[ Upstream commit f9070dc94542093fd516ae4ccea17ef46a4362c5 ]
The locking in force_sig_info is not prepared to deal with a task that
exits or execs (as sighand may change). The is not a locking problem
in force_sig as force_sig is only built to handle synchronous
exceptions.
Further the function force_sig_info changes the signal state if the
signal is ignored, or blocked or if SIGNAL_UNKILLABLE will prevent the
delivery of the signal. The signal SIGKILL can not be ignored and can
not be blocked and SIGNAL_UNKILLABLE won't prevent it from being
delivered.
So using force_sig rather than send_sig for SIGKILL is confusing
and pointless.
Because it won't impact the sending of the signal and and because
using force_sig is wrong, replace force_sig with send_sig.
Cc: Daniel Lezcano <daniel.lezcano@free.fr>
Cc: Serge Hallyn <serge@hallyn.com>
Fixes: cf3f89214ef6 ("pidns: add reboot_pid_ns() to handle the reboot syscall")
It is pointless and confusing to allow a pid namespace hierarchy and
the user namespace hierarchy to get out of sync. The owner of a child
pid namespace should be the owner of the parent pid namespace or
a descendant of the owner of the parent pid namespace.
Otherwise it is possible to construct scenarios where a process has a
capability over a parent pid namespace but does not have the
capability over a child pid namespace. Which confusingly makes
permission checks non-transitive.
It requires use of setns into a pid namespace (but not into a user
namespace) to create such a scenario.
Add the function in_userns to help in making this determination.
v2: Optimized in_userns by using level as suggested
by: Kirill Tkhai <ktkhai@virtuozzo.com>
Ref: 49f4d8b93ccf ("pidns: Capture the user namespace and filter ns_last_pid")
The code can potentially sleep for an indefinite amount of time in
zap_pid_ns_processes triggering the hung task timeout, and increasing
the system average. This is undesirable. Sleep with a task state of
TASK_INTERRUPTIBLE instead of TASK_UNINTERRUPTIBLE to remove these
undesirable side effects.
Apparently under heavy load this has been allowing Chrome to trigger
the hung time task timeout error and cause ChromeOS to reboot.
Reported-by: Vovo Yang <vovoy@google.com>
Reported-by: Guenter Roeck <linux@roeck-us.net>
Tested-by: Guenter Roeck <linux@roeck-us.net>
Fixes: 6347e9009104 ("pidns: guarantee that the pidns init will be the last pidns process reaped")
Cc: stable@vger.kernel.org
pid_ns_for_children set by a task is known only to the task itself, and
it's impossible to identify it from outside.
It's a big problem for checkpoint/restore software like CRIU, because it
can't correctly handle tasks, that do setns(CLONE_NEWPID) in proccess of
their work.
This patch solves the problem, and it exposes pid_ns_for_children to ns
directory in standard way with the name "pid_for_children":
~# ls /proc/5531/ns -l | grep pid
lrwxrwxrwx 1 root root 0 Jan 14 16:38 pid -> pid:[4026531836]
lrwxrwxrwx 1 root root 0 Jan 14 16:38 pid_for_children -> pid:[4026532286]
Link: http://lkml.kernel.org/r/149201123914.6007.2187327078064239572.stgit@localhost.localdomain
Signed-off-by: Kirill Tkhai <ktkhai@virtuozzo.com>
Cc: Andrei Vagin <avagin@virtuozzo.com>
Cc: Andreas Gruenbacher <agruenba@redhat.com>
Cc: Michael Kerrisk <mtk.manpages@googlemail.com>
Cc: Paul Moore <paul@paul-moore.com>
Cc: Eric Biederman <ebiederm@xmission.com>
dependency
Instead of including the full <linux/signal.h>, we are going to include the
types-only <linux/signal_types.h> header in <linux/sched.h>, to further
decouple the scheduler header from the signal headers.
This means that various files which relied on the full <linux/signal.h> need
to be updated to gain an explicit dependency on it.
Update the code that relies on sched.h's inclusion of the <linux/signal.h> header.
Acked-by: Linus Torvalds <torvalds@linux-foundation.org>
<linux/sched/task.h>
We are going to split <linux/sched/task.h> out of <linux/sched.h>, which
will have to be picked up from other headers and a couple of .c files.
Create a trivial placeholder <linux/sched/task.h> file that just
maps to <linux/sched.h> to make this patch obviously correct and
bisectable.
Include the new header in the files that are going to need it.
Add #include <linux/cred.h> dependencies to all .c files rely on sched.h
doing that for them.
Note that even if the count where we need to add extra headers seems high,
it's still a net win, because <linux/sched.h> is included in over
2,200 files ...
[ INFO: possible irq lock inversion dependency detected ]
4.10.0-rc2-00024-g4aecec9-dirty #118 Tainted: G W
swapper/1/0 just changed the state of lock:
(&(&sighand->siglock)->rlock){-.....}, at: [<ffffffffbd0a1bc6>] __lock_task_sighand+0xb6/0x2c0
but this lock took another, HARDIRQ-unsafe lock in the past:
(ucounts_lock){+.+...}
and interrupts could create inverse lock ordering between them.
Chain exists of: &(&sighand->siglock)->rlock --> &(&tty->ctrl_lock)->rlock --> ucounts_lock
Possible interrupt unsafe locking scenario:
CPU0 CPU1
lock(ucounts_lock);
local_irq_disable();
lock(&(&sighand->siglock)->rlock);
lock(&(&tty->ctrl_lock)->rlock);
<Interrupt>
*** DEADLOCK ***
This patch removes a dependency between rlock and ucount_lock.
Fixes: f333c700c610 ("pidns: Add a limit on the number of pid namespaces")
Signed-off-by: Andrei Vagin <avagin@openvz.org>
Acked-by: Al Viro <viro@ZenIV.linux.org.uk>
Each namespace has an owning user namespace and now there is not way
to discover these relationships.
Pid and user namepaces are hierarchical. There is no way to discover
parent-child relationships too.
Why we may want to know relationships between namespaces?
One use would be visualization, in order to understand the running
system. Another would be to answer the question: what capability does
process X have to perform operations on a resource governed by namespace
Y?
One more use-case (which usually called abnormal) is checkpoint/restart.
In CRIU we are going to dump and restore nested namespaces.
There [1] was a discussion about which interface to choose to determing
relationships between namespaces.
Eric suggested to add two ioctl-s [2]:
> Grumble, Grumble. I think this may actually a case for creating ioctls
> for these two cases. Now that random nsfs file descriptors are bind
> mountable the original reason for using proc files is not as pressing.
> One ioctl for the user namespace that owns a file descriptor.
> One ioctl for the parent namespace of a namespace file descriptor.
Here is an implementaions of these ioctl-s.
$ man man7/namespaces.7
Since Linux 4.X, the following ioctl(2) calls are supported for
namespace file descriptors. The correct syntax is:
fd = ioctl(ns_fd, ioctl_type);
where ioctl_type is one of the following:
NS_GET_USERNS
Returns a file descriptor that refers to an owning user names‐
pace.
NS_GET_PARENT
Returns a file descriptor that refers to a parent namespace.
This ioctl(2) can be used for pid and user namespaces. For
user namespaces, NS_GET_PARENT and NS_GET_USERNS have the same
meaning.
In addition to generic ioctl(2) errors, the following specific ones
can occur:
EINVAL NS_GET_PARENT was called for a nonhierarchical namespace.
EPERM The requested namespace is outside of the current namespace
scope.
[1] https://lkml.org/lkml/2016/7/6/158
[2] https://lkml.org/lkml/2016/7/9/101
Changes for v2:
* don't return ENOENT for init_user_ns and init_pid_ns. There is nothing
outside of the init namespace, so we can return EPERM in this case too.
> The fewer special cases the easier the code is to get
> correct, and the easier it is to read. // Eric
Changes for v3:
* rename ns->get_owner() to ns->owner(). get_* usually means that it
grabs a reference.
Cc: "Eric W. Biederman" <ebiederm@xmission.com>
Cc: James Bottomley <James.Bottomley@HansenPartnership.com>
Cc: "Michael Kerrisk (man-pages)" <mtk.manpages@gmail.com>
Cc: "W. Trevor King" <wking@tremily.us>
Cc: Serge Hallyn <serge.hallyn@canonical.com>
parent-child relationships.
In a future we will use this interface to dump and restore nested
namespaces.
Acked-by: Serge Hallyn <serge@hallyn.com>
Return -EPERM if an owning user namespace is outside of a process
current user namespace.
v2: In a first version ns_get_owner returned ENOENT for init_user_ns.
This special cases was removed from this version. There is nothing
outside of init_user_ns, so we can return EPERM.
v3: rename ns->get_owner() to ns->owner(). get_* usually means that it
grabs a reference.
The current error codes returned when a the per user per user
namespace limit are hit (EINVAL, EUSERS, and ENFILE) are wrong. I
asked for advice on linux-api and it we made clear that those were
the wrong error code, but a correct effor code was not suggested.
The best general error code I have found for hitting a resource limit
is ENOSPC. It is not perfect but as it is unambiguous it will serve
until someone comes up with a better error code.
Pull vfs pile #2 from Al Viro:
"Next pile (and there'll be one or two more).
The large piece in this one is getting rid of /proc/*/ns/* weirdness;
among other things, it allows to (finally) make nameidata completely
opaque outside of fs/namei.c, making for easier further cleanups in
there"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs:
coda_venus_readdir(): use file_inode()
fs/namei.c: fold link_path_walk() call into path_init()
path_init(): don't bother with LOOKUP_PARENT in argument
fs/namei.c: new helper (path_cleanup())
path_init(): store the "base" pointer to file in nameidata itself
make default ->i_fop have ->open() fail with ENXIO
make nameidata completely opaque outside of fs/namei.c
kill proc_ns completely
take the targets of /proc/*/ns/* symlinks to separate fs
bury struct proc_ns in fs/proc
copy address of proc_ns_ops into ns_common
new helpers: ns_alloc_inum/ns_free_inum
make proc_ns_operations work with struct ns_common * instead of void *
switch the rest of proc_ns_operations to working with &...->ns
netns: switch ->get()/->put()/->install()/->inum() to working with &net->ns
make mntns ->get()/->put()/->install()/->inum() work with &mnt_ns->ns
common object embedded into various struct ....ns
The comments in zap_pid_ns_processes() are not clear, we need to explain
how this code actually works.
1. "Ignore SIGCHLD" looks like optimization but it is not, we also
need this for correctness.
2. The comment above sys_wait4() could tell more.
EXIT_ZOMBIE child is only possible if it has exited before we
ignored SIGCHLD. Or if it is traced from the parent namespace,
but in this case it will be reaped by debugger after detach,
sys_wait4() acts as a synchronization point.
3. The comment about TASK_DEAD (EXIT_DEAD in fact) children is
outdated. Contrary to what it says we do not need to make sure
they all go away after 0a01f2cc390e "pidns: Make the pidns proc
mount/umount logic obvious".
At the same time, we do need to wait for nr_hashed==init_pids,
but the reasons are quite different and not obvious: setns().
Cc: Aaron Tomlin <atomlin@redhat.com>
Cc: Pavel Emelyanov <xemul@parallels.com>
Cc: Serge Hallyn <serge.hallyn@ubuntu.com>
Cc: Sterling Alexander <stalexan@redhat.com>
take struct ns_common *, for now simply wrappers around proc_{alloc,free}_inum()
We can do that now. And kill ->inum(), while we are at it - all instances
are identical.
for now - just move corresponding ->proc_inum instances over there
Acked-by: "Eric W. Biederman" <ebiederm@xmission.com>
pidns_get()->get_pid_ns() can hit ns == NULL. This task_struct can't
go away, but task_active_pid_ns(task) is NULL if release_task(task)
was already called. Alternatively we could change get_pid_ns(ns) to
check ns != NULL, but it seems that other callers are fine.
Cc: Eric W. Biederman ebiederm@xmission.com>
Cc: stable@kernel.org
makes procfs ->premission() instances safety in RCU mode independent
from vfsmount_lock.
git://git.kernel.org/pub/scm/linux/kernel/git/ebiederm/user-namespace
Pull namespace changes from Eric Biederman:
"This is an assorted mishmash of small cleanups, enhancements and bug
fixes.
The major theme is user namespace mount restrictions. nsown_capable
is killed as it encourages not thinking about details that need to be
considered. A very hard to hit pid namespace exiting bug was finally
tracked and fixed. A couple of cleanups to the basic namespace
infrastructure.
Finally there is an enhancement that makes per user namespace
capabilities usable as capabilities, and an enhancement that allows
the per userns root to nice other processes in the user namespace"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/ebiederm/user-namespace:
userns: Kill nsown_capable it makes the wrong thing easy
capabilities: allow nice if we are privileged
pidns: Don't have unshare(CLONE_NEWPID) imply CLONE_THREAD
userns: Allow PR_CAPBSET_DROP in a user namespace.
namespaces: Simplify copy_namespaces so it is clear what is going on.
pidns: Fix hang in zap_pid_ns_processes by sending a potentially extra wakeup
sysfs: Restrict mounting sysfs
userns: Better restrictions on when proc and sysfs can be mounted
vfs: Don't copy mount bind mounts of /proc/<pid>/ns/mnt between namespaces
kernel/nsproxy.c: Improving a snippet of code.
proc: Restrict mounting the proc filesystem
vfs: Lock in place mounts from more privileged users
nsown_capable is a special case of ns_capable essentially for just CAP_SETUID and
CAP_SETGID. For the existing users it doesn't noticably simplify things and
from the suggested patches I have seen it encourages people to do the wrong
thing. So remove nsown_capable.
Acked-by: Serge Hallyn <serge.hallyn@canonical.com>
nsproxy.pid_ns is *not* the task's pid namespace. The name should clarify
that.
This makes it more obvious that setns on a pid namespace is weird --
it won't change the pid namespace shown in procfs.
Signed-off-by: Andy Lutomirski <luto@amacapital.net>
Reviewed-by: "Eric W. Biederman" <ebiederm@xmission.com>
Pull VFS updates from Al Viro,
Misc cleanups all over the place, mainly wrt /proc interfaces (switch
create_proc_entry to proc_create(), get rid of the deprecated
create_proc_read_entry() in favor of using proc_create_data() and
seq_file etc).
7kloc removed.
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (204 commits)
don't bother with deferred freeing of fdtables
proc: Move non-public stuff from linux/proc_fs.h to fs/proc/internal.h
proc: Make the PROC_I() and PDE() macros internal to procfs
proc: Supply a function to remove a proc entry by PDE
take cgroup_open() and cpuset_open() to fs/proc/base.c
ppc: Clean up scanlog
ppc: Clean up rtas_flash driver somewhat
hostap: proc: Use remove_proc_subtree()
drm: proc: Use remove_proc_subtree()
drm: proc: Use minor->index to label things, not PDE->name
drm: Constify drm_proc_list[]
zoran: Don't print proc_dir_entry data in debug
reiserfs: Don't access the proc_dir_entry in r_open(), r_start() r_show()
proc: Supply an accessor for getting the data from a PDE's parent
airo: Use remove_proc_subtree()
rtl8192u: Don't need to save device proc dir PDE
rtl8187se: Use a dir under /proc/net/r8180/
proc: Add proc_mkdir_data()
proc: Move some bits from linux/proc_fs.h to linux/{of.h,signal.h,tty.h}
proc: Move PDE_NET() to fs/proc/proc_net.c
Split the proc namespace stuff out into linux/proc_ns.h.
cc: netdev@vger.kernel.org
cc: Serge E. Hallyn <serge.hallyn@ubuntu.com>
cc: Eric W. Biederman <ebiederm@xmission.com>
Move BITS_PER_PAGE from pid_namespace.c to pid_namespace.h, since we can
simplify the define PID_MAP_ENTRIES by using the BITS_PER_PAGE.
[akpm@linux-foundation.org: kernel/pid.c:54:1: warning: "BITS_PER_PAGE" redefined]
Signed-off-by: Raphael S.Carvalho <raphael.scarv@gmail.com>
When a multi-threaded init exits and the initial thread is not the
last thread to exit the initial thread hangs around as a zombie
until the last thread exits. In that case zap_pid_ns_processes
needs to wait until there are only 2 hashed pids in the pid
namespace not one.
v2. Replace thread_pid_vnr(me) == 1 with the test thread_group_leader(me)
as suggested by Oleg.
Reported-by: Caj Larsson <caj@omnicloud.com>
Oleg pointed out that in a pid namespace the sequence.
- pid 1 becomes a zombie
- setns(thepidns), fork,...
- reaping pid 1.
- The injected processes exiting.
Can lead to processes attempting access their child reaper and
instead following a stale pointer.
That waitpid for init can return before all of the processes in
the pid namespace have exited is also unfortunate.
Avoid these problems by disabling the allocation of new pids in a pid
namespace when init dies, instead of when the last process in a pid
namespace is reaped.
Pointed-out-by: Oleg Nesterov <oleg@redhat.com>
Reviewed-by: Oleg Nesterov <oleg@redhat.com>
Andy Lutomirski <luto@amacapital.net> found a nasty little bug in
the permissions of setns. With unprivileged user namespaces it
became possible to create new namespaces without privilege.
However the setns calls were relaxed to only require CAP_SYS_ADMIN in
the user nameapce of the targed namespace.
Which made the following nasty sequence possible.
pid = clone(CLONE_NEWUSER | CLONE_NEWNS);
if (pid == 0) { /* child */
system("mount --bind /home/me/passwd /etc/passwd");
else if (pid != 0) { /* parent */
char path[PATH_MAX];
snprintf(path, sizeof(path), "/proc/%u/ns/mnt");
fd = open(path, O_RDONLY);
setns(fd, 0);
system("su -");
Prevent this possibility by requiring CAP_SYS_ADMIN
in the current user namespace when joing all but the user namespace.
Assign a unique proc inode to each namespace, and use that
inode number to ensure we only allocate at most one proc
inode for every namespace in proc.
A single proc inode per namespace allows userspace to test
to see if two processes are in the same namespace.
This has been a long requested feature and only blocked because
a naive implementation would put the id in a global space and
would ultimately require having a namespace for the names of
namespaces, making migration and certain virtualization tricks
impossible.
We still don't have per superblock inode numbers for proc, which
appears necessary for application unaware checkpoint/restart and
migrations (if the application is using namespace file descriptors)
but that is now allowd by the design if it becomes important.
I have preallocated the ipc and uts initial proc inode numbers so
their structures can be statically initialized.
Unsharing of the pid namespace unlike unsharing of other namespaces
does not take affect immediately. Instead it affects the children
created with fork and clone. The first of these children becomes the init
process of the new pid namespace, the rest become oddball children
of pid 0. From the point of view of the new pid namespace the process
that created it is pid 0, as it's pid does not map.
A couple of different semantics were considered but this one was
settled on because it is easy to implement and it is usable from
pam modules. The core reasons for the existence of unshare.
I took a survey of the callers of pam modules and the following
appears to be a representative sample of their logic.
setup stuff include pam
child = fork();
if (!child) {
setuid()
exec /bin/bash
waitpid(child);
pam and other cleanup
As you can see there is a fork to create the unprivileged user
space process. Which means that the unprivileged user space
process will appear as pid 1 in the new pid namespace. Further
most login processes do not cope with extraneous children which
means shifting the duty of reaping extraneous child process to
the creator of those extraneous children makes the system more
comprehensible.
The practical reason for this set of pid namespace semantics is
that it is simple to implement and verify they work correctly.
Whereas an implementation that requres changing the struct
pid on a process comes with a lot more races and pain. Not
the least of which is that glibc caches getpid().
These semantics are implemented by having two notions
of the pid namespace of a proces. There is task_active_pid_ns
which is the pid namspace the process was created with
and the pid namespace that all pids are presented to
that process in. The task_active_pid_ns is stored
in the struct pid of the task.
Then there is the pid namespace that will be used for children
that pid namespace is stored in task->nsproxy->pid_ns.
- Pid namespaces are designed to be inescapable so verify that the
passed in pid namespace is a child of the currently active
pid namespace or the currently active pid namespace itself.
Allowing the currently active pid namespace is important so
the effects of an earlier setns can be cancelled.
task_active_pid_ns(current) != current->ns_proxy->pid_ns will
soon be allowed to support unshare and setns.
The definition of creating a child pid namespace when
task_active_pid_ns(current) != current->ns_proxy->pid_ns could be that
we create a child pid namespace of current->ns_proxy->pid_ns. However
that leads to strange cases like trying to have a single process be
init in multiple pid namespaces, which is racy and hard to think
about.
we create a child pid namespace of task_active_pid_ns(current). While
that seems less racy it does not provide any utility.
Therefore define the semantics of creating a child pid namespace when
task_active_pid_ns(current) != current->ns_proxy->pid_ns to be that the
pid namespace creation fails. That is easy to implement and easy
to think about.
Looking at pid_ns->nr_hashed is a bit simpler and it works for
disjoint process trees that an unshare or a join of a pid_namespace
may create.
Acked-by: "Serge E. Hallyn" <serge@hallyn.com>
Track the number of pids in the proc hash table. When the number of
pids goes to 0 schedule work to unmount the kernel mount of proc.
Move the mount of proc into alloc_pid when we allocate the pid for
init.
Remove the surprising calls of pid_ns_release proc in fork and
proc_flush_task. Those code paths really shouldn't know about proc
namespace implementation details and people have demonstrated several
times that finding and understanding those code paths is difficult and
non-obvious.
Because of the call path detach pid is alwasy called with the
rtnl_lock held free_pid is not allowed to sleep, so the work to
unmounting proc is moved to a work queue. This has the side benefit
of not blocking the entire world waiting for the unnecessary
rcu_barrier in deactivate_locked_super.
In the process of making the code clear and obvious this fixes a bug
reported by Gao feng <gaofeng@cn.fujitsu.com> where we would leak a
mount of proc during clone(CLONE_NEWPID|CLONE_NEWNET) if copy_pid_ns
succeeded and copy_net_ns failed.
- Capture the the user namespace that creates the pid namespace
- Use that user namespace to test if it is ok to write to
/proc/sys/kernel/ns_last_pid.
Zhao Hongjiang <zhaohongjiang@huawei.com> noticed I was missing a put_user_ns
in when destroying a pid_ns. I have foloded his patch into this one
so that bisects will work properly.
'struct pid' is a "variable sized struct" - a header with an array of
upids at the end.
The size of the array depends on a level (depth) of pid namespaces. Now a
level of pidns is not limited, so 'struct pid' can be more than one page.
Looks reasonable, that it should be less than a page. MAX_PIS_NS_LEVEL is
not calculated from PAGE_SIZE, because in this case it depends on
architectures, config options and it will be reduced, if someone adds a
new fields in struct pid or struct upid.
I suggest to set MAX_PIS_NS_LEVEL = 32, because it saves ability to expand
"struct pid" and it's more than enough for all known for me use-cases.
When someone finds a reasonable use case, we can add a config option or a
sysctl parameter.
In addition it will reduce the effect of another problem, when we have
many nested namespaces and the oldest one starts dying.
zap_pid_ns_processe will be called for each namespace and find_vpid will
be called for each process in a namespace. find_vpid will be called
minimum max_level^2 / 2 times. The reason of that is that when we found a
bit in pidmap, we can't determine this pidns is top for this process or it
isn't.
vpid is a heavy operation, so a fork bomb, which create many nested
namespace, can make a system inaccessible for a long time. For example my
system becomes inaccessible for a few minutes with 4000 processes.
[akpm@linux-foundation.org: return -EINVAL in response to excessive nesting, not -ENOMEM]
Signed-off-by: Andrew Vagin <avagin@openvz.org>
Acked-by: Oleg Nesterov <oleg@redhat.com>
Cc: Cyrill Gorcunov <gorcunov@openvz.org>
free_pid_ns() operates in a recursive fashion:
free_pid_ns(parent)
put_pid_ns(parent)
kref_put(&ns->kref, free_pid_ns);
free_pid_ns
thus if there was a huge nesting of namespaces the userspace may trigger
avalanche calling of free_pid_ns leading to kernel stack exhausting and a
panic eventually.
This patch turns the recursion into an iterative loop.
Based on a patch by Andrew Vagin.
[akpm@linux-foundation.org: export put_pid_ns() to modules]
Signed-off-by: Cyrill Gorcunov <gorcunov@openvz.org>
Cc: Andrew Vagin <avagin@openvz.org>
Cc: Greg KH <greg@kroah.com>
Pull user namespace changes from Eric Biederman:
"This is a mostly modest set of changes to enable basic user namespace
support. This allows the code to code to compile with user namespaces
enabled and removes the assumption there is only the initial user
namespace. Everything is converted except for the most complex of the
filesystems: autofs4, 9p, afs, ceph, cifs, coda, fuse, gfs2, ncpfs,
nfs, ocfs2 and xfs as those patches need a bit more review.
The strategy is to push kuid_t and kgid_t values are far down into
subsystems and filesystems as reasonable. Leaving the make_kuid and
from_kuid operations to happen at the edge of userspace, as the values
come off the disk, and as the values come in from the network.
Letting compile type incompatible compile errors (present when user
namespaces are enabled) guide me to find the issues.
The most tricky areas have been the places where we had an implicit
union of uid and gid values and were storing them in an unsigned int.
Those places were converted into explicit unions. I made certain to
handle those places with simple trivial patches.
Out of that work I discovered we have generic interfaces for storing
quota by projid. I had never heard of the project identifiers before.
Adding full user namespace support for project identifiers accounts
for most of the code size growth in my git tree.
Ultimately there will be work to relax privlige checks from
"capable(FOO)" to "ns_capable(user_ns, FOO)" where it is safe allowing
root in a user names to do those things that today we only forbid to
non-root users because it will confuse suid root applications.
While I was pushing kuid_t and kgid_t changes deep into the audit code
I made a few other cleanups. I capitalized on the fact we process
netlink messages in the context of the message sender. I removed
usage of NETLINK_CRED, and started directly using current->tty.
Some of these patches have also made it into maintainer trees, with no
problems from identical code from different trees showing up in
linux-next.
After reading through all of this code I feel like I might be able to
win a game of kernel trivial pursuit."
Fix up some fairly trivial conflicts in netfilter uid/git logging code.
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/ebiederm/user-namespace: (107 commits)
userns: Convert the ufs filesystem to use kuid/kgid where appropriate
userns: Convert the udf filesystem to use kuid/kgid where appropriate
userns: Convert ubifs to use kuid/kgid
userns: Convert squashfs to use kuid/kgid where appropriate
userns: Convert reiserfs to use kuid and kgid where appropriate
userns: Convert jfs to use kuid/kgid where appropriate
userns: Convert jffs2 to use kuid and kgid where appropriate
userns: Convert hpfs to use kuid and kgid where appropriate
userns: Convert btrfs to use kuid/kgid where appropriate
userns: Convert bfs to use kuid/kgid where appropriate
userns: Convert affs to use kuid/kgid wherwe appropriate
userns: On alpha modify linux_to_osf_stat to use convert from kuids and kgids
userns: On ia64 deal with current_uid and current_gid being kuid and kgid
userns: On ppc convert current_uid from a kuid before printing.
userns: Convert s390 getting uid and gid system calls to use kuid and kgid
userns: Convert s390 hypfs to use kuid and kgid where appropriate
userns: Convert binder ipc to use kuids
userns: Teach security_path_chown to take kuids and kgids
userns: Add user namespace support to IMA
userns: Convert EVM to deal with kuids and kgids in it's hmac computation
The kernel doesn't check the pid for negative values, so if you try to
write -2 to /proc/sys/kernel/ns_last_pid, you will get a kernel panic.
The crash happens because the next pid is -1, and alloc_pidmap() will
try to access to a nonexistent pidmap.
map = &pid_ns->pidmap[pid/BITS_PER_PAGE];
Acked-by: Cyrill Gorcunov <gorcunov@openvz.org>
Cc: Eric W. Biederman <ebiederm@xmission.com>
There is a least one modular user so export free_pid_ns so modules can
capture and use the pid namespace on the very rare occasion when it
makes sense.
Today we have a twofold bug. Sometimes release_task on pid == 1 in a pid
namespace can run before other processes in a pid namespace have had
release task called. With the result that pid_ns_release_proc can be
called before the last proc_flus_task() is done using upid->ns->proc_mnt,
resulting in the use of a stale pointer. This same set of circumstances
can lead to waitpid(...) returning for a processes started with
clone(CLONE_NEWPID) before the every process in the pid namespace has
actually exited.
To fix this modify zap_pid_ns_processess wait until all other processes in
the pid namespace have exited, even EXIT_DEAD zombies.
The delay_group_leader and related tests ensure that the thread gruop
leader will be the last thread of a process group to be reaped, or to
become EXIT_DEAD and self reap. With the change to zap_pid_ns_processes
we get the guarantee that pid == 1 in a pid namespace will be the last
task that release_task is called on.
With pid == 1 being the last task to pass through release_task
pid_ns_release_proc can no longer be called too early nor can wait return
before all of the EXIT_DEAD tasks in a pid namespace have exited.
Cc: Louis Rilling <louis.rilling@kerlabs.com>
Acked-by: Pavel Emelyanov <xemul@parallels.com>
Tested-by: Andrew Wagin <avagin@gmail.com>
For those who doesn't need C/R functionality there is no need to control
last pid, ie the pid for the next fork() call.
Cc: Tejun Heo <tj@kernel.org>
Force SIGCHLD handling to SIG_IGN so that signals are not generated and so
that the children autoreap. This increases the parallelize and in general
the speed of network namespace shutdown.
Note self reaping childrean can exist past zap_pid_ns_processess but they
will all be reaped before we allow the pid namespace init task with pid ==
1 to be reaped.
[akpm@linux-foundation.org: checkpatch fixes]
In the case of a child pid namespace, rebooting the system does not really
makes sense. When the pid namespace is used in conjunction with the other
namespaces in order to create a linux container, the reboot syscall leads
to some problems.
A container can reboot the host. That can be fixed by dropping the
sys_reboot capability but we are unable to correctly to poweroff/
halt/reboot a container and the container stays stuck at the shutdown time
with the container's init process waiting indefinitively.
After several attempts, no solution from userspace was found to reliabily
handle the shutdown from a container.
This patch propose to make the init process of the child pid namespace to
exit with a signal status set to : SIGINT if the child pid namespace
called "halt/poweroff" and SIGHUP if the child pid namespace called
"reboot". When the reboot syscall is called and we are not in the initial
pid namespace, we kill the pid namespace for "HALT", "POWEROFF",
"RESTART", and "RESTART2". Otherwise we return EINVAL.
Returning EINVAL is also an easy way to check if this feature is supported
by the kernel when invoking another 'reboot' option like CAD.
By this way the parent process of the child pid namespace knows if it
rebooted or not and can take the right decision.
Test case:
#include <alloca.h>
#include <stdio.h>
#include <sched.h>
#include <unistd.h>
#include <signal.h>
#include <sys/reboot.h>
#include <sys/types.h>
#include <sys/wait.h>
#include <linux/reboot.h>
static int do_reboot(void *arg)
int *cmd = arg;
if (reboot(*cmd))
printf("failed to reboot(%d): %m\n", *cmd);
int test_reboot(int cmd, int sig)
long stack_size = 4096;
void *stack = alloca(stack_size) + stack_size;
int status;
pid_t ret;
ret = clone(do_reboot, stack, CLONE_NEWPID | SIGCHLD, &cmd);
if (ret < 0) {
printf("failed to clone: %m\n");
return -1;
if (wait(&status) < 0) {
printf("unexpected wait error: %m\n");
return -1;
if (!WIFSIGNALED(status)) {
printf("child process exited but was not signaled\n");
return -1;
if (WTERMSIG(status) != sig) {
printf("signal termination is not the one expected\n");
return -1;
return 0;
int main(int argc, char *argv[])
int status;
status = test_reboot(LINUX_REBOOT_CMD_RESTART, SIGHUP);
if (status < 0)
return 1;
printf("reboot(LINUX_REBOOT_CMD_RESTART) succeed\n");
status = test_reboot(LINUX_REBOOT_CMD_RESTART2, SIGHUP);
if (status < 0)
return 1;
printf("reboot(LINUX_REBOOT_CMD_RESTART2) succeed\n");
status = test_reboot(LINUX_REBOOT_CMD_HALT, SIGINT);
if (status < 0)
return 1;
printf("reboot(LINUX_REBOOT_CMD_HALT) succeed\n");
status = test_reboot(LINUX_REBOOT_CMD_POWER_OFF, SIGINT);
if (status < 0)
return 1;
printf("reboot(LINUX_REBOOT_CMD_POWERR_OFF) succeed\n");
status = test_reboot(LINUX_REBOOT_CMD_CAD_ON, -1);
if (status >= 0) {
printf("reboot(LINUX_REBOOT_CMD_CAD_ON) should have failed\n");
return 1;
printf("reboot(LINUX_REBOOT_CMD_CAD_ON) has failed as expected\n");
return 0;
[akpm@linux-foundation.org: tweak and add comments]
Signed-off-by: Daniel Lezcano <daniel.lezcano@free.fr>
Tested-by: Serge Hallyn <serge.hallyn@canonical.com>
Cc: Michael Kerrisk <mtk.manpages@gmail.com>
Change zap_pid_ns_processes() to use SEND_SIG_FORCED, it looks more
clear compared to SEND_SIG_NOINFO which relies on from_ancestor_ns logic
send_signal().
It is also more efficient if we need to kill a lot of tasks because it
doesn't alloc sigqueue.
While at it, add the __fatal_signal_pending(task) check as a minor
optimization.
Cc: Anton Vorontsov <anton.vorontsov@linaro.org>
Cc: KOSAKI Motohiro <kosaki.motohiro@gmail.com>
The sysctl works on the current task's pid namespace, getting and setting
its last_pid field.
Writing is allowed for CAP_SYS_ADMIN-capable tasks thus making it possible
to create a task with desired pid value. This ability is required badly
for the checkpoint/restore in userspace.
This approach suits all the parties for now.
Signed-off-by: Pavel Emelyanov <xemul@parallels.com>
Acked-by: Tejun Heo <tj@kernel.org>
Cc: Serge Hallyn <serue@us.ibm.com>
Reorganize proc_get_sb() so it can be called before the struct pid of the
first process is allocated.
Cc: Alexey Dobriyan <adobriyan@gmail.com>
Acked-by: Serge E. Hallyn <serge@hallyn.com>
