path: root/kernel/kprobes.c
2009-07-30kprobes: Use kernel_text_address() for checking probe addressMasami Hiramatsu
Use kernel_text_address() for checking probe address instead of __kernel_text_address(), because __kernel_text_address() returns true for init functions even after relaseing those functions. That will hit a BUG() in text_poke(). Signed-off-by: Masami Hiramatsu <mhiramat@redhat.com> Cc: Ananth N Mavinakayanahalli <ananth@in.ibm.com> Cc: Jim Keniston <jkenisto@us.ibm.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-07-01kprobes: No need to unlock kprobe_insn_mutexMasami Hiramatsu
Remove needless kprobe_insn_mutex unlocking during safety check in garbage collection, because if someone releases a dirty slot during safety check (which ensures other cpus doesn't execute all dirty slots), the safety check must be fail. So, we need to hold the mutex while checking safety. Signed-off-by: Masami Hiramatsu <mhiramat@redhat.com> Cc: Ananth N Mavinakayanahalli <ananth@in.ibm.com> Cc: Jim Keniston <jkenisto@us.ibm.com> Cc: Ananth N Mavinakayanahalli <ananth@in.ibm.com> LKML-Reference: <20090630210809.17851.28781.stgit@localhost.localdomain> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-05-08kprobes: fix to use text_mutex around arm/disarm kprobeMasami Hiramatsu
Fix kprobes to lock text_mutex around some arch_arm/disarm_kprobe() which are newly added by commit de5bd88d5a5cce3cacea904d3503e5ebdb3852a2. Signed-off-by: Masami Hiramatsu <mhiramat@redhat.com> Acked-by: Ananth N Mavinakayanahalli <ananth@in.ibm.com> Cc: Mathieu Desnoyers <mathieu.desnoyers@polymtl.ca> Cc: Jim Keniston <jkenisto@us.ibm.com> Cc: Ingo Molnar <mingo@elte.hu> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-07kprobes: support per-kprobe disablingMasami Hiramatsu
Add disable_kprobe() and enable_kprobe() to disable/enable kprobes temporarily. disable_kprobe() asynchronously disables probe handlers of specified kprobe. So, after calling it, some handlers can be called at a while. enable_kprobe() enables specified kprobe. aggr_pre_handler and aggr_post_handler check disabled probes. On the other hand aggr_break_handler and aggr_fault_handler don't check it because these handlers will be called while executing pre or post handlers and usually those help error handling. Signed-off-by: Masami Hiramatsu <mhiramat@redhat.com> Acked-by: Ananth N Mavinakayanahalli <ananth@in.ibm.com> Cc: Anil S Keshavamurthy <anil.s.keshavamurthy@intel.com> Cc: David S. Miller <davem@davemloft.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-07kprobes: rename kprobe_enabled to kprobes_all_disarmedMasami Hiramatsu
Rename kprobe_enabled to kprobes_all_disarmed and invert logic due to avoiding naming confusion from per-probe disabling. Signed-off-by: Masami Hiramatsu <mhiramat@redhat.com> Acked-by: Ananth N Mavinakayanahalli <ananth@in.ibm.com> Cc: Anil S Keshavamurthy <anil.s.keshavamurthy@intel.com> Cc: David S. Miller <davem@davemloft.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-07kprobes: move EXPORT_SYMBOL_GPL just after function definitionsMasami Hiramatsu
Clean up positions of EXPORT_SYMBOL_GPL in kernel/kprobes.c according to checkpatch.pl. Signed-off-by: Masami Hiramatsu <mhiramat@redhat.com> Acked-by: Ananth N Mavinakayanahalli <ananth@in.ibm.com> Cc: Anil S Keshavamurthy <anil.s.keshavamurthy@intel.com> Cc: David S. Miller <davem@davemloft.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-07kprobes: cleanup aggr_kprobe related codeMasami Hiramatsu
Currently, kprobes can disable all probes at once, but can't disable it individually (not unregister, just disable an kprobe, because unregistering needs to wait for scheduler synchronization). These patches introduce APIs for on-the-fly per-probe disabling and re-enabling by dis-arming/re-arming its breakpoint instruction. This patch: Change old_p to ap in add_new_kprobe() for readability, copy flags member in add_aggr_kprobe(), and simplify the code flow of register_aggr_kprobe(). Signed-off-by: Masami Hiramatsu <mhiramat@redhat.com> Acked-by: Ananth N Mavinakayanahalli <ananth@in.ibm.com> Cc: Anil S Keshavamurthy <anil.s.keshavamurthy@intel.com> Cc: David S. Miller <davem@davemloft.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-03-18kprobes: Fix locking imbalance in kretprobesAnanth N Mavinakayanahalli
Fix locking imbalance in kretprobes: ===================================== [ BUG: bad unlock balance detected! ] ------------------------------------- kthreadd/2 is trying to release lock (&rp->lock) at: [<c06b3080>] pre_handler_kretprobe+0xea/0xf4 but there are no more locks to release! other info that might help us debug this: 1 lock held by kthreadd/2: #0: (rcu_read_lock){..--}, at: [<c06b2b24>] __atomic_notifier_call_chain+0x0/0x5a stack backtrace: Pid: 2, comm: kthreadd Not tainted 2.6.29-rc8 #1 Call Trace: [<c06ae498>] ? printk+0xf/0x17 [<c06b3080>] ? pre_handler_kretprobe+0xea/0xf4 [<c044ce6c>] print_unlock_inbalance_bug+0xc3/0xce [<c0444d4b>] ? clocksource_read+0x7/0xa [<c04450a4>] ? getnstimeofday+0x5f/0xf6 [<c044a9ca>] ? register_lock_class+0x17/0x293 [<c044b72c>] ? mark_lock+0x1e/0x30b [<c0448956>] ? tick_dev_program_event+0x4a/0xbc [<c0498100>] ? __slab_alloc+0xa5/0x415 [<c06b2fbe>] ? pre_handler_kretprobe+0x28/0xf4 [<c06b3080>] ? pre_handler_kretprobe+0xea/0xf4 [<c044cf1b>] lock_release_non_nested+0xa4/0x1a5 [<c06b3080>] ? pre_handler_kretprobe+0xea/0xf4 [<c044d15d>] lock_release+0x141/0x166 [<c06b07dd>] _spin_unlock_irqrestore+0x19/0x50 [<c06b3080>] pre_handler_kretprobe+0xea/0xf4 [<c06b20b5>] kprobe_exceptions_notify+0x1c9/0x43e [<c06b2b02>] notifier_call_chain+0x26/0x48 [<c06b2b5b>] __atomic_notifier_call_chain+0x37/0x5a [<c06b2b24>] ? __atomic_notifier_call_chain+0x0/0x5a [<c06b2b8a>] atomic_notifier_call_chain+0xc/0xe [<c0442d0d>] notify_die+0x2d/0x2f [<c06b0f9c>] do_int3+0x1f/0x71 [<c06b0e84>] int3+0x2c/0x34 [<c042d476>] ? do_fork+0x1/0x288 [<c040221b>] ? kernel_thread+0x71/0x79 [<c043ed1b>] ? kthread+0x0/0x60 [<c043ed1b>] ? kthread+0x0/0x60 [<c04040b8>] ? kernel_thread_helper+0x0/0x10 [<c043ec7f>] kthreadd+0xac/0x148 [<c043ebd3>] ? kthreadd+0x0/0x148 [<c04040bf>] kernel_thread_helper+0x7/0x10 Signed-off-by: Ananth N Mavinakayanahalli <ananth@in.ibm.com> Tested-by: Bharata B Rao <bharata@linux.vnet.ibm.com> Cc: Masami Hiramatsu <mhiramat@redhat.com> Cc: Jim Keniston <jkenisto@us.ibm.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: <stable@kernel.org> [2.6.29.x, 2.6.28.x, 2.6.27.x] LKML-Reference: <20090318113621.GB4129@in.ibm.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-03-06tracing, Text Edit Lock - kprobes architecture independent supportMathieu Desnoyers
Use the mutual exclusion provided by the text edit lock in the kprobes code. It allows coherent manipulation of the kernel code by other subsystems. Changelog: Move the kernel_text_lock/unlock out of the for loops. Use text_mutex directly instead of a function. Remove whitespace modifications. (note : kprobes_mutex is always taken outside of text_mutex) Signed-off-by: Mathieu Desnoyers <mathieu.desnoyers@polymtl.ca> Acked-by: Ananth N Mavinakayanahalli <ananth@in.ibm.com> Acked-by: Masami Hiramatsu <mhiramat@redhat.com> LKML-Reference: <49B14306.2080202@redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-01-16kprobes: check CONFIG_FREEZER instead of CONFIG_PMMasami Hiramatsu
Check CONFIG_FREEZER instead of CONFIG_PM because kprobe booster depends on freeze_processes() and thaw_processes() when CONFIG_PREEMPT=y. This fixes a linkage error which occurs when CONFIG_PREEMPT=y, CONFIG_PM=y and CONFIG_FREEZER=n. Reported-by: Cheng Renquan <crquan@gmail.com> Signed-off-by: Masami Hiramatsu <mhiramat@redhat.com> Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Acked-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Len Brown <len.brown@intel.com>
2009-01-06kprobes: support probing module __init functionMasami Hiramatsu
Allow kprobes to probe module __init routines. When __init functions are freed, kprobes which probe those functions are set to "Gone" flag. These "Gone" probes are disarmed from the code and never be enabled. Signed-off-by: Masami Hiramatsu <mhiramat@redhat.com> Acked-by: Ananth N Mavinakayanahalli <ananth@in.ibm.com> Cc: Anil S Keshavamurthy <anil.s.keshavamurthy@intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-06kprobes: remove called_from argumentMasami Hiramatsu
Remove called_from argument from kprobes which had been used for preventing self-refering of kernel module. However, since we don't keep module's refcount after registering kprobe any more, there is no reason to check that. This patch also simplifies registering/unregistering functions because we don't need to use __builtin_return_address(0) which was passed to called_from. [ananth@in.ibm.com: build fix] Signed-off-by: Masami Hiramatsu <mhiramat@redhat.com> Acked-by: Ananth N Mavinakayanahalli <ananth@in.ibm.com> Cc: Anil S Keshavamurthy <anil.s.keshavamurthy@intel.com> Signed-off-by: Ananth N Mavinakayanahalli <ananth@in.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-06kprobes: support probing module __exit functionMasami Hiramatsu
Allows kprobes to probe __exit routine. This adds flags member to struct kprobe. When module is freed(kprobes hooks module_notifier to get this event), kprobes which probe the functions in that module are set to "Gone" flag to the flags member. These "Gone" probes are never be enabled. Users can check the GONE flag through debugfs. This also removes mod_refcounted, because we couldn't free a module if kprobe incremented the refcount of that module. [akpm@linux-foundation.org: document some locking] [mhiramat@redhat.com: bugfix: pass aggr_kprobe to arch_remove_kprobe] [mhiramat@redhat.com: bugfix: release old_p's insn_slot before error return] Signed-off-by: Masami Hiramatsu <mhiramat@redhat.com> Acked-by: Ananth N Mavinakayanahalli <ananth@in.ibm.com> Cc: Anil S Keshavamurthy <anil.s.keshavamurthy@intel.com> Signed-off-by: Masami Hiramatsu <mhiramat@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-06kprobes: add __kprobes to kprobe internal functionsMasami Hiramatsu
Add __kprobes to kprobes internal functions for protecting from probing by kprobes itself. Signed-off-by: Masami Hiramatsu <mhiramat@redhat.com> Acked-by: Ananth N Mavinakayanahalli <ananth@in.ibm.com> Cc: Anil S Keshavamurthy <anil.s.keshavamurthy@intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-06kprobes: add kprobe_insn_mutex and cleanup arch_remove_kprobe()Masami Hiramatsu
Add kprobe_insn_mutex for protecting kprobe_insn_pages hlist, and remove kprobe_mutex from architecture dependent code. This allows us to call arch_remove_kprobe() (and free_insn_slot) while holding kprobe_mutex. Signed-off-by: Masami Hiramatsu <mhiramat@redhat.com> Acked-by: Ananth N Mavinakayanahalli <ananth@in.ibm.com> Cc: Anil S Keshavamurthy <anil.s.keshavamurthy@intel.com> Cc: Russell King <rmk@arm.linux.org.uk> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-06kprobes: bugfix: try_module_get even if calling_mod is NULLMasami Hiramatsu
When someone called register_*probe() from kernel-core code(not from module) and that probes a kernel module, users can remove the probed module because kprobe doesn't increment reference counter of the module. (on the other hand, if the kernel-module calls register_*probe, kprobe increments refcount of the probed module.) Currently, we have no register_*probe() calling from kernel-core(except smoke-test, but the smoke-test doesn't probe module), so there is no real bugs. But the logic is wrong(or not fair) and it can causes a problem when someone might want to probe module from kernel. After this patch is applied, even if someone put register_*probe() call in the kernel-core code, it increments the reference counter of the probed module, and it prevents user to remove the module until stopping probing it. Signed-off-by: Masami Hiramatsu <mhiramat@redhat.com> Cc: Lai Jiangshan <laijs@cn.fujitsu.com> Cc: Ananth N Mavinakayanahalli <ananth@in.ibm.com> Cc: Hiroshi Shimamoto <h-shimamoto@ct.jp.nec.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-11-12kernel/kprobes.c: don't pad kretprobe_table_locks[] on uniprocessor buildsAndrew Morton
We only need the cacheline padding on SMP kernels. Saves 6k: text data bss dec hex filename 5713 388 8840 14941 3a5d kernel/kprobes.o 5713 388 2632 8733 221d kernel/kprobes.o Acked-by: Masami Hiramatsu <mhiramat@redhat.com> Cc: Ananth N Mavinakayanahalli <ananth@in.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-11-12kprobes: disable preempt for module_text_address() and kernel_text_address()Masami Hiramatsu
__register_kprobe() can be preempted after checking probing address but before module_text_address() or try_module_get(), and in this interval the module can be unloaded. In that case, try_module_get(probed_mod) will access to invalid address, or kprobe will probe invalid address. This patch uses preempt_disable() to protect it and uses __module_text_address() and __kernel_text_address(). Signed-off-by: Lai Jiangshan <laijs@cn.fujitsu.com> Signed-off-by: Masami Hiramatsu <mhiramat@redhat.com> Cc: Ananth N Mavinakayanahalli <ananth@in.ibm.com> Cc: Hiroshi Shimamoto <h-shimamoto@ct.jp.nec.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-16make kprobes.c:kretprobe_table_lock() staticAdrian Bunk
Make the needlessly global kretprobe_table_lock() static. Signed-off-by: Adrian Bunk <bunk@kernel.org> Acked-by: Ananth N Mavinakayanahalli <ananth@in.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-25kprobes: remove redundant config checkAbhishek Sagar
I noticed that there's a CONFIG_KPROBES check inside kernel/kprobes.c, which is redundant. Signed-off-by: Abhishek Sagar <sagar.abhishek@gmail.com> Acked-by: Masami Hiramatsu <mhiramat@redhat.com> Cc: Ananth N Mavinakayanahalli <ananth@in.ibm.com> Cc: Anil S Keshavamurthy <anil.s.keshavamurthy@intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-25kprobes: improve kretprobe scalability with hashed lockingSrinivasa D S
Currently list of kretprobe instances are stored in kretprobe object (as used_instances,free_instances) and in kretprobe hash table. We have one global kretprobe lock to serialise the access to these lists. This causes only one kretprobe handler to execute at a time. Hence affects system performance, particularly on SMP systems and when return probe is set on lot of functions (like on all systemcalls). Solution proposed here gives fine-grain locks that performs better on SMP system compared to present kretprobe implementation. Solution: 1) Instead of having one global lock to protect kretprobe instances present in kretprobe object and kretprobe hash table. We will have two locks, one lock for protecting kretprobe hash table and another lock for kretporbe object. 2) We hold lock present in kretprobe object while we modify kretprobe instance in kretprobe object and we hold per-hash-list lock while modifying kretprobe instances present in that hash list. To prevent deadlock, we never grab a per-hash-list lock while holding a kretprobe lock. 3) We can remove used_instances from struct kretprobe, as we can track used instances of kretprobe instances using kretprobe hash table. Time duration for kernel compilation ("make -j 8") on a 8-way ppc64 system with return probes set on all systemcalls looks like this. cacheline non-cacheline Un-patched kernel aligned patch aligned patch =============================================================================== real 9m46.784s 9m54.412s 10m2.450s user 40m5.715s 40m7.142s 40m4.273s sys 2m57.754s 2m58.583s 3m17.430s =========================================================== Time duration for kernel compilation ("make -j 8) on the same system, when kernel is not probed. ========================= real 9m26.389s user 40m8.775s sys 2m7.283s ========================= Signed-off-by: Srinivasa DS <srinivasa@in.ibm.com> Signed-off-by: Jim Keniston <jkenisto@us.ibm.com> Acked-by: Ananth N Mavinakayanahalli <ananth@in.ibm.com> Cc: Anil S Keshavamurthy <anil.s.keshavamurthy@intel.com> Cc: David S. Miller <davem@davemloft.net> Cc: Masami Hiramatsu <mhiramat@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-10kernel/kprobes.c: Made kprobe_blacklist static.Daniel Guilak
Signed-off-by: Daniel Guilak <daniel@danielguilak.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-06-12kprobes: fix error checking of batch registrationMasami Hiramatsu
Fix error checking routine to catch an error which occurs in first __register_*probe(). Signed-off-by: Masami Hiramatsu <mhiramat@redhat.com> Cc: Ananth N Mavinakayanahalli <ananth@in.ibm.com> Cc: Jim Keniston <jkenisto@us.ibm.com> Cc: David Miller <davem@davemloft.net> Cc: Anil S Keshavamurthy <anil.s.keshavamurthy@intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-28kprobes: add (un)register_jprobes for batch registrationMasami Hiramatsu
Introduce unregister_/register_jprobes() for jprobe batch registration. Signed-off-by: Masami Hiramatsu <mhiramat@redhat.com> Cc: Ananth N Mavinakayanahalli <ananth@in.ibm.com> Cc: Jim Keniston <jkenisto@us.ibm.com> Cc: Prasanna S Panchamukhi <prasanna@in.ibm.com> Cc: Shaohua Li <shaohua.li@intel.com> Cc: David Miller <davem@davemloft.net> Cc: "Frank Ch. Eigler" <fche@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-28kprobes: add (un)register_kretprobes for batch registrationMasami Hiramatsu
Introduce unregister_/register_kretprobes() for kretprobe batch registration. Signed-off-by: Masami Hiramatsu <mhiramat@redhat.com> Cc: Ananth N Mavinakayanahalli <ananth@in.ibm.com> Cc: Jim Keniston <jkenisto@us.ibm.com> Cc: Prasanna S Panchamukhi <prasanna@in.ibm.com> Cc: Shaohua Li <shaohua.li@intel.com> Cc: David Miller <davem@davemloft.net> Cc: "Frank Ch. Eigler" <fche@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-28kprobes: add (un)register_kprobes for batch registrationMasami Hiramatsu
Introduce unregister_/register_kprobes() for kprobe batch registration. This can reduce waiting time for synchronized_sched() when a lot of probes have to be unregistered at once. Signed-off-by: Masami Hiramatsu <mhiramat@redhat.com> Cc: Ananth N Mavinakayanahalli <ananth@in.ibm.com> Cc: Jim Keniston <jkenisto@us.ibm.com> Cc: Prasanna S Panchamukhi <prasanna@in.ibm.com> Cc: Shaohua Li <shaohua.li@intel.com> Cc: David Miller <davem@davemloft.net> Cc: "Frank Ch. Eigler" <fche@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-28kprobes: prevent probing of preempt_schedule()Srinivasa Ds
Prohibit users from probing preempt_schedule(). One way of prohibiting the user from probing functions is by marking such functions with __kprobes. But this method doesn't work for those functions, which are already marked to different section like preempt_schedule() (belongs to __sched section). So we use blacklist approach to refuse user from probing these functions. In blacklist approach we populate the blacklisted function's starting address and its size in kprobe_blacklist structure. Then we verify the user specified address against start and end of the blacklisted function. So any attempt to register probe on blacklisted functions will be rejected. [akpm@linux-foundation.org: build fix] [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Srinivasa DS <srinivasa@in.ibm.com> Signed-off-by: Ananth N Mavinakayanahalli <ananth@in.ibm.com> Signed-off-by: Jim Keniston <jkenisto@us.ibm.com> Cc: Dave Hansen <haveblue@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-03-04kprobes: fix a null pointer bug in register_kretprobe()Masami Hiramatsu
Fix a bug in regiseter_kretprobe() which does not check rp->kp.symbol_name == NULL before calling kprobe_lookup_name. For maintainability, this introduces kprobe_addr helper function which resolves addr field. It is used by register_kprobe and register_kretprobe. Signed-off-by: Masami Hiramatsu <mhiramat@redhat.com> Cc: Ananth N Mavinakayanahalli <ananth@in.ibm.com> Cc: Jim Keniston <jkenisto@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-03-04Kprobes: indicate kretprobe support in KconfigAnanth N Mavinakayanahalli
Add CONFIG_HAVE_KRETPROBES to the arch/<arch>/Kconfig file for relevant architectures with kprobes support. This facilitates easy handling of in-kernel modules (like samples/kprobes/kretprobe_example.c) that depend on kretprobes being present in the kernel. Thanks to Sam Ravnborg for helping make the patch more lean. Per Mathieu's suggestion, added CONFIG_KRETPROBES and fixed up dependencies. Signed-off-by: Ananth N Mavinakayanahalli <ananth@in.ibm.com> Acked-by: Mathieu Desnoyers <mathieu.desnoyers@polymtl.ca> Acked-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-06kprobes: kretprobe user entry-handlerAbhishek Sagar
Provide support to add an optional user defined callback to be run at function entry of a kretprobe'd function. Also modify the kprobe smoke tests to include an entry-handler during the kretprobe sanity test. Signed-off-by: Abhishek Sagar <sagar.abhishek@gmail.com> Cc: Prasanna S Panchamukhi <prasanna@in.ibm.com> Cc: Ananth N Mavinakayanahalli <ananth@in.ibm.com> Cc: Anil S Keshavamurthy <anil.s.keshavamurthy@intel.com> Acked-by: Jim Keniston <jkenisto@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-01-30x86: kprobes: add kprobes smoke tests that run on bootAnanth N Mavinakayanahalli
Here is a quick and naive smoke test for kprobes. This is intended to just verify if some unrelated change broke the *probes subsystem. It is self contained, architecture agnostic and isn't of any great use by itself. This needs to be built in the kernel and runs a basic set of tests to verify if kprobes, jprobes and kretprobes run fine on the kernel. In case of an error, it'll print out a message with a "BUG" prefix. This is a start; we intend to add more tests to this bucket over time. Thanks to Jim Keniston and Masami Hiramatsu for comments and suggestions. Tested on x86 (32/64) and powerpc. Signed-off-by: Ananth N Mavinakayanahalli <ananth@in.ibm.com> Acked-by: Masami Hiramatsu <mhiramat@redhat.com> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2007-10-16kprobes: support kretprobe blacklistMasami Hiramatsu
Introduce architecture dependent kretprobe blacklists to prohibit users from inserting return probes on the function in which kprobes can be inserted but kretprobes can not. This patch also removes "__kprobes" mark from "__switch_to" on x86_64 and registers "__switch_to" to the blacklist on x86-64, because that mark is to prohibit user from inserting only kretprobe. Signed-off-by: Masami Hiramatsu <mhiramat@redhat.com> Cc: Prasanna S Panchamukhi <prasanna@in.ibm.com> Acked-by: Ananth N Mavinakayanahalli <ananth@in.ibm.com> Cc: Anil S Keshavamurthy <anil.s.keshavamurthy@intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16x86: optimize page faults like all other achitectures and kill notifier cruftChristoph Hellwig
x86(-64) are the last architectures still using the page fault notifier cruft for the kprobes page fault hook. This patch converts them to the proper direct calls, and removes the now unused pagefault notifier bits aswell as the cruft in kprobes.c that was related to this mess. I know Andi didn't really like this, but all other architecture maintainers agreed the direct calls are much better and besides the obvious cruft removal a common way of dealing with kprobes across architectures is important aswell. [akpm@linux-foundation.org: build fix] [akpm@linux-foundation.org: fix sparc64] Signed-off-by: Christoph Hellwig <hch@lst.de> Cc: Andi Kleen <ak@suse.de> Cc: <linux-arch@vger.kernel.org> Cc: Prasanna S Panchamukhi <prasanna@in.ibm.com> Cc: Ananth N Mavinakayanahalli <ananth@in.ibm.com> Cc: Anil S Keshavamurthy <anil.s.keshavamurthy@intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-08-11fix compilation with gcc 4.2Peter Chubb
gcc-4.2 is a lot more picky about its symbol handling. EXPORT_SYMBOL no longer works on symbols that are undefined or defined with static scope. For example, with CONFIG_PROFILE off, I see: kernel/profile.c:206: error: __ksymtab_profile_event_unregister causes a section type conflict kernel/profile.c:205: error: __ksymtab_profile_event_register causes a section type conflict This patch moves the EXPORTs inside the #ifdef CONFIG_PROFILE, so we only try to export symbols that are defined. Also, in kernel/kprobes.c there's an EXPORT_SYMBOL_GPL() for jprobes_return, which if CONFIG_JPROBES is undefined is a static inline and gives the same error. And in drivers/acpi/resources/rsxface.c, there's an ACPI_EXPORT_SYMBOPL() for a static symbol. If it's static, it's not accessible from outside the compilation unit, so should bot be exported. These three changes allow building a zx1_defconfig kernel with gcc 4.2 on IA64. [akpm@linux-foundation.org: export jpobe_return properly] Signed-off-by: Peter Chubb <peterc@gelato.unsw.edu.au> Cc: Prasanna S Panchamukhi <prasanna@in.ibm.com> Cc: Ananth N Mavinakayanahalli <ananth@in.ibm.com> Cc: Anil S Keshavamurthy <anil.s.keshavamurthy@intel.com> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: Len Brown <lenb@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-19jprobes: make jprobes a little safer for usersMichael Ellerman
I realise jprobes are a razor-blades-included type of interface, but that doesn't mean we can't try and make them safer to use. This guy I know once wrote code like this: struct jprobe jp = { .kp.symbol_name = "foo", .entry = "jprobe_foo" }; And then his kernel exploded. Oops. This patch adds an arch hook, arch_deref_entry_point() (I don't like it either) which takes the void * in a struct jprobe, and gives back the text address that it represents. We can then use that in register_jprobe() to check that the entry point we're passed is actually in the kernel text, rather than just some random value. Signed-off-by: Michael Ellerman <michael@ellerman.id.au> Cc: Prasanna S Panchamukhi <prasanna@in.ibm.com> Acked-by: Ananth N Mavinakayanahalli <ananth@in.ibm.com> Cc: Anil S Keshavamurthy <anil.s.keshavamurthy@intel.com> Cc: David S. Miller <davem@davemloft.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08Kprobes: The ON/OFF knob thru debugfsAnanth N Mavinakayanahalli
This patch provides a debugfs knob to turn kprobes on/off o A new file /debug/kprobes/enabled indicates if kprobes is enabled or not (default enabled) o Echoing 0 to this file will disarm all installed probes o Any new probe registration when disabled will register the probe but not arm it. A message will be printed out in such a case. o When a value 1 is echoed to the file, all probes (including ones registered in the intervening period) will be enabled o Unregistration will happen irrespective of whether probes are globally enabled or not. o Update Documentation/kprobes.txt to reflect these changes. While there also update the doc to make it current. We are also looking at providing sysrq key support to tie to the disabling feature provided by this patch. [akpm@linux-foundation.org: Use bool like a bool!] [akpm@linux-foundation.org: add printk facility levels] [cornelia.huck@de.ibm.com: Add the missing arch_trampoline_kprobe() for s390] Signed-off-by: Ananth N Mavinakayanahalli <ananth@in.ibm.com> Signed-off-by: Srinivasa DS <srinivasa@in.ibm.com> Signed-off-by: Cornelia Huck <cornelia.huck@de.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08kprobes: kretprobes simplificationsChristoph Hellwig
- consolidate duplicate code in all arch_prepare_kretprobe instances into common code - replace various odd helpers that use hlist_for_each_entry to get the first elemenet of a list with either a hlist_for_each_entry_save or an opencoded access to the first element in the caller - inline add_rp_inst into it's only remaining caller - use kretprobe_inst_table_head instead of opencoding it Signed-off-by: Christoph Hellwig <hch@lst.de> Cc: Prasanna S Panchamukhi <prasanna@in.ibm.com> Acked-by: Ananth N Mavinakayanahalli <ananth@in.ibm.com> Cc: Anil S Keshavamurthy <anil.s.keshavamurthy@intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08kprobes: codingstyle cleanupsChristoph Hellwig
Remove superflous braces and fix indentation aswell as comments. Signed-off-by: Christoph Hellwig <hch@lst.de> Cc: Prasanna S Panchamukhi <prasanna@in.ibm.com> Cc: Ananth N Mavinakayanahalli <ananth@in.ibm.com> Cc: Anil S Keshavamurthy <anil.s.keshavamurthy@intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08kprobes: use hlist_for_each_entryChristoph Hellwig
2007-05-08Simplify kallsyms_lookup()Alexey Dobriyan
Several kallsyms_lookup() pass dummy arguments but only need, say, module's name. Make kallsyms_lookup() accept NULLs where possible. Also, makes picture clearer about what interfaces are needed for all symbol resolving business. Signed-off-by: Alexey Dobriyan <adobriyan@sw.ru> Cc: Rusty Russell <rusty@rustcorp.com.au> Acked-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08move die notifier handling to common codeChristoph Hellwig
This patch moves the die notifier handling to common code. Previous various architectures had exactly the same code for it. Note that the new code is compiled unconditionally, this should be understood as an appel to the other architecture maintainer to implement support for it aswell (aka sprinkling a notify_die or two in the proper place) arm had a notifiy_die that did something totally different, I renamed it to arm_notify_die as part of the patch and made it static to the file it's declared and used at. avr32 used to pass slightly less information through this interface and I brought it into line with the other architectures. [akpm@linux-foundation.org: build fix] [akpm@linux-foundation.org: fix vmalloc_sync_all bustage] [bryan.wu@analog.com: fix vmalloc_sync_all in nommu] Signed-off-by: Christoph Hellwig <hch@lst.de> Cc: <linux-arch@vger.kernel.org> Cc: Russell King <rmk@arm.linux.org.uk> Signed-off-by: Bryan Wu <bryan.wu@analog.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08kprobes: fix sparse NULL warningRandy Dunlap
Fix sparse NULL warnings: kernel/kprobes.c:915:49: warning: Using plain integer as NULL pointer Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Acked-by: Ananth N Mavinakayanahalli <ananth@in.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-20[PATCH] kprobes: list all active probes in the systemSrinivasa Ds
This patch lists all active probes in the system by scanning through kprobe_table[]. It takes care of aggregate handlers and prints the type of the probe. Letter "k" for kprobes, "j" for jprobes, "r" for kretprobes. It also lists address of the instruction,its symbolic name(function name + offset) and the module name. One can access this file through /sys/kernel/debug/kprobes/list. Output looks like this ===================== llm40:~/a # cat /sys/kernel/debug/kprobes/list c0169ae3 r sys_read+0x0 c0169ae3 k sys_read+0x0 c01694c8 k vfs_write+0x0 c0167d20 r sys_open+0x0 f8e658a6 k reiserfs_delete_inode+0x0 reiserfs c0120f4a k do_fork+0x0 c0120f4a j do_fork+0x0 c0169b4a r sys_write+0x0 c0169b4a k sys_write+0x0 c0169622 r vfs_read+0x0 ================================= [akpm@linux-foundation.org: cleanup] [ananth@in.ibm.com: sparc build fix] Signed-off-by: Srinivasa DS <srinivasa@in.ibm.com> Cc: Prasanna S Panchamukhi <prasanna@in.ibm.com> Cc: Ananth N Mavinakayanahalli <ananth@in.ibm.com> Cc: Anil S Keshavamurthy <anil.s.keshavamurthy@intel.com> Signed-off-by: Ananth N Mavinakayanahalli <ananth@in.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-01-30[PATCH] kprobes: replace magic numbers with enumMasami Hiramatsu
Replace the magic numbers with an enum, and gets rid of a warning on the specific architectures (ex. powerpc) on which the compiler considers 'char' as 'unsigned char'. Signed-off-by: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com> Cc: Prasanna S Panchamukhi <prasanna@in.ibm.com> Cc: Ananth N Mavinakayanahalli <ananth@in.ibm.com> Cc: Anil S Keshavamurthy <anil.s.keshavamurthy@intel.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-12-07[PATCH] kprobes: enable booster on the preemptible kernelMasami Hiramatsu
When we are unregistering a kprobe-booster, we can't release its instruction buffer immediately on the preemptive kernel, because some processes might be preempted on the buffer. The freeze_processes() and thaw_processes() functions can clean most of processes up from the buffer. There are still some non-frozen threads who have the PF_NOFREEZE flag. If those threads are sleeping (not preempted) at the known place outside the buffer, we can ensure safety of freeing. However, the processing of this check routine takes a long time. So, this patch introduces the garbage collection mechanism of insn_slot. It also introduces the "dirty" flag to free_insn_slot because of efficiency. The "clean" instruction slots (dirty flag is cleared) are released immediately. But the "dirty" slots which are used by boosted kprobes, are marked as garbages. collect_garbage_slots() will be invoked to release "dirty" slots if there are more than INSNS_PER_PAGE garbage slots or if there are no unused slots. Cc: "Keshavamurthy, Anil S" <anil.s.keshavamurthy@intel.com> Cc: Ananth N Mavinakayanahalli <ananth@in.ibm.com> Cc: "bibo,mao" <bibo.mao@intel.com> Cc: Prasanna S Panchamukhi <prasanna@in.ibm.com> Cc: Yumiko Sugita <yumiko.sugita.yf@hitachi.com> Cc: Satoshi Oshima <soshima@redhat.com> Cc: Hideo Aoki <haoki@redhat.com> Signed-off-by: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com> Acked-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-02[PATCH] kretprobe spinlock deadlock patchbibo,mao
kprobe_flush_task() possibly calls kfree function during holding kretprobe_lock spinlock, if kfree function is probed by kretprobe that will incur spinlock deadlock. This patch moves kfree function out scope of kretprobe_lock. Signed-off-by: bibo, mao <bibo.mao@intel.com> Signed-off-by: Ananth N Mavinakayanahalli <ananth@in.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-02[PATCH] kprobe whitespace cleanupbibo,mao
Whitespace is used to indent, this patch cleans up these sentences by kernel coding style. Signed-off-by: bibo, mao <bibo.mao@intel.com> Signed-off-by: Ananth N Mavinakayanahalli <ananth@in.ibm.com> Cc: "Luck, Tony" <tony.luck@intel.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-02[PATCH] Kprobes: Make kprobe modules more portableAnanth N Mavinakayanahalli
In an effort to make kprobe modules more portable, here is a patch that: o Introduces the "symbol_name" field to struct kprobe. The symbol->address resolution now happens in the kernel in an architecture agnostic manner. 64-bit powerpc users no longer have to specify the ".symbols" o Introduces the "offset" field to struct kprobe to allow a user to specify an offset into a symbol. o The legacy mechanism of specifying the kprobe.addr is still supported. However, if both the kprobe.addr and kprobe.symbol_name are specified, probe registration fails with an -EINVAL. o The symbol resolution code uses kallsyms_lookup_name(). So CONFIG_KPROBES now depends on CONFIG_KALLSYMS o Apparantly kprobe modules were the only legitimate out-of-tree user of the kallsyms_lookup_name() EXPORT. Now that the symbol resolution happens in-kernel, remove the EXPORT as suggested by Christoph Hellwig o Modify tcp_probe.c that uses the kprobe interface so as to make it work on multiple platforms (in its earlier form, the code wouldn't work, say, on powerpc) Signed-off-by: Ananth N Mavinakayanahalli <ananth@in.ibm.com> Signed-off-by: Prasanna S Panchamukhi <prasanna@in.ibm.com> Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-31[PATCH] IA64: kprobe invalidate icache of jump bufferbibo, mao
Kprobe inserts breakpoint instruction in probepoint and then jumps to instruction slot when breakpoint is hit, the instruction slot icache must be consistent with dcache. Here is the patch which invalidates instruction slot icache area. Without this patch, in some machines there will be fault when executing instruction slot where icache content is inconsistent with dcache. Signed-off-by: bibo,mao <bibo.mao@intel.com> Acked-by: "Luck, Tony" <tony.luck@intel.com> Acked-by: Keshavamurthy Anil S <anil.s.keshavamurthy@intel.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-26[PATCH] Notify page fault call chainAnil S Keshavamurthy
With this patch Kprobes now registers for page fault notifications only when their is an active probe registered. Once all the active probes are unregistered their is no need to be notified of page faults and kprobes unregisters itself from the page fault notifications. Hence we will have ZERO side effects when no probes are active. Signed-off-by: Anil S Keshavamurthy <anil.s.keshavamurthy@intel.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
