commit 27e35715df54cbc4f2d044f681802ae30479e7fb upstream.
When the rtmutex fast path is enabled the slow unlock function can
create the following situation:
spin_lock(foo->m->wait_lock);
foo->m->owner = NULL;
rt_mutex_lock(foo->m); <-- fast path
free = atomic_dec_and_test(foo->refcnt);
rt_mutex_unlock(foo->m); <-- fast path
if (free)
kfree(foo);
spin_unlock(foo->m->wait_lock); <--- Use after free.
Plug the race by changing the slow unlock to the following scheme:
while (!rt_mutex_has_waiters(m)) {
/* Clear the waiters bit in m->owner */
clear_rt_mutex_waiters(m);
owner = rt_mutex_owner(m);
spin_unlock(m->wait_lock);
if (cmpxchg(m->owner, owner, 0) == owner)
return;
spin_lock(m->wait_lock);
So in case of a new waiter incoming while the owner tries the slow
path unlock we have two situations:
unlock(wait_lock);
lock(wait_lock);
cmpxchg(p, owner, 0) == owner
mark_rt_mutex_waiters(lock);
acquire(lock);
Or:
unlock(wait_lock);
lock(wait_lock);
cmpxchg(p, owner, 0) != owner
enqueue_waiter();
unlock(wait_lock);
lock(wait_lock);
wakeup_next waiter();
unlock(wait_lock);
lock(wait_lock);
acquire(lock);
If the fast path is disabled, then the simple
m->owner = NULL;
is sufficient as all access to m->owner is serialized via
m->wait_lock;
Also document and clarify the wakeup_next_waiter function as suggested
by Oleg Nesterov.
Reported-by: Steven Rostedt <rostedt@goodmis.org>
Reviewed-by: Steven Rostedt <rostedt@goodmis.org>
Link: http://lkml.kernel.org/r/20140611183852.937945560@linutronix.de
commit 3d5c9340d1949733eb37616abd15db36aef9a57c upstream.
Even in the case when deadlock detection is not requested by the
caller, we can detect deadlocks. Right now the code stops the lock
chain walk and keeps the waiter enqueued, even on itself. Silly not to
yell when such a scenario is detected and to keep the waiter enqueued.
Return -EDEADLK unconditionally and handle it at the call sites.
The futex calls return -EDEADLK. The non futex ones dequeue the
waiter, throw a warning and put the task into a schedule loop.
Tagged for stable as it makes the code more robust.
Cc: Brad Mouring <bmouring@ni.com>
Link: http://lkml.kernel.org/r/20140605152801.836501969@linutronix.de
commit 82084984383babe728e6e3c9a8e5c46278091315 upstream.
When we walk the lock chain, we drop all locks after each step. So the
lock chain can change under us before we reacquire the locks. That's
harmless in principle as we just follow the wrong lock path. But it
can lead to a false positive in the dead lock detection logic:
T0 holds L0
T0 blocks on L1 held by T1
T1 blocks on L2 held by T2
T2 blocks on L3 held by T3
T4 blocks on L4 held by T4
Now we walk the chain
lock T1 -> lock L2 -> adjust L2 -> unlock T1 ->
lock T2 -> adjust T2 -> drop locks
T2 times out and blocks on L0
Now we continue:
lock T2 -> lock L0 -> deadlock detected, but it's not a deadlock at all.
Brad tried to work around that in the deadlock detection logic itself,
but the more I looked at it the less I liked it, because it's crystal
ball magic after the fact.
We actually can detect a chain change very simple:
lock T1 -> lock L2 -> adjust L2 -> unlock T1 -> lock T2 -> adjust T2 ->
next_lock = T2->pi_blocked_on->lock;
drop locks
Now we continue:
lock T2 ->
if (next_lock != T2->pi_blocked_on->lock)
return;
So if we detect that T2 is now blocked on a different lock we stop the
chain walk. That's also correct in the following scenario:
drop locks
T3 times out and drops L3
T2 acquires L3 and blocks on L4 now
Now we continue:
lock T2 ->
return;
We don't have to follow up the chain at that point, because T2
propagated our priority up to T4 already.
[ Folded a cleanup patch from peterz ]
Reported-by: Brad Mouring <bmouring@ni.com>
Link: http://lkml.kernel.org/r/20140605152801.930031935@linutronix.de
commit 397335f004f41e5fcf7a795e94eb3ab83411a17c upstream.
The current deadlock detection logic does not work reliably due to the
following early exit path:
* Drop out, when the task has no waiters. Note,
* top_waiter can be NULL, when we are in the deboosting
* mode!
if (top_waiter && (!task_has_pi_waiters(task) ||
top_waiter != task_top_pi_waiter(task)))
goto out_unlock_pi;
So this not only exits when the task has no waiters, it also exits
unconditionally when the current waiter is not the top priority waiter
of the task.
So in a nested locking scenario, it might abort the lock chain walk
and therefor miss a potential deadlock.
Simple fix: Continue the chain walk, when deadlock detection is
enabled.
We also avoid the whole enqueue, if we detect the deadlock right away
(A-A). It's an optimization, but also prevents that another waiter who
comes in after the detection and before the task has undone the damage
observes the situation and detects the deadlock and returns
-EDEADLOCK, which is wrong as the other task is not in a deadlock
situation.
Cc: Lai Jiangshan <laijs@cn.fujitsu.com>
Link: http://lkml.kernel.org/r/20140522031949.725272460@linutronix.de
Pull scheduler changes from Ingo Molnar:
- Add the initial implementation of SCHED_DEADLINE support: a real-time
scheduling policy where tasks that meet their deadlines and
periodically execute their instances in less than their runtime quota
see real-time scheduling and won't miss any of their deadlines.
Tasks that go over their quota get delayed (Available to privileged
users for now)
- Clean up and fix preempt_enable_no_resched() abuse all around the
tree
- Do sched_clock() performance optimizations on x86 and elsewhere
- Fix and improve auto-NUMA balancing
- Fix and clean up the idle loop
- Apply various cleanups and fixes
* 'sched-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (60 commits)
sched: Fix __sched_setscheduler() nice test
sched: Move SCHED_RESET_ON_FORK into attr::sched_flags
sched: Fix up attr::sched_priority warning
sched: Fix up scheduler syscall LTP fails
sched: Preserve the nice level over sched_setscheduler() and sched_setparam() calls
sched/core: Fix htmldocs warnings
sched/deadline: No need to check p if dl_se is valid
sched/deadline: Remove unused variables
sched/deadline: Fix sparse static warnings
m68k: Fix build warning in mac_via.h
sched, thermal: Clean up preempt_enable_no_resched() abuse
sched, net: Fixup busy_loop_us_clock()
sched, net: Clean up preempt_enable_no_resched() abuse
sched/preempt: Fix up missed PREEMPT_NEED_RESCHED folding
sched/preempt, locking: Rework local_bh_{dis,en}able()
sched/clock, x86: Avoid a runtime condition in native_sched_clock()
sched/clock: Fix up clear_sched_clock_stable()
sched/clock, x86: Use a static_key for sched_clock_stable
sched/clock: Remove local_irq_disable() from the clocks
sched/clock, x86: Rewrite cyc2ns() to avoid the need to disable IRQs
Some method to deal with rt-mutexes and make sched_dl interact with
the current PI-coded is needed, raising all but trivial issues, that
needs (according to us) to be solved with some restructuring of
the pi-code (i.e., going toward a proxy execution-ish implementation).
This is under development, in the meanwhile, as a temporary solution,
what this commits does is:
- ensure a pi-lock owner with waiters is never throttled down. Instead,
when it runs out of runtime, it immediately gets replenished and it's
deadline is postponed;
- the scheduling parameters (relative deadline and default runtime)
used for that replenishments --during the whole period it holds the
pi-lock-- are the ones of the waiting task with earliest deadline.
Acting this way, we provide some kind of boosting to the lock-owner,
still by using the existing (actually, slightly modified by the previous
commit) pi-architecture.
We would stress the fact that this is only a surely needed, all but
clean solution to the problem. In the end it's only a way to re-start
discussion within the community. So, as always, comments, ideas, rants,
etc.. are welcome! :-)
Signed-off-by: Dario Faggioli <raistlin@linux.it>
Signed-off-by: Juri Lelli <juri.lelli@gmail.com>
[ Added !RT_MUTEXES build fix. ]
Signed-off-by: Peter Zijlstra <peterz@infradead.org>
Link: http://lkml.kernel.org/r/1383831828-15501-11-git-send-email-juri.lelli@gmail.com
Turn the pi-chains from plist to rb-tree, in the rt_mutex code,
and provide a proper comparison function for -deadline and
-priority tasks.
This is done mainly because:
- classical prio field of the plist is just an int, which might
not be enough for representing a deadline;
- manipulating such a list would become O(nr_deadline_tasks),
which might be to much, as the number of -deadline task increases.
Therefore, an rb-tree is used, and tasks are queued in it according
to the following logic:
- among two -priority (i.e., SCHED_BATCH/OTHER/RR/FIFO) tasks, the
one with the higher (lower, actually!) prio wins;
- among a -priority and a -deadline task, the latter always wins;
- among two -deadline tasks, the one with the earliest deadline
wins.
Queueing and dequeueing functions are changed accordingly, for both
the list of a task's pi-waiters and the list of tasks blocked on
a pi-lock.
Signed-off-again-by: Peter Zijlstra <peterz@infradead.org>
Link: http://lkml.kernel.org/r/1383831828-15501-10-git-send-email-juri.lelli@gmail.com
When mutex debugging is enabled and an imbalanced mutex_unlock()
is called, we get the following, slightly confusing warning:
[ 364.208284] DEBUG_LOCKS_WARN_ON(lock->owner != current)
But in that case the warning is due to an imbalanced mutex_unlock() call,
and the lock->owner is NULL - so the message is misleading.
So improve the message by testing for this case specifically:
DEBUG_LOCKS_WARN_ON(!lock->owner)
Signed-off-by: Liu, Chuansheng <chuansheng.liu@intel.com>
Cc: Paul E. McKenney <paulmck@linux.vnet.ibm.com>
Link: http://lkml.kernel.org/r/1386136693.3650.48.camel@cliu38-desktop-build
[ Improved the changelog, changed the patch to use !lock->owner consistently. ]
Lockdep is an awesome piece of code which detects locking issues
which are relevant both to userspace and kernelspace. We can
easily make lockdep work in userspace since there is really no
kernel spacific magic going on in the code.
All we need is to wrap two functions which are used by lockdep
and are very kernel specific.
Doing that will allow tools located in tools/ to easily utilize
lockdep's code for their own use.
Cc: penberg@kernel.org
Cc: torvalds@linux-foundation.org
Link: http://lkml.kernel.org/r/1352753446-24109-1-git-send-email-sasha.levin@oracle.com
There are new Sparse warnings:
>> kernel/locking/lockdep.c:1235:15: sparse: symbol '__lockdep_count_forward_deps' was not declared. Should it be static?
>> kernel/locking/lockdep.c:1261:15: sparse: symbol '__lockdep_count_backward_deps' was not declared. Should it be static?
Please consider folding the attached diff :-)
Signed-off-by: Fengguang Wu <fengguang.wu@intel.com>
Link: http://lkml.kernel.org/r/527d1787.ThzXGoUspZWehFDl\%fengguang.wu@intel.com
> kernel/locking/lockdep_proc.c: In function 'seq_lock_time':
> >> kernel/locking/lockdep_proc.c:424:23: warning: comparison of distinct pointer types lacks a cast [enabled by default]
> 418 static void seq_lock_time(struct seq_file *m, struct lock_time *lt)
> 419 {
> 420 seq_printf(m, "%14lu", lt->nr);
> 421 seq_time(m, lt->min);
> 422 seq_time(m, lt->max);
> 423 seq_time(m, lt->total);
> > 424 seq_time(m, lt->nr ? do_div(lt->total, lt->nr) : 0);
> 425 }
My compiler refuses to actually say that; but it looks wrong in that
do_div() returns the remainder, not the divisor.
Reported-by: Fengguang Wu <fengguang.wu@intel.com>
Tested-by: Fengguang Wu <fengguang.wu@intel.com>
Cc: Davidlohr Bueso <davidlohr@hp.com>
Link: http://lkml.kernel.org/r/20131106164230.GE16117@laptop.programming.kicks-ass.net
Fix this docbook error:
>> docproc: kernel/mutex.c: No such file or directory
by updating the stale references to kernel/mutex.c.
Reported-by: fengguang.wu@intel.com
Link: http://lkml.kernel.org/n/tip-34pikw1tlsskj65rrt5iusrq@git.kernel.org
Suggested-by: Ingo Molnar <mingo@kernel.org>
Link: http://lkml.kernel.org/n/tip-52bjmtty46we26hbfd9sc9iy@git.kernel.org
Link: http://lkml.kernel.org/n/tip-amd6pg1mif6tikbyktfvby3y@git.kernel.org
Notably: changed lib/rwsem* targets from lib- to obj-, no idea about
the ramifications of that.
Link: http://lkml.kernel.org/n/tip-g0kynfh5feriwc6p3h6kpbw6@git.kernel.org
Link: http://lkml.kernel.org/n/tip-p9ijt8div0hwldexwfm4nlhj@git.kernel.org
[ Fixed build failure in kernel/rcu/tree_plugin.h. ]
Link: http://lkml.kernel.org/n/tip-vmw5sf6vzmua1z6nx1cg69h2@git.kernel.org
Link: http://lkml.kernel.org/n/tip-b81ol0z3mon45m51o131yc9j@git.kernel.org
Link: http://lkml.kernel.org/n/tip-wl7s3tta5isufzfguc23et06@git.kernel.org
Link: http://lkml.kernel.org/n/tip-1ditvncg30dgbpvrz2bxfmke@git.kernel.org
