path: root/kernel/kfifo.c
2011-10-31kernel: Map most files to use export.h instead of module.hPaul Gortmaker
The changed files were only including linux/module.h for the EXPORT_SYMBOL infrastructure, and nothing else. Revector them onto the isolated export header for faster compile times. Nothing to see here but a whole lot of instances of: -#include <linux/module.h> +#include <linux/export.h> This commit is only changing the kernel dir; next targets will probably be mm, fs, the arch dirs, etc. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2010-10-01kfifo: fix scatterlist usageIra W. Snyder
The kfifo_dma family of functions use sg_mark_end() on the last element in their scatterlist. This forces use of a fresh scatterlist for each DMA operation, which makes recycling a single scatterlist impossible. Change the behavior of the kfifo_dma functions to match the usage of the dma_map_sg function. This means that users must respect the returned nents value. The sample code is updated to reflect the change. This bug is trivial to cause: call kfifo_dma_in_prepare() such that it prepares a scatterlist with a single entry comprising the whole fifo. This is the case when you map the entirety of a newly created empty fifo. This causes the setup_sgl() function to mark the first scatterlist entry as the end of the chain, no matter what comes after it. Afterwards, add and remove some data from the fifo such that another call to kfifo_dma_in_prepare() will create two scatterlist entries. It returns nents=2. However, due to the previous sg_mark_end() call, sg_is_last() will now return true for the first scatterlist element. This causes the sample code to print a single scatterlist element when it should print two. By removing the call to sg_mark_end(), we make the API as similar as possible to the DMA mapping API. All users are required to respect the returned nents. Signed-off-by: Ira W. Snyder <iws@ovro.caltech.edu> Cc: Stefani Seibold <stefani@seibold.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-08-20kfifo: implement missing __kfifo_skip_r()Andrea Righi
kfifo_skip() is currently broken, due to the missing of the internal helper function. Add it. Signed-off-by: Andrea Righi <arighi@develer.com> Cc: Greg KH <greg@kroah.com> Acked-by: Stefani Seibold <stefani@seibold.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-08-12kernel/kfifo.c: add handling of chained scatterlistsStefani Seibold
The current kfifo scatterlist implementation will not work with chained scatterlists. It assumes that struct scatterlist arrays are allocated contiguously, which is not the case when chained scatterlists (struct sg_table) are in use. Signed-off-by: Stefani Seibold <stefani@seibold.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-08-11kfifo: replace the old non generic APIStefani Seibold
Simply replace the whole kfifo.c and kfifo.h files with the new generic version and fix the kerneldoc API template file. Signed-off-by: Stefani Seibold <stefani@seibold.net> Cc: Greg KH <greg@kroah.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-02-16kfifo: Don't use integer as NULL pointerAnton Vorontsov
This patch fixes following sparse warnings: include/linux/kfifo.h:127:25: warning: Using plain integer as NULL pointer kernel/kfifo.c:83:21: warning: Using plain integer as NULL pointer Signed-off-by: Anton Vorontsov <avorontsov@ru.mvista.com> Acked-by: Stefani Seibold <stefani@seibold.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-02-16kfifo: Make kfifo_initialized work after kfifo_freeAnton Vorontsov
After kfifo rework it's no longer possible to reliably know if kfifo is usable, since after kfifo_free(), kfifo_initialized() would still return true. The correct behaviour is needed for at least FHCI USB driver. This patch fixes the issue by resetting the kfifo to zero values (the same approach is used in kfifo_alloc() if allocation failed). Signed-off-by: Anton Vorontsov <avorontsov@ru.mvista.com> Acked-by: Stefani Seibold <stefani@seibold.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-02-02kfifo: fix kernel-doc notationRandy Dunlap
Fix kfifo kernel-doc warnings: Warning(kernel/kfifo.c:361): No description found for parameter 'total' Warning(kernel/kfifo.c:402): bad line: @ @lenout: pointer to output variable with copied data Warning(kernel/kfifo.c:412): No description found for parameter 'lenout' Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Cc: Stefani Seibold <stefani@seibold.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-01-16kfifo: document everywhere that size has to be power of twoAndi Kleen
On my first try using them I missed that the fifos need to be power of two, resulting in a runtime bug. Document that requirement everywhere (and fix one grammar bug) Signed-off-by: Andi Kleen <ak@linux.intel.com> Acked-by: Stefani Seibold <stefani@seibold.net> Cc: Roland Dreier <rdreier@cisco.com> Cc: Dmitry Torokhov <dmitry.torokhov@gmail.com> Cc: Andy Walls <awalls@radix.net> Cc: Vikram Dhillon <dhillonv10@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-01-16kfifo: add kfifo_out_peekAndi Kleen
In some upcoming code it's useful to peek into a FIFO without permanentely removing data. This patch implements a new kfifo_out_peek() to do this. Signed-off-by: Andi Kleen <ak@linux.intel.com> Acked-by: Stefani Seibold <stefani@seibold.net> Cc: Roland Dreier <rdreier@cisco.com> Cc: Dmitry Torokhov <dmitry.torokhov@gmail.com> Cc: Andy Walls <awalls@radix.net> Cc: Vikram Dhillon <dhillonv10@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-01-16kfifo: sanitize *_user error handlingAndi Kleen
Right now for kfifo_*_user it's not easily possible to distingush between a user copy failing and the FIFO not containing enough data. The problem is that both conditions are multiplexed into the same return code. Avoid this by moving the "copy length" into a separate output parameter and only return 0/-EFAULT in the main return value. I didn't fully adapt the weird "record" variants, those seem to be unused anyways and were rather messy (should they be just removed?) I would appreciate some double checking if I did all the conversions correctly. Signed-off-by: Andi Kleen <ak@linux.intel.com> Cc: Stefani Seibold <stefani@seibold.net> Cc: Roland Dreier <rdreier@cisco.com> Cc: Dmitry Torokhov <dmitry.torokhov@gmail.com> Cc: Andy Walls <awalls@radix.net> Cc: Vikram Dhillon <dhillonv10@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-01-16kfifo: use void * pointers for user buffersAndi Kleen
The pointers to user buffers are currently unsigned char *, which requires a lot of casting in the caller for any non-char typed buffers. Use void * instead. Signed-off-by: Andi Kleen <ak@linux.intel.com> Acked-by: Stefani Seibold <stefani@seibold.net> Cc: Roland Dreier <rdreier@cisco.com> Cc: Dmitry Torokhov <dmitry.torokhov@gmail.com> Cc: Andy Walls <awalls@radix.net> Cc: Vikram Dhillon <dhillonv10@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-12-22kfifo: add record handling functionsStefani Seibold
Add kfifo_in_rec() - puts some record data into the FIFO Add kfifo_out_rec() - gets some record data from the FIFO Add kfifo_from_user_rec() - puts some data from user space into the FIFO Add kfifo_to_user_rec() - gets data from the FIFO and write it to user space Add kfifo_peek_rec() - gets the size of the next FIFO record field Add kfifo_skip_rec() - skip the next fifo out record Add kfifo_avail_rec() - determinate the number of bytes available in a record FIFO Signed-off-by: Stefani Seibold <stefani@seibold.net> Acked-by: Greg Kroah-Hartman <gregkh@suse.de> Acked-by: Mauro Carvalho Chehab <mchehab@redhat.com> Acked-by: Andi Kleen <ak@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-12-22kfifo: add kfifo_skip, kfifo_from_user and kfifo_to_userStefani Seibold
Add kfifo_reset_out() for save lockless discard the fifo output Add kfifo_skip() to skip a number of output bytes Add kfifo_from_user() to copy user space data into the fifo Add kfifo_to_user() to copy fifo data to user space Signed-off-by: Stefani Seibold <stefani@seibold.net> Acked-by: Greg Kroah-Hartman <gregkh@suse.de> Acked-by: Mauro Carvalho Chehab <mchehab@redhat.com> Acked-by: Andi Kleen <ak@linux.intel.com> Acked-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-12-22kfifo: rename kfifo_put... into kfifo_in... and kfifo_get... into kfifo_out...Stefani Seibold
rename kfifo_put... into kfifo_in... to prevent miss use of old non in kernel-tree drivers ditto for kfifo_get... -> kfifo_out... Improve the prototypes of kfifo_in and kfifo_out to make the kerneldoc annotations more readable. Add mini "howto porting to the new API" in kfifo.h Signed-off-by: Stefani Seibold <stefani@seibold.net> Acked-by: Greg Kroah-Hartman <gregkh@suse.de> Acked-by: Mauro Carvalho Chehab <mchehab@redhat.com> Acked-by: Andi Kleen <ak@linux.intel.com> Acked-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-12-22kfifo: cleanup namespaceStefani Seibold
change name of __kfifo_* functions to kfifo_*, because the prefix __kfifo should be reserved for internal functions only. Signed-off-by: Stefani Seibold <stefani@seibold.net> Acked-by: Greg Kroah-Hartman <gregkh@suse.de> Acked-by: Mauro Carvalho Chehab <mchehab@redhat.com> Acked-by: Andi Kleen <ak@linux.intel.com> Acked-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-12-22kfifo: move out spinlockStefani Seibold
Move the pointer to the spinlock out of struct kfifo. Most users in tree do not actually use a spinlock, so the few exceptions now have to call kfifo_{get,put}_locked, which takes an extra argument to a spinlock. Signed-off-by: Stefani Seibold <stefani@seibold.net> Acked-by: Greg Kroah-Hartman <gregkh@suse.de> Acked-by: Mauro Carvalho Chehab <mchehab@redhat.com> Acked-by: Andi Kleen <ak@linux.intel.com> Acked-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-12-22kfifo: move struct kfifo in placeStefani Seibold
This is a new generic kernel FIFO implementation. The current kernel fifo API is not very widely used, because it has to many constrains. Only 17 files in the current 2.6.31-rc5 used it. FIFO's are like list's a very basic thing and a kfifo API which handles the most use case would save a lot of development time and memory resources. I think this are the reasons why kfifo is not in use: - The API is to simple, important functions are missing - A fifo can be only allocated dynamically - There is a requirement of a spinlock whether you need it or not - There is no support for data records inside a fifo So I decided to extend the kfifo in a more generic way without blowing up the API to much. The new API has the following benefits: - Generic usage: For kernel internal use and/or device driver. - Provide an API for the most use case. - Slim API: The whole API provides 25 functions. - Linux style habit. - DECLARE_KFIFO, DEFINE_KFIFO and INIT_KFIFO Macros - Direct copy_to_user from the fifo and copy_from_user into the fifo. - The kfifo itself is an in place member of the using data structure, this save an indirection access and does not waste the kernel allocator. - Lockless access: if only one reader and one writer is active on the fifo, which is the common use case, no additional locking is necessary. - Remove spinlock - give the user the freedom of choice what kind of locking to use if one is required. - Ability to handle records. Three type of records are supported: - Variable length records between 0-255 bytes, with a record size field of 1 bytes. - Variable length records between 0-65535 bytes, with a record size field of 2 bytes. - Fixed size records, which no record size field. - Preserve memory resource. - Performance! - Easy to use! This patch: Since most users want to have the kfifo as part of another object, reorganize the code to allow including struct kfifo in another data structure. This requires changing the kfifo_alloc and kfifo_init prototypes so that we pass an existing kfifo pointer into them. This patch changes the implementation and all existing users. [akpm@linux-foundation.org: fix warning] Signed-off-by: Stefani Seibold <stefani@seibold.net> Acked-by: Greg Kroah-Hartman <gregkh@suse.de> Acked-by: Mauro Carvalho Chehab <mchehab@redhat.com> Acked-by: Andi Kleen <ak@linux.intel.com> Acked-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-19kfifo: Use "const" definitionsAlan Cox
Currently kfifo cannot be used by parts of the kernel that use "const" properly as kfifo itself does not use const for passed data blocks which are indeed const. Signed-off-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-06-16kernel/kfifo.c: replace conditional test with is_power_of_2()Robert P. J. Day
Signed-off-by: Robert P. J. Day <rpjday@crashcourse.ca> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-16is_power_of_2: kernel/kfifo.cvignesh babu
Replace (n & (n-1)) with is_power_of_2() Signed-off-by: vignesh babu <vignesh.babu@wipro.com> Acked-by: Stelian Pop <stelian@popies.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-11[PATCH] Numerous fixes to kernel-doc info in source files.Robert P. J. Day
A variety of (mostly) innocuous fixes to the embedded kernel-doc content in source files, including: * make multi-line initial descriptions single line * denote some function names, constants and structs as such * change erroneous opening '/*' to '/**' in a few places * reword some text for clarity Signed-off-by: Robert P. J. Day <rpjday@mindspring.com> Cc: "Randy.Dunlap" <rdunlap@xenotime.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-09-29[PATCH] memory ordering in __kfifo primitivesPaul E. McKenney
Both __kfifo_put() and __kfifo_get() have header comments stating that if there is but one concurrent reader and one concurrent writer, locking is not necessary. This is almost the case, but a couple of memory barriers are needed. Another option would be to change the header comments to remove the bit about locking not being needed, and to change the those callers who currently don't use locking to add the required locking. The attachment analyzes this approach, but the patch below seems simpler. Signed-off-by: Paul E. McKenney <paulmck@us.ibm.com> Cc: Stelian Pop <stelian@popies.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-08[PATCH] gfp flags annotations - part 1Al Viro
- added typedef unsigned int __nocast gfp_t; - replaced __nocast uses for gfp flags with gfp_t - it gives exactly the same warnings as far as sparse is concerned, doesn't change generated code (from gcc point of view we replaced unsigned int with typedef) and documents what's going on far better. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
