <20100927121843.025801092@linutronix.de> Reviewed-by: H. Peter Anvin <hpa@zytor.com> Reviewed-by: Ingo Molnar <mingo@elte.hu>
2010-10-04genirq: Provide compat handling for chip->set_wake()Thomas Gleixner
Wrap the old chip function set_wake() until the migration is complete and the old chip functions are removed. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Peter Zijlstra <peterz@infradead.org> LKML-Reference: <20100927121842.927527393@linutronix.de> Reviewed-by: H. Peter Anvin <hpa@zytor.com> Reviewed-by: Ingo Molnar <mingo@elte.hu>
2010-10-04genirq: Provide compat handling for chip->set_type()Thomas Gleixner
Wrap the old chip function set_type() until the migration is complete and the old chip functions are removed. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Peter Zijlstra <peterz@infradead.org> LKML-Reference: <20100927121842.832261548@linutronix.de> Reviewed-by: H. Peter Anvin <hpa@zytor.com> Reviewed-by: Ingo Molnar <mingo@elte.hu>
2010-10-04genirq: Provide compat handling for chip->set_affinity()Thomas Gleixner
Wrap the old chip function set_affinity() until the migration is complete and the old chip functions are removed. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Peter Zijlstra <peterz@infradead.org> LKML-Reference: <20100927121842.732894108@linutronix.de> Reviewed-by: H. Peter Anvin <hpa@zytor.com> Reviewed-by: Ingo Molnar <mingo@elte.hu>
2010-10-04genirq: Provide compat handling for chip->startup()Thomas Gleixner
Wrap the old chip function startup() until the migration is complete and the old chip functions are removed. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Peter Zijlstra <peterz@infradead.org> LKML-Reference: <20100927121842.635152961@linutronix.de> Reviewed-by: H. Peter Anvin <hpa@zytor.com> Reviewed-by: Ingo Molnar <mingo@elte.hu>
2010-10-04genirq: Provide compat handling for chip->disable()/shutdown()Thomas Gleixner
Wrap the old chip functions disable() and shutdown() until the migration is complete and the old chip functions are removed. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Peter Zijlstra <peterz@infradead.org> LKML-Reference: <20100927121842.532070631@linutronix.de> Reviewed-by: H. Peter Anvin <hpa@zytor.com> Reviewed-by: Ingo Molnar <mingo@elte.hu>
2010-10-04genirq: Provide compat handling for chip->enable()Thomas Gleixner
Wrap the old chip function enable() until the migration is complete and the old chip functions are removed. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Peter Zijlstra <peterz@infradead.org> LKML-Reference: <20100927121842.437159182@linutronix.de> Reviewed-by: H. Peter Anvin <hpa@zytor.com> Reviewed-by: Ingo Molnar <mingo@elte.hu>
2010-10-04genirq: Provide compat handling for chip->eoi()Thomas Gleixner
Wrap the old chip function eoi() until the migration is complete and the old chip functions are removed. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Peter Zijlstra <peterz@infradead.org> LKML-Reference: <20100927121842.339657617@linutronix.de> Reviewed-by: H. Peter Anvin <hpa@zytor.com> Reviewed-by: Ingo Molnar <mingo@elte.hu>
2010-10-04genirq: Provide compat handling for chip->mask_ack()Thomas Gleixner
Wrap the old chip function mask_ack() until the migration is complete and the old chip functions are removed. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Peter Zijlstra <peterz@infradead.org> LKML-Reference: <20100927121842.240806983@linutronix.de> Reviewed-by: H. Peter Anvin <hpa@zytor.com> Reviewed-by: Ingo Molnar <mingo@elte.hu>
2010-10-04genirq: Provide compat handling for chip->ack()Thomas Gleixner
Wrap the old chip function ack() until the migration is complete and the old chip functions are removed. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Peter Zijlstra <peterz@infradead.org> LKML-Reference: <20100927121842.142624725@linutronix.de> Reviewed-by: H. Peter Anvin <hpa@zytor.com> Reviewed-by: Ingo Molnar <mingo@elte.hu>
2010-10-04genirq: Provide compat handling for chip->unmask()Thomas Gleixner
Wrap the old chip function unmask() until the migration is complete and the old chip functions are removed. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Peter Zijlstra <peterz@infradead.org> LKML-Reference: <20100927121842.043608928@linutronix.de> Reviewed-by: H. Peter Anvin <hpa@zytor.com> Reviewed-by: Ingo Molnar <mingo@elte.hu>
2010-10-04genirq: Provide compat handling for chip->mask()Thomas Gleixner
Wrap the old chip function mask() until the migration is complete and the old chip functions are removed. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Peter Zijlstra <peterz@infradead.org> LKML-Reference: <20100927121841.940355859@linutronix.de> Reviewed-by: H. Peter Anvin <hpa@zytor.com> Reviewed-by: Ingo Molnar <mingo@elte.hu>
2010-10-04genirq: Provide compat handling for bus_lock/bus_sync_unlockThomas Gleixner
Wrap the old chip functions for bus_lock/bus_sync_unlock until the migration is complete and the old chip functions are removed. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Peter Zijlstra <peterz@infradead.org> LKML-Reference: <20100927121841.842536121@linutronix.de> Reviewed-by: H. Peter Anvin <hpa@zytor.com> Reviewed-by: Ingo Molnar <mingo@elte.hu>
2010-10-04genirq: Add new functions to dummy chipsThomas Gleixner
The compat functions go away when the core code is converted. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Reviewed-by: Ingo Molnar <mingo@elte.hu>
2010-10-04genirq: Convert core code to irq_dataThomas Gleixner
Convert all references in the core code to orq, chip, handler_data, chip_data, msi_desc, affinity to irq_data.* Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Reviewed-by: Ingo Molnar <mingo@elte.hu>
2010-10-04genirq: Create irq_dataThomas Gleixner
Low level chip functions need access to irq_desc->handler_data, irq_desc->chip_data and irq_desc->msi_desc. We hand down the irq number to the low level functions, so they need to lookup irq_desc. With sparse irq this means a radix tree lookup. We could hand down irq_desc itself, but low level chip functions have no need to fiddle with it directly and we want to restrict access to irq_desc further. Preparatory patch for new chip functions. Note, that the ugly anon union/struct is there to avoid a full tree wide clean up for now. This is not going to last 3 years like __do_IRQ() Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Peter Zijlstra <peterz@infradead.org> LKML-Reference: <20100927121841.645542300@linutronix.de> Reviewed-by: H. Peter Anvin <hpa@zytor.com> Reviewed-by: Ingo Molnar <mingo@elte.hu>
2010-10-04genirq: Provide KconfigThomas Gleixner
The generic irq Kconfig options are copied around all archs. Provide a generic Kconfig file which can be included. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Peter Zijlstra <peterz@infradead.org> LKML-Reference: <20100927121843.217333624@linutronix.de> Reviewed-by: H. Peter Anvin <hpa@zytor.com> Reviewed-by: Ingo Molnar <mingo@elte.hu>
2010-09-23genirq: Cleanup irq_chip->typename leftoversThomas Gleixner
3 years transition phase is enough. Cleanup the last users and remove the cruft. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Leo Chen <leochen@broadcom.com> Cc: Hirokazu Takata <takata@linux-m32r.org> Cc: Chris Metcalf <cmetcalf@tilera.com> Cc: Jeff Dike <jdike@addtoit.com> Cc: Chris Zankel <chris@zankel.net>
2010-07-29irq: Add new IRQ flag IRQF_NO_SUSPENDIan Campbell
A small number of users of IRQF_TIMER are using it for the implied no suspend behaviour on interrupts which are not timer interrupts. Therefore add a new IRQF_NO_SUSPEND flag, rename IRQF_TIMER to __IRQF_TIMER and redefine IRQF_TIMER in terms of these new flags. Signed-off-by: Ian Campbell <ian.campbell@citrix.com> Cc: Jeremy Fitzhardinge <jeremy@goop.org> Cc: Dmitry Torokhov <dmitry.torokhov@gmail.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Grant Likely <grant.likely@secretlab.ca> Cc: xen-devel@lists.xensource.com Cc: linux-input@vger.kernel.org Cc: linuxppc-dev@ozlabs.org Cc: devicetree-discuss@lists.ozlabs.org LKML-Reference: <1280398595-29708-1-git-send-email-ian.campbell@citrix.com> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
