path: root/kernel/pid.c
2009-07-09kmemleak: Remove alloc_bootmem annotations introduced in the pastCatalin Marinas
kmemleak_alloc() calls were added in some places where alloc_bootmem was called. Since now kmemleak tracks bootmem allocations, these explicit calls should be run. Signed-off-by: Catalin Marinas <catalin.marinas@arm.com> Cc: Ingo Molnar <mingo@elte.hu> Acked-by: Pekka Enberg <penberg@cs.helsinki.fi>
2009-06-29kmemleak: Inform kmemleak about pid_hashCatalin Marinas
Kmemleak does not track alloc_bootmem calls but the pid_hash allocated in pidhash_init() would need to be scanned as it contains pointers to struct pid objects. Signed-off-by: Catalin Marinas <catalin.marinas@arm.com>
2009-06-18pids: clean up find_task_by_pid variantsChristoph Hellwig
find_task_by_pid_type_ns is only used to implement find_task_by_vpid and find_task_by_pid_ns, but both of them pass PIDTYPE_PID as first argument. So just fold find_task_by_pid_type_ns into find_task_by_pid_ns and use find_task_by_pid_ns to implement find_task_by_vpid. While we're at it also remove the exports for find_task_by_pid_ns and find_task_by_vpid - we don't have any modular callers left as the only modular caller of he old pre pid namespace find_task_by_pid (gfs2) was switched to pid_task which operates on a struct pid pointer instead of a pid_t. Given the confusion about pid_t values vs namespace that's generally the better option anyway and I think we're better of restricting modules to do it that way. Signed-off-by: Christoph Hellwig <hch@lst.de> Cc: Pavel Emelyanov <xemul@openvz.org> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Oleg Nesterov <oleg@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-02pids: refactor vnr/nr_ns helpers to make them safeOleg Nesterov
Inho, the safety rules for vnr/nr_ns helpers are horrible and buggy. task_pid_nr_ns(task) needs rcu/tasklist depending on task == current. As for "special" pids, vnr/nr_ns helpers always need rcu. However, if task != current, they are unsafe even under rcu lock, we can't trust task->group_leader without the special checks. And almost every helper has a callsite which needs a fix. Also, it is a bit annoying that the implementations of, say, task_pgrp_vnr() and task_pgrp_nr_ns() are not "symmetrical". This patch introduces the new helper, __task_pid_nr_ns(), which is always safe to use, and turns all other helpers into the trivial wrappers. After this I'll send another patch which converts task_tgid_xxx() as well, they're are a bit special. Signed-off-by: Oleg Nesterov <oleg@redhat.com> Cc: Louis Rilling <Louis.Rilling@kerlabs.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Pavel Emelyanov <xemul@openvz.org> Cc: Sukadev Bhattiprolu <sukadev@linux.vnet.ibm.com> Cc: Roland McGrath <roland@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-02pids: improve get_task_pid() to fix the unsafe sys_wait4()->task_pgrp()Oleg Nesterov
sys_wait4() does get_pid(task_pgrp(current)), this is not safe. We can add rcu lock/unlock around, but we already have get_task_pid() which can be improved to handle the special pids in more reliable manner. Signed-off-by: Oleg Nesterov <oleg@redhat.com> Cc: Louis Rilling <Louis.Rilling@kerlabs.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Pavel Emelyanov <xemul@openvz.org> Cc: Sukadev Bhattiprolu <sukadev@linux.vnet.ibm.com> Cc: Roland McGrath <roland@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-08pid: generalize task_active_pid_nsEric W. Biederman
Currently task_active_pid_ns is not safe to call after a task becomes a zombie and exit_task_namespaces is called, as nsproxy becomes NULL. By reading the pid namespace from the pid of the task we can trivially solve this problem at the cost of one extra memory read in what should be the same cacheline as we read the namespace from. When moving things around I have made task_active_pid_ns out of line because keeping it in pid_namespace.h would require adding includes of pid.h and sched.h that I don't think we want. This change does make task_active_pid_ns unsafe to call during copy_process until we attach a pid on the task_struct which seems to be a reasonable trade off. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: Sukadev Bhattiprolu <sukadev@linux.vnet.ibm.com> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Roland McGrath <roland@redhat.com> Cc: Bastian Blank <bastian@waldi.eu.org> Cc: Pavel Emelyanov <xemul@openvz.org> Cc: Nadia Derbey <Nadia.Derbey@bull.net> Acked-by: Serge Hallyn <serue@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-06trivial: fix then -> than typos in comments and documentationFrederik Schwarzer
- (better, more, bigger ...) then -> (...) than Signed-off-by: Frederik Schwarzer <schwarzerf@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2008-07-25pidns: remove now unused find_pid function.Pavel Emelyanov
This one had the only users so far - the kill_proc, which is removed, so drop this (invalid in namespaced world) call too. And of course - erase all references on it from comments. Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Cc: Oleg Nesterov <oleg@tv-sign.ru> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-25proc: misplaced export of find_get_pidDavid Sterba
Move EXPORT_SYMBOL right after the func Signed-off-by: David Sterba <dsterba@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-19rcu: split list.h and move rcu-protected lists into rculist.hFranck Bui-Huu
Move rcu-protected lists from list.h into a new header file rculist.h. This is done because list are a very used primitive structure all over the kernel and it's currently impossible to include other header files in this list.h without creating some circular dependencies. For example, list.h implements rcu-protected list and uses rcu_dereference() without including rcupdate.h. It actually compiles because users of rcu_dereference() are macros. Others RCU functions could be used too but aren't probably because of this. Therefore this patch creates rculist.h which includes rcupdates without to many changes/troubles. Signed-off-by: Franck Bui-Huu <fbuihuu@gmail.com> Acked-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Acked-by: Josh Triplett <josh@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-04-30pids: introduce change_pid() helperOleg Nesterov
Based on Eric W. Biederman's idea. Without tasklist_lock held task_session()/task_pgrp() can return NULL if the caller races with setprgp()/setsid() which does detach_pid() + attach_pid(). This can happen even if task == current. Intoduce the new helper, change_pid(), which should be used instead. This way the caller always sees the special pid != NULL, either old or new. Also change the prototype of attach_pid(), it always returns 0 and nobody check the returned value. Signed-off-by: Oleg Nesterov <oleg@tv-sign.ru> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Pavel Emelyanov <xemul@openvz.org> Cc: Roland McGrath <roland@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-30pids: de_thread: don't clear session/pgrp pids for the old leaderOleg Nesterov
Based on Eric W. Biederman's idea. Unless task == current, without tasklist_lock held task_session()/task_pgrp() can return NULL if the caller races with de_thread() which switches the group leader. Change transfer_pid() to not clear old->pids[type].pid for the old leader. This means that its .pid can point to "nowhere", but this is already true for sub-threads, and the old leader is not group_leader() any longer. IOW, with or without this change we can't trust task's special pids unless it is the group leader. With this change the following code rcu_read_lock(); task = find_task_by_xxx(); do_something(task_pgrp(task), task_session(task)); rcu_read_unlock(); can't race with exec and hit the NULL pid. Signed-off-by: Oleg Nesterov <oleg@tv-sign.ru> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Pavel Emelyanov <xemul@openvz.org> Cc: Roland McGrath <roland@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-30Deprecate find_task_by_pid()Pavel Emelyanov
There are some places that are known to operate on tasks' global pids only: * the rest_init() call (called on boot) * the kgdb's getthread * the create_kthread() (since the kthread is run in init ns) So use the find_task_by_pid_ns(..., &init_pid_ns) there and schedule the find_task_by_pid for removal. [sukadev@us.ibm.com: Fix warning in kernel/pid.c] Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: Sukadev Bhattiprolu <sukadev@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-30free_pidmap: turn it into free_pidmap(struct upid *)Oleg Nesterov
The callers of free_pidmap() pass 2 members of "struct upid", we can just pass "struct upid *" instead. Shaves off 10 bytes from pid.o. Also, simplify the alloc_pid's "out_free:" error path a little bit. This way it looks more clear which subset of pid->numbers[] we are freeing. Signed-off-by: Oleg Nesterov <oleg@tv-sign.ru> Cc: Pavel Emelyanov <xemul@openvz.org> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc :Roland McGrath <roland@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-08kernel: remove fastcall in kernel/*Harvey Harrison
[akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Acked-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-08pid: Extend/Fix pid_vnrEric W. Biederman
pid_vnr returns the user space pid with respect to the pid namespace the struct pid was allocated in. What we want before we return a pid to user space is the user space pid with respect to the pid namespace of current. pid_vnr is a very nice optimization but because it isn't quite what we want it is easy to use pid_vnr at times when we aren't certain the struct pid was allocated in our pid namespace. Currently this describes at least tiocgpgrp and tiocgsid in ttyio.c the parent process reported in the core dumps and the parent process in get_signal_to_deliver. So unless the performance impact is huge having an interface that does what we want instead of always what we want should be much more reliable and much less error prone. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Cc: Oleg Nesterov <oleg@tv-sign.ru> Acked-by: Pavel Emelyanov <xemul@openvz.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-08namespaces: cleanup the code managed with PID_NS optionPavel Emelyanov
Just like with the user namespaces, move the namespace management code into the separate .c file and mark the (already existing) PID_NS option as "depend on NAMESPACES" [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Acked-by: Serge Hallyn <serue@us.ibm.com> Cc: Cedric Le Goater <clg@fr.ibm.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Herbert Poetzl <herbert@13thfloor.at> Cc: Kirill Korotaev <dev@sw.ru> Cc: Sukadev Bhattiprolu <sukadev@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-07gfs2: make gfs2_glock.gl_owner_pid be a struct pid *Pavel Emelyanov
The gl_owner_pid field is used to get the lock owning task by its pid, so make it in a proper manner, i.e. by using the struct pid pointer and pid_task() function. The pid_task() becomes exported for the gfs2 module. Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Acked-by: Steven Whitehouse <swhiteho@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-11-14pidns: Place under CONFIG_EXPERIMENTALEric W. Biederman
This is my trivial patch to swat innumerable little bugs with a single blow. After some intensive review (my apologies for not having gotten to this sooner) what we have looks like a good base to build on with the current pid namespace code but it is not complete, and it is still much to simple to find issues where the kernel does the wrong thing outside of the initial pid namespace. Until the dust settles and we are certain we have the ABI and the implementation is as correct as humanly possible let's keep process ID namespaces behind CONFIG_EXPERIMENTAL. Allowing us the option of fixing any ABI or other bugs we find as long as they are minor. Allowing users of the kernel to avoid those bugs simply by ensuring their kernel does not have support for multiple pid namespaces. [akpm@linux-foundation.org: coding-style cleanups] Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Cc: Cedric Le Goater <clg@fr.ibm.com> Cc: Adrian Bunk <bunk@kernel.org> Cc: Jeremy Fitzhardinge <jeremy@goop.org> Cc: Kir Kolyshkin <kir@swsoft.com> Cc: Kirill Korotaev <dev@sw.ru> Cc: Pavel Emelyanov <xemul@openvz.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-19Uninline the task_xid_nr_ns() callsPavel Emelyanov
Since these are expanded into call to pid_nr_ns() anyway, it's OK to move the whole routine out-of-line. This is a cheap way to save ~100 bytes from vmlinux. Together with the previous two patches, it saves half-a-kilo from the vmlinux. Un-inline other (currently inlined) functions must be done with additional performance testing. Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Cc: Sukadev Bhattiprolu <sukadev@us.ibm.com> Cc: Oleg Nesterov <oleg@tv-sign.ru> Cc: Paul Menage <menage@google.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-19Uninline find_pid etc set of functionsPavel Emelyanov
The find_pid/_vpid/_pid_ns functions are used to find the struct pid by its id, depending on whic id - global or virtual - is used. The find_vpid() is a macro that pushes the current->nsproxy->pid_ns on the stack to call another function - find_pid_ns(). It turned out, that this dereference together with the push itself cause the kernel text size to grow too much. Move all these out-of-line. Together with the previous patch this saves a bit less that 400 bytes from .text section. Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Cc: Sukadev Bhattiprolu <sukadev@us.ibm.com> Cc: Oleg Nesterov <oleg@tv-sign.ru> Cc: Paul Menage <menage@google.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-19pid namespaces: remove the struct pid unneeded fieldsPavel Emelyanov
Since we've switched from using pid->nr to pid->upids->nr some fields on struct pid are no longer needed Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Cc: Oleg Nesterov <oleg@tv-sign.ru> Cc: Sukadev Bhattiprolu <sukadev@us.ibm.com> Cc: Paul Menage <menage@google.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-19Uninline find_task_by_xxx set of functionsPavel Emelyanov
The find_task_by_something is a set of macros are used to find task by pid depending on what kind of pid is proposed - global or virtual one. All of them are wrappers above the most generic one - find_task_by_pid_type_ns() - and just substitute some args for it. It turned out, that dereferencing the current->nsproxy->pid_ns construction and pushing one more argument on the stack inline cause kernel text size to grow. This patch moves all this stuff out-of-line into kernel/pid.c. Together with the next patch it saves a bit less than 400 bytes from the .text section. Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Cc: Sukadev Bhattiprolu <sukadev@us.ibm.com> Cc: Oleg Nesterov <oleg@tv-sign.ru> Cc: Paul Menage <menage@google.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Acked-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-19pid namespaces: destroy pid namespace on init's deathSukadev Bhattiprolu
Terminate all processes in a namespace when the reaper of the namespace is exiting. We do this by walking the pidmap of the namespace and sending SIGKILL to all processes. Signed-off-by: Sukadev Bhattiprolu <sukadev@us.ibm.com> Acked-by: Pavel Emelyanov <xemul@openvz.org> Cc: Oleg Nesterov <oleg@tv-sign.ru> Cc: Sukadev Bhattiprolu <sukadev@us.ibm.com> Cc: Paul Menage <menage@google.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-19pid namespaces: create a slab-cache for 'struct pid_namespace'Sukadev Bhattiprolu
This will help fixing memory leaks due to bad reference counting. Signed-off-by: Sukadev Bhattiprolu <sukadev@us.ibm.com> Cc: Oleg Nesterov <oleg@tv-sign.ru> Cc: Sukadev Bhattiprolu <sukadev@us.ibm.com> Cc: Paul Menage <menage@google.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-19pid namespaces: allow cloning of new namespacePavel Emelyanov
When clone() is invoked with CLONE_NEWPID, create a new pid namespace and then create a new struct pid for the new process. Allocate pid_t's for the new process in the new pid namespace and all ancestor pid namespaces. Make the newly cloned process the session and process group leader. Since the active pid namespace is special and expected to be the first entry in pid->upid_list, preserve the order of pid namespaces. The size of 'struct pid' is dependent on the the number of pid namespaces the process exists in, so we use multiple pid-caches'. Only one pid cache is created during system startup and this used by processes that exist only in init_pid_ns. When a process clones its pid namespace, we create additional pid caches as necessary and use the pid cache to allocate 'struct pids' for that depth. Note, that with this patch the newly created namespace won't work, since the rest of the kernel still uses global pids, but this is to be fixed soon. Init pid namespace still works. [oleg@tv-sign.ru: merge fix] Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Signed-off-by: Sukadev Bhattiprolu <sukadev@us.ibm.com> Cc: Paul Menage <menage@google.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Oleg Nesterov <oleg@tv-sign.ru> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-19pid namespaces: miscellaneous preparations for pid namespacesPavel Emelyanov
* remove pid.h from pid_namespaces.h; * rework is_(cgroup|global)_init; * optimize (get|put)_pid_ns for init_pid_ns; * declare task_child_reaper to return actual reaper. Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Cc: Oleg Nesterov <oleg@tv-sign.ru> Cc: Sukadev Bhattiprolu <sukadev@us.ibm.com> Cc: Paul Menage <menage@google.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-19pid namespaces: helpers to find the task by its numerical idsPavel Emelyanov
When searching the task by numerical id on may need to find it using global pid (as it is done now in kernel) or by its virtual id, e.g. when sending a signal to a task from one namespace the sender will specify the task's virtual id and we should find the task by this value. [akpm@linux-foundation.org: fix gfs2 linkage] Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Cc: Oleg Nesterov <oleg@tv-sign.ru> Cc: Sukadev Bhattiprolu <sukadev@us.ibm.com> Cc: Paul Menage <menage@google.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-19pid namespaces: helpers to obtain pid numbersPavel Emelyanov
When showing pid to user or getting the pid numerical id for in-kernel use the value of this id may differ depending on the namespace. This set of helpers is used to get the global pid nr, the virtual (i.e. seen by task in its namespace) nr and the nr as it is seen from the specified namespace. Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Cc: Oleg Nesterov <oleg@tv-sign.ru> Cc: Sukadev Bhattiprolu <sukadev@us.ibm.com> Cc: Paul Menage <menage@google.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-19pid namespaces: make alloc_pid(), free_pid() and put_pid() work with struct upidPavel Emelyanov
Each struct upid element of struct pid has to be initialized properly, i.e. its nr mst be allocated from appropriate pidmap and ns set to appropriate namespace. When allocating a new pid, we need to know the namespace this pid will live in, so the additional argument is added to alloc_pid(). On the other hand, the rest of the kernel still uses the pid->nr and pid->pid_chain fields, so these ones are still initialized, but this will be removed soon. Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Cc: Oleg Nesterov <oleg@tv-sign.ru> Cc: Sukadev Bhattiprolu <sukadev@us.ibm.com> Cc: Paul Menage <menage@google.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-19pid namespaces: add support for pid namespaces hierarchyPavel Emelyanov
Each namespace has a parent and is characterized by its "level". Level is the number of the namespace generation. E.g. init namespace has level 0, after cloning new one it will have level 1, the next one - 2 and so on and so forth. This level is not explicitly limited. True hierarchy must have some way to find each namespace's children, but it is not used in the patches, so this ability is not added (yet). Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Cc: Oleg Nesterov <oleg@tv-sign.ru> Cc: Sukadev Bhattiprolu <sukadev@us.ibm.com> Cc: Paul Menage <menage@google.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-19pid namespaces: define is_global_init() and is_container_init()Serge E. Hallyn
is_init() is an ambiguous name for the pid==1 check. Split it into is_global_init() and is_container_init(). A cgroup init has it's tsk->pid == 1. A global init also has it's tsk->pid == 1 and it's active pid namespace is the init_pid_ns. But rather than check the active pid namespace, compare the task structure with 'init_pid_ns.child_reaper', which is initialized during boot to the /sbin/init process and never changes. Changelog: 2.6.22-rc4-mm2-pidns1: - Use 'init_pid_ns.child_reaper' to determine if a given task is the global init (/sbin/init) process. This would improve performance and remove dependence on the task_pid(). 2.6.21-mm2-pidns2: - [Sukadev Bhattiprolu] Changed is_container_init() calls in {powerpc, ppc,avr32}/traps.c for the _exception() call to is_global_init(). This way, we kill only the cgroup if the cgroup's init has a bug rather than force a kernel panic. [akpm@linux-foundation.org: fix comment] [sukadev@us.ibm.com: Use is_global_init() in arch/m32r/mm/fault.c] [bunk@stusta.de: kernel/pid.c: remove unused exports] [sukadev@us.ibm.com: Fix capability.c to work with threaded init] Signed-off-by: Serge E. Hallyn <serue@us.ibm.com> Signed-off-by: Sukadev Bhattiprolu <sukadev@us.ibm.com> Acked-by: Pavel Emelianov <xemul@openvz.org> Cc: Eric W. Biederman <ebiederm@xmission.com> Cc: Cedric Le Goater <clg@fr.ibm.com> Cc: Dave Hansen <haveblue@us.ibm.com> Cc: Herbert Poetzel <herbert@13thfloor.at> Cc: Kirill Korotaev <dev@sw.ru> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-19pid namespaces: define and use task_active_pid_ns() wrapperSukadev Bhattiprolu
With multiple pid namespaces, a process is known by some pid_t in every ancestor pid namespace. Every time the process forks, the child process also gets a pid_t in every ancestor pid namespace. While a process is visible in >=1 pid namespaces, it can see pid_t's in only one pid namespace. We call this pid namespace it's "active pid namespace", and it is always the youngest pid namespace in which the process is known. This patch defines and uses a wrapper to find the active pid namespace of a process. The implementation of the wrapper will be changed in when support for multiple pid namespaces are added. Changelog: 2.6.22-rc4-mm2-pidns1: - [Pavel Emelianov, Alexey Dobriyan] Back out the change to use task_active_pid_ns() in child_reaper() since task->nsproxy can be NULL during task exit (so child_reaper() continues to use init_pid_ns). to implement child_reaper() since init_pid_ns.child_reaper to implement child_reaper() since tsk->nsproxy can be NULL during exit. 2.6.21-rc6-mm1: - Rename task_pid_ns() to task_active_pid_ns() to reflect that a process can have multiple pid namespaces. Signed-off-by: Sukadev Bhattiprolu <sukadev@us.ibm.com> Acked-by: Pavel Emelianov <xemul@openvz.org> Cc: Eric W. Biederman <ebiederm@xmission.com> Cc: Cedric Le Goater <clg@fr.ibm.com> Cc: Dave Hansen <haveblue@us.ibm.com> Cc: Serge Hallyn <serue@us.ibm.com> Cc: Herbert Poetzel <herbert@13thfloor.at> Cc: Kirill Korotaev <dev@sw.ru> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-19pid namespaces: dynamic kmem cache allocator for pid namespacesPavel Emelianov
Add kmem_cache to pid_namespace to allocate pids from. Since both implementations expand the struct pid to carry more numerical values each namespace should have separate cache to store pids of different sizes. Each kmem cache is name "pid_<NR>", where <NR> is the number of numerical ids on the pid. Different namespaces with same level of nesting will have same caches. This patch has two FIXMEs that are to be fixed after we reach the consensus about the struct pid itself. The first one is that the namespace to free the pid from in free_pid() must be taken from pid. Now the init_pid_ns is used. The second FIXME is about the cache allocation. When we do know how long the object will be then we'll have to calculate this size in create_pid_cachep. Right now the sizeof(struct pid) value is used. [akpm@linux-foundation.org: coding-style repair] Signed-off-by: Pavel Emelianov <xemul@openvz.org> Acked-by: Cedric Le Goater <clg@fr.ibm.com> Acked-by: Sukadev Bhattiprolu <sukadev@us.ibm.com> Cc: Kirill Korotaev <dev@openvz.org> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Herbert Poetzl <herbert@13thfloor.at> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-16namespace: ensure clone_flags are always stored in an unsigned longEric W. Biederman
While working on unshare support for the network namespace I noticed we were putting clone flags in an int. Which is weird because the syscall uses unsigned long and we at least need an unsigned to properly hold all of the unshare flags. So to make the code consistent, this patch updates the code to use unsigned long instead of int for the clone flags in those places where we get it wrong today. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Acked-by: Cedric Le Goater <clg@fr.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-11statically initialize struct pid for swapperSukadev Bhattiprolu
Statically initialize a struct pid for the swapper process (pid_t == 0) and attach it to init_task. This is needed so task_pid(), task_pgrp() and task_session() interfaces work on the swapper process also. Signed-off-by: Sukadev Bhattiprolu <sukadev@us.ibm.com> Cc: Cedric Le Goater <clg@fr.ibm.com> Cc: Dave Hansen <haveblue@us.ibm.com> Cc: Serge Hallyn <serue@us.ibm.com> Cc: Eric Biederman <ebiederm@xmission.com> Cc: Herbert Poetzl <herbert@13thfloor.at> Cc: <containers@lists.osdl.org> Acked-by: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-11attach_pid() with struct pid parameterSukadev Bhattiprolu
attach_pid() currently takes a pid_t and then uses find_pid() to find the corresponding struct pid. Sometimes we already have the struct pid. We can then skip find_pid() if attach_pid() were to take a struct pid parameter. Signed-off-by: Sukadev Bhattiprolu <sukadev@us.ibm.com> Cc: Cedric Le Goater <clg@fr.ibm.com> Cc: Dave Hansen <haveblue@us.ibm.com> Cc: Serge Hallyn <serue@us.ibm.com> Cc: <containers@lists.osdl.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08Merge sys_clone()/sys_unshare() nsproxy and namespace handlingBadari Pulavarty
sys_clone() and sys_unshare() both makes copies of nsproxy and its associated namespaces. But they have different code paths. This patch merges all the nsproxy and its associated namespace copy/clone handling (as much as possible). Posted on container list earlier for feedback. - Create a new nsproxy and its associated namespaces and pass it back to caller to attach it to right process. - Changed all copy_*_ns() routines to return a new copy of namespace instead of attaching it to task->nsproxy. - Moved the CAP_SYS_ADMIN checks out of copy_*_ns() routines. - Removed unnessary !ns checks from copy_*_ns() and added BUG_ON() just incase. - Get rid of all individual unshare_*_ns() routines and make use of copy_*_ns() instead. [akpm@osdl.org: cleanups, warning fix] [clg@fr.ibm.com: remove dup_namespaces() declaration] [serue@us.ibm.com: fix CONFIG_IPC_NS=n, clone(CLONE_NEWIPC) retval] [akpm@linux-foundation.org: fix build with CONFIG_SYSVIPC=n] Signed-off-by: Badari Pulavarty <pbadari@us.ibm.com> Signed-off-by: Serge Hallyn <serue@us.ibm.com> Cc: Cedric Le Goater <clg@fr.ibm.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: <containers@lists.osdl.org> Signed-off-by: Cedric Le Goater <clg@fr.ibm.com> Cc: Oleg Nesterov <oleg@tv-sign.ru> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-07KMEM_CACHE(): simplify slab cache creationChristoph Lameter
This patch provides a new macro KMEM_CACHE(<struct>, <flags>) to simplify slab creation. KMEM_CACHE creates a slab with the name of the struct, with the size of the struct and with the alignment of the struct. Additional slab flags may be specified if necessary. Example struct test_slab { int a,b,c; struct list_head; } __cacheline_aligned_in_smp; test_slab_cache = KMEM_CACHE(test_slab, SLAB_PANIC) will create a new slab named "test_slab" of the size sizeof(struct test_slab) and aligned to the alignment of test slab. If it fails then we panic. Signed-off-by: Christoph Lameter <clameter@sgi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-01-30[PATCH] namespaces: fix task exit disasterSerge E. Hallyn
This is based on a patch by Eric W. Biederman, who pointed out that pid namespaces are still fake, and we only have one ever active. So for the time being, we can modify any code which could access tsk->nsproxy->pid_ns during task exit to just use &init_pid_ns instead, and move the exit_task_namespaces call in do_exit() back above exit_notify(), so that an exiting nfs server has a valid tsk->sighand to work with. Long term, pulling pid_ns out of nsproxy might be the cleanest solution. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> [ Eric's patch fixed to take care of free_pid() too ] Signed-off-by: Serge E. Hallyn <serue@us.ibm.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-12-08[PATCH] add child reaper to pid_namespaceSukadev Bhattiprolu
Add a per pid_namespace child-reaper. This is needed so processes are reaped within the same pid space and do not spill over to the parent pid space. Its also needed so containers preserve existing semantic that pid == 1 would reap orphaned children. This is based on Eric Biederman's patch: http://lkml.org/lkml/2006/2/6/285 Signed-off-by: Sukadev Bhattiprolu <sukadev@us.ibm.com> Signed-off-by: Cedric Le Goater <clg@fr.ibm.com> Cc: Kirill Korotaev <dev@openvz.org> Cc: Eric W. Biederman <ebiederm@xmission.com> Cc: Herbert Poetzl <herbert@13thfloor.at> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-08[PATCH] use current->nsproxy->pid_nsCedric Le Goater
Signed-off-by: Cedric Le Goater <clg@fr.ibm.com> Cc: Kirill Korotaev <dev@openvz.org> Cc: Eric W. Biederman <ebiederm@xmission.com> Cc: Herbert Poetzl <herbert@13thfloor.at> Cc: Sukadev Bhattiprolu <sukadev@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-08[PATCH] to nsproxyCedric Le Goater
Add the pid namespace framework to the nsproxy object. The copy of the pid namespace only increases the refcount on the global pid namespace, init_pid_ns, and unshare is not implemented. There is no configuration option to activate or deactivate this feature because this not relevant for the moment. Signed-off-by: Cedric Le Goater <clg@fr.ibm.com> Cc: Kirill Korotaev <dev@openvz.org> Cc: Eric W. Biederman <ebiederm@xmission.com> Cc: Herbert Poetzl <herbert@13thfloor.at> Cc: Sukadev Bhattiprolu <sukadev@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-08[PATCH] rename struct pspace to struct pid_namespaceSukadev Bhattiprolu
Rename struct pspace to struct pid_namespace for consistency with other namespaces (uts_namespace and ipc_namespace). Also rename include/linux/pspace.h to include/linux/pid_namespace.h and variables from pspace to pid_ns. Signed-off-by: Sukadev Bhattiprolu <sukadev@us.ibm.com> Signed-off-by: Cedric Le Goater <clg@fr.ibm.com> Cc: Kirill Korotaev <dev@openvz.org> Cc: Eric W. Biederman <ebiederm@xmission.com> Cc: Herbert Poetzl <herbert@13thfloor.at> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-02[PATCH] introduce get_task_pid() to fix unsafe get_pid()Oleg Nesterov
proc_pid_make_inode: ei->pid = get_pid(task_pid(task)); I think this is not safe. get_pid() can be preempted after checking "pid != NULL". Then the task exits, does detach_pid(), and RCU frees the pid. Signed-off-by: Oleg Nesterov <oleg@tv-sign.ru> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-02[PATCH] Use struct pspace in next_pidmap and find_ge_pidEric W. Biederman
This updates my proc: readdir race fix (take 3) patch to account for the changes made by: Sukadev Bhattiprolu <sukadev@us.ibm.com> to introduce struct pspace. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-02[PATCH] Define struct pspaceSukadev Bhattiprolu
Define a per-container pid space object. And create one instance of this object, init_pspace, to define the entire pid space. Subsequent patches will provide/use interfaces to create/destroy pid spaces. Its a subset/rework of Eric Biederman's patch http://lkml.org/lkml/2006/2/6/285 . Signed-off-by: Eric Biederman <ebiederm@xmission.com> Signed-off-by: Sukadev Bhattiprolu <sukadev@us.ibm.com> Cc: Dave Hansen <haveblue@us.ibm.com> Cc: Serge Hallyn <serue@us.ibm.com> Cc: Cedric Le Goater <clg@fr.ibm.com> Cc: Kirill Korotaev <dev@sw.ru> Cc: Andrey Savochkin <saw@sw.ru> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-02[PATCH] Move pidmap to pspace.hSukadev Bhattiprolu
Move struct pidmap and PIDMAP_ENTRIES to a new file, include/linux/pspace.h where it will be used in subsequent patches to define pid spaces. Its a subset of Eric Biederman's patch http://lkml.org/lkml/2006/2/6/285 [akpm@osdl.org: cleanups] Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: Sukadev Bhattiprolu <sukadev@us.ibm.com> Cc: Dave Hansen <haveblue@us.ibm.com> Cc: Serge Hallyn <serue@us.ibm.com> Cc: Cedric Le Goater <clg@fr.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-02[PATCH] pids coding style use struct pidmap in next_pidmapEric W. Biederman
Use struct pidmap instead of pidmap_t. This updates my proc: readdir race fix (take 3) patch to account for the changes made by: Sukadev Bhattiprolu <sukadev@us.ibm.com> to kill pidmap_t. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
