path: root/kernel/ptrace.c
2009-06-11Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/security-testing-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/security-testing-2.6: (44 commits) nommu: Provide mmap_min_addr definition. TOMOYO: Add description of lists and structures. TOMOYO: Remove unused field. integrity: ima audit dentry_open failure TOMOYO: Remove unused parameter. security: use mmap_min_addr indepedently of security models TOMOYO: Simplify policy reader. TOMOYO: Remove redundant markers. SELinux: define audit permissions for audit tree netlink messages TOMOYO: Remove unused mutex. tomoyo: avoid get+put of task_struct smack: Remove redundant initialization. integrity: nfsd imbalance bug fix rootplug: Remove redundant initialization. smack: do not beyond ARRAY_SIZE of data integrity: move ima_counts_get integrity: path_check update IMA: Add __init notation to ima functions IMA: Minimal IMA policy and boot param for TCB IMA policy selinux: remove obsolete read buffer limit from sel_read_bool ...
2009-06-10Merge branch 'tracing-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'tracing-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (244 commits) Revert "x86, bts: reenable ptrace branch trace support" tracing: do not translate event helper macros in print format ftrace/documentation: fix typo in function grapher name tracing/events: convert block trace points to TRACE_EVENT(), fix !CONFIG_BLOCK tracing: add protection around module events unload tracing: add trace_seq_vprint interface tracing: fix the block trace points print size tracing/events: convert block trace points to TRACE_EVENT() ring-buffer: fix ret in rb_add_time_stamp ring-buffer: pass in lockdep class key for reader_lock tracing: add annotation to what type of stack trace is recorded tracing: fix multiple use of __print_flags and __print_symbolic tracing/events: fix output format of user stack tracing/events: fix output format of kernel stack tracing/trace_stack: fix the number of entries in the header ring-buffer: discard timestamps that are at the start of the buffer ring-buffer: try to discard unneeded timestamps ring-buffer: fix bug in ring_buffer_discard_commit ftrace: do not profile functions when disabled tracing: make trace pipe recognize latency format flag ...
2009-06-09Merge branch 'master' into nextJames Morris
2009-06-04ptrace: revert "ptrace_detach: the wrong wakeup breaks the ERESTARTxxx logic"Oleg Nesterov
Commit 95a3540da9c81a5987be810e1d9a83640a366bd5 ("ptrace_detach: the wrong wakeup breaks the ERESTARTxxx logic") removed the "extra" wake_up_process() from ptrace_detach(), but as Jan pointed out this breaks the compatibility. I believe the changelog is right and this wake_up() is wrong in many ways, but GDB assumes that ptrace(PTRACE_DETACH, child, 0, 0) always wakes up the tracee. Despite the fact this breaks SIGNAL_STOP_STOPPED/group_stop_count logic, and despite the fact this wake_up_process() can break another assumption: PTRACE_DETACH with SIGSTOP should leave the tracee in TASK_STOPPED case. Because the untraced child can dequeue SIGSTOP and call do_signal_stop() before ptrace_detach() calls wake_up_process(). Revert this change for now. We need some fixes even if we we want to keep the current behaviour, but these fixes are not for 2.6.30. Signed-off-by: Oleg Nesterov <oleg@redhat.com> Acked-by: Roland McGrath <roland@redhat.com> Cc: Jan Kratochvil <jan.kratochvil@redhat.com> Cc: Denys Vlasenko <dvlasenk@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-05-11CRED: Rename cred_exec_mutex to reflect that it's a guard against ptraceDavid Howells
Rename cred_exec_mutex to reflect that it's a guard against foreign intervention on a process's credential state, such as is made by ptrace(). The attachment of a debugger to a process affects execve()'s calculation of the new credential state - _and_ also setprocattr()'s calculation of that state. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: James Morris <jmorris@namei.org>
2009-05-07Merge branch 'tracing/hw-branch-tracing' into tracing/coreIngo Molnar
Merge reason: this topic is ready for upstream now. It passed Oleg's review and Andrew had no further mm/* objections/observations either. Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-04-27ptrace: ptrace_attach: fix the usage of ->cred_exec_mutexOleg Nesterov
ptrace_attach() needs task->cred_exec_mutex, not current->cred_exec_mutex. Signed-off-by: Oleg Nesterov <oleg@redhat.com> Acked-by: Roland McGrath <roland@redhat.com> Acked-by: David Howells <dhowells@redhat.com> Signed-off-by: James Morris <jmorris@namei.org>
2009-04-24Merge commit 'v2.6.30-rc3' into tracing/hw-branch-tracingIngo Molnar
Conflicts: arch/x86/kernel/ptrace.c Merge reason: fix the conflict above, and also pick up the CONFIG_BROKEN dependency change from upstream so that we can remove it here. Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-04-13ptrace: fix exit_ptrace() vs ptrace_traceme() raceOleg Nesterov
Pointed out by Roland. The bug was recently introduced by me in "forget_original_parent: split out the un-ptrace part", commit 39c626ae47c469abdfd30c6e42eff884931380d6. Since that patch we have a window after exit_ptrace() drops tasklist and before forget_original_parent() takes it again. In this window the child can do ptrace(PTRACE_TRACEME) and nobody can untrace this child after that. Change ptrace_traceme() to not attach to the exiting ->real_parent. We don't report the error in this case, we pretend we attach right before ->real_parent calls exit_ptrace() which should untrace us anyway. Signed-off-by: Oleg Nesterov <oleg@redhat.com> Acked-by: Roland McGrath <roland@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-08ptrace: some checkpatch fixesRoland McGrath
This fixes all the checkpatch --file complaints about kernel/ptrace.c and also removes an unused #include. I've verified that there are no changes to the compiled code on x86_64. Signed-off-by: Roland McGrath <roland@redhat.com> [ Removed the parts that just split a line - Linus ] Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-07x86, ptrace: add bts context unconditionallyMarkus Metzger
Add the ptrace bts context field to task_struct unconditionally. Initialize the field directly in copy_process(). Remove all the unneeded functionality used to initialize that field. Signed-off-by: Markus Metzger <markus.t.metzger@intel.com> Cc: roland@redhat.com Cc: eranian@googlemail.com Cc: oleg@redhat.com Cc: juan.villacis@intel.com Cc: ak@linux.jf.intel.com LKML-Reference: <20090403144603.292754000@intel.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-04-03Merge branch 'core-cleanups-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'core-cleanups-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: ptrace: remove a useless goto
2009-04-02ptrace_untrace: fix the SIGNAL_STOP_STOPPED checkOleg Nesterov
This bug is ancient too. ptrace_untrace() must not resume the task if the group stop in progress, we should set TASK_STOPPED instead. Unfortunately, we still have problems here: - if the process/thread was traced, SIGNAL_STOP_STOPPED does not necessary means this thread group is stopped. - ptrace breaks the bookkeeping of ->group_stop_count. Signed-off-by: Oleg Nesterov <oleg@redhat.com> Cc: Jerome Marchand <jmarchan@redhat.com> Cc: Roland McGrath <roland@redhat.com> Cc: Denys Vlasenko <dvlasenk@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-02ptrace_detach: the wrong wakeup breaks the ERESTARTxxx logicOleg Nesterov
Another ancient bug. Consider this trivial test-case, int main(void) { int pid = fork(); if (pid) { ptrace(PTRACE_ATTACH, pid, NULL, NULL); wait(NULL); ptrace(PTRACE_DETACH, pid, NULL, NULL); } else { pause(); printf("WE HAVE A KERNEL BUG!!!\n"); } return 0; } the child must not "escape" for sys_pause(), but it can and this was seen in practice. This is because ptrace_detach does: if (!child->exit_state) wake_up_process(child); this wakeup can happen after this child has already restarted sys_pause(), because it gets another wakeup from ptrace_untrace(). With or without this patch, perhaps sys_pause() needs a fix. But this wakeup also breaks the SIGNAL_STOP_STOPPED logic in ptrace_untrace(). Remove this wakeup. The caller saw this task in TASK_TRACED state, and unless it was SIGKILL'ed in between __ptrace_unlink()->ptrace_untrace() should handle this case correctly. If it was SIGKILL'ed, we don't need to wakup the dying tracee too. Signed-off-by: Oleg Nesterov <oleg@redhat.com> Cc: Jerome Marchand <jmarchan@redhat.com> Acked-by: Roland McGrath <roland@redhat.com> Cc: Denys Vlasenko <dvlasenk@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-02forget_original_parent: split out the un-ptrace partOleg Nesterov
By discussion with Roland. - Rename ptrace_exit() to exit_ptrace(), and change it to do all the necessary work with ->ptraced list by its own. - Move this code from exit.c to ptrace.c - Update the comment in ptrace_detach() to explain the rechecking of the child->ptrace. Signed-off-by: Oleg Nesterov <oleg@redhat.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: "Metzger, Markus T" <markus.t.metzger@intel.com> Cc: Roland McGrath <roland@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-02ptrace: fix possible zombie leak on PTRACE_DETACHOleg Nesterov
When ptrace_detach() takes tasklist, the tracee can be SIGKILL'ed. If it has already passed exit_notify() we can leak a zombie, because a) ptracing disables the auto-reaping logic, and b) ->real_parent was not notified about the child's death. ptrace_detach() should follow the ptrace_exit's logic, change the code accordingly. Signed-off-by: Oleg Nesterov <oleg@redhat.com> Cc: Jerome Marchand <jmarchan@redhat.com> Cc: Roland McGrath <roland@redhat.com> Tested-by: Denys Vlasenko <dvlasenk@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-02ptrace: kill __ptrace_detach(), fix ->exit_state checkOleg Nesterov
Move the code from __ptrace_detach() to its single caller and kill this helper. Also, fix the ->exit_state check, we shouldn't wake up EXIT_DEAD tasks. Actually, I think task_is_stopped_or_traced() makes more sense, but this needs another patch. Signed-off-by: Oleg Nesterov <oleg@redhat.com> Cc: Jerome Marchand <jmarchan@redhat.com> Cc: Roland McGrath <roland@redhat.com> Cc: Denys Vlasenko <dvlasenk@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-03-10ptrace: remove a useless gotoAmérico Wang
Impact: cleanup Obviously, this goto is useless. Remove it. Signed-off-by: WANG Cong <xiyou.wangcong@gmail.com> Cc: Andrew Morton <akpm@osdl.org> Cc: Roland McGrath <roland@redhat.com> LKML-Reference: <20090310093447.GC3179@hack> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-01-14[CVE-2009-0029] System call wrappers part 27Heiko Carstens
2008-12-28Merge branch 'tracing-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'tracing-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (241 commits) sched, trace: update trace_sched_wakeup() tracing/ftrace: don't trace on early stage of a secondary cpu boot, v3 Revert "x86: disable X86_PTRACE_BTS" ring-buffer: prevent false positive warning ring-buffer: fix dangling commit race ftrace: enable format arguments checking x86, bts: memory accounting x86, bts: add fork and exit handling ftrace: introduce tracing_reset_online_cpus() helper tracing: fix warnings in kernel/trace/trace_sched_switch.c tracing: fix warning in kernel/trace/trace.c tracing/ring-buffer: remove unused ring_buffer size trace: fix task state printout ftrace: add not to regex on filtering functions trace: better use of stack_trace_enabled for boot up code trace: add a way to enable or disable the stack tracer x86: entry_64 - introduce FTRACE_ frame macro v2 tracing/ftrace: add the printk-msg-only option tracing/ftrace: use preempt_enable_no_resched_notrace in ring_buffer_time_stamp() x86, bts: correctly report invalid bts records ... Fixed up trivial conflict in scripts/recordmcount.pl due to SH bits being already partly merged by the SH merge.
2008-12-20x86, bts: add fork and exit handlingMarkus Metzger
Impact: introduce new ptrace facility Add arch_ptrace_untrace() function that is called when the tracer detaches (either voluntarily or when the tracing task dies); ptrace_disable() is only called on a voluntary detach. Add ptrace_fork() and arch_ptrace_fork(). They are called when a traced task is forked. Clear DS and BTS related fields on fork. Release DS resources and reclaim memory in ptrace_untrace(). This releases resources already when the tracing task dies. We used to do that when the traced task dies. Signed-off-by: Markus Metzger <markus.t.metzger@intel.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-12-04Merge branch 'master' into nextJames Morris
Conflicts: fs/nfsd/nfs4recover.c Manually fixed above to use new creds API functions, e.g. nfs4_save_creds(). Signed-off-by: James Morris <jmorris@namei.org>
2008-11-30remove __ARCH_WANT_COMPAT_SYS_PTRACEChristoph Hellwig
All architectures now use the generic compat_sys_ptrace, as should every new architecture that needs 32bit compat (if we'll ever get another). Remove the now superflous __ARCH_WANT_COMPAT_SYS_PTRACE define, and also kill a comment about __ARCH_SYS_PTRACE that was added after __ARCH_SYS_PTRACE was already gone. Signed-off-by: Christoph Hellwig <hch@lst.de> Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-11-14CRED: Inaugurate COW credentialsDavid Howells
Inaugurate copy-on-write credentials management. This uses RCU to manage the credentials pointer in the task_struct with respect to accesses by other tasks. A process may only modify its own credentials, and so does not need locking to access or modify its own credentials. A mutex (cred_replace_mutex) is added to the task_struct to control the effect of PTRACE_ATTACHED on credential calculations, particularly with respect to execve(). With this patch, the contents of an active credentials struct may not be changed directly; rather a new set of credentials must be prepared, modified and committed using something like the following sequence of events: struct cred *new = prepare_creds(); int ret = blah(new); if (ret < 0) { abort_creds(new); return ret; } return commit_creds(new); There are some exceptions to this rule: the keyrings pointed to by the active credentials may be instantiated - keyrings violate the COW rule as managing COW keyrings is tricky, given that it is possible for a task to directly alter the keys in a keyring in use by another task. To help enforce this, various pointers to sets of credentials, such as those in the task_struct, are declared const. The purpose of this is compile-time discouragement of altering credentials through those pointers. Once a set of credentials has been made public through one of these pointers, it may not be modified, except under special circumstances: (1) Its reference count may incremented and decremented. (2) The keyrings to which it points may be modified, but not replaced. The only safe way to modify anything else is to create a replacement and commit using the functions described in Documentation/credentials.txt (which will be added by a later patch). This patch and the preceding patches have been tested with the LTP SELinux testsuite. This patch makes several logical sets of alteration: (1) execve(). This now prepares and commits credentials in various places in the security code rather than altering the current creds directly. (2) Temporary credential overrides. do_coredump() and sys_faccessat() now prepare their own credentials and temporarily override the ones currently on the acting thread, whilst preventing interference from other threads by holding cred_replace_mutex on the thread being dumped. This will be replaced in a future patch by something that hands down the credentials directly to the functions being called, rather than altering the task's objective credentials. (3) LSM interface. A number of functions have been changed, added or removed: (*) security_capset_check(), ->capset_check() (*) security_capset_set(), ->capset_set() Removed in favour of security_capset(). (*) security_capset(), ->capset() New. This is passed a pointer to the new creds, a pointer to the old creds and the proposed capability sets. It should fill in the new creds or return an error. All pointers, barring the pointer to the new creds, are now const. (*) security_bprm_apply_creds(), ->bprm_apply_creds() Changed; now returns a value, which will cause the process to be killed if it's an error. (*) security_task_alloc(), ->task_alloc_security() Removed in favour of security_prepare_creds(). (*) security_cred_free(), ->cred_free() New. Free security data attached to cred->security. (*) security_prepare_creds(), ->cred_prepare() New. Duplicate any security data attached to cred->security. (*) security_commit_creds(), ->cred_commit() New. Apply any security effects for the upcoming installation of new security by commit_creds(). (*) security_task_post_setuid(), ->task_post_setuid() Removed in favour of security_task_fix_setuid(). (*) security_task_fix_setuid(), ->task_fix_setuid() Fix up the proposed new credentials for setuid(). This is used by cap_set_fix_setuid() to implicitly adjust capabilities in line with setuid() changes. Changes are made to the new credentials, rather than the task itself as in security_task_post_setuid(). (*) security_task_reparent_to_init(), ->task_reparent_to_init() Removed. Instead the task being reparented to init is referred directly to init's credentials. NOTE! This results in the loss of some state: SELinux's osid no longer records the sid of the thread that forked it. (*) security_key_alloc(), ->key_alloc() (*) security_key_permission(), ->key_permission() Changed. These now take cred pointers rather than task pointers to refer to the security context. (4) sys_capset(). This has been simplified and uses less locking. The LSM functions it calls have been merged. (5) reparent_to_kthreadd(). This gives the current thread the same credentials as init by simply using commit_thread() to point that way. (6) __sigqueue_alloc() and switch_uid() __sigqueue_alloc() can't stop the target task from changing its creds beneath it, so this function gets a reference to the currently applicable user_struct which it then passes into the sigqueue struct it returns if successful. switch_uid() is now called from commit_creds(), and possibly should be folded into that. commit_creds() should take care of protecting __sigqueue_alloc(). (7) [sg]et[ug]id() and co and [sg]et_current_groups. The set functions now all use prepare_creds(), commit_creds() and abort_creds() to build and check a new set of credentials before applying it. security_task_set[ug]id() is called inside the prepared section. This guarantees that nothing else will affect the creds until we've finished. The calling of set_dumpable() has been moved into commit_creds(). Much of the functionality of set_user() has been moved into commit_creds(). The get functions all simply access the data directly. (8) security_task_prctl() and cap_task_prctl(). security_task_prctl() has been modified to return -ENOSYS if it doesn't want to handle a function, or otherwise return the return value directly rather than through an argument. Additionally, cap_task_prctl() now prepares a new set of credentials, even if it doesn't end up using it. (9) Keyrings. A number of changes have been made to the keyrings code: (a) switch_uid_keyring(), copy_keys(), exit_keys() and suid_keys() have all been dropped and built in to the credentials functions directly. They may want separating out again later. (b) key_alloc() and search_process_keyrings() now take a cred pointer rather than a task pointer to specify the security context. (c) copy_creds() gives a new thread within the same thread group a new thread keyring if its parent had one, otherwise it discards the thread keyring. (d) The authorisation key now points directly to the credentials to extend the search into rather pointing to the task that carries them. (e) Installing thread, process or session keyrings causes a new set of credentials to be created, even though it's not strictly necessary for process or session keyrings (they're shared). (10) Usermode helper. The usermode helper code now carries a cred struct pointer in its subprocess_info struct instead of a new session keyring pointer. This set of credentials is derived from init_cred and installed on the new process after it has been cloned. call_usermodehelper_setup() allocates the new credentials and call_usermodehelper_freeinfo() discards them if they haven't been used. A special cred function (prepare_usermodeinfo_creds()) is provided specifically for call_usermodehelper_setup() to call. call_usermodehelper_setkeys() adjusts the credentials to sport the supplied keyring as the new session keyring. (11) SELinux. SELinux has a number of changes, in addition to those to support the LSM interface changes mentioned above: (a) selinux_setprocattr() no longer does its check for whether the current ptracer can access processes with the new SID inside the lock that covers getting the ptracer's SID. Whilst this lock ensures that the check is done with the ptracer pinned, the result is only valid until the lock is released, so there's no point doing it inside the lock. (12) is_single_threaded(). This function has been extracted from selinux_setprocattr() and put into a file of its own in the lib/ directory as join_session_keyring() now wants to use it too. The code in SELinux just checked to see whether a task shared mm_structs with other tasks (CLONE_VM), but that isn't good enough. We really want to know if they're part of the same thread group (CLONE_THREAD). (13) nfsd. The NFS server daemon now has to use the COW credentials to set the credentials it is going to use. It really needs to pass the credentials down to the functions it calls, but it can't do that until other patches in this series have been applied. Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: James Morris <jmorris@namei.org> Signed-off-by: James Morris <jmorris@namei.org>
2008-11-14CRED: Use RCU to access another task's creds and to release a task's own credsDavid Howells
Use RCU to access another task's creds and to release a task's own creds. This means that it will be possible for the credentials of a task to be replaced without another task (a) requiring a full lock to read them, and (b) seeing deallocated memory. Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: James Morris <jmorris@namei.org> Acked-by: Serge Hallyn <serue@us.ibm.com> Signed-off-by: James Morris <jmorris@namei.org>
2008-11-14CRED: Separate task security context from task_structDavid Howells
Separate the task security context from task_struct. At this point, the security data is temporarily embedded in the task_struct with two pointers pointing to it. Note that the Alpha arch is altered as it refers to (E)UID and (E)GID in entry.S via asm-offsets. With comment fixes Signed-off-by: Marc Dionne <marc.c.dionne@gmail.com> Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: James Morris <jmorris@namei.org> Acked-by: Serge Hallyn <serue@us.ibm.com> Signed-off-by: James Morris <jmorris@namei.org>
2008-11-14CRED: Wrap task credential accesses in the core kernelDavid Howells
Wrap access to task credentials so that they can be separated more easily from the task_struct during the introduction of COW creds. Change most current->(|e|s|fs)[ug]id to current_(|e|s|fs)[ug]id(). Change some task->e?[ug]id to task_e?[ug]id(). In some places it makes more sense to use RCU directly rather than a convenient wrapper; these will be addressed by later patches. Signed-off-by: David Howells <dhowells@redhat.com> Reviewed-by: James Morris <jmorris@namei.org> Acked-by: Serge Hallyn <serue@us.ibm.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: linux-audit@redhat.com Cc: containers@lists.linux-foundation.org Cc: linux-mm@kvack.org Signed-off-by: James Morris <jmorris@namei.org>
2008-10-20make ptrace_untrace() staticAdrian Bunk
ptrace_untrace() can now become static. Signed-off-by: Adrian Bunk <bunk@kernel.org> Cc: Oleg Nesterov <oleg@tv-sign.ru> Cc: Roland McGrath <roland@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-08-14security: Fix setting of PF_SUPERPRIV by __capable()David Howells
Fix the setting of PF_SUPERPRIV by __capable() as it could corrupt the flags the target process if that is not the current process and it is trying to change its own flags in a different way at the same time. __capable() is using neither atomic ops nor locking to protect t->flags. This patch removes __capable() and introduces has_capability() that doesn't set PF_SUPERPRIV on the process being queried. This patch further splits security_ptrace() in two: (1) security_ptrace_may_access(). This passes judgement on whether one process may access another only (PTRACE_MODE_ATTACH for ptrace() and PTRACE_MODE_READ for /proc), and takes a pointer to the child process. current is the parent. (2) security_ptrace_traceme(). This passes judgement on PTRACE_TRACEME only, and takes only a pointer to the parent process. current is the child. In Smack and commoncap, this uses has_capability() to determine whether the parent will be permitted to use PTRACE_ATTACH if normal checks fail. This does not set PF_SUPERPRIV. Two of the instances of __capable() actually only act on current, and so have been changed to calls to capable(). Of the places that were using __capable(): (1) The OOM killer calls __capable() thrice when weighing the killability of a process. All of these now use has_capability(). (2) cap_ptrace() and smack_ptrace() were using __capable() to check to see whether the parent was allowed to trace any process. As mentioned above, these have been split. For PTRACE_ATTACH and /proc, capable() is now used, and for PTRACE_TRACEME, has_capability() is used. (3) cap_safe_nice() only ever saw current, so now uses capable(). (4) smack_setprocattr() rejected accesses to tasks other than current just after calling __capable(), so the order of these two tests have been switched and capable() is used instead. (5) In smack_file_send_sigiotask(), we need to allow privileged processes to receive SIGIO on files they're manipulating. (6) In smack_task_wait(), we let a process wait for a privileged process, whether or not the process doing the waiting is privileged. I've tested this with the LTP SELinux and syscalls testscripts. Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Serge Hallyn <serue@us.ibm.com> Acked-by: Casey Schaufler <casey@schaufler-ca.com> Acked-by: Andrew G. Morgan <morgan@kernel.org> Acked-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: James Morris <jmorris@namei.org>
2008-07-26tracehook: wait_task_inactiveRoland McGrath
This extends wait_task_inactive() with a new argument so it can be used in a "soft" mode where it will check for the task changing state unexpectedly and back off. There is no change to existing callers. This lays the groundwork to allow robust, noninvasive tracing that can try to sample a blocked thread but back off safely if it wakes up. Signed-off-by: Roland McGrath <roland@redhat.com> Cc: Oleg Nesterov <oleg@tv-sign.ru> Reviewed-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-16ptrace children revampRoland McGrath
ptrace no longer fiddles with the children/sibling links, and the old ptrace_children list is gone. Now ptrace, whether of one's own children or another's via PTRACE_ATTACH, just uses the new ptraced list instead. There should be no user-visible difference that matters. The only change is the order in which do_wait() sees multiple stopped children and stopped ptrace attachees. Since wait_task_stopped() was changed earlier so it no longer reorders the children list, we already know this won't cause any new problems. Signed-off-by: Roland McGrath <roland@redhat.com>
2008-07-14Security: split proc ptrace checking into read vs. attachStephen Smalley
Enable security modules to distinguish reading of process state via proc from full ptrace access by renaming ptrace_may_attach to ptrace_may_access and adding a mode argument indicating whether only read access or full attach access is requested. This allows security modules to permit access to reading process state without granting full ptrace access. The base DAC/capability checking remains unchanged. Read access to /proc/pid/mem continues to apply a full ptrace attach check since check_mem_permission() already requires the current task to already be ptracing the target. The other ptrace checks within proc for elements like environ, maps, and fds are changed to pass the read mode instead of attach. In the SELinux case, we model such reading of process state as a reading of a proc file labeled with the target process' label. This enables SELinux policy to permit such reading of process state without permitting control or manipulation of the target process, as there are a number of cases where programs probe for such information via proc but do not need to be able to control the target (e.g. procps, lsof, PolicyKit, ConsoleKit). At present we have to choose between allowing full ptrace in policy (more permissive than required/desired) or breaking functionality (or in some cases just silencing the denials via dontaudit rules but this can hide genuine attacks). This version of the patch incorporates comments from Casey Schaufler (change/replace existing ptrace_may_attach interface, pass access mode), and Chris Wright (provide greater consistency in the checking). Note that like their predecessors __ptrace_may_attach and ptrace_may_attach, the __ptrace_may_access and ptrace_may_access interfaces use different return value conventions from each other (0 or -errno vs. 1 or 0). I retained this difference to avoid any changes to the caller logic but made the difference clearer by changing the latter interface to return a bool rather than an int and by adding a comment about it to ptrace.h for any future callers. Signed-off-by: Stephen Smalley <sds@tycho.nsa.gov> Acked-by: Chris Wright <chrisw@sous-sol.org> Signed-off-by: James Morris <jmorris@namei.org>
2008-05-01make generic sys_ptrace unconditionalChristoph Hellwig
With s390 the last arch switched to the generic sys_ptrace yesterday so we can now kill the ifdef around it to enforce every new port it using it instead of introducing new weirdo versions. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-30ptrace: permit ptracing of /sbin/initOleg Nesterov
Afaics, currently there are no kernel problems with ptracing init, it can't lose SIGNAL_UNKILLABLE flag and be killed/stopped by accident. The ability to strace/debug init can be very useful if you try to figure out why it does not work as expected. However, admin should know what he does, "gdb /sbin/init 1" stops init, it can't reap orphaned zombies or take care of /etc/inittab until continued. It is even possible to crash init (and thus the whole system) if you wish, ptracer has full control. See also the long discussion: http://marc.info/?t=120628018600001 Signed-off-by: Oleg Nesterov <oleg@tv-sign.ru> Acked-by: Roland McGrath <roland@redhat.com> Acked-by: Pavel Emelyanov <xemul@openvz.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-30ptrace: ptrace_attach: use send_sig_info() instead force_sig_specific()Oleg Nesterov
Nobody can block/ignore SIGSTOP, no need to use force_sig_specific() in ptrace_attach. Use the "regular" send_sig_info(). With this patch stracing of /sbin/init doesn't clear its SIGNAL_UNKILLABLE, but not that this makes ptracing of init safe. Signed-off-by: Oleg Nesterov <oleg@tv-sign.ru> Cc: Roland McGrath <roland@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-30ptrace: __ptrace_unlink: use the ptrace_reparented() helperOleg Nesterov
Currently __ptrace_unlink() checks list_empty(->ptrace_list) to figure out whether the child was reparented. Change the code to use ptrace_reparented() to make this check more explicit and consistent. No functional changes. Signed-off-by: Oleg Nesterov <oleg@tv-sign.ru> Acked-by: Roland McGrath <roland@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-28ptrace: conditionalize compat_ptrace_requestRoland McGrath
My recent additions to compat_ptrace_request made it mandatory for CONFIG_COMPAT arch's to define copy_siginfo_from_user32. This broke some builds, though they all really should get cleaned up in that way. Since all the arch's that actually call compat_ptrace_request have now been cleaned up to use the generic compat_sys_ptrace, we can avoid the build problems on the crufty arch's by changing the conditionals on the definition. Signed-off-by: Roland McGrath <roland@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-21ptrace: compat_ptrace_request siginfoRoland McGrath
This adds support for PTRACE_GETSIGINFO and PTRACE_SETSIGINFO in compat_ptrace_request. It relies on existing arch definitions for copy_siginfo_to_user32 and copy_siginfo_from_user32. On powerpc, this fixes a longstanding regression of 32-bit ptrace calls on 64-bit kernels vs native calls (64-bit calls or 32-bit kernels). This can be seen in a 32-bit call using PTRACE_GETSIGINFO to examine e.g. siginfo_t.si_addr from a signal that sets it. (This was broken as of 2.6.24 and, I presume, many or all prior versions.) Signed-off-by: Roland McGrath <roland@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-08ptrace_check_attach: remove unneeded ->signal != NULL checkOleg Nesterov
It is not possible to see the PT_PTRACED task without ->signal/sighand under tasklist_lock, release_task() does ptrace_unlink() first. If the task was already released before, ptrace_attach() can't succeed and set PT_PTRACED. Remove this check. Signed-off-by: Oleg Nesterov <oleg@tv-sign.ru> Acked-by: Roland McGrath <roland@redhat.com> Cc: Christoph Hellwig <hch@lst.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-08kill PT_ATTACHEDOleg Nesterov
Since the patch "Fix ptrace_attach()/ptrace_traceme()/de_thread() race" commit f5b40e363ad6041a96e3da32281d8faa191597b9 we set PT_ATTACHED and change child->parent "atomically" wrt task_list lock. This means we can remove the checks like "PT_ATTACHED && ->parent != ptracer" which were needed to catch the "ptrace attach is in progress" case. We can also remove the flag itself since nobody else uses it. Signed-off-by: Oleg Nesterov <oleg@tv-sign.ru> Acked-by: Roland McGrath <roland@redhat.com> Cc: Christoph Hellwig <hch@lst.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-06kernel/ptrace.c should #include <linux/syscalls.h>Adrian Bunk
Every file should include the headers containing the prototypes for its global functions (in this case sys_ptrace()). Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-06use __set_task_state() for TRACED/STOPPED tasksOleg Nesterov
1. It is much easier to grep for ->state change if __set_task_state() is used instead of the direct assignment. 2. ptrace_stop() and handle_group_stop() use set_task_state() which adds the unneeded mb() (btw even if we use mb() it is still possible that do_wait() sees the new ->state but not ->exit_code, but this is ok). Signed-off-by: Oleg Nesterov <oleg@tv-sign.ru> Acked-by: Roland McGrath <roland@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-01Merge branch 'task_killable' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/willy/misc * 'task_killable' of git://git.kernel.org/pub/scm/linux/kernel/git/willy/misc: (22 commits) Remove commented-out code copied from NFS NFS: Switch from intr mount option to TASK_KILLABLE Add wait_for_completion_killable Add wait_event_killable Add schedule_timeout_killable Use mutex_lock_killable in vfs_readdir Add mutex_lock_killable Use lock_page_killable Add lock_page_killable Add fatal_signal_pending Add TASK_WAKEKILL exit: Use task_is_* signal: Use task_is_* sched: Use task_contributes_to_load, TASK_ALL and TASK_NORMAL ptrace: Use task_is_* power: Use task_is_* wait: Use TASK_NORMAL proc/base.c: Use task_is_* proc/array.c: Use TASK_REPORT perfmon: Use task_is_* ... Fixed up conflicts in NFS/sunrpc manually..
2008-01-30x86: compat_sys_ptraceRoland McGrath
This adds a generic definition of compat_sys_ptrace that calls compat_arch_ptrace, parallel to sys_ptrace/arch_ptrace. Some machines needing this already define a function by that name. The new generic function is defined only on machines that put #define __ARCH_WANT_COMPAT_SYS_PTRACE into asm/ptrace.h. Signed-off-by: Roland McGrath <roland@redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-01-30x86: compat_ptrace_requestRoland McGrath
This adds a compat_ptrace_request that is the analogue of ptrace_request for the things that 32-on-64 ptrace implementations can share in common. So far there are just a couple of requests handled generically. Signed-off-by: Roland McGrath <roland@redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-01-30x86: ptrace_request peekdata/pokedataRoland McGrath
This makes ptrace_request handle {PEEK,POKE}{TEXT,DATA} directly. Every arch_ptrace that could call generic_ptrace_peekdata already has a default case calling ptrace_request, so this keeps things simpler for the arch code. Signed-off-by: Roland McGrath <roland@redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-01-30ptrace: generic PTRACE_SINGLEBLOCKRoland McGrath
This makes ptrace_request handle PTRACE_SINGLEBLOCK along with PTRACE_CONT et al. The new generic code makes use of the arch_has_block_step macro and generic entry points on machines that define them. [ mingo@elte.hu: bugfix ] Signed-off-by: Roland McGrath <roland@redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-01-30ptrace: generic resumeRoland McGrath
This makes ptrace_request handle all the ptrace requests that wake up the traced task. These do low-level ptrace implementation magic that is not arch-specific and should be kept out of arch code. The implementations on each arch usually do the same thing. The new generic code makes use of the arch_has_single_step macro and generic entry points to handle PTRACE_SINGLESTEP. Signed-off-by: Roland McGrath <roland@redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-01-25ptrace: Call arch_ptrace_attach() when request=PTRACE_TRACEMEHaavard Skinnemoen
arch_ptrace_attach() is a hook that allows the architecture to do book-keeping after a ptrace attach. This patch adds a call to this hook when handling a PTRACE_TRACEME request as well. Currently only one architecture, m32r, implements this hook. When called, it initializes a number of debug trap slots in the ptraced task's thread struct, and it looks to me like this is the right thing to do after a PTRACE_TRACEME request as well, not only after PTRACE_ATTACH. Please correct me if I'm wrong. I want to use this hook on AVR32 to turn the debugging hardware on when a process is actually being debugged and keep it off otherwise. To be able to do this, I need to intercept PTRACE_TRACEME and PTRACE_ATTACH, as well as PTRACE_DETACH and thread exit. The latter two can be handled by existing hooks. Signed-off-by: Haavard Skinnemoen <hskinnemoen@atmel.com>
2008-01-02Fix kernel/ptrace.c compile problem (missing "may_attach()")Linus Torvalds
The previous commit missed one use of "may_attach()" that had been renamed to __ptrace_may_attach(). Tssk, tssk, Al. Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
