path: root/kernel/lockdep_proc.c
2012-10-24lockdep: Use KSYM_NAME_LEN'ed buffer for __get_key_name()Cyrill Gorcunov
Not a big deal, but since other __get_key_name() callers use it lets be consistent. Signed-off-by: Cyrill Gorcunov <gorcunov@openvz.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Link: http://lkml.kernel.org/r/20121020190519.GH25467@moon Signed-off-by: Ingo Molnar <mingo@kernel.org>
2011-10-31kernel: Map most files to use export.h instead of module.hPaul Gortmaker
The changed files were only including linux/module.h for the EXPORT_SYMBOL infrastructure, and nothing else. Revector them onto the isolated export header for faster compile times. Nothing to see here but a whole lot of instances of: -#include <linux/module.h> +#include <linux/export.h> This commit is only changing the kernel dir; next targets will probably be mm, fs, the arch dirs, etc. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2011-03-23lockdep: Remove unused 'factor' variable from lockdep_stats_show()Sergey Senozhatsky
Signed-off-by: Sergey Senozhatsky <sergey.senozhatsky@gmail.com> Cc: Peter Zijlstra <peterz@infradead.org> LKML-Reference: <20110323123828.GB4244@swordfish.minsk.epam.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-11-10locking, lockdep: Convert sprintf_symbol to %pSJoe Perches
Signed-off-by: Joe Perches <joe@perches.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Jiri Kosina <trivial@kernel.org> LKML-Reference: <1288998760-11775-6-git-send-email-joe@perches.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-04-06lockstat: Make lockstat counting per cpuFrederic Weisbecker
Locking statistics are implemented using global atomic variables. This is usually fine unless some path write them very often. This is the case for the function and function graph tracers that disable irqs for each entry saved (except if the function tracer is in preempt disabled only mode). And calls to local_irq_save/restore() increment hardirqs_on_events and hardirqs_off_events stats (or similar stats for redundant versions). Incrementing these global vars for each function ends up in too much cache bouncing if lockstats are enabled. To solve this, implement the debug_atomic_*() operations using per cpu vars. -v2: Use per_cpu() instead of get_cpu_var() to fetch the desired cpu vars on debug_atomic_read() -v3: Store the stats in a structure. No need for local_t as we are NMI/irq safe. -v4: Fix tons of build errors. I thought I had tested it but I probably forgot to select the relevant config. Suggested-by: Steven Rostedt <rostedt@goodmis.org> Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Steven Rostedt <rostedt@goodmis.org> LKML-Reference: <1270505417-8144-1-git-send-regression-fweisbec@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Steven Rostedt <rostedt@goodmis.org>
2009-09-23seq_file: constify seq_operationsJames Morris
Make all seq_operations structs const, to help mitigate against revectoring user-triggerable function pointers. This is derived from the grsecurity patch, although generated from scratch because it's simpler than extracting the changes from there. Signed-off-by: James Morris <jmorris@namei.org> Acked-by: Serge Hallyn <serue@us.ibm.com> Acked-by: Casey Schaufler <casey@schaufler-ca.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-08-31Merge commit 'v2.6.31-rc8' into core/lockingIngo Molnar
Merge reason: we were on -rc4, move to -rc8 before applying a new batch of locking infrastructure changes. Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-08-29lockdep: Remove recursion stattisticsMing Lei
Since lockdep has introduced BFS to avoid recursion, statistics for recursion does not make any sense now. So remove them. Signed-off-by: Ming Lei <tom.leiming@gmail.com> Cc: a.p.zijlstra@chello.nl LKML-Reference: <1251542879-5211-1-git-send-email-tom.leiming@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-08-17lockdep: Simplify lock_stat seqfile codeLi Zefan
- make ls_next() call ls_start() - remove redundant code in lock_stat_release() Signed-off-by: Li Zefan <lizf@cn.fujitsu.com> Cc: Peter Zijlstra <peterz@infradead.org> LKML-Reference: <4A88ED6B.6030602@cn.fujitsu.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-08-17lockdep: Simplify lockdep_chains seqfile codeLi Zefan
- make lc_next() call lc_start() - use lock_chains directly instead of storing it in m->private Signed-off-by: Li Zefan <lizf@cn.fujitsu.com> Cc: Peter Zijlstra <peterz@infradead.org> LKML-Reference: <4A88ED57.5060609@cn.fujitsu.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-08-17lockdep: Simplify lockdep seqfile codeLi Zefan
Use seq_list_start_head() and seq_list_next(). Signed-off-by: Li Zefan <lizf@cn.fujitsu.com> Cc: Peter Zijlstra <peterz@infradead.org> LKML-Reference: <4A88ED41.5000000@cn.fujitsu.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-08-17lockdep: Fix missing entries in /proc/lock_chainsLi Zefan
Two entries are missing in the output of /proc/lock_chains. One is chains[1]. When lc_next() is called the 1st time, chains[0] is returned. And when it's called the 2nd time, chains[2] is returned. The other missing ons is, when lc_start() is called the 2nd time, we should start from chains[@pos-1] but not chains[@pos], because pos == 0 is the header. Signed-off-by: Li Zefan <lizf@cn.fujitsu.com> Cc: Peter Zijlstra <peterz@infradead.org> LKML-Reference: <4A88ED25.2040306@cn.fujitsu.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-08-17lockdep: Fix missing entry in /proc/lock_statLi Zefan
One entry is missing in the output of /proc/lock_stat. The cause is, when ls_start() is called the 2nd time, we should start from stats[@pos-1] but not stats[@pos], because pos == 0 is the header. Signed-off-by: Li Zefan <lizf@cn.fujitsu.com> Cc: Peter Zijlstra <peterz@infradead.org> LKML-Reference: <4A88ED15.20800@cn.fujitsu.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-08-07lockdep: Fix file mode of lock_statLi Zefan
/proc/lock_stat is writable. Signed-off-by: Li Zefan <lizf@cn.fujitsu.com> Cc: Peter Zijlstra <peterz@infradead.org> LKML-Reference: <4A7BE7B6.10904@cn.fujitsu.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-08-02lockdep: Fix BFS buildIngo Molnar
Fix: kernel/built-in.o: In function `lockdep_stats_show': lockdep_proc.c:(.text+0x48202): undefined reference to `max_bfs_queue_depth' As max_bfs_queue_depth is only available under CONFIG_PROVE_LOCKING=y. Cc: Ming Lei <tom.leiming@gmail.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> LKML-Reference: <new-submission> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-07-24lockdep: Add statistics info for max bfs queue depthMing Lei
Add BFS statistics to the existing lockdep stats. Signed-off-by: Ming Lei <tom.leiming@gmail.com> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> LKML-Reference: <1246201486-7308-10-git-send-email-tom.leiming@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-02-14lockstat: warn about disabled lock debuggingPeter Zijlstra
Avoid confusion and clearly state lock debugging got disabled. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-02-14lockdep: get_user_chars() redoPeter Zijlstra
Generic, states independent, get_user_chars(). Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-02-14lockdep: sanitize bit namesPeter Zijlstra
s/\(LOCKF\?_ENABLED_[^ ]*\)S\(_READ\)\?\>/\1\2/g So that the USED_IN and ENABLED have the same names. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-02-14lockdep: annotate reclaim context (__GFP_NOFS)Nick Piggin
Here is another version, with the incremental patch rolled up, and added reclaim context annotation to kswapd, and allocation tracing to slab allocators (which may only ever reach the page allocator in rare cases, so it is good to put annotations here too). Haven't tested this version as such, but it should be getting closer to merge worthy ;) -- After noticing some code in mm/filemap.c accidentally perform a __GFP_FS allocation when it should not have been, I thought it might be a good idea to try to catch this kind of thing with lockdep. I coded up a little idea that seems to work. Unfortunately the system has to actually be in __GFP_FS page reclaim, then take the lock, before it will mark it. But at least that might still be some orders of magnitude more common (and more debuggable) than an actual deadlock condition, so we have some improvement I hope (the concept is no less complete than discovery of a lock's interrupt contexts). I guess we could even do the same thing with __GFP_IO (normal reclaim), and even GFP_NOIO locks too... but filesystems will have the most locks and fiddly code paths, so let's start there and see how it goes. It *seems* to work. I did a quick test. ================================= [ INFO: inconsistent lock state ] 2.6.28-rc6-00007-ged31348-dirty #26 --------------------------------- inconsistent {in-reclaim-W} -> {ov-reclaim-W} usage. modprobe/8526 [HC0[0]:SC0[0]:HE1:SE1] takes: (testlock){--..}, at: [<ffffffffa0020055>] brd_init+0x55/0x216 [brd] {in-reclaim-W} state was registered at: [<ffffffff80267bdb>] __lock_acquire+0x75b/0x1a60 [<ffffffff80268f71>] lock_acquire+0x91/0xc0 [<ffffffff8070f0e1>] mutex_lock_nested+0xb1/0x310 [<ffffffffa002002b>] brd_init+0x2b/0x216 [brd] [<ffffffff8020903b>] _stext+0x3b/0x170 [<ffffffff80272ebf>] sys_init_module+0xaf/0x1e0 [<ffffffff8020c3fb>] system_call_fastpath+0x16/0x1b [<ffffffffffffffff>] 0xffffffffffffffff irq event stamp: 3929 hardirqs last enabled at (3929): [<ffffffff8070f2b5>] mutex_lock_nested+0x285/0x310 hardirqs last disabled at (3928): [<ffffffff8070f089>] mutex_lock_nested+0x59/0x310 softirqs last enabled at (3732): [<ffffffff8061f623>] sk_filter+0x83/0xe0 softirqs last disabled at (3730): [<ffffffff8061f5b6>] sk_filter+0x16/0xe0 other info that might help us debug this: 1 lock held by modprobe/8526: #0: (testlock){--..}, at: [<ffffffffa0020055>] brd_init+0x55/0x216 [brd] stack backtrace: Pid: 8526, comm: modprobe Not tainted 2.6.28-rc6-00007-ged31348-dirty #26 Call Trace: [<ffffffff80265483>] print_usage_bug+0x193/0x1d0 [<ffffffff80266530>] mark_lock+0xaf0/0xca0 [<ffffffff80266735>] mark_held_locks+0x55/0xc0 [<ffffffffa0020000>] ? brd_init+0x0/0x216 [brd] [<ffffffff802667ca>] trace_reclaim_fs+0x2a/0x60 [<ffffffff80285005>] __alloc_pages_internal+0x475/0x580 [<ffffffff8070f29e>] ? mutex_lock_nested+0x26e/0x310 [<ffffffffa0020000>] ? brd_init+0x0/0x216 [brd] [<ffffffffa002006a>] brd_init+0x6a/0x216 [brd] [<ffffffffa0020000>] ? brd_init+0x0/0x216 [brd] [<ffffffff8020903b>] _stext+0x3b/0x170 [<ffffffff8070f8b9>] ? mutex_unlock+0x9/0x10 [<ffffffff8070f83d>] ? __mutex_unlock_slowpath+0x10d/0x180 [<ffffffff802669ec>] ? trace_hardirqs_on_caller+0x12c/0x190 [<ffffffff80272ebf>] sys_init_module+0xaf/0x1e0 [<ffffffff8020c3fb>] system_call_fastpath+0x16/0x1b Signed-off-by: Nick Piggin <npiggin@suse.de> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-10-20lockstat: contend with pointsPeter Zijlstra
We currently only provide points that have to wait on contention, also lists the points we have to wait for. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-09-23lockstat: fixup signed divisionPeter Zijlstra
Some recent modification to this code made me notice the little todo mark. Now that we have more elaborate 64-bit division functions this isn't hard. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-08-26lockstat: fix numerical output rounding errorJoe Korty
Fix rounding error in /proc/lock_stat numerical output. On occasion the two digit fractional part contains the three digit value '100'. This is due to a bug in the rounding algorithm which pushes values in the range '95..99' to '100' rather than to '00' + an increment to the integer part. For example, - 123456.100 old display + 123457.00 new display Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-08-15lockdep: fix build if CONFIG_PROVE_LOCKING not definedStephen Hemminger
If CONFIG_PROVE_LOCKING not defined, then no dependency information is available. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-08-11lockdep: handle chains involving classes defined in modulesRabin Vincent
Solve this by marking the classes as unused and not printing information about the unused classes. Reported-by: Eric Sesterhenn <snakebyte@gmx.de> Signed-off-by: Rabin Vincent <rabin@rab.in> Acked-by: Huang Ying <ying.huang@intel.com> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-07-31lockdep: fix combinatorial explosion in lock subgraph traversalDavid Miller
When we traverse the graph, either forwards or backwards, we are interested in whether a certain property exists somewhere in a node reachable in the graph. Therefore it is never necessary to traverse through a node more than once to get a correct answer to the given query. Take advantage of this property using a global ID counter so that we need not clear all the markers in all the lock_class entries before doing a traversal. A new ID is choosen when we start to traverse, and we continue through a lock_class only if it's ID hasn't been marked with the new value yet. This short-circuiting is essential especially for high CPU count systems. The scheduler has a runqueue per cpu, and needs to take two runqueue locks at a time, which leads to long chains of backwards and forwards subgraphs from these runqueue lock nodes. Without the short-circuit implemented here, a graph traversal on a runqueue lock can take up to (1 << (N - 1)) checks on a system with N cpus. For anything more than 16 cpus or so, lockdep will eventually bring the machine to a complete standstill. Signed-off-by: David S. Miller <davem@davemloft.net> Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-06-24lockdep: add lock_class information to lock_chain and output itHuang, Ying
It is based on x86/master branch of git-x86 tree, and has been tested on x86_64 platform. ChangeLog: v2: - Enclosing proc file system related code into CONFIG_PROVE_LOCKING. - Fix nr_chain_hlocks update code. Signed-off-by: Huang Ying <ying.huang@intel.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-06-20lockdep: add lock_class information to lock_chain and output itHuang, Ying
This patch records array of lock_class into lock_chain, and export lock_chain information via /proc/lockdep_chains. It is based on x86/master branch of git-x86 tree, and has been tested on x86_64 platform. Signed-off-by: Huang Ying <ying.huang@intel.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-06-13lockdep: output lock_class key instead of address for forward dependency outputHuang, Ying
The key instead of address of lock_class should be output in /proc/lockdep when forward dependency is output, because key is output for lock_class itself as identifier too. This patch is based on x86/auto-latest branch of git-x86 tree, and has been tested on x86_64 platform. Signed-off-by: Huang Ying <ying.huang@intel.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-04-29kernel: use non-racy method for proc entries creationDenis V. Lunev
Use proc_create()/proc_create_data() to make sure that ->proc_fops and ->data be setup before gluing PDE to main tree. Signed-off-by: Denis V. Lunev <den@openvz.org> Cc: Alexey Dobriyan <adobriyan@gmail.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-11lockdep: Avoid /proc/lockdep & lock_stat infinite outputTim Pepper
Both /proc/lockdep and /proc/lock_stat output may loop infinitely. When a read() requests an amount of data smaller than the amount of data that the seq_file's foo_show() outputs, the output starts looping and outputs the "stuck" element's data infinitely. There may be multiple sequential calls to foo_start(), foo_next()/foo_show(), and foo_stop() for a single open with sequential read of the file. The _start() does not have to start with the 0th element and _show() might be called multiple times in a row for the same element for a given open/read of the seq_file. Also header output should not be happening in _start(). All output should be in _show(), which SEQ_START_TOKEN is meant to help. Having output in _start() may also negatively impact seq_file's seq_read() and traverse() accounting. Signed-off-by: Tim Pepper <lnxninja@linux.vnet.ibm.com> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Ingo Molnar <mingo@elte.hu> Cc: Ingo Molnar <mingo@elte.hu> Cc: Al Viro <viro@ftp.linux.org.uk>
2007-07-31Fix leak on /proc/lockdep_statsAlexey Dobriyan
Signed-off-by: Alexey Dobriyan <adobriyan@sw.ru> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-19lockstat: better class name representationPeter Zijlstra
optionally add class->name_version and class->subclass to the class name Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-19lockstat: measure lock bouncingPeter Zijlstra
__acquire | lock _____ | \ | __contended | | | wait | _______/ |/ | __acquired | __release | unlock We measure acquisition and contention bouncing. This is done by recording a cpu stamp in each lock instance. Contention bouncing requires the cpu stamp to be set on acquisition. Hence we move __acquired into the generic path. __acquired is then used to measure acquisition bouncing by comparing the current cpu with the old stamp before replacing it. __contended is used to measure contention bouncing (only useful for preemptable locks) [akpm@linux-foundation.org: cleanups] Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Acked-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-19lockdep: various fixesPeter Zijlstra
- update the copyright notices - use the default hash function - fix a thinko in a BUILD_BUG_ON - add a WARN_ON to spot inconsitent naming - fix a termination issue in /proc/lock_stat [akpm@linux-foundation.org: cleanups] Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Acked-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-19lockstat: human readability tweaksPeter Zijlstra
Present all this fancy new lock statistics information: *warning, _wide_ output ahead* (output edited for purpose of brevity) # cat /proc/lock_stat lock_stat version 0.1 ----------------------------------------------------------------------------------------------------------------------------------------------------------------- class name contentions waittime-min waittime-max waittime-total acquisitions holdtime-min holdtime-max holdtime-total ----------------------------------------------------------------------------------------------------------------------------------------------------------------- &inode->i_mutex: 14458 6.57 398832.75 2469412.23 6768876 0.34 11398383.65 339410830.89 --------------- &inode->i_mutex 4486 [<ffffffff802a08f9>] pipe_wait+0x86/0x8d &inode->i_mutex 0 [<ffffffff802a01e8>] pipe_write_fasync+0x29/0x5d &inode->i_mutex 0 [<ffffffff802a0e18>] pipe_read+0x74/0x3a5 &inode->i_mutex 0 [<ffffffff802a1a6a>] do_lookup+0x81/0x1ae ................................................................................................................................................................. &inode->i_data.tree_lock-W: 491 0.27 62.47 493.89 2477833 0.39 468.89 1146584.25 &inode->i_data.tree_lock-R: 65 0.44 4.27 48.78 26288792 0.36 184.62 10197458.24 -------------------------- &inode->i_data.tree_lock 46 [<ffffffff80277095>] __do_page_cache_readahead+0x69/0x24f &inode->i_data.tree_lock 31 [<ffffffff8026f9fb>] add_to_page_cache+0x31/0xba &inode->i_data.tree_lock 0 [<ffffffff802770ee>] __do_page_cache_readahead+0xc2/0x24f &inode->i_data.tree_lock 0 [<ffffffff8026f6e4>] find_get_page+0x1a/0x58 ................................................................................................................................................................. proc_inum_idr.lock: 0 0.00 0.00 0.00 36 0.00 65.60 148.26 proc_subdir_lock: 0 0.00 0.00 0.00 3049859 0.00 106.81 1563212.42 shrinker_rwsem-W: 0 0.00 0.00 0.00 5 0.00 1.73 3.68 shrinker_rwsem-R: 0 0.00 0.00 0.00 633 2.57 246.57 10909.76 'contentions' and 'acquisitions' are the number of such events measured (since the last reset). The waittime- and holdtime- (min, max, total) numbers are presented in microseconds. If there are any contention points, the lock class is presented in the block format (as i_mutex and tree_lock above), otherwise a single line of output is presented. The output is sorted on absolute number of contentions (read + write), this should get the worst offenders presented first, so that: # grep : /proc/lock_stat | head will quickly show who's bad. The stats can be reset using: # echo 0 > /proc/lock_stat [bunk@stusta.de: make 2 functions static] [akpm@linux-foundation.org: fix printk warning] Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Acked-by: Ingo Molnar <mingo@elte.hu> Acked-by: Jason Baron <jbaron@redhat.com> Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-19lockdep: reduce the ifdefferyPeter Zijlstra
Move code around to get fewer but larger #ifdef sections. Break some in-function #ifdefs out into their own functions. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Acked-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-11[PATCH] Fix apparent typo CONFIG_LOCKDEP_DEBUGRobert P. J. Day
Replace the apparent typo CONFIG_LOCKDEP_DEBUG with the correct CONFIG_DEBUG_LOCKDEP. Signed-off-by: Robert P. J. Day <rpjday@mindspring.com> Cc: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-11[PATCH] lockdep: add graph depth information to /proc/lockdepJason Baron
Generate locking graph information into /proc/lockdep, for lock hierarchy documentation and visualization purposes. sample output: c089fd5c OPS: 138 FD: 14 BD: 1 --..: &tty->termios_mutex -> [c07a3430] tty_ldisc_lock -> [c07a37f0] &port_lock_key -> [c07afdc0] &rq->rq_lock_key#2 The lock classes listed are all the first-hop lock dependencies that lockdep has seen so far. Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-12-07[PATCH] struct seq_operations and struct file_operations constificationHelge Deller
- move some file_operations structs into the .rodata section - move static strings from policy_types[] array into the .rodata section - fix generic seq_operations usages, so that those structs may be defined as "const" as well [akpm@osdl.org: couple of fixes] Signed-off-by: Helge Deller <deller@gmx.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-03[PATCH] lockdep: procfsIngo Molnar
Lock validator /proc/lockdep and /proc/lockdep_stats support. (FIXME: should go into debugfs) Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
