path: root/kernel/printk.c
2011-01-13printk: use RCU to prevent potential lock contention in kmsg_dumpHuang Ying
dump_list_lock is used to protect dump_list in kmsg_dumper implementation, kmsg_dump() uses it to traverse dump_list too. But if there is contention on the lock, kmsg_dump() will fail, and the valuable kernel message may be lost. This patch solves this issue with RCU. Because kmsg_dump() only read the list, no lock is needed in kmsg_dump(). So that kmsg_dump() will never fail because of lock contention. Signed-off-by: Huang Ying <ying.huang@intel.com> Cc: "Paul E. McKenney" <paulmck@us.ibm.com> Cc: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-01-13kmsg_dump: add kmsg_dump() calls to the reboot, halt, poweroff and ↵Seiji Aguchi
emergency_restart paths We need to know the reason why system rebooted in support service. However, we can't inform our customers of the reason because final messages are lost on current Linux kernel. This patch improves the situation above because the final messages are saved by adding kmsg_dump() to reboot, halt, poweroff and emergency_restart path. Signed-off-by: Seiji Aguchi <seiji.aguchi@hds.com> Cc: David Woodhouse <dwmw2@infradead.org> Cc: Marco Stornelli <marco.stornelli@gmail.com> Reviewed-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com> Reviewed-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-01-10Merge branch 'master' into nextJames Morris
Conflicts: security/smack/smack_lsm.c Verified and added fix by Stephen Rothwell <sfr@canb.auug.org.au> Ok'd by Casey Schaufler <casey@schaufler-ca.com> Signed-off-by: James Morris <jmorris@namei.org>
2011-01-07Merge branch 'tty-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty-2.6 * 'tty-next' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty-2.6: (36 commits) serial: apbuart: Fixup apbuart_console_init() TTY: Add tty ioctl to figure device node of the system console. tty: add 'active' sysfs attribute to tty0 and console device drivers: serial: apbuart: Handle OF failures gracefully Serial: Avoid unbalanced IRQ wake disable during resume tty: fix typos/errors in tty_driver.h comments pch_uart : fix warnings for 64bit compile 8250: fix uninitialized FIFOs ip2: fix compiler warning on ip2main_pci_tbl specialix: fix compiler warning on specialix_pci_tbl rocket: fix compiler warning on rocket_pci_ids 8250: add a UPIO_DWAPB32 for 32 bit accesses 8250: use container_of() instead of casting serial: omap-serial: Add support for kernel debugger serial: fix pch_uart kconfig & build drivers: char: hvc: add arm JTAG DCC console support RS485 documentation: add 16C950 UART description serial: ifx6x60: fix memory leak serial: ifx6x60: free IRQ on error Serial: EG20T: add PCH_UART driver ... Fixed up conflicts in drivers/serial/apbuart.c with evil merge that makes the code look fairly sane (unlike either side).
2010-12-16tty: add 'active' sysfs attribute to tty0 and console deviceKay Sievers
tty: add 'active' sysfs attribute to tty0 and console device Userspace can query the actual virtual console, and the configured console devices behind /dev/tt0 and /dev/console. The last entry in the list of devices is the active device, analog to the console= kernel command line option. The attribute supports poll(), which is raised when the virtual console is changed or /dev/console is reconfigured. Signed-off-by: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> index 0000000..b138b66
2010-12-09syslog: check cap_syslog when dmesg_restrictSerge E. Hallyn
Eric Paris pointed out that it doesn't make sense to require both CAP_SYS_ADMIN and CAP_SYSLOG for certain syslog actions. So require CAP_SYSLOG, not CAP_SYS_ADMIN, when dmesg_restrict is set. (I'm also consolidating the now common error path) Signed-off-by: Serge E. Hallyn <serge.hallyn@canonical.com> Acked-by: Eric Paris <eparis@redhat.com> Acked-by: Kees Cook <kees.cook@canonical.com> Signed-off-by: James Morris <jmorris@namei.org>
2010-12-08printk: Use this_cpu_{read|write} api on printk_pendingEric Dumazet
__get_cpu_var() is a bit inefficient, lets use __this_cpu_read() and __this_cpu_write() to manipulate printk_pending. printk_needs_cpu(cpu) is called only for the current cpu : Use faster __this_cpu_read(). Remove the redundant unlikely on (cpu_is_offline(cpu)) test: # size kernel/printk.o* text data bss dec hex filename 9942 756 263488 274186 42f0a kernel/printk.o.new 9990 756 263488 274234 42f3a kernel/printk.o.old Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Christoph Lameter <cl@linux.com> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> LKML-Reference: <1290788536.2855.237.camel@edumazet-laptop> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-11-29security: Define CAP_SYSLOGSerge E. Hallyn
Privileged syslog operations currently require CAP_SYS_ADMIN. Split this off into a new CAP_SYSLOG privilege which we can sanely take away from a container through the capability bounding set. With this patch, an lxc container can be prevented from messing with the host's syslog (i.e. dmesg -c). Changelog: mar 12 2010: add selinux capability2:cap_syslog perm Changelog: nov 22 2010: . port to new kernel . add a WARN_ONCE if userspace isn't using CAP_SYSLOG Signed-off-by: Serge Hallyn <serge.hallyn@ubuntu.com> Acked-by: Andrew G. Morgan <morgan@kernel.org> Acked-By: Kees Cook <kees.cook@canonical.com> Cc: James Morris <jmorris@namei.org> Cc: Michael Kerrisk <mtk.manpages@gmail.com> Cc: Stephen Smalley <sds@tycho.nsa.gov> Cc: "Christopher J. PeBenito" <cpebenito@tresys.com> Cc: Eric Paris <eparis@parisplace.org> Signed-off-by: James Morris <jmorris@namei.org>
2010-11-26nohz: Fix printk_needs_cpu() return value on offline cpusHeiko Carstens
This patch fixes a hang observed with 2.6.32 kernels where timers got enqueued on offline cpus. printk_needs_cpu() may return 1 if called on offline cpus. When a cpu gets offlined it schedules the idle process which, before killing its own cpu, will call tick_nohz_stop_sched_tick(). That function in turn will call printk_needs_cpu() in order to check if the local tick can be disabled. On offline cpus this function should naturally return 0 since regardless if the tick gets disabled or not the cpu will be dead short after. That is besides the fact that __cpu_disable() should already have made sure that no interrupts on the offlined cpu will be delivered anyway. In this case it prevents tick_nohz_stop_sched_tick() to call select_nohz_load_balancer(). No idea if that really is a problem. However what made me debug this is that on 2.6.32 the function get_nohz_load_balancer() is used within __mod_timer() to select a cpu on which a timer gets enqueued. If printk_needs_cpu() returns 1 then the nohz_load_balancer cpu doesn't get updated when a cpu gets offlined. It may contain the cpu number of an offline cpu. In turn timers get enqueued on an offline cpu and not very surprisingly they never expire and cause system hangs. This has been observed 2.6.32 kernels. On current kernels __mod_timer() uses get_nohz_timer_target() which doesn't have that problem. However there might be other problems because of the too early exit tick_nohz_stop_sched_tick() in case a cpu goes offline. Easiest way to fix this is just to test if the current cpu is offline and call printk_tick() directly which clears the condition. Alternatively I tried a cpu hotplug notifier which would clear the condition, however between calling the notifier function and printk_needs_cpu() something could have called printk() again and the problem is back again. This seems to be the safest fix. Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: stable@kernel.org LKML-Reference: <20101126120235.406766476@de.ibm.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-11-26printk: Fix wake_up_klogd() vs cpu hotplugHeiko Carstens
wake_up_klogd() may get called from preemptible context but uses __raw_get_cpu_var() to write to a per cpu variable. If it gets preempted between getting the address and writing to it, the cpu in question could be offline if the process gets scheduled back and hence writes to the per cpu data of an offline cpu. This buggy behaviour was introduced with fa33507a "printk: robustify printk, fix #2" which was supposed to fix a "using smp_processor_id() in preemptible" warning. Let's use this_cpu_write() instead which disables preemption and makes sure that the outlined scenario cannot happen. Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Acked-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> LKML-Reference: <20101126124247.GC7023@osiris.boeblingen.de.ibm.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-11-16console: move for_each_console to linux/console.hJiri Slaby
Move it out of printk.c so that we can use it all over the code. There are some potential users which will be converted to that macro in next patches. Signed-off-by: Jiri Slaby <jslaby@suse.cz> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-11-15capabilities/syslog: open code cap_syslog logic to fix build failureEric Paris
The addition of CONFIG_SECURITY_DMESG_RESTRICT resulted in a build failure when CONFIG_PRINTK=n. This is because the capabilities code which used the new option was built even though the variable in question didn't exist. The patch here fixes this by moving the capabilities checks out of the LSM and into the caller. All (known) LSMs should have been calling the capabilities hook already so it actually makes the code organization better to eliminate the hook altogether. Signed-off-by: Eric Paris <eparis@redhat.com> Acked-by: James Morris <jmorris@namei.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-11-12Restrict unprivileged access to kernel syslogDan Rosenberg
The kernel syslog contains debugging information that is often useful during exploitation of other vulnerabilities, such as kernel heap addresses. Rather than futilely attempt to sanitize hundreds (or thousands) of printk statements and simultaneously cripple useful debugging functionality, it is far simpler to create an option that prevents unprivileged users from reading the syslog. This patch, loosely based on grsecurity's GRKERNSEC_DMESG, creates the dmesg_restrict sysctl. When set to "0", the default, no restrictions are enforced. When set to "1", only users with CAP_SYS_ADMIN can read the kernel syslog via dmesg(8) or other mechanisms. [akpm@linux-foundation.org: explain the config option in kernel.txt] Signed-off-by: Dan Rosenberg <drosenberg@vsecurity.com> Acked-by: Ingo Molnar <mingo@elte.hu> Acked-by: Eugene Teo <eugeneteo@kernel.org> Acked-by: Kees Cook <kees.cook@canonical.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-26printk: change type of 'boot_delay' to int *Namhyung Kim
get_option() takes its 2nd arg as int * so passing boot_delay to it caused following warnings from sparse: kernel/printk.c:223:27: warning: incorrect type in argument 2 (different signedness) kernel/printk.c:223:27: expected int *pint kernel/printk.c:223:27: got unsigned int static [toplevel] *<noident> Since boot_delay can't grow more than 10,000 changing it to 'int *' will not produce any problem. Signed-off-by: Namhyung Kim <namhyung@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-26printk: add lock context annotationNamhyung Kim
acquire_console_semaphore_for_printk() releases logbuf_lock but was missing proper annotation. Add it. Signed-off-by: Namhyung Kim <namhyung@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-26printk: fixup declaration of kmsg_reasonsNamhyung Kim
Move redundant 'const' after '*' to make pointer itself const Signed-off-by: Namhyung Kim <namhyung@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-12printk: Make console_sem a semaphore not a pseudo mutexThomas Gleixner
It needs to be investigated whether it can be replaced by a real mutex, but that needs more thought. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Christoph Hellwig <hch@infradead.org> LKML-Reference: <20100907125057.179587334@linutronix.de>
2010-08-09gcc-4.6: printk: use stable variable to dump kmsg bufferAndi Kleen
kmsg_dump takes care to sample the global variables inside a spinlock, but then goes on to use the same variables outside the spinlock region too. Use the correct variable. This will make the race window smaller. Found by gcc 4.6's new warnings. Signed-off-by: Andi Kleen <ak@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-08-05printk: fix delayed messages from CPU hotplug eventsKevin Cernekee
When a secondary CPU is being brought up, it is not uncommon for printk() to be invoked when cpu_online(smp_processor_id()) == 0. The case that I witnessed personally was on MIPS: http://lkml.org/lkml/2010/5/30/4 If (can_use_console() == 0), printk() will spool its output to log_buf and it will be visible in "dmesg", but that output will NOT be echoed to the console until somebody calls release_console_sem() from a CPU that is online. Therefore, the boot time messages from the new CPU can get stuck in "limbo" for a long time, and might suddenly appear on the screen when a completely unrelated event (e.g. "eth0: link is down") occurs. This patch modifies the console code so that any pending messages are automatically flushed out to the console whenever a CPU hotplug operation completes successfully or aborts. The issue was seen on 2.6.34. Original patch by Kevin Cernekee with cleanups by akpm and additional fixes by Santosh Shilimkar. This patch superseeds https://patchwork.linux-mips.org/patch/1357/. Signed-off-by: Kevin Cernekee <cernekee@gmail.com> To: <mingo@elte.hu> To: <akpm@linux-foundation.org> To: <simon.kagstrom@netinsight.net> To: <David.Woodhouse@intel.com> To: <lethal@linux-sh.org> Cc: <linux-kernel@vger.kernel.org> Cc: <linux-mips@linux-mips.org> Reviewed-by: Paul Mundt <lethal@linux-sh.org> Signed-off-by: Kevin Cernekee <cernekee@gmail.com> Patchwork: https://patchwork.linux-mips.org/patch/1534/ LKML-Reference: <ede63b5a20af951c755736f035d1e787772d7c28@localhost> LKML-Reference: <EAF47CD23C76F840A9E7FCE10091EFAB02C5DB6D1F@dbde02.ent.ti.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2010-05-20printk,kdb: capture printk() when in kdb shellJason Wessel
Certain calls from the kdb shell will call out to printk(), and any of these calls should get vectored back to the kdb_printf() so that the kdb pager and processing can be used, as well as to properly channel I/O to the polled I/O devices. CC: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Jason Wessel <jason.wessel@windriver.com> Acked-by: Andrew Morton <akpm@linux-foundation.org>
2010-05-20kdb: core for kgdb back end (2 of 2)Jason Wessel
This patch contains the hooks and instrumentation into kernel which live outside the kernel/debug directory, which the kdb core will call to run commands like lsmod, dmesg, bt etc... CC: linux-arch@vger.kernel.org Signed-off-by: Jason Wessel <jason.wessel@windriver.com> Signed-off-by: Martin Hicks <mort@sgi.com>
2010-03-06printk: avoid warning when CONFIG_PRINTK is disabledGustavo F. Padovan
kernel/printk.c:72: warning: `saved_console_loglevel' defined but not used Signed-off-by: Gustavo F. Padovan <padovan@profusion.mobi> Cc: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-03-01Merge branch 'next' into for-linusJames Morris
2010-02-04syslog: use defined constants instead of raw numbersKees Cook
Right now the syslog "type" action are just raw numbers which makes the source difficult to follow. This patch replaces the raw numbers with defined constants for some level of sanity. Signed-off-by: Kees Cook <kees.cook@canonical.com> Acked-by: John Johansen <john.johansen@canonical.com> Acked-by: Serge Hallyn <serue@us.ibm.com> Signed-off-by: James Morris <jmorris@namei.org>
2010-02-04syslog: distinguish between /proc/kmsg and syscallsKees Cook
This allows the LSM to distinguish between syslog functions originating from /proc/kmsg access and direct syscalls. By default, the commoncaps will now no longer require CAP_SYS_ADMIN to read an opened /proc/kmsg file descriptor. For example the kernel syslog reader can now drop privileges after opening /proc/kmsg, instead of staying privileged with CAP_SYS_ADMIN. MAC systems that implement security_syslog have unchanged behavior. Signed-off-by: Kees Cook <kees.cook@canonical.com> Acked-by: Serge Hallyn <serue@us.ibm.com> Acked-by: John Johansen <john.johansen@canonical.com> Signed-off-by: James Morris <jmorris@namei.org>
2010-01-24Merge git://git.infradead.org/~dwmw2/mtd-2.6.33Linus Torvalds
* git://git.infradead.org/~dwmw2/mtd-2.6.33: mtd: tests: fix read, speed and stress tests on NOR flash mtd: Really add ARM pismo support kmsg_dump: Dump on crash_kexec as well
2009-12-31kmsg_dump: Dump on crash_kexec as wellKOSAKI Motohiro
crash_kexec gets called before kmsg_dump(KMSG_DUMP_OOPS) if panic_on_oops is set, so the kernel log buffer is not stored for this case. This patch adds a KMSG_DUMP_KEXEC dump type which gets called when crash_kexec() is invoked. To avoid getting double dumps, the old KMSG_DUMP_PANIC is moved below crash_kexec(). The mtdoops driver is modified to handle KMSG_DUMP_KEXEC in the same way as a panic. Signed-off-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Acked-by: Simon Kagstrom <simon.kagstrom@netinsight.net> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2009-12-17printk: fix new kernel-doc warningsRandy Dunlap
Fix kernel-doc warnings in printk.c: Warning(kernel/printk.c:1422): No description found for parameter 'dumper' Warning(kernel/printk.c:1422): Excess function parameter 'dump' description in 'kmsg_dump_register' Warning(kernel/printk.c:1451): No description found for parameter 'dumper' Warning(kernel/printk.c:1451): Excess function parameter 'dump' description in 'kmsg_dump_unregister' Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-12-16Merge git://git.infradead.org/mtd-2.6Linus Torvalds
* git://git.infradead.org/mtd-2.6: (90 commits) jffs2: Fix long-standing bug with symlink garbage collection. mtd: OneNAND: Fix test of unsigned in onenand_otp_walk() mtd: cfi_cmdset_0002, fix lock imbalance Revert "mtd: move mxcnd_remove to .exit.text" mtd: m25p80: add support for Macronix MX25L4005A kmsg_dump: fix build for CONFIG_PRINTK=n mtd: nandsim: add support for 4KiB pages mtd: mtdoops: refactor as a kmsg_dumper mtd: mtdoops: make record size configurable mtd: mtdoops: limit the maximum mtd partition size mtd: mtdoops: keep track of used/unused pages in an array mtd: mtdoops: several minor cleanups core: Add kernel message dumper to call on oopses and panics mtd: add ARM pismo support mtd: pxa3xx_nand: Fix PIO data transfer mtd: nand: fix multi-chip suspend problem mtd: add support for switching old SST chips into QRY mode mtd: fix M29W800D dev_id and uaddr mtd: don't use PF_MEMALLOC mtd: Add bad block table overrides to Davinci NAND driver ... Fixed up conflicts (mostly trivial) in drivers/mtd/devices/m25p80.c drivers/mtd/maps/pcmciamtd.c drivers/mtd/nand/pxa3xx_nand.c kernel/printk.c
2009-12-05Merge branch 'core-printk-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'core-printk-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: ratelimit: Make suppressed output messages more useful printk: Remove ratelimit.h from kernel.h ratelimit: Fix/allow use in atomic contexts ratelimit: Use per ratelimit context locking
2009-12-02kmsg_dump: fix build for CONFIG_PRINTK=nRandy Dunlap
kmsg_dump() fails to build when CONFIG_PRINTK=n; provide stubs for the kmsg_dump*() functions when CONFIG_PRINTK=n. kernel/printk.c: In function 'kmsg_dump': kernel/printk.c:1501: error: 'log_buf_len' undeclared (first use in this function) kernel/printk.c:1502: error: 'logged_chars' undeclared (first use in this function) kernel/printk.c:1506: error: 'log_buf' undeclared (first use in this function) Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Acked-by: Simon Kagstrom <simon.kagstrom@netinsight.net> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2009-11-30core: Add kernel message dumper to call on oopses and panicsSimon Kagstrom
The core functionality is implemented as per Linus suggestion from http://lists.infradead.org/pipermail/linux-mtd/2009-October/027620.html (with the kmsg_dump implementation by Linus). A struct kmsg_dumper has been added which contains a callback to dump the kernel log buffers on crashes. The kmsg_dump function gets called from oops_exit() and panic() and invokes this callbacks with the crash reason. [dwmw2: Fix log_end handling] Signed-off-by: Simon Kagstrom <simon.kagstrom@netinsight.net> Reviewed-by: Anders Grafstrom <anders.grafstrom@netinsight.net> Reviewed-by: Linus Torvalds <torvalds@linux-foundation.org> Acked-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2009-10-23ratelimit: Make suppressed output messages more usefulChristian Borntraeger
Today I got: [39648.224782] Registered led device: iwl-phy0::TX [40676.545099] __ratelimit: 246 callbacks suppressed [40676.545103] abcdef[23675]: segfault at 0 ... as you can see the ratelimit message contains a function prefix. Since this is always __ratelimit, this wont help much. This patch changes __ratelimit and printk_ratelimit to print the function name that calls ratelimit. This will pinpoint the responsible function, as long as not several different places call ratelimit with the same ratelimit state at the same time. In that case we catch only one random function that calls ratelimit after the wait period. Signed-off-by: Christian Borntraeger <borntraeger@de.ibm.com> Cc: Dave Young <hidave.darkstar@gmail.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> CC: Andrew Morton <akpm@linux-foundation.org> LKML-Reference: <200910231458.11832.borntraeger@de.ibm.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-09-23printk: add printk_delay to make messages readable for some scenariosDave Young
When syslog is not possible, at the same time there's no serial/net console available, it will be hard to read the printk messages. For example oops/panic/warning messages in shutdown phase. Add a printk delay feature, we can make each printk message delay some milliseconds. Setting the delay by proc/sysctl interface: /proc/sys/kernel/printk_delay The value range from 0 - 10000, default value is 0 [akpm@linux-foundation.org: fix a few things] Signed-off-by: Dave Young <hidave.darkstar@gmail.com> Acked-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-23printk boot_delay: rename printk_delay_msec to loops_per_msecDave Young
Rename `printk_delay_msec' to `loops_per_msec', because the patch "printk: add printk_delay to make messages readable for some scenarios" wishes to more appropriately use the `printk_delay_msec' identifier. [akpm@linux-foundation.org: add a comment] Signed-off-by: Dave Young <hidave.darkstar@gmail.com> Acked-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-22printk: Remove ratelimit.h from kernel.hIngo Molnar
Decouple kernel.h from ratelimit.h: the global declaration of printk's ratelimit_state is not needed, and it leads to messy circular dependencies due to ratelimit.h's (new) adding of a spinlock_types.h include. Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: David S. Miller <davem@davemloft.net> LKML-Reference: <new-submission> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-09-14cleanup console_print()Anirban Sinha
console_print() is an old legacy interface mostly unused in the entire kernel tree. It's best to clean up its existing use and let developers use their own implementation of it as they feel fit. Signed-off-by: Anirban Sinha <asinha@zeugmasystems.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-08-08printk: Fix "printk: Enable the use of more than one CON_BOOT (early console)"Sonic Zhang
Don't return when we find the first bootconsole - it can leave other bootconsoles still installed, and they can be used and cause problems later (if they are in the init section, and eventually released), and cause problems. Make sure we remove all of them. Signed-off-by: Sonic Zhang <Sonic.Zhang@analog.com> Signed-off-by: Robin Getz <rgetz@analog.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-07-10printk: Restore previous console_loglevel when re-enabling loggingFrans Pop
When logging to console is disabled from userspace using klogctl() and later re-enabled, console_loglevel gets set to the default log level instead to the previous value. This means that if the kernel was booted with 'quiet', the boot is suddenly no longer quiet after logging to console gets re-enabled. Save the current console_loglevel when logging is disabled and restore to that value. If the log level is set to a specific value while disabled, this is interpreted as an implicit re-enabling of the logging. The problem that prompted this patch is described in: http://lkml.org/lkml/2009/6/28/234 There are two variations possible on the patch below: 1) If klogctl(7) is called while logging is not disabled, then set level to default (partially preserving current functionality): case 7: /* Enable logging to console */ - console_loglevel = default_console_loglevel; + if (saved_console_loglevel == -1) + console_loglevel = default_console_loglevel; + else { + console_loglevel = saved_console_loglevel; + saved_console_loglevel = -1; + } 2) If klogctl(8) is called while logging is disabled, then don't enable logging, but remember the requested value for when logging does get enabled again: case 8: /* Set level of messages printed to console */ [...] - console_loglevel = len; + if (saved_console_loglevel == -1) + console_loglevel = len; + else + saved_console_loglevel = len; Yet another option would be to ignore the request. Signed-off-by: Frans Pop <elendil@planet.nl> Cc: cryptsetup@packages.debian.org Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> LKML-Reference: <200907061331.49930.elendil@planet.nl> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-07-10printk: Ensure that "console enabled" messages are printed on the consoleRobin Getz
Today, when a console is registered without CON_PRINTBUFFER, end users never see the announcement of it being added, and never know if they missed something, if the console is really at the start or not, and just leads to general confusion. This re-orders existing code, to make sure the console is added, before the "console [%s%d] enabled" is printed out - ensuring that this message is _always_ seen. This has the desired/intended side effect of making sure that "console enabled:" messages are printed on the bootconsole, and the real console. This does cause the same line is printed twice if the bootconsole and real console are the same device, but if they are on different devices, the message is printed to both consoles. Signed-off-by : Robin Getz <rgetz@blackfin.uclinux.org> Cc: "Andrew Morton" <akpm@linux-foundation.org> Cc: "Linus Torvalds" <torvalds@linux-foundation.org> LKML-Reference: <200907091308.37370.rgetz@blackfin.uclinux.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-07-03printk: Enable the use of more than one CON_BOOT (early console)Robin Getz
Today, register_console() assumes the following usage: - The first console to register with a flag set to CON_BOOT is the one and only bootconsole. - If another register_console() is called with an additional CON_BOOT, it is silently rejected. - As soon as a console without the CON_BOOT set calls registers the bootconsole is automatically unregistered. - Once there is a "real" console - register_console() will silently reject any consoles with it's CON_BOOT flag set. In many systems (alpha, blackfin, microblaze, mips, powerpc, sh, & x86), there are early_printk implementations, which use the CON_BOOT which come out serial ports, vga, usb, & memory buffers. In many embedded systems, it would be nice to have two bootconsoles - in case the primary fails, you always have access to a backup memory buffer - but this requires at least two CON_BOOT consoles... This patch enables that functionality. With the change applied, on boot you get (if you try to re-enable a boot console after the "real" console has been registered): root:/> dmesg | grep console bootconsole [early_shadow0] enabled bootconsole [early_BFuart0] enabled Kernel command line: root=/dev/mtdblock0 rw earlyprintk=serial,uart0,57600 console=ttyBF0,57600 nmi_debug=regs console handover:boot [early_BFuart0] boot [early_shadow0] -> real [ttyBF0] Too late to register bootconsole early_shadow0 or: root:/> dmesg | grep console Kernel command line: root=/dev/mtdblock0 rw console=ttyBF0,57600 console [ttyBF0] enabled Signed-off-by: Robin Getz <rgetz@blackfin.uclinux.org> Cc: "Linus Torvalds" <torvalds@linux-foundation.org> Cc: "Andrew Morton" <akpm@linux-foundation.org> Cc: "Mike Frysinger" <vapier.adi@gmail.com> Cc: "Paul Mundt" <lethal@linux-sh.org> LKML-Reference: <200907012108.38030.rgetz@blackfin.uclinux.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-06-16printk: Add KERN_DEFAULT printk log-levelLinus Torvalds
This adds a KERN_DEFAULT loglevel marker, for when you cannot decide which loglevel you want, and just want to keep an existing printk with the default loglevel. The difference between having KERN_DEFAULT and having no log-level marker at all is two-fold: - having the log-level marker will now force a new-line if the previous printout had not added one (perhaps because it forgot, but perhaps because it expected a continuation) - having a log-level marker is required if you are printing out a message that otherwise itself could perhaps otherwise be mistaken for a log-level. Signed-of-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-16printk: clean up handling of log-levels and newlinesLinus Torvalds
It used to be that we would only look at the log-level in a printk() after explicit newlines, which can cause annoying problems when the previous printk() did not end with a '\n'. In that case, the log-level marker would be just printed out in the middle of the line, and be seen as just noise rather than change the logging level. This changes things to always look at the log-level in the first bytes of the printout. If a log level marker is found, it is always used as the log-level. Additionally, if no newline existed, one is added (unless the log-level is the explicit KERN_CONT marker, to explicitly show that it's a continuation of a previous line). Acked-by: Arjan van de Ven <arjan@infradead.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-05Merge branch 'printk-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'printk-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: printk: correct the behavior of printk_timed_ratelimit() vsprintf: unify the format decoding layer for its 3 users, cleanup fix regression from "vsprintf: unify the format decoding layer for its 3 users" vsprintf: fix bug in negative value printing vsprintf: unify the format decoding layer for its 3 users vsprintf: add binary printf printk: introduce printk_once() Fix trivial conflicts (printk_once vs log_buf_kexec_setup() added near each other) in include/linux/kernel.h.
2009-04-02kexec: add dmesg log symbols to /proc/vmcoreinfo listsNeil Horman
It would be nice to be able to extract the dmesg log from a vmcore file without needing to keep the debug symbols for the running kernel handy all the time. We have a facility to do this in /proc/vmcore. This patch adds the log_buf and log_end symbols to the vmcoreinfo area so that tools (like makedumpfile) can easily extract the dmesg logs from a vmcore image. [akpm@linux-foundation.org: several fixes and cleanups] [akpm@linux-foundation.org: fix unused log_buf_kexec_setup()] [akpm@linux-foundation.org: build fix] Signed-off-by: Neil Horman <nhorman@tuxdriver.com> Cc: Simon Horman <horms@verge.net.au> Acked-by: Vivek Goyal <vgoyal@redhat.com> Cc: Neil Horman <nhorman@tuxdriver.com> Cc: Simon Horman <horms@verge.net.au> Cc: Vivek Goyal <vgoyal@redhat.com> Cc: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-03-17printk: correct the behavior of printk_timed_ratelimit()Guillaume Knispel
Impact: fix jiffies-comparison sign-wrap behavior The behavior provided by printk_timed_ratelimit() is, in some situations, probably not what a caller would reasonably expect: bool printk_timed_ratelimit(unsigned long *caller_jiffies, unsigned int interval_msecs) { if (*caller_jiffies == 0 || time_after(jiffies, *caller_jiffies)) { *caller_jiffies = jiffies + msecs_to_jiffies(interval_msecs); return true; } return false; } On a 32 bit computer, if printk_timed_ratelimit() is initially called at time jiffies == Ja, *caller_jiffies is set to Ja + msecs_to_jiffies(interval_msecs): let's say Ja + 42 for this example. If this caller then doesn't call printk_timed_ratelimit() until jiffies == Ja + (1 << 31) + 42 (which can happen as soon as ~ 25 days later on a 1000 HZ system), printk_timed_ratelimit() will then always return false to this caller until jiffies loops completely (1 << 31 more ticks). Ths change makes it only return false if jiffies is in the small time window starting at the previous call when true was returned and ending interval_msecs later. Note that if jiffies loops completely between two calls to printk_timed_ratelimit(), it will obviously still wrongly return false, but this is something with a low probability. If something completely reliable is needed I guess jiffies_64 must be used (which this change does not do). Signed-off-by: Guillaume Knispel <gknispel@proformatique.com> Cc: Ulrich Drepper <drepper@redhat.com> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: Andrew Morton <akpm@osdl.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> LKML-Reference: <20090317161842.0059096b@xilun.lan.proformatique.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-02-21PM: Fix suspend_console and resume_console to use only one semaphoreArve Hjønnevåg
This fixes a race where a thread acquires the console while the console is suspended, and the console is resumed before this thread releases it. In this case, the secondary console semaphore would be left locked, and the primary semaphore would be released twice. This in turn would cause the console switch on suspend or resume to hang forever. Note that suspend_console does not actually lock the console for clients that use acquire_console_sem, it only locks it for clients that use try_acquire_console_sem. If we change suspend_console to fully lock the console, then the kernel may deadlock on suspend. One client of try_acquire_console_sem is acquire_console_semaphore_for_printk, which uses it to prevent printk from using the console while it is suspended. Signed-off-by: Arve Hjønnevåg <arve@android.com> Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Cc: Len Brown <lenb@kernel.org> Cc: Greg KH <gregkh@suse.de> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-14[CVE-2009-0029] System call wrappers part 27Heiko Carstens
2009-01-14[CVE-2009-0029] Make sys_syslog a conditional system callHeiko Carstens
Remove the -ENOSYS implementation for !CONFIG_PRINTK and use the cond_syscall infrastructure instead. Acked-by: Kyle McMartin <kyle@redhat.com> Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com>
2009-01-06trivial: printk: fix indentation of new_text_line declarationJiri Kosina
Remove bogus indentation of new_text_line declaration introduced in commit ac60ad741. Acked-by: Nick Andrew <nick@nick-andrew.net> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
