path: root/kernel/kexec.c
2012-10-06kdump: remove unneeded includeWei Yongjun
The inclusion of <generated/utsrelease.h> is unnecessary. Signed-off-by: Wei Yongjun <yongjun_wei@trendmicro.com.cn> Reviewed-by: Simon Horman <horms@verge.net.au> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-07-30kdump: append newline to the last lien of vmcoreinfo noteVivek Goyal
The last line of vmcoreinfo note does not end with \n. Parsing all the lines in note becomes easier if all lines end with \n instead of trying to special case the last line. I know at least one tool, vmcore-dmesg in kexec-tools tree which made the assumption that all lines end with \n. I think it is a good idea to fix it. Signed-off-by: Vivek Goyal <vgoyal@redhat.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Atsushi Kumagai <kumagai-atsushi@mxc.nes.nec.co.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-03-28Merge branch 'akpm' (Andrew's patch-bomb)Linus Torvalds
Merge third batch of patches from Andrew Morton: - Some MM stragglers - core SMP library cleanups (on_each_cpu_mask) - Some IPI optimisations - kexec - kdump - IPMI - the radix-tree iterator work - various other misc bits. "That'll do for -rc1. I still have ~10 patches for 3.4, will send those along when they've baked a little more." * emailed from Andrew Morton <akpm@linux-foundation.org>: (35 commits) backlight: fix typo in tosa_lcd.c crc32: add help text for the algorithm select option mm: move hugepage test examples to tools/testing/selftests/vm mm: move slabinfo.c to tools/vm mm: move page-types.c from Documentation to tools/vm selftests/Makefile: make `run_tests' depend on `all' selftests: launch individual selftests from the main Makefile radix-tree: use iterators in find_get_pages* functions radix-tree: rewrite gang lookup using iterator radix-tree: introduce bit-optimized iterator fs/proc/namespaces.c: prevent crash when ns_entries[] is empty nbd: rename the nbd_device variable from lo to nbd pidns: add reboot_pid_ns() to handle the reboot syscall sysctl: use bitmap library functions ipmi: use locks on watchdog timeout set on reboot ipmi: simplify locking ipmi: fix message handling during panics ipmi: use a tasklet for handling received messages ipmi: increase KCS timeouts ipmi: decrease the IPMI message transaction time in interrupt mode ...
2012-03-28kexec: add further check to crashkernelZhenzhong Duan
When using crashkernel=2M-256M, the kernel doesn't give any warning. This is misleading sometimes. Signed-off-by: Zhenzhong Duan <zhenzhong.duan@oracle.com> Acked-by: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-03-28kexec: crash: don't save swapper_pg_dir for !CONFIG_MMU configurationsWill Deacon
nommu platforms don't have very interesting swapper_pg_dir pointers and usually just #define them to NULL, meaning that we can't include them in the vmcoreinfo on the kexec crash path. This patch only saves the swapper_pg_dir if we have an MMU. Signed-off-by: Will Deacon <will.deacon@arm.com> Reviewed-by: Simon Horman <horms@verge.net.au> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-03-28Remove all #inclusions of asm/system.hDavid Howells
Remove all #inclusions of asm/system.h preparatory to splitting and killing it. Performed with the following command: perl -p -i -e 's!^#\s*include\s*<asm/system[.]h>.*\n!!' `grep -Irl '^#\s*include\s*<asm/system[.]h>' *` Signed-off-by: David Howells <dhowells@redhat.com>
2012-01-29PM / Sleep: Introduce "late suspend" and "early resume" of devicesRafael J. Wysocki
The current device suspend/resume phases during system-wide power transitions appear to be insufficient for some platforms that want to use the same callback routines for saving device states and related operations during runtime suspend/resume as well as during system suspend/resume. In principle, they could point their .suspend_noirq() and .resume_noirq() to the same callback routines as their .runtime_suspend() and .runtime_resume(), respectively, but at least some of them require device interrupts to be enabled while the code in those routines is running. It also makes sense to have device suspend-resume callbacks that will be executed with runtime PM disabled and with device interrupts enabled in case someone needs to run some special code in that context during system-wide power transitions. Apart from this, .suspend_noirq() and .resume_noirq() were introduced as a workaround for drivers using shared interrupts and failing to prevent their interrupt handlers from accessing suspended hardware. It appears to be better not to use them for other porposes, or we may have to deal with some serious confusion (which seems to be happening already). For the above reasons, introduce new device suspend/resume phases, "late suspend" and "early resume" (and analogously for hibernation) whose callback will be executed with runtime PM disabled and with device interrupts enabled and whose callback pointers generally may point to runtime suspend/resume routines. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Reviewed-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Reviewed-by: Kevin Hilman <khilman@ti.com>
2012-01-12kdump: crashk_res init check for /sys/kernel/kexec_crash_sizeMichael Holzheu
Currently it is possible to set the crash_size via the sysfs /sys/kernel/kexec_crash_size even if no crash kernel memory has been defined with the "crashkernel" parameter. In this case "crashk_res" is not initialized and crashk_res.start = crashk_res.end = 0. Unfortunately resource_size(&crashk_res) returns 1 in this case. This breaks the s390 implementation of crash_(un)map_reserved_pages(). To fix the problem the correct "old_size" is now calculated in crash_shrink_memory(). "old_size is set to "0" if crashk_res is not initialized. With this change crash_shrink_memory() will do nothing, when "crashk_res" is not initialized. It will return "0" for "echo 0 > /sys/kernel/kexec_crash_size" and -EINVAL for "echo [not zero] > /sys/kernel/kexec_crash_size". In addition to that this patch also simplifies the "ret = -EINVAL" vs. "ret = 0" logic as suggested by Simon Horman. Signed-off-by: Michael Holzheu <holzheu@linux.vnet.ibm.com> Reviewed-by: Dave Young <dyoung@redhat.com> Reviewed-by: WANG Cong <xiyou.wangcong@gmail.com> Reviewed-by: Simon Horman <horms@verge.net.au> Cc: Vivek Goyal <vgoyal@redhat.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-01-12kdump: add missing RAM resource in crash_shrink_memory()Michael Holzheu
When shrinking crashkernel memory using /sys/kernel/kexec_crash_size for the newly added memory no RAM resource is created at the moment. Example: $ cat /proc/iomem 00000000-bfffffff : System RAM 00000000-005b7ac3 : Kernel code 005b7ac4-009743bf : Kernel data 009bb000-00a85c33 : Kernel bss c0000000-cfffffff : Crash kernel d0000000-ffffffff : System RAM $ echo 0 > /sys/kernel/kexec_crash_size $ cat /proc/iomem 00000000-bfffffff : System RAM 00000000-005b7ac3 : Kernel code 005b7ac4-009743bf : Kernel data 009bb000-00a85c33 : Kernel bss <<-- here is System RAM missing d0000000-ffffffff : System RAM One result of this bug is that the memory chunk can never be set offline using memory hotplug. With this patch I insert a new "System RAM" resource for the released memory. Then the upper example looks like the following: $ echo 0 > /sys/kernel/kexec_crash_size $ cat /proc/iomem 00000000-bfffffff : System RAM 00000000-005b7ac3 : Kernel code 005b7ac4-009743bf : Kernel data 009bb000-00a85c33 : Kernel bss c0000000-cfffffff : System RAM <<-- new rescoure d0000000-ffffffff : System RAM And now I can set chunk c0000000-cfffffff offline. Signed-off-by: Michael Holzheu <holzheu@linux.vnet.ibm.com> Cc: Vivek Goyal <vgoyal@redhat.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-01-12kexec: remove KMSG_DUMP_KEXECWANG Cong
KMSG_DUMP_KEXEC is useless because we already save kernel messages inside /proc/vmcore, and it is unsafe to allow modules to do other stuffs in a crash dump scenario. [akpm@linux-foundation.org: fix powerpc build] Signed-off-by: WANG Cong <xiyou.wangcong@gmail.com> Reported-by: Vivek Goyal <vgoyal@redhat.com> Acked-by: Vivek Goyal <vgoyal@redhat.com> Acked-by: Jarod Wilson <jarod@redhat.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-12-08PM / Sleep: Replace mutex_[un]lock(&pm_mutex) with [un]lock_system_sleep()Srivatsa S. Bhat
Using [un]lock_system_sleep() is safer than directly using mutex_[un]lock() on 'pm_mutex', since the latter could lead to freezing failures. Hence convert all the present users of mutex_[un]lock(&pm_mutex) to use these safe APIs instead. Suggested-by: Tejun Heo <tj@kernel.org> Signed-off-by: Srivatsa S. Bhat <srivatsa.bhat@linux.vnet.ibm.com> Reviewed-by: Simon Horman <horms@verge.net.au> Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl>
2011-10-30[S390] kdump: Add infrastructure for unmapping crashkernel memoryMichael Holzheu
This patch introduces a mechanism that allows architecture backends to remove page tables for the crashkernel memory. This can protect the loaded kdump kernel from being overwritten by broken kernel code. Two new functions crash_map_reserved_pages() and crash_unmap_reserved_pages() are added that can be implemented by architecture code. The crash_map_reserved_pages() function is called before and crash_unmap_reserved_pages() after the crashkernel segments are loaded. The functions are also called in crash_shrink_memory() to create/remove page tables when the crashkernel memory size is reduced. To support architectures that have large pages this patch also introduces a new define KEXEC_CRASH_MEM_ALIGN. The crashkernel start and size must always be aligned with KEXEC_CRASH_MEM_ALIGN. Cc: Andrew Morton <akpm@linux-foundation.org> Acked-by: Vivek Goyal <vgoyal@redhat.com> Signed-off-by: Michael Holzheu <holzheu@linux.vnet.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2011-10-30[S390] kdump: Initialize vmcoreinfo note at startupMichael Holzheu
Currently the vmcoreinfo note is only initialized in case of kdump. On s390 it is possible to create kernel dumps with other dump mechanisms than kdump (e.g. via hypervisor dump or stand-alone dump tools). For those dumps it would also be desirable to include the vmcoreinfo data. To accomplish this, with this patch the vmcoreinfo ELF note is always initialized, not only in case of a (kdump) crash. On s390 we will add an ABI defined pointer at a well known address to vmcoreinfo so that dump analysis tools are able to find this information. In particular on s390 we have a tool named zgetdump. With this tool it is possible to convert dump formats on the fly using fuse. E.g. you can mount a s390 stand-alone dump as ELF dump. When this is done, the tool finds the vmcoreinfo in the stand-alone dump via the well known ABI defined address and it creates the respective VMCOREINFO ELF note in the output ELF dump. This then can be used e.g. by makedumpfile for dump filtering. No more need for a vmlinux file with debug information. So this will look like the following: $ zgetdump --mount standalone.dump -f elf /mnt $ ls /mnt dump.elf $ readelf -n /mnt/dump.elf $ ... VMCOREINFO 0x00000474 Unknown note type: (0x00000000) $ makedumpfile -c -d 31 /mnt/dump.elf dump.kdump Cc: Andrew Morton <akpm@linux-foundation.org> Acked-by: Vivek Goyal <vgoyal@redhat.com> Signed-off-by: Michael Holzheu <holzheu@linux.vnet.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2011-10-30[S390] kdump: Add KEXEC_CRASH_CONTROL_MEMORY_LIMITMichael Holzheu
On s390 there is a different KEXEC_CONTROL_MEMORY_LIMIT for the normal and the kdump kexec case. Therefore this patch introduces a new macro KEXEC_CRASH_CONTROL_MEMORY_LIMIT. This is set to KEXEC_CONTROL_MEMORY_LIMIT for all architectures that do not define KEXEC_CRASH_CONTROL_MEMORY_LIMIT. Acked-by: Vivek Goyal <vgoyal@redhat.com> Acked-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Michael Holzheu <holzheu@linux.vnet.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2011-06-10treewide: Convert uses of struct resource to resource_size(ptr)Joe Perches
Several fixes as well where the +1 was missing. Done via coccinelle scripts like: @@ struct resource *ptr; @@ - ptr->end - ptr->start + 1 + resource_size(ptr) and some grep and typing. Mostly uncompiled, no cross-compilers. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2011-05-11PM: Remove sysdev suspend, resume and shutdown operationsRafael J. Wysocki
Since suspend, resume and shutdown operations in struct sysdev_class and struct sysdev_driver are not used any more, remove them. Also drop sysdev_suspend(), sysdev_resume() and sysdev_shutdown() used for executing those operations and modify all of their users accordingly. This reduces kernel code size quite a bit and reduces its complexity. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Acked-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-04-20PM: Add missing syscore_suspend() and syscore_resume() callsRafael J. Wysocki
Device suspend/resume infrastructure is used not only by the suspend and hibernate code in kernel/power, but also by APM, Xen and the kexec jump feature. However, commit 40dc166cb5dddbd36aa4ad11c03915ea (PM / Core: Introduce struct syscore_ops for core subsystems PM) failed to add syscore_suspend() and syscore_resume() calls to that code, which generally leads to breakage when the features in question are used. To fix this problem, add the missing syscore_suspend() and syscore_resume() calls to arch/x86/kernel/apm_32.c, kernel/kexec.c and drivers/xen/manage.c. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Acked-by: Greg Kroah-Hartman <gregkh@suse.de> Acked-by: Ian Campbell <ian.campbell@citrix.com>
2011-04-07Merge branch 'for-linus2' of git://git.profusion.mobi/users/lucas/linux-2.6Linus Torvalds
* 'for-linus2' of git://git.profusion.mobi/users/lucas/linux-2.6: Fix common misspellings
2011-04-01kdump: Allow shrinking of kdump region to be overriddenAnton Blanchard
On ppc64 the crashkernel region almost always overlaps an area of firmware. This works fine except when using the sysfs interface to reduce the kdump region. If we free the firmware area we are guaranteed to crash. Rename free_reserved_phys_range to crash_free_reserved_phys_range and make it a weak function so we can override it. Signed-off-by: Anton Blanchard <anton@samba.org> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2010-11-01tree-wide: fix comment/printk typosUwe Kleine-König
"gadget", "through", "command", "maintain", "maintain", "controller", "address", "between", "initiali[zs]e", "instead", "function", "select", "already", "equal", "access", "management", "hierarchy", "registration", "interest", "relative", "memory", "offset", "already", Signed-off-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2010-10-26use clear_page()/copy_page() in favor of memset()/memcpy() on whole pagesJan Beulich
After all that's what they are intended for. Signed-off-by: Jan Beulich <jbeulich@novell.com> Cc: Miklos Szeredi <miklos@szeredi.hu> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: "Rafael J. Wysocki" <rjw@sisk.pl> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-08-11kexec: return -EFAULT on copy_to_user() failuresDan Carpenter
copy_to/from_user() returns the number of bytes remaining to be copied. It never returns a negative value. The correct return code is -EFAULT and not -EIO. All the callers check for non-zero returns so that's Ok, but the return code is passed to the user so we should fix this. Signed-off-by: Dan Carpenter <error27@gmail.com> Cc: Hidetoshi Seto <seto.hidetoshi@jp.fujitsu.com> Cc: "Paul E. McKenney" <paulmck@linux.vnet.ibm.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Simon Kagstrom <simon.kagstrom@netinsight.net> Acked-by: WANG Cong <xiyou.wangcong@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-06-29kexec: fix Oops in crash_shrink_memory()Pavan Naregundi
When crashkernel is not enabled, "echo 0 > /sys/kernel/kexec_crash_size" OOPSes the kernel in crash_shrink_memory. This happens when crash_shrink_memory tries to release the 'crashk_res' resource which are not reserved. Also value of "/sys/kernel/kexec_crash_size" shows as 1, which should be 0. This patch fixes the OOPS in crash_shrink_memory and shows "/sys/kernel/kexec_crash_size" as 0 when crash kernel memory is not reserved. Signed-off-by: Pavan Naregundi <pavan@linux.vnet.ibm.com> Reviewed-by: WANG Cong <xiyou.wangcong@gmail.com> Cc: Simon Horman <horms@verge.net.au> Cc: Vivek Goyal <vgoyal@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-05-11kexec: fix OOPS in crash_kernel_shrinkVitaly Mayatskikh
Two "echo 0 > /sys/kernel/kexec_crash_size" OOPSes kernel. Also content of this file is invalid after first shrink to zero: it shows 1 instead of 0. This scenario is unlikely to happen often (root privs, valid crashkernel= in cmdline, dump-capture kernel not loaded), I hit it only by chance. This patch fixes it. Signed-off-by: Vitaly Mayatskikh <v.mayatskih@gmail.com> Cc: Cong Wang <amwang@redhat.com> Cc: Neil Horman <nhorman@tuxdriver.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-02-17percpu: add __percpu sparse annotations to core kernel subsystemsTejun Heo
Add __percpu sparse annotations to core subsystems. These annotations are to make sparse consider percpu variables to be in a different address space and warn if accessed without going through percpu accessors. This patch doesn't affect normal builds. Signed-off-by: Tejun Heo <tj@kernel.org> Reviewed-by: Christoph Lameter <cl@linux-foundation.org> Acked-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: Jens Axboe <axboe@kernel.dk> Cc: linux-mm@kvack.org Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: Dipankar Sarma <dipankar@in.ibm.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Eric Biederman <ebiederm@xmission.com>
2010-01-24Merge git://git.infradead.org/~dwmw2/mtd-2.6.33Linus Torvalds
* git://git.infradead.org/~dwmw2/mtd-2.6.33: mtd: tests: fix read, speed and stress tests on NOR flash mtd: Really add ARM pismo support kmsg_dump: Dump on crash_kexec as well
2009-12-31kmsg_dump: Dump on crash_kexec as wellKOSAKI Motohiro
crash_kexec gets called before kmsg_dump(KMSG_DUMP_OOPS) if panic_on_oops is set, so the kernel log buffer is not stored for this case. This patch adds a KMSG_DUMP_KEXEC dump type which gets called when crash_kexec() is invoked. To avoid getting double dumps, the old KMSG_DUMP_PANIC is moved below crash_kexec(). The mtdoops driver is modified to handle KMSG_DUMP_KEXEC in the same way as a panic. Signed-off-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Acked-by: Simon Kagstrom <simon.kagstrom@netinsight.net> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2009-12-17Merge branch 'for-33' of git://repo.or.cz/linux-kbuildLinus Torvalds
* 'for-33' of git://repo.or.cz/linux-kbuild: (29 commits) net: fix for utsrelease.h moving to generated gen_init_cpio: fixed fwrite warning kbuild: fix make clean after mismerge kbuild: generate modules.builtin genksyms: properly consider EXPORT_UNUSED_SYMBOL{,_GPL}() score: add asm/asm-offsets.h wrapper unifdef: update to upstream revision 1.190 kbuild: specify absolute paths for cscope kbuild: create include/generated in silentoldconfig scripts/package: deb-pkg: use fakeroot if available scripts/package: add KBUILD_PKG_ROOTCMD variable scripts/package: tar-pkg: use tar --owner=root Kbuild: clean up marker net: add net_tstamp.h to headers_install kbuild: move utsrelease.h to include/generated kbuild: move autoconf.h to include/generated drop explicit include of autoconf.h kbuild: move compile.h to include/generated kbuild: drop include/asm kbuild: do not check for include/asm-$ARCH ... Fixed non-conflicting clean merge of modpost.c as per comments from Stephen Rothwell (modpost.c had grown an include of linux/autoconf.h that needed to be changed to generated/autoconf.h)
2009-12-16kexec: premit reduction of the reserved memory sizeAmerigo Wang
Implement shrinking the reserved memory for crash kernel, if it is more than enough. For example, if you have already reserved 128M, now you just want 100M, you can do: # echo $((100*1024*1024)) > /sys/kernel/kexec_crash_size Note, you can only do this before loading the crash kernel. Signed-off-by: WANG Cong <amwang@redhat.com> Cc: Neil Horman <nhorman@redhat.com> Acked-by: Eric W. Biederman <ebiederm@xmission.com> Cc: Andi Kleen <andi@firstfloor.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-12-12kbuild: move utsrelease.h to include/generatedSam Ravnborg
Fix up all users of utsrelease.h Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Michal Marek <mmarek@suse.cz>
2009-07-29kexec: fix omitting offset in extended crashkernel syntaxHidetoshi Seto
Setting "crashkernel=512M-2G:64M,2G-:128M" does not work but it turns to work if it has a trailing-whitespace, like "crashkernel=512M-2G:64M,2G-:128M ". It was because of a bug in the parser, running over the cmdline. This patch adds a check of the termination. Reported-by: Jin Dongming <jin.dongming@np.css.fujitsu.com> Signed-off-by: Hidetoshi Seto <seto.hidetoshi@jp.fujitsu.com> Tested-by: Jin Dongming <jin.dongming@np.css.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-12PM core: rename suspend and resume functionsAlan Stern
This patch (as1241) renames a bunch of functions in the PM core. Rather than go through a boring list of name changes, suffice it to say that in the end we have a bunch of pairs of functions: device_resume_noirq dpm_resume_noirq device_resume dpm_resume device_complete dpm_complete device_suspend_noirq dpm_suspend_noirq device_suspend dpm_suspend device_prepare dpm_prepare in which device_X does the X operation on a single device and dpm_X invokes device_X for all devices in the dpm_list. In addition, the old dpm_power_up and device_resume_noirq have been combined into a single function (dpm_resume_noirq). Lastly, dpm_suspend_start and dpm_resume_end are the renamed versions of the former top-level device_suspend and device_resume routines. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Acked-by: Magnus Damm <damm@igel.co.jp> Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl>
2009-06-12PM: Rename device_power_down/up()Magnus Damm
Rename the functions performing "_noirq" dev_pm_ops operations from device_power_down() and device_power_up() to device_suspend_noirq() and device_resume_noirq(). The new function names are chosen to show that the functions are responsible for calling the _noirq() versions to finalize the suspend/resume operation. The current function names do not perform power down/up anymore so the names may be misleading. Global function renames: - device_power_down() -> device_suspend_noirq() - device_power_up() -> device_resume_noirq() Static function renames: - suspend_device_noirq() -> __device_suspend_noirq() - resume_device_noirq() -> __device_resume_noirq() Signed-off-by: Magnus Damm <damm@igel.co.jp> Acked-by: Greg Kroah-Hartman <gregkh@suse.de> Acked-by: Len Brown <lenb@kernel.org> Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl>
2009-05-24PM: Do not hold dpm_list_mtx while disabling/enabling nonboot CPUsRafael J. Wysocki
We shouldn't hold dpm_list_mtx while executing [disable|enable]_nonboot_cpus(), because theoretically this may lead to a deadlock as shown by the following example (provided by Johannes Berg): CPU 3 CPU 2 CPU 1 suspend/hibernate something: rtnl_lock() device_pm_lock() -> mutex_lock(&dpm_list_mtx) mutex_lock(&dpm_list_mtx) linkwatch_work -> rtnl_lock() disable_nonboot_cpus() -> flush CPU 3 workqueue Fortunately, device drivers are supposed to stop any activities that might lead to the registration of new device objects way before disable_nonboot_cpus() is called, so it shouldn't be necessary to hold dpm_list_mtx over the entire late part of device suspend and early part of device resume. Thus, during the late suspend and the early resume of devices acquire dpm_list_mtx only when dpm_list is going to be traversed and release it right after that. This patch is reported to fix the regressions tracked as http://bugzilla.kernel.org/show_bug.cgi?id=13245. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Acked-by: Alan Stern <stern@rowland.harvard.edu> Reported-by: Miles Lane <miles.lane@gmail.com> Tested-by: Ming Lei <tom.leiming@gmail.com>
2009-04-02kexec: vmcoreinfo_data[] can become staticDmitri Vorobiev
The vmcoreinfo_data[] array is not used outside of kernel/kexec.c, and can therefore become static. This patch adds the relevant keyword to the definition of the array. Noticed by sparse. Signed-off-by: Dmitri Vorobiev <dmitri.vorobiev@movial.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-02kexec: add dmesg log symbols to /proc/vmcoreinfo listsNeil Horman
It would be nice to be able to extract the dmesg log from a vmcore file without needing to keep the debug symbols for the running kernel handy all the time. We have a facility to do this in /proc/vmcore. This patch adds the log_buf and log_end symbols to the vmcoreinfo area so that tools (like makedumpfile) can easily extract the dmesg logs from a vmcore image. [akpm@linux-foundation.org: several fixes and cleanups] [akpm@linux-foundation.org: fix unused log_buf_kexec_setup()] [akpm@linux-foundation.org: build fix] Signed-off-by: Neil Horman <nhorman@tuxdriver.com> Cc: Simon Horman <horms@verge.net.au> Acked-by: Vivek Goyal <vgoyal@redhat.com> Cc: Neil Horman <nhorman@tuxdriver.com> Cc: Simon Horman <horms@verge.net.au> Cc: Vivek Goyal <vgoyal@redhat.com> Cc: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-03-30kexec: Change kexec jump code orderingRafael J. Wysocki
Change the ordering of the kexec jump code so that the nonboot CPUs are disabled after calling device drivers' "late suspend" methods. This change reflects the recent modifications of the power management code that is also used by kexec jump. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Acked-by: Ingo Molnar <mingo@elte.hu>
2009-03-30PM: Rework handling of interrupts during suspend-resumeRafael J. Wysocki
Use the functions introduced in by the previous patch, suspend_device_irqs(), resume_device_irqs() and check_wakeup_irqs(), to rework the handling of interrupts during suspend (hibernation) and resume. Namely, interrupts will only be disabled on the CPU right before suspending sysdevs, while device drivers will be prevented from receiving interrupts, with the help of the new helper function, before their "late" suspend callbacks run (and analogously during resume). In addition, since the device interrups are now disabled before the CPU has turned all interrupts off and the CPU will ACK the interrupts setting the IRQ_PENDING bit for them, check in sysdev_suspend() if any wake-up interrupts are pending and abort suspend if that's the case. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Acked-by: Ingo Molnar <mingo@elte.hu>
2009-02-22Merge branch 'linus' into x86/apicIngo Molnar
Conflicts: arch/x86/mach-default/setup.c Semantic conflict resolution: arch/x86/kernel/setup.c Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-02-22PM: Split up sysdev_[suspend|resume] from device_power_[down|up]Rafael J. Wysocki
Move the sysdev_suspend/resume from the callee to the callers, with no real change in semantics, so that we can rework the disabling of interrupts during suspend/hibernation. This is based on an earlier patch from Linus. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-02-10elf: add ELF_CORE_COPY_KERNEL_REGS()Tejun Heo
ELF core dump is used for both user land core dump and kernel crash dump. Depending on architecture, register might need to be accessed differently for userland and kernel. Allow architectures to define ELF_CORE_COPY_KERNEL_REGS() and use different operation for kernel register dump. Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-01-14[CVE-2009-0029] System call wrappers part 07Heiko Carstens
2009-01-01cpumask: prepare for iterators to only go to nr_cpu_ids/nr_cpumask_bits.: coreRusty Russell
Impact: cleanup In future, all cpumask ops will only be valid (in general) for bit numbers < nr_cpu_ids. So use that instead of NR_CPUS in iterators and other comparisons. This is always safe: no cpu number can be >= nr_cpu_ids, and nr_cpu_ids is initialized to NR_CPUS at boot. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Mike Travis <travis@sgi.com> Acked-by: Ingo Molnar <mingo@elte.hu> Acked-by: James Morris <jmorris@namei.org> Cc: Eric Biederman <ebiederm@xmission.com>
2008-10-20kexec: fix crash_save_vmcoreinfo_init build problemLuck, Tony
This fixes kernel/kexec.c: In function 'crash_save_vmcoreinfo_init': kernel/kexec.c:1374: error: 'vmlist' undeclared (first use in this function) kernel/kexec.c:1374: error: (Each undeclared identifier is reported only once kernel/kexec.c:1374: error: for each function it appears in.) kernel/kexec.c:1410: error: invalid use of undefined type 'struct vm_struct' make[1]: *** [kernel/kexec.o] Error 1 Signed-off-by: Tony Luck <tony.luck@intel.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-20kdump: add vmlist.addr to vmcoreinfo for x86 vmalloc translation.Ken'ichi Ohmichi
Add the symbols 'vmlist' and offset 'vm_struct.addr' to the vmcoreinfo[1] data for i386 vmalloc translation. makedumpfile[2] needs VMALLOC_START value for distinguishing a vmalloc address or not, because it should choose suitable translation method. If applying this patch, makedumpfile will be able to take VMALLOC_START value from 'vmlist.addr'. vmcoreinfo[1]: The vmcoreinfo data has the minimum debugging information only for dump filtering. makedumpfile[2] uses it to distinguish unnecessary pages and creates a small dumpfile. makedumpfile[2]: dump filtering command https://sourceforge.net/projects/makedumpfile/ Signed-off-by: Ken'ichi Ohmichi <oomichi@mxs.nes.nec.co.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-09-23kexec: fix segmentation fault in kimage_add_entryJonathan Steel
A segmentation fault can occur in kimage_add_entry in kexec.c when loading a kernel image into memory. The fault occurs because a page is requested by calling kimage_alloc_page with gfp_mask GFP_KERNEL and the function may actually return a page with gfp_mask GFP_HIGHUSER. The high mem page is returned because it was swapped with the kernel page due to the kernel page being a page that will shortly be copied to. This patch ensures that kimage_alloc_page returns a page that was created with the correct gfp flags. I have verified the change and fixed the whitespace damage of the original patch. Jonathan did a great job of tracking this down after he hit the problem. -- Eric Signed-off-by: Jonathan Steel <jon.steel@esentire.com> Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Acked-by: Simon Horman <horms@verge.net.au> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-08-15kexec: use a mutex for locking rather than xchg()Andrew Morton
Functionally the same, but more conventional. Cc: Huang Ying <ying.huang@intel.com> Tested-by: Vivek Goyal <vgoyal@redhat.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-08-15kexec jump: fix for ftraceHuang Ying
Ftrace depends on some processor state that we destroyed during kexec and restored by restore_processor_state(). So save_processor_state() and restore_processor_state() are moved into machine_kexec() and ftrace is restored after restore_processor_state(). Signed-off-by: Huang Ying <ying.huang@intel.com> Cc: Pavel Machek <pavel@ucw.cz> Cc: "Rafael J. Wysocki" <rjw@sisk.pl> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Vivek Goyal <vgoyal@redhat.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Steven Rostedt <rostedt@goodmis.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-08-15kexec jump: in sync with hibernation implementationHuang Ying
Add device_pm_lock() and device_pm_unlock() in kernel_kexec() in sync with current hibernation implementation. Signed-off-by: Huang Ying <ying.huang@intel.com> Acked-by: Pavel Machek <pavel@ucw.cz> Cc: "Rafael J. Wysocki" <rjw@sisk.pl> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Vivek Goyal <vgoyal@redhat.com> Cc: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
