path: root/kernel/power
2006-08-03remove obsolete swsusp_encryptPavel Machek
Remove SWSUSP_ENCRYPT config option; it is no longer implemented. Signed-off-by: Pavel Machek <pavel@suse.cz> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-04-17[PATCH] Fix suspend with traced tasksPavel Machek
strace /bin/bash misbehaves after resume; this fixes it. (akpm: it's scary calling refrigerator() in state TASK_TRACED, but it seems to do the right thing). Signed-off-by: Pavel Machek <pavel@suse.cz> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-02-17[PATCH] swsusp: fix breakage with swap on LVMRafael J. Wysocki
Restore the compatibility with the older code and make it possible to suspend if the kernel command line doesn't contain the "resume=" argument Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Cc: Pavel Machek <pavel@ucw.cz> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-02-15[PATCH] swsusp: nuke noisy messageAndrew Morton
I get about 88 squillion of these when suspending an old ad450nx server. Cc: Pavel Roskin <proski@gnu.org> Cc: "Rafael J. Wysocki" <rjw@sisk.pl> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-02-07[PATCH] Fix build failure in recent pm_prepare_* changes.Rafael J. Wysocki
Fix compilation problem in PM headers. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-02-07[PATCH] swsusp: kill unneeded/unbalanced bio_getPavel Machek
- Remove unneeded bio_get() which would cause a bio leak - Writing doesn't dirty pages. Reading dirties pages. - We should dirty the pages after the IO completion, not before (Busy-waiting for disk I/O completion isn't very polite.) Signed-off-by: Pavel Machek <pavel@suse.cz> Cc: "Rafael J. Wysocki" <rjw@sisk.pl> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-02-01Merge branch 'release' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-acpi-2.6
2006-02-01[PATCH] swsusp: do not change log level during suspend/resumeRafael J. Wysocki
Prevent the kernel from setting the log level to 10 unconditionally during suspend/resume which was needed in the past for debugging, but generally is undesirable. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Acked-by: Pavel Machek <pavel@suse.cz> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-02-01[PATCH] swsusp: use bytes as image size unitsRafael J. Wysocki
Make swsusp use bytes as the image size units, which is needed for future compatibility. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Acked-by: Pavel Machek <pavel@ucw.cz> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-24[ACPI] merge 3549 4320 4485 4588 4980 5483 5651 acpica asus fops pnpacpi ↵Len Brown
branches into release Signed-off-by: Len Brown <len.brown@intel.com>
2006-01-15SOFTWARE_SUSPEND: fix a typo in the dependenciesAdrian Bunk
This patch fixes a typo in the dependencies of SOFTWARE_SUSPEND. This patch is based on a report by Jean-Luc Leger <reiga@dspnet.fr.eu.org>. Signed-off-by: Adrian Bunk <bunk@stusta.de> Acked-by: Pavel Machek <pavel@ucw.cz>
2006-01-06[PATCH] swsusp: save image header firstRafael J. Wysocki
This makes the swsusp_info structure become the header of the image in the literal sense (ie. it is saved to the swap and read before any other image data with the help of the swsusp's swap map structure, so generally it is treated in the same way as the rest of the image). The main thing it does is to make swsusp_header contain the offset of the swap map used to track the image data pages rather than the offset of swsusp_info.  Simultaneously, swsusp_info becomes the first image page written to the swap. The other changes are generally consequences of the above with a few exceptions (there's some consolidation in the image reading part as a few functions turn into trivial wrappers around something else). Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Acked-by: Pavel Machek <pavel@suse.cz> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-06[PATCH] swsusp: improve handling of swap partitionsRafael J. Wysocki
This changes the handling of swap partitions by swsusp to avoid locking of the swap devices that are not used for suspend and, consequently, simplifies the code. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Acked-by: Pavel Machek <pavel@ucw.cz> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-06[PATCH] swsusp: make image size limit tunableRafael J. Wysocki
Make the suspend image size limit tunable via /sys/power/image_size. It is necessary for systems on which there is a limited amount of swap available for suspend. It can also be useful for optimizing performance of swsusp on systems with 1 GB of RAM or more. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Acked-by: Pavel Machek <pavel@ucw.cz> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-06[PATCH] swsusp: limit image sizeRafael J. Wysocki
Limit the size of the suspend image to approx. 500 MB, which should improve the overall performance of swsusp on systems with more than 1 GB of RAM. It introduces the constant IMAGE_SIZE that can be set to the preferred size of the image (in MB) and modifies the memory-shrinking part of swsusp to take this constant into account (500 is the default value of IMAGE_SIZE). Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Acked-by: Pavel Machek <pavel@ucw.cz> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-06[PATCH] swsusp: Drop duplicate prototypesPavel Machek
These two prototypes are already present in sched.h, remove duplicate version. Signed-off-by: Pavel Machek <pavel@suse.cz> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-06[PATCH] swsusp: fix enough_free_memRafael J. Wysocki
This patch fixes a problem with the function enough_free_mem() used by swsusp to verify if there is a sufficient number of memory pages available to it to create and save the suspend image. Namely, enough_free_mem() uses nr_free_pages() to obtain the number of free memory pages, which is incorrect, because this function returns the total number of free pages, including free highmem pages, and the highmem pages cannot be used by swsusp for storing the image data. The patch makes enough_free_mem() avoid counting the free highmem pages as available to swsusp. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-06[PATCH] swsusp: improve freeing of memoryRafael J. Wysocki
This patch makes swsusp free only as much memory as needed to complete the suspend and not as much as possible.  In the most of cases this should speed up the suspend and make the system much more responsive after resume, especially if a GUI (eg. X Windows) is used. If needed, the old behavior (ie to free as much memory as possible during suspend) can be restored by unsetting FAST_FREE in power.h Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Acked-by: Pavel Machek <pavel@suse.cz> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-06[PATCH] swsusp: introduce the swap map structureRafael J. Wysocki
This patch introduces the swap map structure that can be used by swsusp for keeping tracks of data pages written to the swap.  The structure itself is described in a comment within the patch. The overall idea is to reduce the amount of metadata written to the swap and to write and read the image pages sequentially, in a file-alike way. This makes the swap-handling part of swsusp fairly independent of its snapshot-handling part and will hopefully allow us to completely separate these two parts in the future. This patch is needed to remove the suspend image size limit imposed by the limited size of the swsusp_info structure, which is essential for x86-64 systems with more than 512 MB of RAM. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Acked-by: Pavel Machek <pavel@suse.cz> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-06[PATCH] swsusp: remove encryptionRafael J. Wysocki
This patch removes the image encryption that is only used by swsusp instead of zeroing the image after resume in order to prevent someone from reading some confidential data from it in the future and it does not protect the image from being read by an unauthorized person before resume. The functionality it provides should really belong to the user space and will possibly be reimplemented after the swap-handling functionality of swsusp is moved to the user space. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Acked-by: Pavel Machek <pavel@suse.cz> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-06[PATCH] swsusp: resume_store() retval fixAndrew Morton
- This function returns -EINVAL all the time. Fix. - Decruftify it a bit too. - Writing to it doesn't seem to do what it's suppoed to do. Cc: Pavel Machek <pavel@ucw.cz> Cc: "Rafael J. Wysocki" <rjw@sisk.pl> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-12-15[ACPI] fix reboot upon suspend-to-diskAlexey Starikovskiy
http://bugzilla.kernel.org/show_bug.cgi?id=4320 Signed-off-by: Alexey Starikovskiy <alexey.y.starikovskiy@intel.com> Acked-by: Pavel Machek <pavel@suse.cz> Signed-off-by: Len Brown <len.brown@intel.com>
2005-11-30[ACPI] SMP S3 resume: evaluate _WAK after INITDavid Shaohua Li
On SMP resume from S3, we reset (INIT) the non-boot processors to boot them cleanly. But the BIOS needs to execute _WAK after INIT in order to properly initialized these processors upon resume. http://bugzilla.kernel.org/show_bug.cgi?id=5651 Signed-off-by: David Shaohua Li <shaohua.li@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2005-11-29[PATCH] fix swsusp on machines not supporting S4Pavel Machek
Fix swsusp on machines not supporting S4. With recent changes, it is not possible to trigger it using /sys filesystem. Swsusp does not really need any support from low-level code, it is possible to reboot or halt at the end of suspend. Signed-off-by: Pavel Machek <pavel@suse.cz> Cc: "Brown, Len" <len.brown@intel.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-13[PATCH] move pm_register/etc. to CONFIG_PM_LEGACY, pm_legacy.hJeff Garzik
Since few people need the support anymore, this moves the legacy pm_xxx functions to CONFIG_PM_LEGACY, and include/linux/pm_legacy.h. Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-09[PATCH] swsusp: rework swsusp_suspendRafael J. Wysocki
This patch makes only the functions in swsusp.c call functions in snapshot.c and not both ways.  It also moves the check for available swap out of swsusp_suspend() which is necessary for separating the swap-handling functions in swsusp from the core code. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Cc: Pavel Machek <pavel@ucw.cz> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-09[PATCH] swsusp: simplify pagedir relocationRafael J. Wysocki
This patch simplifies the relocation of the page backup list (aka pagedir) during resume. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Cc: Pavel Machek <pavel@ucw.cz> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-09[PATCH] swsusp: reduce code duplicationRafael J. Wysocki
The changes made by this patch are necessary for the pagedir relocation simplification in the next patch.  Additionally, these changes allow us to drop check_pagedir() and make get_safe_page() be a one-line wrapper around alloc_image_page() (get_safe_page() goes to snapshot.c, because alloc_image_page() is static and it does not make sense to export it). Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Cc: Pavel Machek <pavel@ucw.cz> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-09[PATCH] sleep: Fix oops in enter_statePavel Machek
If ACPI sleep is not configured, but someone still wants to run swsusp, he'd get oops in enter_state. This is regression since 2.6.14 and this fixes it. Signed-off-by: Pavel Machek <pavel@suse.cz> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-07[PATCH] swsusp: remove unused variablePavel Machek
Remove unused variable, and make code less evil that way. Fix whitespace around for-loop-like macro. Signed-off-by: Pavel Machek <pavel@suse.cz> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-07[PATCH] swsusp cleanupsPavel Machek
This cleans spaces between * and pointer up, and adds "int" in "unsigned int". Signed-off-by: Pavel Machek <pavel@suse.cz> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-30[PATCH] introduce .valid callback for pm_opsShaohua Li
Add pm_ops.valid callback, so only the available pm states show in /sys/power/state. And this also makes an earlier states error report at enter_state before we do actual suspend/resume. Signed-off-by: Shaohua Li<shaohua.li@intel.com> Acked-by: Pavel Machek<pavel@suse.cz> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-30[PATCH] swsusp: two simplificationsRafael J. Wysocki
The following patch simplifies the progress meter in disk.c:free_some_memory() and makes disk.c:pm_suspend_disk() call device_resume() explicitly in the suspend path. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Acked-by: Pavel Machek <pavel@suse.cz> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-30[PATCH] swsusp: get rid of unnecessary wrapper functionRafael J. Wysocki
The following patch merges two functions in a trivial way. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Acked-by: Pavel Machek <pavel@suse.cz> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-30[PATCH] swsusp: cleanupsPavel Machek
Reduce number of ifdefs somehow, and fix whitespace a bit. No real code changes. Signed-off-by: Pavel Machek <pavel@suse.cz> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-30[PATCH] swsusp: remove unneccessary includesPavel Machek
Cleanup comments and remove unneccessary includes. Signed-off-by: Pavel Machek <pavel@suse.cz> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-30[PATCH] swsusp: rework memory freeing on resumeRafael J. Wysocki
The following patch makes swsusp use the PG_nosave and PG_nosave_free flags to mark pages that should be freed in case of an error during resume. This allows us to simplify the code and to use swsusp_free() in all of the swsusp's resume error paths, which makes them actually work. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-30[PATCH] swsusp: reduce the use of global variablesRafael J. Wysocki
2005-10-30[PATCH] swsusp: move snapshot functionality to separate fileRafael J. Wysocki
The following patch moves the functionality of swsusp related to creating and handling the snapshot of memory to a separate file, snapshot.c This should enable us to untangle the code in the future and eventually to implement some parts of swsusp.c in the user space. The patch does not change the code. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Signed-off-by: Pavel Machek <pavel@suse.cz> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-30[PATCH] swsusp: rework image freeingRafael J. Wysocki
The following patch makes swsusp use PG_nosave and PG_nosave_free flags to mark pages that should be freed after the state of the system has been restored from the image (or in case of an error during suspend). This allows us to avoid storing metadata in swap twice and to reduce the amount of memory needed by swsusp.  Additionally, it allows us to simplify the code by removing a couple of functions that are no longer necessary. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Signed-off-by: Pavel Machek <pavel@suse.cz> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-29[PATCH] core remove PageReservedNick Piggin
Remove PageReserved() calls from core code by tightening VM_RESERVED handling in mm/ to cover PageReserved functionality. PageReserved special casing is removed from get_page and put_page. All setting and clearing of PageReserved is retained, and it is now flagged in the page_alloc checks to help ensure we don't introduce any refcount based freeing of Reserved pages. MAP_PRIVATE, PROT_WRITE of VM_RESERVED regions is tentatively being deprecated. We never completely handled it correctly anyway, and is be reintroduced in future if required (Hugh has a proof of concept). Once PageReserved() calls are removed from kernel/power/swsusp.c, and all arch/ and driver code, the Set and Clear calls, and the PG_reserved bit can be trivially removed. Last real user of PageReserved is swsusp, which uses PageReserved to determine whether a struct page points to valid memory or not. This still needs to be addressed (a generic page_is_ram() should work). A last caveat: the ZERO_PAGE is now refcounted and managed with rmap (and thus mapcounted and count towards shared rss). These writes to the struct page could cause excessive cacheline bouncing on big systems. There are a number of ways this could be addressed if it is an issue. Signed-off-by: Nick Piggin <npiggin@suse.de> Refcount bug fix for filemap_xip.c Signed-off-by: Carsten Otte <cotte@de.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-28[PATCH] gfp_t: kernel/*Al Viro
2005-10-10[PATCH] x86_64: Set up safe page tables during resumeRafael J. Wysocki
The following patch makes swsusp avoid the possible temporary corruption of page translation tables during resume on x86-64. This is achieved by creating a copy of the relevant page tables that will not be modified by swsusp and can be safely used by it on resume. The problem is that during resume on x86-64 swsusp may temporarily corrupt the page tables used for the direct mapping of RAM. If that happens, a page fault occurs and cannot be handled properly, which leads to the solid hang of the affected system. This leads to the loss of the system's state from before suspend and may result in the loss of data or the corruption of filesystems, so it is a serious issue. Also, it appears to happen quite often (for me, as often as 50% of the time). The problem is related to the fact that (at least) one of the PMD entries used in the direct memory mapping (starting at PAGE_OFFSET) points to a page table the physical address of which is much greater than the physical address of the PMD entry itself. Moreover, unfortunately, the physical address of the page table before suspend (i.e. the one stored in the suspend image) happens to be different to the physical address of the corresponding page table used during resume (i.e. the one that is valid right before swsusp_arch_resume() in arch/x86_64/kernel/suspend_asm.S is executed). Thus while the image is restored, the "offending" PMD entry gets overwritten, so it does not point to the right physical address any more (i.e. there's no page table at the address pointed to by it, because it points to the address the page table has been at during suspend). Consequently, if the PMD entry is used later on, and it _is_ used in the process of copying the image pages, a page fault occurs, but it cannot be handled in the normal way and the system hangs. In principle we can call create_resume_mapping() from swsusp_arch_resume() (ie. from suspend_asm.S), but then the memory allocations in create_resume_mapping(), resume_pud_mapping(), and resume_pmd_mapping() must be made carefully so that we use _only_ NosaveFree pages in them (the other pages are overwritten by the loop in swsusp_arch_resume()). Additionally, we are in atomic context at that time, so we cannot use GFP_KERNEL. Moreover, if one of the allocations fails, we should free all of the allocated pages, so we need to trace them somehow. All of this is done in the appended patch, except that the functions populating the page tables are located in arch/x86_64/kernel/suspend.c rather than in init.c. It may be done in a more elegan way in the future, with the help of some swsusp patches that are in the works now. [AK: move some externs into headers, renamed a function] Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Signed-off-by: Andi Kleen <ak@suse.de> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-28[PATCH] swsusp: avoid problems if there are too many pages to saveRafael J. Wysocki
The following patch makes swsusp avoid problems during resume if there are too many pages to save on suspend. It adds a constant that allows us to verify if we are going to save too many pages and implements the check (this is done as early as we can tell that the check will trigger, which is in swsusp_alloc()). Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Acked-by: Pavel Machek <pavel@suse.cz> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-28[PATCH] swsusp: prevent possible memory leakRafael J. Wysocki
Prevent swsusp from leaking some memory in case of an error in read_pagedir(). It also prevents the BUG_ON() from triggering if there's an error while reading swap. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Acked-by: Pavel Machek <pavel@ucw.cz> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-28[PATCH] swsusp: remove wrong code from data_freeRafael J. Wysocki
The following patch removes some wrong code from the data_free() function in swsusp. This function could only be called if there's an error while writing the suspend image to swap, so it is not triggered easily. However, if triggered, it would probably corrupt some memory. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Acked-by: Pavel Machek <pavel@ucw.cz> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-22[PATCH] swsusp: fix commentsPavel Machek
Fix comments in swsusp. Signed-off-by: Pavel Machek <pavel@suse.cz> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-22[PATCH] swsusp: do not trigger BUG_ON() if there is not enough memoryRafael J. Wysocki
The following patch makes swsusp avoid triggering the BUG_ON() in swsusp_suspend() if there is not enough memory for suspend. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Cc: Pavel Machek <pavel@ucw.cz> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-22[PATCH] SOFTWARE_SUSPEND needs HOTPLUG_CPU on SMPRandy Dunlap
Signed-off-by: Randy Dunlap <rdunlap@xenotime.net> Acked-by: Pavel Machek <pavel@ucw.cz> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-22[PATCH] suspend: cleanup calling of power off methods.Eric W. Biederman
In the lead up to 2.6.13 I fixed a large number of reboot problems by making the calling conventions consistent. Despite checking and double checking my work it appears I missed an obvious one. The S4 suspend code for PM_DISK_PLATFORM was also calling device_shutdown without setting system_state, and was not calling the appropriate reboot_notifier. This patch fixes the bug by replacing the call of device_suspend with kernel_poweroff_prepare. Various forms of this failure have been fixed and tracked for a while. Thanks for tracking this down go to: Alexey Starikovskiy, Meelis Roos <mroos@linux.ee>, Nigel Cunningham <ncunningham@cyclades.com>, Pierre Ossman <drzeus-list@drzeus.cx> History of this bug is at: http://bugme.osdl.org/show_bug.cgi?id=4320 Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
