Merge disabling kprobe to unregistering kprobe function
and add comments for disabing/unregistring process.
Current unregistering code disables(disarms) kprobes after
checking target kprobe status. This patch changes it to
disabling kprobe first after that it changing the kprobe's
state. This allows to share probe disabling code between
disable_kprobe() and unregister_kprobe().
Signed-off-by: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com>
Cc: Ananth N Mavinakayanahalli <ananth@in.ibm.com>
Cc: Jason Baron <jbaron@redhat.com>
Cc: Mathieu Desnoyers <mathieu.desnoyers@efficios.com>
Cc: 2nddept-manager@sdl.hitachi.co.jp
LKML-Reference: <20101203095356.2961.30152.stgit@ltc236.sdl.hitachi.co.jp>
Rename irrelevant uses of "old_p" to more appropriate names.
Originally, "old_p" just meant "the old kprobe on given address"
but current code uses that name as "just another kprobe" or
something like that. This patch renames those pointer names
to more appropriate one for maintainability.
LKML-Reference: <20101203095350.2961.48110.stgit@ltc236.sdl.hitachi.co.jp>
Kprobes and jump label were having a race between mutexes that
was fixed by reordering the jump label. But this reordering
moved the jump label mutex into a preempt disable location.
This patch does a little fiddling to move the grabbing of
the jump label mutex from inside the preempt disable section
and still keep the order correct between the mutex and the
kprobes lock.
Reported-by: Ingo Molnar <mingo@elte.hu>
Acked-by: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com>
register_kprobe() downs the 'text_mutex' and then calls
jump_label_text_reserved(), which downs the 'jump_label_mutex'.
However, the jump label code takes those mutexes in the reverse
order.
Fix by requiring the caller of jump_label_text_reserved() to do
the jump label locking via the newly added: jump_label_lock(),
jump_label_unlock(). Currently, kprobes is the only user
of jump_label_text_reserved().
Signed-off-by: Jason Baron <jbaron@redhat.com>
LKML-Reference: <759032c48d5e30c27f0bba003d09bffa8e9f28bb.1285965957.git.jbaron@redhat.com>
* 'perf-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (50 commits)
perf python scripting: Add futex-contention script
perf python scripting: Fixup cut'n'paste error in sctop script
perf scripting: Shut up 'perf record' final status
perf record: Remove newline character from perror() argument
perf python scripting: Support fedora 11 (audit 1.7.17)
perf python scripting: Improve the syscalls-by-pid script
perf python scripting: print the syscall name on sctop
perf python scripting: Improve the syscalls-counts script
perf python scripting: Improve the failed-syscalls-by-pid script
kprobes: Remove redundant text_mutex lock in optimize
x86/oprofile: Fix uninitialized variable use in debug printk
tracing: Fix 'faild' -> 'failed' typo
perf probe: Fix format specified for Dwarf_Off parameter
perf trace: Fix detection of script extension
perf trace: Use $PERF_EXEC_PATH in canned report scripts
perf tools: Document event modifiers
perf tools: Remove direct slang.h include
perf_events: Fix for transaction recovery in group_sched_in()
perf_events: Revert: Fix transaction recovery in group_sched_in()
perf, x86: Use NUMA aware allocations for PEBS/BTS/DS allocations
Remove text_mutex locking in optimize_all_kprobes, because
this function doesn't modify text. It simply queues probes on
optimization list for kprobe_optimizer worker thread.
Signed-off-by: Masami Hiramatsu <mhiramat@redhat.com>
Cc: Anil S Keshavamurthy <anil.s.keshavamurthy@intel.com>
Cc: Namhyung Kim <namhyung@gmail.com>
LKML-Reference: <20101025131801.19160.70939.stgit@ltc236.sdl.hitachi.co.jp>
* 'llseek' of git://git.kernel.org/pub/scm/linux/kernel/git/arnd/bkl:
vfs: make no_llseek the default
vfs: don't use BKL in default_llseek
llseek: automatically add .llseek fop
libfs: use generic_file_llseek for simple_attr
mac80211: disallow seeks in minstrel debug code
lirc: make chardev nonseekable
viotape: use noop_llseek
raw: use explicit llseek file operations
ibmasmfs: use generic_file_llseek
spufs: use llseek in all file operations
arm/omap: use generic_file_llseek in iommu_debug
lkdtm: use generic_file_llseek in debugfs
net/wireless: use generic_file_llseek in debugfs
drm: use noop_llseek
All file_operations should get a .llseek operation so we can make
nonseekable_open the default for future file operations without a
.llseek pointer.
The three cases that we can automatically detect are no_llseek, seq_lseek
and default_llseek. For cases where we can we can automatically prove that
the file offset is always ignored, we use noop_llseek, which maintains
the current behavior of not returning an error from a seek.
New drivers should normally not use noop_llseek but instead use no_llseek
and call nonseekable_open at open time. Existing drivers can be converted
to do the same when the maintainer knows for certain that no user code
relies on calling seek on the device file.
The generated code is often incorrectly indented and right now contains
comments that clarify for each added line why a specific variant was
chosen. In the version that gets submitted upstream, the comments will
be gone and I will manually fix the indentation, because there does not
seem to be a way to do that using coccinelle.
Some amount of new code is currently sitting in linux-next that should get
the same modifications, which I will do at the end of the merge window.
Many thanks to Julia Lawall for helping me learn to write a semantic
patch that does all this.
===== begin semantic patch =====
// This adds an llseek= method to all file operations,
// as a preparation for making no_llseek the default.
// The rules are
// - use no_llseek explicitly if we do nonseekable_open
// - use seq_lseek for sequential files
// - use default_llseek if we know we access f_pos
// - use noop_llseek if we know we don't access f_pos,
// but we still want to allow users to call lseek
@ open1 exists @
identifier nested_open;
nested_open(...)
nonseekable_open(...)
@ open exists@
identifier open_f;
identifier i, f;
identifier open1.nested_open;
int open_f(struct inode *i, struct file *f)
nested_open(...)
@ read disable optional_qualifier exists @
identifier read_f;
identifier f, p, s, off;
type ssize_t, size_t, loff_t;
expression E;
identifier func;
ssize_t read_f(struct file *f, char *p, size_t s, loff_t *off)
*off = E
*off += E
func(..., off, ...)
E = *off
@ read_no_fpos disable optional_qualifier exists @
identifier read_f;
... when != off
@ write @
identifier write_f;
expression E;
identifier func;
ssize_t write_f(struct file *f, const char *p, size_t s, loff_t *off)
*off = E
*off += E
func(..., off, ...)
E = *off
@ write_no_fpos @
identifier write_f;
... when != off
@ fops0 @
identifier fops;
struct file_operations fops = {
@ has_llseek depends on fops0 @
identifier fops0.fops;
identifier llseek_f;
.llseek = llseek_f,
@ has_read depends on fops0 @
identifier read_f;
.read = read_f,
@ has_write depends on fops0 @
identifier write_f;
.write = write_f,
@ has_open depends on fops0 @
identifier open_f;
.open = open_f,
// use no_llseek if we call nonseekable_open
@ nonseekable1 depends on !has_llseek && has_open @
identifier nso ~= "nonseekable_open";
... .open = nso, ...
+.llseek = no_llseek, /* nonseekable */
@ nonseekable2 depends on !has_llseek @
identifier open.open_f;
... .open = open_f, ...
+.llseek = no_llseek, /* open uses nonseekable */
// use seq_lseek for sequential files
@ seq depends on !has_llseek @
identifier sr ~= "seq_read";
... .read = sr, ...
+.llseek = seq_lseek, /* we have seq_read */
// use default_llseek if there is a readdir
@ fops1 depends on !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
identifier readdir_e;
// any other fop is used that changes pos
... .readdir = readdir_e, ...
+.llseek = default_llseek, /* readdir is present */
// use default_llseek if at least one of read/write touches f_pos
@ fops2 depends on !fops1 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
identifier read.read_f;
// read fops use offset
... .read = read_f, ...
+.llseek = default_llseek, /* read accesses f_pos */
@ fops3 depends on !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
identifier write.write_f;
// write fops use offset
... .write = write_f, ...
+ .llseek = default_llseek, /* write accesses f_pos */
// Use noop_llseek if neither read nor write accesses f_pos
@ fops4 depends on !fops1 && !fops2 && !fops3 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
identifier read_no_fpos.read_f;
identifier write_no_fpos.write_f;
.write = write_f,
.read = read_f,
+.llseek = noop_llseek, /* read and write both use no f_pos */
@ depends on has_write && !has_read && !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
+.llseek = noop_llseek, /* write uses no f_pos */
@ depends on has_read && !has_write && !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
+.llseek = noop_llseek, /* read uses no f_pos */
@ depends on !has_read && !has_write && !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
+.llseek = noop_llseek, /* no read or write fn */
===== End semantic patch =====
Cc: Julia Lawall <julia@diku.dk>
Add a jump_label_text_reserved(void *start, void *end), so that other
pieces of code that want to modify kernel text, can first verify that
jump label has not reserved the instruction.
Acked-by: Masami Hiramatsu <mhiramat@redhat.com>
LKML-Reference: <06236663a3a7b1c1f13576bb9eccb6d9c17b7bfe.1284733808.git.jbaron@redhat.com>
base patch to implement 'jump labeling'. Based on a new 'asm goto' inline
assembly gcc mechanism, we can now branch to labels from an 'asm goto'
statment. This allows us to create a 'no-op' fastpath, which can subsequently
be patched with a jump to the slowpath code. This is useful for code which
might be rarely used, but which we'd like to be able to call, if needed.
Tracepoints are the current usecase that these are being implemented for.
LKML-Reference: <ee8b3595967989fdaf84e698dc7447d315ce972a.1284733808.git.jbaron@redhat.com>
[ cleaned up some formating ]
This removes following warnings when build with C=1
warning: context imbalance in 'kretprobe_hash_lock' - wrong count at exit
warning: context imbalance in 'kretprobe_table_lock' - wrong count at exit
warning: context imbalance in 'kretprobe_hash_unlock' - unexpected unlock
warning: context imbalance in 'kretprobe_table_unlock' - unexpected unlock
Signed-off-by: Namhyung Kim <namhyung@gmail.com>
LKML-Reference: <1284512670-2369-6-git-send-email-namhyung@gmail.com>
Make following (internal) functions static to make sparse
happier :-)
* get_optimized_kprobe: only called from static functions
* kretprobe_table_unlock: _lock function is static
* kprobes_optinsn_template_holder: never called but holding asm code
LKML-Reference: <1284512670-2369-4-git-send-email-namhyung@gmail.com>
Verify jprobe's entry point is a function entry point
using kallsyms' offset value.
LKML-Reference: <1284512670-2369-3-git-send-email-namhyung@gmail.com>
Remove call to kernel_text_address() in register_jprobes()
because it is called right after in register_kprobe().
LKML-Reference: <1284512670-2369-2-git-send-email-namhyung@gmail.com>
Move enable/disable_kprobe() API out from debugfs related code,
because these interfaces are not related to debugfs interface.
This fixes a compiler warning.
Acked-by: Ananth N Mavinakayanahalli <ananth@in.ibm.com>
Acked-by: Tony Luck <tony.luck@intel.com>
Cc: systemtap <systemtap@sources.redhat.com>
Cc: DLE <dle-develop@lists.sourceforge.net>
LKML-Reference: <20100427223312.2322.60512.stgit@localhost6.localdomain6>
execution slot
From : Ananth N Mavinakayanahalli <ananth@in.ibm.com>
When freeing the instruction slot, the arithmetic to calculate
the index of the slot in the page needs to account for the total
size of the instruction on the various architectures.
Calculate the index correctly when freeing the out-of-line
execution slot.
Reported-by: Sachin Sant <sachinp@in.ibm.com>
Reported-by: Heiko Carstens <heiko.carstens@de.ibm.com>
Signed-off-by: Ananth N Mavinakayanahalli <ananth@in.ibm.com>
LKML-Reference: <4B9667AB.9050507@redhat.com>
Add /proc/sys/debug/kprobes-optimization sysctl which enables
and disables kprobes jump optimization on the fly for debugging.
Changes in v7:
- Remove ctl_name = CTL_UNNUMBERED for upstream compatibility.
Changes in v6:
- Update comments and coding style.
Cc: Jim Keniston <jkenisto@us.ibm.com>
Cc: Srikar Dronamraju <srikar@linux.vnet.ibm.com>
Cc: Anders Kaseorg <andersk@ksplice.com>
Cc: Tim Abbott <tabbott@ksplice.com>
Cc: Mathieu Desnoyers <compudj@krystal.dyndns.org>
LKML-Reference: <20100225133415.6725.8274.stgit@localhost6.localdomain6>
Introduce kprobes jump optimization arch-independent parts.
Kprobes uses breakpoint instruction for interrupting execution
flow, on some architectures, it can be replaced by a jump
instruction and interruption emulation code. This gains kprobs'
performance drastically.
To enable this feature, set CONFIG_OPTPROBES=y (default y if the
arch supports OPTPROBE).
Changes in v9:
- Fix a bug to optimize probe when enabling.
- Check nearby probes can be optimize/unoptimize when disarming/arming
kprobes, instead of registering/unregistering. This will help
kprobe-tracer because most of probes on it are usually disabled.
Changes in v6:
- Cleanup coding style for readability.
- Add comments around get/put_online_cpus().
Changes in v5:
- Use get_online_cpus()/put_online_cpus() for avoiding text_mutex
deadlock.
LKML-Reference: <20100225133407.6725.81992.stgit@localhost6.localdomain6>
Make insn_slot framework support various size slots.
Current insn_slot just supports one-size instruction buffer
slot. However, kprobes jump optimization needs larger size
buffers.
LKML-Reference: <20100225133358.6725.82430.stgit@localhost6.localdomain6>
Since mcount function can be called from everywhere,
it should be blacklisted. Moreover, the "mcount" symbol
is a special symbol name. So, it is better to put it in
the generic blacklist.
LKML-Reference: <20100205062433.3745.36726.stgit@dhcp-100-2-132.bos.redhat.com>
Check whether the address of new probe is already reserved by
ftrace or alternatives (on x86) when registering new probe.
If reserved, it returns an error and not register the probe.
Cc: przemyslaw@pawelczyk.it
LKML-Reference: <20100202214918.4694.94179.stgit@dhcp-100-2-132.bos.redhat.com>
Disable kprobe booster when CONFIG_PREEMPT=y at this time,
because it can't ensure that all kernel threads preempted on
kprobe's boosted slot run out from the slot even using
freeze_processes().
The booster on preemptive kernel will be resumed if
synchronize_tasks() or something like that is introduced.
LKML-Reference: <20100202214904.4694.24330.stgit@dhcp-100-2-132.bos.redhat.com>
Every time I see this:
kernel/kprobes.c: In function 'register_kretprobe':
kernel/kprobes.c:1038: warning: comparison of distinct pointer types lacks a cast
I'm wondering if something changed in common code and we need to
do something for s390. Apparently that's not the case.
Let's get rid of this annoying warning.
Cc: Masami Hiramatsu <mhiramat@redhat.com>
LKML-Reference: <20091221120224.GA4471@osiris.boeblingen.de.ibm.com>
* 'perf-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (470 commits)
x86: Fix comments of register/stack access functions
perf tools: Replace %m with %a in sscanf
hw-breakpoints: Keep track of user disabled breakpoints
tracing/syscalls: Make syscall events print callbacks static
tracing: Add DEFINE_EVENT(), DEFINE_SINGLE_EVENT() support to docbook
perf: Don't free perf_mmap_data until work has been done
perf_event: Fix compile error
perf tools: Fix _GNU_SOURCE macro related strndup() build error
trace_syscalls: Remove unused syscall_name_to_nr()
trace_syscalls: Simplify syscall profile
trace_syscalls: Remove duplicate init_enter_##sname()
trace_syscalls: Add syscall_nr field to struct syscall_metadata
trace_syscalls: Remove enter_id exit_id
trace_syscalls: Set event_enter_##sname->data to its metadata
trace_syscalls: Remove unused event_syscall_enter and event_syscall_exit
perf_event: Initialize data.period in perf_swevent_hrtimer()
perf probe: Simplify event naming
perf probe: Add --list option for listing current probe events
perf probe: Add argv_split() from lib/argv_split.c
perf probe: Move probe event utility functions to probe-event.c
For as long as kretprobes have existed, we've allocated NR_CPUS
instances of kretprobe_instance structures. With the default
value of CONFIG_NR_CPUS increasing on certain architectures, we
are potentially wasting kernel memory.
See http://sourceware.org/bugzilla/show_bug.cgi?id=10839#c3 for
more details.
Use a saner num_possible_cpus() instead of NR_CPUS for
allocation.
Cc: fweisbec@gmail.com
LKML-Reference: <20091030135310.GA22230@in.ibm.com>
kernel/trace/trace_event_profile.c
Merge reason: update to -rc5 and resolve conflict.
[akpm@linux-foundation.org: fix KVM]
kernel/trace/Makefile
kernel/trace/trace.h
kernel/trace/trace_event_types.h
kernel/trace/trace_export.c
Merge reason:
Sync with latest significant tracing core changes.
Make all seq_operations structs const, to help mitigate against
revectoring user-triggerable function pointers.
This is derived from the grsecurity patch, although generated from scratch
because it's simpler than extracting the changes from there.
Signed-off-by: James Morris <jmorris@namei.org>
Acked-by: Serge Hallyn <serue@us.ibm.com>
Acked-by: Casey Schaufler <casey@schaufler-ca.com>
Prevent re-registration of the same kprobe. This situation, though
unlikely, needs to be flagged since it can lead to a system crash if
it's not handled.
The core change itself is small, but the helper routine needed to be
moved around a bit; hence the diffstat.
Signed-off-by: Ananth N Mavinakayanahalli<ananth@in.ibm.com>
Cc: Frank Ch. Eigler <fche@redhat.com>
Cc: K.Prasad <prasad@linux.vnet.ibm.com>
Cc: Lai Jiangshan <laijs@cn.fujitsu.com>
Cc: Li Zefan <lizf@cn.fujitsu.com>
Cc: Tom Zanussi <tzanussi@gmail.com>
LKML-Reference: <20090915051307.GB26458@in.ibm.com>
Move irq-exit functions to .kprobes.text section to protect against
kprobes recursion.
When I ran kprobe stress test on x86-32, I found below symbols
cause unrecoverable recursive probing:
ret_from_exception
ret_from_intr
check_userspace
restore_all
restore_all_notrace
restore_nocheck
irq_return
And also, I found some interrupt/exception entry points that
cause similar problems.
This patch moves those symbols (including their container functions)
to .kprobes.text section to prevent any kprobes probing.
LKML-Reference: <20090908164755.24050.81182.stgit@dhcp-100-2-132.bos.redhat.com>
Since do_debug() calls get_debugreg(), native_get_debugreg() will be
called from singlestepping. This can cause an int3 infinite loop.
We can't put it in the .text.kprobes section because it is inlined,
then we blacklist its name.
LKML-Reference: <20090827172332.8246.34194.stgit@localhost.localdomain>
Kprobes can enter into a probing recursion, ie: a kprobe that does an
endless loop because one of its core mechanism function used during
probing is also probed itself.
This patch helps pinpointing the kprobe that raised such recursion
by dumping it and raising a BUG instead of a warning (we also disarm
the kprobe to try avoiding recursion in BUG itself). Having a BUG
instead of a warning stops the stacktrace in the right place and
doesn't pollute the logs with hundreds of traces that eventually end
up in a stack overflow.
kernel/trace/trace_events_filter.c
We use the tracing/core version.
Use kernel_text_address() for checking probe address instead of
__kernel_text_address(), because __kernel_text_address() returns true
for init functions even after relaseing those functions.
That will hit a BUG() in text_poke().
Use struct list instead of struct hlist for managing
insn_pages, because insn_pages doesn't use hash table.
LKML-Reference: <20090630210814.17851.64651.stgit@localhost.localdomain>
Remove needless kprobe_insn_mutex unlocking during safety check
in garbage collection, because if someone releases a dirty slot
during safety check (which ensures other cpus doesn't execute
all dirty slots), the safety check must be fail. So, we need to
hold the mutex while checking safety.
LKML-Reference: <20090630210809.17851.28781.stgit@localhost.localdomain>
Fix kprobes to lock text_mutex around some arch_arm/disarm_kprobe() which
are newly added by commit de5bd88d5a5cce3cacea904d3503e5ebdb3852a2.
Cc: Mathieu Desnoyers <mathieu.desnoyers@polymtl.ca>
Add disable_kprobe() and enable_kprobe() to disable/enable kprobes
temporarily.
disable_kprobe() asynchronously disables probe handlers of specified
kprobe. So, after calling it, some handlers can be called at a while.
enable_kprobe() enables specified kprobe.
aggr_pre_handler and aggr_post_handler check disabled probes. On the
other hand aggr_break_handler and aggr_fault_handler don't check it
because these handlers will be called while executing pre or post handlers
and usually those help error handling.
Rename kprobe_enabled to kprobes_all_disarmed and invert logic due to
avoiding naming confusion from per-probe disabling.
Clean up positions of EXPORT_SYMBOL_GPL in kernel/kprobes.c according to
checkpatch.pl.
Currently, kprobes can disable all probes at once, but can't disable it
individually (not unregister, just disable an kprobe, because
unregistering needs to wait for scheduler synchronization). These patches
introduce APIs for on-the-fly per-probe disabling and re-enabling by
dis-arming/re-arming its breakpoint instruction.
This patch:
Change old_p to ap in add_new_kprobe() for readability, copy flags member
in add_aggr_kprobe(), and simplify the code flow of
register_aggr_kprobe().
Fix locking imbalance in kretprobes:
[ BUG: bad unlock balance detected! ]
kthreadd/2 is trying to release lock (&rp->lock) at:
[<c06b3080>] pre_handler_kretprobe+0xea/0xf4
but there are no more locks to release!
1 lock held by kthreadd/2:
#0: (rcu_read_lock){..--}, at: [<c06b2b24>] __atomic_notifier_call_chain+0x0/0x5a
stack backtrace:
Pid: 2, comm: kthreadd Not tainted 2.6.29-rc8 #1
Call Trace:
[<c06ae498>] ? printk+0xf/0x17
[<c06b3080>] ? pre_handler_kretprobe+0xea/0xf4
[<c044ce6c>] print_unlock_inbalance_bug+0xc3/0xce
[<c0444d4b>] ? clocksource_read+0x7/0xa
[<c04450a4>] ? getnstimeofday+0x5f/0xf6
[<c044a9ca>] ? register_lock_class+0x17/0x293
[<c044b72c>] ? mark_lock+0x1e/0x30b
[<c0448956>] ? tick_dev_program_event+0x4a/0xbc
[<c0498100>] ? __slab_alloc+0xa5/0x415
[<c06b2fbe>] ? pre_handler_kretprobe+0x28/0xf4
[<c044cf1b>] lock_release_non_nested+0xa4/0x1a5
[<c044d15d>] lock_release+0x141/0x166
[<c06b07dd>] _spin_unlock_irqrestore+0x19/0x50
[<c06b20b5>] kprobe_exceptions_notify+0x1c9/0x43e
[<c06b2b02>] notifier_call_chain+0x26/0x48
[<c06b2b5b>] __atomic_notifier_call_chain+0x37/0x5a
[<c06b2b24>] ? __atomic_notifier_call_chain+0x0/0x5a
[<c06b2b8a>] atomic_notifier_call_chain+0xc/0xe
[<c0442d0d>] notify_die+0x2d/0x2f
[<c06b0f9c>] do_int3+0x1f/0x71
[<c06b0e84>] int3+0x2c/0x34
[<c042d476>] ? do_fork+0x1/0x288
[<c040221b>] ? kernel_thread+0x71/0x79
[<c043ed1b>] ? kthread+0x0/0x60
[<c04040b8>] ? kernel_thread_helper+0x0/0x10
[<c043ec7f>] kthreadd+0xac/0x148
[<c043ebd3>] ? kthreadd+0x0/0x148
[<c04040bf>] kernel_thread_helper+0x7/0x10
Tested-by: Bharata B Rao <bharata@linux.vnet.ibm.com>
Cc: <stable@kernel.org> [2.6.29.x, 2.6.28.x, 2.6.27.x]
LKML-Reference: <20090318113621.GB4129@in.ibm.com>
Use the mutual exclusion provided by the text edit lock in the kprobes code. It
allows coherent manipulation of the kernel code by other subsystems.
Changelog:
Move the kernel_text_lock/unlock out of the for loops.
Use text_mutex directly instead of a function.
Remove whitespace modifications.
(note : kprobes_mutex is always taken outside of text_mutex)
Signed-off-by: Mathieu Desnoyers <mathieu.desnoyers@polymtl.ca>
LKML-Reference: <49B14306.2080202@redhat.com>
Check CONFIG_FREEZER instead of CONFIG_PM because kprobe booster
depends on freeze_processes() and thaw_processes() when CONFIG_PREEMPT=y.
This fixes a linkage error which occurs when CONFIG_PREEMPT=y, CONFIG_PM=y
and CONFIG_FREEZER=n.
Reported-by: Cheng Renquan <crquan@gmail.com>
Signed-off-by: Len Brown <len.brown@intel.com>
Allow kprobes to probe module __init routines. When __init functions are
freed, kprobes which probe those functions are set to "Gone" flag. These
"Gone" probes are disarmed from the code and never be enabled.
Remove called_from argument from kprobes which had been used for
preventing self-refering of kernel module. However, since we don't keep
module's refcount after registering kprobe any more, there is no reason to
check that.
This patch also simplifies registering/unregistering functions because we
don't need to use __builtin_return_address(0) which was passed to
called_from.
[ananth@in.ibm.com: build fix]
Allows kprobes to probe __exit routine. This adds flags member to struct
kprobe. When module is freed(kprobes hooks module_notifier to get this
event), kprobes which probe the functions in that module are set to "Gone"
flag to the flags member. These "Gone" probes are never be enabled.
Users can check the GONE flag through debugfs.
This also removes mod_refcounted, because we couldn't free a module if
kprobe incremented the refcount of that module.
[akpm@linux-foundation.org: document some locking]
[mhiramat@redhat.com: bugfix: pass aggr_kprobe to arch_remove_kprobe]
[mhiramat@redhat.com: bugfix: release old_p's insn_slot before error return]
Add __kprobes to kprobes internal functions for protecting from probing by
kprobes itself.
Add kprobe_insn_mutex for protecting kprobe_insn_pages hlist, and remove
kprobe_mutex from architecture dependent code.
This allows us to call arch_remove_kprobe() (and free_insn_slot) while
holding kprobe_mutex.
Cc: "Luck, Tony" <tony.luck@intel.com>
