The mainline kernel as of 2.6.34-rc5 is not affected by this problem because
commit 10fad5e46f6c7bdfb01b1a012380a38e3c6ab346 fixed it by refactoring.
lockdep fix incorrect percpu usage
Should use per_cpu_ptr() to obfuscate the per cpu pointers (RELOC_HIDE is needed
for per cpu pointers).
git blame points to commit:
lockdep.c: commit 8e18257d29238311e82085152741f0c3aa18b74d
But it's really just moving the code around. But it's enough to say that the
problems appeared before Jul 19 01:48:54 2007, which brings us back to 2.6.23.
It should be applied to stable 2.6.23.x to 2.6.33.x (or whichever of these
stable branches are still maintained).
(tested on 2.6.33.1 x86_64)
Signed-off-by: Mathieu Desnoyers <mathieu.desnoyers@efficios.com>
CC: Randy Dunlap <randy.dunlap@oracle.com>
CC: Eric Dumazet <dada1@cosmosbay.com>
CC: Rusty Russell <rusty@rustcorp.com.au>
CC: Peter Zijlstra <a.p.zijlstra@chello.nl>
CC: Tejun Heo <tj@kernel.org>
CC: Ingo Molnar <mingo@elte.hu>
CC: Andrew Morton <akpm@linux-foundation.org>
CC: Linus Torvalds <torvalds@linux-foundation.org>
CC: Greg Kroah-Hartman <gregkh@suse.de>
CC: Steven Rostedt <rostedt@goodmis.org>
Some tracepoint magic (TRACE_EVENT(lock_acquired)) relies on
the fact that lock hold times are positive and uses div64 on
that. That triggered a build warning on MIPS, and probably
causes bad output in certain circumstances as well.
Make it truly positive.
Reported-by: Andrew Morton <akpm@linux-foundation.org>
LKML-Reference: <1254818502.21044.112.camel@laptop>
This allows lockdep to locate symbols that are in arch-specific data
sections (such as data in Blackfin on-chip SRAM regions).
Cc: Robin Getz <rgetz@blackfin.uclinux.org>
Since lockdep has introduced BFS to avoid recursion, statistics
for recursion does not make any sense now. So remove them.
Signed-off-by: Ming Lei <tom.leiming@gmail.com>
Cc: a.p.zijlstra@chello.nl
LKML-Reference: <1251542879-5211-1-git-send-email-tom.leiming@gmail.com>
The unit is KB, so sizeof(struct circular_queue) should be
divided by 1024.
Cc: akpm@linux-foundation.org
Cc: torvalds@linux-foundation.org
Cc: davem@davemloft.net
Cc: Ming Lei <tom.leiming@gmail.com>
LKML-Reference: <1249220616-7190-1-git-send-email-tom.leiming@gmail.com>
We still can apply DaveM's generation count optimization to
BFS, based on the following idea:
- before doing each BFS, increase the global generation id
by 1
- if one node in the graph has been visited, mark it as
visited by storing the current global generation id into
the node's dep_gen_id field
- so we can decide if one node has been visited already, by
comparing the node's dep_gen_id with the global generation id.
By applying DaveM's generation count optimization to current
implementation of BFS, we gain the following advantages:
- we save MAX_LOCKDEP_ENTRIES/8 bytes memory;
- we remove the bitmap_zero(bfs_accessed, MAX_LOCKDEP_ENTRIES);
in each BFS, which is very time-consuming since
MAX_LOCKDEP_ENTRIES may be very large.(16384UL)
LKML-Reference: <1248274089-6358-1-git-send-email-tom.leiming@gmail.com>
spin_lock_nest_lock() allows to take many instances of the same
class, this can easily lead to overflow of MAX_LOCK_DEPTH.
To avoid this overflow, we'll stop accounting instances but
start reference counting the class in the held_lock structure.
[ We could maintain a list of instances, if we'd move the hlock
stuff into __lock_acquired(), but that would require
significant modifications to the current code. ]
We restrict this mode to spin_lock_nest_lock() only, because it
degrades the lockdep quality due to lost of instance.
For lockstat this means we don't track lock statistics for any
but the first lock in the series.
Currently nesting is limited to 11 bits because that was the
spare space available in held_lock. This yields a 2048
instances maximium.
Cc: Marcelo Tosatti <mtosatti@redhat.com>
Add a lockdep helper to validate that we indeed are the owner
of a lock.
fixes a few comments and whitespaces that annoyed me.
Truncate stupid -1 entries in backtraces.
LKML-Reference: <1248096665.15751.8816.camel@twins>
Some cleanups of the lockdep code after the BFS series:
- Remove the last traces of the generation id
- Fixup comment style
- Move the bfs routines into lockdep.c
- Cleanup the bfs routines
[ tom.leiming@gmail.com: Fix crash ]
LKML-Reference: <1246201486-7308-11-git-send-email-tom.leiming@gmail.com>
Add BFS statistics to the existing lockdep stats.
LKML-Reference: <1246201486-7308-10-git-send-email-tom.leiming@gmail.com>
Also account the BFS memory usage.
[ fix build for !PROVE_LOCKING ]
LKML-Reference: <1246201486-7308-9-git-send-email-tom.leiming@gmail.com>
Implement lockdep_count_{for,back}ward using BFS.
LKML-Reference: <1246201486-7308-8-git-send-email-tom.leiming@gmail.com>
Since the shortest lock dependencies' path may be obtained by BFS,
we print the shortest one by print_shortest_lock_dependencies().
LKML-Reference: <1246201486-7308-7-git-send-email-tom.leiming@gmail.com>
This patch uses BFS to implement find_usage_*wards(),which
was originally writen by DFS.
LKML-Reference: <1246201486-7308-6-git-send-email-tom.leiming@gmail.com>
This patch uses BFS to implement check_noncircular() and
prints the generated shortest circle if exists.
LKML-Reference: <1246201486-7308-5-git-send-email-tom.leiming@gmail.com>
1,introduce match() to BFS in order to make it usable to
match different pattern;
2,also rename some functions to make them more suitable.
LKML-Reference: <1246201486-7308-4-git-send-email-tom.leiming@gmail.com>
1,replace %MAX_CIRCULAR_QUE_SIZE with &(MAX_CIRCULAR_QUE_SIZE-1)
since we define MAX_CIRCULAR_QUE_SIZE as power of 2;
2,use bitmap to mark if a lock is accessed in BFS in order to
clear it quickly, because we may search a graph many times.
LKML-Reference: <1246201486-7308-3-git-send-email-tom.leiming@gmail.com>
Currently lockdep will print the 1st circle detected if it
exists when acquiring a new (next) lock.
This patch prints the shortest path from the next lock to be
acquired to the previous held lock if a circle is found.
The patch still uses the current method to check circle, and
once the circle is found, breadth-first search algorithem is
used to compute the shortest path from the next lock to the
previous lock in the forward lock dependency graph.
Printing the shortest path will shorten the dependency chain,
and make troubleshooting for possible circular locking easier.
LKML-Reference: <1246201486-7308-2-git-send-email-tom.leiming@gmail.com>
Merge reason: tracing/core was on a .30-rc1 base and was missing out on
on a handful of tracing fixes present in .30-rc5-almost.
Steven Rostedt reported:
> OK, I think I figured this bug out. This is a lockdep issue with respect
> to tracepoints.
> The trace points in lockdep are called all the time. Outside the lockdep
> logic. But if lockdep were to trigger an error / warning (which this run
> did) we might be in trouble. For new locks, like the dentry->d_lock, that
> are created, they will not get a name:
> void lockdep_init_map(struct lockdep_map *lock, const char *name,
> struct lock_class_key *key, int subclass)
> if (unlikely(!debug_locks))
> return;
> When a problem is found by lockdep, debug_locks becomes false. Thus we
> stop allocating names for locks. This dentry->d_lock I had, now has no
> name. Worse yet, I have CONFIG_DEBUG_VM set, that scrambles non
> initialized memory. Thus, when the trace point was hit, it had junk for
> the lock->name, and the machine crashed.
Ah, nice catch. I think we should put at least the name in regardless.
Ensure we at least initialize the trivial entries of the depmap so that
they can be relied upon, even when lockdep itself decided to pack up and
go home.
[ Impact: fix lock tracing after lockdep warnings. ]
Reported-by: Steven Rostedt <rostedt@goodmis.org>
Acked-by: Steven Rostedt <rostedt@goodmis.org>
LKML-Reference: <1239954049.23397.4156.camel@laptop>
Impact: clean up
Create a sub directory in include/trace called events to keep the
trace point headers in their own separate directory. Only headers that
declare trace points should be defined in this directory.
Cc: Neil Horman <nhorman@tuxdriver.com>
Cc: Zhao Lei <zhaolei@cn.fujitsu.com>
Cc: Eduard - Gabriel Munteanu <eduard.munteanu@linux360.ro>
Cc: Pekka Enberg <penberg@cs.helsinki.fi>
This patch lowers the number of places a developer must modify to add
new tracepoints. The current method to add a new tracepoint
into an existing system is to write the trace point macro in the
trace header with one of the macros TRACE_EVENT, TRACE_FORMAT or
DECLARE_TRACE, then they must add the same named item into the C file
with the macro DEFINE_TRACE(name) and then add the trace point.
This change cuts out the needing to add the DEFINE_TRACE(name).
Every file that uses the tracepoint must still include the trace/<type>.h
file, but the one C file must also add a define before the including
of that file.
#define CREATE_TRACE_POINTS
#include <trace/mytrace.h>
This will cause the trace/mytrace.h file to also produce the C code
necessary to implement the trace point.
Note, if more than one trace/<type>.h is used to create the C code
it is best to list them all together.
#include <trace/foo.h>
#include <trace/bar.h>
#include <trace/fido.h>
Thanks to Mathieu Desnoyers and Christoph Hellwig for coming up with
the cleaner solution of the define above the includes over my first
design to have the C code include a "special" header.
This patch converts sched, irq and lockdep and skb to use this new
method.
While trying to optimize the new lock on reiserfs to replace
the bkl, I find the lock tracing very useful though it lacks
something important for performance (and latency) instrumentation:
the time a task waits for a lock.
That's what this patch implements:
bash-4816 [000] 202.652815: lock_contended: lock_contended: &sb->s_type->i_mutex_key
bash-4816 [000] 202.652819: lock_acquired: &rq->lock (0.000 us)
<...>-4787 [000] 202.652825: lock_acquired: &rq->lock (0.000 us)
<...>-4787 [000] 202.652829: lock_acquired: &rq->lock (0.000 us)
bash-4816 [000] 202.652833: lock_acquired: &sb->s_type->i_mutex_key (16.005 us)
As shown above, the "lock acquired" field is followed by the time
it has been waiting for the lock. Usually, a lock contended entry
is followed by a near lock_acquired entry with a non-zero time waited.
Acked-by: Peter Zijlstra <peterz@infradead.org>
LKML-Reference: <1238975373-15739-1-git-send-email-fweisbec@gmail.com>
* 'locking-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
lockdep: add stack dumps to asserts
hrtimer: fix rq->lock inversion (again)
include/linux/slub_def.h
lib/Kconfig.debug
mm/slob.c
mm/slub.c
Have a better idea about exactly which loc causes a lockdep
limit overflow. Often it's a bug or inefficiency in that
subsystem.
LKML-Reference: <1237376327.5069.253.camel@laptop>
lib/Kconfig.debug
Heiko reported that we grab the graph lock with irqs enabled.
Fix this by providng the same wrapper as all other lockdep entry
functions have.
Reported-by: Heiko Carstens <heiko.carstens@de.ibm.com>
Cc: Nick Piggin <npiggin@suse.de>
LKML-Reference: <1237544000.24626.52.camel@twins>
Impact: cleanup
The atomic debug modifiers are already defined in
kernel/lockdep_internals.h.
Signed-off-by: David Rientjes <rientjes@google.com>
LKML-Reference: <alpine.DEB.2.00.0903050222160.30401@chino.kir.corp.google.com>
Augment the traces with lock names when lockdep is available:
1) | down_read_trylock() {
1) | _spin_lock_irqsave() {
1) | /* lock_acquire: &sem->wait_lock */
1) 4.201 us | }
1) | _spin_unlock_irqrestore() {
1) | /* lock_release: &sem->wait_lock */
1) 3.523 us | }
1) | /* lock_acquire: try read &mm->mmap_sem */
1) + 13.386 us | }
1) 1.635 us | find_vma();
1) | handle_mm_fault() {
1) | __do_fault() {
1) | filemap_fault() {
1) | find_lock_page() {
1) | find_get_page() {
1) | /* lock_acquire: read rcu_read_lock */
1) | /* lock_release: rcu_read_lock */
1) 5.697 us | }
1) 8.158 us | }
1) + 11.079 us | }
1) | _spin_lock() {
1) | /* lock_acquire: __pte_lockptr(page) */
1) 3.949 us | }
1) 1.460 us | page_add_file_rmap();
1) | _spin_unlock() {
1) | /* lock_release: __pte_lockptr(page) */
1) 3.115 us | }
1) | unlock_page() {
1) 1.421 us | page_waitqueue();
1) 1.220 us | __wake_up_bit();
1) 6.519 us | }
1) + 34.328 us | }
1) + 37.452 us | }
1) | up_read() {
1) | /* lock_release: &mm->mmap_sem */
1) 3.865 us | }
1) 8.562 us | }
1) + 17.370 us | }
Cc: =?ISO-8859-1?Q?T=F6r=F6k?= Edwin <edwintorok@gmail.com>
Cc: Jason Baron <jbaron@redhat.com>
LKML-Reference: <1236166375.5330.7209.camel@laptop>
Impact: clarify lockdep printk text
print_irq_inversion_bug() gets handed state strings of the form
"HARDIRQ", "SOFTIRQ", "RECLAIM_FS"
and appends "-irq-{un,}safe" to them, which is either redudant for *IRQ or
confusing in the RECLAIM_FS case.
LKML-Reference: <1236175192.5330.7585.camel@laptop>
In the recent mark_lock_irq() rework a bug snuck in that would report the
state of write locks causing irq inversion under a read lock as a read
lock.
Fix this by masking the read bit of the state when validating write
dependencies.
LKML-Reference: <1236172646.5330.7450.camel@laptop>
The __GFP_FS annotations fail to build with CONFIG_LOCKDEP=y,
CONFIG_PROVE_LOCKING=n, ammend that.
Arnd pointed out we have the stringify macro magic already in-kernel.
CC: Arnd Bergmann <arnd@arndb.de>
Remove the manual state iteration thingy.
Generic, states independent, get_user_chars().
there's too much repetition of code..
re-add some of the comments that got lost in the refactoring.
Now that we have nice numerical relations for the states, remove the macro
magics.
Now what its only two functions, they again look rather similar.
These two are also remakably similar
The _READ helpers show remarkable similarity, merge them.
Kill another argument
take away another parameter
In order to unify them, take some arguments away
split mark_lock_irq() into 4 simple helper functions
generate the usage strings
XXX capital invasion :-(
