path: root/kernel/ptrace.c
2013-06-29Fix: kernel/ptrace.c: ptrace_peek_siginfo() missing __put_user() validationMathieu Desnoyers
This __put_user() could be used by unprivileged processes to write into kernel memory. The issue here is that even if copy_siginfo_to_user() fails, the error code is not checked before __put_user() is executed. Luckily, ptrace_peek_siginfo() has been added within the 3.10-rc cycle, so it has not hit a stable release yet. Signed-off-by: Mathieu Desnoyers <mathieu.desnoyers@efficios.com> Acked-by: Oleg Nesterov <oleg@redhat.com> Cc: Andrey Vagin <avagin@openvz.org> Cc: Roland McGrath <roland@redhat.com> Cc: Paul McKenney <paulmck@linux.vnet.ibm.com> Cc: David Howells <dhowells@redhat.com> Cc: Dave Jones <davej@redhat.com> Cc: Pavel Emelyanov <xemul@parallels.com> Cc: Pedro Alves <palves@redhat.com> Cc: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-05-07aio: don't include aio.h in sched.hKent Overstreet
Faster kernel compiles by way of fewer unnecessary includes. [akpm@linux-foundation.org: fix fallout] [akpm@linux-foundation.org: fix build] Signed-off-by: Kent Overstreet <koverstreet@google.com> Cc: Zach Brown <zab@redhat.com> Cc: Felipe Balbi <balbi@ti.com> Cc: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Cc: Mark Fasheh <mfasheh@suse.com> Cc: Joel Becker <jlbec@evilplan.org> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: Jens Axboe <axboe@kernel.dk> Cc: Asai Thambi S P <asamymuthupa@micron.com> Cc: Selvan Mani <smani@micron.com> Cc: Sam Bradshaw <sbradshaw@micron.com> Cc: Jeff Moyer <jmoyer@redhat.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Benjamin LaHaise <bcrl@kvack.org> Reviewed-by: "Theodore Ts'o" <tytso@mit.edu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-04-30ptrace: add ability to retrieve signals without removing from a queue (v4)Andrey Vagin
This patch adds a new ptrace request PTRACE_PEEKSIGINFO. This request is used to retrieve information about pending signals starting with the specified sequence number. Siginfo_t structures are copied from the child into the buffer starting at "data". The argument "addr" is a pointer to struct ptrace_peeksiginfo_args. struct ptrace_peeksiginfo_args { u64 off; /* from which siginfo to start */ u32 flags; s32 nr; /* how may siginfos to take */ }; "nr" has type "s32", because ptrace() returns "long", which has 32 bits on i386 and a negative values is used for errors. Currently here is only one flag PTRACE_PEEKSIGINFO_SHARED for dumping signals from process-wide queue. If this flag is not set, signals are read from a per-thread queue. The request PTRACE_PEEKSIGINFO returns a number of dumped signals. If a signal with the specified sequence number doesn't exist, ptrace returns zero. The request returns an error, if no signal has been dumped. Errors: EINVAL - one or more specified flags are not supported or nr is negative EFAULT - buf or addr is outside your accessible address space. A result siginfo contains a kernel part of si_code which usually striped, but it's required for queuing the same siginfo back during restore of pending signals. This functionality is required for checkpointing pending signals. Pedro Alves suggested using it in "gdb" to peek at pending signals. gdb already uses PTRACE_GETSIGINFO to get the siginfo for the signal which was already dequeued. This functionality allows gdb to look at the pending signals which were not reported yet. The prototype of this code was developed by Oleg Nesterov. Signed-off-by: Andrew Vagin <avagin@openvz.org> Cc: Roland McGrath <roland@redhat.com> Cc: Oleg Nesterov <oleg@redhat.com> Cc: "Paul E. McKenney" <paulmck@linux.vnet.ibm.com> Cc: David Howells <dhowells@redhat.com> Cc: Dave Jones <davej@redhat.com> Cc: "Michael Kerrisk (man-pages)" <mtk.manpages@gmail.com> Cc: Pavel Emelyanov <xemul@parallels.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Pedro Alves <palves@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-02-08uprobes: Add exports for module useJosh Stone
The original pull message for uprobes (commit 654443e2) noted: This tree includes uprobes support in 'perf probe' - but SystemTap (and other tools) can take advantage of user probe points as well. In order to actually be usable in module-based tools like SystemTap, the interface needs to be exported. This patch first adds the obvious exports for uprobe_register and uprobe_unregister. Then it also adds one for task_user_regset_view, which is necessary to get the correct state of userspace registers. Signed-off-by: Josh Stone <jistone@redhat.com> Signed-off-by: Oleg Nesterov <oleg@redhat.com>
2013-01-22ptrace: ensure arch_ptrace/ptrace_request can never race with SIGKILLOleg Nesterov
putreg() assumes that the tracee is not running and pt_regs_access() can safely play with its stack. However a killed tracee can return from ptrace_stop() to the low-level asm code and do RESTORE_REST, this means that debugger can actually read/modify the kernel stack until the tracee does SAVE_REST again. set_task_blockstep() can race with SIGKILL too and in some sense this race is even worse, the very fact the tracee can be woken up breaks the logic. As Linus suggested we can clear TASK_WAKEKILL around the arch_ptrace() call, this ensures that nobody can ever wakeup the tracee while the debugger looks at it. Not only this fixes the mentioned problems, we can do some cleanups/simplifications in arch_ptrace() paths. Probably ptrace_unfreeze_traced() needs more callers, for example it makes sense to make the tracee killable for oom-killer before access_process_vm(). While at it, add the comment into may_ptrace_stop() to explain why ptrace_stop() still can't rely on SIGKILL and signal_pending_state(). Reported-by: Salman Qazi <sqazi@google.com> Reported-by: Suleiman Souhlal <suleiman@google.com> Suggested-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Oleg Nesterov <oleg@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-01-22ptrace: introduce signal_wake_up_state() and ptrace_signal_wake_up()Oleg Nesterov
Cleanup and preparation for the next change. signal_wake_up(resume => true) is overused. None of ptrace/jctl callers actually want to wakeup a TASK_WAKEKILL task, but they can't specify the necessary mask. Turn signal_wake_up() into signal_wake_up_state(state), reintroduce signal_wake_up() as a trivial helper, and add ptrace_signal_wake_up() which adds __TASK_TRACED. This way ptrace_signal_wake_up() can work "inside" ptrace_request() even if the tracee doesn't have the TASK_WAKEKILL bit set. Signed-off-by: Oleg Nesterov <oleg@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-01-20ia64: kill thread_matches(), unexport ptrace_check_attach()Oleg Nesterov
The ia64 function "thread_matches()" has no users since commit e868a55c2a8c ("[IA64] remove find_thread_for_addr()"). Remove it. This allows us to make ptrace_check_attach() static to kernel/ptrace.c, which is good since we'll need to change the semantics of it and fix up all the callers. Signed-off-by: Oleg Nesterov <oleg@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-12-17Merge branch 'akpm' (Andrew's patch-bomb)Linus Torvalds
Merge misc patches from Andrew Morton: "Incoming: - lots of misc stuff - backlight tree updates - lib/ updates - Oleg's percpu-rwsem changes - checkpatch - rtc - aoe - more checkpoint/restart support I still have a pile of MM stuff pending - Pekka should be merging later today after which that is good to go. A number of other things are twiddling thumbs awaiting maintainer merges." * emailed patches from Andrew Morton <akpm@linux-foundation.org>: (180 commits) scatterlist: don't BUG when we can trivially return a proper error. docs: update documentation about /proc/<pid>/fdinfo/<fd> fanotify output fs, fanotify: add @mflags field to fanotify output docs: add documentation about /proc/<pid>/fdinfo/<fd> output fs, notify: add procfs fdinfo helper fs, exportfs: add exportfs_encode_inode_fh() helper fs, exportfs: escape nil dereference if no s_export_op present fs, epoll: add procfs fdinfo helper fs, eventfd: add procfs fdinfo helper procfs: add ability to plug in auxiliary fdinfo providers tools/testing/selftests/kcmp/kcmp_test.c: print reason for failure in kcmp_test breakpoint selftests: print failure status instead of cause make error kcmp selftests: print fail status instead of cause make error kcmp selftests: make run_tests fix mem-hotplug selftests: print failure status instead of cause make error cpu-hotplug selftests: print failure status instead of cause make error mqueue selftests: print failure status instead of cause make error vm selftests: print failure status instead of cause make error ubifs: use prandom_bytes mtd: nandsim: use prandom_bytes ...
2012-12-17ptrace: introduce PTRACE_O_EXITKILLOleg Nesterov
Ptrace jailers want to be sure that the tracee can never escape from the control. However if the tracer dies unexpectedly the tracee continues to run in potentially unsafe mode. Add the new ptrace option PTRACE_O_EXITKILL. If the tracer exits it sends SIGKILL to every tracee which has this bit set. Note that the new option is not equal to the last-option << 1. Because currently all options have an event, and the new one starts the eventless group. It uses the random 20 bit, so we have the room for 12 more events, but we can also add the new eventless options below this one. Suggested by Amnon Shiloh. Signed-off-by: Oleg Nesterov <oleg@redhat.com> Tested-by: Amnon Shiloh <u3557@miso.sublimeip.com> Cc: Denys Vlasenko <dvlasenk@redhat.com> Cc: Michael Kerrisk <mtk.manpages@gmail.com> Cc: Serge Hallyn <serge.hallyn@canonical.com> Cc: Chris Evans <scarybeasts@gmail.com> Cc: David Howells <dhowells@redhat.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-11-20userns: Kill task_user_nsEric W. Biederman
The task_user_ns function hides the fact that it is getting the user namespace from struct cred on the task. struct cred may go away as soon as the rcu lock is released. This leads to a race where we can dereference a stale user namespace pointer. To make it obvious a struct cred is involved kill task_user_ns. To kill the race modify the users of task_user_ns to only reference the user namespace while the rcu lock is held. Cc: Kees Cook <keescook@chromium.org> Cc: James Morris <james.l.morris@oracle.com> Acked-by: Kees Cook <keescook@chromium.org> Acked-by: Serge Hallyn <serge.hallyn@canonical.com> Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com>
2012-08-03ptrace: mark __ptrace_may_access() staticTetsuo Handa
__ptrace_may_access() is used within only kernel/ptrace.c. Signed-off-by: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp> Signed-off-by: James Morris <james.l.morris@oracle.com>
2012-05-03userns: Convert ptrace, kill, set_priority permission checks to work with ↵Eric W. Biederman
kuids and kgids Update the permission checks to use the new uid_eq and gid_eq helpers and remove the now unnecessary user_ns equality comparison. Acked-by: Serge Hallyn <serge.hallyn@canonical.com> Signed-off-by: Eric W. Biederman <ebiederm@xmission.com>
2012-04-07userns: Use cred->user_ns instead of cred->user->user_nsEric W. Biederman
Optimize performance and prepare for the removal of the user_ns reference from user_struct. Remove the slow long walk through cred->user->user_ns and instead go straight to cred->user_ns. Acked-by: Serge Hallyn <serge.hallyn@canonical.com> Signed-off-by: Eric W. Biederman <ebiederm@xmission.com>
2012-03-23ptrace: remove PTRACE_SEIZE_DEVEL bitDenys Vlasenko
PTRACE_SEIZE code is tested and ready for production use, remove the code which requires special bit in data argument to make PTRACE_SEIZE work. Strace team prepares for a new release of strace, and we would like to ship the code which uses PTRACE_SEIZE, preferably after this change goes into released kernel. Signed-off-by: Denys Vlasenko <vda.linux@googlemail.com> Acked-by: Tejun Heo <tj@kernel.org> Acked-by: Oleg Nesterov <oleg@redhat.com> Cc: Pedro Alves <palves@redhat.com> Cc: Jan Kratochvil <jan.kratochvil@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-03-23ptrace: make PTRACE_SEIZE set ptrace options specified in 'data' parameterDenys Vlasenko
This can be used to close a few corner cases in strace where we get unwanted racy behavior after attach, but before we have a chance to set options (the notorious post-execve SIGTRAP comes to mind), and removes the need to track "did we set opts for this task" state in strace internals. While we are at it: Make it possible to extend SEIZE in the future with more functionality by passing non-zero 'addr' parameter. To that end, error out if 'addr' is non-zero. PTRACE_ATTACH did not (and still does not) have such check, and users (strace) do pass garbage there... let's avoid repeating this mistake with SEIZE. Set all task->ptrace bits in one operation - before this change, we were adding PT_SEIZED and PT_PTRACE_CAP with task->ptrace |= BIT ops. This was probably ok (not a bug), but let's be on a safer side. Changes since v2: use (unsigned long) casts instead of (long) ones, move PTRACE_SEIZE_DEVEL-related code to separate lines of code. Signed-off-by: Denys Vlasenko <vda.linux@googlemail.com> Acked-by: Tejun Heo <tj@kernel.org> Cc: Pedro Alves <palves@redhat.com> Reviewed-by: Oleg Nesterov <oleg@redhat.com> Cc: Jan Kratochvil <jan.kratochvil@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-03-23ptrace: simplify PTRACE_foo constants and PTRACE_SETOPTIONS codeDenys Vlasenko
Exchange PT_TRACESYSGOOD and PT_PTRACE_CAP bit positions, which makes PT_option bits contiguous and therefore makes code in ptrace_setoptions() much simpler. Every PTRACE_O_TRACEevent is defined to (1 << PTRACE_EVENT_event) instead of using explicit numeric constants, to ensure we don't mess up relationship between bit positions and event ids. PT_EVENT_FLAG_SHIFT was not particularly useful, PT_OPT_FLAG_SHIFT with value of PT_EVENT_FLAG_SHIFT-1 is easier to use. PT_TRACE_MASK constant is nuked, the only its use is replaced by (PTRACE_O_MASK << PT_OPT_FLAG_SHIFT). Signed-off-by: Denys Vlasenko <vda.linux@googlemail.com> Acked-by: Tejun Heo <tj@kernel.org> Reviewed-by: Oleg Nesterov <oleg@redhat.com> Cc: Pedro Alves <palves@redhat.com> Cc: Jan Kratochvil <jan.kratochvil@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-03-23ptrace: don't modify flags on PTRACE_SETOPTIONS failureDenys Vlasenko
On ptrace(PTRACE_SETOPTIONS, pid, 0, <opts>), we used to set those option bits which are known, and then fail with -EINVAL if there are some unknown bits in <opts>. This is inconsistent with typical error handling, which does not change any state if input is invalid. This patch changes PTRACE_SETOPTIONS behavior so that in this case, we return -EINVAL and don't change any bits in task->ptrace. It's very unlikely that there is userspace code in the wild which will be affected by this change: it should have the form ptrace(PTRACE_SETOPTIONS, pid, 0, PTRACE_O_BOGUSOPT) where PTRACE_O_BOGUSOPT is a constant unknown to the kernel. But kernel headers, naturally, don't contain any PTRACE_O_BOGUSOPTs, thus the only way userspace can use one if it defines one itself. I can't see why anyone would do such a thing deliberately. Signed-off-by: Denys Vlasenko <vda.linux@googlemail.com> Acked-by: Tejun Heo <tj@kernel.org> Reviewed-by: Oleg Nesterov <oleg@redhat.com> Cc: Pedro Alves <palves@redhat.com> Cc: Jan Kratochvil <jan.kratochvil@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-01-14Merge branch 'for-linus' of git://selinuxproject.org/~jmorris/linux-securityLinus Torvalds
* 'for-linus' of git://selinuxproject.org/~jmorris/linux-security: capabilities: remove __cap_full_set definition security: remove the security_netlink_recv hook as it is equivalent to capable() ptrace: do not audit capability check when outputing /proc/pid/stat capabilities: remove task_ns_* functions capabitlies: ns_capable can use the cap helpers rather than lsm call capabilities: style only - move capable below ns_capable capabilites: introduce new has_ns_capabilities_noaudit capabilities: call has_ns_capability from has_capability capabilities: remove all _real_ interfaces capabilities: introduce security_capable_noaudit capabilities: reverse arguments to security_capable capabilities: remove the task from capable LSM hook entirely selinux: sparse fix: fix several warnings in the security server cod selinux: sparse fix: fix warnings in netlink code selinux: sparse fix: eliminate warnings for selinuxfs selinux: sparse fix: declare selinux_disable() in security.h selinux: sparse fix: move selinux_complete_init selinux: sparse fix: make selinux_secmark_refcount static SELinux: Fix RCU deref check warning in sel_netport_insert() Manually fix up a semantic mis-merge wrt security_netlink_recv(): - the interface was removed in commit fd7784615248 ("security: remove the security_netlink_recv hook as it is equivalent to capable()") - a new user of it appeared in commit a38f7907b926 ("crypto: Add userspace configuration API") causing no automatic merge conflict, but Eric Paris pointed out the issue.
2012-01-05ptrace: do not audit capability check when outputing /proc/pid/statEric Paris
Reading /proc/pid/stat of another process checks if one has ptrace permissions on that process. If one does have permissions it outputs some data about the process which might have security and attack implications. If the current task does not have ptrace permissions the read still works, but those fields are filled with inocuous (0) values. Since this check and a subsequent denial is not a violation of the security policy we should not audit such denials. This can be quite useful to removing ptrace broadly across a system without flooding the logs when ps is run or something which harmlessly walks proc. Signed-off-by: Eric Paris <eparis@redhat.com> Acked-by: Serge E. Hallyn <serge.hallyn@canonical.com>
2012-01-05capabilities: remove task_ns_* functionsEric Paris
task_ in the front of a function, in the security subsystem anyway, means to me at least, that we are operating with that task as the subject of the security decision. In this case what it means is that we are using current as the subject but we use the task to get the right namespace. Who in the world would ever realize that's what task_ns_capability means just by the name? This patch eliminates the task_ns functions entirely and uses the has_ns_capability function instead. This means we explicitly open code the ns in question in the caller. I think it makes the caller a LOT more clear what is going on. Signed-off-by: Eric Paris <eparis@redhat.com> Acked-by: Serge E. Hallyn <serge.hallyn@canonical.com>
2012-01-04ptrace: ensure JOBCTL_STOP_SIGMASK is not zero after detachOleg Nesterov
This is the temporary simple fix for 3.2, we need more changes in this area. 1. do_signal_stop() assumes that the running untraced thread in the stopped thread group is not possible. This was our goal but it is not yet achieved: a stopped-but-resumed tracee can clone the running thread which can initiate another group-stop. Remove WARN_ON_ONCE(!current->ptrace). 2. A new thread always starts with ->jobctl = 0. If it is auto-attached and this group is stopped, __ptrace_unlink() sets JOBCTL_STOP_PENDING but JOBCTL_STOP_SIGMASK part is zero, this triggers WANR_ON(!signr) in do_jobctl_trap() if another debugger attaches. Change __ptrace_unlink() to set the artificial SIGSTOP for report. Alternatively we could change ptrace_init_task() to copy signr from current, but this means we can copy it for no reason and hide the possible similar problems. Acked-by: Tejun Heo <tj@kernel.org> Cc: <stable@kernel.org> [3.1] Signed-off-by: Oleg Nesterov <oleg@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-10-31kernel: Map most files to use export.h instead of module.hPaul Gortmaker
The changed files were only including linux/module.h for the EXPORT_SYMBOL infrastructure, and nothing else. Revector them onto the isolated export header for faster compile times. Nothing to see here but a whole lot of instances of: -#include <linux/module.h> +#include <linux/export.h> This commit is only changing the kernel dir; next targets will probably be mm, fs, the arch dirs, etc. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2011-09-25ptrace: PTRACE_LISTEN forgets to unlock ->siglockOleg Nesterov
If PTRACE_LISTEN fails after lock_task_sighand() it doesn't drop ->siglock. Reported-by: Matt Fleming <matt.fleming@intel.com> Signed-off-by: Oleg Nesterov <oleg@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-18connector: add an event for monitoring process tracersVladimir Zapolskiy
This change adds a procfs connector event, which is emitted on every successful process tracer attach or detach. If some process connects to other one, kernelspace connector reports process id and thread group id of both these involved processes. On disconnection null process id is returned. Such an event allows to create a simple automated userspace mechanism to be aware about processes connecting to others, therefore predefined process policies can be applied to them if needed. Note, a detach signal is emitted only in case, if a tracer process explicitly executes PTRACE_DETACH request. In other cases like tracee or tracer exit detach event from proc connector is not reported. Signed-off-by: Vladimir Zapolskiy <vzapolskiy@gmail.com> Acked-by: Evgeniy Polyakov <zbr@ioremap.net> Cc: David S. Miller <davem@davemloft.net> Signed-off-by: Oleg Nesterov <oleg@redhat.com>
2011-06-27do not change dead_task->exit_signalOleg Nesterov
__ptrace_detach() and do_notify_parent() set task->exit_signal = -1 to mark the task dead. This is no longer needed, nobody checks exit_signal to detect the EXIT_DEAD task. Signed-off-by: Oleg Nesterov <oleg@redhat.com> Reviewed-by: Tejun Heo <tj@kernel.org>
2011-06-27__ptrace_detach: avoid task_detached(), check do_notify_parent()Oleg Nesterov
__ptrace_detach() relies on the current obscure behaviour of do_notify_parent(tsk) which changes tsk->exit_signal if this child should be silently reaped. That is why we check task_detached(), it is true if the task is sub-thread, or it is the group_leader but its exit_signal was changed by do_notify_parent(). This is confusing, change the code to rely on !thread_group_leader() or the value returned by do_notify_parent(). Signed-off-by: Oleg Nesterov <oleg@redhat.com> Acked-by: Tejun Heo <tj@kernel.org>
2011-06-16ptrace: implement PTRACE_LISTENTejun Heo
The previous patch implemented async notification for ptrace but it only worked while trace is running. This patch introduces PTRACE_LISTEN which is suggested by Oleg Nestrov. It's allowed iff tracee is in STOP trap and puts tracee into quasi-running state - tracee never really runs but wait(2) and ptrace(2) consider it to be running. While ptracer is listening, tracee is allowed to re-enter STOP to notify an async event. Listening state is cleared on the first notification. Ptracer can also clear it by issuing INTERRUPT - tracee will re-trap into STOP with listening state cleared. This allows ptracer to monitor group stop state without running tracee - use INTERRUPT to put tracee into STOP trap, issue LISTEN and then wait(2) to wait for the next group stop event. When it happens, PTRACE_GETSIGINFO provides information to determine the current state. Test program follows. #define PTRACE_SEIZE 0x4206 #define PTRACE_INTERRUPT 0x4207 #define PTRACE_LISTEN 0x4208 #define PTRACE_SEIZE_DEVEL 0x80000000 static const struct timespec ts1s = { .tv_sec = 1 }; int main(int argc, char **argv) { pid_t tracee, tracer; int i; tracee = fork(); if (!tracee) while (1) pause(); tracer = fork(); if (!tracer) { siginfo_t si; ptrace(PTRACE_SEIZE, tracee, NULL, (void *)(unsigned long)PTRACE_SEIZE_DEVEL); ptrace(PTRACE_INTERRUPT, tracee, NULL, NULL); repeat: waitid(P_PID, tracee, NULL, WSTOPPED); ptrace(PTRACE_GETSIGINFO, tracee, NULL, &si); if (!si.si_code) { printf("tracer: SIG %d\n", si.si_signo); ptrace(PTRACE_CONT, tracee, NULL, (void *)(unsigned long)si.si_signo); goto repeat; } printf("tracer: stopped=%d signo=%d\n", si.si_signo != SIGTRAP, si.si_signo); if (si.si_signo != SIGTRAP) ptrace(PTRACE_LISTEN, tracee, NULL, NULL); else ptrace(PTRACE_CONT, tracee, NULL, NULL); goto repeat; } for (i = 0; i < 3; i++) { nanosleep(&ts1s, NULL); printf("mother: SIGSTOP\n"); kill(tracee, SIGSTOP); nanosleep(&ts1s, NULL); printf("mother: SIGCONT\n"); kill(tracee, SIGCONT); } nanosleep(&ts1s, NULL); kill(tracer, SIGKILL); kill(tracee, SIGKILL); return 0; } This is identical to the program to test TRAP_NOTIFY except that tracee is PTRACE_LISTEN'd instead of PTRACE_CONT'd when group stopped. This allows ptracer to monitor when group stop ends without running tracee. # ./test-listen tracer: stopped=0 signo=5 mother: SIGSTOP tracer: SIG 19 tracer: stopped=1 signo=19 mother: SIGCONT tracer: stopped=0 signo=5 tracer: SIG 18 mother: SIGSTOP tracer: SIG 19 tracer: stopped=1 signo=19 mother: SIGCONT tracer: stopped=0 signo=5 tracer: SIG 18 mother: SIGSTOP tracer: SIG 19 tracer: stopped=1 signo=19 mother: SIGCONT tracer: stopped=0 signo=5 tracer: SIG 18 -v2: Moved JOBCTL_LISTENING check in wait_task_stopped() into task_stopped_code() as suggested by Oleg. Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Oleg Nesterov <oleg@redhat.com>
2011-06-16ptrace: implement PTRACE_INTERRUPTTejun Heo
Currently, there's no way to trap a running ptracee short of sending a signal which has various side effects. This patch implements PTRACE_INTERRUPT which traps ptracee without any signal or job control related side effect. The implementation is almost trivial. It uses the group stop trap - SIGTRAP | PTRACE_EVENT_STOP << 8. A new trap flag JOBCTL_TRAP_INTERRUPT is added, which is set on PTRACE_INTERRUPT and cleared when any trap happens. As INTERRUPT should be useable regardless of the current state of tracee, task_is_traced() test in ptrace_check_attach() is skipped for INTERRUPT. PTRACE_INTERRUPT is available iff tracee is attached with PTRACE_SEIZE. Test program follows. #define PTRACE_SEIZE 0x4206 #define PTRACE_INTERRUPT 0x4207 #define PTRACE_SEIZE_DEVEL 0x80000000 static const struct timespec ts100ms = { .tv_nsec = 100000000 }; static const struct timespec ts1s = { .tv_sec = 1 }; static const struct timespec ts3s = { .tv_sec = 3 }; int main(int argc, char **argv) { pid_t tracee; tracee = fork(); if (tracee == 0) { nanosleep(&ts100ms, NULL); while (1) { printf("tracee: alive pid=%d\n", getpid()); nanosleep(&ts1s, NULL); } } if (argc > 1) kill(tracee, SIGSTOP); nanosleep(&ts100ms, NULL); ptrace(PTRACE_SEIZE, tracee, NULL, (void *)(unsigned long)PTRACE_SEIZE_DEVEL); if (argc > 1) { waitid(P_PID, tracee, NULL, WSTOPPED); ptrace(PTRACE_CONT, tracee, NULL, NULL); } nanosleep(&ts3s, NULL); printf("tracer: INTERRUPT and DETACH\n"); ptrace(PTRACE_INTERRUPT, tracee, NULL, NULL); waitid(P_PID, tracee, NULL, WSTOPPED); ptrace(PTRACE_DETACH, tracee, NULL, NULL); nanosleep(&ts3s, NULL); printf("tracer: exiting\n"); kill(tracee, SIGKILL); return 0; } When called without argument, tracee is seized from running state, interrupted and then detached back to running state. # ./test-interrupt tracee: alive pid=4546 tracee: alive pid=4546 tracee: alive pid=4546 tracer: INTERRUPT and DETACH tracee: alive pid=4546 tracee: alive pid=4546 tracee: alive pid=4546 tracer: exiting When called with argument, tracee is seized from stopped state, continued, interrupted and then detached back to stopped state. # ./test-interrupt 1 tracee: alive pid=4548 tracee: alive pid=4548 tracee: alive pid=4548 tracer: INTERRUPT and DETACH tracer: exiting Before PTRACE_INTERRUPT, once the tracee was running, there was no way to trap tracee and do PTRACE_DETACH without causing side effect. -v2: Updated to use task_set_jobctl_pending() so that it doesn't end up scheduling TRAP_STOP if child is dying which may make the child unkillable. Spotted by Oleg. Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Oleg Nesterov <oleg@redhat.com>
2011-06-16ptrace: implement PTRACE_SEIZETejun Heo
PTRACE_ATTACH implicitly issues SIGSTOP on attach which has side effects on tracee signal and job control states. This patch implements a new ptrace request PTRACE_SEIZE which attaches a tracee without trapping it or affecting its signal and job control states. The usage is the same with PTRACE_ATTACH but it takes PTRACE_SEIZE_* flags in @data. Currently, the only defined flag is PTRACE_SEIZE_DEVEL which is a temporary flag to enable PTRACE_SEIZE. PTRACE_SEIZE will change ptrace behaviors outside of attach itself. The changes will be implemented gradually and the DEVEL flag is to prevent programs which expect full SEIZE behavior from using it before all the behavior modifications are complete while allowing unit testing. The flag will be removed once SEIZE behaviors are completely implemented. * PTRACE_SEIZE, unlike ATTACH, doesn't force tracee to trap. After attaching tracee continues to run unless a trap condition occurs. * PTRACE_SEIZE doesn't affect signal or group stop state. * If PTRACE_SEIZE'd, group stop uses PTRACE_EVENT_STOP trap which uses exit_code of (signr | PTRACE_EVENT_STOP << 8) where signr is one of the stopping signals if group stop is in effect or SIGTRAP otherwise, and returns usual trap siginfo on PTRACE_GETSIGINFO instead of NULL. Seizing sets PT_SEIZED in ->ptrace of the tracee. This flag will be used to determine whether new SEIZE behaviors should be enabled. Test program follows. #define PTRACE_SEIZE 0x4206 #define PTRACE_SEIZE_DEVEL 0x80000000 static const struct timespec ts100ms = { .tv_nsec = 100000000 }; static const struct timespec ts1s = { .tv_sec = 1 }; static const struct timespec ts3s = { .tv_sec = 3 }; int main(int argc, char **argv) { pid_t tracee; tracee = fork(); if (tracee == 0) { nanosleep(&ts100ms, NULL); while (1) { printf("tracee: alive\n"); nanosleep(&ts1s, NULL); } } if (argc > 1) kill(tracee, SIGSTOP); nanosleep(&ts100ms, NULL); ptrace(PTRACE_SEIZE, tracee, NULL, (void *)(unsigned long)PTRACE_SEIZE_DEVEL); if (argc > 1) { waitid(P_PID, tracee, NULL, WSTOPPED); ptrace(PTRACE_CONT, tracee, NULL, NULL); } nanosleep(&ts3s, NULL); printf("tracer: exiting\n"); return 0; } When the above program is called w/o argument, tracee is seized while running and remains running. When tracer exits, tracee continues to run and print out messages. # ./test-seize-simple tracee: alive tracee: alive tracee: alive tracer: exiting tracee: alive tracee: alive When called with an argument, tracee is seized from stopped state and continued, and returns to stopped state when tracer exits. # ./test-seize tracee: alive tracee: alive tracee: alive tracer: exiting # ps -el|grep test-seize 1 T 0 4720 1 0 80 0 - 941 signal ttyS0 00:00:00 test-seize -v2: SEIZE doesn't schedule TRAP_STOP and leaves tracee running as Jan suggested. -v3: PTRACE_EVENT_STOP traps now report group stop state by signr. If group stop is in effect the stop signal number is returned as part of exit_code; otherwise, SIGTRAP. This was suggested by Denys and Oleg. Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Jan Kratochvil <jan.kratochvil@redhat.com> Cc: Denys Vlasenko <vda.linux@googlemail.com> Cc: Oleg Nesterov <oleg@redhat.com>
2011-06-16job control: introduce JOBCTL_TRAP_STOP and use it for group stop trapTejun Heo
do_signal_stop() implemented both normal group stop and trap for group stop while ptraced. This approach has been enough but scheduled changes require trap mechanism which can be used in more generic manner and using group stop trap for generic trap site simplifies both userland visible interface and implementation. This patch adds a new jobctl flag - JOBCTL_TRAP_STOP. When set, it triggers a trap site, which behaves like group stop trap, in get_signal_to_deliver() after checking for pending signals. While ptraced, do_signal_stop() doesn't stop itself. It initiates group stop if requested and schedules JOBCTL_TRAP_STOP and returns. The caller - get_signal_to_deliver() - is responsible for checking whether TRAP_STOP is pending afterwards and handling it. ptrace_attach() is updated to use JOBCTL_TRAP_STOP instead of JOBCTL_STOP_PENDING and __ptrace_unlink() to clear all pending trap bits and TRAPPING so that TRAP_STOP and future trap bits don't linger after detach. While at it, add proper function comment to do_signal_stop() and make it return bool. -v2: __ptrace_unlink() updated to clear JOBCTL_TRAP_MASK and TRAPPING instead of JOBCTL_PENDING_MASK. This avoids accidentally clearing JOBCTL_STOP_CONSUME. Spotted by Oleg. -v3: do_signal_stop() updated to return %false without dropping siglock while ptraced and TRAP_STOP check moved inside for(;;) loop after group stop participation. This avoids unnecessary relocking and also will help avoiding unnecessary traps by consuming group stop before handling pending traps. -v4: Jobctl trap handling moved into a separate function - do_jobctl_trap(). Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Oleg Nesterov <oleg@redhat.com>
2011-06-04ptrace: use bit_waitqueue for TRAPPING instead of wait_chldexitTejun Heo
ptracer->signal->wait_chldexit was used to wait for TRAPPING; however, ->wait_chldexit was already complicated with waker-side filtering without adding TRAPPING wait on top of it. Also, it unnecessarily made TRAPPING clearing depend on the current ptrace relationship - if the ptracee is detached, wakeup is lost. There is no reason to use signal->wait_chldexit here. We're just waiting for JOBCTL_TRAPPING bit to clear and given the relatively infrequent use of ptrace, bit_waitqueue can serve it perfectly. This patch makes JOBCTL_TRAPPING wait use bit_waitqueue instead of signal->wait_chldexit. -v2: Use JOBCTL_*_BIT macros instead of ilog2() as suggested by Linus. Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Oleg Nesterov <oleg@redhat.com>
2011-06-04job control: introduce task_set_jobctl_pending()Tejun Heo
task->jobctl currently hosts JOBCTL_STOP_PENDING and will host TRAP pending bits too. Setting pending conditions on a dying task may make the task unkillable. Currently, each setting site is responsible for checking for the condition but with to-be-added job control traps this becomes too fragile. This patch adds task_set_jobctl_pending() which should be used when setting task->jobctl bits to schedule a stop or trap. The function performs the followings to ease setting pending bits. * Sanity checks. * If fatal signal is pending or PF_EXITING is set, no bit is set. * STOP_SIGMASK is automatically cleared if new value is being set. do_signal_stop() and ptrace_attach() are updated to use task_set_jobctl_pending() instead of setting STOP_PENDING explicitly. The surrounding structures around setting are changed to fit task_set_jobctl_pending() better but there should be no userland visible behavior difference. Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Oleg Nesterov <oleg@redhat.com> Signed-off-by: Oleg Nesterov <oleg@redhat.com>
2011-06-04ptrace: ptrace_check_attach(): rename @kill to @ignore_state and add commentsTejun Heo
PTRACE_INTERRUPT is going to be added which should also skip task_is_traced() check in ptrace_check_attach(). Rename @kill to @ignore_state and make it bool. Add function comment while at it. This patch doesn't introduce any behavior difference. Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Oleg Nesterov <oleg@redhat.com>
2011-06-04job control: rename signal->group_stop and flags to jobctl and update themTejun Heo
signal->group_stop currently hosts mostly group stop related flags; however, it's gonna be used for wider purposes and the GROUP_STOP_ flag prefix becomes confusing. Rename signal->group_stop to signal->jobctl and rename all GROUP_STOP_* flags to JOBCTL_*. Bit position macros JOBCTL_*_BIT are defined and JOBCTL_* flags are defined in terms of them to allow using bitops later. While at it, reassign JOBCTL_TRAPPING to bit 22 to better accomodate future additions. This doesn't cause any functional change. -v2: JOBCTL_*_BIT macros added as suggested by Linus. Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Oleg Nesterov <oleg@redhat.com>
2011-06-04ptrace: remove silly wait_trap variable from ptrace_attach()Tejun Heo
Remove local variable wait_trap which determines whether to wait for !TRAPPING or not and simply wait for it if attach was successful. -v2: Oleg pointed out wait should happen iff attach was successful. Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Oleg Nesterov <oleg@redhat.com> Signed-off-by: Oleg Nesterov <oleg@redhat.com>
2011-05-25ptrace: ptrace_resume() shouldn't wake up !TASK_TRACED threadOleg Nesterov
It is not clear why ptrace_resume() does wake_up_process(). Unless the caller is PTRACE_KILL the tracee should be TASK_TRACED so we can use wake_up_state(__TASK_TRACED). If sys_ptrace() races with SIGKILL we do not need the extra and potentionally spurious wakeup. If the caller is PTRACE_KILL, wake_up_process() is even more wrong. The tracee can sleep in any state in any place, and if we have a buggy code which doesn't handle a spurious wakeup correctly PTRACE_KILL can be used to exploit it. For example: int main(void) { int child, status; child = fork(); if (!child) { int ret; assert(ptrace(PTRACE_TRACEME, 0,0,0) == 0); ret = pause(); printf("pause: %d %m\n", ret); return 0x23; } sleep(1); assert(ptrace(PTRACE_KILL, child, 0,0) == 0); assert(child == wait(&status)); printf("wait: %x\n", status); return 0; } prints "pause: -1 Unknown error 514", -ERESTARTNOHAND leaks to the userland. In this case sys_pause() is buggy as well and should be fixed. I do not know what was the original rationality behind PTRACE_KILL. The man page is simply wrong and afaics it was always wrong. Imho it should be deprecated, or may be it should do send_sig(SIGKILL) as Denys suggests, but in any case I do not think that the current behaviour was intentional. Note: there is another problem, ptrace_resume() changes ->exit_code and this can race with SIGKILL too. Eventually we should change ptrace to not use ->exit_code. Signed-off-by: Oleg Nesterov <oleg@redhat.com>
2011-05-20Merge branch 'ptrace' of git://git.kernel.org/pub/scm/linux/kernel/git/oleg/miscLinus Torvalds
* 'ptrace' of git://git.kernel.org/pub/scm/linux/kernel/git/oleg/misc: (41 commits) signal: trivial, fix the "timespec declared inside parameter list" warning job control: reorganize wait_task_stopped() ptrace: fix signal->wait_chldexit usage in task_clear_group_stop_trapping() signal: sys_sigprocmask() needs retarget_shared_pending() signal: cleanup sys_sigprocmask() signal: rename signandsets() to sigandnsets() signal: do_sigtimedwait() needs retarget_shared_pending() signal: introduce do_sigtimedwait() to factor out compat/native code signal: sys_rt_sigtimedwait: simplify the timeout logic signal: cleanup sys_rt_sigprocmask() x86: signal: sys_rt_sigreturn() should use set_current_blocked() x86: signal: handle_signal() should use set_current_blocked() signal: sigprocmask() should do retarget_shared_pending() signal: sigprocmask: narrow the scope of ->siglock signal: retarget_shared_pending: optimize while_each_thread() loop signal: retarget_shared_pending: consider shared/unblocked signals only signal: introduce retarget_shared_pending() ptrace: ptrace_check_attach() should not do s/STOPPED/TRACED/ signal: Turn SIGNAL_STOP_DEQUEUED into GROUP_STOP_DEQUEUED signal: do_signal_stop: Remove the unneeded task_clear_group_stop_pending() ...
2011-04-25ptrace: Prepare to fix racy accesses on task breakpointsFrederic Weisbecker
When a task is traced and is in a stopped state, the tracer may execute a ptrace request to examine the tracee state and get its task struct. Right after, the tracee can be killed and thus its breakpoints released. This can happen concurrently when the tracer is in the middle of reading or modifying these breakpoints, leading to dereferencing a freed pointer. Hence, to prepare the fix, create a generic breakpoint reference holding API. When a reference on the breakpoints of a task is held, the breakpoints won't be released until the last reference is dropped. After that, no more ptrace request on the task's breakpoints can be serviced for the tracer. Reported-by: Oleg Nesterov <oleg@redhat.com> Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Will Deacon <will.deacon@arm.com> Cc: Prasad <prasad@linux.vnet.ibm.com> Cc: Paul Mundt <lethal@linux-sh.org> Cc: v2.6.33.. <stable@kernel.org> Link: http://lkml.kernel.org/r/1302284067-7860-2-git-send-email-fweisbec@gmail.com
2011-04-07Merge branch 'ptrace' of ↵Oleg Nesterov
git://git.kernel.org/pub/scm/linux/kernel/git/tj/misc into ptrace
2011-04-04ptrace: ptrace_check_attach() should not do s/STOPPED/TRACED/Oleg Nesterov
After "ptrace: Clean transitions between TASK_STOPPED and TRACED" d79fdd6d96f46fabb779d86332e3677c6f5c2a4f, ptrace_check_attach() should never see a TASK_STOPPED tracee and s/STOPPED/TRACED/ is no longer legal. Add the warning. Note: ptrace_check_attach() can be greatly simplified, in particular it doesn't need tasklist. But I'd prefer another patch for that. Signed-off-by: Oleg Nesterov <oleg@redhat.com> Signed-off-by: Tejun Heo <tj@kernel.org>
2011-03-23userns: allow ptrace from non-init user namespacesSerge E. Hallyn
ptrace is allowed to tasks in the same user namespace according to the usual rules (i.e. the same rules as for two tasks in the init user namespace). ptrace is also allowed to a user namespace to which the current task the has CAP_SYS_PTRACE capability. Changelog: Dec 31: Address feedback by Eric: . Correct ptrace uid check . Rename may_ptrace_ns to ptrace_capable . Also fix the cap_ptrace checks. Jan 1: Use const cred struct Jan 11: use task_ns_capable() in place of ptrace_capable(). Feb 23: same_or_ancestore_user_ns() was not an appropriate check to constrain cap_issubset. Rather, cap_issubset() only is meaningful when both capsets are in the same user_ns. Signed-off-by: Serge E. Hallyn <serge.hallyn@canonical.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Acked-by: Daniel Lezcano <daniel.lezcano@free.fr> Acked-by: David Howells <dhowells@redhat.com> Cc: James Morris <jmorris@namei.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-23ptrace: Always put ptracee into appropriate execution stateTejun Heo
Currently, __ptrace_unlink() wakes up the tracee iff it's in TASK_TRACED. For unlinking from PTRACE_DETACH, this is correct as the tracee is guaranteed to be in TASK_TRACED or dead; however, unlinking also happens when the ptracer exits and in this case the ptracee can be in any state and ptrace might be left running even if the group it belongs to is stopped. This patch updates __ptrace_unlink() such that GROUP_STOP_PENDING is reinstated regardless of the ptracee's current state as long as it's alive and makes sure that signal_wake_up() is called if execution state transition is necessary. Test case follows. #include <unistd.h> #include <time.h> #include <sys/types.h> #include <sys/ptrace.h> #include <sys/wait.h> static const struct timespec ts1s = { .tv_sec = 1 }; int main(void) { pid_t tracee; siginfo_t si; tracee = fork(); if (tracee == 0) { while (1) { nanosleep(&ts1s, NULL); write(1, ".", 1); } } ptrace(PTRACE_ATTACH, tracee, NULL, NULL); waitid(P_PID, tracee, &si, WSTOPPED); ptrace(PTRACE_CONT, tracee, NULL, (void *)(long)si.si_status); waitid(P_PID, tracee, &si, WSTOPPED); ptrace(PTRACE_CONT, tracee, NULL, (void *)(long)si.si_status); write(1, "exiting", 7); return 0; } Before the patch, after the parent process exits, the child is left running and prints out "." every second. exiting..... (continues) After the patch, the group stop initiated by the implied SIGSTOP from PTRACE_ATTACH is re-established when the parent exits. exiting Signed-off-by: Tejun Heo <tj@kernel.org> Reported-by: Oleg Nesterov <oleg@redhat.com> Acked-by: Oleg Nesterov <oleg@redhat.com>
2011-03-23ptrace: Collapse ptrace_untrace() into __ptrace_unlink()Tejun Heo
Remove the extra task_is_traced() check in __ptrace_unlink() and collapse ptrace_untrace() into __ptrace_unlink(). This is to prepare for further changes. While at it, drop the comment on top of ptrace_untrace() and convert __ptrace_unlink() comment to docbook format. Detailed comment will be added by the next patch. This patch doesn't cause any visible behavior changes. Signed-off-by: Tejun Heo <tj@kernel.org> Acked-by: Oleg Nesterov <oleg@redhat.com>
2011-03-23ptrace: Clean transitions between TASK_STOPPED and TRACEDTejun Heo
Currently, if the task is STOPPED on ptrace attach, it's left alone and the state is silently changed to TRACED on the next ptrace call. The behavior breaks the assumption that arch_ptrace_stop() is called before any task is poked by ptrace and is ugly in that a task manipulates the state of another task directly. With GROUP_STOP_PENDING, the transitions between TASK_STOPPED and TRACED can be made clean. The tracer can use the flag to tell the tracee to retry stop on attach and detach. On retry, the tracee will enter the desired state in the correct way. The lower 16bits of task->group_stop is used to remember the signal number which caused the last group stop. This is used while retrying for ptrace attach as the original group_exit_code could have been consumed with wait(2) by then. As the real parent may wait(2) and consume the group_exit_code anytime, the group_exit_code needs to be saved separately so that it can be used when switching from regular sleep to ptrace_stop(). This is recorded in the lower 16bits of task->group_stop. If a task is already stopped and there's no intervening SIGCONT, a ptrace request immediately following a successful PTRACE_ATTACH should always succeed even if the tracer doesn't wait(2) for attach completion; however, with this change, the tracee might still be TASK_RUNNING trying to enter TASK_TRACED which would cause the following request to fail with -ESRCH. This intermediate state is hidden from the ptracer by setting GROUP_STOP_TRAPPING on attach and making ptrace_check_attach() wait for it to clear on its signal->wait_chldexit. Completing the transition or getting killed clears TRAPPING and wakes up the tracer. Note that the STOPPED -> RUNNING -> TRACED transition is still visible to other threads which are in the same group as the ptracer and the reverse transition is visible to all. Please read the comments for details. Oleg: * Spotted a race condition where a task may retry group stop without proper bookkeeping. Fixed by redoing bookkeeping on retry. * Spotted that the transition is visible to userland in several different ways. Most are fixed with GROUP_STOP_TRAPPING. Unhandled corner case is documented. * Pointed out not setting GROUP_STOP_SIGMASK on an already stopped task would result in more consistent behavior. * Pointed out that calling ptrace_stop() from do_signal_stop() in TASK_STOPPED can race with group stop start logic and then confuse the TRAPPING wait in ptrace_check_attach(). ptrace_stop() is now called with TASK_RUNNING. * Suggested using signal->wait_chldexit instead of bit wait. * Spotted a race condition between TRACED transition and clearing of TRAPPING. Signed-off-by: Tejun Heo <tj@kernel.org> Acked-by: Oleg Nesterov <oleg@redhat.com> Cc: Roland McGrath <roland@redhat.com> Cc: Jan Kratochvil <jan.kratochvil@redhat.com>
2011-03-23ptrace: Remove the extra wake_up_state() from ptrace_detach()Tejun Heo
This wake_up_state() has a turbulent history. This is a remnant from ancient ptrace implementation and patently wrong. Commit 95a3540d (ptrace_detach: the wrong wakeup breaks the ERESTARTxxx logic) removed it but the change was reverted later by commit edaba2c5 (ptrace: revert "ptrace_detach: the wrong wakeup breaks the ERESTARTxxx logic") citing compatibility breakage and general brokeness of the whole group stop / ptrace interaction. Then, recently, it got converted from wake_up_process() to wake_up_state() to make it less dangerous. Digging through the mailing archives, the compatibility breakage doesn't seem to be critical in the sense that the behavior isn't well defined or reliable to begin with and it seems to have been agreed to remove the wakeup with proper cleanup of the whole thing. Now that the group stop and its interaction with ptrace are being cleaned up, it's high time to finally kill this silliness. Signed-off-by: Tejun Heo <tj@kernel.org> Acked-by: Oleg Nesterov <oleg@redhat.com> Cc: Roland McGrath <roland@redhat.com>
2011-03-04Mark ptrace_{traceme,attach,detach} staticLinus Torvalds
They are only used inside kernel/ptrace.c, and have been for a long time. We don't want to go back to the bad-old-days when architectures did things on their own, so make them static and private. Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-02-11ptrace: use safer wake up on ptrace_detach()Tejun Heo
The wake_up_process() call in ptrace_detach() is spurious and not interlocked with the tracee state. IOW, the tracee could be running or sleeping in any place in the kernel by the time wake_up_process() is called. This can lead to the tracee waking up unexpectedly which can be dangerous. The wake_up is spurious and should be removed but for now reduce its toxicity by only waking up if the tracee is in TRACED or STOPPED state. This bug can possibly be used as an attack vector. I don't think it will take too much effort to come up with an attack which triggers oops somewhere. Most sleeps are wrapped in condition test loops and should be safe but we have quite a number of places where sleep and wakeup conditions are expected to be interlocked. Although the window of opportunity is tiny, ptrace can be used by non-privileged users and with some loading the window can definitely be extended and exploited. Signed-off-by: Tejun Heo <tj@kernel.org> Acked-by: Roland McGrath <roland@redhat.com> Acked-by: Oleg Nesterov <oleg@redhat.com> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-27signals: move cred_guard_mutex from task_struct to signal_structKOSAKI Motohiro
Oleg Nesterov pointed out we have to prevent multiple-threads-inside-exec itself and we can reuse ->cred_guard_mutex for it. Yes, concurrent execve() has no worth. Let's move ->cred_guard_mutex from task_struct to signal_struct. It naturally prevent multiple-threads-inside-exec. Signed-off-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Reviewed-by: Oleg Nesterov <oleg@redhat.com> Acked-by: Roland McGrath <roland@redhat.com> Acked-by: David Howells <dhowells@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-27ptrace: cleanup ptrace_request()Namhyung Kim
Use new 'datavp' and 'datalp' variables to remove unnecesary castings. Signed-off-by: Namhyung Kim <namhyung@gmail.com> Acked-by: Roland McGrath <roland@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-27ptrace: change signature of sys_ptrace() and friendsNamhyung Kim
Since userspace API of ptrace syscall defines @addr and @data as void pointers, it would be more appropriate to define them as unsigned long in kernel. Therefore related functions are changed also. 'unsigned long' is typically used in other places in kernel as an opaque data type and that using this helps cleaning up a lot of warnings from sparse. Suggested-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Namhyung Kim <namhyung@gmail.com> Acked-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Roland McGrath <roland@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
