path: root/kernel/kexec.c
2011-10-30[S390] kdump: Add infrastructure for unmapping crashkernel memoryMichael Holzheu
This patch introduces a mechanism that allows architecture backends to remove page tables for the crashkernel memory. This can protect the loaded kdump kernel from being overwritten by broken kernel code. Two new functions crash_map_reserved_pages() and crash_unmap_reserved_pages() are added that can be implemented by architecture code. The crash_map_reserved_pages() function is called before and crash_unmap_reserved_pages() after the crashkernel segments are loaded. The functions are also called in crash_shrink_memory() to create/remove page tables when the crashkernel memory size is reduced. To support architectures that have large pages this patch also introduces a new define KEXEC_CRASH_MEM_ALIGN. The crashkernel start and size must always be aligned with KEXEC_CRASH_MEM_ALIGN. Cc: Andrew Morton <akpm@linux-foundation.org> Acked-by: Vivek Goyal <vgoyal@redhat.com> Signed-off-by: Michael Holzheu <holzheu@linux.vnet.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2011-10-30[S390] kdump: Initialize vmcoreinfo note at startupMichael Holzheu
Currently the vmcoreinfo note is only initialized in case of kdump. On s390 it is possible to create kernel dumps with other dump mechanisms than kdump (e.g. via hypervisor dump or stand-alone dump tools). For those dumps it would also be desirable to include the vmcoreinfo data. To accomplish this, with this patch the vmcoreinfo ELF note is always initialized, not only in case of a (kdump) crash. On s390 we will add an ABI defined pointer at a well known address to vmcoreinfo so that dump analysis tools are able to find this information. In particular on s390 we have a tool named zgetdump. With this tool it is possible to convert dump formats on the fly using fuse. E.g. you can mount a s390 stand-alone dump as ELF dump. When this is done, the tool finds the vmcoreinfo in the stand-alone dump via the well known ABI defined address and it creates the respective VMCOREINFO ELF note in the output ELF dump. This then can be used e.g. by makedumpfile for dump filtering. No more need for a vmlinux file with debug information. So this will look like the following: $ zgetdump --mount standalone.dump -f elf /mnt $ ls /mnt dump.elf $ readelf -n /mnt/dump.elf $ ... VMCOREINFO 0x00000474 Unknown note type: (0x00000000) $ makedumpfile -c -d 31 /mnt/dump.elf dump.kdump Cc: Andrew Morton <akpm@linux-foundation.org> Acked-by: Vivek Goyal <vgoyal@redhat.com> Signed-off-by: Michael Holzheu <holzheu@linux.vnet.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2011-10-30[S390] kdump: Add KEXEC_CRASH_CONTROL_MEMORY_LIMITMichael Holzheu
On s390 there is a different KEXEC_CONTROL_MEMORY_LIMIT for the normal and the kdump kexec case. Therefore this patch introduces a new macro KEXEC_CRASH_CONTROL_MEMORY_LIMIT. This is set to KEXEC_CONTROL_MEMORY_LIMIT for all architectures that do not define KEXEC_CRASH_CONTROL_MEMORY_LIMIT. Acked-by: Vivek Goyal <vgoyal@redhat.com> Acked-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Michael Holzheu <holzheu@linux.vnet.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2011-06-10treewide: Convert uses of struct resource to resource_size(ptr)Joe Perches
Several fixes as well where the +1 was missing. Done via coccinelle scripts like: @@ struct resource *ptr; @@ - ptr->end - ptr->start + 1 + resource_size(ptr) and some grep and typing. Mostly uncompiled, no cross-compilers. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2011-05-11PM: Remove sysdev suspend, resume and shutdown operationsRafael J. Wysocki
Since suspend, resume and shutdown operations in struct sysdev_class and struct sysdev_driver are not used any more, remove them. Also drop sysdev_suspend(), sysdev_resume() and sysdev_shutdown() used for executing those operations and modify all of their users accordingly. This reduces kernel code size quite a bit and reduces its complexity. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Acked-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-04-20PM: Add missing syscore_suspend() and syscore_resume() callsRafael J. Wysocki
Device suspend/resume infrastructure is used not only by the suspend and hibernate code in kernel/power, but also by APM, Xen and the kexec jump feature. However, commit 40dc166cb5dddbd36aa4ad11c03915ea (PM / Core: Introduce struct syscore_ops for core subsystems PM) failed to add syscore_suspend() and syscore_resume() calls to that code, which generally leads to breakage when the features in question are used. To fix this problem, add the missing syscore_suspend() and syscore_resume() calls to arch/x86/kernel/apm_32.c, kernel/kexec.c and drivers/xen/manage.c. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Acked-by: Greg Kroah-Hartman <gregkh@suse.de> Acked-by: Ian Campbell <ian.campbell@citrix.com>
2011-04-07Merge branch 'for-linus2' of git://git.profusion.mobi/users/lucas/linux-2.6Linus Torvalds
* 'for-linus2' of git://git.profusion.mobi/users/lucas/linux-2.6: Fix common misspellings
2011-04-01kdump: Allow shrinking of kdump region to be overriddenAnton Blanchard
On ppc64 the crashkernel region almost always overlaps an area of firmware. This works fine except when using the sysfs interface to reduce the kdump region. If we free the firmware area we are guaranteed to crash. Rename free_reserved_phys_range to crash_free_reserved_phys_range and make it a weak function so we can override it. Signed-off-by: Anton Blanchard <anton@samba.org> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2010-11-01tree-wide: fix comment/printk typosUwe Kleine-König
"gadget", "through", "command", "maintain", "maintain", "controller", "address", "between", "initiali[zs]e", "instead", "function", "select", "already", "equal", "access", "management", "hierarchy", "registration", "interest", "relative", "memory", "offset", "already", Signed-off-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2010-10-26use clear_page()/copy_page() in favor of memset()/memcpy() on whole pagesJan Beulich
After all that's what they are intended for. Signed-off-by: Jan Beulich <jbeulich@novell.com> Cc: Miklos Szeredi <miklos@szeredi.hu> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: "Rafael J. Wysocki" <rjw@sisk.pl> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-08-11kexec: return -EFAULT on copy_to_user() failuresDan Carpenter
copy_to/from_user() returns the number of bytes remaining to be copied. It never returns a negative value. The correct return code is -EFAULT and not -EIO. All the callers check for non-zero returns so that's Ok, but the return code is passed to the user so we should fix this. Signed-off-by: Dan Carpenter <error27@gmail.com> Cc: Hidetoshi Seto <seto.hidetoshi@jp.fujitsu.com> Cc: "Paul E. McKenney" <paulmck@linux.vnet.ibm.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Simon Kagstrom <simon.kagstrom@netinsight.net> Acked-by: WANG Cong <xiyou.wangcong@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-06-29kexec: fix Oops in crash_shrink_memory()Pavan Naregundi
When crashkernel is not enabled, "echo 0 > /sys/kernel/kexec_crash_size" OOPSes the kernel in crash_shrink_memory. This happens when crash_shrink_memory tries to release the 'crashk_res' resource which are not reserved. Also value of "/sys/kernel/kexec_crash_size" shows as 1, which should be 0. This patch fixes the OOPS in crash_shrink_memory and shows "/sys/kernel/kexec_crash_size" as 0 when crash kernel memory is not reserved. Signed-off-by: Pavan Naregundi <pavan@linux.vnet.ibm.com> Reviewed-by: WANG Cong <xiyou.wangcong@gmail.com> Cc: Simon Horman <horms@verge.net.au> Cc: Vivek Goyal <vgoyal@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-05-11kexec: fix OOPS in crash_kernel_shrinkVitaly Mayatskikh
Two "echo 0 > /sys/kernel/kexec_crash_size" OOPSes kernel. Also content of this file is invalid after first shrink to zero: it shows 1 instead of 0. This scenario is unlikely to happen often (root privs, valid crashkernel= in cmdline, dump-capture kernel not loaded), I hit it only by chance. This patch fixes it. Signed-off-by: Vitaly Mayatskikh <v.mayatskih@gmail.com> Cc: Cong Wang <amwang@redhat.com> Cc: Neil Horman <nhorman@tuxdriver.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-02-17percpu: add __percpu sparse annotations to core kernel subsystemsTejun Heo
Add __percpu sparse annotations to core subsystems. These annotations are to make sparse consider percpu variables to be in a different address space and warn if accessed without going through percpu accessors. This patch doesn't affect normal builds. Signed-off-by: Tejun Heo <tj@kernel.org> Reviewed-by: Christoph Lameter <cl@linux-foundation.org> Acked-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: Jens Axboe <axboe@kernel.dk> Cc: linux-mm@kvack.org Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: Dipankar Sarma <dipankar@in.ibm.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Eric Biederman <ebiederm@xmission.com>
2010-01-24Merge git://git.infradead.org/~dwmw2/mtd-2.6.33Linus Torvalds
* git://git.infradead.org/~dwmw2/mtd-2.6.33: mtd: tests: fix read, speed and stress tests on NOR flash mtd: Really add ARM pismo support kmsg_dump: Dump on crash_kexec as well
2009-12-31kmsg_dump: Dump on crash_kexec as wellKOSAKI Motohiro
crash_kexec gets called before kmsg_dump(KMSG_DUMP_OOPS) if panic_on_oops is set, so the kernel log buffer is not stored for this case. This patch adds a KMSG_DUMP_KEXEC dump type which gets called when crash_kexec() is invoked. To avoid getting double dumps, the old KMSG_DUMP_PANIC is moved below crash_kexec(). The mtdoops driver is modified to handle KMSG_DUMP_KEXEC in the same way as a panic. Signed-off-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Acked-by: Simon Kagstrom <simon.kagstrom@netinsight.net> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2009-12-17Merge branch 'for-33' of git://repo.or.cz/linux-kbuildLinus Torvalds
* 'for-33' of git://repo.or.cz/linux-kbuild: (29 commits) net: fix for utsrelease.h moving to generated gen_init_cpio: fixed fwrite warning kbuild: fix make clean after mismerge kbuild: generate modules.builtin genksyms: properly consider EXPORT_UNUSED_SYMBOL{,_GPL}() score: add asm/asm-offsets.h wrapper unifdef: update to upstream revision 1.190 kbuild: specify absolute paths for cscope kbuild: create include/generated in silentoldconfig scripts/package: deb-pkg: use fakeroot if available scripts/package: add KBUILD_PKG_ROOTCMD variable scripts/package: tar-pkg: use tar --owner=root Kbuild: clean up marker net: add net_tstamp.h to headers_install kbuild: move utsrelease.h to include/generated kbuild: move autoconf.h to include/generated drop explicit include of autoconf.h kbuild: move compile.h to include/generated kbuild: drop include/asm kbuild: do not check for include/asm-$ARCH ... Fixed non-conflicting clean merge of modpost.c as per comments from Stephen Rothwell (modpost.c had grown an include of linux/autoconf.h that needed to be changed to generated/autoconf.h)
2009-12-16kexec: premit reduction of the reserved memory sizeAmerigo Wang
Implement shrinking the reserved memory for crash kernel, if it is more than enough. For example, if you have already reserved 128M, now you just want 100M, you can do: # echo $((100*1024*1024)) > /sys/kernel/kexec_crash_size Note, you can only do this before loading the crash kernel. Signed-off-by: WANG Cong <amwang@redhat.com> Cc: Neil Horman <nhorman@redhat.com> Acked-by: Eric W. Biederman <ebiederm@xmission.com> Cc: Andi Kleen <andi@firstfloor.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-12-12kbuild: move utsrelease.h to include/generatedSam Ravnborg
Fix up all users of utsrelease.h Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Michal Marek <mmarek@suse.cz>
2009-07-29kexec: fix omitting offset in extended crashkernel syntaxHidetoshi Seto
Setting "crashkernel=512M-2G:64M,2G-:128M" does not work but it turns to work if it has a trailing-whitespace, like "crashkernel=512M-2G:64M,2G-:128M ". It was because of a bug in the parser, running over the cmdline. This patch adds a check of the termination. Reported-by: Jin Dongming <jin.dongming@np.css.fujitsu.com> Signed-off-by: Hidetoshi Seto <seto.hidetoshi@jp.fujitsu.com> Tested-by: Jin Dongming <jin.dongming@np.css.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-12PM core: rename suspend and resume functionsAlan Stern
This patch (as1241) renames a bunch of functions in the PM core. Rather than go through a boring list of name changes, suffice it to say that in the end we have a bunch of pairs of functions: device_resume_noirq dpm_resume_noirq device_resume dpm_resume device_complete dpm_complete device_suspend_noirq dpm_suspend_noirq device_suspend dpm_suspend device_prepare dpm_prepare in which device_X does the X operation on a single device and dpm_X invokes device_X for all devices in the dpm_list. In addition, the old dpm_power_up and device_resume_noirq have been combined into a single function (dpm_resume_noirq). Lastly, dpm_suspend_start and dpm_resume_end are the renamed versions of the former top-level device_suspend and device_resume routines. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Acked-by: Magnus Damm <damm@igel.co.jp> Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl>
2009-06-12PM: Rename device_power_down/up()Magnus Damm
Rename the functions performing "_noirq" dev_pm_ops operations from device_power_down() and device_power_up() to device_suspend_noirq() and device_resume_noirq(). The new function names are chosen to show that the functions are responsible for calling the _noirq() versions to finalize the suspend/resume operation. The current function names do not perform power down/up anymore so the names may be misleading. Global function renames: - device_power_down() -> device_suspend_noirq() - device_power_up() -> device_resume_noirq() Static function renames: - suspend_device_noirq() -> __device_suspend_noirq() - resume_device_noirq() -> __device_resume_noirq() Signed-off-by: Magnus Damm <damm@igel.co.jp> Acked-by: Greg Kroah-Hartman <gregkh@suse.de> Acked-by: Len Brown <lenb@kernel.org> Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl>
2009-05-24PM: Do not hold dpm_list_mtx while disabling/enabling nonboot CPUsRafael J. Wysocki
We shouldn't hold dpm_list_mtx while executing [disable|enable]_nonboot_cpus(), because theoretically this may lead to a deadlock as shown by the following example (provided by Johannes Berg): CPU 3 CPU 2 CPU 1 suspend/hibernate something: rtnl_lock() device_pm_lock() -> mutex_lock(&dpm_list_mtx) mutex_lock(&dpm_list_mtx) linkwatch_work -> rtnl_lock() disable_nonboot_cpus() -> flush CPU 3 workqueue Fortunately, device drivers are supposed to stop any activities that might lead to the registration of new device objects way before disable_nonboot_cpus() is called, so it shouldn't be necessary to hold dpm_list_mtx over the entire late part of device suspend and early part of device resume. Thus, during the late suspend and the early resume of devices acquire dpm_list_mtx only when dpm_list is going to be traversed and release it right after that. This patch is reported to fix the regressions tracked as http://bugzilla.kernel.org/show_bug.cgi?id=13245. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Acked-by: Alan Stern <stern@rowland.harvard.edu> Reported-by: Miles Lane <miles.lane@gmail.com> Tested-by: Ming Lei <tom.leiming@gmail.com>
2009-04-02kexec: vmcoreinfo_data[] can become staticDmitri Vorobiev
The vmcoreinfo_data[] array is not used outside of kernel/kexec.c, and can therefore become static. This patch adds the relevant keyword to the definition of the array. Noticed by sparse. Signed-off-by: Dmitri Vorobiev <dmitri.vorobiev@movial.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-02kexec: add dmesg log symbols to /proc/vmcoreinfo listsNeil Horman
It would be nice to be able to extract the dmesg log from a vmcore file without needing to keep the debug symbols for the running kernel handy all the time. We have a facility to do this in /proc/vmcore. This patch adds the log_buf and log_end symbols to the vmcoreinfo area so that tools (like makedumpfile) can easily extract the dmesg logs from a vmcore image. [akpm@linux-foundation.org: several fixes and cleanups] [akpm@linux-foundation.org: fix unused log_buf_kexec_setup()] [akpm@linux-foundation.org: build fix] Signed-off-by: Neil Horman <nhorman@tuxdriver.com> Cc: Simon Horman <horms@verge.net.au> Acked-by: Vivek Goyal <vgoyal@redhat.com> Cc: Neil Horman <nhorman@tuxdriver.com> Cc: Simon Horman <horms@verge.net.au> Cc: Vivek Goyal <vgoyal@redhat.com> Cc: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-03-30kexec: Change kexec jump code orderingRafael J. Wysocki
Change the ordering of the kexec jump code so that the nonboot CPUs are disabled after calling device drivers' "late suspend" methods. This change reflects the recent modifications of the power management code that is also used by kexec jump. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Acked-by: Ingo Molnar <mingo@elte.hu>
2009-03-30PM: Rework handling of interrupts during suspend-resumeRafael J. Wysocki
Use the functions introduced in by the previous patch, suspend_device_irqs(), resume_device_irqs() and check_wakeup_irqs(), to rework the handling of interrupts during suspend (hibernation) and resume. Namely, interrupts will only be disabled on the CPU right before suspending sysdevs, while device drivers will be prevented from receiving interrupts, with the help of the new helper function, before their "late" suspend callbacks run (and analogously during resume). In addition, since the device interrups are now disabled before the CPU has turned all interrupts off and the CPU will ACK the interrupts setting the IRQ_PENDING bit for them, check in sysdev_suspend() if any wake-up interrupts are pending and abort suspend if that's the case. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Acked-by: Ingo Molnar <mingo@elte.hu>
2009-02-22Merge branch 'linus' into x86/apicIngo Molnar
Conflicts: arch/x86/mach-default/setup.c Semantic conflict resolution: arch/x86/kernel/setup.c Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-02-22PM: Split up sysdev_[suspend|resume] from device_power_[down|up]Rafael J. Wysocki
Move the sysdev_suspend/resume from the callee to the callers, with no real change in semantics, so that we can rework the disabling of interrupts during suspend/hibernation. This is based on an earlier patch from Linus. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-02-10elf: add ELF_CORE_COPY_KERNEL_REGS()Tejun Heo
ELF core dump is used for both user land core dump and kernel crash dump. Depending on architecture, register might need to be accessed differently for userland and kernel. Allow architectures to define ELF_CORE_COPY_KERNEL_REGS() and use different operation for kernel register dump. Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-01-14[CVE-2009-0029] System call wrappers part 07Heiko Carstens
2009-01-01cpumask: prepare for iterators to only go to nr_cpu_ids/nr_cpumask_bits.: coreRusty Russell
Impact: cleanup In future, all cpumask ops will only be valid (in general) for bit numbers < nr_cpu_ids. So use that instead of NR_CPUS in iterators and other comparisons. This is always safe: no cpu number can be >= nr_cpu_ids, and nr_cpu_ids is initialized to NR_CPUS at boot. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Mike Travis <travis@sgi.com> Acked-by: Ingo Molnar <mingo@elte.hu> Acked-by: James Morris <jmorris@namei.org> Cc: Eric Biederman <ebiederm@xmission.com>
2008-10-20kexec: fix crash_save_vmcoreinfo_init build problemLuck, Tony
This fixes kernel/kexec.c: In function 'crash_save_vmcoreinfo_init': kernel/kexec.c:1374: error: 'vmlist' undeclared (first use in this function) kernel/kexec.c:1374: error: (Each undeclared identifier is reported only once kernel/kexec.c:1374: error: for each function it appears in.) kernel/kexec.c:1410: error: invalid use of undefined type 'struct vm_struct' make[1]: *** [kernel/kexec.o] Error 1 Signed-off-by: Tony Luck <tony.luck@intel.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-20kdump: add vmlist.addr to vmcoreinfo for x86 vmalloc translation.Ken'ichi Ohmichi
Add the symbols 'vmlist' and offset 'vm_struct.addr' to the vmcoreinfo[1] data for i386 vmalloc translation. makedumpfile[2] needs VMALLOC_START value for distinguishing a vmalloc address or not, because it should choose suitable translation method. If applying this patch, makedumpfile will be able to take VMALLOC_START value from 'vmlist.addr'. vmcoreinfo[1]: The vmcoreinfo data has the minimum debugging information only for dump filtering. makedumpfile[2] uses it to distinguish unnecessary pages and creates a small dumpfile. makedumpfile[2]: dump filtering command https://sourceforge.net/projects/makedumpfile/ Signed-off-by: Ken'ichi Ohmichi <oomichi@mxs.nes.nec.co.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-09-23kexec: fix segmentation fault in kimage_add_entryJonathan Steel
A segmentation fault can occur in kimage_add_entry in kexec.c when loading a kernel image into memory. The fault occurs because a page is requested by calling kimage_alloc_page with gfp_mask GFP_KERNEL and the function may actually return a page with gfp_mask GFP_HIGHUSER. The high mem page is returned because it was swapped with the kernel page due to the kernel page being a page that will shortly be copied to. This patch ensures that kimage_alloc_page returns a page that was created with the correct gfp flags. I have verified the change and fixed the whitespace damage of the original patch. Jonathan did a great job of tracking this down after he hit the problem. -- Eric Signed-off-by: Jonathan Steel <jon.steel@esentire.com> Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Acked-by: Simon Horman <horms@verge.net.au> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-08-15kexec: use a mutex for locking rather than xchg()Andrew Morton
Functionally the same, but more conventional. Cc: Huang Ying <ying.huang@intel.com> Tested-by: Vivek Goyal <vgoyal@redhat.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-08-15kexec jump: fix for ftraceHuang Ying
Ftrace depends on some processor state that we destroyed during kexec and restored by restore_processor_state(). So save_processor_state() and restore_processor_state() are moved into machine_kexec() and ftrace is restored after restore_processor_state(). Signed-off-by: Huang Ying <ying.huang@intel.com> Cc: Pavel Machek <pavel@ucw.cz> Cc: "Rafael J. Wysocki" <rjw@sisk.pl> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Vivek Goyal <vgoyal@redhat.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Steven Rostedt <rostedt@goodmis.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-08-15kexec jump: in sync with hibernation implementationHuang Ying
Add device_pm_lock() and device_pm_unlock() in kernel_kexec() in sync with current hibernation implementation. Signed-off-by: Huang Ying <ying.huang@intel.com> Acked-by: Pavel Machek <pavel@ucw.cz> Cc: "Rafael J. Wysocki" <rjw@sisk.pl> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Vivek Goyal <vgoyal@redhat.com> Cc: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-08-15kexec jump: remove duplication of kexec_restart_prepare()Huang Ying
Call kernel_restart_prepare() in kernel_kexec() instead of duplicating the code. Signed-off-by: Huang Ying <ying.huang@intel.com> Acked-by: Pavel Machek <pavel@suse.cz> Acked-by: Vivek Goyal <vgoyal@redhat.com> Cc: Pavel Machek <pavel@ucw.cz> Cc: "Rafael J. Wysocki" <rjw@sisk.pl> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Vivek Goyal <vgoyal@redhat.com> Cc: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-08-15kexec jump: rename KEXEC_CONTROL_CODE_SIZE to KEXEC_CONTROL_PAGE_SIZEHuang Ying
Rename KEXEC_CONTROL_CODE_SIZE to KEXEC_CONTROL_PAGE_SIZE, because control page is used for not only code on some platform. For example in kexec jump, it is used for data and stack too. [akpm@linux-foundation.org: unbreak powerpc and arm, finish conversion] Signed-off-by: Huang Ying <ying.huang@intel.com> Cc: Pavel Machek <pavel@ucw.cz> Cc: "Rafael J. Wysocki" <rjw@sisk.pl> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Vivek Goyal <vgoyal@redhat.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Russell King <rmk@arm.linux.org.uk> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-08-15kexec jump: clean up #ifdef and commentsHuang Ying
Move if (kexec_image->preserve_context) { ... } into #ifdef CONFIG_KEXEC_JUMP to make code looks cleaner. Fix no longer correct comments of kernel_kexec(). Signed-off-by: Huang Ying <ying.huang@intel.com> Acked-by: Vivek Goyal <vgoyal@redhat.com> Cc: Pavel Machek <pavel@ucw.cz> Cc: "Rafael J. Wysocki" <rjw@sisk.pl> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Vivek Goyal <vgoyal@redhat.com> Cc: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-08-15kexec: fix compilation warning on xchg(&kexec_lock, 0) in kernel_kexec()Huang Ying
kernel/kexec.c: In function 'kernel_kexec': kernel/kexec.c:1506: warning: value computed is not used Signed-off-by: Huang Ying <ying.huang@intel.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-26kexec jump: save/restore device stateHuang Ying
This patch implements devices state save/restore before after kexec. This patch together with features in kexec_jump patch can be used for following: - A simple hibernation implementation without ACPI support. You can kexec a hibernating kernel, save the memory image of original system and shutdown the system. When resuming, you restore the memory image of original system via ordinary kexec load then jump back. - Kernel/system debug through making system snapshot. You can make system snapshot, jump back, do some thing and make another system snapshot. - Cooperative multi-kernel/system. With kexec jump, you can switch between several kernels/systems quickly without boot process except the first time. This appears like swap a whole kernel/system out/in. - A general method to call program in physical mode (paging turning off). This can be used to invoke BIOS code under Linux. The following user-space tools can be used with kexec jump: - kexec-tools needs to be patched to support kexec jump. The patches and the precompiled kexec can be download from the following URL: source: http://khibernation.sourceforge.net/download/release_v10/kexec-tools/kexec-tools-src_git_kh10.tar.bz2 patches: http://khibernation.sourceforge.net/download/release_v10/kexec-tools/kexec-tools-patches_git_kh10.tar.bz2 binary: http://khibernation.sourceforge.net/download/release_v10/kexec-tools/kexec_git_kh10 - makedumpfile with patches are used as memory image saving tool, it can exclude free pages from original kernel memory image file. The patches and the precompiled makedumpfile can be download from the following URL: source: http://khibernation.sourceforge.net/download/release_v10/makedumpfile/makedumpfile-src_cvs_kh10.tar.bz2 patches: http://khibernation.sourceforge.net/download/release_v10/makedumpfile/makedumpfile-patches_cvs_kh10.tar.bz2 binary: http://khibernation.sourceforge.net/download/release_v10/makedumpfile/makedumpfile_cvs_kh10 - An initramfs image can be used as the root file system of kexeced kernel. An initramfs image built with "BuildRoot" can be downloaded from the following URL: initramfs image: http://khibernation.sourceforge.net/download/release_v10/initramfs/rootfs_cvs_kh10.gz All user space tools above are included in the initramfs image. Usage example of simple hibernation: 1. Compile and install patched kernel with following options selected: CONFIG_X86_32=y CONFIG_RELOCATABLE=y CONFIG_KEXEC=y CONFIG_CRASH_DUMP=y CONFIG_PM=y CONFIG_HIBERNATION=y CONFIG_KEXEC_JUMP=y 2. Build an initramfs image contains kexec-tool and makedumpfile, or download the pre-built initramfs image, called rootfs.gz in following text. 3. Prepare a partition to save memory image of original kernel, called hibernating partition in following text. 4. Boot kernel compiled in step 1 (kernel A). 5. In the kernel A, load kernel compiled in step 1 (kernel B) with /sbin/kexec. The shell command line can be as follow: /sbin/kexec --load-preserve-context /boot/bzImage --mem-min=0x100000 --mem-max=0xffffff --initrd=rootfs.gz 6. Boot the kernel B with following shell command line: /sbin/kexec -e 7. The kernel B will boot as normal kexec. In kernel B the memory image of kernel A can be saved into hibernating partition as follow: jump_back_entry=`cat /proc/cmdline | tr ' ' '\n' | grep kexec_jump_back_entry | cut -d '='` echo $jump_back_entry > kexec_jump_back_entry cp /proc/vmcore dump.elf Then you can shutdown the machine as normal. 8. Boot kernel compiled in step 1 (kernel C). Use the rootfs.gz as root file system. 9. In kernel C, load the memory image of kernel A as follow: /sbin/kexec -l --args-none --entry=`cat kexec_jump_back_entry` dump.elf 10. Jump back to the kernel A as follow: /sbin/kexec -e Then, kernel A is resumed. Implementation point: To support jumping between two kernels, before jumping to (executing) the new kernel and jumping back to the original kernel, the devices are put into quiescent state, and the state of devices and CPU is saved. After jumping back from kexeced kernel and jumping to the new kernel, the state of devices and CPU are restored accordingly. The devices/CPU state save/restore code of software suspend is called to implement corresponding function. Known issues: - Because the segment number supported by sys_kexec_load is limited, hibernation image with many segments may not be load. This is planned to be eliminated by adding a new flag to sys_kexec_load to make a image can be loaded with multiple sys_kexec_load invoking. Now, only the i386 architecture is supported. Signed-off-by: Huang Ying <ying.huang@intel.com> Acked-by: Vivek Goyal <vgoyal@redhat.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Pavel Machek <pavel@ucw.cz> Cc: Nigel Cunningham <nigel@nigel.suspend2.net> Cc: "Rafael J. Wysocki" <rjw@sisk.pl> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-26kexec jumpHuang Ying
This patch provides an enhancement to kexec/kdump. It implements the following features: - Backup/restore memory used by the original kernel before/after kexec. - Save/restore CPU state before/after kexec. The features of this patch can be used as a general method to call program in physical mode (paging turning off). This can be used to call BIOS code under Linux. kexec-tools needs to be patched to support kexec jump. The patches and the precompiled kexec can be download from the following URL: source: http://khibernation.sourceforge.net/download/release_v10/kexec-tools/kexec-tools-src_git_kh10.tar.bz2 patches: http://khibernation.sourceforge.net/download/release_v10/kexec-tools/kexec-tools-patches_git_kh10.tar.bz2 binary: http://khibernation.sourceforge.net/download/release_v10/kexec-tools/kexec_git_kh10 Usage example of calling some physical mode code and return: 1. Compile and install patched kernel with following options selected: CONFIG_X86_32=y CONFIG_KEXEC=y CONFIG_PM=y CONFIG_KEXEC_JUMP=y 2. Build patched kexec-tool or download the pre-built one. 3. Build some physical mode executable named such as "phy_mode" 4. Boot kernel compiled in step 1. 5. Load physical mode executable with /sbin/kexec. The shell command line can be as follow: /sbin/kexec --load-preserve-context --args-none phy_mode 6. Call physical mode executable with following shell command line: /sbin/kexec -e Implementation point: To support jumping without reserving memory. One shadow backup page (source page) is allocated for each page used by kexeced code image (destination page). When do kexec_load, the image of kexeced code is loaded into source pages, and before executing, the destination pages and the source pages are swapped, so the contents of destination pages are backupped. Before jumping to the kexeced code image and after jumping back to the original kernel, the destination pages and the source pages are swapped too. C ABI (calling convention) is used as communication protocol between kernel and called code. A flag named KEXEC_PRESERVE_CONTEXT for sys_kexec_load is added to indicate that the loaded kernel image is used for jumping back. Now, only the i386 architecture is supported. Signed-off-by: Huang Ying <ying.huang@intel.com> Acked-by: Vivek Goyal <vgoyal@redhat.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Pavel Machek <pavel@ucw.cz> Cc: Nigel Cunningham <nigel@nigel.suspend2.net> Cc: "Rafael J. Wysocki" <rjw@sisk.pl> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-26kernel/kexec.c: make 'kimage_terminate' voidWANG Cong
Since kimage_terminate() always returns 0, make it void. Signed-off-by: WANG Cong <wangcong@zeuux.org> Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-01kexec: make extended crashkernel= syntax less confusingMichael Ellerman
The extended crashkernel syntax is a little confusing in the way it handles ranges. eg: crashkernel=512M-2G:64M,2G-:128M Means if the machine has between 512M and 2G of memory the crash region should be 64M, and if the machine has 2G of memory the region should be 64M. Only if the machine has more than 2G memory will 128M be allocated. Although that semantic is correct, it is somewhat baffling. Instead I propose that the end of the range means the first address past the end of the range, ie: 512M up to but not including 2G. [bwalle@suse.de: clarify inclusive/exclusive in crashkernel commandline in documentation] Signed-off-by: Michael Ellerman <michael@ellerman.id.au> Acked-by: Bernhard Walle <bwalle@suse.de> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Simon Horman <horms@verge.net.au> Signed-off-by: Bernhard Walle <bwalle@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-28vmcoreinfo: add page flags valuesKen'ichi Ohmichi
Add some values of page flags to the vmcoreinfo data. The vmcoreinfo data has the minimum debugging information only for dump filtering. makedumpfile (dump filtering command) gets it to distinguish unnecessary pages, and makedumpfile creates a small dumpfile. An old makedumpfile (v1.2.4 or before) had assumed some values of page flags internally, and this implementation could not follow the change of these values. For example, Christoph Lameter is changing these values by the follwing patch: http://lkml.org/lkml/2008/2/29/463 So a new makedumpfile (v1.2.5) came to need these values and I created this patch to let the kernel output them. Signed-off-by: Ken'ichi Ohmichi <oomichi@mxs.nes.nec.co.jp> Cc: Christoph Lameter <clameter@sgi.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Acked-by: Vivek Goyal <vgoyal@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-18kernel: Remove unnecessary inclusions of asm/semaphore.hMatthew Wilcox
None of these files use any of the functionality promised by asm/semaphore.h. Signed-off-by: Matthew Wilcox <willy@linux.intel.com>
2008-02-07vmcoreinfo: add "VMCOREINFO_" to all the call for vmcoreinfo_append_str()Ken'ichi Ohmichi
For readability, all the calls to vmcoreinfo_append_str() are changed to macros having a prefix "VMCOREINFO_". This discussion is the following: http://www.ussg.iu.edu/hypermail/linux/kernel/0709.3/0584.html Signed-off-by: Ken'ichi Ohmichi <oomichi@mxs.nes.nec.co.jp> Acked-by: Simon Horman <horms@verge.net.au> Cc: David Rientjes <rientjes@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
