path: root/kernel/kthread.c
2008-04-21Merge branch 'semaphore' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/willy/misc * 'semaphore' of git://git.kernel.org/pub/scm/linux/kernel/git/willy/misc: Deprecate the asm/semaphore.h files in feature-removal-schedule. Convert asm/semaphore.h users to linux/semaphore.h security: Remove unnecessary inclusions of asm/semaphore.h lib: Remove unnecessary inclusions of asm/semaphore.h kernel: Remove unnecessary inclusions of asm/semaphore.h include: Remove unnecessary inclusions of asm/semaphore.h fs: Remove unnecessary inclusions of asm/semaphore.h drivers: Remove unnecessary inclusions of asm/semaphore.h net: Remove unnecessary inclusions of asm/semaphore.h arch: Remove unnecessary inclusions of asm/semaphore.h
2008-04-19sched: fix cpus_allowed settingsGregory Haskins
Signed-off-by: Gregory Haskins <ghaskins@novell.com> Acked-by: Steven Rostedt <srostedt@redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-04-18kernel: Remove unnecessary inclusions of asm/semaphore.hMatthew Wilcox
None of these files use any of the functionality promised by asm/semaphore.h. Signed-off-by: Matthew Wilcox <willy@linux.intel.com>
2008-01-25sched: fix, always create kernel threads with normal priorityMichal Schmidt
Ensure that the kernel threads are created with the usual nice level and affinity even if kthreadd's properties were changed from the default by root. Signed-off-by: Michal Schmidt <mschmidt@redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2007-07-31kthread: silence bogus section mismatch warningSatyam Sharma
WARNING: kernel/built-in.o(.text+0x16910): Section mismatch: reference to .init.text: (between 'kthreadd' and 'init_waitqueue_head') comes because kernel/kthread.c:kthreadd() is not __init but calls kthreadd_setup() which is __init. But this is ok, because kthreadd_setup() is only ever called at init time, and then kthreadd() proceeds into its "for (;;)" loop. We could mark kthreadd __init_refok, but kthreadd_setup() with just one callsite and 4 lines in it (it's been that small since 10ab825bdef8df51) doesn't need to be a separate function at all -- so let's just move those four lines at beginning of kthreadd() itself. Signed-off-by: Satyam Sharma <ssatyam@cse.iitk.ac.in> Acked-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-16mm: fix improper .init-type section referencesJan Beulich
.. which modpost started warning about. Signed-off-by: Jan Beulich <jbeulich@novell.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-23freezer: fix kthread_create vs freezer theoretical raceOleg Nesterov
kthread() sleeps in TASK_INTERRUPTIBLE state waiting for the first wakeup. In theory, this wakeup may come from freeze_process()->signal_wake_up(), so the task can disappear even before kthread_create() sets its ->comm. Change kthread() to use TASK_UNINTERRUPTIBLE. [akpm@linux-foundation.org: s/BUG_ON/WARN_ON+recover] Signed-off-by: Oleg Nesterov <oleg@tv-sign.ru> Acked-by: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Cc: Gautham R Shenoy <ego@in.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-09change kernel threads to ignore signals instead of blocking themOleg Nesterov
Currently kernel threads use sigprocmask(SIG_BLOCK) to protect against signals. This doesn't prevent the signal delivery, this only blocks signal_wake_up(). Every "killall -33 kthreadd" means a "struct siginfo" leak. Change kthreadd_setup() to set all handlers to SIG_IGN instead of blocking them (make a new helper ignore_signals() for that). If the kernel thread needs some signal, it should use allow_signal() anyway, and in that case it should not use CLONE_SIGHAND. Note that we can't change daemonize() (should die!) in the same way, because it can be used along with CLONE_SIGHAND. This means that allow_signal() still should unblock the signal to work correctly with daemonize()ed threads. However, disallow_signal() doesn't block the signal any longer but ignores it. NOTE: with or without this patch the kernel threads are not protected from handle_stop_signal(), this seems harmless, but not good. Signed-off-by: Oleg Nesterov <oleg@tv-sign.ru> Acked-by: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-09kthread: don't depend on work queuesEric W. Biederman
Currently there is a circular reference between work queue initialization and kthread initialization. This prevents the kthread infrastructure from initializing until after work queues have been initialized. We want the properties of tasks created with kthread_create to be as close as possible to the init_task and to not be contaminated by user processes. The later we start our kthreadd that creates these tasks the harder it is to avoid contamination from user processes and the more of a mess we have to clean up because the defaults have changed on us. So this patch modifies the kthread support to not use work queues but to instead use a simple list of structures, and to have kthreadd start from init_task immediately after our kernel thread that execs /sbin/init. By being a true child of init_task we only have to change those process settings that we want to have different from init_task, such as our process name, the cpus that are allowed, blocking all signals and setting SIGCHLD to SIG_IGN so that all of our children are reaped automatically. By being a true child of init_task we also naturally get our ppid set to 0 and do not wind up as a child of PID == 1. Ensuring that tasks generated by kthread_create will not slow down the functioning of the wait family of functions. [akpm@linux-foundation.org: use interruptible sleeps] Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Cc: Oleg Nesterov <oleg@tv-sign.ru> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-11[PATCH] Numerous fixes to kernel-doc info in source files.Robert P. J. Day
A variety of (mostly) innocuous fixes to the embedded kernel-doc content in source files, including: * make multi-line initial descriptions single line * denote some function names, constants and structs as such * change erroneous opening '/*' to '/**' in a few places * reword some text for clarity Signed-off-by: Robert P. J. Day <rpjday@mindspring.com> Cc: "Randy.Dunlap" <rdunlap@xenotime.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-11-22WorkStruct: Pass the work_struct pointer instead of context dataDavid Howells
Pass the work_struct pointer to the work function rather than context data. The work function can use container_of() to work out the data. For the cases where the container of the work_struct may go away the moment the pending bit is cleared, it is made possible to defer the release of the structure by deferring the clearing of the pending bit. To make this work, an extra flag is introduced into the management side of the work_struct. This governs auto-release of the structure upon execution. Ordinarily, the work queue executor would release the work_struct for further scheduling or deallocation by clearing the pending bit prior to jumping to the work function. This means that, unless the driver makes some guarantee itself that the work_struct won't go away, the work function may not access anything else in the work_struct or its container lest they be deallocated.. This is a problem if the auxiliary data is taken away (as done by the last patch). However, if the pending bit is *not* cleared before jumping to the work function, then the work function *may* access the work_struct and its container with no problems. But then the work function must itself release the work_struct by calling work_release(). In most cases, automatic release is fine, so this is the default. Special initiators exist for the non-auto-release case (ending in _NAR). Signed-Off-By: David Howells <dhowells@redhat.com>
2006-07-14[PATCH] remove kernel/kthread.c:kthread_stop_sem()Adrian Bunk
Remove the now-unneeded kthread_stop_sem(). Signed-off-by: Adrian Bunk <bunk@stusta.de> Acked-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-25[PATCH] kthread: move kernel-doc and put it into DocBookRandy Dunlap
Move kthread API kernel-doc from kthread.h to kthread.c & fix it. Add kthread API to kernel-api DocBook. Signed-off-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-25[PATCH] find_task_by_pid() needs tasklist_lockAndrew Morton
A couple of places are forgetting to take it. The kswapd case is probably unimportant. keventd_create_kthread() was racy. The whole thing is a bit flakey: you start a kernel thread, get its pid from kernel_thread() then look up its task_struct. a) It assumes that pid recycling takes a "long" time. b) We get a task_struct but no reference was taken on it. The owner of the kswapd and kthread task_struct*'s must assume that the new thread won't exit unexpectedly. Because if it does, they're left holding dead memory and any attempt to control or stop that task will crash. Cc: Christoph Hellwig <hch@lst.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-23[PATCH] sem2mutex: kernel/Arjan van de Ven
Semaphore to mutex conversion. The conversion was generated via scripts, and the result was validated automatically via a script as well. Signed-off-by: Arjan van de Ven <arjan@infradead.org> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-30[PATCH] Add kthread_stop_sem()Alan Stern
Enhance the kthread API by adding kthread_stop_sem, for use in stopping threads that spend their idle time waiting on a semaphore. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-05-01[PATCH] use smp_mb/wmb/rmb where possibleakpm@osdl.org
Replace a number of memory barriers with smp_ variants. This means we won't take the unnecessary hit on UP machines. Signed-off-by: Anton Blanchard <anton@samba.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
