Although syslog_seq and log_next_seq stuff are protected by logbuf_lock
spin log, it's not enough. Say we have two processes A and B, and let
syslog_seq = N, while log_next_seq = N + 1, and the two processes both
come to syslog_print at almost the same time. And No matter which
process get the spin lock first, it will increase syslog_seq by one,
then release spin lock; thus later, another process increase syslog_seq
by one again. In this case, syslog_seq is bigger than syslog_next_seq.
And latter, it would make:
wait_event_interruptiable(log_wait, syslog != log_next_seq)
don't wait any more even there is no new write comes. Thus it introduce
a infinite loop reading.
I can easily see this kind of issue by the following steps:
# cat /proc/kmsg # at meantime, I don't kill rsyslog
# So they are the two processes.
# xinit # I added drm.debug=6 in the kernel parameter line,
# so that it will produce lots of message and let that
# issue happen
It's 100% reproducable on my side. And my disk will be filled up by
/var/log/messages in a quite short time.
So, introduce a mutex_lock to stop syslog_seq from going wild just like
what devkmsg_read() does. It does fix this issue as expected.
v2: use mutex_lock_interruptiable() instead (comments from Kay)
Signed-off-by: Yuanhan Liu <yuanhan.liu@linux.intel.com>
Reviewed-by: Fengguang Wu <fengguang.wu@intel.com>
Acked-By: Kay Sievers <kay@vrfy.org>
Provide an iterator to receive the log buffer content, and convert all
kmsg_dump() users to it.
The structured data in the kmsg buffer now contains binary data, which
should no longer be copied verbatim to the kmsg_dump() users.
The iterator should provide reliable access to the buffer data, and also
supports proper log line-aware chunking of data while iterating.
Signed-off-by: Kay Sievers <kay@vrfy.org>
Tested-by: Tony Luck <tony.luck@intel.com>
Reported-by: Anton Vorontsov <anton.vorontsov@linaro.org>
Tested-by: Anton Vorontsov <anton.vorontsov@linaro.org>
Commit 7ff9554bb578ba02166071d2d487b7fc7d860d62, printk: convert
byte-buffer to variable-length record buffer, causes systems using
EABI to crash very early in the boot cycle. The first entry in struct
log is a u64, which for EABI must be 8 byte aligned.
Make use of __alignof__() so the compiler to decide the alignment, but
allow it to be overridden using CONFIG_HAVE_EFFICIENT_UNALIGNED_ACCESS,
for systems which can perform unaligned access and want to save
a few bytes of space.
Tested on Orion5x and Kirkwood.
Signed-off-by: Andrew Lunn <andrew@lunn.ch>
Tested-by: Stephen Warren <swarren@wwwdotorg.org>
Acked-by: Stephen Warren <swarren@wwwdotorg.org>
Acked-by: Kay Sievers <kay@vrfy.org>
Arrange the continuation printk() buffering to be fully separated from the
ordinary full line users.
Limit the exposure to races and wrong printk() line merges to users of
continuation only. Ordinary full line users racing against continuation
users will no longer affect each other.
Multiple continuation users from different threads, racing against each
other will not wrongly be merged into a single line, but printed as
separate lines.
Test output of a kernel module which starts two separate threads which
race against each other, one of them printing a single full terminated
line:
printk("(AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA)\n");
The other one printing the line, every character separate in a
continuation loop:
printk("(C");
for (i = 0; i < 58; i++)
printk(KERN_CONT "C");
printk(KERN_CONT "C)\n");
Behavior of single and non-thread-aware printk() buffer:
# modprobe printk-race
printk test init
(CC(AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA)
CCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCC)
(CCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCC)
New behavior with separate and thread-aware continuation buffer:
printk test init
Cc: Joe Perches <joe@perches.com>
Cc: Ted Ts'o <tytso@mit.edu>
Cc: Jonathan Corbet <corbet@lwn.net>
Cc: Sasha Levin <levinsasha928@gmail.com>
Calls like:
printk("\n *** DEADLOCK ***\n\n");
will print 3 properly indented, separated, syslog + timestamp prefixed lines in
the log output.
Reported-By: Sasha Levin <levinsasha928@gmail.com>
Add a stub for prepend_timestamp() when CONFIG_PRINTK is not
enabled. Fixes this build error:
kernel/printk.c:1770:3: error: implicit declaration of function 'prepend_timestamp'
Cc: Kay Sievers <kay@vrfy.org>
Signed-off-by: Randy Dunlap <rdunlap@xenotime.net>
__log_buf must be aligned, because a 64-bit value is written directly
to it as part of struct log. Alignment of the log entries is typically
handled by log_store(), but this only triggers for subsequent entries,
not the very first (or wrapped) entries.
The output of the timestamps got lost with the conversion of the
kmsg buffer to records; restore the old behavior.
Document, that CONFIG_PRINTK_TIME now only controls the output of
the timestamps in the syslog() system call and on the console, and
not the recording of the timestamps.
Reported-by: Yinghai Lu <yinghai@kernel.org>
This prevents the merging of printk() continuation lines of different
threads, in the case they race against each other.
It should properly isolate "atomic" single-line printk() users from
continuation users, to make sure the single-line users will never be
merged with the racy continuation ones.
Reported-by: Randy Dunlap <rdunlap@xenotime.net>
On Tue, May 8, 2012 at 10:02 AM, Stephen Rothwell <sfr@canb.auug.org.au> wrote:
> kernel/built-in.o: In function `devkmsg_read':
> printk.c:(.text+0x27e8): undefined reference to `__udivdi3'
> Most probably the "msg->ts_nsec / 1000" since
> ts_nsec is a u64 and this is a 32 bit build ...
Support for multiple concurrent readers of /dev/kmsg, with read(),
seek(), poll() support. Output of message sequence numbers, to allow
userspace log consumers to reliably reconnect and reconstruct their
state at any given time. After open("/dev/kmsg"), read() always
returns *all* buffered records. If only future messages should be
read, SEEK_END can be used. In case records get overwritten while
/dev/kmsg is held open, or records get faster overwritten than they
are read, the next read() will return -EPIPE and the current reading
position gets updated to the next available record. The passed
sequence numbers allow the log consumer to calculate the amount of
lost messages.
[root@mop ~]# cat /dev/kmsg
5,0,0;Linux version 3.4.0-rc1+ (kay@mop) (gcc version 4.7.0 20120315 ...
6,159,423091;ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-ff])
7,160,424069;pci_root PNP0A03:00: host bridge window [io 0x0000-0x0cf7] (ignored)
SUBSYSTEM=acpi
DEVICE=+acpi:PNP0A03:00
6,339,5140900;NET: Registered protocol family 10
30,340,5690716;udevd[80]: starting version 181
6,341,6081421;FDC 0 is a S82078B
6,345,6154686;microcode: CPU0 sig=0x623, pf=0x0, revision=0x0
7,346,6156968;sr 1:0:0:0: Attached scsi CD-ROM sr0
SUBSYSTEM=scsi
DEVICE=+scsi:1:0:0:0
6,347,6289375;microcode: CPU1 sig=0x623, pf=0x0, revision=0x0
Cc: Karel Zak <kzak@redhat.com>
Tested-by: William Douglas <william.douglas@intel.com>
- Record-based stream instead of the traditional byte stream
buffer. All records carry a 64 bit timestamp, the syslog facility
and priority in the record header.
- Records consume almost the same amount, sometimes less memory than
the traditional byte stream buffer (if printk_time is enabled). The record
header is 16 bytes long, plus some padding bytes at the end if needed.
The byte-stream buffer needed 3 chars for the syslog prefix, 15 char for
the timestamp and a newline.
- Buffer management is based on message sequence numbers. When records
need to be discarded, the reading heads move on to the next full
record. Unlike the byte-stream buffer, no old logged lines get
truncated or partly overwritten by new ones. Sequence numbers also
allow consumers of the log stream to get notified if any message in
the stream they are about to read gets discarded during the time
of reading.
- Better buffered IO support for KERN_CONT continuation lines, when printk()
is called multiple times for a single line. The use of KERN_CONT is now
mandatory to use continuation; a few places in the kernel need trivial fixes
here. The buffering could possibly be extended to per-cpu variables to allow
better thread-safety for multiple printk() invocations for a single line.
- Full-featured syslog facility value support. Different facilities
can tag their messages. All userspace-injected messages enforce a
facility value > 0 now, to be able to reliably distinguish them from
the kernel-generated messages. Independent subsystems like a
baseband processor running its own firmware, or a kernel-related
userspace process can use their own unique facility values. Multiple
independent log streams can co-exist that way in the same
buffer. All share the same global sequence number counter to ensure
proper ordering (and interleaving) and to allow the consumers of the
log to reliably correlate the events from different facilities.
Pull scheduler changes for v3.4 from Ingo Molnar
* 'sched-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (27 commits)
printk: Make it compile with !CONFIG_PRINTK
sched/x86: Fix overflow in cyc2ns_offset
sched: Fix nohz load accounting -- again!
sched: Update yield() docs
printk/sched: Introduce special printk_sched() for those awkward moments
sched/nohz: Correctly initialize 'next_balance' in 'nohz' idle balancer
sched: Cleanup cpu_active madness
sched: Fix load-balance wreckage
sched: Clean up parameter passing of proc_sched_autogroup_set_nice()
sched: Ditch per cgroup task lists for load-balancing
sched: Rename load-balancing fields
sched: Move load-balancing arguments into helper struct
sched/rt: Do not submit new work when PI-blocked
sched/rt: Prevent idle task boosting
sched/wait: Add __wake_up_all_locked() API
sched/rt: Document scheduler related skip-resched-check sites
sched/rt: Use schedule_preempt_disabled()
sched/rt: Add schedule_preempt_disabled()
sched/rt: Do not throttle when PI boosting
sched/rt: Keep period timer ticking when rt throttling is active
Commit 3ccf3e830615 ("printk/sched: Introduce special
printk_sched() for those awkward moments") overlooked
an #ifdef, so move code around to respect these directives.
Cc: Randy Dunlap <rdunlap@xenotime.net>
Link: http://lkml.kernel.org/r/1331811337.18960.179.camel@twins
Merge reason: merge back final fixes, prepare for the merge window.
Merge reason: We are going to queue up a dependent patch.
There's a few awkward printk()s inside of scheduler guts that people
prefer to keep but really are rather deadlock prone. Fudge around it
by storing the text in a per-cpu buffer and poll it using the existing
printk_tick() handler.
This will drop output when its more frequent than once a tick, however
only the affinity thing could possible go that fast and for that just
one should suffice to notify the admin he's done something silly..
Link: http://lkml.kernel.org/n/tip-wua3lmkt3dg8nfts66o6brne@git.kernel.org
Since commit 04c6862c055f ("kmsg_dump: add kmsg_dump() calls to the
reboot, halt, poweroff and emergency_restart paths"), kmsg_dump() gets
run on normal paths including poweroff and reboot.
This is less than ideal given pstore implementations that can only
represent single backtraces, since a reboot may overwrite a stored oops
before it's been picked up by userspace. In addition, some pstore
backends may have low performance and provide a significant delay in
reboot as a result.
This patch adds a printk.always_kmsg_dump kernel parameter (which can also
be changed from userspace). Without it, the code will only be run on
failure paths rather than on normal paths. The option can be enabled in
environments where there's a desire to attempt to audit whether or not a
reboot was cleanly requested or not.
Acked-by: Seiji Aguchi <seiji.aguchi@hds.com>
Cc: Seiji Aguchi <seiji.aguchi@hds.com>
Cc: Marco Stornelli <marco.stornelli@gmail.com>
Cc: Artem Bityutskiy <Artem.Bityutskiy@nokia.com>
Cc: Vivek Goyal <vgoyal@redhat.com>
Cc: Don Zickus <dzickus@redhat.com>
Add a printk.console trace point to record any printk
messages into the trace, regardless of the current
console loglevel. This can help correlate (existing)
printk debugging with other tracing.
Link: http://lkml.kernel.org/r/1322161388.5366.54.camel@jlt3.sipsolutions.net
Acked-by: Frederic Weisbecker <fweisbec@gmail.com>
Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl>
module_param(bool) used to counter-intuitively take an int. In
fddd5201 (mid-2009) we allowed bool or int/unsigned int using a messy
trick.
It's time to remove the int/unsigned int option. For this version
it'll simply give a warning, but it'll break next kernel version.
You don't need module_param_name if the name is the same!
Cc: Yanmin Zhang <yanmin_zhang@linux.intel.com>
* 'core-printk-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
printk, lockdep: Switch to tracked irq ops
printk, lockdep: Remove superfluous preempt_disable()
printk, lockdep: Disable lock debugging on zap_locks()
git://git.kernel.org/pub/scm/linux/kernel/git/tj/misc into core/memblock
Commit 4f2a8d3cf5e ("printk: Fix console_sem vs logbuf_lock unlock race")
introduced another silly bug where we would want to acquire an already
held lock. Avoid this.
Reported-by: Andrea Arcangeli <aarcange@redhat.com>
Conflicts & resolutions:
* arch/x86/xen/setup.c
dc91c728fd "xen: allow extra memory to be in multiple regions"
24aa07882b "memblock, x86: Replace memblock_x86_reserve/free..."
conflicted on xen_add_extra_mem() updates. The resolution is
trivial as the latter just want to replace
memblock_x86_reserve_range() with memblock_reserve().
* drivers/pci/intel-iommu.c
166e9278a3f "x86/ia64: intel-iommu: move to drivers/iommu/"
5dfe8660a3d "bootmem: Replace work_with_active_regions() with..."
conflicted as the former moved the file under drivers/iommu/.
Resolved by applying the chnages from the latter on the moved
file.
* mm/Kconfig
6661672053a "memblock: add NO_BOOTMEM config symbol"
c378ddd53f9 "memblock, x86: Make ARCH_DISCARD_MEMBLOCK a config option"
conflicted trivially. Both added config options. Just
letting both add their own options resolves the conflict.
* mm/memblock.c
d1f0ece6cdc "mm/memblock.c: small function definition fixes"
ed7b56a799c "memblock: Remove memblock_memory_can_coalesce()"
confliected. The former updates function removed by the
latter. Resolution is trivial.
Switch to local_irq_ ops so that the irq state is properly tracked
(raw_local_irq_* isn't tracked by lockdep, causing confusion).
Possible now that commit dd4e5d3ac4a ("lockdep: Fix
trace_[soft,hard]irqs_[on,off]() recursion") cured the reason we
needed the raw_ ops.
The raw_lock_irq_{save,restore}() already implies a
non-preemptibility.
zap_locks() is used by printk() in a last ditch effort to get data
out, clearly we cannot trust lock state after this so make it disable
lock debugging.
Also don't treat printk recursion through lockdep as a normal
recursion bug but try hard to get the lockdep splat out.
Link: http://lkml.kernel.org/n/tip-kqxwmo4xz37e1s8w0xopvr0q@git.kernel.org
Currently log_prefix is testing that the first character of the log level
and facility is less than '0' and greater than '9' (which is always
false).
Since the code being updated works because strtoul bombs out (endp isn't
updated) and 0 is returned anyway just remove the check and don't change
the behavior of the function.
Signed-off-by: William Douglas <william.douglas@intel.com>
false). It should be testing to see if the character less than '0' or
greater than '9' instead. This patch makes that change.
The code being changed worked because strtoul bombs out (endp isn't
updated) and 0 is returned anyway.
We are enabling some power features on medfield. To test suspend-2-RAM
conveniently, we need turn on/off console_suspend_enabled frequently.
Add a module parameter, so users could change it by:
/sys/module/printk/parameters/console_suspend
Signed-off-by: Yanmin Zhang <yanmin_zhang@linux.intel.com>
conveniently, we need turn on/off ignore_loglevel frequently without
rebooting.
Add a module parameter, so users can change it by:
/sys/module/printk/parameters/ignore_loglevel
Signed-off-by: Yanmin Zhang <yanmin.zhang@intel.com>
The logbuf_lock lock can be taken in atomic context and therefore
cannot be preempted on -rt - annotate it.
In mainline this change documents the low level nature of
the lock - otherwise there's no functional difference. Lockdep
and Sparse checking will work as usual.
[ merged and fixed it ]
It seems that 7bf693951a8e ("console: allow to retain boot console via
boot option keep_bootcon") doesn't always achieve what it aims, as when
printk_late_init() runs it unconditionally turns off all boot consoles.
With this patch, I am able to see more messages on the boot console in
KVM guests than I can without, when keep_bootcon is specified.
I think it is appropriate for the relevant -stable trees. However, it's
more of an annoyance than a serious bug (ideally you don't need to keep
the boot console around as console handover should be working -- I was
encountering a situation where the console handover wasn't working and
not having the boot console available meant I couldn't see why).
Signed-off-by: Nishanth Aravamudan <nacc@us.ibm.com>
Cc: Alan Cox <alan@lxorguk.ukuu.org.uk>
Cc: Greg KH <gregkh@suse.de>
Acked-by: Fabio M. Di Nitto <fdinitto@redhat.com>
Cc: <stable@kernel.org> [2.6.39.x, 3.0.x]
syslog-ng versions before 3.3.0beta1 (2011-05-12) assume that
CAP_SYS_ADMIN is sufficient to access syslog, so ever since CAP_SYSLOG
was introduced (2010-11-25) they have triggered a warning.
Commit ee24aebffb75 ("cap_syslog: accept CAP_SYS_ADMIN for now")
improved matters a little by making syslog-ng work again, just keeping
the WARN_ONCE(). But still, this is a warning that writes a stack trace
we don't care about to syslog, sets a taint flag, and alarms sysadmins
when nothing worse has happened than use of an old userspace with a
recent kernel.
Convert the WARN_ONCE to a printk_once to avoid that while continuing to
give userspace developers a hint that this is an unwanted
backward-compatibility feature and won't be around forever.
Reported-by: Ralf Hildebrandt <ralf.hildebrandt@charite.de>
Reported-by: Niels <zorglub_olsen@hotmail.com>
Reported-by: Paweł Sikora <pluto@agmk.net>
Signed-off-by: Jonathan Nieder <jrnieder@gmail.com>
Liked-by: Gergely Nagy <algernon@madhouse-project.org>
Acked-by: Serge Hallyn <serge@hallyn.com>
Acked-by: James Morris <jmorris@namei.org>
25818f0f28 (memblock: Make MEMBLOCK_ERROR be 0) thankfully made
MEMBLOCK_ERROR 0 and there already are codes which expect error return
to be 0. There's no point in keeping MEMBLOCK_ERROR around. End its
misery.
Link: http://lkml.kernel.org/r/1310457490-3356-6-git-send-email-tj@kernel.org
Cc: Yinghai Lu <yinghai@kernel.org>
Fix up the fallout from commit 0b5e1c5255 ("printk: Release
console_sem after logbuf_lock").
The reason for unlocking the console_sem under the logbuf_lock
is that a concurrent printk() might fill up the buffer but fail
to acquire the console sem, resulting in a missed write to the
console until a subsequent console_sem acquire/release cycle.
Cc: efault@gmx.de
Link: http://lkml.kernel.org/r/1308734409.1022.14.camel@twins
Release console_sem after unlocking the logbuf_lock so that we don't
generate wakeups while holding logbuf_lock. This avoids some lock
inversion troubles once we remove the lockdep_off bits between
logbuf_lock and rq->lock (prints while holding rq->lock vs doing
wakeups while holding logbuf_lock).
There's of course still an actual deadlock where the printk()s under
rq->lock will issue a wakeup from the up() call, but lockdep won't
warn about that since semaphores are not tracked.
Link: http://lkml.kernel.org/n/tip-j8swthl12u73h4znbvitljzd@git.kernel.org
On larger systems, because of the numerous ACPI, Bootmem and EFI messages,
the static log buffer overflows before the larger one specified by the
log_buf_len param is allocated. Minimize the overflow by allocating the
new log buffer as soon as possible.
On kernels without memblock, a later call to setup_log_buf from
kernel/init.c is the fallback.
[akpm@linux-foundation.org: fix CONFIG_PRINTK=n build]
Signed-off-by: Mike Travis <travis@sgi.com>
Cc: Yinghai Lu <yhlu.kernel@gmail.com>
Cc: Jack Steiner <steiner@sgi.com>
We've been burned by regressions/bugs which we later realized could have
been triaged quicker if only we'd paid closer attention to dmesg. To make
it easier to audit dmesg, we'd like to make DEFAULT_MESSAGE_LEVEL
Kconfig-settable. That way we can set it to KERN_NOTICE and audit any
messages <= KERN_WARNING.
Signed-off-by: Mandeep Singh Baines <msb@chromium.org>
Cc: Olof Johansson <olofj@chromium.org>
Cc: Randy Dunlap <randy.dunlap@oracle.com>
For a platform with many consoles like:
"console=tty1 console=ttyMFD2 console=ttyS0 earlyprintk=mrst"
Each time when the non "selected_console" (tty1 and ttyMFD2 here) get
registered, the existing kernel message will be printed out on registered
consoles again, the "mrst" early console will get some same message for 3
times, and "tty1" will get some for twice.
As suggested by Andrew Morton, every time a new console is registered, it
will be set as the "exclusive" console which will dump the already
existing kernel messages.
Signed-off-by: Feng Tang <feng.tang@intel.com>
On some architectures, the boot process involves de-registering the boot
console (early boot), initialize drivers and then re-register the console.
This mechanism introduces a window in which no printk can happen on the
console and messages are buffered and then printed once the new console is
available.
If a kernel crashes during this window, all it's left on the boot console
is "console [foo] enabled, bootconsole disabled" making debug of the crash
rather 'interesting'.
By adding "keep_bootcon" option, do not unregister the boot console, that
will allow to printk everything that is happening up to the crash.
The option is clearly meant only for debugging purposes as it introduces
lots of duplicated info printed on console, but will make bug report from
users easier as it doesn't require a kernel build just to figure out where
we crash.
Signed-off-by: Fabio M. Di Nitto <fabbione@fabbione.net>
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core-2.6
* 'driver-core-next' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core-2.6: (50 commits)
printk: do not mangle valid userspace syslog prefixes
efivars: Add Documentation
efivars: Expose efivars functionality to external drivers.
efivars: Parameterize operations.
efivars: Split out variable registration
efivars: parameterize efivars
efivars: Make efivars bin_attributes dynamic
efivars: move efivars globals into struct efivars
drivers:misc: ti-st: fix debugging code
kref: Fix typo in kref documentation
UIO: add PRUSS UIO driver support
Fix spelling mistakes in Documentation/zh_CN/SubmittingPatches
firmware: Fix unaligned memory accesses in dmi-sysfs
firmware: Add documentation for /sys/firmware/dmi
firmware: Expose DMI type 15 System Event Log
firmware: Break out system_event_log in dmi-sysfs
firmware: Basic dmi-sysfs support
firmware: Add DMI entry types to the headers
Driver core: convert platform_{get,set}_drvdata to static inline functions
Translate linux-2.6/Documentation/magic-number.txt into Chinese
printk: do not mangle valid userspace syslog prefixes with /dev/kmsg
Log messages passed to the kernel log by using /dev/kmsg or /dev/ttyprintk
might contain a syslog prefix including the syslog facility value.
This makes printk to recognize these headers properly, extract the real log
level from it to use, and add the prefix as a proper prefix to the
log buffer, instead of wrongly printing it as the log message text.
Before:
$ echo '<14>text' > /dev/kmsg
$ dmesg -r
<4>[135159.594810] <14>text
After:
$ dmesg -r
<14>[ 50.750654] text
Cc: Lennart Poettering <lennart@poettering.net>
Signed-off-by: Kay Sievers <kay.sievers@vrfy.org>
In commit ce6ada35bdf7 ("security: Define CAP_SYSLOG") Serge Hallyn
introduced CAP_SYSLOG, but broke backwards compatibility by no longer
accepting CAP_SYS_ADMIN as an override (it would cause a warning and
then reject the operation).
Re-instate CAP_SYS_ADMIN - but keeping the warning - as an acceptable
capability until any legacy applications have been updated. There are
apparently applications out there that drop all capabilities except for
CAP_SYS_ADMIN in order to access the syslog.
(This is a re-implementation of a patch by Serge, cleaning the logic up
and making the code more readable)
Reviewed-by: James Morris <jmorris@namei.org>
The -rt patches change the console_semaphore to console_mutex. As a
result, a quite large chunk of the patches changes all
acquire/release_console_sem() to acquire/release_console_mutex()
This commit makes things use more neutral function names which dont make
implications about the underlying lock.
The only real change is the return value of console_trylock which is
inverted from try_acquire_console_sem()
This patch also paves the way to switching console_sem from a semaphore to
a mutex.
[akpm@linux-foundation.org: make console_trylock return 1 on success, per Geert]
Signed-off-by: Torben Hohn <torbenh@gmx.de>
Cc: Thomas Gleixner <tglx@tglx.de>
dump_list_lock is used to protect dump_list in kmsg_dumper implementation,
kmsg_dump() uses it to traverse dump_list too. But if there is contention
on the lock, kmsg_dump() will fail, and the valuable kernel message may be
lost.
This patch solves this issue with RCU. Because kmsg_dump() only read the
list, no lock is needed in kmsg_dump(). So that kmsg_dump() will never
fail because of lock contention.
Signed-off-by: Huang Ying <ying.huang@intel.com>
Cc: "Paul E. McKenney" <paulmck@us.ibm.com>
We need to know the reason why system rebooted in support service.
However, we can't inform our customers of the reason because final
messages are lost on current Linux kernel.
This patch improves the situation above because the final messages are
saved by adding kmsg_dump() to reboot, halt, poweroff and
emergency_restart path.
Signed-off-by: Seiji Aguchi <seiji.aguchi@hds.com>
Reviewed-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com>
Reviewed-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com>
security/smack/smack_lsm.c
Verified and added fix by Stephen Rothwell <sfr@canb.auug.org.au>
Ok'd by Casey Schaufler <casey@schaufler-ca.com>
Signed-off-by: James Morris <jmorris@namei.org>
