path: root/kernel/profile.c
2008-11-30cpuinit fixes in kernel/*Al Viro
2008-11-18kernel/profile.c: fix section mismatch warningRakib Mullick
Impact: fix section mismatch warning in kernel/profile.c Here, profile_nop function has been called from a non-init function create_hash_tables(void). Which generetes a section mismatch warning. Previously, create_hash_tables(void) was a init function. So, removing __init from create_hash_tables(void) requires profile_nop to be non-init. This patch makes profile_nop function inline and fixes the following warning: WARNING: vmlinux.o(.text+0x6ebb6): Section mismatch in reference from the function create_hash_tables() to the function .init.text:profile_nop() The function create_hash_tables() references the function __init profile_nop(). This is often because create_hash_tables lacks a __init annotation or the annotation of profile_nop is wrong. Signed-off-by: Rakib Mullick <rakib.mullick@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-10-30kernel/profile: fix profile_init() section mismatchPaul Mundt
profile_init() calls in to alloc_bootmem() on early initialization. While alloc_bootmem() is __init, the reference itself is safe in that it is tucked below a !slab_is_available() check. So, flag profile_init() as __ref. Signed-off-by: Paul Mundt <lethal@linux-sh.org> Cc: Dave Hansen <dave@linux.vnet.ibm.com> Cc: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-16profiling: dynamically enable readprofile at runtimeDave Hansen
Way too often, I have a machine that exhibits some kind of crappy behavior. The CPU looks wedged in the kernel or it is spending way too much system time and I wonder what is responsible. I try to run readprofile. But, of course, Ubuntu doesn't enable it by default. Dang! The reason we boot-time enable it is that it takes a big bufffer that we generally can only bootmem alloc. But, does it hurt to at least try and runtime-alloc it? To use: echo 2 > /sys/kernel/profile Then run readprofile like normal. This should fix the compile issue with allmodconfig. I've compile-tested on a bunch more configs now including a few more architectures. Signed-off-by: Dave Hansen <dave@linux.vnet.ibm.com> Acked-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-25build kernel/profile.o only when requestedAdrian Bunk
Build kernel/profile.o only if CONFIG_PROFILING is enabled. This makes CONFIG_PROFILING=n kernels smaller. As a bonus, some profile_tick() calls and one branch from schedule() are now eliminated with CONFIG_PROFILING=n (but I doubt these are measurable effects). This patch changes the effects of CONFIG_PROFILING=n, but I don't think having more than two choices would be the better choice. This patch also adds the name of the first parameter to the prototypes of profile_{hits,tick}() since I anyway had to add them for the dummy functions. Signed-off-by: Adrian Bunk <bunk@kernel.org> Cc: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-06-26on_each_cpu(): kill unused 'retry' parameterJens Axboe
It's not even passed on to smp_call_function() anymore, since that was removed. So kill it. Acked-by: Jeremy Fitzhardinge <jeremy.fitzhardinge@citrix.com> Reviewed-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-04-29kernel: use non-racy method for proc entries creationDenis V. Lunev
Use proc_create()/proc_create_data() to make sure that ->proc_fops and ->data be setup before gluing PDE to main tree. Signed-off-by: Denis V. Lunev <den@openvz.org> Cc: Alexey Dobriyan <adobriyan@gmail.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-18kernel: Remove unnecessary inclusions of asm/semaphore.hMatthew Wilcox
None of these files use any of the functionality promised by asm/semaphore.h. Signed-off-by: Matthew Wilcox <willy@linux.intel.com>
2008-02-08Nuke a duplicate include from profile.cJesper Juhl
Remove duplicate inclusion of linux/profile.h from kernel/profile.c Signed-off-by: Jesper Juhl <jesper.juhl@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-01-25debug: clean up kernel/profile.cPaolo Ciarrocchi
Before: total: 25 errors, 13 warnings, 602 lines checked After: total: 0 errors, 2 warnings, 601 lines checked No code changed: kernel/profile.o: text data bss dec hex filename 3048 236 24 3308 cec profile.o.before 3048 236 24 3308 cec profile.o.after md5: 2501d64748a4d350dffb11203e2a5182 profile.o.before.asm 2501d64748a4d350dffb11203e2a5182 profile.o.after.asm Signed-off-by: Paolo Ciarrocchi <paolo.ciarrocchi@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2007-10-24sched: document profile=sleep requiring CONFIG_SCHEDSTATSMel Gorman
profile=sleep only works if CONFIG_SCHEDSTATS is set. This patch notes the limitation in Documentation/kernel-parameters.txt and prints a warning at boot-time if profile=sleep is used without CONFIG_SCHEDSTAT. Signed-off-by: Mel Gorman <mel@csn.ul.ie> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2007-10-17make kernel/profile.c:time_hook staticAdrian Bunk
{,un}register_timer_hook() is the API that should be used. Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16Memoryless nodes: Allow profiling data to fall back to other nodesChristoph Lameter
Processors on memoryless nodes must be able to fall back to remote nodes in order to get a profiling buffer. This may lead to excessive NUMA traffic but I think we should allow this rather than failing. Signed-off-by: Christoph Lameter <clameter@sgi.com> Acked-by: Nishanth Aravamudan <nacc@us.ibm.com> Acked-by: Lee Schermerhorn <lee.schermerhorn@hp.com> Acked-by: Bob Picco <bob.picco@hp.com> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Mel Gorman <mel@skynet.ie> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-08-11fix compilation with gcc 4.2Peter Chubb
gcc-4.2 is a lot more picky about its symbol handling. EXPORT_SYMBOL no longer works on symbols that are undefined or defined with static scope. For example, with CONFIG_PROFILE off, I see: kernel/profile.c:206: error: __ksymtab_profile_event_unregister causes a section type conflict kernel/profile.c:205: error: __ksymtab_profile_event_register causes a section type conflict This patch moves the EXPORTs inside the #ifdef CONFIG_PROFILE, so we only try to export symbols that are defined. Also, in kernel/kprobes.c there's an EXPORT_SYMBOL_GPL() for jprobes_return, which if CONFIG_JPROBES is undefined is a static inline and gives the same error. And in drivers/acpi/resources/rsxface.c, there's an ACPI_EXPORT_SYMBOPL() for a static symbol. If it's static, it's not accessible from outside the compilation unit, so should bot be exported. These three changes allow building a zx1_defconfig kernel with gcc 4.2 on IA64. [akpm@linux-foundation.org: export jpobe_return properly] Signed-off-by: Peter Chubb <peterc@gelato.unsw.edu.au> Cc: Prasanna S Panchamukhi <prasanna@in.ibm.com> Cc: Ananth N Mavinakayanahalli <ananth@in.ibm.com> Cc: Anil S Keshavamurthy <anil.s.keshavamurthy@intel.com> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: Len Brown <lenb@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-21Detach sched.h from mm.hAlexey Dobriyan
First thing mm.h does is including sched.h solely for can_do_mlock() inline function which has "current" dereference inside. By dealing with can_do_mlock() mm.h can be detached from sched.h which is good. See below, why. This patch a) removes unconditional inclusion of sched.h from mm.h b) makes can_do_mlock() normal function in mm/mlock.c c) exports can_do_mlock() to not break compilation d) adds sched.h inclusions back to files that were getting it indirectly. e) adds less bloated headers to some files (asm/signal.h, jiffies.h) that were getting them indirectly Net result is: a) mm.h users would get less code to open, read, preprocess, parse, ... if they don't need sched.h b) sched.h stops being dependency for significant number of files: on x86_64 allmodconfig touching sched.h results in recompile of 4083 files, after patch it's only 3744 (-8.3%). Cross-compile tested on all arm defconfigs, all mips defconfigs, all powerpc defconfigs, alpha alpha-up arm i386 i386-up i386-defconfig i386-allnoconfig ia64 ia64-up m68k mips parisc parisc-up powerpc powerpc-up s390 s390-up sparc sparc-up sparc64 sparc64-up um-x86_64 x86_64 x86_64-up x86_64-defconfig x86_64-allnoconfig as well as my two usual configs. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-09Add suspend-related notifications for CPU hotplugRafael J. Wysocki
Since nonboot CPUs are now disabled after tasks and devices have been frozen and the CPU hotplug infrastructure is used for this purpose, we need special CPU hotplug notifications that will help the CPU-hotplug-aware subsystems distinguish normal CPU hotplug events from CPU hotplug events related to a system-wide suspend or resume operation in progress. This patch introduces such notifications and causes them to be used during suspend and resume transitions. It also changes all of the CPU-hotplug-aware subsystems to take these notifications into consideration (for now they are handled in the same way as the corresponding "normal" ones). [oleg@tv-sign.ru: cleanups] Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Cc: Gautham R Shenoy <ego@in.ibm.com> Cc: Pavel Machek <pavel@ucw.cz> Signed-off-by: Oleg Nesterov <oleg@tv-sign.ru> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-11[PATCH] proc: remove useless (and buggy) ->nlink settingsAlexey Dobriyan
Bug: pnx8550 code creates directory but resets ->nlink to 1. create_proc_entry() et al will correctly set ->nlink for you. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Jeff Dike <jdike@addtoit.com> Cc: Corey Minyard <minyard@acm.org> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Cc: Kyle McMartin <kyle@mcmartin.ca> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Greg KH <greg@kroah.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-01-23[PATCH] fix "kvm: add vm exit profiling"Andrew Morton
export profile_hits() on !SMP too. Cc: Ingo Molnar <mingo@elte.hu> Cc: Avi Kivity <avi@qumranet.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-01-11[PATCH] KVM: add VM-exit profilingIngo Molnar
This adds the profile=kvm boot option, which enables KVM to profile VM exits. Use: "readprofile -m ./System.map | sort -n" to see the resulting output: [...] 18246 serial_out 148.3415 18945 native_flush_tlb 378.9000 23618 serial_in 212.7748 29279 __spin_unlock_irq 622.9574 43447 native_apic_write 2068.9048 52702 enable_8259A_irq 742.2817 54250 vgacon_scroll 89.3740 67394 ide_inb 6126.7273 79514 copy_page_range 98.1654 84868 do_wp_page 86.6000 140266 pit_read 783.6089 151436 ide_outb 25239.3333 152668 native_io_delay 21809.7143 174783 mask_and_ack_8259A 783.7803 362404 native_set_pte_at 36240.4000 1688747 total 0.5009 Signed-off-by: Ingo Molnar <mingo@elte.hu> Acked-by: Avi Kivity <avi@qumranet.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2007-01-05[PATCH] profiling: fix sched profiling typoIngo Molnar
Fix sched profiling typo, introduced by the sleep profiling patch. This bug caused profile=sched to not work. Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-07[PATCH] struct seq_operations and struct file_operations constificationHelge Deller
- move some file_operations structs into the .rodata section - move static strings from policy_types[] array into the .rodata section - fix generic seq_operations usages, so that those structs may be defined as "const" as well [akpm@osdl.org: couple of fixes] Signed-off-by: Helge Deller <deller@gmx.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-07[PATCH] hotplug CPU: clean up hotcpu_notifier() useIngo Molnar
There was lots of #ifdef noise in the kernel due to hotcpu_notifier(fn, prio) not correctly marking 'fn' as used in the !HOTPLUG_CPU case, and thus generating compiler warnings of unused symbols, hence forcing people to add #ifdefs. the compiler can skip truly unused functions just fine: text data bss dec hex filename 1624412 728710 3674856 6027978 5bfaca vmlinux.before 1624412 728710 3674856 6027978 5bfaca vmlinux.after [akpm@osdl.org: topology.c fix] Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-07[PATCH] sleep profilingIngo Molnar
Implement prof=sleep profiling. TASK_UNINTERRUPTIBLE sleeps will be taken as a profile hit, and every millisecond spent sleeping causes a profile-hit for the call site that initiated the sleep. Sample readprofile output on i386: 306 ps2_sendbyte 1.3973 432 call_usermodehelper_keys 1.9548 484 ps2_command 0.6453 790 __driver_attach 4.7879 1593 msleep 44.2500 3976 sync_buffer 64.1290 4076 do_lookup 12.4648 8587 sync_page 122.6714 20820 total 0.0067 (NOTE: architectures need to check whether get_wchan() can be called from deep within the wakeup path.) akpm: we need to mark more functions __sched. lock_sock(), msleep(), others.. akpm: the contention in do_lookup() is a surprise. Presumably doing disk reads for directory contents while holding i_mutex. [akpm@osdl.org: various fixes] Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-07[PATCH] profile: fix uaccess handlingHeiko Carstens
Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-11[PATCH] bitmap: parse input from kernel and user buffersReinette Chatre
lib/bitmap.c:bitmap_parse() is a library function that received as input a user buffer. This seemed to have originated from the way the write_proc function of the /proc filesystem operates. This has been reworked to not use kmalloc and eliminates a lot of get_user() overhead by performing one access_ok before using __get_user(). We need to test if we are in kernel or user space (is_user) and access the buffer differently. We cannot use __get_user() to access kernel addresses in all cases, for example in architectures with separate address space for kernel and user. This function will be useful for other uses as well; for example, taking input for /sysfs instead of /proc, so it was changed to accept kernel buffers. We have this use for the Linux UWB project, as part as the upcoming bandwidth allocator code. Only a few routines used this function and they were changed too. Signed-off-by: Reinette Chatre <reinette.chatre@linux.intel.com> Signed-off-by: Inaky Perez-Gonzalez <inaky@linux.intel.com> Cc: Paul Jackson <pj@sgi.com> Cc: Joe Korty <joe.korty@ccur.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
Maintain a per-CPU global "struct pt_regs *" variable which can be used instead of passing regs around manually through all ~1800 interrupt handlers in the Linux kernel. The regs pointer is used in few places, but it potentially costs both stack space and code to pass it around. On the FRV arch, removing the regs parameter from all the genirq function results in a 20% speed up of the IRQ exit path (ie: from leaving timer_interrupt() to leaving do_IRQ()). Where appropriate, an arch may override the generic storage facility and do something different with the variable. On FRV, for instance, the address is maintained in GR28 at all times inside the kernel as part of general exception handling. Having looked over the code, it appears that the parameter may be handed down through up to twenty or so layers of functions. Consider a USB character device attached to a USB hub, attached to a USB controller that posts its interrupts through a cascaded auxiliary interrupt controller. A character device driver may want to pass regs to the sysrq handler through the input layer which adds another few layers of parameter passing. I've build this code with allyesconfig for x86_64 and i386. I've runtested the main part of the code on FRV and i386, though I can't test most of the drivers. I've also done partial conversion for powerpc and MIPS - these at least compile with minimal configurations. This will affect all archs. Mostly the changes should be relatively easy. Take do_IRQ(), store the regs pointer at the beginning, saving the old one: struct pt_regs *old_regs = set_irq_regs(regs); And put the old one back at the end: set_irq_regs(old_regs); Don't pass regs through to generic_handle_irq() or __do_IRQ(). In timer_interrupt(), this sort of change will be necessary: - update_process_times(user_mode(regs)); - profile_tick(CPU_PROFILING, regs); + update_process_times(user_mode(get_irq_regs())); + profile_tick(CPU_PROFILING); I'd like to move update_process_times()'s use of get_irq_regs() into itself, except that i386, alone of the archs, uses something other than user_mode(). Some notes on the interrupt handling in the drivers: (*) input_dev() is now gone entirely. The regs pointer is no longer stored in the input_dev struct. (*) finish_unlinks() in drivers/usb/host/ohci-q.c needs checking. It does something different depending on whether it's been supplied with a regs pointer or not. (*) Various IRQ handler function pointers have been moved to type irq_handler_t. Signed-Off-By: David Howells <dhowells@redhat.com> (cherry picked from 1b16e7ac850969f38b375e511e3fa2f474a33867 commit)
2006-09-26[PATCH] Profiling: require buffer allocation on the correct nodeChristoph Lameter
Profiling really suffers with off node buffers. Fail if no memory is available on the nodes. The profiling code can deal with these failures should they occur. Signed-off-by: Christoph Lameter <clameter@sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-27[PATCH] cpu hotplug: revert init patch submitted for 2.6.17Chandra Seetharaman
In 2.6.17, there was a problem with cpu_notifiers and XFS. I provided a band-aid solution to solve that problem. In the process, i undid all the changes you both were making to ensure that these notifiers were available only at init time (unless CONFIG_HOTPLUG_CPU is defined). We deferred the real fix to 2.6.18. Here is a set of patches that fixes the XFS problem cleanly and makes the cpu notifiers available only at init time (unless CONFIG_HOTPLUG_CPU is defined). If CONFIG_HOTPLUG_CPU is defined then cpu notifiers are available at run time. This patch reverts the notifier_call changes made in 2.6.17 Signed-off-by: Chandra Seetharaman <sekharan@us.ibm.com> Cc: Ashok Raj <ashok.raj@intel.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-04-26[PATCH] Remove __devinit and __cpuinit from notifier_call definitionsChandra Seetharaman
Few of the notifier_chain_register() callers use __init in the definition of notifier_call. It is incorrect as the function definition should be available after the initializations (they do not unregister them during initializations). This patch fixes all such usages to _not_ have the notifier_call __init section. Signed-off-by: Chandra Seetharaman <sekharan@us.ibm.com> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-27[PATCH] Notifier chain update: API changesAlan Stern
The kernel's implementation of notifier chains is unsafe. There is no protection against entries being added to or removed from a chain while the chain is in use. The issues were discussed in this thread: http://marc.theaimsgroup.com/?l=linux-kernel&m=113018709002036&w=2 We noticed that notifier chains in the kernel fall into two basic usage classes: "Blocking" chains are always called from a process context and the callout routines are allowed to sleep; "Atomic" chains can be called from an atomic context and the callout routines are not allowed to sleep. We decided to codify this distinction and make it part of the API. Therefore this set of patches introduces three new, parallel APIs: one for blocking notifiers, one for atomic notifiers, and one for "raw" notifiers (which is really just the old API under a new name). New kinds of data structures are used for the heads of the chains, and new routines are defined for registration, unregistration, and calling a chain. The three APIs are explained in include/linux/notifier.h and their implementation is in kernel/sys.c. With atomic and blocking chains, the implementation guarantees that the chain links will not be corrupted and that chain callers will not get messed up by entries being added or removed. For raw chains the implementation provides no guarantees at all; users of this API must provide their own protections. (The idea was that situations may come up where the assumptions of the atomic and blocking APIs are not appropriate, so it should be possible for users to handle these things in their own way.) There are some limitations, which should not be too hard to live with. For atomic/blocking chains, registration and unregistration must always be done in a process context since the chain is protected by a mutex/rwsem. Also, a callout routine for a non-raw chain must not try to register or unregister entries on its own chain. (This did happen in a couple of places and the code had to be changed to avoid it.) Since atomic chains may be called from within an NMI handler, they cannot use spinlocks for synchronization. Instead we use RCU. The overhead falls almost entirely in the unregister routine, which is okay since unregistration is much less frequent that calling a chain. Here is the list of chains that we adjusted and their classifications. None of them use the raw API, so for the moment it is only a placeholder. ATOMIC CHAINS ------------- arch/i386/kernel/traps.c: i386die_chain arch/ia64/kernel/traps.c: ia64die_chain arch/powerpc/kernel/traps.c: powerpc_die_chain arch/sparc64/kernel/traps.c: sparc64die_chain arch/x86_64/kernel/traps.c: die_chain drivers/char/ipmi/ipmi_si_intf.c: xaction_notifier_list kernel/panic.c: panic_notifier_list kernel/profile.c: task_free_notifier net/bluetooth/hci_core.c: hci_notifier net/ipv4/netfilter/ip_conntrack_core.c: ip_conntrack_chain net/ipv4/netfilter/ip_conntrack_core.c: ip_conntrack_expect_chain net/ipv6/addrconf.c: inet6addr_chain net/netfilter/nf_conntrack_core.c: nf_conntrack_chain net/netfilter/nf_conntrack_core.c: nf_conntrack_expect_chain net/netlink/af_netlink.c: netlink_chain BLOCKING CHAINS --------------- arch/powerpc/platforms/pseries/reconfig.c: pSeries_reconfig_chain arch/s390/kernel/process.c: idle_chain arch/x86_64/kernel/process.c idle_notifier drivers/base/memory.c: memory_chain drivers/cpufreq/cpufreq.c cpufreq_policy_notifier_list drivers/cpufreq/cpufreq.c cpufreq_transition_notifier_list drivers/macintosh/adb.c: adb_client_list drivers/macintosh/via-pmu.c sleep_notifier_list drivers/macintosh/via-pmu68k.c sleep_notifier_list drivers/macintosh/windfarm_core.c wf_client_list drivers/usb/core/notify.c usb_notifier_list drivers/video/fbmem.c fb_notifier_list kernel/cpu.c cpu_chain kernel/module.c module_notify_list kernel/profile.c munmap_notifier kernel/profile.c task_exit_notifier kernel/sys.c reboot_notifier_list net/core/dev.c netdev_chain net/decnet/dn_dev.c: dnaddr_chain net/ipv4/devinet.c: inetaddr_chain It's possible that some of these classifications are wrong. If they are, please let us know or submit a patch to fix them. Note that any chain that gets called very frequently should be atomic, because the rwsem read-locking used for blocking chains is very likely to incur cache misses on SMP systems. (However, if the chain's callout routines may sleep then the chain cannot be atomic.) The patch set was written by Alan Stern and Chandra Seetharaman, incorporating material written by Keith Owens and suggestions from Paul McKenney and Andrew Morton. [jes@sgi.com: restructure the notifier chain initialization macros] Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Chandra Seetharaman <sekharan@us.ibm.com> Signed-off-by: Jes Sorensen <jes@sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-23[PATCH] sem2mutex: kernel/Arjan van de Ven
Semaphore to mutex conversion. The conversion was generated via scripts, and the result was validated automatically via a script as well. Signed-off-by: Arjan van de Ven <arjan@infradead.org> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-07-07[PATCH] mostly_read data sectionChristoph Lameter
Add a new section called ".data.read_mostly" for data items that are read frequently and rarely written to like cpumaps etc. If these maps are placed in the .data section then these frequenly read items may end up in cachelines with data is is frequently updated. In that case all processors in an SMP system must needlessly reload the cachelines again and again containing elements of those frequently used variables. The ability to share these cachelines will allow each cpu in an SMP system to keep local copies of those shared cachelines thereby optimizing performance. Signed-off-by: Alok N Kataria <alokk@calsoftinc.com> Signed-off-by: Shobhit Dayal <shobhit@calsoftinc.com> Signed-off-by: Christoph Lameter <christoph@scalex86.org> Signed-off-by: Shai Fultheim <shai@scalex86.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-05-17[PATCH] profile.c: `schedule' parsing fixWilliam Lee Irwin III
profile=schedule parsing is not quite what it should be. First, str[7] is 'e', not ',', but then even if it did fall through, prof_on = SCHED_PROFILING would be clobbered inside if (get_option(...)) So a small amount of rearrangement is done in this patch to correct it. Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-05-01[PATCH] Change synchronize_kernel to _rcu and _schedPaul E. McKenney
This patch changes calls to synchronize_kernel(), deprecated in the earlier "Deprecate synchronize_kernel, GPL replacement" patch to instead call the new synchronize_rcu() and synchronize_sched() APIs. Signed-off-by: Paul E. McKenney <paulmck@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-05-01[PATCH] use smp_mb/wmb/rmb where possibleakpm@osdl.org
Replace a number of memory barriers with smp_ variants. This means we won't take the unnecessary hit on UP machines. Signed-off-by: Anton Blanchard <anton@samba.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
