path: root/kernel/ptrace.c
2006-09-29[PATCH] pidspace: is_init()Sukadev Bhattiprolu
This is an updated version of Eric Biederman's is_init() patch. (http://lkml.org/lkml/2006/2/6/280). It applies cleanly to 2.6.18-rc3 and replaces a few more instances of ->pid == 1 with is_init(). Further, is_init() checks pid and thus removes dependency on Eric's other patches for now. Eric's original description: There are a lot of places in the kernel where we test for init because we give it special properties. Most significantly init must not die. This results in code all over the kernel test ->pid == 1. Introduce is_init to capture this case. With multiple pid spaces for all of the cases affected we are looking for only the first process on the system, not some other process that has pid == 1. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: Sukadev Bhattiprolu <sukadev@us.ibm.com> Cc: Dave Hansen <haveblue@us.ibm.com> Cc: Serge Hallyn <serue@us.ibm.com> Cc: Cedric Le Goater <clg@fr.ibm.com> Cc: <lxc-devel@lists.sourceforge.net> Acked-by: Paul Mackerras <paulus@samba.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-27[PATCH] NOMMU: Check that access_process_vm() has a valid targetDavid Howells
Check that access_process_vm() is accessing a valid mapping in the target process. This limits ptrace() accesses and accesses through /proc/<pid>/maps to only those regions actually mapped by a program. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-03[PATCH] sched: cleanup, remove task_t, convert to struct task_structIngo Molnar
cleanup: remove task_t and convert all the uses to struct task_struct. I introduced it for the scheduler anno and it was a mistake. Conversion was mostly scripted, the result was reviewed and all secondary whitespace and style impact (if any) was fixed up by hand. Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-26[PATCH] coredump: kill ptrace related stuffOleg Nesterov
With this patch zap_process() sets SIGNAL_GROUP_EXIT while sending SIGKILL to the thread group. This means that a TASK_TRACED task 1. Will be awakened by signal_wake_up(1) 2. Can't sleep again via ptrace_notify() 3. Can't go to do_signal_stop() after return from ptrace_stop() in get_signal_to_deliver() So we can remove all ptrace related stuff from coredump path. Signed-off-by: Oleg Nesterov <oleg@tv-sign.ru> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Roland McGrath <roland@redhat.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-26[PATCH] proc: Cleanup proc_fd_access_allowedEric W. Biederman
In process of getting proc_fd_access_allowed to work it has developed a few warts. In particular the special case that always allows introspection and the special case to allow inspection of kernel threads. The special case for introspection is needed for /proc/self/mem. The special case for kernel threads really should be overridable by security modules. So consolidate these checks into ptrace.c:may_attach(). The check to always allow introspection is trivial. The check to allow access to kernel threads, and zombies is a little trickier. mem_read and mem_write already verify an mm exists so it isn't needed twice. proc_fd_access_allowed only doesn't want a check to verify task->mm exits, s it prevents all access to kernel threads. So just move the task->mm check into ptrace_attach where it is needed for practical reasons. I did a quick audit and none of the security modules in the kernel seem to care if they are passed a task without an mm into security_ptrace. So the above move should be safe and it allows security modules to come up with more restrictive policy. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Cc: Stephen Smalley <sds@tycho.nsa.gov> Cc: Chris Wright <chrisw@sous-sol.org> Cc: James Morris <jmorris@namei.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-05-11ptrace_attach: fix possible deadlock schenario with irqsLinus Torvalds
Eric Biederman points out that we can't take the task_lock while holding tasklist_lock for writing, because another CPU that holds the task lock might take an interrupt that then tries to take tasklist_lock for writing. Which would be a nasty deadlock, with one CPU spinning forever in an interrupt handler (although admittedly you need to really work at triggering it ;) Since the ptrace_attach() code is special and very unusual, just make it be extra careful, and use trylock+repeat to avoid the possible deadlock. Cc: Oleg Nesterov <oleg@tv-sign.ru> Cc: Eric W. Biederman <ebiederm@xmission.com> Cc: Roland McGrath <roland@redhat.com> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-05-07Fix ptrace_attach()/ptrace_traceme()/de_thread() raceLinus Torvalds
This holds the task lock (and, for ptrace_attach, the tasklist_lock) over the actual attach event, which closes a race between attacking to a thread that is either doing a PTRACE_TRACEME or getting de-threaded. Thanks to Oleg Nesterov for reminding me about this, and Chris Wright for noticing a lost return value in my first version. Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-04-14[PATCH] fix non-leader exec under ptraceRoland McGrath
This reverts most of commit 30e0fca6c1d7d26f3f2daa4dd2b12c51dadc778a. It broke the case of non-leader MT exec when ptraced. I think the bug it was intended to fix was already addressed by commit 788e05a67c343fa22f2ae1d3ca264e7f15c25eaf. Signed-off-by: Roland McGrath <roland@redhat.com> Acked-by: Oleg Nesterov <oleg@tv-sign.ru> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-04-02BUG_ON() Conversion in kernel/ptrace.cEric Sesterhenn
this changes if() BUG(); constructs to BUG_ON() which is cleaner, contains unlikely() and can better optimized away. Signed-off-by: Eric Sesterhenn <snakebyte@gmx.de> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-03-28[PATCH] don't use REMOVE_LINKS/SET_LINKS for reparentingOleg Nesterov
There are places where kernel uses REMOVE_LINKS/SET_LINKS while changing process's ->parent. Use add_parent/remove_parent instead, they don't abuse of global process list. Signed-off-by: Oleg Nesterov <oleg@tv-sign.ru> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-02-15[PATCH] fix zap_thread's ptrace related problemsOleg Nesterov
1. The tracee can go from ptrace_stop() to do_signal_stop() after __ptrace_unlink(p). 2. It is unsafe to __ptrace_unlink(p) while p->parent may wait for tasklist_lock in ptrace_detach(). Signed-off-by: Oleg Nesterov <oleg@tv-sign.ru> Cc: Roland McGrath <roland@redhat.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Christoph Hellwig <hch@lst.de> Cc: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-02-14[PATCH] compound page: no access_process_vm checkHugh Dickins
The PageCompound check before access_process_vm's set_page_dirty_lock is no longer necessary, so remove it. But leave the PageCompound checks in bio_set_pages_dirty, dio_bio_complete and nfs_free_user_pages: at least some of those were introduced as a little optimization on hugetlb pages. Signed-off-by: Hugh Dickins <hugh@veritas.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-11[PATCH] move capable() to capability.hRandy.Dunlap
- Move capable() from sched.h to capability.h; - Use <linux/capability.h> where capable() is used (in include/, block/, ipc/, kernel/, a few drivers/, mm/, security/, & sound/; many more drivers/ to go) Signed-off-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-08[PATCH] use ptrace_get_task_struct in various placesChristoph Hellwig
The ptrace_get_task_struct() helper that I added as part of the ptrace consolidation is useful in variety of places that currently opencode it. Switch them to the common helpers. Add a ptrace_traceme() helper that needs to be explicitly called, and simplify the ptrace_get_task_struct() interface. We don't need the request argument now, and we return the task_struct directly, using ERR_PTR() for error returns. It's a bit more code in the callers, but we have two sane routines that do one thing well now. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-29[PATCH] Fix crash when ptrace poking hugepage areasDavid Gibson
set_page_dirty() will not cope with being handed a page * which is part of a compound page, but not the master page in that compound page. This case can occur via access_process_vm() if you attemp to write to another process's hugepage memory area using ptrace() (causing an oops or hang). This patch fixes the bug by only calling set_page_dirty() from access_process_vm() if the page is not a compound page. We already use a similar fix in bio_set_pages_dirty() for the case of direct io to hugepages. Signed-off-by: David Gibson <david@gibson.dropbear.id.au> Acked-by: William Irwin <wli@holomorphy.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-13[PATCH] fix task_struct leak in ptraceChristoph Hellwig
When ptrace_attach fails we need to drop the task_struct reference. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-09Fix ptrace self-attach ruleLinus Torvalds
Before we did CLONE_THREAD, the way to check whether we were attaching to ourselves was to just check "current == task", but with CLONE_THREAD we should check that the thread group ID matches instead. Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-07[PATCH] consolidate sys_ptrace()Christoph Hellwig
The sys_ptrace boilerplate code (everything outside the big switch statement for the arch-specific requests) is shared by most architectures. This patch moves it to kernel/ptrace.c and leaves the arch-specific code as arch_ptrace. Some architectures have a too different ptrace so we have to exclude them. They continue to keep their implementations. For sh64 I had to add a sh64_ptrace wrapper because it does some initialization on the first call. For um I removed an ifdefed SUBARCH_PTRACE_SPECIAL block, but SUBARCH_PTRACE_SPECIAL isn't defined anywhere in the tree. Signed-off-by: Christoph Hellwig <hch@lst.de> Acked-by: Paul Mackerras <paulus@samba.org> Acked-by: Ralf Baechle <ralf@linux-mips.org> Acked-By: David Howells <dhowells@redhat.com> Acked-by: Russell King <rmk+kernel@arm.linux.org.uk> Acked-by: Paul Mundt <lethal@linux-sh.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-30[PATCH] ptrace/coredump/exit_group deadlockAndrea Arcangeli
I could seldom reproduce a deadlock with a task not killable in T state (TASK_STOPPED, not TASK_TRACED) by attaching a NPTL threaded program to gdb, by segfaulting the task and triggering a core dump while some other task is executing exit_group and while one task is in ptrace_attached TASK_STOPPED state (not TASK_TRACED yet). This originated from a gdb bugreport (the fact gdb was segfaulting the task wasn't a kernel bug), but I just incidentally noticed the gdb bug triggered a real kernel bug as well. Most threads hangs in exit_mm because the core_dumping is still going, the core dumping hangs because the stopped task doesn't exit, the stopped task can't wakeup because it has SIGNAL_GROUP_EXIT set, hence the deadlock. To me it seems that the problem is that the force_sig_specific(SIGKILL) in zap_threads is a noop if the task has PF_PTRACED set (like in this case because gdb is attached). The __ptrace_unlink does nothing because the signal->flags is set to SIGNAL_GROUP_EXIT|SIGNAL_STOP_DEQUEUED (verified). The above info also shows that the stopped task hit a race and got the stop signal (presumably by the ptrace_attach, only the attach, state is still TASK_STOPPED and gdb hangs waiting the core before it can set it to TASK_TRACED) after one of the thread invoked the core dump (it's the core dump that sets signal->flags to SIGNAL_GROUP_EXIT). So beside the fact nobody would wakeup the task in __ptrace_unlink (the state is _not_ TASK_TRACED), there's a secondary problem in the signal handling code, where a task should ignore the ptrace-sigstops as long as SIGNAL_GROUP_EXIT is set (or the wakeup in __ptrace_unlink path wouldn't be enough). So I attempted to make this patch that seems to fix the problem. There were various ways to fix it, perhaps you prefer a different one, I just opted to the one that looked safer to me. I also removed the clearing of the stopped bits from the zap_other_threads (zap_other_threads was safe unlike zap_threads). I don't like useless code, this whole NPTL signal/ptrace thing is already unreadable enough and full of corner cases without confusing useless code into it to make it even less readable. And if this code is really needed, then you may want to explain why it's not being done in the other paths that sets SIGNAL_GROUP_EXIT at least. Even after this patch I still wonder who serializes the read of p->ptrace in zap_threads. Patch is called ptrace-core_dump-exit_group-deadlock-1. This was the trace I've got: test T ffff81003e8118c0 0 14305 1 14311 14309 (NOTLB) ffff810058ccdde8 0000000000000082 000001f4000037e1 ffff810000000013 00000000000000f8 ffff81003e811b00 ffff81003e8118c0 ffff810011362100 0000000000000012 ffff810017ca4180 Call Trace:<ffffffff801317ed>{try_to_wake_up+893} <ffffffff80141677>{finish_stop+87} <ffffffff8014367f>{get_signal_to_deliver+1359} <ffffffff8010d3ad>{do_signal+157} <ffffffff8013deee>{ptrace_check_attach+222} <ffffffff80111575>{sys_ptrace+2293} <ffffffff80131810>{default_wake_function+0} <ffffffff80196399>{sys_ioctl+73} <ffffffff8010dd27>{sysret_signal+28} <ffffffff8010e00f>{ptregscall_common+103} test D ffff810011362100 0 14309 1 14305 14312 (NOTLB) ffff810053c81cf8 0000000000000082 0000000000000286 0000000000000001 0000000000000195 ffff810011362340 ffff810011362100 ffff81002e338040 ffff810001e0ca80 0000000000000001 Call Trace:<ffffffff801317ed>{try_to_wake_up+893} <ffffffff8044677d>{wait_for_completion+173} <ffffffff80131810>{default_wake_function+0} <ffffffff80137435>{exit_mm+149} <ffffffff801381af>{do_exit+479} <ffffffff80138d0c>{do_group_exit+252} <ffffffff801436db>{get_signal_to_deliver+1451} <ffffffff8010d3ad>{do_signal+157} <ffffffff8013deee>{ptrace_check_attach+222} <ffffffff80140850>{specific_send_sig_info+2 <ffffffff8014208a>{force_sig_info+186} <ffffffff804479a0>{do_int3+112} <ffffffff8010e308>{retint_signal+61} test D ffff81002e338040 0 14311 1 14716 14305 (NOTLB) ffff81005ca8dcf8 0000000000000082 0000000000000286 0000000000000001 0000000000000120 ffff81002e338280 ffff81002e338040 ffff8100481cb740 ffff810001e0ca80 0000000000000001 Call Trace:<ffffffff801317ed>{try_to_wake_up+893} <ffffffff8044677d>{wait_for_completion+173} <ffffffff80131810>{default_wake_function+0} <ffffffff80137435>{exit_mm+149} <ffffffff801381af>{do_exit+479} <ffffffff80142d0e>{__dequeue_signal+558} <ffffffff80138d0c>{do_group_exit+252} <ffffffff801436db>{get_signal_to_deliver+1451} <ffffffff8010d3ad>{do_signal+157} <ffffffff8013deee>{ptrace_check_attach+222} <ffffffff80140850>{specific_send_sig_info+208} <ffffffff8014208a>{force_sig_info+186} <ffffffff804479a0>{do_int3+112} <ffffffff8010e308>{retint_signal+61} test D ffff810017ca4180 0 14312 1 14309 13882 (NOTLB) ffff81005d15fcb8 0000000000000082 ffff81005d15fc58 ffffffff80130816 0000000000000897 ffff810017ca43c0 ffff810017ca4180 ffff81003e8118c0 0000000000000082 ffffffff801317ed Call Trace:<ffffffff80130816>{activate_task+150} <ffffffff801317ed>{try_to_wake_up+893} <ffffffff8044677d>{wait_for_completion+173} <ffffffff80131810>{default_wake_function+0} <ffffffff8018cdc3>{do_coredump+819} <ffffffff80445f52>{thread_return+82} <ffffffff801436d4>{get_signal_to_deliver+1444} <ffffffff8010d3ad>{do_signal+157} <ffffffff8013deee>{ptrace_check_attach+222} <ffffffff80140850>{specific_send_sig_info+2 <ffffffff804472e5>{_spin_unlock_irqrestore+5} <ffffffff8014208a>{force_sig_info+186} <ffffffff804476ff>{do_general_protection+159} <ffffffff8010e308>{retint_signal+61} Signed-off-by: Andrea Arcangeli <andrea@suse.de> Cc: Roland McGrath <roland@redhat.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Linus Torvalds <torvalds@osdl.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-07[PATCH] remove duplicated code from proc and ptraceMiklos Szeredi
Extract common code used by ptrace_attach() and may_ptrace_attach() into a separate function. Signed-off-by: Miklos Szeredi <miklos@szeredi.hu> Cc: <viro@parcelfarce.linux.theplanet.co.uk> Cc: Christoph Hellwig <hch@lst.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-05-01[PATCH] convert that currently tests _NSIG directly to use valid_signal()Jesper Juhl
Convert most of the current code that uses _NSIG directly to instead use valid_signal(). This avoids gcc -W warnings and off-by-one errors. Signed-off-by: Jesper Juhl <juhl-lkml@dif.dk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-05-01[PATCH] use smp_mb/wmb/rmb where possibleakpm@osdl.org
Replace a number of memory barriers with smp_ variants. This means we won't take the unnecessary hit on UP machines. Signed-off-by: Anton Blanchard <anton@samba.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
