path: root/kernel/profile.c
2015-02-13profile: use %*pb[l] to print bitmaps including cpumasks and nodemasksTejun Heo
printk and friends can now format bitmaps using '%*pb[l]'. cpumask and nodemask also provide cpumask_pr_args() and nodemask_pr_args() respectively which can be used to generate the two printf arguments necessary to format the specified cpu/nodemask. Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-06-06kernel/profile.c: use static const char instead of static charFabian Frederick
schedstr, sleepstr and kvmstr are only used in strcmp & strlen Signed-off-by: Fabian Frederick <fabf@skynet.be> Cc: Paul Gortmaker <paul.gortmaker@windriver.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-06-06kernel/profile.c: convert printk to pr_foo()Fabian Frederick
2014-04-07Merge tag 'cpu-hotplug-3.15-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm Pull CPU hotplug notifiers registration fixes from Rafael Wysocki: "The purpose of this single series of commits from Srivatsa S Bhat (with a small piece from Gautham R Shenoy) touching multiple subsystems that use CPU hotplug notifiers is to provide a way to register them that will not lead to deadlocks with CPU online/offline operations as described in the changelog of commit 93ae4f978ca7f ("CPU hotplug: Provide lockless versions of callback registration functions"). The first three commits in the series introduce the API and document it and the rest simply goes through the users of CPU hotplug notifiers and converts them to using the new method" * tag 'cpu-hotplug-3.15-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm: (52 commits) net/iucv/iucv.c: Fix CPU hotplug callback registration net/core/flow.c: Fix CPU hotplug callback registration mm, zswap: Fix CPU hotplug callback registration mm, vmstat: Fix CPU hotplug callback registration profile: Fix CPU hotplug callback registration trace, ring-buffer: Fix CPU hotplug callback registration xen, balloon: Fix CPU hotplug callback registration hwmon, via-cputemp: Fix CPU hotplug callback registration hwmon, coretemp: Fix CPU hotplug callback registration thermal, x86-pkg-temp: Fix CPU hotplug callback registration octeon, watchdog: Fix CPU hotplug callback registration oprofile, nmi-timer: Fix CPU hotplug callback registration intel-idle: Fix CPU hotplug callback registration clocksource, dummy-timer: Fix CPU hotplug callback registration drivers/base/topology.c: Fix CPU hotplug callback registration acpi-cpufreq: Fix CPU hotplug callback registration zsmalloc: Fix CPU hotplug callback registration scsi, fcoe: Fix CPU hotplug callback registration scsi, bnx2fc: Fix CPU hotplug callback registration scsi, bnx2i: Fix CPU hotplug callback registration ...
2014-04-03kernel: audit/fix non-modular users of module_init in core codePaul Gortmaker
Code that is obj-y (always built-in) or dependent on a bool Kconfig (built-in or absent) can never be modular. So using module_init as an alias for __initcall can be somewhat misleading. Fix these up now, so that we can relocate module_init from init.h into module.h in the future. If we don't do this, we'd have to add module.h to obviously non-modular code, and that would be a worse thing. The audit targets the following module_init users for change: kernel/user.c obj-y kernel/kexec.c bool KEXEC (one instance per arch) kernel/profile.c bool PROFILING kernel/hung_task.c bool DETECT_HUNG_TASK kernel/sched/stats.c bool SCHEDSTATS kernel/user_namespace.c bool USER_NS Note that direct use of __initcall is discouraged, vs. one of the priority categorized subgroups. As __initcall gets mapped onto device_initcall, our use of subsys_initcall (which makes sense for these files) will thus change this registration from level 6-device to level 4-subsys (i.e. slightly earlier). However no observable impact of that difference has been observed during testing. Also, two instances of missing ";" at EOL are fixed in kexec. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> Cc: Ingo Molnar <mingo@redhat.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Eric Biederman <ebiederm@xmission.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-03-20profile: Fix CPU hotplug callback registrationSrivatsa S. Bhat
Subsystems that want to register CPU hotplug callbacks, as well as perform initialization for the CPUs that are already online, often do it as shown below: get_online_cpus(); for_each_online_cpu(cpu) init_cpu(cpu); register_cpu_notifier(&foobar_cpu_notifier); put_online_cpus(); This is wrong, since it is prone to ABBA deadlocks involving the cpu_add_remove_lock and the cpu_hotplug.lock (when running concurrently with CPU hotplug operations). Instead, the correct and race-free way of performing the callback registration is: cpu_notifier_register_begin(); for_each_online_cpu(cpu) init_cpu(cpu); /* Note the use of the double underscored version of the API */ __register_cpu_notifier(&foobar_cpu_notifier); cpu_notifier_register_done(); Fix the profile code by using this latter form of callback registration. Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Mauro Carvalho Chehab <mchehab@redhat.com> Cc: Ingo Molnar <mingo@kernel.org> Signed-off-by: Srivatsa S. Bhat <srivatsa.bhat@linux.vnet.ibm.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2014-03-10mm: fix GFP_THISNODE callers and clarifyJohannes Weiner
GFP_THISNODE is for callers that implement their own clever fallback to remote nodes. It restricts the allocation to the specified node and does not invoke reclaim, assuming that the caller will take care of it when the fallback fails, e.g. through a subsequent allocation request without GFP_THISNODE set. However, many current GFP_THISNODE users only want the node exclusive aspect of the flag, without actually implementing their own fallback or triggering reclaim if necessary. This results in things like page migration failing prematurely even when there is easily reclaimable memory available, unless kswapd happens to be running already or a concurrent allocation attempt triggers the necessary reclaim. Convert all callsites that don't implement their own fallback strategy to __GFP_THISNODE. This restricts the allocation a single node too, but at the same time allows the allocator to enter the slowpath, wake kswapd, and invoke direct reclaim if necessary, to make the allocation happen when memory is full. Signed-off-by: Johannes Weiner <hannes@cmpxchg.org> Acked-by: Rik van Riel <riel@redhat.com> Cc: Jan Stancek <jstancek@redhat.com> Cc: Mel Gorman <mgorman@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-07-14kernel: delete __cpuinit usage from all core kernel filesPaul Gortmaker
The __cpuinit type of throwaway sections might have made sense some time ago when RAM was more constrained, but now the savings do not offset the cost and complications. For example, the fix in commit 5e427ec2d0 ("x86: Fix bit corruption at CPU resume time") is a good example of the nasty type of bugs that can be created with improper use of the various __init prefixes. After a discussion on LKML[1] it was decided that cpuinit should go the way of devinit and be phased out. Once all the users are gone, we can then finally remove the macros themselves from linux/init.h. This removes all the uses of the __cpuinit macros from C files in the core kernel directories (kernel, init, lib, mm, and include) that don't really have a specific maintainer. [1] https://lkml.org/lkml/2013/5/20/589 Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2013-05-01proc: Supply PDE attribute setting accessor functionsDavid Howells
Supply accessor functions to set attributes in proc_dir_entry structs. The following are supplied: proc_set_size() and proc_set_user(). Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Mauro Carvalho Chehab <mchehab@redhat.com> cc: linuxppc-dev@lists.ozlabs.org cc: linux-media@vger.kernel.org cc: netdev@vger.kernel.org cc: linux-wireless@vger.kernel.org cc: linux-pci@vger.kernel.org cc: netfilter-devel@vger.kernel.org cc: alsa-devel@alsa-project.org Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2013-04-09create_proc_cpu_mask() doesn't need an argument...Al Viro
2013-01-24profiling: Remove unused timer hookFrederic Weisbecker
The last remaining user was oprofile and its use has been removed a while ago in commit bc078e4eab65f11bba ("oprofile: convert oprofile from timer_hook to hrtimer"). There doesn't seem to be any upstream user of this hook for about two years now. And I'm not even aware of any out of tree user. Let's remove it. Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com> Cc: Alessio Igor Bogani <abogani@kernel.org> Cc: Avi Kivity <avi@redhat.com> Cc: Chris Metcalf <cmetcalf@tilera.com> Cc: Christoph Lameter <cl@linux.com> Cc: Geoff Levand <geoff@infradead.org> Cc: Gilad Ben Yossef <gilad@benyossef.com> Cc: Hakan Akkan <hakanakkan@gmail.com> Cc: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: Paul Gortmaker <paul.gortmaker@windriver.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Steven Rostedt <rostedt@goodmis.org> Link: http://lkml.kernel.org/r/1356191991-2251-1-git-send-email-fweisbec@gmail.com Signed-off-by: Ingo Molnar <mingo@kernel.org>
2012-12-06propagate name change to comments in kernel sourceNadia Yvette Chambers
I've legally changed my name with New York State, the US Social Security Administration, et al. This patch propagates the name change and change in initials and login to comments in the kernel source as well. Signed-off-by: Nadia Yvette Chambers <nyc@holomorphy.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2011-10-31kernel: Map most files to use export.h instead of module.hPaul Gortmaker
The changed files were only including linux/module.h for the EXPORT_SYMBOL infrastructure, and nothing else. Revector them onto the isolated export header for faster compile times. Nothing to see here but a whole lot of instances of: -#include <linux/module.h> +#include <linux/export.h> This commit is only changing the kernel dir; next targets will probably be mm, fs, the arch dirs, etc. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2011-05-26kernel/profile.c: remove some duplicate code from profile_hits()Rakib Mullick
profile_hits() has a common check for prof_on and prof_buffer regardless of SMP or !SMP. So, remove some duplicate code by splitting profile_hits into two. [akpm@linux-foundation.org: make do_profile_hits static] Signed-off-by: Rakib Mullick <rakib.mullick@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-31profile: Use vzalloc() rather than vmalloc() & memset()Jesper Juhl
There's no reason to memset() manually when we have vzalloc(). Signed-off-by: Jesper Juhl <jj@chaosbits.net> Cc: Arjan van de Ven <arjan@infradead.org> Cc: William Irwin <wli@holomorphy.com> LKML-Reference: <alpine.LNX.2.00.1010302150310.1572@swampdragon.chaosbits.net> Signed-off-by: Ingo Molnar <mingo@elte.hu>
All file_operations should get a .llseek operation so we can make nonseekable_open the default for future file operations without a .llseek pointer. The three cases that we can automatically detect are no_llseek, seq_lseek and default_llseek. For cases where we can we can automatically prove that the file offset is always ignored, we use noop_llseek, which maintains the current behavior of not returning an error from a seek. New drivers should normally not use noop_llseek but instead use no_llseek and call nonseekable_open at open time. Existing drivers can be converted to do the same when the maintainer knows for certain that no user code relies on calling seek on the device file. The generated code is often incorrectly indented and right now contains comments that clarify for each added line why a specific variant was chosen. In the version that gets submitted upstream, the comments will be gone and I will manually fix the indentation, because there does not seem to be a way to do that using coccinelle. Some amount of new code is currently sitting in linux-next that should get the same modifications, which I will do at the end of the merge window. Many thanks to Julia Lawall for helping me learn to write a semantic patch that does all this. ===== begin semantic patch ===== // This adds an llseek= method to all file operations, // as a preparation for making no_llseek the default. // // The rules are // - use no_llseek explicitly if we do nonseekable_open // - use seq_lseek for sequential files // - use default_llseek if we know we access f_pos // - use noop_llseek if we know we don't access f_pos, // but we still want to allow users to call lseek // @ open1 exists @ identifier nested_open; @@ nested_open(...) { <+... nonseekable_open(...) ...+> } @ open exists@ identifier open_f; identifier i, f; identifier open1.nested_open; @@ int open_f(struct inode *i, struct file *f) { <+... ( nonseekable_open(...) | nested_open(...) ) ...+> } @ read disable optional_qualifier exists @ identifier read_f; identifier f, p, s, off; type ssize_t, size_t, loff_t; expression E; identifier func; @@ ssize_t read_f(struct file *f, char *p, size_t s, loff_t *off) { <+... ( *off = E | *off += E | func(..., off, ...) | E = *off ) ...+> } @ read_no_fpos disable optional_qualifier exists @ identifier read_f; identifier f, p, s, off; type ssize_t, size_t, loff_t; @@ ssize_t read_f(struct file *f, char *p, size_t s, loff_t *off) { ... when != off } @ write @ identifier write_f; identifier f, p, s, off; type ssize_t, size_t, loff_t; expression E; identifier func; @@ ssize_t write_f(struct file *f, const char *p, size_t s, loff_t *off) { <+... ( *off = E | *off += E | func(..., off, ...) | E = *off ) ...+> } @ write_no_fpos @ identifier write_f; identifier f, p, s, off; type ssize_t, size_t, loff_t; @@ ssize_t write_f(struct file *f, const char *p, size_t s, loff_t *off) { ... when != off } @ fops0 @ identifier fops; @@ struct file_operations fops = { ... }; @ has_llseek depends on fops0 @ identifier fops0.fops; identifier llseek_f; @@ struct file_operations fops = { ... .llseek = llseek_f, ... }; @ has_read depends on fops0 @ identifier fops0.fops; identifier read_f; @@ struct file_operations fops = { ... .read = read_f, ... }; @ has_write depends on fops0 @ identifier fops0.fops; identifier write_f; @@ struct file_operations fops = { ... .write = write_f, ... }; @ has_open depends on fops0 @ identifier fops0.fops; identifier open_f; @@ struct file_operations fops = { ... .open = open_f, ... }; // use no_llseek if we call nonseekable_open //////////////////////////////////////////// @ nonseekable1 depends on !has_llseek && has_open @ identifier fops0.fops; identifier nso ~= "nonseekable_open"; @@ struct file_operations fops = { ... .open = nso, ... +.llseek = no_llseek, /* nonseekable */ }; @ nonseekable2 depends on !has_llseek @ identifier fops0.fops; identifier open.open_f; @@ struct file_operations fops = { ... .open = open_f, ... +.llseek = no_llseek, /* open uses nonseekable */ }; // use seq_lseek for sequential files ///////////////////////////////////// @ seq depends on !has_llseek @ identifier fops0.fops; identifier sr ~= "seq_read"; @@ struct file_operations fops = { ... .read = sr, ... +.llseek = seq_lseek, /* we have seq_read */ }; // use default_llseek if there is a readdir /////////////////////////////////////////// @ fops1 depends on !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; identifier readdir_e; @@ // any other fop is used that changes pos struct file_operations fops = { ... .readdir = readdir_e, ... +.llseek = default_llseek, /* readdir is present */ }; // use default_llseek if at least one of read/write touches f_pos ///////////////////////////////////////////////////////////////// @ fops2 depends on !fops1 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; identifier read.read_f; @@ // read fops use offset struct file_operations fops = { ... .read = read_f, ... +.llseek = default_llseek, /* read accesses f_pos */ }; @ fops3 depends on !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; identifier write.write_f; @@ // write fops use offset struct file_operations fops = { ... .write = write_f, ... + .llseek = default_llseek, /* write accesses f_pos */ }; // Use noop_llseek if neither read nor write accesses f_pos /////////////////////////////////////////////////////////// @ fops4 depends on !fops1 && !fops2 && !fops3 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; identifier read_no_fpos.read_f; identifier write_no_fpos.write_f; @@ // write fops use offset struct file_operations fops = { ... .write = write_f, .read = read_f, ... +.llseek = noop_llseek, /* read and write both use no f_pos */ }; @ depends on has_write && !has_read && !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; identifier write_no_fpos.write_f; @@ struct file_operations fops = { ... .write = write_f, ... +.llseek = noop_llseek, /* write uses no f_pos */ }; @ depends on has_read && !has_write && !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; identifier read_no_fpos.read_f; @@ struct file_operations fops = { ... .read = read_f, ... +.llseek = noop_llseek, /* read uses no f_pos */ }; @ depends on !has_read && !has_write && !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; @@ struct file_operations fops = { ... +.llseek = noop_llseek, /* no read or write fn */ }; ===== End semantic patch ===== Signed-off-by: Arnd Bergmann <arnd@arndb.de> Cc: Julia Lawall <julia@diku.dk> Cc: Christoph Hellwig <hch@infradead.org>
2010-05-27numa: in-kernel profiling: use cpu_to_mem() for per cpu allocationsLee Schermerhorn
In kernel profiling requires that we be able to allocate "local" memory for each cpu. Use "cpu_to_mem()" instead of "cpu_to_node()" to support memoryless nodes. Depends on the "numa_mem_id()" patch. Signed-off-by: Lee Schermerhorn <lee.schermerhorn@hp.com> Cc: Tejun Heo <tj@kernel.org> Cc: Mel Gorman <mel@csn.ul.ie> Cc: Christoph Lameter <cl@linux-foundation.org> Cc: Nick Piggin <npiggin@suse.de> Cc: David Rientjes <rientjes@google.com> Cc: Eric Whitney <eric.whitney@hp.com> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: Pekka Enberg <penberg@cs.helsinki.fi> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-05-27kernel/: convert cpu notifier to return encapsulate errno valueAkinobu Mita
By the previous modification, the cpu notifier can return encapsulate errno value. This converts the cpu notifiers for kernel/*.c Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Peter Zijlstra <peterz@infradead.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-05-14profile: fix stats and data leakageHugh Dickins
If the kernel is large or the profiling step small, /proc/profile leaks data and readprofile shows silly stats, until readprofile -r has reset the buffer: clear the prof_buffer when it is vmalloc()ed. Signed-off-by: Hugh Dickins <hughd@google.com> Cc: stable@kernel.org Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-20kernel/profile.c: Switch /proc/irq/prof_cpu_mask to seq_fileAlexey Dobriyan
Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-07-29profile: suppress warning about large allocations when profile=1 is specifiedMel Gorman
When profile= is used, a large buffer is allocated early at boot. This can be larger than what the page allocator can provide so it prints a warning. However, the caller is able to handle the situation so this patch suppresses the warning. Signed-off-by: Mel Gorman <mel@csn.ul.ie> Cc: "Rafael J. Wysocki" <rjw@sisk.pl> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-16page allocator: do not check NUMA node ID when the caller knows the node is ↵Mel Gorman
valid Callers of alloc_pages_node() can optionally specify -1 as a node to mean "allocate from the current node". However, a number of the callers in fast paths know for a fact their node is valid. To avoid a comparison and branch, this patch adds alloc_pages_exact_node() that only checks the nid with VM_BUG_ON(). Callers that know their node is valid are then converted. Signed-off-by: Mel Gorman <mel@csn.ul.ie> Reviewed-by: Christoph Lameter <cl@linux-foundation.org> Reviewed-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Reviewed-by: Pekka Enberg <penberg@cs.helsinki.fi> Acked-by: Paul Mundt <lethal@linux-sh.org> [for the SLOB NUMA bits] Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Nick Piggin <nickpiggin@yahoo.com.au> Cc: Dave Hansen <dave@linux.vnet.ibm.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-11x86: remove some alloc_bootmem_cpumask_var callingYinghai Lu
Now that we set up the slab allocator earlier, we can get rid of some alloc_bootmem_cpumask_var() calls in boot code. Cc: Ingo Molnar <mingo@elte.hu> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Yinghai Lu <yinghai@kernel.org> Signed-off-by: Pekka Enberg <penberg@cs.helsinki.fi>
2009-02-10profiling: fix broken profiling regressionHugh Dickins
Impact: fix broken /proc/profile on UP machines Commit c309b917cab55799ea489d7b5f1b77025d9f8462 "cpumask: convert kernel/profile.c" broke profiling. prof_cpu_mask was previously initialized to CPU_MASK_ALL, but left uninitialized in that commit. We need to copy cpu_possible_mask (cpu_online_mask is not enough). Signed-off-by: Hugh Dickins <hugh@veritas.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-01-06profile: don't include <asm/ptrace.h> twice.KOSAKI Motohiro
Currently, kernel/profile.c include <asm/ptrace.h> twice. It can be removed. Signed-off-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-01cpumask: convert kernel/profile.cRusty Russell
Impact: Reduce kernel memory usage, use new cpumask API. Avoid a static cpumask_t for prof_cpu_mask, and an on-stack cpumask_t in prof_cpu_mask_write_proc. Both become cpumask_var_t. prof_cpu_mask is only allocated when profiling is on, but the NULL checks are optimized out by gcc for the !CPUMASK_OFFSTACK case. Also removed some strange and unnecessary casts. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2008-12-30Merge branch 'master' of ↵Rusty Russell
git://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux-2.6
2008-12-13cpumask: change cpumask_scnprintf, cpumask_parse_user, cpulist_parse, and ↵Rusty Russell
cpulist_scnprintf to take pointers. Impact: change calling convention of existing cpumask APIs Most cpumask functions started with cpus_: these have been replaced by cpumask_ ones which take struct cpumask pointers as expected. These four functions don't have good replacement names; fortunately they're rarely used, so we just change them over. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Mike Travis <travis@sgi.com> Acked-by: Ingo Molnar <mingo@elte.hu> Cc: paulus@samba.org Cc: mingo@redhat.com Cc: tony.luck@intel.com Cc: ralf@linux-mips.org Cc: Greg Kroah-Hartman <gregkh@suse.de> Cc: cl@linux-foundation.org Cc: srostedt@redhat.com
2008-12-04Merge commit 'v2.6.28-rc7' into tracing/coreIngo Molnar
2008-11-30cpuinit fixes in kernel/*Al Viro
2008-11-19profiling: clean up profile_nop()Andrew Morton
Impact: cleanup No point in inlining this. Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-11-18kernel/profile.c: fix section mismatch warningRakib Mullick
Impact: fix section mismatch warning in kernel/profile.c Here, profile_nop function has been called from a non-init function create_hash_tables(void). Which generetes a section mismatch warning. Previously, create_hash_tables(void) was a init function. So, removing __init from create_hash_tables(void) requires profile_nop to be non-init. This patch makes profile_nop function inline and fixes the following warning: WARNING: vmlinux.o(.text+0x6ebb6): Section mismatch in reference from the function create_hash_tables() to the function .init.text:profile_nop() The function create_hash_tables() references the function __init profile_nop(). This is often because create_hash_tables lacks a __init annotation or the annotation of profile_nop is wrong. Signed-off-by: Rakib Mullick <rakib.mullick@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-10-30kernel/profile: fix profile_init() section mismatchPaul Mundt
profile_init() calls in to alloc_bootmem() on early initialization. While alloc_bootmem() is __init, the reference itself is safe in that it is tucked below a !slab_is_available() check. So, flag profile_init() as __ref. Signed-off-by: Paul Mundt <lethal@linux-sh.org> Cc: Dave Hansen <dave@linux.vnet.ibm.com> Cc: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-16profiling: dynamically enable readprofile at runtimeDave Hansen
Way too often, I have a machine that exhibits some kind of crappy behavior. The CPU looks wedged in the kernel or it is spending way too much system time and I wonder what is responsible. I try to run readprofile. But, of course, Ubuntu doesn't enable it by default. Dang! The reason we boot-time enable it is that it takes a big bufffer that we generally can only bootmem alloc. But, does it hurt to at least try and runtime-alloc it? To use: echo 2 > /sys/kernel/profile Then run readprofile like normal. This should fix the compile issue with allmodconfig. I've compile-tested on a bunch more configs now including a few more architectures. Signed-off-by: Dave Hansen <dave@linux.vnet.ibm.com> Acked-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-25build kernel/profile.o only when requestedAdrian Bunk
Build kernel/profile.o only if CONFIG_PROFILING is enabled. This makes CONFIG_PROFILING=n kernels smaller. As a bonus, some profile_tick() calls and one branch from schedule() are now eliminated with CONFIG_PROFILING=n (but I doubt these are measurable effects). This patch changes the effects of CONFIG_PROFILING=n, but I don't think having more than two choices would be the better choice. This patch also adds the name of the first parameter to the prototypes of profile_{hits,tick}() since I anyway had to add them for the dummy functions. Signed-off-by: Adrian Bunk <bunk@kernel.org> Cc: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-06-26on_each_cpu(): kill unused 'retry' parameterJens Axboe
It's not even passed on to smp_call_function() anymore, since that was removed. So kill it. Acked-by: Jeremy Fitzhardinge <jeremy.fitzhardinge@citrix.com> Reviewed-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-04-29kernel: use non-racy method for proc entries creationDenis V. Lunev
Use proc_create()/proc_create_data() to make sure that ->proc_fops and ->data be setup before gluing PDE to main tree. Signed-off-by: Denis V. Lunev <den@openvz.org> Cc: Alexey Dobriyan <adobriyan@gmail.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-18kernel: Remove unnecessary inclusions of asm/semaphore.hMatthew Wilcox
None of these files use any of the functionality promised by asm/semaphore.h. Signed-off-by: Matthew Wilcox <willy@linux.intel.com>
2008-02-08Nuke a duplicate include from profile.cJesper Juhl
Remove duplicate inclusion of linux/profile.h from kernel/profile.c Signed-off-by: Jesper Juhl <jesper.juhl@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-01-25debug: clean up kernel/profile.cPaolo Ciarrocchi
Before: total: 25 errors, 13 warnings, 602 lines checked After: total: 0 errors, 2 warnings, 601 lines checked No code changed: kernel/profile.o: text data bss dec hex filename 3048 236 24 3308 cec profile.o.before 3048 236 24 3308 cec profile.o.after md5: 2501d64748a4d350dffb11203e2a5182 profile.o.before.asm 2501d64748a4d350dffb11203e2a5182 profile.o.after.asm Signed-off-by: Paolo Ciarrocchi <paolo.ciarrocchi@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2007-10-24sched: document profile=sleep requiring CONFIG_SCHEDSTATSMel Gorman
profile=sleep only works if CONFIG_SCHEDSTATS is set. This patch notes the limitation in Documentation/kernel-parameters.txt and prints a warning at boot-time if profile=sleep is used without CONFIG_SCHEDSTAT. Signed-off-by: Mel Gorman <mel@csn.ul.ie> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2007-10-17make kernel/profile.c:time_hook staticAdrian Bunk
{,un}register_timer_hook() is the API that should be used. Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16Memoryless nodes: Allow profiling data to fall back to other nodesChristoph Lameter
Processors on memoryless nodes must be able to fall back to remote nodes in order to get a profiling buffer. This may lead to excessive NUMA traffic but I think we should allow this rather than failing. Signed-off-by: Christoph Lameter <clameter@sgi.com> Acked-by: Nishanth Aravamudan <nacc@us.ibm.com> Acked-by: Lee Schermerhorn <lee.schermerhorn@hp.com> Acked-by: Bob Picco <bob.picco@hp.com> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Mel Gorman <mel@skynet.ie> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-08-11fix compilation with gcc 4.2Peter Chubb
gcc-4.2 is a lot more picky about its symbol handling. EXPORT_SYMBOL no longer works on symbols that are undefined or defined with static scope. For example, with CONFIG_PROFILE off, I see: kernel/profile.c:206: error: __ksymtab_profile_event_unregister causes a section type conflict kernel/profile.c:205: error: __ksymtab_profile_event_register causes a section type conflict This patch moves the EXPORTs inside the #ifdef CONFIG_PROFILE, so we only try to export symbols that are defined. Also, in kernel/kprobes.c there's an EXPORT_SYMBOL_GPL() for jprobes_return, which if CONFIG_JPROBES is undefined is a static inline and gives the same error. And in drivers/acpi/resources/rsxface.c, there's an ACPI_EXPORT_SYMBOPL() for a static symbol. If it's static, it's not accessible from outside the compilation unit, so should bot be exported. These three changes allow building a zx1_defconfig kernel with gcc 4.2 on IA64. [akpm@linux-foundation.org: export jpobe_return properly] Signed-off-by: Peter Chubb <peterc@gelato.unsw.edu.au> Cc: Prasanna S Panchamukhi <prasanna@in.ibm.com> Cc: Ananth N Mavinakayanahalli <ananth@in.ibm.com> Cc: Anil S Keshavamurthy <anil.s.keshavamurthy@intel.com> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: Len Brown <lenb@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-21Detach sched.h from mm.hAlexey Dobriyan
First thing mm.h does is including sched.h solely for can_do_mlock() inline function which has "current" dereference inside. By dealing with can_do_mlock() mm.h can be detached from sched.h which is good. See below, why. This patch a) removes unconditional inclusion of sched.h from mm.h b) makes can_do_mlock() normal function in mm/mlock.c c) exports can_do_mlock() to not break compilation d) adds sched.h inclusions back to files that were getting it indirectly. e) adds less bloated headers to some files (asm/signal.h, jiffies.h) that were getting them indirectly Net result is: a) mm.h users would get less code to open, read, preprocess, parse, ... if they don't need sched.h b) sched.h stops being dependency for significant number of files: on x86_64 allmodconfig touching sched.h results in recompile of 4083 files, after patch it's only 3744 (-8.3%). Cross-compile tested on all arm defconfigs, all mips defconfigs, all powerpc defconfigs, alpha alpha-up arm i386 i386-up i386-defconfig i386-allnoconfig ia64 ia64-up m68k mips parisc parisc-up powerpc powerpc-up s390 s390-up sparc sparc-up sparc64 sparc64-up um-x86_64 x86_64 x86_64-up x86_64-defconfig x86_64-allnoconfig as well as my two usual configs. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-09Add suspend-related notifications for CPU hotplugRafael J. Wysocki
Since nonboot CPUs are now disabled after tasks and devices have been frozen and the CPU hotplug infrastructure is used for this purpose, we need special CPU hotplug notifications that will help the CPU-hotplug-aware subsystems distinguish normal CPU hotplug events from CPU hotplug events related to a system-wide suspend or resume operation in progress. This patch introduces such notifications and causes them to be used during suspend and resume transitions. It also changes all of the CPU-hotplug-aware subsystems to take these notifications into consideration (for now they are handled in the same way as the corresponding "normal" ones). [oleg@tv-sign.ru: cleanups] Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Cc: Gautham R Shenoy <ego@in.ibm.com> Cc: Pavel Machek <pavel@ucw.cz> Signed-off-by: Oleg Nesterov <oleg@tv-sign.ru> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-11[PATCH] proc: remove useless (and buggy) ->nlink settingsAlexey Dobriyan
Bug: pnx8550 code creates directory but resets ->nlink to 1. create_proc_entry() et al will correctly set ->nlink for you. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Jeff Dike <jdike@addtoit.com> Cc: Corey Minyard <minyard@acm.org> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Cc: Kyle McMartin <kyle@mcmartin.ca> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Greg KH <greg@kroah.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-01-23[PATCH] fix "kvm: add vm exit profiling"Andrew Morton
export profile_hits() on !SMP too. Cc: Ingo Molnar <mingo@elte.hu> Cc: Avi Kivity <avi@qumranet.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-01-11[PATCH] KVM: add VM-exit profilingIngo Molnar
This adds the profile=kvm boot option, which enables KVM to profile VM exits. Use: "readprofile -m ./System.map | sort -n" to see the resulting output: [...] 18246 serial_out 148.3415 18945 native_flush_tlb 378.9000 23618 serial_in 212.7748 29279 __spin_unlock_irq 622.9574 43447 native_apic_write 2068.9048 52702 enable_8259A_irq 742.2817 54250 vgacon_scroll 89.3740 67394 ide_inb 6126.7273 79514 copy_page_range 98.1654 84868 do_wp_page 86.6000 140266 pit_read 783.6089 151436 ide_outb 25239.3333 152668 native_io_delay 21809.7143 174783 mask_and_ack_8259A 783.7803 362404 native_set_pte_at 36240.4000 1688747 total 0.5009 Signed-off-by: Ingo Molnar <mingo@elte.hu> Acked-by: Avi Kivity <avi@qumranet.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2007-01-05[PATCH] profiling: fix sched profiling typoIngo Molnar
Fix sched profiling typo, introduced by the sleep profiling patch. This bug caused profile=sched to not work. Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
