path: root/kernel/kprobes.c
2017-05-25tracing/kprobes: Enforce kprobes teardown after testingThomas Gleixner
commit 30e7d894c1478c88d50ce94ddcdbd7f9763d9cdd upstream. Enabling the tracer selftest triggers occasionally the warning in text_poke(), which warns when the to be modified page is not marked reserved. The reason is that the tracer selftest installs kprobes on functions marked __init for testing. These probes are removed after the tests, but that removal schedules the delayed kprobes_optimizer work, which will do the actual text poke. If the work is executed after the init text is freed, then the warning triggers. The bug can be reproduced reliably when the work delay is increased. Flush the optimizer work and wait for the optimizing/unoptimizing lists to become empty before returning from the kprobes tracer selftest. That ensures that all operations which were queued due to the probes removal have completed. Link: http://lkml.kernel.org/r/20170516094802.76a468bb@gandalf.local.home Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: Masami Hiramatsu <mhiramat@kernel.org> Fixes: 6274de498 ("kprobes: Support delayed unoptimizing") Signed-off-by: Steven Rostedt (VMware) <rostedt@goodmis.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-10-11kprobes: include <asm/sections.h> instead of <asm-generic/sections.h>Christoph Hellwig
asm-generic headers are generic implementations for architecture specific code and should not be included by common code. Thus use the asm/ version of sections.h to get at the linker sections. Link: http://lkml.kernel.org/r/1473602302-6208-1-git-send-email-hch@lst.de Signed-off-by: Christoph Hellwig <hch@lst.de> Acked-by: Masami Hiramatsu <mhiramat@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-08-04perf/x86/hw_breakpoints: Disallow kernel breakpoints unless kprobe-safeAndy Lutomirski
Code on the kprobe blacklist doesn't want unexpected int3 exceptions. It probably doesn't want unexpected debug exceptions either. Be safe: disallow breakpoints in nokprobes code. On non-CONFIG_KPROBES kernels, there is no kprobe blacklist. In that case, disallow kernel breakpoints entirely. It will be particularly important to keep hw breakpoints out of the entry and NMI code once we move debug exceptions off the IST stack. Signed-off-by: Andy Lutomirski <luto@kernel.org> Signed-off-by: Peter Zijlstra (Intel) <peterz@infradead.org> Cc: Borislav Petkov <bp@alien8.de> Cc: Brian Gerst <brgerst@gmail.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Thomas Gleixner <tglx@linutronix.de> Link: http://lkml.kernel.org/r/e14b152af99640448d895e3c2a8c2d5ee19a1325.1438312874.git.luto@kernel.org Signed-off-by: Ingo Molnar <mingo@kernel.org>
2015-02-13kprobes: makes kprobes/enabled works correctly for optimized kprobes.Wang Nan
debugfs/kprobes/enabled doesn't work correctly on optimized kprobes. Masami Hiramatsu has a test report on x86_64 platform: https://lkml.org/lkml/2015/1/19/274 This patch forces it to unoptimize kprobe if kprobes_all_disarmed is set. It also checks the flag in unregistering path for skipping unneeded disarming process when kprobes globally disarmed. Signed-off-by: Wang Nan <wangnan0@huawei.com> Signed-off-by: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com> Cc: Ingo Molnar <mingo@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-02-13kprobes: set kprobes_all_disarmed earlier to enable re-optimization.Wang Nan
In original code, the probed instruction doesn't get optimized after echo 0 > /sys/kernel/debug/kprobes/enabled echo 1 > /sys/kernel/debug/kprobes/enabled This is because original code checks kprobes_all_disarmed in optimize_kprobe(), but this flag is turned off after calling that function. Therefore, optimize_kprobe() will see kprobes_all_disarmed == true and doesn't do the optimization. This patch simply turns off kprobes_all_disarmed earlier to enable optimization. Signed-off-by: Wang Nan <wangnan0@huawei.com> Signed-off-by: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com> Cc: Ingo Molnar <mingo@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-02-12Merge branch 'for-linus' of git://ftp.arm.linux.org.uk/~rmk/linux-armLinus Torvalds
Pull ARM updates from Russell King: - clang assembly fixes from Ard - optimisations and cleanups for Aurora L2 cache support - efficient L2 cache support for secure monitor API on Exynos SoCs - debug menu cleanup from Daniel Thompson to allow better behaviour for multiplatform kernels - StrongARM SA11x0 conversion to irq domains, and pxa_timer - kprobes updates for older ARM CPUs - move probes support out of arch/arm/kernel to arch/arm/probes - add inline asm support for the rbit (reverse bits) instruction - provide an ARM mode secondary CPU entry point (for Qualcomm CPUs) - remove the unused ARMv3 user access code - add driver_override support to AMBA Primecell bus * 'for-linus' of git://ftp.arm.linux.org.uk/~rmk/linux-arm: (55 commits) ARM: 8256/1: driver coamba: add device binding path 'driver_override' ARM: 8301/1: qcom: Use secondary_startup_arm() ARM: 8302/1: Add a secondary_startup that assumes ARM mode ARM: 8300/1: teach __asmeq that r11 == fp and r12 == ip ARM: kprobes: Fix compilation error caused by superfluous '*' ARM: 8297/1: cache-l2x0: optimize aurora range operations ARM: 8296/1: cache-l2x0: clean up aurora cache handling ARM: 8284/1: sa1100: clear RCSR_SMR on resume ARM: 8283/1: sa1100: collie: clear PWER register on machine init ARM: 8282/1: sa1100: use handle_domain_irq ARM: 8281/1: sa1100: move GPIO-related IRQ code to gpio driver ARM: 8280/1: sa1100: switch to irq_domain_add_simple() ARM: 8279/1: sa1100: merge both GPIO irqdomains ARM: 8278/1: sa1100: split irq handling for low GPIOs ARM: 8291/1: replace magic number with PAGE_SHIFT macro in fixup_pv code ARM: 8290/1: decompressor: fix a wrong comment ARM: 8286/1: mm: Fix dma_contiguous_reserve comment ARM: 8248/1: pm: remove outdated comment ARM: 8274/1: Fix DEBUG_LL for multi-platform kernels (without PL01X) ARM: 8273/1: Seperate DEBUG_UART_PHYS from DEBUG_LL on EP93XX ...
2015-01-20module: remove mod arg from module_free, rename module_memfree().Rusty Russell
Nothing needs the module pointer any more, and the next patch will call it from RCU, where the module itself might no longer exist. Removing the arg is the safest approach. This just codifies the use of the module_alloc/module_free pattern which ftrace and bpf use. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Acked-by: Alexei Starovoitov <ast@kernel.org> Cc: Mikael Starvik <starvik@axis.com> Cc: Jesper Nilsson <jesper.nilsson@axis.com> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Ley Foon Tan <lftan@altera.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Chris Metcalf <cmetcalf@ezchip.com> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: x86@kernel.org Cc: Ananth N Mavinakayanahalli <ananth@in.ibm.com> Cc: Anil S Keshavamurthy <anil.s.keshavamurthy@intel.com> Cc: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com> Cc: linux-cris-kernel@axis.com Cc: linux-kernel@vger.kernel.org Cc: linux-mips@linux-mips.org Cc: nios2-dev@lists.rocketboards.org Cc: linuxppc-dev@lists.ozlabs.org Cc: sparclinux@vger.kernel.org Cc: netdev@vger.kernel.org
2015-01-13kprobes: Pass the original kprobe for preparing optimized kprobeMasami Hiramatsu
Pass the original kprobe for preparing an optimized kprobe arch-dep part, since for some architecture (e.g. ARM32) requires the information in original kprobe. Signed-off-by: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com> Signed-off-by: Wang Nan <wangnan0@huawei.com> Signed-off-by: Jon Medhurst <tixy@linaro.org>
2014-12-11Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/s390/linux Pull s390 updates from Martin Schwidefsky: "The most notable change for this pull request is the ftrace rework from Heiko. It brings a small performance improvement and the ground work to support a new gcc option to replace the mcount blocks with a single nop. Two new s390 specific system calls are added to emulate user space mmio for PCI, an artifact of the how PCI memory is accessed. Two patches for the memory management with changes to common code. For KVM mm_forbids_zeropage is added which disables the empty zero page for an mm that is used by a KVM process. And an optimization, pmdp_get_and_clear_full is added analog to ptep_get_and_clear_full. Some micro optimization for the cmpxchg and the spinlock code. And as usual bug fixes and cleanups" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/s390/linux: (46 commits) s390/cputime: fix 31-bit compile s390/scm_block: make the number of reqs per HW req configurable s390/scm_block: handle multiple requests in one HW request s390/scm_block: allocate aidaw pages only when necessary s390/scm_block: use mempool to manage aidaw requests s390/eadm: change timeout value s390/mm: fix memory leak of ptlock in pmd_free_tlb s390: use local symbol names in entry[64].S s390/ptrace: always include vector registers in core files s390/simd: clear vector register pointer on fork/clone s390: translate cputime magic constants to macros s390/idle: convert open coded idle time seqcount s390/idle: add missing irq off lockdep annotation s390/debug: avoid function call for debug_sprintf_* s390/kprobes: fix instruction copy for out of line execution s390: remove diag 44 calls from cpu_relax() s390/dasd: retry partition detection s390/dasd: fix list corruption for sleep_on requests s390/dasd: fix infinite term I/O loop s390/dasd: remove unused code ...
2014-11-21kprobes: Add IPMODIFY flag to kprobe_ftrace_opsMasami Hiramatsu
Add FTRACE_OPS_FL_IPMODIFY flag to kprobe_ftrace_ops since kprobes can changes regs->ip. Link: http://lkml.kernel.org/r/20141121102523.11844.21298.stgit@localhost.localdomain Signed-off-by: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com> Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2014-10-27kprobes: introduce weak arch_check_ftrace_location() helper functionHeiko Carstens
Introduce weak arch_check_ftrace_location() helper function which architectures can override in order to implement handling of kprobes on function tracer call sites on their own, without depending on common code or implementing the KPROBES_ON_FTRACE feature. Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Acked-by: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com> Acked-by: Steven Rostedt <rostedt@goodmis.org> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2014-08-08kprobes: Skip kretprobe hit in NMI context to avoid deadlockMasami Hiramatsu
Skip kretprobe hit in NMI context, because if an NMI happens inside the critical section protected by kretprobe_table.lock and another(or same) kretprobe hit, pre_kretprobe_handler tries to lock kretprobe_table.lock again. Normal interrupts have no problem because they are disabled with the lock. Signed-off-by: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com> Acked-by: Ananth N Mavinakayanahalli <ananth@in.ibm.com> Cc: David S. Miller <davem@davemloft.net> Link: http://lkml.kernel.org/r/20140804031016.11433.65539.stgit@kbuild-fedora.novalocal [ Minor edits for clarity. ] Signed-off-by: Ingo Molnar <mingo@kernel.org>
2014-07-18kprobes: Fix "Failed to find blacklist" probing errors on ia64 and ppc64Masami Hiramatsu
On ia64 and ppc64, function pointers do not point to the entry address of the function, but to the address of a function descriptor (which contains the entry address and misc data). Since the kprobes code passes the function pointer stored by NOKPROBE_SYMBOL() to kallsyms_lookup_size_offset() for initalizing its blacklist, it fails and reports many errors, such as: Failed to find blacklist 0001013168300000 Failed to find blacklist 0001013000f0a000 [...] To fix this bug, use arch_deref_entry_point() to get the function entry address for kallsyms_lookup_size_offset() instead of the raw function pointer. Suzuki also pointed out that blacklist entries should also be updated as well. Reported-by: Tony Luck <tony.luck@gmail.com> Fixed-by: Suzuki K. Poulose <suzuki@in.ibm.com> Tested-by: Tony Luck <tony.luck@intel.com> Tested-by: Michael Ellerman <mpe@ellerman.id.au> Signed-off-by: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com> Acked-by: Michael Ellerman <mpe@ellerman.id.au> (for powerpc) Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Jeremy Fitzhardinge <jeremy@goop.org> Cc: sparse@chrisli.org Cc: Paul Mackerras <paulus@samba.org> Cc: akataria@vmware.com Cc: anil.s.keshavamurthy@intel.com Cc: Fenghua Yu <fenghua.yu@intel.com> Cc: Arnd Bergmann <arnd@arndb.de> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: Chris Wright <chrisw@sous-sol.org> Cc: yrl.pp-manager.tt@hitachi.com Cc: Kevin Hao <haokexin@gmail.com> Cc: Ananth N Mavinakayanahalli <ananth@in.ibm.com> Cc: rdunlap@infradead.org Cc: dl9pf@gmx.de Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: David S. Miller <davem@davemloft.net> Cc: linux-ia64@vger.kernel.org Cc: linuxppc-dev@lists.ozlabs.org Link: http://lkml.kernel.org/r/20140717114411.13401.2632.stgit@kbuild-fedora.novalocal Signed-off-by: Ingo Molnar <mingo@kernel.org>
2014-04-24kprobes: Show blacklist entries via debugfsMasami Hiramatsu
Show blacklist entries (function names with the address range) via /sys/kernel/debug/kprobes/blacklist. Note that at this point the blacklist supports only in vmlinux, not module. So the list is fixed and not updated. Signed-off-by: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com> Cc: Ananth N Mavinakayanahalli <ananth@in.ibm.com> Cc: Anil S Keshavamurthy <anil.s.keshavamurthy@intel.com> Cc: David S. Miller <davem@davemloft.net> Link: http://lkml.kernel.org/r/20140417081849.26341.11609.stgit@ltc230.yrl.intra.hitachi.co.jp Signed-off-by: Ingo Molnar <mingo@kernel.org>
2014-04-24kprobes: Use NOKPROBE_SYMBOL macro instead of __kprobesMasami Hiramatsu
Use NOKPROBE_SYMBOL macro to protect functions from kprobes instead of __kprobes annotation. Signed-off-by: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com> Reviewed-by: Steven Rostedt <rostedt@goodmis.org> Cc: Ananth N Mavinakayanahalli <ananth@in.ibm.com> Cc: Anil S Keshavamurthy <anil.s.keshavamurthy@intel.com> Cc: David S. Miller <davem@davemloft.net> Link: http://lkml.kernel.org/r/20140417081821.26341.40362.stgit@ltc230.yrl.intra.hitachi.co.jp Signed-off-by: Ingo Molnar <mingo@kernel.org>
2014-04-24kprobes: Allow probe on some kprobe functionsMasami Hiramatsu
There is no need to prohibit probing on the functions used for preparation, registeration, optimization, controll etc. Those are safely probed because those are not invoked from breakpoint/fault/debug handlers, there is no chance to cause recursive exceptions. Following functions are now removed from the kprobes blacklist: add_new_kprobe aggr_kprobe_disabled alloc_aggr_kprobe alloc_aggr_kprobe arm_all_kprobes __arm_kprobe arm_kprobe arm_kprobe_ftrace check_kprobe_address_safe collect_garbage_slots collect_garbage_slots collect_one_slot debugfs_kprobe_init __disable_kprobe disable_kprobe disarm_all_kprobes __disarm_kprobe disarm_kprobe disarm_kprobe_ftrace do_free_cleaned_kprobes do_optimize_kprobes do_unoptimize_kprobes enable_kprobe force_unoptimize_kprobe free_aggr_kprobe free_aggr_kprobe __free_insn_slot __get_insn_slot get_optimized_kprobe __get_valid_kprobe init_aggr_kprobe init_aggr_kprobe in_nokprobe_functions kick_kprobe_optimizer kill_kprobe kill_optimized_kprobe kprobe_addr kprobe_optimizer kprobe_queued kprobe_seq_next kprobe_seq_start kprobe_seq_stop kprobes_module_callback kprobes_open optimize_all_kprobes optimize_kprobe prepare_kprobe prepare_optimized_kprobe register_aggr_kprobe register_jprobe register_jprobes register_kprobe register_kprobes register_kretprobe register_kretprobe register_kretprobes register_kretprobes report_probe show_kprobe_addr try_to_optimize_kprobe unoptimize_all_kprobes unoptimize_kprobe unregister_jprobe unregister_jprobes unregister_kprobe __unregister_kprobe_bottom unregister_kprobes __unregister_kprobe_top unregister_kretprobe unregister_kretprobe unregister_kretprobes unregister_kretprobes wait_for_kprobe_optimizer I tested those functions by putting kprobes on all instructions in the functions with the bash script I sent to LKML. See: https://lkml.org/lkml/2014/3/27/33 Signed-off-by: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com> Link: http://lkml.kernel.org/r/20140417081753.26341.57889.stgit@ltc230.yrl.intra.hitachi.co.jp Cc: Ananth N Mavinakayanahalli <ananth@in.ibm.com> Cc: Anil S Keshavamurthy <anil.s.keshavamurthy@intel.com> Cc: David S. Miller <davem@davemloft.net> Cc: fche@redhat.com Cc: systemtap@sourceware.org Signed-off-by: Ingo Molnar <mingo@kernel.org>
2014-04-24kprobes: Introduce NOKPROBE_SYMBOL() macro to maintain kprobes blacklistMasami Hiramatsu
Introduce NOKPROBE_SYMBOL() macro which builds a kprobes blacklist at kernel build time. The usage of this macro is similar to EXPORT_SYMBOL(), placed after the function definition: NOKPROBE_SYMBOL(function); Since this macro will inhibit inlining of static/inline functions, this patch also introduces a nokprobe_inline macro for static/inline functions. In this case, we must use NOKPROBE_SYMBOL() for the inline function caller. When CONFIG_KPROBES=y, the macro stores the given function address in the "_kprobe_blacklist" section. Since the data structures are not fully initialized by the macro (because there is no "size" information), those are re-initialized at boot time by using kallsyms. Signed-off-by: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com> Link: http://lkml.kernel.org/r/20140417081705.26341.96719.stgit@ltc230.yrl.intra.hitachi.co.jp Cc: Alok Kataria <akataria@vmware.com> Cc: Ananth N Mavinakayanahalli <ananth@in.ibm.com> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Anil S Keshavamurthy <anil.s.keshavamurthy@intel.com> Cc: Arnd Bergmann <arnd@arndb.de> Cc: Christopher Li <sparse@chrisli.org> Cc: Chris Wright <chrisw@sous-sol.org> Cc: David S. Miller <davem@davemloft.net> Cc: Jan-Simon Möller <dl9pf@gmx.de> Cc: Jeremy Fitzhardinge <jeremy@goop.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Randy Dunlap <rdunlap@infradead.org> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: linux-arch@vger.kernel.org Cc: linux-doc@vger.kernel.org Cc: linux-sparse@vger.kernel.org Cc: virtualization@lists.linux-foundation.org Signed-off-by: Ingo Molnar <mingo@kernel.org>
2014-04-24kprobes: Prohibit probing on .entry.text codeMasami Hiramatsu
.entry.text is a code area which is used for interrupt/syscall entries, which includes many sensitive code. Thus, it is better to prohibit probing on all of such code instead of a part of that. Since some symbols are already registered on kprobe blacklist, this also removes them from the blacklist. Signed-off-by: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com> Reviewed-by: Steven Rostedt <rostedt@goodmis.org> Cc: Ananth N Mavinakayanahalli <ananth@in.ibm.com> Cc: Anil S Keshavamurthy <anil.s.keshavamurthy@intel.com> Cc: Borislav Petkov <bp@suse.de> Cc: David S. Miller <davem@davemloft.net> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Jan Kiszka <jan.kiszka@siemens.com> Cc: Jiri Kosina <jkosina@suse.cz> Cc: Jonathan Lebon <jlebon@redhat.com> Cc: Seiji Aguchi <seiji.aguchi@hds.com> Link: http://lkml.kernel.org/r/20140417081658.26341.57354.stgit@ltc230.yrl.intra.hitachi.co.jp Signed-off-by: Ingo Molnar <mingo@kernel.org>
2013-11-13kprobes: use KSYM_NAME_LEN to size identifier buffersJoe Mario
Use KSYM_NAME_LEN to size identifier buffers, so that it can be easier increased. Signed-off-by: Joe Mario <jmario@redhat.com> Signed-off-by: Andi Kleen <ak@linux.intel.com> Acked-by: Ananth N Mavinakayanahalli <ananth@in.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-09-11kprobes: allow to specify custom allocator for insn cachesHeiko Carstens
The current two insn slot caches both use module_alloc/module_free to allocate and free insn slot cache pages. For s390 this is not sufficient since there is the need to allocate insn slots that are either within the vmalloc module area or within dma memory. Therefore add a mechanism which allows to specify an own allocator for an own insn slot cache. Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Acked-by: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com> Cc: Ananth N Mavinakayanahalli <ananth@in.ibm.com> Cc: Ingo Molnar <mingo@kernel.org> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-09-11kprobes: unify insn cachesHeiko Carstens
The current kpropes insn caches allocate memory areas for insn slots with module_alloc(). The assumption is that the kernel image and module area are both within the same +/- 2GB memory area. This however is not true for s390 where the kernel image resides within the first 2GB (DMA memory area), but the module area is far away in the vmalloc area, usually somewhere close below the 4TB area. For new pc relative instructions s390 needs insn slots that are within +/- 2GB of each area. That way we can patch displacements of pc-relative instructions within the insn slots just like x86 and powerpc. The module area works already with the normal insn slot allocator, however there is currently no way to get insn slots that are within the first 2GB on s390 (aka DMA area). Therefore this patch set modifies the kprobes insn slot cache code in order to allow to specify a custom allocator for the insn slot cache pages. In addition architecure can now have private insn slot caches withhout the need to modify common code. Patch 1 unifies and simplifies the current insn and optinsn caches implementation. This is a preparation which allows to add more insn caches in a simple way. Patch 2 adds the possibility to specify a custom allocator. Patch 3 makes s390 use the new insn slot mechanisms and adds support for pc-relative instructions with long displacements. This patch (of 3): The two insn caches (insn, and optinsn) each have an own mutex and alloc/free functions (get_[opt]insn_slot() / free_[opt]insn_slot()). Since there is the need for yet another insn cache which satifies dma allocations on s390, unify and simplify the current implementation: - Move the per insn cache mutex into struct kprobe_insn_cache. - Move the alloc/free functions to kprobe.h so they are simply wrappers for the generic __get_insn_slot/__free_insn_slot functions. The implementation is done with a DEFINE_INSN_CACHE_OPS() macro which provides the alloc/free functions for each cache if needed. - move the struct kprobe_insn_cache to kprobe.h which allows to generate architecture specific insn slot caches outside of the core kprobes code. Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com> Cc: Ananth N Mavinakayanahalli <ananth@in.ibm.com> Cc: Ingo Molnar <mingo@kernel.org> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-07-03kprobes: handle empty/invalid input to debugfs "enabled" fileMathias Krause
When writing invalid input to 'debug/kprobes/enabled' it'll silently be ignored. Even worse, when writing an empty string to this file, the outcome is purely random as the switch statement will make its decision based on the value of an uninitialized stack variable. Fix this by handling invalid/empty input as error returning -EINVAL. Signed-off-by: Mathias Krause <minipli@googlemail.com> Cc: Ananth N Mavinakayanahalli <ananth@in.ibm.com> Cc: Anil S Keshavamurthy <anil.s.keshavamurthy@intel.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-05-28kprobes: Fix to free gone and unused optprobesMasami Hiramatsu
Fix to free gone and unused optprobes. This bug will cause a kernel panic if the user reuses the killed and unused probe. Reported at: http://sourceware.org/ml/systemtap/2013-q2/msg00142.html In the normal path, an optprobe on an init function is unregistered when a module goes live. unregister_kprobe(kp) -> __unregister_kprobe_top ->__disable_kprobe ->disarm_kprobe(ap == op) ->__disarm_kprobe ->unoptimize_kprobe : the op is queued on unoptimizing_list and do nothing in __unregister_kprobe_bottom After a while (usually wait 5 jiffies), kprobe_optimizer runs to unoptimize and free optprobe. kprobe_optimizer ->do_unoptimize_kprobes ->arch_unoptimize_kprobes : moved to free_list ->do_free_cleaned_kprobes ->hlist_del: the op is removed ->free_aggr_kprobe ->arch_remove_optimized_kprobe ->arch_remove_kprobe ->kfree: the op is freed Here, if kprobes_module_callback is called and the delayed unoptimizing probe is picked BEFORE kprobe_optimizer runs, kprobes_module_callback ->kill_kprobe ->kill_optimized_kprobe : dequeued from unoptimizing_list <=!!! ->arch_remove_optimized_kprobe ->arch_remove_kprobe (but op is not freed, and on the kprobe hash table) This doesn't happen if the probe unregistration is done AFTER kprobes_module_callback is called (because at that time the op is gone), and kprobe-tracer does it. To fix this bug, this patch changes kprobes_module_callback to enqueue the op to freeing_list at kill_optimized_kprobe only if the op is unused. The unused probes on freeing_list will be freed in do_free_cleaned_kprobes. Note that this calls arch_remove_*kprobe twice on the same probe. Thus those functions have to check the double free. Fortunately, most of arch codes already checked that except for mips. This will be fixed in the next patch. Signed-off-by: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com> Cc: Timo Juhani Lindfors <timo.lindfors@iki.fi> Cc: Ananth N Mavinakayanahalli <ananth@in.ibm.com> Cc: Anil S Keshavamurthy <anil.s.keshavamurthy@intel.com> Cc: Frank Ch. Eigler <fche@redhat.com> Cc: systemtap@sourceware.org Cc: yrl.pp-manager.tt@hitachi.com Cc: David S. Miller <davem@davemloft.net> Cc: "David S. Miller" <davem@davemloft.net> Link: http://lkml.kernel.org/r/20130522093409.9084.63554.stgit@mhiramat-M0-7522 [ Minor edits. ] Signed-off-by: Ingo Molnar <mingo@kernel.org>
2013-04-18kprobes: Fix a double lock bug of kprobe_mutexMasami Hiramatsu
Fix a double locking bug caused when debug.kprobe-optimization=0. While the proc_kprobes_optimization_handler locks kprobe_mutex, wait_for_kprobe_optimizer locks it again and that causes a double lock. To fix the bug, this introduces different mutex for protecting sysctl parameter and locks it in proc_kprobes_optimization_handler. Of course, since we need to lock kprobe_mutex when touching kprobes resources, that is done in *optimize_all_kprobes(). This bug was introduced by commit ad72b3bea744 ("kprobes: fix wait_for_kprobe_optimizer()") Signed-off-by: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com> Acked-by: Ananth N Mavinakayanahalli <ananth@in.ibm.com> Cc: Ingo Molnar <mingo@redhat.com> Cc: Tejun Heo <tj@kernel.org> Cc: "David S. Miller" <davem@davemloft.net> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-02-27hlist: drop the node parameter from iteratorsSasha Levin
I'm not sure why, but the hlist for each entry iterators were conceived list_for_each_entry(pos, head, member) The hlist ones were greedy and wanted an extra parameter: hlist_for_each_entry(tpos, pos, head, member) Why did they need an extra pos parameter? I'm not quite sure. Not only they don't really need it, it also prevents the iterator from looking exactly like the list iterator, which is unfortunate. Besides the semantic patch, there was some manual work required: - Fix up the actual hlist iterators in linux/list.h - Fix up the declaration of other iterators based on the hlist ones. - A very small amount of places were using the 'node' parameter, this was modified to use 'obj->member' instead. - Coccinelle didn't handle the hlist_for_each_entry_safe iterator properly, so those had to be fixed up manually. The semantic patch which is mostly the work of Peter Senna Tschudin is here: @@ iterator name hlist_for_each_entry, hlist_for_each_entry_continue, hlist_for_each_entry_from, hlist_for_each_entry_rcu, hlist_for_each_entry_rcu_bh, hlist_for_each_entry_continue_rcu_bh, for_each_busy_worker, ax25_uid_for_each, ax25_for_each, inet_bind_bucket_for_each, sctp_for_each_hentry, sk_for_each, sk_for_each_rcu, sk_for_each_from, sk_for_each_safe, sk_for_each_bound, hlist_for_each_entry_safe, hlist_for_each_entry_continue_rcu, nr_neigh_for_each, nr_neigh_for_each_safe, nr_node_for_each, nr_node_for_each_safe, for_each_gfn_indirect_valid_sp, for_each_gfn_sp, for_each_host; type T; expression a,c,d,e; identifier b; statement S; @@ -T b; <+... when != b ( hlist_for_each_entry(a, - b, c, d) S | hlist_for_each_entry_continue(a, - b, c) S | hlist_for_each_entry_from(a, - b, c) S | hlist_for_each_entry_rcu(a, - b, c, d) S | hlist_for_each_entry_rcu_bh(a, - b, c, d) S | hlist_for_each_entry_continue_rcu_bh(a, - b, c) S | for_each_busy_worker(a, c, - b, d) S | ax25_uid_for_each(a, - b, c) S | ax25_for_each(a, - b, c) S | inet_bind_bucket_for_each(a, - b, c) S | sctp_for_each_hentry(a, - b, c) S | sk_for_each(a, - b, c) S | sk_for_each_rcu(a, - b, c) S | sk_for_each_from -(a, b) +(a) S + sk_for_each_from(a) S | sk_for_each_safe(a, - b, c, d) S | sk_for_each_bound(a, - b, c) S | hlist_for_each_entry_safe(a, - b, c, d, e) S | hlist_for_each_entry_continue_rcu(a, - b, c) S | nr_neigh_for_each(a, - b, c) S | nr_neigh_for_each_safe(a, - b, c, d) S | nr_node_for_each(a, - b, c) S | nr_node_for_each_safe(a, - b, c, d) S | - for_each_gfn_sp(a, c, d, b) S + for_each_gfn_sp(a, c, d) S | - for_each_gfn_indirect_valid_sp(a, c, d, b) S + for_each_gfn_indirect_valid_sp(a, c, d) S | for_each_host(a, - b, c) S | for_each_host_safe(a, - b, c, d) S | for_each_mesh_entry(a, - b, c, d) S ) ...+> [akpm@linux-foundation.org: drop bogus change from net/ipv4/raw.c] [akpm@linux-foundation.org: drop bogus hunk from net/ipv6/raw.c] [akpm@linux-foundation.org: checkpatch fixes] [akpm@linux-foundation.org: fix warnings] [akpm@linux-foudnation.org: redo intrusive kvm changes] Tested-by: Peter Senna Tschudin <peter.senna@gmail.com> Acked-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Signed-off-by: Sasha Levin <sasha.levin@oracle.com> Cc: Wu Fengguang <fengguang.wu@intel.com> Cc: Marcelo Tosatti <mtosatti@redhat.com> Cc: Gleb Natapov <gleb@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-02-19Merge branch 'for-3.9-cleanups' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tj/wq Pull workqueue [delayed_]work_pending() cleanups from Tejun Heo: "This is part of on-going cleanups to remove / minimize usages of workqueue interfaces which are deprecated and/or misleading. This round drops a number of usages of [delayed_]work_pending(), which are dangerous as they lack any form of synchronization and thus often lead to buggy / unnecessary code. There are a couple legitimate use cases in kernel. Hopefully, they can be converted and [delayed_]work_pending() can be removed completely. Even if not, removing most of misuses should make it more difficult to find examples of misuses and thus slow down growth of them. These changes are independent from other workqueue changes." * 'for-3.9-cleanups' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/wq: wimax/i2400m: fix i2400m->wake_tx_skb handling kprobes: fix wait_for_kprobe_optimizer() ipw2x00: simplify scan_event handling video/exynos: don't use [delayed_]work_pending() tty/max3100: don't use [delayed_]work_pending() x86/mce: don't use [delayed_]work_pending() rfkill: don't use [delayed_]work_pending() wl1251: don't use [delayed_]work_pending() thinkpad_acpi: don't use [delayed_]work_pending() mwifiex: don't use [delayed_]work_pending() sja1000: don't use [delayed_]work_pending()
2013-02-09kprobes: fix wait_for_kprobe_optimizer()Tejun Heo
wait_for_kprobe_optimizer() seems largely broken. It uses optimizer_comp which is never re-initialized, so wait_for_kprobe_optimizer() will never wait for anything once kprobe_optimizer() finishes all pending jobs for the first time. Also, aside from completion, delayed_work_pending() is %false once kprobe_optimizer() starts execution and wait_for_kprobe_optimizer() won't wait for it. Reimplement it so that it flushes optimizing_work until [un]optimizing_lists are empty. Note that this also makes optimizing_work execute immediately if someone's waiting for it, which is the nicer behavior. Only compile tested. Signed-off-by: Tejun Heo <tj@kernel.org> Acked-by: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com> Cc: Ananth N Mavinakayanahalli <ananth@in.ibm.com> Cc: Anil S Keshavamurthy <anil.s.keshavamurthy@intel.com> Cc: "David S. Miller" <davem@davemloft.net>
2013-01-21kprobes/x86: Move ftrace-based kprobe code into kprobes-ftrace.cMasami Hiramatsu
Split ftrace-based kprobes code from kprobes, and introduce CONFIG_(HAVE_)KPROBES_ON_FTRACE Kconfig flags. For the cleanup reason, this also moves kprobe_ftrace check into skip_singlestep. Link: http://lkml.kernel.org/r/20120928081520.3560.25624.stgit@ltc138.sdl.hitachi.co.jp Cc: Ingo Molnar <mingo@elte.hu> Cc: Ananth N Mavinakayanahalli <ananth@in.ibm.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@redhat.com> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Signed-off-by: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com> Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2012-09-13kprobes/x86: Fix to support jprobes on ftrace-based kprobeMasami Hiramatsu
Fix kprobes/x86 to support jprobes on ftrace-based kprobes. Because of -mfentry support of ftrace, ftrace is now put on the beginning of function where jprobes are put. Originally ftrace-based kprobes doesn't support jprobe because it will change regs->ip and ftrace doesn't support changing IP and ftrace itself doesn't conflict jprobe. However, ftrace -mfentry support moves mcount call on the top of functions where jprobes are put. This means that jprobe always conflicts with ftrace-based kprobe and fails. This patch allows ftrace-based kprobes to support jprobes by allowing to modify regs->ip and kprobes breakpoint handler also allows to skip singlestepping because there is a ftrace call (not an original instruction). Link: http://lkml.kernel.org/r/20120905143125.10329.90836.stgit@localhost.localdomain Reported-by: Fengguang Wu <fengguang.wu@intel.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: "H. Peter Anvin" <hpa@zytor.com> Signed-off-by: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com> Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2012-07-31kprobes/x86: ftrace based optimization for x86Masami Hiramatsu
Add function tracer based kprobe optimization support handlers on x86. This allows kprobes to use function tracer for probing on mcount call. Link: http://lkml.kernel.org/r/20120605102838.27845.26317.stgit@localhost.localdomain Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@redhat.com> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: Ananth N Mavinakayanahalli <ananth@in.ibm.com> Cc: "Frank Ch. Eigler" <fche@redhat.com> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Frederic Weisbecker <fweisbec@gmail.com> Signed-off-by: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com> [ Updated to new port of ftrace save regs functions ] Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2012-07-31kprobes: introduce ftrace based optimizationMasami Hiramatsu
Introduce function trace based kprobes optimization. With using ftrace optimization, kprobes on the mcount calling address, use ftrace's mcount call instead of breakpoint. Furthermore, this optimization works with preemptive kernel not like as current jump-based optimization. Of cource, this feature works only if the probe is on mcount call. Only if kprobe.break_handler is set, that probe is not optimized with ftrace (nor put on ftrace). The reason why this limitation comes is that this break_handler may be used only from jprobes which changes ip address (for fetching the function arguments), but function tracer ignores modified ip address. Changes in v2: - Fix ftrace_ops registering right after setting its filter. - Unregister ftrace_ops if there is no kprobe using. - Remove notrace dependency from __kprobes macro. Link: http://lkml.kernel.org/r/20120605102832.27845.63461.stgit@localhost.localdomain Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@redhat.com> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: Ananth N Mavinakayanahalli <ananth@in.ibm.com> Cc: "Frank Ch. Eigler" <fche@redhat.com> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Frederic Weisbecker <fweisbec@gmail.com> Signed-off-by: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com> Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2012-07-31kprobes: Move locks into appropriate functionsMasami Hiramatsu
Break a big critical region into fine-grained pieces at registering kprobe path. This helps us to solve circular locking dependency when introducing ftrace-based kprobes. Link: http://lkml.kernel.org/r/20120605102826.27845.81689.stgit@localhost.localdomain Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@redhat.com> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: Ananth N Mavinakayanahalli <ananth@in.ibm.com> Cc: "Frank Ch. Eigler" <fche@redhat.com> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Frederic Weisbecker <fweisbec@gmail.com> Signed-off-by: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com> Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2012-07-31kprobes: cleanup to separate probe-able checkMasami Hiramatsu
Separate probe-able address checking code from register_kprobe(). Link: http://lkml.kernel.org/r/20120605102820.27845.90133.stgit@localhost.localdomain Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@redhat.com> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: Ananth N Mavinakayanahalli <ananth@in.ibm.com> Cc: "Frank Ch. Eigler" <fche@redhat.com> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Frederic Weisbecker <fweisbec@gmail.com> Signed-off-by: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com> Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2012-07-31kprobes: Inverse taking of module_mutex with kprobe_mutexSteven Rostedt
Currently module_mutex is taken before kprobe_mutex, but this can cause issues when we have kprobes register ftrace, as the ftrace mutex is taken before enabling a tracepoint, which currently takes the module mutex. If module_mutex is taken before kprobe_mutex, then we can not have kprobes use the ftrace infrastructure. There seems to be no reason that the kprobe_mutex can't be taken before the module_mutex. Running lockdep shows that it is safe among the kernels I've run. Link: http://lkml.kernel.org/r/20120605102814.27845.21047.stgit@localhost.localdomain Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@redhat.com> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: Ananth N Mavinakayanahalli <ananth@in.ibm.com> Cc: "Frank Ch. Eigler" <fche@redhat.com> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com> Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2012-03-05kprobes: return proper error code from register_kprobe()Prashanth Nageshappa
register_kprobe() aborts if the address of the new request falls in a prohibited area (such as ftrace pouch, __kprobes annotated functions, non-kernel text addresses, jump label text). We however don't return the right error on this abort, resulting in a silent failure - incorrect adding/reporting of kprobes ('perf probe do_fork+18' or 'perf probe mcount' for instance). In V2 we are incorporating Masami Hiramatsu's feedback. This patch fixes it by returning -EINVAL upon failure. While we are here, rename the label used for exit to be more appropriate. Signed-off-by: Ananth N Mavinakayanahalli <ananth@in.ibm.com> Signed-off-by: Prashanth K Nageshappa <prashanth@linux.vnet.ibm.com> Acked-by: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com> Cc: Jason Baron <jbaron@redhat.com> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-02-03kprobes: fix a memory leak in function pre_handler_kretprobe()Jiang Liu
In function pre_handler_kretprobe(), the allocated kretprobe_instance object will get leaked if the entry_handler callback returns non-zero. This may cause all the preallocated kretprobe_instance objects exhausted. This issue can be reproduced by changing samples/kprobes/kretprobe_example.c to probe "mutex_unlock". And the fix is straightforward: just put the allocated kretprobe_instance object back onto the free_instances list. [akpm@linux-foundation.org: use raw_spin_lock/unlock] Signed-off-by: Jiang Liu <jiang.liu@huawei.com> Acked-by: Jim Keniston <jkenisto@us.ibm.com> Acked-by: Ananth N Mavinakayanahalli <ananth@in.ibm.com> Cc: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com> Cc: Anil S Keshavamurthy <anil.s.keshavamurthy@intel.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-01-23kprobes: initialize before using a hlistAnanth N Mavinakayanahalli
Commit ef53d9c5e ("kprobes: improve kretprobe scalability with hashed locking") introduced a bug where we can potentially leak kretprobe_instances since we initialize a hlist head after having used it. Initialize the hlist head before using it. Reported by: Jim Keniston <jkenisto@us.ibm.com> Acked-by: Jim Keniston <jkenisto@us.ibm.com> Signed-off-by: Ananth N Mavinakayanahalli <ananth@in.ibm.com> Acked-by: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com> Cc: Srinivasa D S <srinivasa@in.ibm.com> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-01-12kprobes: silence DEBUG_STRICT_USER_COPY_CHECKS=y warningStephen Boyd
Enabling DEBUG_STRICT_USER_COPY_CHECKS causes the following warning: In file included from arch/x86/include/asm/uaccess.h:573, from kernel/kprobes.c:55: In function 'copy_from_user', inlined from 'write_enabled_file_bool' at kernel/kprobes.c:2191: arch/x86/include/asm/uaccess_64.h:65: warning: call to 'copy_from_user_overflow' declared with attribute warning: copy_from_user() buffer size is not provably correct presumably due to buf_size being signed causing GCC to fail to see that buf_size can't become negative. Signed-off-by: Stephen Boyd <sboyd@codeaurora.org> Cc: Ananth N Mavinakayanahalli <ananth@in.ibm.com> Cc: Anil S Keshavamurthy <anil.s.keshavamurthy@intel.com> Cc: David S. Miller <davem@davemloft.net> Acked-by: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-10-31kernel: Map most files to use export.h instead of module.hPaul Gortmaker
The changed files were only including linux/module.h for the EXPORT_SYMBOL infrastructure, and nothing else. Revector them onto the isolated export header for faster compile times. Nothing to see here but a whole lot of instances of: -#include <linux/module.h> +#include <linux/export.h> This commit is only changing the kernel dir; next targets will probably be mm, fs, the arch dirs, etc. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2011-09-13locking, kprobes: Annotate the hash locks and kretprobe.lock as rawThomas Gleixner
The kprobe locks can be taken in atomic context and therefore cannot be preempted on -rt - annotate it. In mainline this change documents the low level nature of the lock - otherwise there's no functional difference. Lockdep and Sparse checking will work as usual. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-07-15kprobes: Return -ENOENT if probe point doesn't existMasami Hiramatsu
Return -ENOENT if probe point doesn't exist, but still returns -EINVAL if both of kprobe->addr and kprobe->symbol_name are specified or both are not specified. Acked-by: Ananth N Mavinakayanahalli <ananth@in.ibm.com> Signed-off-by: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com> Cc: Ananth N Mavinakayanahalli <ananth@in.ibm.com> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Anil S Keshavamurthy <anil.s.keshavamurthy@intel.com> Cc: "David S. Miller" <davem@davemloft.net> Link: http://lkml.kernel.org/r/20110627072650.6528.67329.stgit@fedora15 Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2011-01-07Merge branch 'for-2.6.38' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tj/percpu * 'for-2.6.38' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/percpu: (30 commits) gameport: use this_cpu_read instead of lookup x86: udelay: Use this_cpu_read to avoid address calculation x86: Use this_cpu_inc_return for nmi counter x86: Replace uses of current_cpu_data with this_cpu ops x86: Use this_cpu_ops to optimize code vmstat: User per cpu atomics to avoid interrupt disable / enable irq_work: Use per cpu atomics instead of regular atomics cpuops: Use cmpxchg for xchg to avoid lock semantics x86: this_cpu_cmpxchg and this_cpu_xchg operations percpu: Generic this_cpu_cmpxchg() and this_cpu_xchg support percpu,x86: relocate this_cpu_add_return() and friends connector: Use this_cpu operations xen: Use this_cpu_inc_return taskstats: Use this_cpu_ops random: Use this_cpu_inc_return fs: Use this_cpu_inc_return in buffer.c highmem: Use this_cpu_xx_return() operations vmstat: Use this_cpu_inc_return for vm statistics x86: Support for this_cpu_add, sub, dec, inc_return percpu: Generic support for this_cpu_add, sub, dec, inc_return ... Fixed up conflicts: in arch/x86/kernel/{apic/nmi.c, apic/x2apic_uv_x.c, process.c} as per Tejun.
2010-12-17kprobes: Use this_cpu_opsChristoph Lameter
Use this_cpu ops in various places to optimize per cpu data access. Cc: Jason Baron <jbaron@redhat.com> Cc: Namhyung Kim <namhyung@gmail.com> Acked-by: H. Peter Anvin <hpa@zytor.com> Signed-off-by: Christoph Lameter <cl@linux.com> Signed-off-by: Tejun Heo <tj@kernel.org>
2010-12-06kprobes: Use text_poke_smp_batch for unoptimizingMasami Hiramatsu
Use text_poke_smp_batch() on unoptimization path for reducing the number of stop_machine() issues. If the number of unoptimizing probes is more than MAX_OPTIMIZE_PROBES(=256), kprobes unoptimizes first MAX_OPTIMIZE_PROBES probes and kicks optimizer for remaining probes. Signed-off-by: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ananth N Mavinakayanahalli <ananth@in.ibm.com> Cc: Jason Baron <jbaron@redhat.com> Cc: Mathieu Desnoyers <mathieu.desnoyers@efficios.com> Cc: 2nddept-manager@sdl.hitachi.co.jp Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Steven Rostedt <rostedt@goodmis.org> LKML-Reference: <20101203095434.2961.22657.stgit@ltc236.sdl.hitachi.co.jp> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-12-06kprobes: Use text_poke_smp_batch for optimizingMasami Hiramatsu
Use text_poke_smp_batch() in optimization path for reducing the number of stop_machine() issues. If the number of optimizing probes is more than MAX_OPTIMIZE_PROBES(=256), kprobes optimizes first MAX_OPTIMIZE_PROBES probes and kicks optimizer for remaining probes. Changes in v5: - Use kick_kprobe_optimizer() instead of directly calling schedule_delayed_work(). - Rescheduling optimizer outside of kprobe mutex lock. Changes in v2: - Allocate code buffer and parameters in arch_init_kprobes() instead of using static arraies. - Merge previous max optimization limit patch into this patch. So, this patch introduces upper limit of optimization at once. Signed-off-by: Masami Hiramatsu <mhiramat@redhat.com> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ananth N Mavinakayanahalli <ananth@in.ibm.com> Cc: Jason Baron <jbaron@redhat.com> Cc: Mathieu Desnoyers <mathieu.desnoyers@efficios.com> Cc: 2nddept-manager@sdl.hitachi.co.jp Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Steven Rostedt <rostedt@goodmis.org> LKML-Reference: <20101203095428.2961.8994.stgit@ltc236.sdl.hitachi.co.jp> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-12-06kprobes: Reuse unused kprobeMasami Hiramatsu
Reuse unused (waiting for unoptimizing and no user handler) kprobe on given address instead of returning -EBUSY for registering a new kprobe. Signed-off-by: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ananth N Mavinakayanahalli <ananth@in.ibm.com> Cc: Jason Baron <jbaron@redhat.com> Cc: Mathieu Desnoyers <mathieu.desnoyers@efficios.com> Cc: 2nddept-manager@sdl.hitachi.co.jp LKML-Reference: <20101203095416.2961.39080.stgit@ltc236.sdl.hitachi.co.jp> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-12-06kprobes: Support delayed unoptimizingMasami Hiramatsu
Unoptimization occurs when a probe is unregistered or disabled, and is heavy because it recovers instructions by using stop_machine(). This patch delays unoptimization operations and unoptimize several probes at once by using text_poke_smp_batch(). This can avoid unexpected system slowdown coming from stop_machine(). Changes in v5: - Split this patch into several cleanup patches and this patch. - Fix some text_mutex lock miss. - Use bool instead of int for behavior flags. - Add additional comment for (un)optimizing path. Changes in v2: - Use dynamic allocated buffers and params. Signed-off-by: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ananth N Mavinakayanahalli <ananth@in.ibm.com> Cc: Jason Baron <jbaron@redhat.com> Cc: Mathieu Desnoyers <mathieu.desnoyers@efficios.com> Cc: 2nddept-manager@sdl.hitachi.co.jp LKML-Reference: <20101203095409.2961.82733.stgit@ltc236.sdl.hitachi.co.jp> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-12-06kprobes: Separate kprobe optimizing code from optimizerMasami Hiramatsu
Separate kprobe optimizing code from optimizer, this will make easy to introducing unoptimizing code in optimizer. Signed-off-by: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ananth N Mavinakayanahalli <ananth@in.ibm.com> Cc: Jason Baron <jbaron@redhat.com> Cc: Mathieu Desnoyers <mathieu.desnoyers@efficios.com> Cc: 2nddept-manager@sdl.hitachi.co.jp LKML-Reference: <20101203095403.2961.91201.stgit@ltc236.sdl.hitachi.co.jp> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-12-06kprobes: Cleanup disabling and unregistering pathMasami Hiramatsu
Merge disabling kprobe to unregistering kprobe function and add comments for disabing/unregistring process. Current unregistering code disables(disarms) kprobes after checking target kprobe status. This patch changes it to disabling kprobe first after that it changing the kprobe's state. This allows to share probe disabling code between disable_kprobe() and unregister_kprobe(). Signed-off-by: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ananth N Mavinakayanahalli <ananth@in.ibm.com> Cc: Jason Baron <jbaron@redhat.com> Cc: Mathieu Desnoyers <mathieu.desnoyers@efficios.com> Cc: 2nddept-manager@sdl.hitachi.co.jp LKML-Reference: <20101203095356.2961.30152.stgit@ltc236.sdl.hitachi.co.jp> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-12-06kprobes: Rename old_p to more appropriate nameMasami Hiramatsu
Rename irrelevant uses of "old_p" to more appropriate names. Originally, "old_p" just meant "the old kprobe on given address" but current code uses that name as "just another kprobe" or something like that. This patch renames those pointer names to more appropriate one for maintainability. Signed-off-by: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ananth N Mavinakayanahalli <ananth@in.ibm.com> Cc: Jason Baron <jbaron@redhat.com> Cc: Mathieu Desnoyers <mathieu.desnoyers@efficios.com> Cc: 2nddept-manager@sdl.hitachi.co.jp LKML-Reference: <20101203095350.2961.48110.stgit@ltc236.sdl.hitachi.co.jp> Signed-off-by: Ingo Molnar <mingo@elte.hu>
