path: root/kernel/rcu/tree.c
2013-11-16Merge tag 'trace-3.13' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-trace Pull tracing update from Steven Rostedt: "This batch of changes is mostly clean ups and small bug fixes. The only real feature that was added this release is from Namhyung Kim, who introduced "set_graph_notrace" filter that lets you run the function graph tracer and not trace particular functions and their call chain. Tom Zanussi added some updates to the ftrace multibuffer tracing that made it more consistent with the top level tracing. One of the fixes for perf function tracing required an API change in RCU; the addition of "rcu_is_watching()". As Paul McKenney is pushing that change in this release too, he gave me a branch that included all the changes to get that working, and I pulled that into my tree in order to complete the perf function tracing fix" * tag 'trace-3.13' of git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-trace: tracing: Add rcu annotation for syscall trace descriptors tracing: Do not use signed enums with unsigned long long in fgragh output tracing: Remove unused function ftrace_off_permanent() tracing: Do not assign filp->private_data to freed memory tracing: Add helper function tracing_is_disabled() tracing: Open tracer when ftrace_dump_on_oops is used tracing: Add support for SOFT_DISABLE to syscall events tracing: Make register/unregister_ftrace_command __init tracing: Update event filters for multibuffer recordmcount.pl: Add support for __fentry__ ftrace: Have control op function callback only trace when RCU is watching rcu: Do not trace rcu_is_watching() functions ftrace/x86: skip over the breakpoint for ftrace caller trace/trace_stat: use rbtree postorder iteration helper instead of opencoding ftrace: Add set_graph_notrace filter ftrace: Narrow down the protected area of graph_lock ftrace: Introduce struct ftrace_graph_data ftrace: Get rid of ftrace_graph_filter_enabled tracing: Fix potential out-of-bounds in trace_get_user() tracing: Show more exact help information about snapshot
2013-11-12Merge branch 'sched-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull scheduler changes from Ingo Molnar: "The main changes in this cycle are: - (much) improved CONFIG_NUMA_BALANCING support from Mel Gorman, Rik van Riel, Peter Zijlstra et al. Yay! - optimize preemption counter handling: merge the NEED_RESCHED flag into the preempt_count variable, by Peter Zijlstra. - wait.h fixes and code reorganization from Peter Zijlstra - cfs_bandwidth fixes from Ben Segall - SMP load-balancer cleanups from Peter Zijstra - idle balancer improvements from Jason Low - other fixes and cleanups" * 'sched-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (129 commits) ftrace, sched: Add TRACE_FLAG_PREEMPT_RESCHED stop_machine: Fix race between stop_two_cpus() and stop_cpus() sched: Remove unnecessary iteration over sched domains to update nr_busy_cpus sched: Fix asymmetric scheduling for POWER7 sched: Move completion code from core.c to completion.c sched: Move wait code from core.c to wait.c sched: Move wait.c into kernel/sched/ sched/wait: Fix __wait_event_interruptible_lock_irq_timeout() sched: Avoid throttle_cfs_rq() racing with period_timer stopping sched: Guarantee new group-entities always have weight sched: Fix hrtimer_cancel()/rq->lock deadlock sched: Fix cfs_bandwidth misuse of hrtimer_expires_remaining sched: Fix race on toggling cfs_bandwidth_used sched: Remove extra put_online_cpus() inside sched_setaffinity() sched/rt: Fix task_tick_rt() comment sched/wait: Fix build breakage sched/wait: Introduce prepare_to_wait_event() sched/wait: Add ___wait_cond_timeout() to wait_event*_timeout() too sched: Remove get_online_cpus() usage sched: Fix race in migrate_swap_stop() ...
2013-10-15rcu: Move RCU-related source code to kernel/rcu directoryPaul E. McKenney
Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Reviewed-by: Ingo Molnar <mingo@kernel.org>
