path: root/kernel/power/autosleep.c
2013-07-15PM / Sleep: avoid 'autosleep' in shutdown progressLiu ShuoX
Prevent automatic system suspend from happening during system shutdown by making try_to_suspend() check system_state and return immediately if it is not SYSTEM_RUNNING. This prevents the following breakage from happening (scenario from Zhang Yanmin): Kernel starts shutdown and calls all device driver's shutdown callback. When a driver's shutdown is called, the last wakelock is released and suspend-to-ram starts. However, as some driver's shut down callbacks already shut down devices and disabled runtime pm, the suspend-to-ram calls driver's suspend callback without noticing that device is already off and causes crash. [rjw: Changelog] Signed-off-by: Liu ShuoX <shuox.liu@intel.com> Cc: 3.5+ <stable@vger.kernel.org> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2013-01-26PM: don't use [delayed_]work_pending()Tejun Heo
There's no need to test whether a (delayed) work item is pending before queueing, flushing or cancelling it, so remove work_pending() tests used in those cases. Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2012-05-01PM / Sleep: Add "prevent autosleep time" statistics to wakeup sourcesRafael J. Wysocki
Android uses one wakelock statistics that is only necessary for opportunistic sleep. Namely, the prevent_suspend_time field accumulates the total time the given wakelock has been locked while "automatic suspend" was enabled. Add an analogous field, prevent_sleep_time, to wakeup sources and make it behave in a similar way. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Acked-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-05-01PM / Sleep: Implement opportunistic sleep, v2Rafael J. Wysocki
Introduce a mechanism by which the kernel can trigger global transitions to a sleep state chosen by user space if there are no active wakeup sources. It consists of a new sysfs attribute, /sys/power/autosleep, that can be written one of the strings returned by reads from /sys/power/state, an ordered workqueue and a work item carrying out the "suspend" operations. If a string representing the system's sleep state is written to /sys/power/autosleep, the work item triggering transitions to that state is queued up and it requeues itself after every execution until user space writes "off" to /sys/power/autosleep. That work item enables the detection of wakeup events using the functions already defined in drivers/base/power/wakeup.c (with one small modification) and calls either pm_suspend(), or hibernate() to put the system into a sleep state. If a wakeup event is reported while the transition is in progress, it will abort the transition and the "system suspend" work item will be queued up again. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Acked-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Reviewed-by: NeilBrown <neilb@suse.de>
