path: root/kernel/pid.c
2017-08-24pids: make task_tgid_nr_ns() safeOleg Nesterov
commit dd1c1f2f2028a7b851f701fc6a8ebe39dcb95e7c upstream. This was reported many times, and this was even mentioned in commit 52ee2dfdd4f5 ("pids: refactor vnr/nr_ns helpers to make them safe") but somehow nobody bothered to fix the obvious problem: task_tgid_nr_ns() is not safe because task->group_leader points to nowhere after the exiting task passes exit_notify(), rcu_read_lock() can not help. We really need to change __unhash_process() to nullify group_leader, parent, and real_parent, but this needs some cleanups. Until then we can turn task_tgid_nr_ns() into another user of __task_pid_nr_ns() and fix the problem. Reported-by: Troy Kensinger <tkensinger@google.com> Signed-off-by: Oleg Nesterov <oleg@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-11-24pidns: fix NULL dereference in __task_pid_nr_ns()Eric Dumazet
I got a crash during a "perf top" session that was caused by a race in __task_pid_nr_ns() : pid_nr_ns() was inlined, but apparently compiler chose to read task->pids[type].pid twice, and the pid->level dereference crashed because we got a NULL pointer at the second read : if (pid && ns->level <= pid->level) { // CRASH Just use RCU API properly to solve this race, and not worry about "perf top" crashing hosts :( get_task_pid() can benefit from same fix. Signed-off-by: Eric Dumazet <edumazet@google.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-07-22rcu: Rename rcu_lockdep_assert() to RCU_LOCKDEP_WARN()Paul E. McKenney
This commit renames rcu_lockdep_assert() to RCU_LOCKDEP_WARN() for consistency with the WARN() series of macros. This also requires inverting the sense of the conditional, which this commit also does. Reported-by: Ingo Molnar <mingo@kernel.org> Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Reviewed-by: Ingo Molnar <mingo@kernel.org>
2015-04-17fork: report pid reservation failure properlyMichal Hocko
copy_process will report any failure in alloc_pid as ENOMEM currently which is misleading because the pid allocation might fail not only when the memory is short but also when the pid space is consumed already. The current man page even mentions this case: : EAGAIN : : A system-imposed limit on the number of threads was encountered. : There are a number of limits that may trigger this error: the : RLIMIT_NPROC soft resource limit (set via setrlimit(2)), which : limits the number of processes and threads for a real user ID, was : reached; the kernel's system-wide limit on the number of processes : and threads, /proc/sys/kernel/threads-max, was reached (see : proc(5)); or the maximum number of PIDs, /proc/sys/kernel/pid_max, : was reached (see proc(5)). so the current behavior is also incorrect wrt. documentation. POSIX man page also suggest returing EAGAIN when the process count limit is reached. This patch simply propagates error code from alloc_pid and makes sure we return -EAGAIN due to reservation failure. This will make behavior of fork closer to both our documentation and POSIX. alloc_pid might alsoo fail when the reaper in the pid namespace is dead (the namespace basically disallows all new processes) and there is no good error code which would match documented ones. We have traditionally returned ENOMEM for this case which is misleading as well but as per Eric W. Biederman this behavior is documented in man pid_namespaces(7) : If the "init" process of a PID namespace terminates, the kernel : terminates all of the processes in the namespace via a SIGKILL signal. : This behavior reflects the fact that the "init" process is essential for : the correct operation of a PID namespace. In this case, a subsequent : fork(2) into this PID namespace will fail with the error ENOMEM; it is : not possible to create a new processes in a PID namespace whose "init" : process has terminated. and introducing a new error code would be too risky so let's stick to ENOMEM for this case. Signed-off-by: Michal Hocko <mhocko@suse.cz> Cc: Oleg Nesterov <oleg@redhat.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Michael Kerrisk <mtk.manpages@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-12-16Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull vfs pile #2 from Al Viro: "Next pile (and there'll be one or two more). The large piece in this one is getting rid of /proc/*/ns/* weirdness; among other things, it allows to (finally) make nameidata completely opaque outside of fs/namei.c, making for easier further cleanups in there" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: coda_venus_readdir(): use file_inode() fs/namei.c: fold link_path_walk() call into path_init() path_init(): don't bother with LOOKUP_PARENT in argument fs/namei.c: new helper (path_cleanup()) path_init(): store the "base" pointer to file in nameidata itself make default ->i_fop have ->open() fail with ENXIO make nameidata completely opaque outside of fs/namei.c kill proc_ns completely take the targets of /proc/*/ns/* symlinks to separate fs bury struct proc_ns in fs/proc copy address of proc_ns_ops into ns_common new helpers: ns_alloc_inum/ns_free_inum make proc_ns_operations work with struct ns_common * instead of void * switch the rest of proc_ns_operations to working with &...->ns netns: switch ->get()/->put()/->install()/->inum() to working with &net->ns make mntns ->get()/->put()/->install()/->inum() work with &mnt_ns->ns common object embedded into various struct ....ns
2014-12-10exit: pidns: alloc_pid() leaks pid_namespace if child_reaper is exitingOleg Nesterov
alloc_pid() does get_pid_ns() beforehand but forgets to put_pid_ns() if it fails because disable_pid_allocation() was called by the exiting child_reaper. We could simply move get_pid_ns() down to successful return, but this fix tries to be as trivial as possible. Signed-off-by: Oleg Nesterov <oleg@redhat.com> Reviewed-by: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Aaron Tomlin <atomlin@redhat.com> Cc: Pavel Emelyanov <xemul@parallels.com> Cc: Serge Hallyn <serge.hallyn@ubuntu.com> Cc: Sterling Alexander <stalexan@redhat.com> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-12-04copy address of proc_ns_ops into ns_commonAl Viro
2014-12-04common object embedded into various struct ....nsAl Viro
for now - just move corresponding ->proc_inum instances over there Acked-by: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2013-09-30pidns: fix free_pid() to handle the first fork failureOleg Nesterov
"case 0" in free_pid() assumes that disable_pid_allocation() should clear PIDNS_HASH_ADDING before the last pid goes away. However this doesn't happen if the first fork() fails to create the child reaper which should call disable_pid_allocation(). Signed-off-by: Oleg Nesterov <oleg@redhat.com> Reviewed-by: "Eric W. Biederman" <ebiederm@xmission.com> Cc: "Serge E. Hallyn" <serge@hallyn.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-08-30pidns: Fix hang in zap_pid_ns_processes by sending a potentially extra wakeupEric W. Biederman
Serge Hallyn <serge.hallyn@ubuntu.com> writes: > Since commit af4b8a83add95ef40716401395b44a1b579965f4 it's been > possible to get into a situation where a pidns reaper is > <defunct>, reparented to host pid 1, but never reaped. How to > reproduce this is documented at > > https://bugs.launchpad.net/ubuntu/+source/lxc/+bug/1168526 > (and see > https://bugs.launchpad.net/ubuntu/+source/lxc/+bug/1168526/comments/13) > In short, run repeated starts of a container whose init is > > Process.exit(0); > > sysrq-t when such a task is playing zombie shows: > > [ 131.132978] init x ffff88011fc14580 0 2084 2039 0x00000000 > [ 131.132978] ffff880116e89ea8 0000000000000002 ffff880116e89fd8 0000000000014580 > [ 131.132978] ffff880116e89fd8 0000000000014580 ffff8801172a0000 ffff8801172a0000 > [ 131.132978] ffff8801172a0630 ffff88011729fff0 ffff880116e14650 ffff88011729fff0 > [ 131.132978] Call Trace: > [ 131.132978] [<ffffffff816f6159>] schedule+0x29/0x70 > [ 131.132978] [<ffffffff81064591>] do_exit+0x6e1/0xa40 > [ 131.132978] [<ffffffff81071eae>] ? signal_wake_up_state+0x1e/0x30 > [ 131.132978] [<ffffffff8106496f>] do_group_exit+0x3f/0xa0 > [ 131.132978] [<ffffffff810649e4>] SyS_exit_group+0x14/0x20 > [ 131.132978] [<ffffffff8170102f>] tracesys+0xe1/0xe6 > > Further debugging showed that every time this happened, zap_pid_ns_processes() > started with nr_hashed being 3, while we were expecting it to drop to 2. > Any time it didn't happen, nr_hashed was 1 or 2. So the reaper was > waiting for nr_hashed to become 2, but free_pid() only wakes the reaper > if nr_hashed hits 1. The issue is that when the task group leader of an init process exits before other tasks of the init process when the init process finally exits it will be a secondary task sleeping in zap_pid_ns_processes and waiting to wake up when the number of hashed pids drops to two. This case waits forever as free_pid only sends a wake up when the number of hashed pids drops to 1. To correct this the simple strategy of sending a possibly unncessary wake up when the number of hashed pids drops to 2 is adopted. Sending one extraneous wake up is relatively harmless, at worst we waste a little cpu time in the rare case when a pid namespace appropaches exiting. We can detect the case when the pid namespace drops to just two pids hashed race free in free_pid. Dereferencing pid_ns->child_reaper with the pidmap_lock held is safe without out the tasklist_lock because it is guaranteed that the detach_pid will be called on the child_reaper before it is freed and detach_pid calls __change_pid which calls free_pid which takes the pidmap_lock. __change_pid only calls free_pid if this is the last use of the pid. For a thread that is not the thread group leader the threads pid will only ever have one user because a threads pid is not allowed to be the pid of a process, of a process group or a session. For a thread that is a thread group leader all of the other threads of that process will be reaped before it is allowed for the thread group leader to be reaped ensuring there will only be one user of the threads pid as a process pid. Furthermore because the thread is the init process of a pid namespace all of the other processes in the pid namespace will have also been already freed leading to the fact that the pid will not be used as a session pid or a process group pid for any other running process. CC: stable@vger.kernel.org Acked-by: Serge Hallyn <serge.hallyn@canonical.com> Tested-by: Serge Hallyn <serge.hallyn@canonical.com> Reported-by: Serge Hallyn <serge.hallyn@ubuntu.com> Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com>
2013-07-03kernel/pid.c: move statementRaphael S. Carvalho
Move statement to static initilization of init_pid_ns. Signed-off-by: Raphael S. Carvalho <raphael.scarv@gmail.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Acked-by: Serge Hallyn <serge.hallyn@canonical.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-07-03kernel/fork.c:copy_process(): don't add the uninitialized child to ↵Oleg Nesterov
thread/task/pid lists copy_process() adds the new child to thread_group/init_task.tasks list and then does attach_pid(child, PIDTYPE_PID). This means that the lockless next_thread() or next_task() can see this thread with the wrong pid. Say, "ls /proc/pid/task" can list the same inode twice. We could move attach_pid(child, PIDTYPE_PID) up, but in this case find_task_by_vpid() can find the new thread before it was fully initialized. And this is already true for PIDTYPE_PGID/PIDTYPE_SID, With this patch copy_process() initializes child->pids[*].pid first, then calls attach_pid() to insert the task into the pid->tasks list. attach_pid() no longer need the "struct pid*" argument, it is always called after pid_link->pid was already set. Signed-off-by: Oleg Nesterov <oleg@redhat.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Michal Hocko <mhocko@suse.cz> Cc: Pavel Emelyanov <xemul@parallels.com> Cc: Sergey Dyasly <dserrg@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-05-01Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull VFS updates from Al Viro, Misc cleanups all over the place, mainly wrt /proc interfaces (switch create_proc_entry to proc_create(), get rid of the deprecated create_proc_read_entry() in favor of using proc_create_data() and seq_file etc). 7kloc removed. * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (204 commits) don't bother with deferred freeing of fdtables proc: Move non-public stuff from linux/proc_fs.h to fs/proc/internal.h proc: Make the PROC_I() and PDE() macros internal to procfs proc: Supply a function to remove a proc entry by PDE take cgroup_open() and cpuset_open() to fs/proc/base.c ppc: Clean up scanlog ppc: Clean up rtas_flash driver somewhat hostap: proc: Use remove_proc_subtree() drm: proc: Use remove_proc_subtree() drm: proc: Use minor->index to label things, not PDE->name drm: Constify drm_proc_list[] zoran: Don't print proc_dir_entry data in debug reiserfs: Don't access the proc_dir_entry in r_open(), r_start() r_show() proc: Supply an accessor for getting the data from a PDE's parent airo: Use remove_proc_subtree() rtl8192u: Don't need to save device proc dir PDE rtl8187se: Use a dir under /proc/net/r8180/ proc: Add proc_mkdir_data() proc: Move some bits from linux/proc_fs.h to linux/{of.h,signal.h,tty.h} proc: Move PDE_NET() to fs/proc/proc_net.c ...
2013-05-01proc: Split the namespace stuff out into linux/proc_ns.hDavid Howells
Split the proc namespace stuff out into linux/proc_ns.h. Signed-off-by: David Howells <dhowells@redhat.com> cc: netdev@vger.kernel.org cc: Serge E. Hallyn <serge.hallyn@ubuntu.com> cc: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2013-04-30pid_namespace.c/.h: simplify definesRaphael S.Carvalho
Move BITS_PER_PAGE from pid_namespace.c to pid_namespace.h, since we can simplify the define PID_MAP_ENTRIES by using the BITS_PER_PAGE. [akpm@linux-foundation.org: kernel/pid.c:54:1: warning: "BITS_PER_PAGE" redefined] Signed-off-by: Raphael S.Carvalho <raphael.scarv@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-04-30kernel/pid.c: improve flow of a loop inside alloc_pidmap.Raphael S. Carvalho
find_next_offset() searches for an available "cleaned bit" in the respective pid bitmap (page), so returns the offset if found, otherwise it returns a value equals to BITS_PER_PAGE. For example, suppose find_next_offset didn't find any available bit, so there's no purpose to call mk_pid (Wasteful Cpu Cycles). Therefore, I found it could be better to call mk_pid after the checking (offset < BITS_PER_PAGE) returned sucessfully! Another point: If (offset < BITS_PER_PAGE) results in a "failure", then mk_pid would be called again afterwards. [akpm@linux-foundation.org: simplify code] Signed-off-by: Raphael S. Carvalho <raphael.scarv@gmail.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Serge Hallyn <serge.hallyn@canonical.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-02-27hlist: drop the node parameter from iteratorsSasha Levin
I'm not sure why, but the hlist for each entry iterators were conceived list_for_each_entry(pos, head, member) The hlist ones were greedy and wanted an extra parameter: hlist_for_each_entry(tpos, pos, head, member) Why did they need an extra pos parameter? I'm not quite sure. Not only they don't really need it, it also prevents the iterator from looking exactly like the list iterator, which is unfortunate. Besides the semantic patch, there was some manual work required: - Fix up the actual hlist iterators in linux/list.h - Fix up the declaration of other iterators based on the hlist ones. - A very small amount of places were using the 'node' parameter, this was modified to use 'obj->member' instead. - Coccinelle didn't handle the hlist_for_each_entry_safe iterator properly, so those had to be fixed up manually. The semantic patch which is mostly the work of Peter Senna Tschudin is here: @@ iterator name hlist_for_each_entry, hlist_for_each_entry_continue, hlist_for_each_entry_from, hlist_for_each_entry_rcu, hlist_for_each_entry_rcu_bh, hlist_for_each_entry_continue_rcu_bh, for_each_busy_worker, ax25_uid_for_each, ax25_for_each, inet_bind_bucket_for_each, sctp_for_each_hentry, sk_for_each, sk_for_each_rcu, sk_for_each_from, sk_for_each_safe, sk_for_each_bound, hlist_for_each_entry_safe, hlist_for_each_entry_continue_rcu, nr_neigh_for_each, nr_neigh_for_each_safe, nr_node_for_each, nr_node_for_each_safe, for_each_gfn_indirect_valid_sp, for_each_gfn_sp, for_each_host; type T; expression a,c,d,e; identifier b; statement S; @@ -T b; <+... when != b ( hlist_for_each_entry(a, - b, c, d) S | hlist_for_each_entry_continue(a, - b, c) S | hlist_for_each_entry_from(a, - b, c) S | hlist_for_each_entry_rcu(a, - b, c, d) S | hlist_for_each_entry_rcu_bh(a, - b, c, d) S | hlist_for_each_entry_continue_rcu_bh(a, - b, c) S | for_each_busy_worker(a, c, - b, d) S | ax25_uid_for_each(a, - b, c) S | ax25_for_each(a, - b, c) S | inet_bind_bucket_for_each(a, - b, c) S | sctp_for_each_hentry(a, - b, c) S | sk_for_each(a, - b, c) S | sk_for_each_rcu(a, - b, c) S | sk_for_each_from -(a, b) +(a) S + sk_for_each_from(a) S | sk_for_each_safe(a, - b, c, d) S | sk_for_each_bound(a, - b, c) S | hlist_for_each_entry_safe(a, - b, c, d, e) S | hlist_for_each_entry_continue_rcu(a, - b, c) S | nr_neigh_for_each(a, - b, c) S | nr_neigh_for_each_safe(a, - b, c, d) S | nr_node_for_each(a, - b, c) S | nr_node_for_each_safe(a, - b, c, d) S | - for_each_gfn_sp(a, c, d, b) S + for_each_gfn_sp(a, c, d) S | - for_each_gfn_indirect_valid_sp(a, c, d, b) S + for_each_gfn_indirect_valid_sp(a, c, d) S | for_each_host(a, - b, c) S | for_each_host_safe(a, - b, c, d) S | for_each_mesh_entry(a, - b, c, d) S ) ...+> [akpm@linux-foundation.org: drop bogus change from net/ipv4/raw.c] [akpm@linux-foundation.org: drop bogus hunk from net/ipv6/raw.c] [akpm@linux-foundation.org: checkpatch fixes] [akpm@linux-foundation.org: fix warnings] [akpm@linux-foudnation.org: redo intrusive kvm changes] Tested-by: Peter Senna Tschudin <peter.senna@gmail.com> Acked-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Signed-off-by: Sasha Levin <sasha.levin@oracle.com> Cc: Wu Fengguang <fengguang.wu@intel.com> Cc: Marcelo Tosatti <mtosatti@redhat.com> Cc: Gleb Natapov <gleb@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-02-12kernel/pid.c: reenable interrupts when alloc_pid() fails because init has exitedEric W. Biederman
We're forgetting to reenable local interrupts on an error path. Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com> Reported-by: Josh Boyer <jwboyer@redhat.com> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-12-25pidns: Stop pid allocation when init diesEric W. Biederman
Oleg pointed out that in a pid namespace the sequence. - pid 1 becomes a zombie - setns(thepidns), fork,... - reaping pid 1. - The injected processes exiting. Can lead to processes attempting access their child reaper and instead following a stale pointer. That waitpid for init can return before all of the processes in the pid namespace have exited is also unfortunate. Avoid these problems by disabling the allocation of new pids in a pid namespace when init dies, instead of when the last process in a pid namespace is reaped. Pointed-out-by: Oleg Nesterov <oleg@redhat.com> Reviewed-by: Oleg Nesterov <oleg@redhat.com> Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com>
2012-12-17Merge branch 'akpm' (Andrew's patch-bomb)Linus Torvalds
Merge misc patches from Andrew Morton: "Incoming: - lots of misc stuff - backlight tree updates - lib/ updates - Oleg's percpu-rwsem changes - checkpatch - rtc - aoe - more checkpoint/restart support I still have a pile of MM stuff pending - Pekka should be merging later today after which that is good to go. A number of other things are twiddling thumbs awaiting maintainer merges." * emailed patches from Andrew Morton <akpm@linux-foundation.org>: (180 commits) scatterlist: don't BUG when we can trivially return a proper error. docs: update documentation about /proc/<pid>/fdinfo/<fd> fanotify output fs, fanotify: add @mflags field to fanotify output docs: add documentation about /proc/<pid>/fdinfo/<fd> output fs, notify: add procfs fdinfo helper fs, exportfs: add exportfs_encode_inode_fh() helper fs, exportfs: escape nil dereference if no s_export_op present fs, epoll: add procfs fdinfo helper fs, eventfd: add procfs fdinfo helper procfs: add ability to plug in auxiliary fdinfo providers tools/testing/selftests/kcmp/kcmp_test.c: print reason for failure in kcmp_test breakpoint selftests: print failure status instead of cause make error kcmp selftests: print fail status instead of cause make error kcmp selftests: make run_tests fix mem-hotplug selftests: print failure status instead of cause make error cpu-hotplug selftests: print failure status instead of cause make error mqueue selftests: print failure status instead of cause make error vm selftests: print failure status instead of cause make error ubifs: use prandom_bytes mtd: nandsim: use prandom_bytes ...
2012-12-17pidns: remove unused is_container_init()Gao feng
Since commit 1cdcbec1a337 ("CRED: Neuter sys_capset()") is_container_init() has no callers. Signed-off-by: Gao feng <gaofeng@cn.fujitsu.com> Cc: David Howells <dhowells@redhat.com> Acked-by: Serge Hallyn <serge.hallyn@canonical.com> Cc: James Morris <jmorris@namei.org> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-12-17Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/ebiederm/user-namespace Pull user namespace changes from Eric Biederman: "While small this set of changes is very significant with respect to containers in general and user namespaces in particular. The user space interface is now complete. This set of changes adds support for unprivileged users to create user namespaces and as a user namespace root to create other namespaces. The tyranny of supporting suid root preventing unprivileged users from using cool new kernel features is broken. This set of changes completes the work on setns, adding support for the pid, user, mount namespaces. This set of changes includes a bunch of basic pid namespace cleanups/simplifications. Of particular significance is the rework of the pid namespace cleanup so it no longer requires sending out tendrils into all kinds of unexpected cleanup paths for operation. At least one case of broken error handling is fixed by this cleanup. The files under /proc/<pid>/ns/ have been converted from regular files to magic symlinks which prevents incorrect caching by the VFS, ensuring the files always refer to the namespace the process is currently using and ensuring that the ptrace_mayaccess permission checks are always applied. The files under /proc/<pid>/ns/ have been given stable inode numbers so it is now possible to see if different processes share the same namespaces. Through the David Miller's net tree are changes to relax many of the permission checks in the networking stack to allowing the user namespace root to usefully use the networking stack. Similar changes for the mount namespace and the pid namespace are coming through my tree. Two small changes to add user namespace support were commited here adn in David Miller's -net tree so that I could complete the work on the /proc/<pid>/ns/ files in this tree. Work remains to make it safe to build user namespaces and 9p, afs, ceph, cifs, coda, gfs2, ncpfs, nfs, nfsd, ocfs2, and xfs so the Kconfig guard remains in place preventing that user namespaces from being built when any of those filesystems are enabled. Future design work remains to allow root users outside of the initial user namespace to mount more than just /proc and /sys." * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/ebiederm/user-namespace: (38 commits) proc: Usable inode numbers for the namespace file descriptors. proc: Fix the namespace inode permission checks. proc: Generalize proc inode allocation userns: Allow unprivilged mounts of proc and sysfs userns: For /proc/self/{uid,gid}_map derive the lower userns from the struct file procfs: Print task uids and gids in the userns that opened the proc file userns: Implement unshare of the user namespace userns: Implent proc namespace operations userns: Kill task_user_ns userns: Make create_new_namespaces take a user_ns parameter userns: Allow unprivileged use of setns. userns: Allow unprivileged users to create new namespaces userns: Allow setting a userns mapping to your current uid. userns: Allow chown and setgid preservation userns: Allow unprivileged users to create user namespaces. userns: Ignore suid and sgid on binaries if the uid or gid can not be mapped userns: fix return value on mntns_install() failure vfs: Allow unprivileged manipulation of the mount namespace. vfs: Only support slave subtrees across different user namespaces vfs: Add a user namespace reference from struct mnt_namespace ...
2012-12-06propagate name change to comments in kernel sourceNadia Yvette Chambers
I've legally changed my name with New York State, the US Social Security Administration, et al. This patch propagates the name change and change in initials and login to comments in the kernel source as well. Signed-off-by: Nadia Yvette Chambers <nyc@holomorphy.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2012-11-20proc: Usable inode numbers for the namespace file descriptors.Eric W. Biederman
Assign a unique proc inode to each namespace, and use that inode number to ensure we only allocate at most one proc inode for every namespace in proc. A single proc inode per namespace allows userspace to test to see if two processes are in the same namespace. This has been a long requested feature and only blocked because a naive implementation would put the id in a global space and would ultimately require having a namespace for the names of namespaces, making migration and certain virtualization tricks impossible. We still don't have per superblock inode numbers for proc, which appears necessary for application unaware checkpoint/restart and migrations (if the application is using namespace file descriptors) but that is now allowd by the design if it becomes important. I have preallocated the ipc and uts initial proc inode numbers so their structures can be statically initialized. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com>
2012-11-19pidns: Wait in zap_pid_ns_processes until pid_ns->nr_hashed == 1Eric W. Biederman
Looking at pid_ns->nr_hashed is a bit simpler and it works for disjoint process trees that an unshare or a join of a pid_namespace may create. Acked-by: "Serge E. Hallyn" <serge@hallyn.com> Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com>
2012-11-19pidns: Don't allow new processes in a dead pid namespace.Eric W. Biederman
Set nr_hashed to -1 just before we schedule the work to cleanup proc. Test nr_hashed just before we hash a new pid and if nr_hashed is < 0 fail. This guaranteees that processes never enter a pid namespaces after we have cleaned up the state to support processes in a pid namespace. Currently sending SIGKILL to all of the process in a pid namespace as init exists gives us this guarantee but we need something a little stronger to support unsharing and joining a pid namespace. Acked-by: "Serge E. Hallyn" <serge@hallyn.com> Signed-off-by: Eric W. Biederman <ebiederm@xmission.com>
2012-11-19pidns: Make the pidns proc mount/umount logic obvious.Eric W. Biederman
Track the number of pids in the proc hash table. When the number of pids goes to 0 schedule work to unmount the kernel mount of proc. Move the mount of proc into alloc_pid when we allocate the pid for init. Remove the surprising calls of pid_ns_release proc in fork and proc_flush_task. Those code paths really shouldn't know about proc namespace implementation details and people have demonstrated several times that finding and understanding those code paths is difficult and non-obvious. Because of the call path detach pid is alwasy called with the rtnl_lock held free_pid is not allowed to sleep, so the work to unmounting proc is moved to a work queue. This has the side benefit of not blocking the entire world waiting for the unnecessary rcu_barrier in deactivate_locked_super. In the process of making the code clear and obvious this fixes a bug reported by Gao feng <gaofeng@cn.fujitsu.com> where we would leak a mount of proc during clone(CLONE_NEWPID|CLONE_NEWNET) if copy_pid_ns succeeded and copy_net_ns failed. Acked-by: "Serge E. Hallyn" <serge@hallyn.com> Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com>
2012-11-19pidns: Use task_active_pid_ns where appropriateEric W. Biederman
The expressions tsk->nsproxy->pid_ns and task_active_pid_ns aka ns_of_pid(task_pid(tsk)) should have the same number of cache line misses with the practical difference that ns_of_pid(task_pid(tsk)) is released later in a processes life. Furthermore by using task_active_pid_ns it becomes trivial to write an unshare implementation for the the pid namespace. So I have used task_active_pid_ns everywhere I can. In fork since the pid has not yet been attached to the process I use ns_of_pid, to achieve the same effect. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com>
2012-11-19pidns: Capture the user namespace and filter ns_last_pidEric W. Biederman
- Capture the the user namespace that creates the pid namespace - Use that user namespace to test if it is ok to write to /proc/sys/kernel/ns_last_pid. Zhao Hongjiang <zhaohongjiang@huawei.com> noticed I was missing a put_user_ns in when destroying a pid_ns. I have foloded his patch into this one so that bisects will work properly. Acked-by: Serge Hallyn <serge.hallyn@canonical.com> Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com>
2012-08-14net ip6 flowlabel: Make owner a union of struct pid * and kuid_tEric W. Biederman
Correct a long standing omission and use struct pid in the owner field of struct ip6_flowlabel when the share type is IPV6_FL_S_PROCESS. This guarantees we don't have issues when pid wraparound occurs. Use a kuid_t in the owner field of struct ip6_flowlabel when the share type is IPV6_FL_S_USER to add user namespace support. In /proc/net/ip6_flowlabel capture the current pid namespace when opening the file and release the pid namespace when the file is closed ensuring we print the pid owner value that is meaning to the reader of the file. Similarly use from_kuid_munged to print uid values that are meaningful to the reader of the file. This requires exporting pid_nr_ns so that ipv6 can continue to built as a module. Yoiks what silliness Acked-by: David S. Miller <davem@davemloft.net> Acked-by: Serge Hallyn <serge.hallyn@canonical.com> Signed-off-by: Eric W. Biederman <ebiederm@xmission.com>
2012-05-24mm: add a low limit to alloc_large_system_hashTim Bird
UDP stack needs a minimum hash size value for proper operation and also uses alloc_large_system_hash() for proper NUMA distribution of its hash tables and automatic sizing depending on available system memory. On some low memory situations, udp_table_init() must ignore the alloc_large_system_hash() result and reallocs a bigger memory area. As we cannot easily free old hash table, we leak it and kmemleak can issue a warning. This patch adds a low limit parameter to alloc_large_system_hash() to solve this problem. We then specify UDP_HTABLE_SIZE_MIN for UDP/UDPLite hash table allocation. Reported-by: Mark Asselstine <mark.asselstine@windriver.com> Reported-by: Tim Bird <tim.bird@am.sony.com> Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Cc: Paul Gortmaker <paul.gortmaker@windriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-02-13vfs: fix panic in __d_lookup() with high dentry hashtable countsDimitri Sivanich
When the number of dentry cache hash table entries gets too high (2147483648 entries), as happens by default on a 16TB system, use of a signed integer in the dcache_init() initialization loop prevents the dentry_hashtable from getting initialized, causing a panic in __d_lookup(). Fix this in dcache_init() and similar areas. Signed-off-by: Dimitri Sivanich <sivanich@sgi.com> Acked-by: David S. Miller <davem@davemloft.net> Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-01-12sysctl: add the kernel.ns_last_pid controlPavel Emelyanov
The sysctl works on the current task's pid namespace, getting and setting its last_pid field. Writing is allowed for CAP_SYS_ADMIN-capable tasks thus making it possible to create a task with desired pid value. This ability is required badly for the checkpoint/restore in userspace. This approach suits all the parties for now. Signed-off-by: Pavel Emelyanov <xemul@parallels.com> Acked-by: Tejun Heo <tj@kernel.org> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Cyrill Gorcunov <gorcunov@openvz.org> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Serge Hallyn <serue@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-10-31kernel: Map most files to use export.h instead of module.hPaul Gortmaker
The changed files were only including linux/module.h for the EXPORT_SYMBOL infrastructure, and nothing else. Revector them onto the isolated export header for faster compile times. Nothing to see here but a whole lot of instances of: -#include <linux/module.h> +#include <linux/export.h> This commit is only changing the kernel dir; next targets will probably be mm, fs, the arch dirs, etc. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2011-09-28rcu: Restore checks for blocking in RCU read-side critical sectionsPaul E. McKenney
Long ago, using TREE_RCU with PREEMPT would result in "scheduling while atomic" diagnostics if you blocked in an RCU read-side critical section. However, PREEMPT now implies TREE_PREEMPT_RCU, which defeats this diagnostic. This commit therefore adds a replacement diagnostic based on PROVE_RCU. Because rcu_lockdep_assert() and lockdep_rcu_dereference() are now being used for things that have nothing to do with rcu_dereference(), rename lockdep_rcu_dereference() to lockdep_rcu_suspicious() and add a third argument that is a string indicating what is suspicious. This third argument is passed in from a new third argument to rcu_lockdep_assert(). Update all calls to rcu_lockdep_assert() to add an informative third argument. Also, add a pair of rcu_lockdep_assert() calls from within rcu_note_context_switch(), one complaining if a context switch occurs in an RCU-bh read-side critical section and another complaining if a context switch occurs in an RCU-sched read-side critical section. These are present only if the PROVE_RCU kernel parameter is enabled. Finally, fix some checkpatch whitespace complaints in lockdep.c. Again, you must enable PROVE_RCU to see these new diagnostics. But you are enabling PROVE_RCU to check out new RCU uses in any case, aren't you? Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com>
2011-07-08rcu: treewide: Do not use rcu_read_lock_held when calling rcu_dereference_checkMichal Hocko
Since ca5ecddf (rcu: define __rcu address space modifier for sparse) rcu_dereference_check use rcu_read_lock_held as a part of condition automatically so callers do not have to do that as well. Signed-off-by: Michal Hocko <mhocko@suse.cz> Acked-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2011-04-18next_pidmap: fix overflow conditionLinus Torvalds
next_pidmap() just quietly accepted whatever 'last' pid that was passed in, which is not all that safe when one of the users is /proc. Admittedly the proc code should do some sanity checking on the range (and that will be the next commit), but that doesn't mean that the helper functions should just do that pidmap pointer arithmetic without checking the range of its arguments. So clamp 'last' to PID_MAX_LIMIT. The fact that we then do "last+1" doesn't really matter, the for-loop does check against the end of the pidmap array properly (it's only the actual pointer arithmetic overflow case we need to worry about, and going one bit beyond isn't going to overflow). [ Use PID_MAX_LIMIT rather than pid_max as per Eric Biederman ] Reported-by: Tavis Ormandy <taviso@cmpxchg8b.com> Analyzed-by: Robert Święcki <robert@swiecki.net> Cc: Eric W. Biederman <ebiederm@xmission.com> Cc: Pavel Emelyanov <xemul@openvz.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-17export pid symbols needed for kvm_vcpu_on_spinRik van Riel
Export the symbols required for a race-free kvm_vcpu_on_spin. Signed-off-by: Rik van Riel <riel@redhat.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2010-08-19Add RCU check for find_task_by_vpid().Tetsuo Handa
find_task_by_vpid() says "Must be called under rcu_read_lock().". But due to commit 3120438 "rcu: Disable lockdep checking in RCU list-traversal primitives", we are currently unable to catch "find_task_by_vpid() with tasklist_lock held but RCU lock not held" errors due to the RCU-lockdep checks being suppressed in the RCU variants of the struct list_head traversals. This commit therefore places an explicit check for being in an RCU read-side critical section in find_task_by_pid_ns(). =================================================== [ INFO: suspicious rcu_dereference_check() usage. ] --------------------------------------------------- kernel/pid.c:386 invoked rcu_dereference_check() without protection! other info that might help us debug this: rcu_scheduler_active = 1, debug_locks = 1 1 lock held by rc.sysinit/1102: #0: (tasklist_lock){.+.+..}, at: [<c1048340>] sys_setpgid+0x40/0x160 stack backtrace: Pid: 1102, comm: rc.sysinit Not tainted 2.6.35-rc3-dirty #1 Call Trace: [<c105e714>] lockdep_rcu_dereference+0x94/0xb0 [<c104b4cd>] find_task_by_pid_ns+0x6d/0x70 [<c104b4e8>] find_task_by_vpid+0x18/0x20 [<c1048347>] sys_setpgid+0x47/0x160 [<c1002b50>] sysenter_do_call+0x12/0x36 Commit updated to use a new rcu_lockdep_assert() exported API rather than the old internal __do_rcu_dereference(). Signed-off-by: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp> Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Reviewed-by: Josh Triplett <josh@joshtriplett.org>
2010-08-19rculist: avoid __rcu annotationsArnd Bergmann
This avoids warnings from missing __rcu annotations in the rculist implementation, making it possible to use the same lists in both RCU and non-RCU cases. We can add rculist annotations later, together with lockdep support for rculist, which is missing as well, but that may involve changing all the users. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: Pavel Emelyanov <xemul@openvz.org> Cc: Sukadev Bhattiprolu <sukadev@us.ibm.com> Reviewed-by: Josh Triplett <josh@joshtriplett.org>
2010-08-11pids: alloc_pidmap: remove the unnecessary boundary checksOleg Nesterov
alloc_pidmap() calculates max_scan so that if the initial offset != 0 we inspect the first map->page twice. This is correct, we want to find the unused bits < offset in this bitmap block. Add the comment. But it doesn't make any sense to stop the find_next_offset() loop when we are looking into this map->page for the second time. We have already already checked the bits >= offset during the first attempt, it is fine to do this again, no matter if we succeed this time or not. Remove this hard-to-understand code. It optimizes the very unlikely case when we are going to fail, but slows down the more likely case. Signed-off-by: Oleg Nesterov <oleg@redhat.com> Cc: Salman Qazi <sqazi@google.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Sukadev Bhattiprolu <sukadev@us.ibm.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-08-11pids: fix a race in pid generation that causes pids to be reused immediatelySalman
A program that repeatedly forks and waits is susceptible to having the same pid repeated, especially when it competes with another instance of the same program. This is really bad for bash implementation. Furthermore, many shell scripts assume that pid numbers will not be used for some length of time. Race Description: A B // pid == offset == n // pid == offset == n + 1 test_and_set_bit(offset, map->page) test_and_set_bit(offset, map->page); pid_ns->last_pid = pid; pid_ns->last_pid = pid; // pid == n + 1 is freed (wait()) // Next fork()... last = pid_ns->last_pid; // == n pid = last + 1; Code to reproduce it (Running multiple instances is more effective): #include <errno.h> #include <sys/types.h> #include <sys/wait.h> #include <unistd.h> #include <stdio.h> #include <stdlib.h> // The distance mod 32768 between two pids, where the first pid is expected // to be smaller than the second. int PidDistance(pid_t first, pid_t second) { return (second + 32768 - first) % 32768; } int main(int argc, char* argv[]) { int failed = 0; pid_t last_pid = 0; int i; printf("%d\n", sizeof(pid_t)); for (i = 0; i < 10000000; ++i) { if (i % 32786 == 0) printf("Iter: %d\n", i/32768); int child_exit_code = i % 256; pid_t pid = fork(); if (pid == -1) { fprintf(stderr, "fork failed, iteration %d, errno=%d", i, errno); exit(1); } if (pid == 0) { // Child exit(child_exit_code); } else { // Parent if (i > 0) { int distance = PidDistance(last_pid, pid); if (distance == 0 || distance > 30000) { fprintf(stderr, "Unexpected pid sequence: previous fork: pid=%d, " "current fork: pid=%d for iteration=%d.\n", last_pid, pid, i); failed = 1; } } last_pid = pid; int status; int reaped = wait(&status); if (reaped != pid) { fprintf(stderr, "Wait return value: expected pid=%d, " "got %d, iteration %d\n", pid, reaped, i); failed = 1; } else if (WEXITSTATUS(status) != child_exit_code) { fprintf(stderr, "Unexpected exit status %x, iteration %d\n", WEXITSTATUS(status), i); failed = 1; } } } exit(failed); } Thanks to Ted Tso for the key ideas of this implementation. Signed-off-by: Salman Qazi <sqazi@google.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Theodore Ts'o <tytso@mit.edu> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Sukadev Bhattiprolu <sukadev@us.ibm.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-05-27pids: increase pid_max based on num_possible_cpusHedi Berriche
On a system with a substantial number of processors, the early default pid_max of 32k will not be enough. A system with 1664 CPU's, there are 25163 processes started before the login prompt. It's estimated that with 2048 CPU's we will pass the 32k limit. With 4096, we'll reach that limit very early during the boot cycle, and processes would stall waiting for an available pid. This patch increases the early maximum number of pids available, and increases the minimum number of pids that can be set during runtime. [akpm@linux-foundation.org: fix warnings] Signed-off-by: Hedi Berriche <hedi@sgi.com> Signed-off-by: Mike Travis <travis@sgi.com> Signed-off-by: Robin Holt <holt@sgi.com> Acked-by: Linus Torvalds <torvalds@linux-foundation.org> Cc: Ingo Molnar <mingo@elte.hu> Cc: Pavel Machek <pavel@ucw.cz> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Cc: Greg KH <gregkh@suse.de> Cc: Rik van Riel <riel@redhat.com> Cc: John Stoffel <john@stoffel.org> Cc: Jack Steiner <steiner@sgi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-03-13Merge branch 'core-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'core-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: locking: Make sparse work with inline spinlocks and rwlocks x86/mce: Fix RCU lockdep splats rcu: Increase RCU CPU stall timeouts if PROVE_RCU ftrace: Replace read_barrier_depends() with rcu_dereference_raw() rcu: Suppress RCU lockdep warnings during early boot rcu, ftrace: Fix RCU lockdep splat in ftrace_perf_buf_prepare() rcu: Suppress __mpol_dup() false positive from RCU lockdep rcu: Make rcu_read_lock_sched_held() handle !PREEMPT rcu: Add control variables to lockdep_rcu_dereference() diagnostics rcu, cgroup: Relax the check in task_subsys_state() as early boot is now handled by lockdep-RCU rcu: Use wrapper function instead of exporting tasklist_lock sched, rcu: Fix rcu_dereference() for RCU-lockdep rcu: Make task_subsys_state() RCU-lockdep checks handle boot-time use rcu: Fix holdoff for accelerated GPs for last non-dynticked CPU x86/gart: Unexport gart_iommu_aperture Fix trivial conflicts in kernel/trace/ftrace.c
2010-03-06kernel/pid.c: update comment on find_task_by_pid_nsTetsuo Handa
tasklist_lock does protect the task and its pid, it can't go away. The problem is that find_pid_ns() itself is unsafe without rcu lock, it can race with copy_process()->free_pid(any_pid). Protecting copy_process()->free_pid(any_pid) with tasklist_lock would make it possible to call find_task_by_pid_ns() under tasklist safely, but we don't do so because we are trying to get rid of the read_lock sites of tasklist_lock. Signed-off-by: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp> Cc: Oleg Nesterov <oleg@redhat.com> Cc: "Paul E. McKenney" <paulmck@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-03-04rcu: Use wrapper function instead of exporting tasklist_lockPaul E. McKenney
Lockdep-RCU commit d11c563d exported tasklist_lock, which is not a good thing. This patch instead exports a function that uses lockdep to check whether tasklist_lock is held. Suggested-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: laijs@cn.fujitsu.com Cc: dipankar@in.ibm.com Cc: mathieu.desnoyers@polymtl.ca Cc: josh@joshtriplett.org Cc: dvhltc@us.ibm.com Cc: niv@us.ibm.com Cc: peterz@infradead.org Cc: rostedt@goodmis.org Cc: Valdis.Kletnieks@vt.edu Cc: dhowells@redhat.com Cc: Christoph Hellwig <hch@lst.de> LKML-Reference: <1267631219-8713-1-git-send-email-paulmck@linux.vnet.ibm.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-02-25sched: Use lockdep-based checking on rcu_dereference()Paul E. McKenney
Update the rcu_dereference() usages to take advantage of the new lockdep-based checking. Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: laijs@cn.fujitsu.com Cc: dipankar@in.ibm.com Cc: mathieu.desnoyers@polymtl.ca Cc: josh@joshtriplett.org Cc: dvhltc@us.ibm.com Cc: niv@us.ibm.com Cc: peterz@infradead.org Cc: rostedt@goodmis.org Cc: Valdis.Kletnieks@vt.edu Cc: dhowells@redhat.com LKML-Reference: <1266887105-1528-6-git-send-email-paulmck@linux.vnet.ibm.com> [ -v2: fix allmodconfig missing symbol export build failure on x86 ] Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-12-16pid: reduce code size by using a pointer to iterate over arrayAndré Goddard Rosa
It decreases code size by 16 bytes on my gcc 4.4.1 on Core 2: text data bss dec hex filename 4314 2216 8 6538 198a kernel/pid.o-BEFORE 4298 2216 8 6522 197a kernel/pid.o-AFTER Signed-off-by: André Goddard Rosa <andre.goddard@gmail.com> Cc: Pekka Enberg <penberg@cs.helsinki.fi> Cc: Oleg Nesterov <oleg@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-12-16pid: tighten pidmap spinlock critical section by removing kfree()André Goddard Rosa
Avoid calling kfree() under pidmap spinlock, calling it afterwards. Normally kfree() is fast, but sometimes it can be slow, so avoid calling it under the spinlock if we can do it. Signed-off-by: André Goddard Rosa <andre.goddard@gmail.com> Cc: Pekka Enberg <penberg@cs.helsinki.fi> Cc: Oleg Nesterov <oleg@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-22mm: also use alloc_large_system_hash() for the PID hash tableJan Beulich
This is being done by allowing boot time allocations to specify that they may want a sub-page sized amount of memory. Overall this seems more consistent with the other hash table allocations, and allows making two supposedly mm-only variables really mm-only (nr_{kernel,all}_pages). Signed-off-by: Jan Beulich <jbeulich@novell.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Mel Gorman <mel@csn.ul.ie> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
