path: root/kernel/printk
2019-12-01printk: fix integer overflow in setup_log_buf()Sergey Senozhatsky
[ Upstream commit d2130e82e9454304e9b91ba9da551b5989af8c27 ] The way we calculate logbuf free space percentage overflows signed integer: int free; free = __LOG_BUF_LEN - log_next_idx; pr_info("early log buf free: %u(%u%%)\n", free, (free * 100) / __LOG_BUF_LEN); We support LOG_BUF_LEN of up to 1<<25 bytes. Since setup_log_buf() is called during early init, logbuf is mostly empty, so __LOG_BUF_LEN - log_next_idx is close to 1<<25. Thus when we multiply it by 100, we overflow signed integer value range: 100 is 2^6 + 2^5 + 2^2. Example, booting with LOG_BUF_LEN 1<<25 and log_buf_len=2G boot param: [ 0.075317] log_buf_len: -2147483648 bytes [ 0.075319] early log buf free: 33549896(-28%) Make "free" unsigned integer and use appropriate printk() specifier. Link: http://lkml.kernel.org/r/20181010113308.9337-1-sergey.senozhatsky@gmail.com To: Steven Rostedt <rostedt@goodmis.org> Cc: linux-kernel@vger.kernel.org Cc: Sergey Senozhatsky <sergey.senozhatsky.work@gmail.com> Signed-off-by: Sergey Senozhatsky <sergey.senozhatsky@gmail.com> Signed-off-by: Petr Mladek <pmladek@suse.com> Signed-off-by: Sasha Levin <sashal@kernel.org>
2019-11-24printk: Give error on attempt to set log buffer length to over 2GHe Zhe
[ Upstream commit e6fe3e5b7d16e8f146a4ae7fe481bc6e97acde1e ] The current printk() is ready to handle log buffer size up to 2G. Give an explicit error for users who want to use larger log buffer. Also fix printk formatting to show the 2G as a positive number. Link: http://lkml.kernel.org/r/20181008135916.gg4kkmoki5bgtco5@pathway.suse.cz Cc: rostedt@goodmis.org Cc: linux-kernel@vger.kernel.org Suggested-by: Sergey Senozhatsky <sergey.senozhatsky@gmail.com> Signed-off-by: He Zhe <zhe.he@windriver.com> Reviewed-by: Sergey Senozhatsky <sergey.senozhatsky@gmail.com> [pmladek: Fixed to the really safe limit 2GB.] Signed-off-by: Petr Mladek <pmladek@suse.com> Signed-off-by: Sasha Levin <sashal@kernel.org>
2019-10-05printk: Do not lose last line in kmsg buffer dumpVincent Whitchurch
commit c9dccacfccc72c32692eedff4a27a4b0833a2afd upstream. kmsg_dump_get_buffer() is supposed to select all the youngest log messages which fit into the provided buffer. It determines the correct start index by using msg_print_text() with a NULL buffer to calculate the size of each entry. However, when performing the actual writes, msg_print_text() only writes the entry to the buffer if the written len is lesser than the size of the buffer. So if the lengths of the selected youngest log messages happen to precisely fill up the provided buffer, the last log message is not included. We don't want to modify msg_print_text() to fill up the buffer and start returning a length which is equal to the size of the buffer, since callers of its other users, such as kmsg_dump_get_line(), depend upon the current behaviour. Instead, fix kmsg_dump_get_buffer() to compensate for this. For example, with the following two final prints: [ 6.427502] AAAAAAAAAAAAA [ 6.427769] BBBBBBBB12345 A dump of a 64-byte buffer filled by kmsg_dump_get_buffer(), before this patch: 00000000: 3c 30 3e 5b 20 20 20 20 36 2e 35 32 32 31 39 37 <0>[ 6.522197 00000010: 5d 20 41 41 41 41 41 41 41 41 41 41 41 41 41 0a ] AAAAAAAAAAAAA. 00000020: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00000030: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ After this patch: 00000000: 3c 30 3e 5b 20 20 20 20 36 2e 34 35 36 36 37 38 <0>[ 6.456678 00000010: 5d 20 42 42 42 42 42 42 42 42 31 32 33 34 35 0a ] BBBBBBBB12345. 00000020: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00000030: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ Link: http://lkml.kernel.org/r/20190711142937.4083-1-vincent.whitchurch@axis.com Fixes: e2ae715d66bf4bec ("kmsg - kmsg_dump() use iterator to receive log buffer content") To: rostedt@goodmis.org Cc: linux-kernel@vger.kernel.org Cc: <stable@vger.kernel.org> # v3.5+ Signed-off-by: Vincent Whitchurch <vincent.whitchurch@axis.com> Reviewed-by: Sergey Senozhatsky <sergey.senozhatsky@gmail.com> Signed-off-by: Petr Mladek <pmladek@suse.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-12-17printk: Wake klogd when passing console_lock ownerPetr Mladek
[ Upstream commit c14376de3a1befa70d9811ca2872d47367b48767 ] wake_klogd is a local variable in console_unlock(). The information is lost when the console_lock owner using the busy wait added by the commit dbdda842fe96f8932 ("printk: Add console owner and waiter logic to load balance console writes"). The following race is possible: CPU0 CPU1 console_unlock() for (;;) /* calling console for last message */ printk() log_store() log_next_seq++; /* see new message */ if (seen_seq != log_next_seq) { wake_klogd = true; seen_seq = log_next_seq; } console_lock_spinning_enable(); if (console_trylock_spinning()) /* spinning */ if (console_lock_spinning_disable_and_check()) { printk_safe_exit_irqrestore(flags); return; console_unlock() if (seen_seq != log_next_seq) { /* already seen */ /* nothing to do */ Result: Nobody would wakeup klogd. One solution would be to make a global variable from wake_klogd. But then we would need to manipulate it under a lock or so. This patch wakes klogd also when console_lock is passed to the spinning waiter. It looks like the right way to go. Also userspace should have a chance to see and store any "flood" of messages. Note that the very late klogd wake up was a historic solution. It made sense on single CPU systems or when sys_syslog() operations were synchronized using the big kernel lock like in v2.1.113. But it is questionable these days. Fixes: dbdda842fe96f8932 ("printk: Add console owner and waiter logic to load balance console writes") Link: http://lkml.kernel.org/r/20180226155734.dzwg3aovqnwtvkoy@pathway.suse.cz Cc: Steven Rostedt <rostedt@goodmis.org> Cc: linux-kernel@vger.kernel.org Cc: Tejun Heo <tj@kernel.org> Suggested-by: Sergey Senozhatsky <sergey.senozhatsky@gmail.com> Reviewed-by: Sergey Senozhatsky <sergey.senozhatsky@gmail.com> Signed-off-by: Petr Mladek <pmladek@suse.com> Signed-off-by: Sasha Levin <sashal@kernel.org>
2018-12-17printk: Never set console_may_schedule in console_trylock()Sergey Senozhatsky
[ Upstream commit fd5f7cde1b85d4c8e09ca46ce948e008a2377f64 ] This patch, basically, reverts commit 6b97a20d3a79 ("printk: set may_schedule for some of console_trylock() callers"). That commit was a mistake, it introduced a big dependency on the scheduler, by enabling preemption under console_sem in printk()->console_unlock() path, which is rather too critical. The patch did not significantly reduce the possibilities of printk() lockups, but made it possible to stall printk(), as has been reported by Tetsuo Handa [1]. Another issues is that preemption under console_sem also messes up with Steven Rostedt's hand off scheme, by making it possible to sleep with console_sem both in console_unlock() and in vprintk_emit(), after acquiring the console_sem ownership (anywhere between printk_safe_exit_irqrestore() in console_trylock_spinning() and printk_safe_enter_irqsave() in console_unlock()). This makes hand off less likely and, at the same time, may result in a significant amount of pending logbuf messages. Preempted console_sem owner makes it impossible for other CPUs to emit logbuf messages, but does not make it impossible for other CPUs to append new messages to the logbuf. Reinstate the old behavior and make printk() non-preemptible. Should any printk() lockup reports arrive they must be handled in a different way. [1] http://lkml.kernel.org/r/201603022101.CAH73907.OVOOMFHFFtQJSL%20()%20I-love%20!%20SAKURA%20!%20ne%20!%20jp Fixes: 6b97a20d3a79 ("printk: set may_schedule for some of console_trylock() callers") Link: http://lkml.kernel.org/r/20180116044716.GE6607@jagdpanzerIV To: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp> Cc: Sergey Senozhatsky <sergey.senozhatsky@gmail.com> Cc: Tejun Heo <tj@kernel.org> Cc: akpm@linux-foundation.org Cc: linux-mm@kvack.org Cc: Cong Wang <xiyou.wangcong@gmail.com> Cc: Dave Hansen <dave.hansen@intel.com> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: Mel Gorman <mgorman@suse.de> Cc: Michal Hocko <mhocko@kernel.org> Cc: Vlastimil Babka <vbabka@suse.cz> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Jan Kara <jack@suse.cz> Cc: Mathieu Desnoyers <mathieu.desnoyers@efficios.com> Cc: Byungchul Park <byungchul.park@lge.com> Cc: Pavel Machek <pavel@ucw.cz> Cc: linux-kernel@vger.kernel.org Signed-off-by: Sergey Senozhatsky <sergey.senozhatsky@gmail.com> Reported-by: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp> Reviewed-by: Steven Rostedt (VMware) <rostedt@goodmis.org> Signed-off-by: Petr Mladek <pmladek@suse.com> Signed-off-by: Sasha Levin <sashal@kernel.org>
2018-12-17printk: Hide console waiter logic into helpersPetr Mladek
[ Upstream commit c162d5b4338d72deed61aa65ed0f2f4ba2bbc8ab ] The commit ("printk: Add console owner and waiter logic to load balance console writes") made vprintk_emit() and console_unlock() even more complicated. This patch extracts the new code into 3 helper functions. They should help to keep it rather self-contained. It will be easier to use and maintain. This patch just shuffles the existing code. It does not change the functionality. Link: http://lkml.kernel.org/r/20180112160837.GD24497@linux.suse Cc: akpm@linux-foundation.org Cc: linux-mm@kvack.org Cc: Cong Wang <xiyou.wangcong@gmail.com> Cc: Dave Hansen <dave.hansen@intel.com> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: Mel Gorman <mgorman@suse.de> Cc: Michal Hocko <mhocko@kernel.org> Cc: Vlastimil Babka <vbabka@suse.cz> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Jan Kara <jack@suse.cz> Cc: Mathieu Desnoyers <mathieu.desnoyers@efficios.com> Cc: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp> Cc: rostedt@home.goodmis.org Cc: Byungchul Park <byungchul.park@lge.com> Cc: Tejun Heo <tj@kernel.org> Cc: Pavel Machek <pavel@ucw.cz> Cc: linux-kernel@vger.kernel.org Reviewed-by: Steven Rostedt (VMware) <rostedt@goodmis.org> Acked-by: Sergey Senozhatsky <sergey.senozhatsky@gmail.com> Signed-off-by: Petr Mladek <pmladek@suse.com> Signed-off-by: Sasha Levin <sashal@kernel.org>
2018-12-17printk: Add console owner and waiter logic to load balance console writesSteven Rostedt (VMware)
[ Upstream commit dbdda842fe96f8932bae554f0adf463c27c42bc7 ] This patch implements what I discussed in Kernel Summit. I added lockdep annotation (hopefully correctly), and it hasn't had any splats (since I fixed some bugs in the first iterations). It did catch problems when I had the owner covering too much. But now that the owner is only set when actively calling the consoles, lockdep has stayed quiet. Here's the design again: I added a "console_owner" which is set to a task that is actively writing to the consoles. It is *not* the same as the owner of the console_lock. It is only set when doing the calls to the console functions. It is protected by a console_owner_lock which is a raw spin lock. There is a console_waiter. This is set when there is an active console owner that is not current, and waiter is not set. This too is protected by console_owner_lock. In printk() when it tries to write to the consoles, we have: if (console_trylock()) console_unlock(); Now I added an else, which will check if there is an active owner, and no current waiter. If that is the case, then console_waiter is set, and the task goes into a spin until it is no longer set. When the active console owner finishes writing the current message to the consoles, it grabs the console_owner_lock and sees if there is a waiter, and clears console_owner. If there is a waiter, then it breaks out of the loop, clears the waiter flag (because that will release the waiter from its spin), and exits. Note, it does *not* release the console semaphore. Because it is a semaphore, there is no owner. Another task may release it. This means that the waiter is guaranteed to be the new console owner! Which it becomes. Then the waiter calls console_unlock() and continues to write to the consoles. If another task comes along and does a printk() it too can become the new waiter, and we wash rinse and repeat! By Petr Mladek about possible new deadlocks: The thing is that we move console_sem only to printk() call that normally calls console_unlock() as well. It means that the transferred owner should not bring new type of dependencies. As Steven said somewhere: "If there is a deadlock, it was there even before." We could look at it from this side. The possible deadlock would look like: CPU0 CPU1 console_unlock() console_owner = current; spin_lockA() printk() spin = true; while (...) call_console_drivers() spin_lockA() This would be a deadlock. CPU0 would wait for the lock A. While CPU1 would own the lockA and would wait for CPU0 to finish calling the console drivers and pass the console_sem owner. But if the above is true than the following scenario was already possible before: CPU0 spin_lockA() printk() console_unlock() call_console_drivers() spin_lockA() By other words, this deadlock was there even before. Such deadlocks are prevented by using printk_deferred() in the sections guarded by the lock A. By Steven Rostedt: To demonstrate the issue, this module has been shown to lock up a system with 4 CPUs and a slow console (like a serial console). It is also able to lock up a 8 CPU system with only a fast (VGA) console, by passing in "loops=100". The changes in this commit prevent this module from locking up the system. #include <linux/module.h> #include <linux/delay.h> #include <linux/sched.h> #include <linux/mutex.h> #include <linux/workqueue.h> #include <linux/hrtimer.h> static bool stop_testing; static unsigned int loops = 1; static void preempt_printk_workfn(struct work_struct *work) { int i; while (!READ_ONCE(stop_testing)) { for (i = 0; i < loops && !READ_ONCE(stop_testing); i++) { preempt_disable(); pr_emerg("%5d%-75s\n", smp_processor_id(), " XXX NOPREEMPT"); preempt_enable(); } msleep(1); } } static struct work_struct __percpu *works; static void finish(void) { int cpu; WRITE_ONCE(stop_testing, true); for_each_online_cpu(cpu) flush_work(per_cpu_ptr(works, cpu)); free_percpu(works); } static int __init test_init(void) { int cpu; works = alloc_percpu(struct work_struct); if (!works) return -ENOMEM; /* * This is just a test module. This will break if you * do any CPU hot plugging between loading and * unloading the module. */ for_each_online_cpu(cpu) { struct work_struct *work = per_cpu_ptr(works, cpu); INIT_WORK(work, &preempt_printk_workfn); schedule_work_on(cpu, work); } return 0; } static void __exit test_exit(void) { finish(); } module_param(loops, uint, 0); module_init(test_init); module_exit(test_exit); MODULE_LICENSE("GPL"); Link: http://lkml.kernel.org/r/20180110132418.7080-2-pmladek@suse.com Cc: akpm@linux-foundation.org Cc: linux-mm@kvack.org Cc: Cong Wang <xiyou.wangcong@gmail.com> Cc: Dave Hansen <dave.hansen@intel.com> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: Mel Gorman <mgorman@suse.de> Cc: Michal Hocko <mhocko@kernel.org> Cc: Vlastimil Babka <vbabka@suse.cz> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Jan Kara <jack@suse.cz> Cc: Mathieu Desnoyers <mathieu.desnoyers@efficios.com> Cc: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp> Cc: Byungchul Park <byungchul.park@lge.com> Cc: Tejun Heo <tj@kernel.org> Cc: Pavel Machek <pavel@ucw.cz> Cc: linux-kernel@vger.kernel.org Signed-off-by: Steven Rostedt (VMware) <rostedt@goodmis.org> [pmladek@suse.com: Commit message about possible deadlocks] Acked-by: Sergey Senozhatsky <sergey.senozhatsky@gmail.com> Signed-off-by: Petr Mladek <pmladek@suse.com> Signed-off-by: Sasha Levin <sashal@kernel.org>
2018-12-17Revert "printk: Never set console_may_schedule in console_trylock()"Sasha Levin
This reverts commit c9b8d580b3fb0ab65d37c372aef19a318fda3199. This is just a technical revert to make the printk fix apply cleanly, this patch will be re-picked in about 3 commits.
2018-11-21printk: Never set console_may_schedule in console_trylock()Sergey Senozhatsky
commit fd5f7cde1b85d4c8e09ca46ce948e008a2377f64 upstream. This patch, basically, reverts commit 6b97a20d3a79 ("printk: set may_schedule for some of console_trylock() callers"). That commit was a mistake, it introduced a big dependency on the scheduler, by enabling preemption under console_sem in printk()->console_unlock() path, which is rather too critical. The patch did not significantly reduce the possibilities of printk() lockups, but made it possible to stall printk(), as has been reported by Tetsuo Handa [1]. Another issues is that preemption under console_sem also messes up with Steven Rostedt's hand off scheme, by making it possible to sleep with console_sem both in console_unlock() and in vprintk_emit(), after acquiring the console_sem ownership (anywhere between printk_safe_exit_irqrestore() in console_trylock_spinning() and printk_safe_enter_irqsave() in console_unlock()). This makes hand off less likely and, at the same time, may result in a significant amount of pending logbuf messages. Preempted console_sem owner makes it impossible for other CPUs to emit logbuf messages, but does not make it impossible for other CPUs to append new messages to the logbuf. Reinstate the old behavior and make printk() non-preemptible. Should any printk() lockup reports arrive they must be handled in a different way. [1] http://lkml.kernel.org/r/201603022101.CAH73907.OVOOMFHFFtQJSL%20()%20I-love%20!%20SAKURA%20!%20ne%20!%20jp Fixes: 6b97a20d3a79 ("printk: set may_schedule for some of console_trylock() callers") Link: http://lkml.kernel.org/r/20180116044716.GE6607@jagdpanzerIV To: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp> Cc: Sergey Senozhatsky <sergey.senozhatsky@gmail.com> Cc: Tejun Heo <tj@kernel.org> Cc: akpm@linux-foundation.org Cc: linux-mm@kvack.org Cc: Cong Wang <xiyou.wangcong@gmail.com> Cc: Dave Hansen <dave.hansen@intel.com> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: Mel Gorman <mgorman@suse.de> Cc: Michal Hocko <mhocko@kernel.org> Cc: Vlastimil Babka <vbabka@suse.cz> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Jan Kara <jack@suse.cz> Cc: Mathieu Desnoyers <mathieu.desnoyers@efficios.com> Cc: Byungchul Park <byungchul.park@lge.com> Cc: Pavel Machek <pavel@ucw.cz> Cc: linux-kernel@vger.kernel.org Signed-off-by: Sergey Senozhatsky <sergey.senozhatsky@gmail.com> Reported-by: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp> Reviewed-by: Steven Rostedt (VMware) <rostedt@goodmis.org> Signed-off-by: Petr Mladek <pmladek@suse.com> Signed-off-by: Sudip Mukherjee <sudipm.mukherjee@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-11-13printk: Fix panic caused by passing log_buf_len to command lineHe Zhe
commit 277fcdb2cfee38ccdbe07e705dbd4896ba0c9930 upstream. log_buf_len_setup does not check input argument before passing it to simple_strtoull. The argument would be a NULL pointer if "log_buf_len", without its value, is set in command line and thus causes the following panic. PANIC: early exception 0xe3 IP 10:ffffffffaaeacd0d error 0 cr2 0x0 [ 0.000000] CPU: 0 PID: 0 Comm: swapper Not tainted 4.19.0-rc4-yocto-standard+ #1 [ 0.000000] RIP: 0010:_parse_integer_fixup_radix+0xd/0x70 ... [ 0.000000] Call Trace: [ 0.000000] simple_strtoull+0x29/0x70 [ 0.000000] memparse+0x26/0x90 [ 0.000000] log_buf_len_setup+0x17/0x22 [ 0.000000] do_early_param+0x57/0x8e [ 0.000000] parse_args+0x208/0x320 [ 0.000000] ? rdinit_setup+0x30/0x30 [ 0.000000] parse_early_options+0x29/0x2d [ 0.000000] ? rdinit_setup+0x30/0x30 [ 0.000000] parse_early_param+0x36/0x4d [ 0.000000] setup_arch+0x336/0x99e [ 0.000000] start_kernel+0x6f/0x4ee [ 0.000000] x86_64_start_reservations+0x24/0x26 [ 0.000000] x86_64_start_kernel+0x6f/0x72 [ 0.000000] secondary_startup_64+0xa4/0xb0 This patch adds a check to prevent the panic. Link: http://lkml.kernel.org/r/1538239553-81805-1-git-send-email-zhe.he@windriver.com Cc: stable@vger.kernel.org Cc: rostedt@goodmis.org Cc: linux-kernel@vger.kernel.org Signed-off-by: He Zhe <zhe.he@windriver.com> Reviewed-by: Sergey Senozhatsky <sergey.senozhatsky@gmail.com> Signed-off-by: Petr Mladek <pmladek@suse.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-09-09printk/tracing: Do not trace printk_nmi_enter()Steven Rostedt (VMware)
commit d1c392c9e2a301f38998a353f467f76414e38725 upstream. I hit the following splat in my tests: ------------[ cut here ]------------ IRQs not enabled as expected WARNING: CPU: 3 PID: 0 at kernel/time/tick-sched.c:982 tick_nohz_idle_enter+0x44/0x8c Modules linked in: ip6t_REJECT nf_reject_ipv6 ip6table_filter ip6_tables ipv6 CPU: 3 PID: 0 Comm: swapper/3 Not tainted 4.19.0-rc2-test+ #2 Hardware name: MSI MS-7823/CSM-H87M-G43 (MS-7823), BIOS V1.6 02/22/2014 EIP: tick_nohz_idle_enter+0x44/0x8c Code: ec 05 00 00 00 75 26 83 b8 c0 05 00 00 00 75 1d 80 3d d0 36 3e c1 00 75 14 68 94 63 12 c1 c6 05 d0 36 3e c1 01 e8 04 ee f8 ff <0f> 0b 58 fa bb a0 e5 66 c1 e8 25 0f 04 00 64 03 1d 28 31 52 c1 8b EAX: 0000001c EBX: f26e7f8c ECX: 00000006 EDX: 00000007 ESI: f26dd1c0 EDI: 00000000 EBP: f26e7f40 ESP: f26e7f38 DS: 007b ES: 007b FS: 00d8 GS: 00e0 SS: 0068 EFLAGS: 00010296 CR0: 80050033 CR2: 0813c6b0 CR3: 2f342000 CR4: 001406f0 Call Trace: do_idle+0x33/0x202 cpu_startup_entry+0x61/0x63 start_secondary+0x18e/0x1ed startup_32_smp+0x164/0x168 irq event stamp: 18773830 hardirqs last enabled at (18773829): [<c040150c>] trace_hardirqs_on_thunk+0xc/0x10 hardirqs last disabled at (18773830): [<c040151c>] trace_hardirqs_off_thunk+0xc/0x10 softirqs last enabled at (18773824): [<c0ddaa6f>] __do_softirq+0x25f/0x2bf softirqs last disabled at (18773767): [<c0416bbe>] call_on_stack+0x45/0x4b ---[ end trace b7c64aa79e17954a ]--- After a bit of debugging, I found what was happening. This would trigger when performing "perf" with a high NMI interrupt rate, while enabling and disabling function tracer. Ftrace uses breakpoints to convert the nops at the start of functions to calls to the function trampolines. The breakpoint traps disable interrupts and this makes calls into lockdep via the trace_hardirqs_off_thunk in the entry.S code. What happens is the following: do_idle { [interrupts enabled] <interrupt> [interrupts disabled] TRACE_IRQS_OFF [lockdep says irqs off] [...] TRACE_IRQS_IRET test if pt_regs say return to interrupts enabled [yes] TRACE_IRQS_ON [lockdep says irqs are on] <nmi> nmi_enter() { printk_nmi_enter() [traced by ftrace] [ hit ftrace breakpoint ] <breakpoint exception> TRACE_IRQS_OFF [lockdep says irqs off] [...] TRACE_IRQS_IRET [return from breakpoint] test if pt_regs say interrupts enabled [no] [iret back to interrupt] [iret back to code] tick_nohz_idle_enter() { lockdep_assert_irqs_enabled() [lockdep say no!] Although interrupts are indeed enabled, lockdep thinks it is not, and since we now do asserts via lockdep, it gives a false warning. The issue here is that printk_nmi_enter() is called before lockdep_off(), which disables lockdep (for this reason) in NMIs. By simply not allowing ftrace to see printk_nmi_enter() (via notrace annotation) we keep lockdep from getting confused. Cc: stable@vger.kernel.org Fixes: 42a0bb3f71383 ("printk/nmi: generic solution for safe printk in NMI") Acked-by: Sergey Senozhatsky <sergey.senozhatsky@gmail.com> Acked-by: Petr Mladek <pmladek@suse.com> Signed-off-by: Steven Rostedt (VMware) <rostedt@goodmis.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-09-05printk/nmi: Prevent deadlock when accessing the main log buffer in NMIPetr Mladek
commit 03fc7f9c99c1e7ae2925d459e8487f1a6f199f79 upstream. The commit 719f6a7040f1bdaf96 ("printk: Use the main logbuf in NMI when logbuf_lock is available") brought back the possible deadlocks in printk() and NMI. The check of logbuf_lock is done only in printk_nmi_enter() to prevent mixed output. But another CPU might take the lock later, enter NMI, and: + Both NMIs might be serialized by yet another lock, for example, the one in nmi_cpu_backtrace(). + The other CPU might get stopped in NMI, see smp_send_stop() in panic(). The only safe solution is to use trylock when storing the message into the main log-buffer. It might cause reordering when some lines go to the main lock buffer directly and others are delayed via the per-CPU buffer. It means that it is not useful in general. This patch replaces the problematic NMI deferred context with NMI direct context. It can be used to mark a code that might produce many messages in NMI and the risk of losing them is more critical than problems with eventual reordering. The context is then used when dumping trace buffers on oops. It was the primary motivation for the original fix. Also the reordering is even smaller issue there because some traces have their own time stamps. Finally, nmi_cpu_backtrace() need not longer be serialized because it will always us the per-CPU buffers again. Fixes: 719f6a7040f1bdaf96 ("printk: Use the main logbuf in NMI when logbuf_lock is available") Cc: stable@vger.kernel.org Link: http://lkml.kernel.org/r/20180627142028.11259-1-pmladek@suse.com To: Steven Rostedt <rostedt@goodmis.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp> Cc: Sergey Senozhatsky <sergey.senozhatsky.work@gmail.com> Cc: linux-kernel@vger.kernel.org Cc: stable@vger.kernel.org Acked-by: Sergey Senozhatsky <sergey.senozhatsky@gmail.com> Signed-off-by: Petr Mladek <pmladek@suse.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-09-05printk: Create helper function to queue deferred console handlingPetr Mladek
commit a338f84dc196f44b63ba0863d2f34fd9b1613572 upstream. It is just a preparation step. The patch does not change the existing behavior. Link: http://lkml.kernel.org/r/20180627140817.27764-3-pmladek@suse.com To: Steven Rostedt <rostedt@goodmis.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp> Cc: Sergey Senozhatsky <sergey.senozhatsky.work@gmail.com> Cc: linux-kernel@vger.kernel.org Cc: stable@vger.kernel.org Acked-by: Sergey Senozhatsky <sergey.senozhatsky@gmail.com> Signed-off-by: Petr Mladek <pmladek@suse.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-09-05printk: Split the code for storing a message into the log bufferPetr Mladek
commit ba552399954dde1b388f7749fecad5c349216981 upstream. It is just a preparation step. The patch does not change the existing behavior. Link: http://lkml.kernel.org/r/20180627140817.27764-2-pmladek@suse.com To: Steven Rostedt <rostedt@goodmis.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp> Cc: Sergey Senozhatsky <sergey.senozhatsky.work@gmail.com> Cc: linux-kernel@vger.kernel.org Cc: stable@vger.kernel.org Acked-by: Sergey Senozhatsky <sergey.senozhatsky@gmail.com> Signed-off-by: Petr Mladek <pmladek@suse.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-08-03printk: drop in_nmi check from printk_safe_flush_on_panic()Sergey Senozhatsky
[ Upstream commit 554755be08fba31c74f66b82a485e5513205af84 ] Drop the in_nmi() check from printk_safe_flush_on_panic() and attempt to re-init (IOW unlock) locked logbuf spinlock from panic CPU regardless of its context. Otherwise, theoretically, we can deadlock on logbuf trying to flush per-CPU buffers: a) Panic CPU is running in non-NMI context b) Panic CPU sends out shutdown IPI via reboot vector c) Panic CPU fails to stop all remote CPUs d) Panic CPU sends out shutdown IPI via NMI vector One of the CPUs that we bring down via NMI vector can hold logbuf spin lock (theoretically). Link: http://lkml.kernel.org/r/20180530070350.10131-1-sergey.senozhatsky@gmail.com To: Steven Rostedt <rostedt@goodmis.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: linux-kernel@vger.kernel.org Signed-off-by: Sergey Senozhatsky <sergey.senozhatsky@gmail.com> Signed-off-by: Petr Mladek <pmladek@suse.com> Signed-off-by: Sasha Levin <alexander.levin@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-07-03printk: fix possible reuse of va_list variableTetsuo Handa
commit 988a35f8da1dec5a8cd2788054d1e717be61bf25 upstream. I noticed that there is a possibility that printk_safe_log_store() causes kernel oops because "args" parameter is passed to vsnprintf() again when atomic_cmpxchg() detected that we raced. Fix this by using va_copy(). Link: http://lkml.kernel.org/r/201805112002.GIF21216.OFVHFOMLJtQFSO@I-love.SAKURA.ne.jp Cc: Peter Zijlstra <peterz@infradead.org> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: dvyukov@google.com Cc: syzkaller@googlegroups.com Cc: fengguang.wu@intel.com Cc: linux-kernel@vger.kernel.org Signed-off-by: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp> Fixes: 42a0bb3f71383b45 ("printk/nmi: generic solution for safe printk in NMI") Cc: 4.7+ <stable@vger.kernel.org> # v4.7+ Reviewed-by: Sergey Senozhatsky <sergey.senozhatsky@gmail.com> Signed-off-by: Petr Mladek <pmladek@suse.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
Many source files in the tree are missing licensing information, which makes it harder for compliance tools to determine the correct license. By default all files without license information are under the default license of the kernel, which is GPL version 2. Update the files which contain no license information with the 'GPL-2.0' SPDX license identifier. The SPDX identifier is a legally binding shorthand, which can be used instead of the full boiler plate text. This patch is based on work done by Thomas Gleixner and Kate Stewart and Philippe Ombredanne. How this work was done: Patches were generated and checked against linux-4.14-rc6 for a subset of the use cases: - file had no licensing information it it. - file was a */uapi/* one with no licensing information in it, - file was a */uapi/* one with existing licensing information, Further patches will be generated in subsequent months to fix up cases where non-standard license headers were used, and references to license had to be inferred by heuristics based on keywords. The analysis to determine which SPDX License Identifier to be applied to a file was done in a spreadsheet of side by side results from of the output of two independent scanners (ScanCode & Windriver) producing SPDX tag:value files created by Philippe Ombredanne. Philippe prepared the base worksheet, and did an initial spot review of a few 1000 files. The 4.13 kernel was the starting point of the analysis with 60,537 files assessed. Kate Stewart did a file by file comparison of the scanner results in the spreadsheet to determine which SPDX license identifier(s) to be applied to the file. She confirmed any determination that was not immediately clear with lawyers working with the Linux Foundation. Criteria used to select files for SPDX license identifier tagging was: - Files considered eligible had to be source code files. - Make and config files were included as candidates if they contained >5 lines of source - File already had some variant of a license header in it (even if <5 lines). All documentation files were explicitly excluded. The following heuristics were used to determine which SPDX license identifiers to apply. - when both scanners couldn't find any license traces, file was considered to have no license information in it, and the top level COPYING file license applied. For non */uapi/* files that summary was: SPDX license identifier # files ---------------------------------------------------|------- GPL-2.0 11139 and resulted in the first patch in this series. If that file was a */uapi/* path one, it was "GPL-2.0 WITH Linux-syscall-note" otherwise it was "GPL-2.0". Results of that was: SPDX license identifier # files ---------------------------------------------------|------- GPL-2.0 WITH Linux-syscall-note 930 and resulted in the second patch in this series. - if a file had some form of licensing information in it, and was one of the */uapi/* ones, it was denoted with the Linux-syscall-note if any GPL family license was found in the file or had no licensing in it (per prior point). Results summary: SPDX license identifier # files ---------------------------------------------------|------ GPL-2.0 WITH Linux-syscall-note 270 GPL-2.0+ WITH Linux-syscall-note 169 ((GPL-2.0 WITH Linux-syscall-note) OR BSD-2-Clause) 21 ((GPL-2.0 WITH Linux-syscall-note) OR BSD-3-Clause) 17 LGPL-2.1+ WITH Linux-syscall-note 15 GPL-1.0+ WITH Linux-syscall-note 14 ((GPL-2.0+ WITH Linux-syscall-note) OR BSD-3-Clause) 5 LGPL-2.0+ WITH Linux-syscall-note 4 LGPL-2.1 WITH Linux-syscall-note 3 ((GPL-2.0 WITH Linux-syscall-note) OR MIT) 3 ((GPL-2.0 WITH Linux-syscall-note) AND MIT) 1 and that resulted in the third patch in this series. - when the two scanners agreed on the detected license(s), that became the concluded license(s). - when there was disagreement between the two scanners (one detected a license but the other didn't, or they both detected different licenses) a manual inspection of the file occurred. - In most cases a manual inspection of the information in the file resulted in a clear resolution of the license that should apply (and which scanner probably needed to revisit its heuristics). - When it was not immediately clear, the license identifier was confirmed with lawyers working with the Linux Foundation. - If there was any question as to the appropriate license identifier, the file was flagged for further research and to be revisited later in time. In total, over 70 hours of logged manual review was done on the spreadsheet to determine the SPDX license identifiers to apply to the source files by Kate, Philippe, Thomas and, in some cases, confirmation by lawyers working with the Linux Foundation. Kate also obtained a third independent scan of the 4.13 code base from FOSSology, and compared selected files where the other two scanners disagreed against that SPDX file, to see if there was new insights. The Windriver scanner is based on an older version of FOSSology in part, so they are related. Thomas did random spot checks in about 500 files from the spreadsheets for the uapi headers and agreed with SPDX license identifier in the files he inspected. For the non-uapi files Thomas did random spot checks in about 15000 files. In initial set of patches against 4.14-rc6, 3 files were found to have copy/paste license identifier errors, and have been fixed to reflect the correct identifier. Additionally Philippe spent 10 hours this week doing a detailed manual inspection and review of the 12,461 patched files from the initial patch version early this week with: - a full scancode scan run, collecting the matched texts, detected license ids and scores - reviewing anything where there was a license detected (about 500+ files) to ensure that the applied SPDX license was correct - reviewing anything where there was no detection but the patch license was not GPL-2.0 WITH Linux-syscall-note to ensure that the applied SPDX license was correct This produced a worksheet with 20 files needing minor correction. This worksheet was then exported into 3 different .csv files for the different types of files to be modified. These .csv files were then reviewed by Greg. Thomas wrote a script to parse the csv files and add the proper SPDX tag to the file, in the format that the file expected. This script was further refined by Greg based on the output to detect more types of files automatically and to distinguish between header and source .c files (which need different comment types.) Finally Greg ran the script using the .csv files to generate the patches. Reviewed-by: Kate Stewart <kstewart@linuxfoundation.org> Reviewed-by: Philippe Ombredanne <pombredanne@nexb.com> Reviewed-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-09-07Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/pmladek/printk Pull printk updates from Petr Mladek: - Do not allow use of freed init data and code even when boot consoles are forced to stay. Also check for the init memory more precisely. - Some code clean up by starting contributors. * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/pmladek/printk: printk: Clean up do_syslog() error handling printk/console: Enhance the check for consoles using init memory printk/console: Always disable boot consoles that use init memory before it is freed printk: Modify operators of printed_len and text_len
2017-08-17Revert "pstore: Honor dmesg_restrict sysctl on dmesg dumps"Kees Cook
This reverts commit 68c4a4f8abc60c9440ede9cd123d48b78325f7a3, with various conflict clean-ups. The capability check required too much privilege compared to simple DAC controls. A system builder was forced to have crash handler processes run with CAP_SYSLOG which would give it the ability to read (and wipe) the _current_ dmesg, which is much more access than being given access only to the historical log stored in pstorefs. With the prior commit to make the root directory 0750, the files are protected by default but a system builder can now opt to give access to a specific group (via chgrp on the pstorefs root directory) without being forced to also give away CAP_SYSLOG. Suggested-by: Nick Kralevich <nnk@google.com> Signed-off-by: Kees Cook <keescook@chromium.org> Reviewed-by: Petr Mladek <pmladek@suse.cz> Reviewed-by: Sergey Senozhatsky <sergey.senozhatsky@gmail.com>
2017-08-15printk: Clean up do_syslog() error handlingNikitas Angelinas
The error variable in do_syslog() is preemptively set to the error code before the error condition is checked, and then set to 0 if the error condition is not encountered. This is not necessary, as it is likely simpler to return immediately upon encountering the error condition. A redundant set of the error variable to 0 is also removed. This patch has been build-tested on x86_64, but not tested for functionality. Link: http://lkml.kernel.org/r/20170730033636.GA935@vostro Cc: Steven Rostedt <rostedt@goodmis.org> Cc: linux-kernel@vger.kernel.org Signed-off-by: Nikitas Angelinas <nikitas.angelinas@gmail.com> Reviewed-by: Sergey Senozhatsky <sergey.senozhatsky@gmail.com> Signed-off-by: Petr Mladek <pmladek@suse.com>
2017-07-27printk/console: Enhance the check for consoles using init memoryPetr Mladek
printk_late_init() is responsible for disabling boot consoles that use init memory. It checks the address of struct console for this. But this is not enough. For example, there are several early consoles that have write() method in the init section and struct console in the normal section. They are not disabled and could cause fancy and hard to debug system states. It is even more complicated by the macros EARLYCON_DECLARE() and OF_EARLYCON_DECLARE() where various struct members are set at runtime by the provided setup() function. I have tried to reproduce this problem and forced the classic uart early console to stay using keep_bootcon parameter. In particular I used earlycon=uart,io,0x3f8 keep_bootcon console=ttyS0,115200. The system did not boot: [ 1.570496] PM: Image not found (code -22) [ 1.570496] PM: Image not found (code -22) [ 1.571886] PM: Hibernation image not present or could not be loaded. [ 1.571886] PM: Hibernation image not present or could not be loaded. [ 1.576407] Freeing unused kernel memory: 2528K [ 1.577244] kernel tried to execute NX-protected page - exploit attempt? (uid: 0) The double lines are caused by having both early uart console and ttyS0 console enabled at the same time. The early console stopped working when the init memory was freed. Fortunately, the invalid call was caught by the NX-protexted page check and did not cause any silent fancy problems. This patch adds a check for many other addresses stored in struct console. It omits setup() and match() that are used only when the console is registered. Therefore they have already been used at this point and there is no reason to use them again. Link: http://lkml.kernel.org/r/1500036673-7122-3-git-send-email-pmladek@suse.com Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Matt Redfearn <matt.redfearn@imgtec.com> Cc: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Cc: Jiri Slaby <jslaby@suse.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: Alan Cox <gnomes@lxorguk.ukuu.org.uk> Cc: "Fabio M. Di Nitto" <fdinitto@redhat.com> Cc: linux-serial@vger.kernel.org Cc: linux-kernel@vger.kernel.org Reviewed-by: Sergey Senozhatsky <sergey.senozhatsky@gmail.com> Signed-off-by: Petr Mladek <pmladek@suse.com>
2017-07-27printk/console: Always disable boot consoles that use init memory before it ↵Matt Redfearn
is freed Commit 4c30c6f566c0 ("kernel/printk: do not turn off bootconsole in printk_late_init() if keep_bootcon") added a check on keep_bootcon to ensure that boot consoles were kept around until the real console is registered. This can lead to problems if the boot console data and code are in the init section, since it can be freed before the boot console is unregistered. Commit 81cc26f2bd11 ("printk: only unregister boot consoles when necessary") fixed this a better way. It allowed to keep boot consoles that did not use init data. Unfortunately it did not remove the check of keep_bootcon. This can lead to crashes and weird panics when the bootconsole is accessed after free, especially if page poisoning is in use and the code / data have been overwritten with a poison value. To prevent this, always free the boot console if it is within the init section. In addition, print a warning about that the console is removed prematurely. Finally there is a new comment how to avoid the warning. It replaced an explanation that duplicated a more comprehensive function description few lines above. Fixes: 4c30c6f566c0 ("kernel/printk: do not turn off bootconsole in printk_late_init() if keep_bootcon") Link: http://lkml.kernel.org/r/1500036673-7122-2-git-send-email-pmladek@suse.com Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Cc: Jiri Slaby <jslaby@suse.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: Alan Cox <gnomes@lxorguk.ukuu.org.uk> Cc: "Fabio M. Di Nitto" <fdinitto@redhat.com> Cc: linux-serial@vger.kernel.org Cc: linux-kernel@vger.kernel.org Signed-off-by: Matt Redfearn <matt.redfearn@imgtec.com> [pmladek@suse.com: print the warning, code and comments clean up] Reviewed-by: Sergey Senozhatsky <sergey.senozhatsky@gmail.com> Signed-off-by: Petr Mladek <pmladek@suse.com>
2017-07-27printk: Modify operators of printed_len and text_lenPierre Kuo
With commit <ddb9baa82226> ("printk: report lost messages in printk safe/nmi contexts") and commit <8b1742c9c207> ("printk: remove zap_locks() function"), it seems we can remove initialization, "=0", of text_len and directly assign result of log_output to printed_len. Link: http://lkml.kernel.org/r/1499755255-6258-1-git-send-email-vichy.kuo@gmail.com Cc: rostedt@goodmis.org Cc: linux-kernel@vger.kernel.org Cc: joe@perches.com Signed-off-by: Pierre Kuo <vichy.kuo@gmail.com> Reviewed-by: Sergey Senozhatsky <sergey.senozhatsky@gmail.com> Signed-off-by: Petr Mladek <pmladek@suse.com>
2017-07-05Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/pmladek/printk Pull printk updates from Petr Mladek: - Store printk() messages into the main log buffer directly even in NMI when the lock is available. It is the best effort to print even large chunk of text. It is handy, for example, when all ftrace messages are printed during the system panic in NMI. - Add missing annotations to calm down compiler warnings * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/pmladek/printk: printk: add __printf attributes to internal functions printk: Use the main logbuf in NMI when logbuf_lock is available
2017-07-03Merge branch 'for-4.13' into for-linusPetr Mladek
2017-06-20Merge branch 'WIP.sched/core' into sched/coreIngo Molnar
Conflicts: kernel/sched/Makefile Pick up the waitqueue related renames - it didn't get much feedback, so it appears to be uncontroversial. Famous last words? ;-) Signed-off-by: Ingo Molnar <mingo@kernel.org>
2017-06-13printk: add __printf attributes to internal functionsNicolas Iooss
When compiling with -Wsuggest-attribute=format, gcc complains that some functions in kernel/printk/printk_safe.c transmit their argument to printf-like functions without having a printf attribute. Silence these warnings by adding relevant __printf attributes. Link: http://lkml.kernel.org/r/20170524054950.6722-1-nicolas.iooss_linux@m4x.org Cc: Steven Rostedt <rostedt@goodmis.org> Cc: linux-kernel@vger.kernel.org Signed-off-by: Nicolas Iooss <nicolas.iooss_linux@m4x.org> Reviewed-by: Sergey Senozhatsky <sergey.senozhatsky@gmail.com> Signed-off-by: Petr Mladek <pmladek@suse.com>
2017-06-08Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/pmladek/printk Pull printk fix from Petr Mladek: "This reverts a fix added into 4.12-rc1. It caused the kernel log to be printed on another console when two consoles of the same type were defined, e.g. console=ttyS0 console=ttyS1. This configuration was never supported by kernel itself, but it started to make sense with systemd. In other words, the commit broke userspace" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/pmladek/printk: Revert "printk: fix double printing with earlycon"
2017-06-08Revert "printk: fix double printing with earlycon"Petr Mladek
This reverts commit cf39bf58afdaabc0b86f141630fb3fd18190294e. The commit regression to users that define both console=ttyS1 and console=ttyS0 on the command line, see https://lkml.kernel.org/r/20170509082915.GA13236@bistromath.localdomain The kernel log messages always appeared only on one serial port. It is even documented in Documentation/admin-guide/serial-console.rst: "Note that you can only define one console per device type (serial, video)." The above mentioned commit changed the order in which the command line parameters are searched. As a result, the kernel log messages go to the last mentioned ttyS* instead of the first one. We long thought that using two console=ttyS* on the command line did not make sense. But then we realized that console= parameters were handled also by systemd, see http://0pointer.de/blog/projects/serial-console.html "By default systemd will instantiate one serial-getty@.service on the main kernel console, if it is not a virtual terminal." where "[4] If multiple kernel consoles are used simultaneously, the main console is the one listed first in /sys/class/tty/console/active, which is the last one listed on the kernel command line." This puts the original report into another light. The system is running in qemu. The first serial port is used to store the messages into a file. The second one is used to login to the system via a socket. It depends on systemd and the historic kernel behavior. By other words, systemd causes that it makes sense to define both console=ttyS1 console=ttyS0 on the command line. The kernel fix caused regression related to userspace (systemd) and need to be reverted. In addition, it went out that the fix helped only partially. The messages still were duplicated when the boot console was removed early by late_initcall(printk_late_init). Then the entire log was replayed when the same console was registered as a normal one. Link: 20170606160339.GC7604@pathway.suse.cz Cc: Aleksey Makarov <aleksey.makarov@linaro.org> Cc: Sabrina Dubroca <sd@queasysnail.net> Cc: Sudeep Holla <sudeep.holla@arm.com> Cc: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Cc: Peter Hurley <peter@hurleysoftware.com> Cc: Jiri Slaby <jslaby@suse.com> Cc: Robin Murphy <robin.murphy@arm.com>, Cc: Steven Rostedt <rostedt@goodmis.org> Cc: "Nair, Jayachandran" <Jayachandran.Nair@cavium.com> Cc: linux-serial@vger.kernel.org Cc: linux-kernel@vger.kernel.org Reported-by: Sabrina Dubroca <sd@queasysnail.net> Acked-by: Sergey Senozhatsky <sergey.senozhatsky@gmail.com> Signed-off-by: Petr Mladek <pmladek@suse.com>
2017-05-23printk: Adjust system_state checksThomas Gleixner
To enable smp_processor_id() and might_sleep() debug checks earlier, it's required to add system states between SYSTEM_BOOTING and SYSTEM_RUNNING. Adjust the system_state check in boot_delay_msec() to handle the extra states. Tested-by: Mark Rutland <mark.rutland@arm.com> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Peter Zijlstra (Intel) <peterz@infradead.org> Reviewed-by: Steven Rostedt (VMware) <rostedt@goodmis.org> Cc: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Peter Zijlstra <peterz@infradead.org> Link: http://lkml.kernel.org/r/20170516184736.027534895@linutronix.de Signed-off-by: Ingo Molnar <mingo@kernel.org>
2017-05-19printk: Use the main logbuf in NMI when logbuf_lock is availablePetr Mladek
The commit 42a0bb3f71383b457a7d ("printk/nmi: generic solution for safe printk in NMI") caused that printk stores messages into a temporary buffer in NMI context. The buffer is per-CPU and therefore the size is rather limited. It works quite well for NMI backtraces. But there are longer logs that might get printed in NMI context, for example, lockdep warnings, ftrace_dump_on_oops. The temporary buffer is used to avoid deadlocks caused by logbuf_lock. Also it is needed to avoid races with the other temporary buffer that is used when PRINTK_SAFE_CONTEXT is entered. But the main buffer can be used in NMI if the lock is available and we did not interrupt PRINTK_SAFE_CONTEXT. The lock is checked using raw_spin_is_locked(). It might cause false negatives when the lock is taken on another CPU and this CPU is in the safe context from other reasons. Note that the safe context is used also to get console semaphore or when calling console drivers. For this reason, we do the check in printk_nmi_enter(). It makes the handling consistent for the entire NMI handler and avoids reshuffling of the messages. The patch also defines special printk context that allows to use printk_deferred() in NMI. Note that we could not flush the messages to the consoles because console drivers might use many other internal locks. The newly created vprintk_deferred() disables the preemption only around the irq work handling. It is needed there to keep the consistency between the two per-CPU variables. But there is no reason to disable preemption around vprintk_emit(). Finally, the patch puts back explicit serialization of the NMI backtraces from different CPUs. It was removed by the commit a9edc88093287183ac934b ("x86/nmi: Perform a safe NMI stack trace on all CPUs"). It was not needed because the flushing of the temporary per-CPU buffers was serialized. Link: http://lkml.kernel.org/r/1493912763-24873-1-git-send-email-pmladek@suse.com Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Russell King <rack+kernel@arm.linux.org.uk> Cc: Daniel Thompson <daniel.thompson@linaro.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Chris Metcalf <cmetcalf@ezchip.com> Cc: x86@kernel.org Cc: linux-arm-kernel@lists.infradead.org Cc: linux-kernel@vger.kernel.org Suggested-by: Sergey Senozhatsky <sergey.senozhatsky@gmail.com> Acked-by: Sergey Senozhatsky <sergey.senozhatsky@gmail.com> Signed-off-by: Petr Mladek <pmladek@suse.com>
2017-05-08Merge tag 'tty-4.12-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty Pull tty/serial updates from Greg KH: "Here is the "big" TTY/Serial patch updates for 4.12-rc1 Not a lot of new things here, the normal number of serial driver updates and additions, tiny bugs fixed, and some core files split up to make future changes a bit easier for Nicolas's "tiny-tty" work. All of these have been in linux-next for a while" * tag 'tty-4.12-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty: (62 commits) serial: small Makefile reordering tty: split job control support into a file of its own tty: move baudrate handling code to a file of its own console: move console_init() out of tty_io.c serial: 8250_early: Add earlycon support for Palmchip UART tty: pl011: use "qdf2400_e44" as the earlycon name for QDF2400 E44 vt: make mouse selection of non-ASCII consistent vt: set mouse selection word-chars to gpm's default imx-serial: Reduce RX DMA startup latency when opening for reading serial: omap: suspend device on probe errors serial: omap: fix runtime-pm handling on unbind tty: serial: omap: add UPF_BOOT_AUTOCONF flag for DT init serial: samsung: Remove useless spinlock serial: samsung: Add missing checks for dma_map_single failure serial: samsung: Use right device for DMA-mapping calls serial: imx: setup DCEDTE early and ensure DCD and RI irqs to be off tty: fix comment typo s/repsonsible/responsible/ tty: amba-pl011: Fix spurious TX interrupts serial: xuartps: Enable clocks in the pm disable case also serial: core: Re-use struct uart_port {name} field ...
2017-05-08crash: move crashkernel parsing and vmcore related code under CONFIG_CRASH_COREHari Bathini
Patch series "kexec/fadump: remove dependency with CONFIG_KEXEC and reuse crashkernel parameter for fadump", v4. Traditionally, kdump is used to save vmcore in case of a crash. Some architectures like powerpc can save vmcore using architecture specific support instead of kexec/kdump mechanism. Such architecture specific support also needs to reserve memory, to be used by dump capture kernel. crashkernel parameter can be a reused, for memory reservation, by such architecture specific infrastructure. This patchset removes dependency with CONFIG_KEXEC for crashkernel parameter and vmcoreinfo related code as it can be reused without kexec support. Also, crashkernel parameter is reused instead of fadump_reserve_mem to reserve memory for fadump. The first patch moves crashkernel parameter parsing and vmcoreinfo related code under CONFIG_CRASH_CORE instead of CONFIG_KEXEC_CORE. The second patch reuses the definitions of append_elf_note() & final_note() functions under CONFIG_CRASH_CORE in IA64 arch code. The third patch removes dependency on CONFIG_KEXEC for firmware-assisted dump (fadump) in powerpc. The next patch reuses crashkernel parameter for reserving memory for fadump, instead of the fadump_reserve_mem parameter. This has the advantage of using all syntaxes crashkernel parameter supports, for fadump as well. The last patch updates fadump kernel documentation about use of crashkernel parameter. This patch (of 5): Traditionally, kdump is used to save vmcore in case of a crash. Some architectures like powerpc can save vmcore using architecture specific support instead of kexec/kdump mechanism. Such architecture specific support also needs to reserve memory, to be used by dump capture kernel. crashkernel parameter can be a reused, for memory reservation, by such architecture specific infrastructure. But currently, code related to vmcoreinfo and parsing of crashkernel parameter is built under CONFIG_KEXEC_CORE. This patch introduces CONFIG_CRASH_CORE and moves the above mentioned code under this config, allowing code reuse without dependency on CONFIG_KEXEC. There is no functional change with this patch. Link: http://lkml.kernel.org/r/149035338104.6881.4550894432615189948.stgit@hbathini.in.ibm.com Signed-off-by: Hari Bathini <hbathini@linux.vnet.ibm.com> Acked-by: Dave Young <dyoung@redhat.com> Cc: Fenghua Yu <fenghua.yu@intel.com> Cc: Tony Luck <tony.luck@intel.com> Cc: Eric Biederman <ebiederm@xmission.com> Cc: Mahesh Salgaonkar <mahesh@linux.vnet.ibm.com> Cc: Vivek Goyal <vgoyal@redhat.com> Cc: Michael Ellerman <mpe@ellerman.id.au> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2017-05-03Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/pmladek/printk Pull printk updates from Petr Mladek: - There is a situation when early console is not deregistered because the preferred one matches a wrong entry. It caused messages to appear twice. This is the 2nd attempt to fix it. The first one was wrong, see the commit c6c7d83b9c9e ('Revert "console: don't prefer first registered if DT specifies stdout-path"'). The fix is coupled with some small code clean up. Well, the console registration code would deserve a big one. We need to think about it. - Do not lose information about the preemtive context when the console semaphore is re-taken. - Do not block CPU hotplug when someone else is already pushing messages to the console. * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/pmladek/printk: printk: fix double printing with earlycon printk: rename selected_console -> preferred_console printk: fix name/type/scope of preferred_console var printk: Correctly handle preemption in console_unlock() printk: use console_trylock() in console_cpu_notify()
2017-04-18console: move console_init() out of tty_io.cNicolas Pitre
All the console driver handling code lives in printk.c. Move console_init() there as well so console support can still be used when the TTY code is configured out. No logical changes from this patch. Signed-off-by: Nicolas Pitre <nico@linaro.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-04-12printk: fix double printing with earlyconAleksey Makarov
If a console was specified by ACPI SPCR table _and_ command line parameters like "console=ttyAMA0" _and_ "earlycon" were specified, then log messages appear twice. The root cause is that the code traverses the list of specified consoles (the `console_cmdline` array) and stops at the first match. But it may happen that the same console is referred by the elements of this array twice: pl011,mmio,0x87e024000000,115200 -- from SPCR ttyAMA0 -- from command line but in this case `preferred_console` points to the second entry and the flag CON_CONSDEV is not set, so bootconsole is not deregistered. To fix that, introduce an invariant "The last non-braille console is always the preferred one" on the entries of the console_cmdline array. Then traverse it in reverse order to be sure that if the console is preferred then it will be the first matching entry. Introduce variable console_cmdline_cnt that keeps the number of elements of the console_cmdline array (Petr Mladek). It helps to get rid of the loop that searches for the end of this array. Link: http://lkml.kernel.org/r/20170405202006.18234-1-aleksey.makarov@linaro.org Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Cc: Peter Hurley <peter@hurleysoftware.com> Cc: Jiri Slaby <jslaby@suse.com> Cc: Robin Murphy <robin.murphy@arm.com> Cc: "Nair, Jayachandran" <Jayachandran.Nair@cavium.com> Cc: linux-serial@vger.kernel.org Cc: linux-kernel@vger.kernel.org Signed-off-by: Aleksey Makarov <aleksey.makarov@linaro.org> Reported-by: Sudeep Holla <sudeep.holla@arm.com> Acked-by: Sergey Senozhatsky <sergey.senozhatsky@gmail.com> Signed-off-by: Petr Mladek <pmladek@suse.com>
2017-04-12printk: rename selected_console -> preferred_consoleAleksey Makarov
The variable selected_console is set in __add_preferred_console() to point to the last console parameter that was added to the console_cmdline array. Rename it to preferred_console so that the name reflects the usage. Petr Mladek: "[..] the selected_console/preferred_console value is used to keep the console first in the console_drivers list. IMHO, the main effect is that each line will first appear on this console, see call_console_drivers(). But the message will still appear also on all other enabled consoles. From this point, the name "preferred" sounds better to me. More consoles are selected (enabled) and only one is preferred (first)." Link: http://lkml.kernel.org/r/20170315102854.1763-3-aleksey.makarov@linaro.org Cc: Sudeep Holla <sudeep.holla@arm.com> Cc: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Cc: Jiri Slaby <jslaby@suse.com> Cc: Robin Murphy <robin.murphy@arm.com> Cc: "Nair, Jayachandran" <Jayachandran.Nair@cavium.com> Cc: linux-serial@vger.kernel.org Cc: linux-kernel@vger.kernel.org Signed-off-by: Aleksey Makarov <aleksey.makarov@linaro.org> Suggested-by: Peter Hurley <peter@hurleysoftware.com> Acked-by: Steven Rostedt (VMware) <rostedt@goodmis.org> Reviewed-by: Sergey Senozhatsky <sergey.senozhatsky@gmail.com> Signed-off-by: Petr Mladek <pmladek@suse.com>
2017-04-12printk: fix name/type/scope of preferred_console varAleksey Makarov
The variable preferred_console is used only inside register_console() and its semantics is boolean. It is negative when no console has been made preferred. Make it static bool and rename to has_preferred. Renaming was suggested by Peter Hurley Link: http://lkml.kernel.org/r/20170315102854.1763-2-aleksey.makarov@linaro.org Cc: Sudeep Holla <sudeep.holla@arm.com> Cc: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Cc: Peter Hurley <peter@hurleysoftware.com> Cc: Jiri Slaby <jslaby@suse.com> Cc: Robin Murphy <robin.murphy@arm.com> Cc: "Nair, Jayachandran" <Jayachandran.Nair@cavium.com> Cc: linux-serial@vger.kernel.org Cc: linux-kernel@vger.kernel.org Signed-off-by: Aleksey Makarov <aleksey.makarov@linaro.org> Reviewed-by: Steven Rostedt (VMware) <rostedt@goodmis.org> Reviewed-by: Sergey Senozhatsky <sergey.senozhatsky@gmail.com> Signed-off-by: Petr Mladek <pmladek@suse.com>
2017-04-04printk: Correctly handle preemption in console_unlock()Petr Mladek
Some console drivers code calls console_conditional_schedule() that looks at @console_may_schedule. The value must be cleared when the drivers are called from console_unlock() with interrupts disabled. But rescheduling is fine when the same code is called, for example, from tty operations where the console semaphore is taken via console_lock(). This is why @console_may_schedule is cleared before calling console drivers. The original value is stored to decide if we could sleep between lines. Now, @console_may_schedule is not cleared when we call console_trylock() and jump back to the "again" goto label. This has become a problem, since the commit 6b97a20d3a7909daa066 ("printk: set may_schedule for some of console_trylock() callers"). @console_may_schedule might get enabled now. There is also the opposite problem. console_lock() can be called only from preemptive context. It can always enable scheduling in the console code. But console_trylock() is not able to detect it when CONFIG_PREEMPT_COUNT is disabled. Therefore we should use the original @console_may_schedule value after re-acquiring the console semaphore in console_unlock(). This patch solves both problems by moving the "again" goto label. Alternative solution was to clear and restore the value around call_console_drivers(). Then console_conditional_schedule() could be used also inside console_unlock(). But there was a potential race with console_flush_on_panic() as reported by Sergey Senozhatsky. That function should be called only where there is only one CPU and with interrupts disabled. But better be on the safe side because stopping CPUs might fail. Fixes: 6b97a20d3a7909 ("printk: set may_schedule for some of console_trylock() callers") Link: http://lkml.kernel.org/r/1490372045-22288-1-git-send-email-pmladek@suse.com Suggested-by: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Cc: Jiri Slaby <jslaby@suse.cz> Cc: linux-fbdev@vger.kernel.org Cc: linux-kernel@vger.kernel.org Reviewed-by: Sergey Senozhatsky <sergey.senozhatsky@gmail.com> Signed-off-by: Petr Mladek <pmladek@suse.com>
2017-03-31braille-console: Fix value returned by _braille_console_setupSamuel Thibault
commit bbeddf52adc1 ("printk: move braille console support into separate braille.[ch] files") introduced _braille_console_setup() to outline the braille initialization code. There was however some confusion over the value it was supposed to return. commit 2cfe6c4ac7ee ("printk: Fix return of braille_register_console()") tried to fix it but failed to. This fixes and documents the returned value according to the use in printk.c: non-zero return means a parsing error, and thus this console configuration should be ignored. Signed-off-by: Samuel Thibault <samuel.thibault@ens-lyon.org> Cc: Aleksey Makarov <aleksey.makarov@linaro.org> Cc: Joe Perches <joe@perches.com> Cc: Ming Lei <ming.lei@canonical.com> Cc: Steven Rostedt <rostedt@goodmis.org> Acked-by: Petr Mladek <pmladek@suse.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-03-24printk: use console_trylock() in console_cpu_notify()Sergey Senozhatsky
There is no need to always call blocking console_lock() in console_cpu_notify(), it's quite possible that console_sem can be locked by other CPU on the system, either already printing or soon to begin printing the messages. console_lock() in this case can simply block CPU hotplug for unknown period of time (console_unlock() is time unbound). Not that hotplug is very fast, but still, with other CPUs being online and doing printk() console_cpu_notify() can stuck. Use console_trylock() instead and opt-out if console_sem is already acquired from another CPU, since that CPU will do the printing for us. Link: http://lkml.kernel.org/r/20170121104729.8585-1-sergey.senozhatsky@gmail.com Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Sebastian Andrzej Siewior <bigeasy@linutronix.de> Cc: Ingo Molnar <mingo@kernel.org> Cc: linux-kernel@vger.kernel.org Signed-off-by: Sergey Senozhatsky <sergey.senozhatsky@gmail.com> Signed-off-by: Petr Mladek <pmladek@suse.com>
2017-03-02sched/headers: Prepare for new header dependencies before moving code to ↵Ingo Molnar
<linux/sched/task_stack.h> We are going to split <linux/sched/task_stack.h> out of <linux/sched.h>, which will have to be picked up from other headers and a couple of .c files. Create a trivial placeholder <linux/sched/task_stack.h> file that just maps to <linux/sched.h> to make this patch obviously correct and bisectable. Include the new header in the files that are going to need it. Acked-by: Linus Torvalds <torvalds@linux-foundation.org> Cc: Mike Galbraith <efault@gmx.de> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: linux-kernel@vger.kernel.org Signed-off-by: Ingo Molnar <mingo@kernel.org>
<linux/sched/debug.h> We are going to split <linux/sched/debug.h> out of <linux/sched.h>, which will have to be picked up from other headers and a couple of .c files. Create a trivial placeholder <linux/sched/debug.h> file that just maps to <linux/sched.h> to make this patch obviously correct and bisectable. Include the new header in the files that are going to need it. Acked-by: Linus Torvalds <torvalds@linux-foundation.org> Cc: Mike Galbraith <efault@gmx.de> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: linux-kernel@vger.kernel.org Signed-off-by: Ingo Molnar <mingo@kernel.org>
<linux/sched/clock.h> We are going to split <linux/sched/clock.h> out of <linux/sched.h>, which will have to be picked up from other headers and .c files. Create a trivial placeholder <linux/sched/clock.h> file that just maps to <linux/sched.h> to make this patch obviously correct and bisectable. Include the new header in the files that are going to need it. Acked-by: Linus Torvalds <torvalds@linux-foundation.org> Cc: Mike Galbraith <efault@gmx.de> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: linux-kernel@vger.kernel.org Signed-off-by: Ingo Molnar <mingo@kernel.org>
2017-02-22Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/pmladek/printk Pull printk updates from Petr Mladek: - Add Petr Mladek, Sergey Senozhatsky as printk maintainers, and Steven Rostedt as the printk reviewer. This idea came up after the discussion about printk issues at Kernel Summit. It was formulated and discussed at lkml[1]. - Extend a lock-less NMI per-cpu buffers idea to handle recursive printk() calls by Sergey Senozhatsky[2]. It is the first step in sanitizing printk as discussed at Kernel Summit. The change allows to see messages that would normally get ignored or would cause a deadlock. Also it allows to enable lockdep in printk(). This already paid off. The testing in linux-next helped to discover two old problems that were hidden before[3][4]. - Remove unused parameter by Sergey Senozhatsky. Clean up after a past change. [1] http://lkml.kernel.org/r/1481798878-31898-1-git-send-email-pmladek@suse.com [2] http://lkml.kernel.org/r/20161227141611.940-1-sergey.senozhatsky@gmail.com [3] http://lkml.kernel.org/r/20170215044332.30449-1-sergey.senozhatsky@gmail.com [4] http://lkml.kernel.org/r/20170217015932.11898-1-sergey.senozhatsky@gmail.com * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/pmladek/printk: printk: drop call_console_drivers() unused param printk: convert the rest to printk-safe printk: remove zap_locks() function printk: use printk_safe buffers in printk printk: report lost messages in printk safe/nmi contexts printk: always use deferred printk when flush printk_safe lines printk: introduce per-cpu safe_print seq buffer printk: rename nmi.c and exported api printk: use vprintk_func in vprintk() MAINTAINERS: Add printk maintainers
2017-02-18printk: use rcuidle console tracepointSergey Senozhatsky
Use rcuidle console tracepoint because, apparently, it may be issued from an idle CPU: hw-breakpoint: Failed to enable monitor mode on CPU 0. hw-breakpoint: CPU 0 failed to disable vector catch =============================== [ ERR: suspicious RCU usage. ] 4.10.0-rc8-next-20170215+ #119 Not tainted ------------------------------- ./include/trace/events/printk.h:32 suspicious rcu_dereference_check() usage! other info that might help us debug this: RCU used illegally from idle CPU! rcu_scheduler_active = 2, debug_locks = 0 RCU used illegally from extended quiescent state! 2 locks held by swapper/0/0: #0: (cpu_pm_notifier_lock){......}, at: [<c0237e2c>] cpu_pm_exit+0x10/0x54 #1: (console_lock){+.+.+.}, at: [<c01ab350>] vprintk_emit+0x264/0x474 stack backtrace: CPU: 0 PID: 0 Comm: swapper/0 Not tainted 4.10.0-rc8-next-20170215+ #119 Hardware name: Generic OMAP4 (Flattened Device Tree) console_unlock vprintk_emit vprintk_default printk reset_ctrl_regs dbg_cpu_pm_notify notifier_call_chain cpu_pm_exit omap_enter_idle_coupled cpuidle_enter_state cpuidle_enter_state_coupled do_idle cpu_startup_entry start_kernel This RCU warning, however, is suppressed by lockdep_off() in printk(). lockdep_off() increments the ->lockdep_recursion counter and thus disables RCU_LOCKDEP_WARN() and debug_lockdep_rcu_enabled(), which want lockdep to be enabled "current->lockdep_recursion == 0". Link: http://lkml.kernel.org/r/20170217015932.11898-1-sergey.senozhatsky@gmail.com Signed-off-by: Sergey Senozhatsky <sergey.senozhatsky@gmail.com> Reported-by: Tony Lindgren <tony@atomide.com> Tested-by: Tony Lindgren <tony@atomide.com> Acked-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Acked-by: Steven Rostedt (VMware) <rostedt@goodmis.org> Cc: Petr Mladek <pmladek@suse.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Tony Lindgren <tony@atomide.com> Cc: Russell King <rmk@armlinux.org.uk> Cc: <stable@vger.kernel.org> [3.4+] Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2017-02-08printk: drop call_console_drivers() unused paramSergey Senozhatsky
We do suppress_message_printing() check before we call call_console_drivers() now, so `level' param is not needed anymore. Link: http://lkml.kernel.org/r/20161224140902.1962-2-sergey.senozhatsky@gmail.com Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Peter Hurley <peter@hurleysoftware.com> Cc: linux-kernel@vger.kernel.org Signed-off-by: Sergey Senozhatsky <sergey.senozhatsky@gmail.com> Signed-off-by: Petr Mladek <pmladek@suse.com>
2017-02-08printk: convert the rest to printk-safeSergey Senozhatsky
This patch converts the rest of logbuf users (which are out of printk recursion case, but can deadlock in printk). To make printk-safe usage easier the patch introduces 4 helper macros: - logbuf_lock_irq()/logbuf_unlock_irq() lock/unlock the logbuf lock and disable/enable local IRQ - logbuf_lock_irqsave(flags)/logbuf_unlock_irqrestore(flags) lock/unlock the logbuf lock and saves/restores local IRQ state Link: http://lkml.kernel.org/r/20161227141611.940-9-sergey.senozhatsky@gmail.com Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Jan Kara <jack@suse.cz> Cc: Tejun Heo <tj@kernel.org> Cc: Calvin Owens <calvinowens@fb.com> Cc: Ingo Molnar <mingo@redhat.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Andy Lutomirski <luto@kernel.org> Cc: Peter Hurley <peter@hurleysoftware.com> Cc: linux-kernel@vger.kernel.org Signed-off-by: Sergey Senozhatsky <sergey.senozhatsky@gmail.com> Signed-off-by: Petr Mladek <pmladek@suse.com>
2017-02-08printk: remove zap_locks() functionSergey Senozhatsky
We use printk-safe now which makes printk-recursion detection code in vprintk_emit() unreachable. The tricky thing here is that, apart from detecting and reporting printk recursions, that code also used to zap_locks() in case of panic() from the same CPU. However, zap_locks() does not look to be needed anymore: 1) Since commit 08d78658f393 ("panic: release stale console lock to always get the logbuf printed out") panic flushing of `logbuf' to console ignores the state of `console_sem' by doing panic() console_trylock(); console_unlock(); 2) Since commit cf9b1106c81c ("printk/nmi: flush NMI messages on the system panic") panic attempts to zap the `logbuf_lock' spin_lock to successfully flush nmi messages to `logbuf'. Basically, it seems that we either already do what zap_locks() used to do but in other places or we ignore the state of the lock. The only reaming difference is that we don't re-init the console semaphore in printk_safe_flush_on_panic(), but this is not necessary because we don't call console drivers from printk_safe_flush_on_panic() due to the fact that we are using a deferred printk() version (as was suggested by Petr Mladek). Link: http://lkml.kernel.org/r/20161227141611.940-8-sergey.senozhatsky@gmail.com Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Jan Kara <jack@suse.cz> Cc: Tejun Heo <tj@kernel.org> Cc: Calvin Owens <calvinowens@fb.com> Cc: Ingo Molnar <mingo@redhat.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Andy Lutomirski <luto@kernel.org> Cc: Peter Hurley <peter@hurleysoftware.com> Cc: linux-kernel@vger.kernel.org Signed-off-by: Sergey Senozhatsky <sergey.senozhatsky@gmail.com> Signed-off-by: Petr Mladek <pmladek@suse.com>
2017-02-08printk: use printk_safe buffers in printkSergey Senozhatsky
Use printk_safe per-CPU buffers in printk recursion-prone blocks: -- around logbuf_lock protected sections in vprintk_emit() and console_unlock() -- around down_trylock_console_sem() and up_console_sem() Note that this solution addresses deadlocks caused by printk() recursive calls only. That is vprintk_emit() and console_unlock(). The rest will be converted in a followup patch. Another thing to note is that we now keep lockdep enabled in printk, because we are protected against the printk recursion caused by lockdep in vprintk_emit() by the printk-safe mechanism - we first switch to per-CPU buffers and only then access the deadlock-prone locks. Examples: 1) printk() from logbuf_lock spin_lock section Assume the following code: printk() raw_spin_lock(&logbuf_lock); WARN_ON(1); raw_spin_unlock(&logbuf_lock); which now produces: ------------[ cut here ]------------ WARNING: CPU: 0 PID: 366 at kernel/printk/printk.c:1811 vprintk_emit CPU: 0 PID: 366 Comm: bash Call Trace: warn_slowpath_null+0x1d/0x1f vprintk_emit+0x1cd/0x438 vprintk_default+0x1d/0x1f printk+0x48/0x50 [..] 2) printk() from semaphore sem->lock spin_lock section Assume the following code printk() console_trylock() down_trylock() raw_spin_lock_irqsave(&sem->lock, flags); WARN_ON(1); raw_spin_unlock_irqrestore(&sem->lock, flags); which now produces: ------------[ cut here ]------------ WARNING: CPU: 1 PID: 363 at kernel/locking/semaphore.c:141 down_trylock CPU: 1 PID: 363 Comm: bash Call Trace: warn_slowpath_null+0x1d/0x1f down_trylock+0x3d/0x62 ? vprintk_emit+0x3f9/0x414 console_trylock+0x31/0xeb vprintk_emit+0x3f9/0x414 vprintk_default+0x1d/0x1f printk+0x48/0x50 [..] 3) printk() from console_unlock() Assume the following code: printk() console_unlock() raw_spin_lock(&logbuf_lock); WARN_ON(1); raw_spin_unlock(&logbuf_lock); which now produces: ------------[ cut here ]------------ WARNING: CPU: 1 PID: 329 at kernel/printk/printk.c:2384 console_unlock CPU: 1 PID: 329 Comm: bash Call Trace: warn_slowpath_null+0x18/0x1a console_unlock+0x12d/0x559 ? trace_hardirqs_on_caller+0x16d/0x189 ? trace_hardirqs_on+0xd/0xf vprintk_emit+0x363/0x374 vprintk_default+0x18/0x1a printk+0x43/0x4b [..] 4) printk() from try_to_wake_up() Assume the following code: printk() console_unlock() up() try_to_wake_up() raw_spin_lock_irqsave(&p->pi_lock, flags); WARN_ON(1); raw_spin_unlock_irqrestore(&p->pi_lock, flags); which now produces: ------------[ cut here ]------------ WARNING: CPU: 3 PID: 363 at kernel/sched/core.c:2028 try_to_wake_up CPU: 3 PID: 363 Comm: bash Call Trace: warn_slowpath_null+0x1d/0x1f try_to_wake_up+0x7f/0x4f7 wake_up_process+0x15/0x17 __up.isra.0+0x56/0x63 up+0x32/0x42 __up_console_sem+0x37/0x55 console_unlock+0x21e/0x4c2 vprintk_emit+0x41c/0x462 vprintk_default+0x1d/0x1f printk+0x48/0x50 [..] 5) printk() from call_console_drivers() Assume the following code: printk() console_unlock() call_console_drivers() ... WARN_ON(1); which now produces: ------------[ cut here ]------------ WARNING: CPU: 2 PID: 305 at kernel/printk/printk.c:1604 call_console_drivers CPU: 2 PID: 305 Comm: bash Call Trace: warn_slowpath_null+0x18/0x1a call_console_drivers.isra.6.constprop.16+0x3a/0xb0 console_unlock+0x471/0x48e vprintk_emit+0x1f4/0x206 vprintk_default+0x18/0x1a vprintk_func+0x6e/0x70 printk+0x3e/0x46 [..] 6) unsupported placeholder in printk() format now prints an actual warning from vscnprintf(), instead of 'BUG: recent printk recursion!'. ------------[ cut here ]------------ WARNING: CPU: 5 PID: 337 at lib/vsprintf.c:1900 format_decode Please remove unsupported % in format string CPU: 5 PID: 337 Comm: bash Call Trace: dump_stack+0x4f/0x65 __warn+0xc2/0xdd warn_slowpath_fmt+0x4b/0x53 format_decode+0x22c/0x308 vsnprintf+0x89/0x3b7 vscnprintf+0xd/0x26 vprintk_emit+0xb4/0x238 vprintk_default+0x1d/0x1f vprintk_func+0x6c/0x73 printk+0x43/0x4b [..] Link: http://lkml.kernel.org/r/20161227141611.940-7-sergey.senozhatsky@gmail.com Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Jan Kara <jack@suse.cz> Cc: Tejun Heo <tj@kernel.org> Cc: Calvin Owens <calvinowens@fb.com> Cc: Ingo Molnar <mingo@redhat.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Andy Lutomirski <luto@kernel.org> Cc: Peter Hurley <peter@hurleysoftware.com> Cc: linux-kernel@vger.kernel.org Signed-off-by: Sergey Senozhatsky <sergey.senozhatsky@gmail.com> Signed-off-by: Petr Mladek <pmladek@suse.com> Reviewed-by: Steven Rostedt (VMware) <rostedt@goodmis.org>
