commit 06489cfbd915ff36c8e36df27f1c2dc60f97ca56 upstream.
Given the fact that devm_memremap_pages() requires a percpu_ref that is
torn down by devm_memremap_pages_release() the current support for mapping
RAM is broken.
Support for remapping "System RAM" has been broken since the beginning and
there is no existing user of this this code path, so just kill the support
and make it an explicit error.
This cleanup also simplifies a follow-on patch to fix the error path when
setting a devm release action for devm_memremap_pages_release() fails.
Link: http://lkml.kernel.org/r/154275557997.76910.14689813630968180480.stgit@dwillia2-desk3.amr.corp.intel.com
Reviewed-by: "Jérôme Glisse" <jglisse@redhat.com>
Reviewed-by: Logan Gunthorpe <logang@deltatee.com>
Cc: Balbir Singh <bsingharora@gmail.com>
Cc: Michal Hocko <mhocko@suse.com>
Cc: <stable@vger.kernel.org>
commit 808153e1187fa77ac7d7dad261ff476888dcf398 upstream.
devm_memremap_pages() is a facility that can create struct page entries
for any arbitrary range and give drivers the ability to subvert core
aspects of page management.
Specifically the facility is tightly integrated with the kernel's memory
hotplug functionality. It injects an altmap argument deep into the
architecture specific vmemmap implementation to allow allocating from
specific reserved pages, and it has Linux specific assumptions about page
structure reference counting relative to get_user_pages() and
get_user_pages_fast(). It was an oversight and a mistake that this was
not marked EXPORT_SYMBOL_GPL from the outset.
Again, devm_memremap_pagex() exposes and relies upon core kernel internal
assumptions and will continue to evolve along with 'struct page', memory
hotplug, and support for new memory types / topologies. Only an in-kernel
GPL-only driver is expected to keep up with this ongoing evolution. This
interface, and functionality derived from this interface, is not suitable
for kernel-external drivers.
Link: http://lkml.kernel.org/r/154275557457.76910.16923571232582744134.stgit@dwillia2-desk3.amr.corp.intel.com
Cc: "Jérôme Glisse" <jglisse@redhat.com>
Cc: Logan Gunthorpe <logang@deltatee.com>
commit 15d36fecd0bdc7510b70a0e5ec6671140b3fce0c upstream.
When pmem namespaces created are smaller than section size, this can
cause an issue during removal and gpf was observed:
general protection fault: 0000 1 SMP PTI
CPU: 36 PID: 3941 Comm: ndctl Tainted: G W 4.14.28-1.el7uek.x86_64 #2
task: ffff88acda150000 task.stack: ffffc900233a4000
RIP: 0010:__put_page+0x56/0x79
Call Trace:
devm_memremap_pages_release+0x155/0x23a
release_nodes+0x21e/0x260
devres_release_all+0x3c/0x48
device_release_driver_internal+0x15c/0x207
device_release_driver+0x12/0x14
unbind_store+0xba/0xd8
drv_attr_store+0x27/0x31
sysfs_kf_write+0x3f/0x46
kernfs_fop_write+0x10f/0x18b
__vfs_write+0x3a/0x16d
vfs_write+0xb2/0x1a1
SyS_write+0x55/0xb9
do_syscall_64+0x79/0x1ae
entry_SYSCALL_64_after_hwframe+0x3d/0x0
Add code to check whether we have a mapping already in the same section
and prevent additional mappings from being created if that is the case.
Link: http://lkml.kernel.org/r/152909478401.50143.312364396244072931.stgit@djiang5-desk3.ch.intel.com
Signed-off-by: Dave Jiang <dave.jiang@intel.com>
Cc: Dan Williams <dan.j.williams@intel.com>
Cc: Robert Elliott <elliott@hpe.com>
Cc: Jeff Moyer <jmoyer@redhat.com>
Cc: Matthew Wilcox <willy@infradead.org>
Signed-off-by: Sudip Mukherjee <sudipm.mukherjee@gmail.com>
commit 77dd66a3c67c93ab401ccc15efff25578be281fd upstream.
If devm_memremap_pages() detects a collision while adding entries
to the radix-tree, we call pgmap_radix_release(). Unfortunately,
the function removes *all* entries for the range -- including the
entries that caused the collision in the first place.
Modify pgmap_radix_release() to take an additional argument to
indicate where to stop, so that only newly added entries are removed
from the tree.
Fixes: 9476df7d80df ("mm: introduce find_dev_pagemap()")
Signed-off-by: Jan H. Schönherr <jschoenh@amazon.de>
commit 10a0cd6e4932b5078215b1ec2c896597eec0eff9 upstream.
The functions devm_memremap_pages() and devm_memremap_pages_release() use
different ways to calculate the section-aligned amount of memory. The
latter function may use an incorrect size if the memory region is small
but straddles a section border.
Use the same code for both.
Fixes: 5f29a77cd957 ("mm: fix mixed zone detection in devm_memremap_pages")
devm_memremap_pages is initializing struct pages in for_each_device_pfn
and that can take quite some time. We have even seen a soft lockup
triggering on a non preemptive kernel
NMI watchdog: BUG: soft lockup - CPU#61 stuck for 22s! [kworker/u641:11:1808]
RIP: 0010:[<ffffffff8118b6b7>] [<ffffffff8118b6b7>] devm_memremap_pages+0x327/0x430
Call Trace:
pmem_attach_disk+0x2fd/0x3f0 [nd_pmem]
nvdimm_bus_probe+0x64/0x110 [libnvdimm]
driver_probe_device+0x1f7/0x420
bus_for_each_drv+0x52/0x80
__device_attach+0xb0/0x130
bus_probe_device+0x87/0xa0
device_add+0x3fc/0x5f0
nd_async_device_register+0xe/0x40 [libnvdimm]
async_run_entry_fn+0x43/0x150
process_one_work+0x14e/0x410
worker_thread+0x116/0x490
kthread+0xc7/0xe0
ret_from_fork+0x3f/0x70
fix this by adding cond_resched every 1024 pages.
Link: http://lkml.kernel.org/r/20170918121410.24466-4-mhocko@kernel.org
Signed-off-by: Michal Hocko <mhocko@suse.com>
Reported-by: Johannes Thumshirn <jthumshirn@suse.de>
Tested-by: Johannes Thumshirn <jthumshirn@suse.de>
Cc: Dan Williams <dan.j.williams@gmail.com>
Platform with advance system bus (like CAPI or CCIX) allow device memory
to be accessible from CPU in a cache coherent fashion. Add a new type of
ZONE_DEVICE to represent such memory. The use case are the same as for
the un-addressable device memory but without all the corners cases.
Link: http://lkml.kernel.org/r/20170817000548.32038-19-jglisse@redhat.com
Signed-off-by: Jérôme Glisse <jglisse@redhat.com>
Cc: Aneesh Kumar <aneesh.kumar@linux.vnet.ibm.com>
Cc: Paul E. McKenney <paulmck@linux.vnet.ibm.com>
Cc: Ross Zwisler <ross.zwisler@linux.intel.com>
Cc: David Nellans <dnellans@nvidia.com>
Cc: Evgeny Baskakov <ebaskakov@nvidia.com>
Cc: John Hubbard <jhubbard@nvidia.com>
Cc: Kirill A. Shutemov <kirill.shutemov@linux.intel.com>
Cc: Mark Hairgrove <mhairgrove@nvidia.com>
Cc: Michal Hocko <mhocko@kernel.org>
Cc: Sherry Cheung <SCheung@nvidia.com>
Cc: Subhash Gutti <sgutti@nvidia.com>
Cc: Vladimir Davydov <vdavydov.dev@gmail.com>
Cc: Bob Liu <liubo95@huawei.com>
HMM pages (private or public device pages) are ZONE_DEVICE page and thus
need special handling when it comes to lru or refcount. This patch make
sure that memcontrol properly handle those when it face them. Those pages
are use like regular pages in a process address space either as anonymous
page or as file back page. So from memcg point of view we want to handle
them like regular page for now at least.
Link: http://lkml.kernel.org/r/20170817000548.32038-11-jglisse@redhat.com
Acked-by: Balbir Singh <bsingharora@gmail.com>
A ZONE_DEVICE page that reach a refcount of 1 is free ie no longer have
any user. For device private pages this is important to catch and thus we
need to special case put_page() for this.
Link: http://lkml.kernel.org/r/20170817000548.32038-9-jglisse@redhat.com
HMM (heterogeneous memory management) need struct page to support
migration from system main memory to device memory. Reasons for HMM and
migration to device memory is explained with HMM core patch.
This patch deals with device memory that is un-addressable memory (ie CPU
can not access it). Hence we do not want those struct page to be manage
like regular memory. That is why we extend ZONE_DEVICE to support
different types of memory.
A persistent memory type is define for existing user of ZONE_DEVICE and a
new device un-addressable type is added for the un-addressable memory
type. There is a clear separation between what is expected from each
memory type and existing user of ZONE_DEVICE are un-affected by new
requirement and new use of the un-addressable type. All specific code
path are protect with test against the memory type.
Because memory is un-addressable we use a new special swap type for when a
page is migrated to device memory (this reduces the number of maximum swap
file).
The main two additions beside memory type to ZONE_DEVICE is two callbacks.
First one, page_free() is call whenever page refcount reach 1 (which
means the page is free as ZONE_DEVICE page never reach a refcount of 0).
This allow device driver to manage its memory and associated struct page.
The second callback page_fault() happens when there is a CPU access to an
address that is back by a device page (which are un-addressable by the
CPU). This callback is responsible to migrate the page back to system
main memory. Device driver can not block migration back to system memory,
HMM make sure that such page can not be pin into device memory.
If device is in some error condition and can not migrate memory back then
a CPU page fault to device memory should end with SIGBUS.
[arnd@arndb.de: fix warning]
Link: http://lkml.kernel.org/r/20170823133213.712917-1-arnd@arndb.de
Link: http://lkml.kernel.org/r/20170817000548.32038-8-jglisse@redhat.com
Acked-by: Dan Williams <dan.j.williams@intel.com>
devm_memremap_pages() records mapped ranges in pgmap_radix with an entry
per section's worth of memory (128MB). The key for each of those
entries is a section number.
This leads to false positives when devm_memremap_pages() is passed a
section-unaligned range as lookups in the misalignment fail to return
NULL. We can close this hole by using the pfn as the key for entries in
the tree. The number of entries required to describe a remapped range
is reduced by leveraging multi-order entries.
In practice this approach usually yields just one entry in the tree if
the size and starting address are of the same power-of-2 alignment.
Previously we always needed nr_entries = mapping_size / 128MB.
Link: https://lists.01.org/pipermail/linux-nvdimm/2016-August/006666.html
Link: http://lkml.kernel.org/r/150215410565.39310.13767886055248249438.stgit@dwillia2-desk3.amr.corp.intel.com
Reported-by: Toshi Kani <toshi.kani@hpe.com>
Cc: Matthew Wilcox <mawilcox@microsoft.com>
Boot data (such as EFI related data) is not encrypted when the system is
booted because UEFI/BIOS does not run with SME active. In order to access
this data properly it needs to be mapped decrypted.
Update early_memremap() to provide an arch specific routine to modify the
pagetable protection attributes before they are applied to the new
mapping. This is used to remove the encryption mask for boot related data.
Update memremap() to provide an arch specific routine to determine if RAM
remapping is allowed. RAM remapping will cause an encrypted mapping to be
generated. By preventing RAM remapping, ioremap_cache() will be used
instead, which will provide a decrypted mapping of the boot related data.
Signed-off-by: Tom Lendacky <thomas.lendacky@amd.com>
Reviewed-by: Matt Fleming <matt@codeblueprint.co.uk>
Reviewed-by: Borislav Petkov <bp@suse.de>
Cc: Alexander Potapenko <glider@google.com>
Cc: Andrey Ryabinin <aryabinin@virtuozzo.com>
Cc: Brijesh Singh <brijesh.singh@amd.com>
Cc: Dave Young <dyoung@redhat.com>
Cc: Dmitry Vyukov <dvyukov@google.com>
Cc: Jonathan Corbet <corbet@lwn.net>
Cc: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
Cc: Larry Woodman <lwoodman@redhat.com>
Cc: Michael S. Tsirkin <mst@redhat.com>
Cc: Radim Krčmář <rkrcmar@redhat.com>
Cc: Toshimitsu Kani <toshi.kani@hpe.com>
Cc: kasan-dev@googlegroups.com
Cc: kvm@vger.kernel.org
Cc: linux-doc@vger.kernel.org
Cc: linux-efi@vger.kernel.org
Cc: linux-mm@kvack.org
Link: http://lkml.kernel.org/r/81fb6b4117a5df6b9f2eda342f81bbef4b23d2e5.1500319216.git.thomas.lendacky@amd.com
arch_add_memory gets for_device argument which then controls whether we
want to create memblocks for created memory sections. Simplify the
logic by telling whether we want memblocks directly rather than going
through pointless negation. This also makes the api easier to
understand because it is clear what we want rather than nothing telling
for_device which can mean anything.
This shouldn't introduce any functional change.
Link: http://lkml.kernel.org/r/20170515085827.16474-13-mhocko@kernel.org
Tested-by: Dan Williams <dan.j.williams@intel.com>
Acked-by: Vlastimil Babka <vbabka@suse.cz>
Cc: Daniel Kiper <daniel.kiper@oracle.com>
Cc: Igor Mammedov <imammedo@redhat.com>
Cc: Jerome Glisse <jglisse@redhat.com>
Cc: Joonsoo Kim <js1304@gmail.com>
Cc: Reza Arbab <arbab@linux.vnet.ibm.com>
Cc: Tobias Regnery <tobias.regnery@gmail.com>
Cc: Toshi Kani <toshi.kani@hpe.com>
Cc: Vitaly Kuznetsov <vkuznets@redhat.com>
Cc: Xishi Qiu <qiuxishi@huawei.com>
Cc: Yasuaki Ishimatsu <isimatu.yasuaki@jp.fujitsu.com>
The current memory hotplug implementation relies on having all the
struct pages associate with a zone/node during the physical hotplug
phase (arch_add_memory->__add_pages->__add_section->__add_zone). In the
vast majority of cases this means that they are added to ZONE_NORMAL.
This has been so since 9d99aaa31f59 ("[PATCH] x86_64: Support memory
hotadd without sparsemem") and it wasn't a big deal back then because
movable onlining didn't exist yet.
Much later memory hotplug wanted to (ab)use ZONE_MOVABLE for movable
onlining 511c2aba8f07 ("mm, memory-hotplug: dynamic configure movable
memory and portion memory") and then things got more complicated.
Rather than reconsidering the zone association which was no longer
needed (because the memory hotplug already depended on SPARSEMEM) a
convoluted semantic of zone shifting has been developed. Only the
currently last memblock or the one adjacent to the zone_movable can be
onlined movable. This essentially means that the online type changes as
the new memblocks are added.
Let's simulate memory hot online manually
$ echo 0x100000000 > /sys/devices/system/memory/probe
$ grep . /sys/devices/system/memory/memory32/valid_zones
Normal Movable
$ echo $((0x100000000+(128<<20))) > /sys/devices/system/memory/probe
$ grep . /sys/devices/system/memory/memory3?/valid_zones
/sys/devices/system/memory/memory32/valid_zones:Normal
/sys/devices/system/memory/memory33/valid_zones:Normal Movable
$ echo $((0x100000000+2*(128<<20))) > /sys/devices/system/memory/probe
/sys/devices/system/memory/memory34/valid_zones:Normal Movable
$ echo online_movable > /sys/devices/system/memory/memory34/state
/sys/devices/system/memory/memory34/valid_zones:Movable Normal
This is an awkward semantic because an udev event is sent as soon as the
block is onlined and an udev handler might want to online it based on
some policy (e.g. association with a node) but it will inherently race
with new blocks showing up.
This patch changes the physical online phase to not associate pages with
any zone at all. All the pages are just marked reserved and wait for
the onlining phase to be associated with the zone as per the online
request. There are only two requirements
- existing ZONE_NORMAL and ZONE_MOVABLE cannot overlap
- ZONE_NORMAL precedes ZONE_MOVABLE in physical addresses
the latter one is not an inherent requirement and can be changed in the
future. It preserves the current behavior and made the code slightly
simpler. This is subject to change in future.
This means that the same physical online steps as above will lead to the
following state: Normal Movable
/sys/devices/system/memory/memory32/valid_zones:Normal Movable
Implementation:
The current move_pfn_range is reimplemented to check the above
requirements (allow_online_pfn_range) and then updates the respective
zone (move_pfn_range_to_zone), the pgdat and links all the pages in the
pfn range with the zone/node. __add_pages is updated to not require the
zone and only initializes sections in the range. This allowed to
simplify the arch_add_memory code (s390 could get rid of quite some of
code).
devm_memremap_pages is the only user of arch_add_memory which relies on
the zone association because it only hooks into the memory hotplug only
half way. It uses it to associate the new memory with ZONE_DEVICE but
doesn't allow it to be {on,off}lined via sysfs. This means that this
particular code path has to call move_pfn_range_to_zone explicitly.
The original zone shifting code is kept in place and will be removed in
the follow up patch for an easier review.
Please note that this patch also changes the original behavior when
offlining a memory block adjacent to another zone (Normal vs. Movable)
used to allow to change its movable type. This will be handled later.
[richard.weiyang@gmail.com: simplify zone_intersects()]
Link: http://lkml.kernel.org/r/20170616092335.5177-1-richard.weiyang@gmail.com
[richard.weiyang@gmail.com: remove duplicate call for set_page_links]
Link: http://lkml.kernel.org/r/20170616092335.5177-2-richard.weiyang@gmail.com
[akpm@linux-foundation.org: remove unused local `i']
Link: http://lkml.kernel.org/r/20170515085827.16474-12-mhocko@kernel.org
Signed-off-by: Wei Yang <richard.weiyang@gmail.com>
Tested-by: Reza Arbab <arbab@linux.vnet.ibm.com>
Acked-by: Heiko Carstens <heiko.carstens@de.ibm.com> # For s390 bits
reference to fix pmem crash
The x86 conversion to the generic GUP code included a small change which causes
crashes and data corruption in the pmem code - not good.
The root cause is that the /dev/pmem driver code implicitly relies on the x86
get_user_pages() implementation doing a get_page() on the page refcount, because
get_page() does a get_zone_device_page() which properly refcounts pmem's separate
page struct arrays that are not present in the regular page struct structures.
(The pmem driver does this because it can cover huge memory areas.)
But the x86 conversion to the generic GUP code changed the get_page() to
page_cache_get_speculative() which is faster but doesn't do the
get_zone_device_page() call the pmem code relies on.
One way to solve the regression would be to change the generic GUP code to use
get_page(), but that would slow things down a bit and punish other generic-GUP
using architectures for an x86-ism they did not care about. (Arguably the pmem
driver was probably not working reliably for them: but nvdimm is an Intel
feature, so non-x86 exposure is probably still limited.)
So restructure the pmem code's interface with the MM instead: get rid of the
get/put_zone_device_page() distinction, integrate put_zone_device_page() into
__put_page() and and restructure the pmem completion-wait and teardown machinery:
Kirill points out that the calls to {get,put}_dev_pagemap() can be
removed from the mm fast path if we take a single get_dev_pagemap()
reference to signify that the page is alive and use the final put of the
page to drop that reference.
This does require some care to make sure that any waits for the
percpu_ref to drop to zero occur *after* devm_memremap_page_release(),
since it now maintains its own elevated reference.
This speeds up things while also making the pmem refcounting more robust going
forward.
Suggested-by: Kirill Shutemov <kirill.shutemov@linux.intel.com>
Tested-by: Kirill Shutemov <kirill.shutemov@linux.intel.com>
Cc: Brian Gerst <brgerst@gmail.com>
Cc: Denys Vlasenko <dvlasenk@redhat.com>
Cc: Josh Poimboeuf <jpoimboe@redhat.com>
Cc: Jérôme Glisse <jglisse@redhat.com>
Link: http://lkml.kernel.org/r/149339998297.24933.1129582806028305912.stgit@dwillia2-desk3.amr.corp.intel.com
Commit bfc8c90139eb ("mem-hotplug: implement get/put_online_mems")
introduced new functions get/put_online_mems() and mem_hotplug_begin/end()
in order to allow similar semantics for memory hotplug like for cpu
hotplug.
The corresponding functions for cpu hotplug are get/put_online_cpus()
and cpu_hotplug_begin/done() for cpu hotplug.
The commit however missed to introduce functions that would serialize
memory hotplug operations like they are done for cpu hotplug with
cpu_maps_update_begin/done().
This basically leaves mem_hotplug.active_writer unprotected and allows
concurrent writers to modify it, which may lead to problems as outlined
by commit f931ab479dd2 ("mm: fix devm_memremap_pages crash, use
mem_hotplug_{begin, done}").
That commit was extended again with commit b5d24fda9c3d ("mm,
devm_memremap_pages: hold device_hotplug lock over mem_hotplug_{begin,
done}") which serializes memory hotplug operations for some call sites
by using the device_hotplug lock.
In addition with commit 3fc21924100b ("mm: validate device_hotplug is held
for memory hotplug") a sanity check was added to mem_hotplug_begin() to
verify that the device_hotplug lock is held.
This in turn triggers the following warning on s390:
WARNING: CPU: 6 PID: 1 at drivers/base/core.c:643 assert_held_device_hotplug+0x4a/0x58
Call Trace:
assert_held_device_hotplug+0x40/0x58)
mem_hotplug_begin+0x34/0xc8
add_memory_resource+0x7e/0x1f8
add_memory+0xda/0x130
add_memory_merged+0x15c/0x178
sclp_detect_standby_memory+0x2ae/0x2f8
do_one_initcall+0xa2/0x150
kernel_init_freeable+0x228/0x2d8
kernel_init+0x2a/0x140
kernel_thread_starter+0x6/0xc
One possible fix would be to add more lock_device_hotplug() and
unlock_device_hotplug() calls around each call site of
mem_hotplug_begin/end(). But that would give the device_hotplug lock
additional semantics it better should not have (serialize memory hotplug
operations).
Instead add a new memory_add_remove_lock which has the similar semantics
like cpu_add_remove_lock for cpu hotplug.
To keep things hopefully a bit easier the lock will be locked and unlocked
within the mem_hotplug_begin/end() functions.
Link: http://lkml.kernel.org/r/20170314125226.16779-2-heiko.carstens@de.ibm.com
Reported-by: Sebastian Ott <sebott@linux.vnet.ibm.com>
Acked-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
Cc: Ben Hutchings <ben@decadent.org.uk>
Cc: Gerald Schaefer <gerald.schaefer@de.ibm.com>
The mem_hotplug_{begin,done} lock coordinates with {get,put}_online_mems()
to hold off "readers" of the current state of memory from new hotplug
actions. mem_hotplug_begin() expects exclusive access, via the
device_hotplug lock, to set mem_hotplug.active_writer. Calling
mem_hotplug_begin() without locking device_hotplug can lead to
corrupting mem_hotplug.refcount and missed wakeups / soft lockups.
[dan.j.williams@intel.com: v2]
Link: http://lkml.kernel.org/r/148728203365.38457.17804568297887708345.stgit@dwillia2-desk3.amr.corp.intel.com
Link: http://lkml.kernel.org/r/148693885680.16345.17802627926777862337.stgit@dwillia2-desk3.amr.corp.intel.com
Fixes: f931ab479dd2 ("mm: fix devm_memremap_pages crash, use mem_hotplug_{begin, done}")
Reported-by: Ben Hutchings <ben@decadent.org.uk>
Cc: Masayoshi Mizuma <m.mizuma@jp.fujitsu.com>
Both arch_add_memory() and arch_remove_memory() expect a single threaded
context.
For example, arch/x86/mm/init_64.c::kernel_physical_mapping_init() does
not hold any locks over this check and branch:
if (pgd_val(*pgd)) {
pud = (pud_t *)pgd_page_vaddr(*pgd);
paddr_last = phys_pud_init(pud, __pa(vaddr),
__pa(vaddr_end),
page_size_mask);
continue;
pud = alloc_low_page();
paddr_last = phys_pud_init(pud, __pa(vaddr), __pa(vaddr_end),
page_size_mask);
The result is that two threads calling devm_memremap_pages()
simultaneously can end up colliding on pgd initialization. This leads
to crash signatures like the following where the loser of the race
initializes the wrong pgd entry:
BUG: unable to handle kernel paging request at ffff888ebfff0000
IP: memcpy_erms+0x6/0x10
PGD 2f8e8fc067 PUD 0 /* <---- Invalid PUD */
Oops: 0000 [#1] SMP DEBUG_PAGEALLOC
CPU: 54 PID: 3818 Comm: systemd-udevd Not tainted 4.6.7+ #13
task: ffff882fac290040 ti: ffff882f887a4000 task.ti: ffff882f887a4000
RIP: memcpy_erms+0x6/0x10
Call Trace:
? pmem_do_bvec+0x205/0x370 [nd_pmem]
? blk_queue_enter+0x3a/0x280
pmem_rw_page+0x38/0x80 [nd_pmem]
bdev_read_page+0x84/0xb0
Hold the standard memory hotplug mutex over calls to
arch_{add,remove}_memory().
Fixes: 41e94a851304 ("add devm_memremap_pages")
Link: http://lkml.kernel.org/r/148357647831.9498.12606007370121652979.stgit@dwillia2-desk3.amr.corp.intel.com
track_pfn_insert() in vmf_insert_pfn_pmd() is marking dax mappings as
uncacheable rendering them impractical for application usage. DAX-pte
mappings are cached and the goal of establishing DAX-pmd mappings is to
attain more performance, not dramatically less (3 orders of magnitude).
track_pfn_insert() relies on a previous call to reserve_memtype() to
establish the expected page_cache_mode for the range. While memremap()
arranges for reserve_memtype() to be called, devm_memremap_pages() does
not. So, teach track_pfn_insert() and untrack_pfn() how to handle
tracking without a vma, and arrange for devm_memremap_pages() to
establish the write-back-cache reservation in the memtype tree.
Cc: Nilesh Choudhury <nilesh.choudhury@oracle.com>
Reported-by: Kai Zhang <kai.ka.zhang@oracle.com>
Acked-by: Andrew Morton <akpm@linux-foundation.org>
git://git.kernel.org/pub/scm/linux/kernel/git/nvdimm/nvdimm
Pull libnvdimm updates from Dan Williams:
- Replace pcommit with ADR / directed-flushing.
The pcommit instruction, which has not shipped on any product, is
deprecated. Instead, the requirement is that platforms implement
either ADR, or provide one or more flush addresses per nvdimm.
ADR (Asynchronous DRAM Refresh) flushes data in posted write buffers
to the memory controller on a power-fail event.
Flush addresses are defined in ACPI 6.x as an NVDIMM Firmware
Interface Table (NFIT) sub-structure: "Flush Hint Address Structure".
A flush hint is an mmio address that when written and fenced assures
that all previous posted writes targeting a given dimm have been
flushed to media.
- On-demand ARS (address range scrub).
Linux uses the results of the ACPI ARS commands to track bad blocks
in pmem devices. When latent errors are detected we re-scrub the
media to refresh the bad block list, userspace can also request a
re-scrub at any time.
- Support for the Microsoft DSM (device specific method) command
format.
- Support for EDK2/OVMF virtual disk device memory ranges.
- Various fixes and cleanups across the subsystem.
* tag 'libnvdimm-for-4.8' of git://git.kernel.org/pub/scm/linux/kernel/git/nvdimm/nvdimm: (41 commits)
libnvdimm-btt: Delete an unnecessary check before the function call "__nd_device_register"
nfit: do an ARS scrub on hitting a latent media error
nfit: move to nfit/ sub-directory
nfit, libnvdimm: allow an ARS scrub to be triggered on demand
libnvdimm: register nvdimm_bus devices with an nd_bus driver
pmem: clarify a debug print in pmem_clear_poison
x86/insn: remove pcommit
Revert "KVM: x86: add pcommit support"
nfit, tools/testing/nvdimm/: unify shutdown paths
libnvdimm: move ->module to struct nvdimm_bus_descriptor
nfit: cleanup acpi_nfit_init calling convention
nfit: fix _FIT evaluation memory leak + use after free
tools/testing/nvdimm: add manufacturing_{date|location} dimm properties
tools/testing/nvdimm: add virtual ramdisk range
acpi, nfit: treat virtual ramdisk SPA as pmem region
pmem: kill __pmem address space
pmem: kill wmb_pmem()
libnvdimm, pmem: use nvdimm_flush() for namespace I/O writes
fs/dax: remove wmb_pmem()
libnvdimm, pmem: flush posted-write queues on shutdown
Now that ZONE_DEVICE depends on SPARSEMEM_VMEMMAP we can simplify some
ifdef guards to just ZONE_DEVICE.
Link: http://lkml.kernel.org/r/146687646788.39261.8020536391978771940.stgit@dwillia2-desk3.amr.corp.intel.com
Reported-by: Vlastimil Babka <vbabka@suse.cz>
Cc: Eric Sandeen <sandeen@redhat.com>
Currently phys_to_pfn_t() is an exported symbol to allow nfit_test to
override it and indicate that nfit_test-pmem is not device-mapped. Now,
we want to enable nfit_test to operate without DMA_CMA and the pmem it
provides will no longer be physically contiguous, i.e. won't be capable
of supporting direct_access requests larger than a page. Make
pmem_direct_access() a weak symbol so that it can be replaced by the
tools/testing/nvdimm/ version, and move phys_to_pfn_t() to a static
inline now that it no longer needs to be overridden.
Acked-by: Johannes Thumshirn <jthumshirn@suse.de>
Currently, the memremap code serves MEMREMAP_WB mappings directly from
the kernel direct mapping, unless the region is in high memory, in which
case it falls back to using ioremap_cache(). However, the semantics of
ioremap_cache() are not unambiguously defined, and on ARM, it will
actually result in a mapping type that differs from the attributes used
for the linear mapping, and for this reason, the ioremap_cache() call
fails if the region is part of the memory managed by the kernel.
So instead, implement an optional hook 'arch_memremap_wb' whose default
implementation calls ioremap_cache() as before, but which can be
overridden by the architecture to do what is appropriate for it.
Signed-off-by: Ard Biesheuvel <ard.biesheuvel@linaro.org>
Add a flag to memremap() for writecombine mappings. Mappings satisfied
by this flag will not be cached, however writes may be delayed or
combined into more efficient bursts. This is most suitable for buffers
written sequentially by the CPU for use by other DMA devices.
Signed-off-by: Brian Starkey <brian.starkey@arm.com>
Reviewed-by: Catalin Marinas <catalin.marinas@arm.com>
These patches implement a MEMREMAP_WC flag for memremap(), which can be
used to obtain writecombine mappings. This is then used for setting up
dma_coherent_mem regions which use the DMA_MEMORY_MAP flag.
The motivation is to fix an alignment fault on arm64, and the suggestion
to implement MEMREMAP_WC for this case was made at [1]. That particular
issue is handled in patch 4, which makes sure that the appropriate
memset function is used when zeroing allocations mapped as IO memory.
This patch (of 4):
Don't modify the flags input argument to memremap(). MEMREMAP_WB is
already a special case so we can check for it directly instead of
clearing flag bits in each mapper.
Commit 4b94ffdc4163 ("x86, mm: introduce vmem_altmap to augment
vmemmap_populate()"), introduced the to_vmem_altmap() function.
The comments in this function contain two typos (one misspelling of the
Kconfig option CONFIG_SPARSEMEM_VMEMMAP, and one missing letter 'n'),
let's fix them up.
Signed-off-by: Andreas Ziegler <andreas.ziegler@fau.de>
Pull ram resource handling changes from Ingo Molnar:
"Core kernel resource handling changes to support NVDIMM error
injection.
This tree introduces a new I/O resource type, IORESOURCE_SYSTEM_RAM,
for System RAM while keeping the current IORESOURCE_MEM type bit set
for all memory-mapped ranges (including System RAM) for backward
compatibility.
With this resource flag it no longer takes a strcmp() loop through the
resource tree to find "System RAM" resources.
The new resource type is then used to extend ACPI/APEI error injection
facility to also support NVDIMM"
* 'core-resources-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
ACPI/EINJ: Allow memory error injection to NVDIMM
resource: Kill walk_iomem_res()
x86/kexec: Remove walk_iomem_res() call with GART type
x86, kexec, nvdimm: Use walk_iomem_res_desc() for iomem search
resource: Add walk_iomem_res_desc()
memremap: Change region_intersects() to take @flags and @desc
arm/samsung: Change s3c_pm_run_res() to use System RAM type
resource: Change walk_system_ram() to use System RAM type
drivers: Initialize resource entry to zero
xen, mm: Set IORESOURCE_SYSTEM_RAM to System RAM
kexec: Set IORESOURCE_SYSTEM_RAM for System RAM
arch: Set IORESOURCE_SYSTEM_RAM flag for System RAM
ia64: Set System RAM type and descriptor
x86/e820: Set System RAM type and descriptor
resource: Add I/O resource descriptor
resource: Handle resource flags properly
resource: Add System RAM resource type
In memremap's helper function try_ram_remap(), we dereference a struct
page pointer that was derived from a PFN that is known to be covered by
a 'System RAM' iomem region, and is thus assumed to be a 'valid' PFN,
i.e., a PFN that has a struct page associated with it and is covered by
the kernel direct mapping.
However, the assumption that there is a 1:1 relation between the System
RAM iomem region and the kernel direct mapping is not universally valid
on all architectures, and on ARM and arm64, 'System RAM' may include
regions for which pfn_valid() returns false.
Generally speaking, both __va() and pfn_to_page() should only ever be
called on PFNs/physical addresses for which pfn_valid() returns true, so
add that check to try_ram_remap().
The check for whether we overlap "System RAM" needs to be done at
section granularity. For example a system with the following mapping:
100000000-37bffffff : System RAM
37c000000-837ffffff : Persistent Memory
...is unable to use devm_memremap_pages() as it would result in two
zones colliding within a given section.
Reviewed-by: Toshi Kani <toshi.kani@hpe.com>
Given we have uninitialized list_heads being passed to list_add() it
will always be the case that those uninitialized values randomly trigger
the poison value. Especially since a list_add() operation will seed the
stack with the poison value for later stack allocations to trip over.
For example, see these two false positive reports:
list_add attempted on force-poisoned entry
WARNING: at lib/list_debug.c:34
NIP [c00000000043c390] __list_add+0xb0/0x150
LR [c00000000043c38c] __list_add+0xac/0x150
Call Trace:
__list_add+0xac/0x150 (unreliable)
__down+0x4c/0xf8
down+0x68/0x70
xfs_buf_lock+0x4c/0x150 [xfs]
list_add attempted on force-poisoned entry(0000000000000500),
new->next == d0000000059ecdb0, new->prev == 0000000000000500
WARNING: at lib/list_debug.c:33
NIP [c00000000042db78] __list_add+0xa8/0x140
LR [c00000000042db74] __list_add+0xa4/0x140
Call Trace:
__list_add+0xa4/0x140 (unreliable)
rwsem_down_read_failed+0x6c/0x1a0
down_read+0x58/0x60
xfs_log_commit_cil+0x7c/0x600 [xfs]
Fixes: commit 5c2c2587b132 ("mm, dax, pmem: introduce {get|put}_dev_pagemap() for dax-gup")
Reported-by: Eryu Guan <eguan@redhat.com>
Tested-by: Eryu Guan <eguan@redhat.com>
Pull libnvdimm fixes from Dan Williams:
- Two fixes for compatibility with the ACPI 6.1 specification.
Without these fixes multi-interface DIMMs will fail to be probed, and
address range scrub commands to find memory errors will give results
that the kernel will mis-interpret. For multi-interface DIMMs Linux
will accept either the original 6.0 implementation or 6.1.
For address range scrub we'll only support 6.1 since ACPI formalized
this DSM differently than the original example [1] implemented in
v4.2. The expectation is that production systems will only ever ship
the ACPI 6.1 address range scrub command definition.
- The wider async address range scrub work targeting 4.6 discovered
that the original synchronous implementation in 4.5 is not sizing its
return buffer correctly.
- Arnd caught that my recent fix to the size of the pfn_t flags missed
updating the flags variable used in the pmem driver.
- Toshi found that we mishandle the memremap() return value in
devm_memremap().
* 'libnvdimm-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/nvdimm/nvdimm:
nvdimm: use 'u64' for pfn flags
devm_memremap: Fix error value when memremap failed
nfit: update address range scrub commands to the acpi 6.1 format
libnvdimm, tools/testing/nvdimm: fix 'ars_status' output buffer sizing
nfit: fix multi-interface dimm handling, acpi6.1 compatibility
devm_memremap() returns an ERR_PTR() value in case of error.
However, it returns NULL when memremap() failed. This causes
the caller, such as the pmem driver, to proceed and oops later.
Change devm_memremap() to return ERR_PTR(-ENXIO) when memremap()
failed.
Signed-off-by: Toshi Kani <toshi.kani@hpe.com>
Reviewed-by: Ross Zwisler <ross.zwisler@linux.intel.com>
The pmem driver calls devm_memremap() to map a persistent memory range.
When the pmem driver is unloaded, this memremap'd range is not released
so the kernel will leak a vma.
Fix devm_memremap_release() to handle a given memremap'd address
properly.
Cc: Matthew Wilcox <willy@linux.intel.com>
The pfn_t type uses an unsigned long to store a pfn + flags value. On a
64-bit platform the upper 12 bits of an unsigned long are never used for
storing the value of a pfn. However, this is not true on highmem
platforms, all 32-bits of a pfn value are used to address a 44-bit
physical address space. A pfn_t needs to store a 64-bit value.
Link: https://bugzilla.kernel.org/show_bug.cgi?id=112211
Fixes: 01c8f1c44b83 ("mm, dax, gpu: convert vm_insert_mixed to pfn_t")
Reported-by: Stuart Foster <smf.linux@ntlworld.com>
Reported-by: Julian Margetson <runaway@candw.ms>
Tested-by: Julian Margetson <runaway@candw.ms>
A dma_addr_t is potentially smaller than a phys_addr_t on some archs.
Don't truncate the address when doing the pfn conversion.
Reported-by: Matthew Wilcox <willy@linux.intel.com>
[willy: fix pfn_t_to_phys as well]
Change region_intersects() to identify a target with @flags and
@desc, instead of @name with strcmp().
Change the callers of region_intersects(), memremap() and
devm_memremap(), to set IORESOURCE_SYSTEM_RAM in @flags and
IORES_DESC_NONE in @desc when searching System RAM.
Also, export region_intersects() so that the ACPI EINJ error
injection driver can call this function in a later patch.
Cc: Ard Biesheuvel <ard.biesheuvel@linaro.org>
Cc: Jakub Sitnicki <jsitnicki@gmail.com>
Cc: Jan Kara <jack@suse.cz>
Cc: Jiang Liu <jiang.liu@linux.intel.com>
Cc: Konstantin Khlebnikov <koct9i@gmail.com>
Cc: Luis R. Rodriguez <mcgrof@suse.com>
Cc: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com>
Cc: Tejun Heo <tj@kernel.org>
Cc: Toshi Kani <toshi.kani@hp.com>
Cc: linux-mm <linux-mm@kvack.org>
Link: http://lkml.kernel.org/r/1453841853-11383-13-git-send-email-bp@alien8.de
to_vmem_altmap() needs to return valid results until
arch_remove_memory() completes. It also needs to be valid for any pfn
in a section regardless of whether that pfn maps to data. This escape
was a result of a bug in the unit test.
The signature of this bug is that free_pagetable() fails to retrieve a
vmem_altmap and goes off into the weeds:
BUG: unable to handle kernel NULL pointer dereference at (null)
IP: [<ffffffff811d2629>] get_pfnblock_flags_mask+0x49/0x60
Call Trace:
[<ffffffff811d3477>] free_hot_cold_page+0x97/0x1d0
[<ffffffff811d367a>] __free_pages+0x2a/0x40
[<ffffffff8191e669>] free_pagetable+0x8c/0xd4
[<ffffffff8191ef4e>] remove_pagetable+0x37a/0x808
[<ffffffff8191b210>] vmemmap_free+0x10/0x20
Fixes: 4b94ffdc4163 ("x86, mm: introduce vmem_altmap to augment vmemmap_populate()")
Reported-by: Jeff Moyer <jmoyer@redhat.com>
A dax mapping establishes a pte with _PAGE_DEVMAP set when the driver
has established a devm_memremap_pages() mapping, i.e. when the pfn_t
return from ->direct_access() has PFN_DEV and PFN_MAP set. Later, when
encountering _PAGE_DEVMAP during a page table walk we lookup and pin a
struct dev_pagemap instance to keep the result of pfn_to_page() valid
until put_page().
Tested-by: Logan Gunthorpe <logang@deltatee.com>
Cc: Dave Hansen <dave@sr71.net>
get_dev_page() enables paths like get_user_pages() to pin a dynamically
mapped pfn-range (devm_memremap_pages()) while the resulting struct page
objects are in use. Unlike get_page() it may fail if the device is, or
is in the process of being, disabled. While the initial lookup of the
range may be an expensive list walk, the result is cached to speed up
subsequent lookups which are likely to be in the same mapped range.
devm_memremap_pages() now requires a reference counter to be specified
at init time. For pmem this means moving request_queue allocation into
pmem_alloc() so the existing queue usage counter can track "device
pages".
ZONE_DEVICE pages always have an elevated count and will never be on an
lru reclaim list. That space in 'struct page' can be redirected for
other uses, but for safety introduce a poison value that will always
trip __list_add() to assert. This allows half of the struct list_head
storage to be reclaimed with some assurance to back up the assumption
that the page count never goes to zero and a list_add() is never
attempted.
In support of providing struct page for large persistent memory
capacities, use struct vmem_altmap to change the default policy for
allocating memory for the memmap array. The default vmemmap_populate()
allocates page table storage area from the page allocator. Given
persistent memory capacities relative to DRAM it may not be feasible to
store the memmap in 'System Memory'. Instead vmem_altmap represents
pre-allocated "device pages" to satisfy vmemmap_alloc_block_buf()
requests.
Reported-by: kbuild test robot <lkp@intel.com>
Cc: Dave Hansen <dave.hansen@linux.intel.com>
There are several scenarios where we need to retrieve and update
metadata associated with a given devm_memremap_pages() mapping, and the
only lookup key available is a pfn in the range:
1/ We want to augment vmemmap_populate() (called via arch_add_memory())
to allocate memmap storage from pre-allocated pages reserved by the
device driver. At vmemmap_alloc_block_buf() time it grabs device pages
rather than page allocator pages. This is in support of
devm_memremap_pages() mappings where the memmap is too large to fit in
main memory (i.e. large persistent memory devices).
2/ Taking a reference against the mapping when inserting device pages
into the address_space radix of a given inode. This facilitates
unmap_mapping_range() and truncate_inode_pages() operations when the
driver is tearing down the mapping.
3/ get_user_pages() operations on ZONE_DEVICE memory require taking a
reference against the mapping so that the driver teardown path can
revoke and drain usage of device pages.
For the purpose of communicating the optional presence of a 'struct
page' for the pfn returned from ->direct_access(), introduce a type that
encapsulates a page-frame-number plus flags. These flags contain the
historical "page_link" encoding for a scatterlist entry, but can also
denote "device memory". Where "device memory" is a set of pfns that are
not part of the kernel's linear mapping by default, but are accessed via
the same memory controller as ram.
The motivation for this new type is large capacity persistent memory
that needs struct page entries in the 'memmap' to support 3rd party DMA
(i.e. O_DIRECT I/O with a persistent memory source/target). However,
we also need it in support of maintaining a list of mapped inodes which
need to be unmapped at driver teardown or freeze_bdev() time.
"Outside of the new ACPI-NFIT hot-add support this pull request is more
notable for what it does not contain, than what it does. There were a
handful of development topics this cycle, dax get_user_pages, dax
fsync, and raw block dax, that need more more iteration and will wait
for 4.5.
The patches to make devm and the pmem driver NUMA aware have been in
-next for several weeks. The hot-add support has not, but is
contained to the NFIT driver and is passing unit tests. The coredump
support is straightforward and was looked over by Jeff. All of it has
received a 0day build success notification across 107 configs.
Summary:
- Add support for the ACPI 6.0 NFIT hot add mechanism to process
updates of the NFIT at runtime.
- Teach the coredump implementation how to filter out DAX mappings.
- Introduce NUMA hints for allocations made by the pmem driver, and
as a side effect all devm allocations now hint their NUMA node by
default"
* tag 'libnvdimm-for-4.4' of git://git.kernel.org/pub/scm/linux/kernel/git/nvdimm/nvdimm:
coredump: add DAX filtering for FDPIC ELF coredumps
coredump: add DAX filtering for ELF coredumps
acpi: nfit: Add support for hot-add
nfit: in acpi_nfit_init, break on a 0-length table
pmem, memremap: convert to numa aware allocations
devm_memremap_pages: use numa_mem_id
devm: make allocations numa aware by default
devm_memremap: convert to return ERR_PTR
devm_memunmap: use devres_release()
pmem: kill memremap_pmem()
x86, mm: quiet arch_add_memory()
Currently memremap checks if the range is "System RAM" and returns the
kernel linear address. This is broken for highmem platforms where a
range may be "System RAM", but is not part of the kernel linear mapping.
Fallback to ioremap_cache() in these cases, to let the arch code attempt
to handle it.
Note that ARM ioremap will WARN when attempting to remap ram, and in
that case the caller needs to be fixed. For this reason, existing
ioremap_cache() usages for ARM are already trained to avoid attempts to
remap ram.
The impact of this bug is low for now since the pmem driver is the only
user of memremap(), but this is important to fix before more conversions
to memremap arrive in 4.4.
Cc: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
Reported-by: Ard Biesheuvel <ard.biesheuvel@linaro.org>
Acked-by: Ard Biesheuvel <ard.biesheuvel@linaro.org>
Given that pmem ranges come with numa-locality hints, arrange for the
resulting driver objects to be obtained from node-local memory.
Reviewed-by: Tejun Heo <tj@kernel.org>
Hint to closest numa node for the placement of newly allocated pages.
As that is where the device's other allocations will originate by
default when it does not specify a NUMA node.
Make devm_memremap consistent with the error return scheme of
devm_memremap_pages to remove special casing in the pmem driver.
Remove open coded call to memunmap.
This behaves like devm_memremap except that it ensures we have page
structures available that can back the region.
[djbw: catch attempts to remap RAM, drop flags]
