path: root/kernel/kfifo.c
2006-09-29[PATCH] memory ordering in __kfifo primitivesPaul E. McKenney
Both __kfifo_put() and __kfifo_get() have header comments stating that if there is but one concurrent reader and one concurrent writer, locking is not necessary. This is almost the case, but a couple of memory barriers are needed. Another option would be to change the header comments to remove the bit about locking not being needed, and to change the those callers who currently don't use locking to add the required locking. The attachment analyzes this approach, but the patch below seems simpler. Signed-off-by: Paul E. McKenney <paulmck@us.ibm.com> Cc: Stelian Pop <stelian@popies.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-08[PATCH] gfp flags annotations - part 1Al Viro
- added typedef unsigned int __nocast gfp_t; - replaced __nocast uses for gfp flags with gfp_t - it gives exactly the same warnings as far as sparse is concerned, doesn't change generated code (from gcc point of view we replaced unsigned int with typedef) and documents what's going on far better. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
