path: root/kernel/lockdep.c
2010-06-09sched_clock: Add local_clock() API and improve documentationPeter Zijlstra
For people who otherwise get to write: cpu_clock(smp_processor_id()), there is now: local_clock(). Also, as per suggestion from Andrew, provide some documentation on the various clock interfaces, and minimize the unsigned long long vs u64 mess. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Jens Axboe <jaxboe@fusionio.com> LKML-Reference: <1275052414.1645.52.camel@laptop> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-05-21lockdep: Add novalidate class for dev->mutex conversionPeter Zijlstra
The conversion of device->sem to device->mutex resulted in lockdep warnings. Create a novalidate class for now until the driver folks come up with separate classes. That way we have at least the basic mutex debugging coverage. Add a checkpatch error so the usage is reserved for device->mutex. [ tglx: checkpatch and compile fix for LOCKDEP=n ] Signed-off-by: Peter Zijlstra <peterz@infradead.org> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-05-18Merge branch 'perf-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'perf-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (311 commits) perf tools: Add mode to build without newt support perf symbols: symbol inconsistency message should be done only at verbose=1 perf tui: Add explicit -lslang option perf options: Type check all the remaining OPT_ variants perf options: Type check OPT_BOOLEAN and fix the offenders perf options: Check v type in OPT_U?INTEGER perf options: Introduce OPT_UINTEGER perf tui: Add workaround for slang < 2.1.4 perf record: Fix bug mismatch with -c option definition perf options: Introduce OPT_U64 perf tui: Add help window to show key associations perf tui: Make <- exit menus too perf newt: Add single key shortcuts for zoom into DSO and threads perf newt: Exit browser unconditionally when CTRL+C, q or Q is pressed perf newt: Fix the 'A'/'a' shortcut for annotate perf newt: Make <- exit the ui_browser x86, perf: P4 PMU - fix counters management logic perf newt: Make <- zoom out filters perf report: Report number of events, not samples perf hist: Clarify events_stats fields usage ... Fix up trivial conflicts in kernel/fork.c and tools/perf/builtin-record.c
2010-05-18Merge branch 'core-rcu-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'core-rcu-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (24 commits) rcu: remove all rcu head initializations, except on_stack initializations rcu head introduce rcu head init on stack Debugobjects transition check rcu: fix build bug in RCU_FAST_NO_HZ builds rcu: RCU_FAST_NO_HZ must check RCU dyntick state rcu: make SRCU usable in modules rcu: improve the RCU CPU-stall warning documentation rcu: reduce the number of spurious RCU_SOFTIRQ invocations rcu: permit discontiguous cpu_possible_mask CPU numbering rcu: improve RCU CPU stall-warning messages rcu: print boot-time console messages if RCU configs out of ordinary rcu: disable CPU stall warnings upon panic rcu: enable CPU_STALL_VERBOSE by default rcu: slim down rcutiny by removing rcu_scheduler_active and friends rcu: refactor RCU's context-switch handling rcu: rename rcutiny rcu_ctrlblk to rcu_sched_ctrlblk rcu: shrink rcutiny by making synchronize_rcu_bh() be inline rcu: fix now-bogus rcu_scheduler_active comments. rcu: Fix bogus CONFIG_PROVE_LOCKING in comments to reflect reality. rcu: ignore offline CPUs in last non-dyntick-idle CPU check ...
2010-05-10rcu: optionally leave lockdep enabled after RCU lockdep splatLai Jiangshan
There is no need to disable lockdep after an RCU lockdep splat, so remove the debug_lockdeps_off() from lockdep_rcu_dereference(). To avoid repeated lockdep splats, use a static variable in the inlined rcu_dereference_check() and rcu_dereference_protected() macros so that a given instance splats only once, but so that multiple instances can be detected per boot. This is controlled by a new config variable CONFIG_PROVE_RCU_REPEATEDLY, which is disabled by default. This provides the normal lockdep behavior by default, but permits people who want to find multiple RCU-lockdep splats per boot to easily do so. Requested-by: Eric Paris <eparis@redhat.com> Signed-off-by: Lai Jiangshan <laijs@cn.fujitsu.com> Tested-by: Eric Paris <eparis@redhat.com> Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com>
2010-05-09tracing: Drop the nested field from lock_release eventFrederic Weisbecker
Drop the nested field as we don't use it. Every nested state can be computed from a state machine on post processing already. Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Hitoshi Mitake <mitake@dcl.info.waseda.ac.jp> Cc: Steven Rostedt <rostedt@goodmis.org>
2010-05-09tracing: Drop lock_acquired waittime fieldFrederic Weisbecker
Drop the waittime field from the lock_acquired event, we can calculate it by substracting the lock_acquired event timestamp with the matching lock_acquire one. It is not needed and takes useless space in the traces. Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Hitoshi Mitake <mitake@dcl.info.waseda.ac.jp> Cc: Steven Rostedt <rostedt@goodmis.org>
2010-05-07lockdep: Reduce stack_trace usageYong Zhang
When calling check_prevs_add(), if all validations passed add_lock_to_list() will add new lock to dependency tree and alloc stack_trace for each list_entry. But at this time, we are always on the same stack, so stack_trace for each list_entry has the same value. This is redundant and eats up lots of memory which could lead to warning on low MAX_STACK_TRACE_ENTRIES. Use one copy of stack_trace instead. V2: As suggested by Peter Zijlstra, move save_trace() from check_prevs_add() to check_prev_add(). Add tracking for trylock dependence which is also redundant. Signed-off-by: Yong Zhang <yong.zhang0@windriver.com> Cc: David S. Miller <davem@davemloft.net> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> LKML-Reference: <20100504065711.GC10784@windriver.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-05-04lockdep: Provide off case for redundant_hardirqs_on incrementFrederic Weisbecker
We forgot to provide a !CONFIG_DEBUG_LOCKDEP case for the redundant_hardirqs_on stat handling. Manage that in the headers with a new __debug_atomic_inc() helper. Fixes: kernel/lockdep.c:2306: error: 'lockdep_stats' undeclared (first use in this function) kernel/lockdep.c:2306: error: (Each undeclared identifier is reported only once kernel/lockdep.c:2306: error: for each function it appears in.) Reported-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com> Cc: Peter Zijlstra <peterz@infradead.org>
2010-04-30lockdep: Fix redundant_hardirqs_on incremented with irqs enabledFrederic Weisbecker
When a path restore the flags while irqs are already enabled, we update the per cpu var redundant_hardirqs_on in a racy fashion and debug_atomic_inc() warns about this situation. In this particular case, loosing a few hits in a stat is not a big deal, so increment it without protection. v2: Don't bother with disabling irq, we can miss one count in rare situations Reported-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: David Miller <davem@davemloft.net> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2010-04-30Merge commit 'v2.6.34-rc6' into core/lockingFrederic Weisbecker
Merge reason: Further lockdep patches depend on per cpu updates made in -rc1.
2010-04-06lockstat: Make lockstat counting per cpuFrederic Weisbecker
Locking statistics are implemented using global atomic variables. This is usually fine unless some path write them very often. This is the case for the function and function graph tracers that disable irqs for each entry saved (except if the function tracer is in preempt disabled only mode). And calls to local_irq_save/restore() increment hardirqs_on_events and hardirqs_off_events stats (or similar stats for redundant versions). Incrementing these global vars for each function ends up in too much cache bouncing if lockstats are enabled. To solve this, implement the debug_atomic_*() operations using per cpu vars. -v2: Use per_cpu() instead of get_cpu_var() to fetch the desired cpu vars on debug_atomic_read() -v3: Store the stats in a structure. No need for local_t as we are NMI/irq safe. -v4: Fix tons of build errors. I thought I had tested it but I probably forgot to select the relevant config. Suggested-by: Steven Rostedt <rostedt@goodmis.org> Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Steven Rostedt <rostedt@goodmis.org> LKML-Reference: <1270505417-8144-1-git-send-regression-fweisbec@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Steven Rostedt <rostedt@goodmis.org>
2010-04-05Merge branch 'slabh' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/miscLinus Torvalds
* 'slabh' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/misc: eeepc-wmi: include slab.h staging/otus: include slab.h from usbdrv.h percpu: don't implicitly include slab.h from percpu.h kmemcheck: Fix build errors due to missing slab.h include cleanup: Update gfp.h and slab.h includes to prepare for breaking implicit slab.h inclusion from percpu.h iwlwifi: don't include iwl-dev.h from iwl-devtrace.h x86: don't include slab.h from arch/x86/include/asm/pgtable_32.h Fix up trivial conflicts in include/linux/percpu.h due to is_kernel_percpu_address() having been introduced since the slab.h cleanup with the percpu_up.c splitup.
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-03-29percpu, module: implement and use is_kernel/module_percpu_address()Tejun Heo
lockdep has custom code to check whether a pointer belongs to static percpu area which is somewhat broken. Implement proper is_kernel/module_percpu_address() and replace the custom code. On UP, percpu variables are regular static variables and can't be distinguished from them. Always return %false on UP. Signed-off-by: Tejun Heo <tj@kernel.org> Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: Ingo Molnar <mingo@redhat.com>
2010-03-18Merge branch 'perf-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'perf-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (35 commits) perf: Fix unexported generic perf_arch_fetch_caller_regs perf record: Don't try to find buildids in a zero sized file perf: export perf_trace_regs and perf_arch_fetch_caller_regs perf, x86: Fix hw_perf_enable() event assignment perf, ppc: Fix compile error due to new cpu notifiers perf: Make the install relative to DESTDIR if specified kprobes: Calculate the index correctly when freeing the out-of-line execution slot perf tools: Fix sparse CPU numbering related bugs perf_event: Fix oops triggered by cpu offline/online perf: Drop the obsolete profile naming for trace events perf: Take a hot regs snapshot for trace events perf: Introduce new perf_fetch_caller_regs() for hot regs snapshot perf/x86-64: Use frame pointer to walk on irq and process stacks lockdep: Move lock events under lockdep recursion protection perf report: Print the map table just after samples for which no map was found perf report: Add multiple event support perf session: Change perf_session post processing functions to take histogram tree perf session: Add storage for seperating event types in report perf session: Change add_hist_entry to take the tree root instead of session perf record: Add ID and to recorded event data when recording multiple events ...
2010-03-10lockdep: Move lock events under lockdep recursion protectionFrederic Weisbecker
There are rcu locked read side areas in the path where we submit a trace event. And these rcu_read_(un)lock() trigger lock events, which create recursive events. One pair in do_perf_sw_event: __lock_acquire | |--96.11%-- lock_acquire | | | |--27.21%-- do_perf_sw_event | | perf_tp_event | | | | | |--49.62%-- ftrace_profile_lock_release | | | lock_release | | | | | | | |--33.85%-- _raw_spin_unlock Another pair in perf_output_begin/end: __lock_acquire |--23.40%-- perf_output_begin | | __perf_event_overflow | | perf_swevent_overflow | | perf_swevent_add | | perf_swevent_ctx_event | | do_perf_sw_event | | perf_tp_event | | | | | |--55.37%-- ftrace_profile_lock_acquire | | | lock_acquire | | | | | | | |--37.31%-- _raw_spin_lock The problem is not that much the trace recursion itself, as we have a recursion protection already (though it's always wasteful to recurse). But the trace events are outside the lockdep recursion protection, then each lockdep event triggers a lock trace, which will trigger two other lockdep events. Here the recursive lock trace event won't be taken because of the trace recursion, so the recursion stops there but lockdep will still analyse these new events: To sum up, for each lockdep events we have: lock_*() | trace lock_acquire | ----- rcu_read_lock() | | | lock_acquire() | | | trace_lock_acquire() (stopped) | | | lockdep analyze | ----- rcu_read_unlock() | lock_release | trace_lock_release() (stopped) | lockdep analyze And you can repeat the above two times as we have two rcu read side sections when we submit an event. This is fixed in this patch by moving the lock trace event under the lockdep recursion protection. Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Hitoshi Mitake <mitake@dcl.info.waseda.ac.jp> Cc: Li Zefan <lizf@cn.fujitsu.com> Cc: Lai Jiangshan <laijs@cn.fujitsu.com> Cc: Masami Hiramatsu <mhiramat@redhat.com> Cc: Jens Axboe <jens.axboe@oracle.com>
2010-03-04rcu: Add control variables to lockdep_rcu_dereference() diagnosticsPaul E. McKenney
Add the values of rcu_scheduler_active() and debug_locks() to the lockdep_rcu_dereference() output to help diagnose RCU lockdep splats that occur shortly after the scheduler starts. Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: laijs@cn.fujitsu.com Cc: dipankar@in.ibm.com Cc: mathieu.desnoyers@polymtl.ca Cc: josh@joshtriplett.org Cc: dvhltc@us.ibm.com Cc: niv@us.ibm.com Cc: peterz@infradead.org Cc: rostedt@goodmis.org Cc: Valdis.Kletnieks@vt.edu Cc: dhowells@redhat.com LKML-Reference: <1267631219-8713-4-git-send-email-paulmck@linux.vnet.ibm.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-02-26rcu: Make lockdep_rcu_dereference() message less alarmistPaul E. McKenney
Change from "unsafe" to "suspicious", given that there will be false alarms. Suggested-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: laijs@cn.fujitsu.com Cc: dipankar@in.ibm.com Cc: mathieu.desnoyers@polymtl.ca Cc: josh@joshtriplett.org Cc: dvhltc@us.ibm.com Cc: niv@us.ibm.com Cc: peterz@infradead.org Cc: rostedt@goodmis.org Cc: Valdis.Kletnieks@vt.edu Cc: dhowells@redhat.com LKML-Reference: <1267135607-7056-1-git-send-email-paulmck@linux.vnet.ibm.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-02-25rcu: Integrate rcu_dereference_check() message into lockdepPaul E. McKenney
Make rcu_dereference_check() print the list of held locks in addition to the stack dump to ease debugging. Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: laijs@cn.fujitsu.com Cc: dipankar@in.ibm.com Cc: mathieu.desnoyers@polymtl.ca Cc: josh@joshtriplett.org Cc: dvhltc@us.ibm.com Cc: niv@us.ibm.com Cc: peterz@infradead.org Cc: rostedt@goodmis.org Cc: Valdis.Kletnieks@vt.edu Cc: dhowells@redhat.com LKML-Reference: <1266887105-1528-3-git-send-email-paulmck@linux.vnet.ibm.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-01-27lockdep: Fix check_usage_backwards() error messageOleg Nesterov
Lockdep has found the real bug, but the output doesn't look right to me: > ========================================================= > [ INFO: possible irq lock inversion dependency detected ] > 2.6.33-rc5 #77 > --------------------------------------------------------- > emacs/1609 just changed the state of lock: > (&(&tty->ctrl_lock)->rlock){+.....}, at: [<ffffffff8127c648>] tty_fasync+0xe8/0x190 > but this lock took another, HARDIRQ-unsafe lock in the past: > (&(&sighand->siglock)->rlock){-.....} "HARDIRQ-unsafe" and "this lock took another" looks wrong, afaics. > ... key at: [<ffffffff81c054a4>] __key.46539+0x0/0x8 > ... acquired at: > [<ffffffff81089af6>] __lock_acquire+0x1056/0x15a0 > [<ffffffff8108a0df>] lock_acquire+0x9f/0x120 > [<ffffffff81423012>] _raw_spin_lock_irqsave+0x52/0x90 > [<ffffffff8127c1be>] __proc_set_tty+0x3e/0x150 > [<ffffffff8127e01d>] tty_open+0x51d/0x5e0 The stack-trace shows that this lock (ctrl_lock) was taken under ->siglock (which is hopefully irq-safe). This is a clear typo in check_usage_backwards() where we tell the print a fancy routine we're forwards. Signed-off-by: Oleg Nesterov <oleg@redhat.com> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> LKML-Reference: <20100126181641.GA10460@redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-12-14locking: Convert __raw_spin* functions to arch_spin*Thomas Gleixner
Name space cleanup. No functional change. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: Peter Zijlstra <peterz@infradead.org> Acked-by: David S. Miller <davem@davemloft.net> Acked-by: Ingo Molnar <mingo@elte.hu> Cc: linux-arch@vger.kernel.org
2009-12-14locking: Rename __RAW_SPIN_LOCK_UNLOCKED to __ARCH_SPIN_LOCK_UNLOCKEDThomas Gleixner
Further name space cleanup. No functional change Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: Peter Zijlstra <peterz@infradead.org> Acked-by: David S. Miller <davem@davemloft.net> Acked-by: Ingo Molnar <mingo@elte.hu> Cc: linux-arch@vger.kernel.org
2009-12-14locking: Convert raw_spinlock to arch_spinlockThomas Gleixner
The raw_spin* namespace was taken by lockdep for the architecture specific implementations. raw_spin_* would be the ideal name space for the spinlocks which are not converted to sleeping locks in preempt-rt. Linus suggested to convert the raw_ to arch_ locks and cleanup the name space instead of using an artifical name like core_spin, atomic_spin or whatever No functional change. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: Peter Zijlstra <peterz@infradead.org> Acked-by: David S. Miller <davem@davemloft.net> Acked-by: Ingo Molnar <mingo@elte.hu> Cc: linux-arch@vger.kernel.org
2009-12-14Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tj/percpu * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/percpu: (34 commits) m68k: rename global variable vmalloc_end to m68k_vmalloc_end percpu: add missing per_cpu_ptr_to_phys() definition for UP percpu: Fix kdump failure if booted with percpu_alloc=page percpu: make misc percpu symbols unique percpu: make percpu symbols in ia64 unique percpu: make percpu symbols in powerpc unique percpu: make percpu symbols in x86 unique percpu: make percpu symbols in xen unique percpu: make percpu symbols in cpufreq unique percpu: make percpu symbols in oprofile unique percpu: make percpu symbols in tracer unique percpu: make percpu symbols under kernel/ and mm/ unique percpu: remove some sparse warnings percpu: make alloc_percpu() handle array types vmalloc: fix use of non-existent percpu variable in put_cpu_var() this_cpu: Use this_cpu_xx in trace_functions_graph.c this_cpu: Use this_cpu_xx for ftrace this_cpu: Use this_cpu_xx in nmi handling this_cpu: Use this_cpu operations in RCU this_cpu: Use this_cpu ops for VM statistics ... Fix up trivial (famous last words) global per-cpu naming conflicts in arch/x86/kvm/svm.c mm/slab.c
2009-12-10lockdep: Avoid out of bounds array reference in save_trace()Luck, Tony
ia64 found this the hard way (because we currently have a stub for save_stack_trace() that does nothing). But it would be a good idea to be cautious in case a real save_stack_trace() bailed out with an error before it set trace->nr_entries. Signed-off-by: Tony Luck <tony.luck@intel.com> Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: luming.yu@intel.com LKML-Reference: <4b2024d085302c2a2@agluck-desktop.sc.intel.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-12-06lockstat: Fix min, max times in /proc/lock_statsFrank Rowand
Fix min, max times in /proc/lock_stats (1) When collecting lock hold and wait times, if the current minimum time is zero, it will be replaced by the next time. (2) When aggregating minimum and maximum lock hold and wait times accross cpus, the values are added, instead of selecting the minimum and maximum. Signed-off-by: Frank Rowand <frank.rowand@am.sony.com> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> LKML-Reference: <4B05BBAE.2050005@am.sony.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-11-13tracing: Rename 'lockdep' event subsystem into 'lock'Frederic Weisbecker
Lockdep events subsystem gathers various locking related events such as a request, release, contention or acquisition of a lock. The name of this event subsystem is a bit of a misnomer since these events are not quite related to lockdep but more generally to locking, ie: these events are not reporting lock dependencies or possible deadlock scenario but pure locking events. Hence this rename. Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com> Acked-by: Peter Zijlstra <peterz@infradead.org> Acked-by: Hitoshi Mitake <mitake@dcl.info.waseda.ac.jp> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Li Zefan <lizf@cn.fujitsu.com> LKML-Reference: <1258103194-843-1-git-send-email-fweisbec@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-10-29percpu: make percpu symbols under kernel/ and mm/ uniqueTejun Heo
This patch updates percpu related symbols under kernel/ and mm/ such that percpu symbols are unique and don't clash with local symbols. This serves two purposes of decreasing the possibility of global percpu symbol collision and allowing dropping per_cpu__ prefix from percpu symbols. * kernel/lockdep.c: s/lock_stats/cpu_lock_stats/ * kernel/sched.c: s/init_rq_rt/init_rt_rq_var/ (any better idea?) s/sched_group_cpus/sched_groups/ * kernel/softirq.c: s/ksoftirqd/run_ksoftirqd/a * kernel/softlockup.c: s/(*)_timestamp/softlockup_\1_ts/ s/watchdog_task/softlockup_watchdog/ s/timestamp/ts/ for local variables * kernel/time/timer_stats: s/lookup_lock/tstats_lookup_lock/ * mm/slab.c: s/reap_work/slab_reap_work/ s/reap_node/slab_reap_node/ * mm/vmstat.c: local variable changed to avoid collision with vmstat_work Partly based on Rusty Russell's "alloc_percpu: rename percpu vars which cause name clashes" patch. Signed-off-by: Tejun Heo <tj@kernel.org> Acked-by: (slab/vmstat) Christoph Lameter <cl@linux-foundation.org> Reviewed-by: Christoph Lameter <cl@linux-foundation.org> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: Ingo Molnar <mingo@redhat.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Nick Piggin <npiggin@suse.de>
2009-10-09lockdep: Use cpu_clock() for lockstatPeter Zijlstra
Some tracepoint magic (TRACE_EVENT(lock_acquired)) relies on the fact that lock hold times are positive and uses div64 on that. That triggered a build warning on MIPS, and probably causes bad output in certain circumstances as well. Make it truly positive. Reported-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> LKML-Reference: <1254818502.21044.112.camel@laptop> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-09-23lockdep: use new arch_is_kernel_data()Mike Frysinger
This allows lockdep to locate symbols that are in arch-specific data sections (such as data in Blackfin on-chip SRAM regions). Signed-off-by: Mike Frysinger <vapier@gentoo.org> Cc: Ingo Molnar <mingo@elte.hu> Cc: Robin Getz <rgetz@blackfin.uclinux.org> Cc: Sam Ravnborg <sam@ravnborg.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-08-29lockdep: Remove recursion stattisticsMing Lei
Since lockdep has introduced BFS to avoid recursion, statistics for recursion does not make any sense now. So remove them. Signed-off-by: Ming Lei <tom.leiming@gmail.com> Cc: a.p.zijlstra@chello.nl LKML-Reference: <1251542879-5211-1-git-send-email-tom.leiming@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-08-02lockdep: Fix memory usage info of BFSMing Lei
The unit is KB, so sizeof(struct circular_queue) should be divided by 1024. Signed-off-by: Ming Lei <tom.leiming@gmail.com> Cc: akpm@linux-foundation.org Cc: torvalds@linux-foundation.org Cc: davem@davemloft.net Cc: Ming Lei <tom.leiming@gmail.com> Cc: a.p.zijlstra@chello.nl LKML-Reference: <1249220616-7190-1-git-send-email-tom.leiming@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-08-02lockdep: Reintroduce generation count to make BFS fasterMing Lei
We still can apply DaveM's generation count optimization to BFS, based on the following idea: - before doing each BFS, increase the global generation id by 1 - if one node in the graph has been visited, mark it as visited by storing the current global generation id into the node's dep_gen_id field - so we can decide if one node has been visited already, by comparing the node's dep_gen_id with the global generation id. By applying DaveM's generation count optimization to current implementation of BFS, we gain the following advantages: - we save MAX_LOCKDEP_ENTRIES/8 bytes memory; - we remove the bitmap_zero(bfs_accessed, MAX_LOCKDEP_ENTRIES); in each BFS, which is very time-consuming since MAX_LOCKDEP_ENTRIES may be very large.(16384UL) Signed-off-by: Ming Lei <tom.leiming@gmail.com> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: "David S. Miller" <davem@davemloft.net> LKML-Reference: <1248274089-6358-1-git-send-email-tom.leiming@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-08-02lockdep: Deal with many similar locksPeter Zijlstra
spin_lock_nest_lock() allows to take many instances of the same class, this can easily lead to overflow of MAX_LOCK_DEPTH. To avoid this overflow, we'll stop accounting instances but start reference counting the class in the held_lock structure. [ We could maintain a list of instances, if we'd move the hlock stuff into __lock_acquired(), but that would require significant modifications to the current code. ] We restrict this mode to spin_lock_nest_lock() only, because it degrades the lockdep quality due to lost of instance. For lockstat this means we don't track lock statistics for any but the first lock in the series. Currently nesting is limited to 11 bits because that was the spare space available in held_lock. This yields a 2048 instances maximium. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Marcelo Tosatti <mtosatti@redhat.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-08-02lockdep: Introduce lockdep_assert_held()Peter Zijlstra
Add a lockdep helper to validate that we indeed are the owner of a lock. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-08-02lockdep: Fix style nitsPeter Zijlstra
fixes a few comments and whitespaces that annoyed me. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-08-02lockdep: Fix backtracesPeter Zijlstra
Truncate stupid -1 entries in backtraces. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> LKML-Reference: <1248096665.15751.8816.camel@twins> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-07-24lockdep: BFS cleanupPeter Zijlstra
Some cleanups of the lockdep code after the BFS series: - Remove the last traces of the generation id - Fixup comment style - Move the bfs routines into lockdep.c - Cleanup the bfs routines [ tom.leiming@gmail.com: Fix crash ] Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> LKML-Reference: <1246201486-7308-11-git-send-email-tom.leiming@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-07-24lockdep: Add statistics info for max bfs queue depthMing Lei
Add BFS statistics to the existing lockdep stats. Signed-off-by: Ming Lei <tom.leiming@gmail.com> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> LKML-Reference: <1246201486-7308-10-git-send-email-tom.leiming@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-07-24lockdep: Update memory usage introduced by BFSMing Lei
Also account the BFS memory usage. Signed-off-by: Ming Lei <tom.leiming@gmail.com> [ fix build for !PROVE_LOCKING ] Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> LKML-Reference: <1246201486-7308-9-git-send-email-tom.leiming@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-07-24lockdep: Implement lockdep_count_*ward_deps by BFSMing Lei
Implement lockdep_count_{for,back}ward using BFS. Signed-off-by: Ming Lei <tom.leiming@gmail.com> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> LKML-Reference: <1246201486-7308-8-git-send-email-tom.leiming@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-07-24lockdep: Introduce print_shortest_lock_dependenciesMing Lei
Since the shortest lock dependencies' path may be obtained by BFS, we print the shortest one by print_shortest_lock_dependencies(). Signed-off-by: Ming Lei <tom.leiming@gmail.com> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> LKML-Reference: <1246201486-7308-7-git-send-email-tom.leiming@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-07-24lockdep: Implement find_usage_*wards by BFSMing Lei
This patch uses BFS to implement find_usage_*wards(),which was originally writen by DFS. Signed-off-by: Ming Lei <tom.leiming@gmail.com> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> LKML-Reference: <1246201486-7308-6-git-send-email-tom.leiming@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-07-24lockdep: Implement check_noncircular() by BFSMing Lei
This patch uses BFS to implement check_noncircular() and prints the generated shortest circle if exists. Signed-off-by: Ming Lei <tom.leiming@gmail.com> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> LKML-Reference: <1246201486-7308-5-git-send-email-tom.leiming@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-07-24lockdep: Introduce match function to BFSMing Lei
1,introduce match() to BFS in order to make it usable to match different pattern; 2,also rename some functions to make them more suitable. Signed-off-by: Ming Lei <tom.leiming@gmail.com> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> LKML-Reference: <1246201486-7308-4-git-send-email-tom.leiming@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-07-24lockdep: Improve implementation of BFSMing Lei
1,replace %MAX_CIRCULAR_QUE_SIZE with &(MAX_CIRCULAR_QUE_SIZE-1) since we define MAX_CIRCULAR_QUE_SIZE as power of 2; 2,use bitmap to mark if a lock is accessed in BFS in order to clear it quickly, because we may search a graph many times. Signed-off-by: Ming Lei <tom.leiming@gmail.com> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> LKML-Reference: <1246201486-7308-3-git-send-email-tom.leiming@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-07-24lockdep: Print the shortest dependency chain if finding a circleMing Lei
Currently lockdep will print the 1st circle detected if it exists when acquiring a new (next) lock. This patch prints the shortest path from the next lock to be acquired to the previous held lock if a circle is found. The patch still uses the current method to check circle, and once the circle is found, breadth-first search algorithem is used to compute the shortest path from the next lock to the previous lock in the forward lock dependency graph. Printing the shortest path will shorten the dependency chain, and make troubleshooting for possible circular locking easier. Signed-off-by: Ming Lei <tom.leiming@gmail.com> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> LKML-Reference: <1246201486-7308-2-git-send-email-tom.leiming@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-05-07Merge branch 'linus' into tracing/coreIngo Molnar
Merge reason: tracing/core was on a .30-rc1 base and was missing out on on a handful of tracing fixes present in .30-rc5-almost. Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-04-17lockdep: more robust lockdep_map init sequencePeter Zijlstra
Steven Rostedt reported: > OK, I think I figured this bug out. This is a lockdep issue with respect > to tracepoints. > > The trace points in lockdep are called all the time. Outside the lockdep > logic. But if lockdep were to trigger an error / warning (which this run > did) we might be in trouble. For new locks, like the dentry->d_lock, that > are created, they will not get a name: > > void lockdep_init_map(struct lockdep_map *lock, const char *name, > struct lock_class_key *key, int subclass) > { > if (unlikely(!debug_locks)) > return; > > When a problem is found by lockdep, debug_locks becomes false. Thus we > stop allocating names for locks. This dentry->d_lock I had, now has no > name. Worse yet, I have CONFIG_DEBUG_VM set, that scrambles non > initialized memory. Thus, when the trace point was hit, it had junk for > the lock->name, and the machine crashed. Ah, nice catch. I think we should put at least the name in regardless. Ensure we at least initialize the trivial entries of the depmap so that they can be relied upon, even when lockdep itself decided to pack up and go home. [ Impact: fix lock tracing after lockdep warnings. ] Reported-by: Steven Rostedt <rostedt@goodmis.org> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Acked-by: Steven Rostedt <rostedt@goodmis.org> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Frederic Weisbecker <fweisbec@gmail.com> LKML-Reference: <1239954049.23397.4156.camel@laptop> Signed-off-by: Ingo Molnar <mingo@elte.hu>
