path: root/kernel/mutex.c
2013-04-19mutex: Back out architecture specific check for negative mutex countWaiman Long
Linus suggested that probably all the supported architectures can allow a negative mutex count without incorrect behavior, so we can then back out the architecture specific change and allow the mutex count to go to any negative number. That should further reduce contention for non-x86 architecture. Suggested-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Waiman Long <Waiman.Long@hp.com> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Chandramouleeswaran Aswin <aswin@hp.com> Cc: Davidlohr Bueso <davidlohr.bueso@hp.com> Cc: Norton Scott J <scott.norton@hp.com> Cc: Rik van Riel <riel@redhat.com> Cc: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: David Howells <dhowells@redhat.com> Cc: Dave Jones <davej@redhat.com> Cc: Clark Williams <williams@redhat.com> Cc: Peter Zijlstra <peterz@infradead.org> Link: http://lkml.kernel.org/r/1366226594-5506-5-git-send-email-Waiman.Long@hp.com Signed-off-by: Ingo Molnar <mingo@kernel.org>
2013-04-19mutex: Queue mutex spinners with MCS lock to reduce cacheline contentionWaiman Long
The current mutex spinning code (with MUTEX_SPIN_ON_OWNER option turned on) allow multiple tasks to spin on a single mutex concurrently. A potential problem with the current approach is that when the mutex becomes available, all the spinning tasks will try to acquire the mutex more or less simultaneously. As a result, there will be a lot of cacheline bouncing especially on systems with a large number of CPUs. This patch tries to reduce this kind of contention by putting the mutex spinners into a queue so that only the first one in the queue will try to acquire the mutex. This will reduce contention and allow all the tasks to move forward faster. The queuing of mutex spinners is done using an MCS lock based implementation which will further reduce contention on the mutex cacheline than a similar ticket spinlock based implementation. This patch will add a new field into the mutex data structure for holding the MCS lock. This expands the mutex size by 8 bytes for 64-bit system and 4 bytes for 32-bit system. This overhead will be avoid if the MUTEX_SPIN_ON_OWNER option is turned off. The following table shows the jobs per minute (JPM) scalability data on an 8-node 80-core Westmere box with a 3.7.10 kernel. The numactl command is used to restrict the running of the fserver workloads to 1/2/4/8 nodes with hyperthreading off. +-----------------+-----------+-----------+-------------+----------+ | Configuration | Mean JPM | Mean JPM | Mean JPM | % Change | | | w/o patch | patch 1 | patches 1&2 | 1->1&2 | +-----------------+------------------------------------------------+ | | User Range 1100 - 2000 | +-----------------+------------------------------------------------+ | 8 nodes, HT off | 227972 | 227237 | 305043 | +34.2% | | 4 nodes, HT off | 393503 | 381558 | 394650 | +3.4% | | 2 nodes, HT off | 334957 | 325240 | 338853 | +4.2% | | 1 node , HT off | 198141 | 197972 | 198075 | +0.1% | +-----------------+------------------------------------------------+ | | User Range 200 - 1000 | +-----------------+------------------------------------------------+ | 8 nodes, HT off | 282325 | 312870 | 332185 | +6.2% | | 4 nodes, HT off | 390698 | 378279 | 393419 | +4.0% | | 2 nodes, HT off | 336986 | 326543 | 340260 | +4.2% | | 1 node , HT off | 197588 | 197622 | 197582 | 0.0% | +-----------------+-----------+-----------+-------------+----------+ At low user range 10-100, the JPM differences were within +/-1%. So they are not that interesting. The fserver workload uses mutex spinning extensively. With just the mutex change in the first patch, there is no noticeable change in performance. Rather, there is a slight drop in performance. This mutex spinning patch more than recovers the lost performance and show a significant increase of +30% at high user load with the full 8 nodes. Similar improvements were also seen in a 3.8 kernel. The table below shows the %time spent by different kernel functions as reported by perf when running the fserver workload at 1500 users with all 8 nodes. +-----------------------+-----------+---------+-------------+ | Function | % time | % time | % time | | | w/o patch | patch 1 | patches 1&2 | +-----------------------+-----------+---------+-------------+ | __read_lock_failed | 34.96% | 34.91% | 29.14% | | __write_lock_failed | 10.14% | 10.68% | 7.51% | | mutex_spin_on_owner | 3.62% | 3.42% | 2.33% | | mspin_lock | N/A | N/A | 9.90% | | __mutex_lock_slowpath | 1.46% | 0.81% | 0.14% | | _raw_spin_lock | 2.25% | 2.50% | 1.10% | +-----------------------+-----------+---------+-------------+ The fserver workload for an 8-node system is dominated by the contention in the read/write lock. Mutex contention also plays a role. With the first patch only, mutex contention is down (as shown by the __mutex_lock_slowpath figure) which help a little bit. We saw only a few percents improvement with that. By applying patch 2 as well, the single mutex_spin_on_owner figure is now split out into an additional mspin_lock figure. The time increases from 3.42% to 11.23%. It shows a great reduction in contention among the spinners leading to a 30% improvement. The time ratio 9.9/2.33=4.3 indicates that there are on average 4+ spinners waiting in the spin_lock loop for each spinner in the mutex_spin_on_owner loop. Contention in other locking functions also go down by quite a lot. The table below shows the performance change of both patches 1 & 2 over patch 1 alone in other AIM7 workloads (at 8 nodes, hyperthreading off). +--------------+---------------+----------------+-----------------+ | Workload | mean % change | mean % change | mean % change | | | 10-100 users | 200-1000 users | 1100-2000 users | +--------------+---------------+----------------+-----------------+ | alltests | 0.0% | -0.8% | +0.6% | | five_sec | -0.3% | +0.8% | +0.8% | | high_systime | +0.4% | +2.4% | +2.1% | | new_fserver | +0.1% | +14.1% | +34.2% | | shared | -0.5% | -0.3% | -0.4% | | short | -1.7% | -9.8% | -8.3% | +--------------+---------------+----------------+-----------------+ The short workload is the only one that shows a decline in performance probably due to the spinner locking and queuing overhead. Signed-off-by: Waiman Long <Waiman.Long@hp.com> Reviewed-by: Davidlohr Bueso <davidlohr.bueso@hp.com> Acked-by: Rik van Riel <riel@redhat.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Chandramouleeswaran Aswin <aswin@hp.com> Cc: Norton Scott J <scott.norton@hp.com> Cc: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: David Howells <dhowells@redhat.com> Cc: Dave Jones <davej@redhat.com> Cc: Clark Williams <williams@redhat.com> Cc: Peter Zijlstra <peterz@infradead.org> Link: http://lkml.kernel.org/r/1366226594-5506-4-git-send-email-Waiman.Long@hp.com Signed-off-by: Ingo Molnar <mingo@kernel.org>
2013-04-19mutex: Make more scalable by doing less atomic operationsWaiman Long
In the __mutex_lock_common() function, an initial entry into the lock slow path will cause two atomic_xchg instructions to be issued. Together with the atomic decrement in the fast path, a total of three atomic read-modify-write instructions will be issued in rapid succession. This can cause a lot of cache bouncing when many tasks are trying to acquire the mutex at the same time. This patch will reduce the number of atomic_xchg instructions used by checking the counter value first before issuing the instruction. The atomic_read() function is just a simple memory read. The atomic_xchg() function, on the other hand, can be up to 2 order of magnitude or even more in cost when compared with atomic_read(). By using atomic_read() to check the value first before calling atomic_xchg(), we can avoid a lot of unnecessary cache coherency traffic. The only downside with this change is that a task on the slow path will have a tiny bit less chance of getting the mutex when competing with another task in the fast path. The same is true for the atomic_cmpxchg() function in the mutex-spin-on-owner loop. So an atomic_read() is also performed before calling atomic_cmpxchg(). The mutex locking and unlocking code for the x86 architecture can allow any negative number to be used in the mutex count to indicate that some tasks are waiting for the mutex. I am not so sure if that is the case for the other architectures. So the default is to avoid atomic_xchg() if the count has already been set to -1. For x86, the check is modified to include all negative numbers to cover a larger case. The following table shows the jobs per minutes (JPM) scalability data on an 8-node 80-core Westmere box with a 3.7.10 kernel. The numactl command is used to restrict the running of the high_systime workloads to 1/2/4/8 nodes with hyperthreading on and off. +-----------------+-----------+------------+----------+ | Configuration | Mean JPM | Mean JPM | % Change | | | w/o patch | with patch | | +-----------------+-----------------------------------+ | | User Range 1100 - 2000 | +-----------------+-----------------------------------+ | 8 nodes, HT on | 36980 | 148590 | +301.8% | | 8 nodes, HT off | 42799 | 145011 | +238.8% | | 4 nodes, HT on | 61318 | 118445 | +51.1% | | 4 nodes, HT off | 158481 | 158592 | +0.1% | | 2 nodes, HT on | 180602 | 173967 | -3.7% | | 2 nodes, HT off | 198409 | 198073 | -0.2% | | 1 node , HT on | 149042 | 147671 | -0.9% | | 1 node , HT off | 126036 | 126533 | +0.4% | +-----------------+-----------------------------------+ | | User Range 200 - 1000 | +-----------------+-----------------------------------+ | 8 nodes, HT on | 41525 | 122349 | +194.6% | | 8 nodes, HT off | 49866 | 124032 | +148.7% | | 4 nodes, HT on | 66409 | 106984 | +61.1% | | 4 nodes, HT off | 119880 | 130508 | +8.9% | | 2 nodes, HT on | 138003 | 133948 | -2.9% | | 2 nodes, HT off | 132792 | 131997 | -0.6% | | 1 node , HT on | 116593 | 115859 | -0.6% | | 1 node , HT off | 104499 | 104597 | +0.1% | +-----------------+------------+-----------+----------+ At low user range 10-100, the JPM differences were within +/-1%. So they are not that interesting. AIM7 benchmark run has a pretty large run-to-run variance due to random nature of the subtests executed. So a difference of less than +-5% may not be really significant. This patch improves high_systime workload performance at 4 nodes and up by maintaining transaction rates without significant drop-off at high node count. The patch has practically no impact on 1 and 2 nodes system. The table below shows the percentage time (as reported by perf record -a -s -g) spent on the __mutex_lock_slowpath() function by the high_systime workload at 1500 users for 2/4/8-node configurations with hyperthreading off. +---------------+-----------------+------------------+---------+ | Configuration | %Time w/o patch | %Time with patch | %Change | +---------------+-----------------+------------------+---------+ | 8 nodes | 65.34% | 0.69% | -99% | | 4 nodes | 8.70% | 1.02% | -88% | | 2 nodes | 0.41% | 0.32% | -22% | +---------------+-----------------+------------------+---------+ It is obvious that the dramatic performance improvement at 8 nodes was due to the drastic cut in the time spent within the __mutex_lock_slowpath() function. The table below show the improvements in other AIM7 workloads (at 8 nodes, hyperthreading off). +--------------+---------------+----------------+-----------------+ | Workload | mean % change | mean % change | mean % change | | | 10-100 users | 200-1000 users | 1100-2000 users | +--------------+---------------+----------------+-----------------+ | alltests | +0.6% | +104.2% | +185.9% | | five_sec | +1.9% | +0.9% | +0.9% | | fserver | +1.4% | -7.7% | +5.1% | | new_fserver | -0.5% | +3.2% | +3.1% | | shared | +13.1% | +146.1% | +181.5% | | short | +7.4% | +5.0% | +4.2% | +--------------+---------------+----------------+-----------------+ Signed-off-by: Waiman Long <Waiman.Long@hp.com> Reviewed-by: Davidlohr Bueso <davidlohr.bueso@hp.com> Reviewed-by: Rik van Riel <riel@redhat.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Chandramouleeswaran Aswin <aswin@hp.com> Cc: Norton: Scott J <scott.norton@hp.com> Cc: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: David Howells <dhowells@redhat.com> Cc: Dave Jones <davej@redhat.com> Cc: Clark Williams <williams@redhat.com> Cc: Peter Zijlstra <peterz@infradead.org> Link: http://lkml.kernel.org/r/1366226594-5506-3-git-send-email-Waiman.Long@hp.com Signed-off-by: Ingo Molnar <mingo@kernel.org>
2013-04-19mutex: Move mutex spinning code from sched/core.c back to mutex.cWaiman Long
As mentioned by Ingo, the SCHED_FEAT_OWNER_SPIN scheduler feature bit was really just an early hack to make with/without mutex-spinning testable. So it is no longer necessary. This patch removes the SCHED_FEAT_OWNER_SPIN feature bit and move the mutex spinning code from kernel/sched/core.c back to kernel/mutex.c which is where they should belong. Signed-off-by: Waiman Long <Waiman.Long@hp.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Chandramouleeswaran Aswin <aswin@hp.com> Cc: Davidlohr Bueso <davidlohr.bueso@hp.com> Cc: Norton Scott J <scott.norton@hp.com> Cc: Rik van Riel <riel@redhat.com> Cc: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: David Howells <dhowells@redhat.com> Cc: Dave Jones <davej@redhat.com> Cc: Clark Williams <williams@redhat.com> Cc: Peter Zijlstra <peterz@infradead.org> Link: http://lkml.kernel.org/r/1366226594-5506-2-git-send-email-Waiman.Long@hp.com Signed-off-by: Ingo Molnar <mingo@kernel.org>
2013-02-07sched/rt: Move rt specific bits into new header fileClark Williams
Move rt scheduler definitions out of include/linux/sched.h into new file include/linux/sched/rt.h Signed-off-by: Clark Williams <williams@redhat.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Steven Rostedt <rostedt@goodmis.org> Link: http://lkml.kernel.org/r/20130207094707.7b9f825f@riff.lan Signed-off-by: Ingo Molnar <mingo@kernel.org>
2012-03-01sched/rt: Use schedule_preempt_disabled()Thomas Gleixner
Coccinelle based conversion. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Link: http://lkml.kernel.org/n/tip-24swm5zut3h9c4a6s46x8rws@git.kernel.org Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-10-31kernel: Map most files to use export.h instead of module.hPaul Gortmaker
The changed files were only including linux/module.h for the EXPORT_SYMBOL infrastructure, and nothing else. Revector them onto the isolated export header for faster compile times. Nothing to see here but a whole lot of instances of: -#include <linux/module.h> +#include <linux/export.h> This commit is only changing the kernel dir; next targets will probably be mm, fs, the arch dirs, etc. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2011-05-25lockdep, mutex: provide mutex_lock_nest_lockPeter Zijlstra
In order to convert i_mmap_lock to a mutex we need a mutex equivalent to spin_lock_nest_lock(), thus provide the mutex_lock_nest_lock() annotation. As with spin_lock_nest_lock(), mutex_lock_nest_lock() allows annotation of the locking pattern where an outer lock serializes the acquisition order of nested locks. That is, if every time you lock multiple locks A, say A1 and A2 you first acquire N, the order of acquiring A1 and A2 is irrelevant. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: David Miller <davem@davemloft.net> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Russell King <rmk@arm.linux.org.uk> Cc: Paul Mundt <lethal@linux-sh.org> Cc: Jeff Dike <jdike@addtoit.com> Cc: Richard Weinberger <richard@nod.at> Cc: Tony Luck <tony.luck@intel.com> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Hugh Dickins <hughd@google.com> Cc: Mel Gorman <mel@csn.ul.ie> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Nick Piggin <npiggin@kernel.dk> Cc: Namhyung Kim <namhyung@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-04-24sched: Get rid of lock_depthJonathan Corbet
Neil Brown pointed out that lock_depth somehow escaped the BKL removal work. Let's get rid of it now. Note that the perf scripting utilities still have a bunch of code for dealing with common_lock_depth in tracepoints; I have left that in place in case anybody wants to use that code with older kernels. Suggested-by: Neil Brown <neilb@suse.de> Signed-off-by: Jonathan Corbet <corbet@lwn.net> Cc: Arnd Bergmann <arnd@arndb.de> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Andrew Morton <akpm@linux-foundation.org> Link: http://lkml.kernel.org/r/20110422111910.456c0e84@bike.lwn.net Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-04-14mutex: Use p->on_cpu for the adaptive spinPeter Zijlstra
Since we now have p->on_cpu unconditionally available, use it to re-implement mutex_spin_on_owner. Requested-by: Thomas Gleixner <tglx@linutronix.de> Reviewed-by: Frank Rowand <frank.rowand@am.sony.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Nick Piggin <npiggin@kernel.dk> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Link: http://lkml.kernel.org/r/20110405152728.826338173@chello.nl
2010-11-26mutexes, sched: Introduce arch_mutex_cpu_relax()Gerald Schaefer
The spinning mutex implementation uses cpu_relax() in busy loops as a compiler barrier. Depending on the architecture, cpu_relax() may do more than needed in this specific mutex spin loops. On System z we also give up the time slice of the virtual cpu in cpu_relax(), which prevents effective spinning on the mutex. This patch replaces cpu_relax() in the spinning mutex code with arch_mutex_cpu_relax(), which can be defined by each architecture that selects HAVE_ARCH_MUTEX_CPU_RELAX. The default is still cpu_relax(), so this patch should not affect other architectures than System z for now. Signed-off-by: Gerald Schaefer <gerald.schaefer@de.ibm.com> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> LKML-Reference: <1290437256.7455.4.camel@thinkpad> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-09-03mutex: Fix annotations to include it in kernel-locking docbookRandy Dunlap
Fix kernel-doc notation in linux/mutex.h and kernel/mutex.c, then add these 2 files to the kernel-locking docbook as the Mutex API reference chapter. Add one API function to mutex-design.txt and correct a typo in that file. Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Cc: Rusty Russell <rusty@rustcorp.com.au> LKML-Reference: <20100902154816.6cc2f9ad.randy.dunlap@oracle.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-05-19mutex: Fix optimistic spinning vs. BKLTony Breeds
Currently, we can hit a nasty case with optimistic spinning on mutexes: CPU A tries to take a mutex, while holding the BKL CPU B tried to take the BLK while holding the mutex This looks like a AB-BA scenario but in practice, is allowed and happens due to the auto-release on schedule() nature of the BKL. In that case, the optimistic spinning code can get us into a situation where instead of going to sleep, A will spin waiting for B who is spinning waiting for A, and the only way out of that loop is the need_resched() test in mutex_spin_on_owner(). This patch fixes it by completely disabling spinning if we own the BKL. This adds one more detail to the extensive list of reasons why it's a bad idea for kernel code to be holding the BKL. Signed-off-by: Tony Breeds <tony@bakeyournoodle.com> Acked-by: Linus Torvalds <torvalds@linux-foundation.org> Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: <stable@kernel.org> LKML-Reference: <20100519054636.GC12389@ozlabs.org> [ added an unlikely() attribute to the branch ] Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-12-03mutex: Better control mutex adaptive spinning configFrederic Weisbecker
Introduce CONFIG_MUTEX_SPIN_ON_OWNER so that we can centralize in a single place the conditions that determine its definition and use. Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com> Acked-by: Peter Zijlstra <peterz@infradead.org> LKML-Reference: <1259783357-8542-1-git-send-regression-fweisbec@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Cc: Peter Zijlstra <peterz@infradead.org>
2009-06-11Merge branch 'linus' into perfcounters/coreIngo Molnar
Conflicts: arch/x86/kernel/irqinit.c arch/x86/kernel/irqinit_64.c arch/x86/kernel/traps.c arch/x86/mm/fault.c include/linux/sched.h kernel/exit.c
2009-06-10Merge branch 'locking-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'locking-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: spinlock: Add missing __raw_spin_lock_flags() stub for UP mutex: add atomic_dec_and_mutex_lock(), fix locking, rtmutex.c: Documentation cleanup mutex: add atomic_dec_and_mutex_lock()
2009-05-11Merge commit 'v2.6.30-rc5' into sched/coreIngo Molnar
Merge reason: sched/core was on .30-rc1 before, update to latest fixes Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-05-06Merge branch 'core/locking' into perfcounters/coreIngo Molnar
Merge reason: we moved a mutex.h commit that originated from the perfcounters tree into core/locking - but now merge back that branch to solve a merge artifact and to pick up cleanups of this commit that happened in core/locking. Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-04-30mutex: add atomic_dec_and_mutex_lock(), fixAndrew Morton
include/linux/mutex.h:136: warning: 'mutex_lock' declared inline after being called include/linux/mutex.h:136: warning: previous declaration of 'mutex_lock' was here uninline it. [ Impact: clean up and uninline, address compiler warning ] Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Christoph Hellwig <hch@lst.de> Cc: Eric Paris <eparis@redhat.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> LKML-Reference: <200904292318.n3TNIsi6028340@imap1.linux-foundation.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-04-29Merge branch 'linus' into perfcounters/coreIngo Molnar
Merge reason: This brach was on -rc1, refresh it to almost-rc4 to pick up the latest upstream fixes. Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-04-20sched: remove extra call overhead for schedule()Peter Zijlstra
Lai Jiangshan's patch reminded me that I promised Nick to remove that extra call overhead in schedule(). Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> LKML-Reference: <20090313112300.927414207@chello.nl> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-04-09mutex: have non-spinning mutexes on s390 by defaultHeiko Carstens
Impact: performance regression fix for s390 The adaptive spinning mutexes will not always do what one would expect on virtualized architectures like s390. Especially the cpu_relax() loop in mutex_spin_on_owner might hurt if the mutex holding cpu has been scheduled away by the hypervisor. We would end up in a cpu_relax() loop when there is no chance that the state of the mutex changes until the target cpu has been scheduled again by the hypervisor. For that reason we should change the default behaviour to no-spin on s390. We do have an instruction which allows to yield the current cpu in favour of a different target cpu. Also we have an instruction which allows us to figure out if the target cpu is physically backed. However we need to do some performance tests until we can come up with a solution that will do the right thing on s390. Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Christian Borntraeger <borntraeger@de.ibm.com> LKML-Reference: <20090409184834.7a0df7b2@osiris.boeblingen.de.ibm.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-04-06mutex: drop "inline" from mutex_lock() inside kernel/mutex.cH. Peter Anvin
Impact: build fix mutex_lock() is was defined inline in kernel/mutex.c, but wasn't declared so not in <linux/mutex.h>. This didn't cause a problem until checkin 3a2d367d9aabac486ac4444c6c7ec7a1dab16267 added the atomic_dec_and_mutex_lock() inline in between declaration and definion. This broke building with CONFIG_ALLOW_WARNINGS=n, e.g. make allnoconfig. Either from the source code nor the allnoconfig binary output I cannot find any internal references to mutex_lock() in kernel/mutex.c, so presumably this "inline" is now-useless legacy. Cc: Eric Paris <eparis@redhat.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Paul Mackerras <paulus@samba.org> Orig-LKML-Reference: <tip-3a2d367d9aabac486ac4444c6c7ec7a1dab16267@git.kernel.org> Signed-off-by: H. Peter Anvin <hpa@linux.intel.com>
2009-01-14mutex: adaptive spinnning, performance tweaksChris Mason
Spin more agressively. This is less fair but also markedly faster. The numbers: * dbench 50 (higher is better): spin 1282MB/s v10 548MB/s v10 no wait 1868MB/s * 4k creates (numbers in files/second higher is better): spin avg 200.60 median 193.20 std 19.71 high 305.93 low 186.82 v10 avg 180.94 median 175.28 std 13.91 high 229.31 low 168.73 v10 no wait avg 232.18 median 222.38 std 22.91 high 314.66 low 209.12 * File stats (numbers in seconds, lower is better): spin 2.27s v10 5.1s v10 no wait 1.6s ( The source changes are smaller than they look, I just moved the need_resched checks in __mutex_lock_common after the cmpxchg. ) Signed-off-by: Chris Mason <chris.mason@oracle.com> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-01-14mutex: implement adaptive spinningPeter Zijlstra
Change mutex contention behaviour such that it will sometimes busy wait on acquisition - moving its behaviour closer to that of spinlocks. This concept got ported to mainline from the -rt tree, where it was originally implemented for rtmutexes by Steven Rostedt, based on work by Gregory Haskins. Testing with Ingo's test-mutex application (http://lkml.org/lkml/2006/1/8/50) gave a 345% boost for VFS scalability on my testbox: # ./test-mutex-shm V 16 10 | grep "^avg ops" avg ops/sec: 296604 # ./test-mutex-shm V 16 10 | grep "^avg ops" avg ops/sec: 85870 The key criteria for the busy wait is that the lock owner has to be running on a (different) cpu. The idea is that as long as the owner is running, there is a fair chance it'll release the lock soon, and thus we'll be better off spinning instead of blocking/scheduling. Since regular mutexes (as opposed to rtmutexes) do not atomically track the owner, we add the owner in a non-atomic fashion and deal with the races in the slowpath. Furthermore, to ease the testing of the performance impact of this new code, there is means to disable this behaviour runtime (without having to reboot the system), when scheduler debugging is enabled (CONFIG_SCHED_DEBUG=y), by issuing the following command: # echo NO_OWNER_SPIN > /debug/sched_features This command re-enables spinning again (this is also the default): # echo OWNER_SPIN > /debug/sched_features Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-01-14mutex: preemption fixesPeter Zijlstra
The problem is that dropping the spinlock right before schedule is a voluntary preemption point and can cause a schedule, right after which we schedule again. Fix this inefficiency by keeping preemption disabled until we schedule, do this by explicity disabling preemption and providing a schedule() variant that assumes preemption is already disabled. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-01-14mutex: small cleanupPeter Zijlstra
Remove a local variable by combining an assingment and test in one. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-11-24mutex: __used is needed for function referenced only from inline asmTörök Edwin
Impact: fix build failure on llvm-gcc-4.2 According to the gcc manual, the 'used' attribute should be applied to functions referenced only from inline assembly. This fixes a build failure with llvm-gcc-4.2, which deleted __mutex_lock_slowpath, __mutex_unlock_slowpath. Signed-off-by: Török Edwin <edwintorok@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-10-20lockstat: contend with pointsPeter Zijlstra
We currently only provide points that have to wait on contention, also lists the points we have to wait for. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-07-28locking: fix mutex @key parameter kernel-doc notationRandy Dunlap
Fix @key parameter to mutex_init() and one of its callers. Warning(linux-2.6.26-git11//drivers/base/class.c:210): No description found for parameter 'key' Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Acked-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-06-10__mutex_lock_common: use signal_pending_state()Oleg Nesterov
Change __mutex_lock_common() to use signal_pending_state() for the sake of the code re-use. This adds 7 bytes to kernel/mutex.o, but afaics only because gcc isn't smart enough. (btw, uninlining of __mutex_lock_common() shrinks .text from 2722 to 1542, perhaps it is worth doing). Signed-off-by: Oleg Nesterov <oleg@tv-sign.ru> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-02-08kernel: remove fastcall in kernel/*Harvey Harrison
[akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Acked-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-12-06Add mutex_lock_killableLiam R. Howlett
Similar to mutex_lock_interruptible, it can be interrupted by a fatal signal only. Signed-off-by: Liam R. Howlett <howlett@gmail.com> Acked-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Matthew Wilcox <willy@linux.intel.com>
2007-10-11lockdep: fixup mutex annotationsPeter Zijlstra
The fancy mutex_lock fastpath has too many indirections to track the caller hence all contentions are perceived to come from mutex_lock(). Avoid this by explicitly not using the fastpath code (it was disabled already anyway). Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2007-07-19lockstat: measure lock bouncingPeter Zijlstra
__acquire | lock _____ | \ | __contended | | | wait | _______/ |/ | __acquired | __release | unlock We measure acquisition and contention bouncing. This is done by recording a cpu stamp in each lock instance. Contention bouncing requires the cpu stamp to be set on acquisition. Hence we move __acquired into the generic path. __acquired is then used to measure acquisition bouncing by comparing the current cpu with the old stamp before replacing it. __contended is used to measure contention bouncing (only useful for preemptable locks) [akpm@linux-foundation.org: cleanups] Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Acked-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-19lockstat: hook into spinlock_t, rwlock_t, rwsem and mutexPeter Zijlstra
Call the new lockstat tracking functions from the various lock primitives. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Acked-by: Ingo Molnar <mingo@elte.hu> Acked-by: Jason Baron <jbaron@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-09wrap access to thread_infoRoman Zippel
Recently a few direct accesses to the thread_info in the task structure snuck back, so this wraps them with the appropriate wrapper. Signed-off-by: Roman Zippel <zippel@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-12-08[PATCH] lockdep: avoid lockdep warning in mdNeilBrown
md_open takes ->reconfig_mutex which causes lockdep to complain. This (normally) doesn't have deadlock potential as the possible conflict is with a reconfig_mutex in a different device. I say "normally" because if a loop were created in the array->member hierarchy a deadlock could happen. However that causes bigger problems than a deadlock and should be fixed independently. So we flag the lock in md_open as a nested lock. This requires defining mutex_lock_interruptible_nested. Cc: Ingo Molnar <mingo@elte.hu> Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Acked-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-03[PATCH] lockdep: prove mutex locking correctnessIngo Molnar
Use the lock validator framework to prove mutex locking correctness. Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-03[PATCH] lockdep: mutex section binutils workaroundIngo Molnar
Work around weird section nesting build bug causing smp-alternatives failures under certain circumstances. Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-03[PATCH] lockdep: better lock debuggingIngo Molnar
Generic lock debugging: - generalized lock debugging framework. For example, a bug in one lock subsystem turns off debugging in all lock subsystems. - got rid of the caller address passing (__IP__/__IP_DECL__/etc.) from the mutex/rtmutex debugging code: it caused way too much prototype hackery, and lockdep will give the same information anyway. - ability to do silent tests - check lock freeing in vfree too. - more finegrained debugging options, to allow distributions to turn off more expensive debugging features. There's no separate 'held mutexes' list anymore - but there's a 'held locks' stack within lockdep, which unifies deadlock detection across all lock classes. (this is independent of the lockdep validation stuff - lockdep first checks whether we are holding a lock already) Here are the current debugging options: CONFIG_DEBUG_MUTEXES=y CONFIG_DEBUG_LOCK_ALLOC=y which do: config DEBUG_MUTEXES bool "Mutex debugging, basic checks" config DEBUG_LOCK_ALLOC bool "Detect incorrect freeing of live mutexes" Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-03[PATCH] lockdep: rename DEBUG_WARN_ON()Ingo Molnar
Rename DEBUG_WARN_ON() to the less generic DEBUG_LOCKS_WARN_ON() name, so that it's clear that this is a lock-debugging internal mechanism. Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-26[PATCH] work around ppc64 bootup bug by making mutex-debugging save/restore irqsIngo Molnar
It seems ppc64 wants to lock mutexes in early bootup code, with interrupts disabled, and they expect interrupts to stay disabled, else they crash. Work around this bug by making mutex debugging variants save/restore irq flags. Signed-off-by: Ingo Molnar <mingo@elte.hu> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mackerras <paulus@samba.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-10[PATCH] mutex: trivial whitespace cleanupsIngo Molnar
Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-10[PATCH] mark mutex_lock*() as might_sleep()Ingo Molnar
Mark mutex_lock() and mutex_lock_interruptible() as might_sleep() functions. Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-10[PATCH] fix i386 mutex fastpath on FRAME_POINTER && !DEBUG_MUTEXESIngo Molnar
Call the mutex slowpath more conservatively - e.g. FRAME_POINTERS can change the calling convention, in which case a direct branch to the slowpath becomes illegal. Bug found by Hugh Dickins. Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-09[PATCH] mutex subsystem, coreIngo Molnar
mutex implementation, core files: just the basic subsystem, no users of it. Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Arjan van de Ven <arjan@infradead.org>
