path: root/kernel/irq_work.c
2010-12-18irq_work: Use per cpu atomics instead of regular atomicsChristoph Lameter
The irq work queue is a per cpu object and it is sufficient for synchronization if per cpu atomics are used. Doing so simplifies the code and reduces the overhead of the code. Before: christoph@linux-2.6$ size kernel/irq_work.o text data bss dec hex filename 451 8 1 460 1cc kernel/irq_work.o After: christoph@linux-2.6$ size kernel/irq_work.o text data bss dec hex filename 438 8 1 447 1bf kernel/irq_work.o Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Christoph Lameter <cl@linux.com>
2010-11-18irq_work: Drop cmpxchg() resultSergio Aguirre
The compiler warned us about: kernel/irq_work.c: In function 'irq_work_run': kernel/irq_work.c:148: warning: value computed is not used Dropping the cmpxchg() result is indeed weird, but correct - so annotate away the warning. Signed-off-by: Sergio Aguirre <saaguirre@ti.com> Cc: Huang Ying <ying.huang@intel.com> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Kyle McMartin <kyle@mcmartin.ca> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> LKML-Reference: <1289930567-17828-1-git-send-email-saaguirre@ti.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-10-18irq_work: Add generic hardirq context callbacksPeter Zijlstra
Provide a mechanism that allows running code in IRQ context. It is most useful for NMI code that needs to interact with the rest of the system -- like wakeup a task to drain buffers. Perf currently has such a mechanism, so extract that and provide it as a generic feature, independent of perf so that others may also benefit. The IRQ context callback is generated through self-IPIs where possible, or on architectures like powerpc the decrementer (the built-in timer facility) is set to generate an interrupt immediately. Architectures that don't have anything like this get to do with a callback from the timer tick. These architectures can call irq_work_run() at the tail of any IRQ handlers that might enqueue such work (like the perf IRQ handler) to avoid undue latencies in processing the work. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Acked-by: Kyle McMartin <kyle@mcmartin.ca> Acked-by: Martin Schwidefsky <schwidefsky@de.ibm.com> [ various fixes ] Signed-off-by: Huang Ying <ying.huang@intel.com> LKML-Reference: <1287036094.7768.291.camel@yhuang-dev> Signed-off-by: Ingo Molnar <mingo@elte.hu>
