path: root/kernel/pm_qos_params.c
2011-05-29Merge branch 'idle-release' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-idle-2.6 * 'idle-release' of git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-idle-2.6: x86 idle: deprecate mwait_idle() and "idle=mwait" cmdline param x86 idle: deprecate "no-hlt" cmdline param x86 idle APM: deprecate CONFIG_APM_CPU_IDLE x86 idle floppy: deprecate disable_hlt() x86 idle: EXPORT_SYMBOL(default_idle, pm_idle) only when APM demands it x86 idle: clarify AMD erratum 400 workaround idle governor: Avoid lock acquisition to read pm_qos before entering idle cpuidle: menu: fixed wrapping timers at 4.294 seconds
2011-05-29idle governor: Avoid lock acquisition to read pm_qos before entering idleTim Chen
Thanks to the reviews and comments by Rafael, James, Mark and Andi. Here's version 2 of the patch incorporating your comments and also some update to my previous patch comments. I noticed that before entering idle state, the menu idle governor will look up the current pm_qos target value according to the list of qos requests received. This look up currently needs the acquisition of a lock to access the list of qos requests to find the qos target value, slowing down the entrance into idle state due to contention by multiple cpus to access this list. The contention is severe when there are a lot of cpus waking and going into idle. For example, for a simple workload that has 32 pair of processes ping ponging messages to each other, where 64 cpu cores are active in test system, I see the following profile with 37.82% of cpu cycles spent in contention of pm_qos_lock: - 37.82% swapper [kernel.kallsyms] [k] _raw_spin_lock_irqsave - _raw_spin_lock_irqsave - 95.65% pm_qos_request menu_select cpuidle_idle_call - cpu_idle 99.98% start_secondary A better approach will be to cache the updated pm_qos target value so reading it does not require lock acquisition as in the patch below. With this patch the contention for pm_qos_lock is removed and I saw a 2.2X increase in throughput for my message passing workload. cc: stable@kernel.org Signed-off-by: Tim Chen <tim.c.chen@linux.intel.com> Acked-by: Andi Kleen <ak@linux.intel.com> Acked-by: James Bottomley <James.Bottomley@suse.de> Acked-by: mark gross <markgross@thegnar.org> Signed-off-by: Len Brown <len.brown@intel.com>
2011-05-27Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rafael/suspend-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/suspend-2.6: PM: Fix PM QOS's user mode interface to work with ASCII input PM / Hibernate: Update kerneldoc comments in hibernate.c PM / Hibernate: Remove arch_prepare_suspend() PM / Hibernate: Update some comments in core hibernate code
2011-05-27PM: Fix PM QOS's user mode interface to work with ASCII inputRafael J. Wysocki
Make pm_qos_power_write() accept values passed to it in the ASCII hex format either with or without an ending newline. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Acked-by: Mark Gross <markgross@thegnar.org>
2011-04-10treewide: remove extra semicolonsJustin P. Mattock
Signed-off-by: Justin P. Mattock <justinmattock@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2011-03-15PM QoS: Make pm_qos settings readableThomas Renninger
I have a machine where entering deep C-states broke. pm_qos was a hot candidate, but I couldn't find any way to double check without the need of recompiling. While in this case it was a driver bug (ath9k): https://bugzilla.kernel.org/show_bug.cgi?id=27532 powertop or others may want to read out cpu_dma_latency restrictions which could be the cause of preventing a machine entering deeper C-states. Output with this patch: # default value of 2000 * USEC_PER_SEC (0x77359400) cat /dev/network_latency |hexdump 0000000 9400 7735 0000004 # value of 55 us which is the reason for not entering C2 cat /dev/cpu_dma_latency |hexdump 0000000 0037 0000 0000004 There is no reason to hide this info -> make pm_qos files readable. Signed-off-by: Thomas Renninger <trenn@suse.de> Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl>
2010-11-15PM / PM QoS: Fix reversed min and maxColin Cross
pm_qos_get_value had min and max reversed, causing all pm_qos requests to have no effect. Signed-off-by: Colin Cross <ccross@android.com> Acked-by: mark <markgross@thegnar.org> Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Cc: stable@kernel.org
2010-10-24Merge branch 'for-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (39 commits) Update broken web addresses in arch directory. Update broken web addresses in the kernel. Revert "drivers/usb: Remove unnecessary return's from void functions" for musb gadget Revert "Fix typo: configuation => configuration" partially ida: document IDA_BITMAP_LONGS calculation ext2: fix a typo on comment in ext2/inode.c drivers/scsi: Remove unnecessary casts of private_data drivers/s390: Remove unnecessary casts of private_data net/sunrpc/rpc_pipe.c: Remove unnecessary casts of private_data drivers/infiniband: Remove unnecessary casts of private_data drivers/gpu/drm: Remove unnecessary casts of private_data kernel/pm_qos_params.c: Remove unnecessary casts of private_data fs/ecryptfs: Remove unnecessary casts of private_data fs/seq_file.c: Remove unnecessary casts of private_data arm: uengine.c: remove C99 comments arm: scoop.c: remove C99 comments Fix typo configue => configure in comments Fix typo: configuation => configuration Fix typo interrest[ing|ed] => interest[ing|ed] Fix various typos of valid in comments ... Fix up trivial conflicts in: drivers/char/ipmi/ipmi_si_intf.c drivers/usb/gadget/rndis.c net/irda/irnet/irnet_ppp.c
All file_operations should get a .llseek operation so we can make nonseekable_open the default for future file operations without a .llseek pointer. The three cases that we can automatically detect are no_llseek, seq_lseek and default_llseek. For cases where we can we can automatically prove that the file offset is always ignored, we use noop_llseek, which maintains the current behavior of not returning an error from a seek. New drivers should normally not use noop_llseek but instead use no_llseek and call nonseekable_open at open time. Existing drivers can be converted to do the same when the maintainer knows for certain that no user code relies on calling seek on the device file. The generated code is often incorrectly indented and right now contains comments that clarify for each added line why a specific variant was chosen. In the version that gets submitted upstream, the comments will be gone and I will manually fix the indentation, because there does not seem to be a way to do that using coccinelle. Some amount of new code is currently sitting in linux-next that should get the same modifications, which I will do at the end of the merge window. Many thanks to Julia Lawall for helping me learn to write a semantic patch that does all this. ===== begin semantic patch ===== // This adds an llseek= method to all file operations, // as a preparation for making no_llseek the default. // // The rules are // - use no_llseek explicitly if we do nonseekable_open // - use seq_lseek for sequential files // - use default_llseek if we know we access f_pos // - use noop_llseek if we know we don't access f_pos, // but we still want to allow users to call lseek // @ open1 exists @ identifier nested_open; @@ nested_open(...) { <+... nonseekable_open(...) ...+> } @ open exists@ identifier open_f; identifier i, f; identifier open1.nested_open; @@ int open_f(struct inode *i, struct file *f) { <+... ( nonseekable_open(...) | nested_open(...) ) ...+> } @ read disable optional_qualifier exists @ identifier read_f; identifier f, p, s, off; type ssize_t, size_t, loff_t; expression E; identifier func; @@ ssize_t read_f(struct file *f, char *p, size_t s, loff_t *off) { <+... ( *off = E | *off += E | func(..., off, ...) | E = *off ) ...+> } @ read_no_fpos disable optional_qualifier exists @ identifier read_f; identifier f, p, s, off; type ssize_t, size_t, loff_t; @@ ssize_t read_f(struct file *f, char *p, size_t s, loff_t *off) { ... when != off } @ write @ identifier write_f; identifier f, p, s, off; type ssize_t, size_t, loff_t; expression E; identifier func; @@ ssize_t write_f(struct file *f, const char *p, size_t s, loff_t *off) { <+... ( *off = E | *off += E | func(..., off, ...) | E = *off ) ...+> } @ write_no_fpos @ identifier write_f; identifier f, p, s, off; type ssize_t, size_t, loff_t; @@ ssize_t write_f(struct file *f, const char *p, size_t s, loff_t *off) { ... when != off } @ fops0 @ identifier fops; @@ struct file_operations fops = { ... }; @ has_llseek depends on fops0 @ identifier fops0.fops; identifier llseek_f; @@ struct file_operations fops = { ... .llseek = llseek_f, ... }; @ has_read depends on fops0 @ identifier fops0.fops; identifier read_f; @@ struct file_operations fops = { ... .read = read_f, ... }; @ has_write depends on fops0 @ identifier fops0.fops; identifier write_f; @@ struct file_operations fops = { ... .write = write_f, ... }; @ has_open depends on fops0 @ identifier fops0.fops; identifier open_f; @@ struct file_operations fops = { ... .open = open_f, ... }; // use no_llseek if we call nonseekable_open //////////////////////////////////////////// @ nonseekable1 depends on !has_llseek && has_open @ identifier fops0.fops; identifier nso ~= "nonseekable_open"; @@ struct file_operations fops = { ... .open = nso, ... +.llseek = no_llseek, /* nonseekable */ }; @ nonseekable2 depends on !has_llseek @ identifier fops0.fops; identifier open.open_f; @@ struct file_operations fops = { ... .open = open_f, ... +.llseek = no_llseek, /* open uses nonseekable */ }; // use seq_lseek for sequential files ///////////////////////////////////// @ seq depends on !has_llseek @ identifier fops0.fops; identifier sr ~= "seq_read"; @@ struct file_operations fops = { ... .read = sr, ... +.llseek = seq_lseek, /* we have seq_read */ }; // use default_llseek if there is a readdir /////////////////////////////////////////// @ fops1 depends on !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; identifier readdir_e; @@ // any other fop is used that changes pos struct file_operations fops = { ... .readdir = readdir_e, ... +.llseek = default_llseek, /* readdir is present */ }; // use default_llseek if at least one of read/write touches f_pos ///////////////////////////////////////////////////////////////// @ fops2 depends on !fops1 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; identifier read.read_f; @@ // read fops use offset struct file_operations fops = { ... .read = read_f, ... +.llseek = default_llseek, /* read accesses f_pos */ }; @ fops3 depends on !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; identifier write.write_f; @@ // write fops use offset struct file_operations fops = { ... .write = write_f, ... + .llseek = default_llseek, /* write accesses f_pos */ }; // Use noop_llseek if neither read nor write accesses f_pos /////////////////////////////////////////////////////////// @ fops4 depends on !fops1 && !fops2 && !fops3 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; identifier read_no_fpos.read_f; identifier write_no_fpos.write_f; @@ // write fops use offset struct file_operations fops = { ... .write = write_f, .read = read_f, ... +.llseek = noop_llseek, /* read and write both use no f_pos */ }; @ depends on has_write && !has_read && !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; identifier write_no_fpos.write_f; @@ struct file_operations fops = { ... .write = write_f, ... +.llseek = noop_llseek, /* write uses no f_pos */ }; @ depends on has_read && !has_write && !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; identifier read_no_fpos.read_f; @@ struct file_operations fops = { ... .read = read_f, ... +.llseek = noop_llseek, /* read uses no f_pos */ }; @ depends on !has_read && !has_write && !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; @@ struct file_operations fops = { ... +.llseek = noop_llseek, /* no read or write fn */ }; ===== End semantic patch ===== Signed-off-by: Arnd Bergmann <arnd@arndb.de> Cc: Julia Lawall <julia@diku.dk> Cc: Christoph Hellwig <hch@infradead.org>
2010-09-23kernel/pm_qos_params.c: Remove unnecessary casts of private_dataJoe Perches
Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2010-09-11PM QoS: Correct pr_debug() misuse and improve parameter checksmark gross
Correct some pr_debug() misuse and add a stronger parameter check to pm_qos_write() for the ASCII hex value case. Thanks to Dan Carpenter for pointing out the problem! Signed-off-by: mark gross <markgross@thegnar.org> Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl>
2010-08-26PM QoS: Fix inline documentation.Saravana Kannan
Fix the pm_qos_add_request() kerneldoc comment that doesn't reflect the behavior of the function after the last PM QoS update. Signed-off-by: Saravana Kannan <skannan@codeaurora.org> Acked-by: mark gross <markgross@thegnar.org> Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl>
2010-08-24PM QoS: Fix kzalloc() parameters swapped in pm_qos_power_open()David Alan Gilbert
sparse spotted that the kzalloc() in pm_qos_power_open() in the current Linus' git tree had its parameters swapped. Fix this. Signed-off-by: David Alan Gilbert <linux@treblig.org> Acked-by: mark gross <markgross@thegnar.org> Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl>
2010-07-19pm_qos: Get rid of the allocation in pm_qos_add_request()James Bottomley
All current users of pm_qos_add_request() have the ability to supply the memory required by the pm_qos routines, so make them do this and eliminate the kmalloc() with pm_qos_add_request(). This has the double benefit of making the call never fail and allowing it to be called from atomic context. Signed-off-by: James Bottomley <James.Bottomley@suse.de> Signed-off-by: mark gross <markgross@thegnar.org> Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl>
2010-07-19pm_qos: Reimplement using plistsJames Bottomley
A lot of the pm_qos extremal value handling is really duplicating what a priority ordered list does, just in a less efficient fashion. Simply redoing the implementation in terms of a plist gets rid of a lot of this junk (although there are several other strange things that could do with tidying up, like pm_qos_request_list has to carry the pm_qos_class with every node, simply because it doesn't get passed in to pm_qos_update_request even though every caller knows full well what parameter it's updating). I think this redo is a win independent of android, so we should do something like this now. Signed-off-by: James Bottomley <James.Bottomley@suse.de> Signed-off-by: mark gross <markgross@thegnar.org> Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl>
2010-05-17PM: PM QOS update fixMark Gross
This update handles a use case where pm_qos update requests need to silently fail if the update is being sent to a handle that is NULL. The problem was that the original pm_qos silently fails when a request update is passed to a parameter that has not been added to the list yet. This update restores that behavior. Signed-off-by: markgross <markgross@thegnar.org> Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl>
2010-05-10PM QOS updateMark Gross
This patch changes the string based list management to a handle base implementation to help with the hot path use of pm-qos, it also renames much of the API to use "request" as opposed to "requirement" that was used in the initial implementation. I did this because request more accurately represents what it actually does. Also, I added a string based ABI for users wanting to use a string interface. So if the user writes 0xDDDDDDDD formatted hex it will be accepted by the interface. (someone asked me for it and I don't think it hurts anything.) This patch updates some documentation input I got from Randy. Signed-off-by: markgross <mgross@linux.intel.com> Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl>
2009-10-14pm_qos: clean up racy global "name" variableJonathan Corbet
"name" is a poor name for a file-global variable. It was used in three different functions, with no mutual exclusion. But it's just a tiny, temporary string; let's just move it onto the stack in the functions that need it. Also use snprintf() just in case. Signed-off-by: Jonathan Corbet <corbet@lwn.net> LKML-Reference: <20091010153349.113570550@linutronix.de> Acked-by: Mark Gross <mgross@linux.intel.com> Reviewed-by: Frederic Weisbecker <fweisbec@gmail.com> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2009-10-14pm_qos: remove BKLJonathan Corbet
pm_qos_power_open got its lock_kernel() calls from the open() pushdown. A look at the code shows that the only global resources accessed are pm_qos_array and "name". pm_qos_array doesn't change (things pointed to therein do change, but they are atomics and/or are protected by pm_qos_lock). Accesses to "name" are totally unprotected with or without the BKL; that will be fixed shortly. The BKL is not helpful here; take it out. Signed-off-by: Jonathan Corbet <corbet@lwn.net> LKML-Reference: <20091010153349.071381158@linutronix.de> Acked-by: Mark Gross <mgross@linux.intel.com> Reviewed-by: Frederic Weisbecker <fweisbec@gmail.com> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-09-02pm_qos_requirement might sleepJohn Kacur
Make PM_QOS and CPU_IDLE play nicer when run with the RT-Preempt kernel. The purpose of the patch is to remove the spin_lock around the read in the function pm_qos_requirement - since spinlocks can sleep in -rt and this function is called from idle. CPU_IDLE polls the target_value's of some of the pm_qos parameters from the idle loop causing sleeping locking warnings. Changing the target_value to an atomic avoids this issue. Remove the spinlock in pm_qos_requirement by making target_value an atomic type. Signed-off-by: mark gross <mgross@linux.intel.com> Signed-off-by: John Kacur <jkacur@gmail.com> Cc: Steven Rostedt <rostedt@goodmis.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-08-05pm_qos: spelling fixesRichard Hughes
A documentation cleanup patch. With a minor tweak to clarify units for kbs. [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: mark gross <mgross@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-02pm_qos_params: BKL pushdownArnd Bergmann
[jmc: added <linux/smp_lock.h>] Signed-off-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Jonathan Corbet <corbet@lwn.net>
2008-02-05pm qos infrastructure and interfaceMark Gross
The following patch is a generalization of the latency.c implementation done by Arjan last year. It provides infrastructure for more than one parameter, and exposes a user mode interface for processes to register pm_qos expectations of processes. This interface provides a kernel and user mode interface for registering performance expectations by drivers, subsystems and user space applications on one of the parameters. Currently we have {cpu_dma_latency, network_latency, network_throughput} as the initial set of pm_qos parameters. The infrastructure exposes multiple misc device nodes one per implemented parameter. The set of parameters implement is defined by pm_qos_power_init() and pm_qos_params.h. This is done because having the available parameters being runtime configurable or changeable from a driver was seen as too easy to abuse. For each parameter a list of performance requirements is maintained along with an aggregated target value. The aggregated target value is updated with changes to the requirement list or elements of the list. Typically the aggregated target value is simply the max or min of the requirement values held in the parameter list elements. >From kernel mode the use of this interface is simple: pm_qos_add_requirement(param_id, name, target_value): Will insert a named element in the list for that identified PM_QOS parameter with the target value. Upon change to this list the new target is recomputed and any registered notifiers are called only if the target value is now different. pm_qos_update_requirement(param_id, name, new_target_value): Will search the list identified by the param_id for the named list element and then update its target value, calling the notification tree if the aggregated target is changed. with that name is already registered. pm_qos_remove_requirement(param_id, name): Will search the identified list for the named element and remove it, after removal it will update the aggregate target and call the notification tree if the target was changed as a result of removing the named requirement. >From user mode: Only processes can register a pm_qos requirement. To provide for automatic cleanup for process the interface requires the process to register its parameter requirements in the following way: To register the default pm_qos target for the specific parameter, the process must open one of /dev/[cpu_dma_latency, network_latency, network_throughput] As long as the device node is held open that process has a registered requirement on the parameter. The name of the requirement is "process_<PID>" derived from the current->pid from within the open system call. To change the requested target value the process needs to write a s32 value to the open device node. This translates to a pm_qos_update_requirement call. To remove the user mode request for a target value simply close the device node. [akpm@linux-foundation.org: fix warnings] [akpm@linux-foundation.org: fix build] [akpm@linux-foundation.org: fix build again] [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: mark gross <mgross@linux.intel.com> Cc: "John W. Linville" <linville@tuxdriver.com> Cc: Len Brown <lenb@kernel.org> Cc: Jaroslav Kysela <perex@suse.cz> Cc: Takashi Iwai <tiwai@suse.de> Cc: Arjan van de Ven <arjan@infradead.org> Cc: Venki Pallipadi <venkatesh.pallipadi@intel.com> Cc: Adam Belay <abelay@novell.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
