path: root/kernel/rcupdate.c
2010-10-07Merge branch 'rcu/urgent' of ↵Ingo Molnar
git://git.kernel.org/pub/scm/linux/kernel/git/paulmck/linux-2.6-rcu into core/rcu
2010-10-05rcu: move check from rcu_dereference_bh to rcu_read_lock_bh_heldPaul E. McKenney
As suggested by Linus, push the irqs_disabled() down to the rcu_read_lock_bh_held() level so that all callers get the benefit of the correct check. Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com>
2010-08-19rcu: define __rcu address space modifier for sparsePaul E. McKenney
This commit provides definitions for the __rcu annotation defined earlier. This annotation permits sparse to check for correct use of RCU-protected pointers. If a pointer that is annotated with __rcu is accessed directly (as opposed to via rcu_dereference(), rcu_assign_pointer(), or one of their variants), sparse can be made to complain. To enable such complaints, use the new default-disabled CONFIG_SPARSE_RCU_POINTER kernel configuration option. Please note that these sparse complaints are intended to be a debugging aid, -not- a code-style-enforcement mechanism. There are special rcu_dereference_protected() and rcu_access_pointer() accessors for use when RCU read-side protection is not required, for example, when no other CPU has access to the data structure in question or while the current CPU hold the update-side lock. This patch also updates a number of docbook comments that were showing their age. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: Christopher Li <sparse@chrisli.org> Reviewed-by: Josh Triplett <josh@joshtriplett.org>
2010-06-14tree/tiny rcu: Add debug RCU head objectsMathieu Desnoyers
Helps finding racy users of call_rcu(), which results in hangs because list entries are overwritten and/or skipped. Changelog since v4: - Bissectability is now OK - Now generate a WARN_ON_ONCE() for non-initialized rcu_head passed to call_rcu(). Statically initialized objects are detected with object_is_static(). - Rename rcu_head_init_on_stack to init_rcu_head_on_stack. - Remove init_rcu_head() completely. Changelog since v3: - Include comments from Lai Jiangshan This new patch version is based on the debugobjects with the newly introduced "active state" tracker. Non-initialized entries are all considered as "statically initialized". An activation fixup (triggered by call_rcu()) takes care of performing the debug object initialization without issuing any warning. Since we cannot increase the size of struct rcu_head, I don't see much room to put an identifier for statically initialized rcu_head structures. So for now, we have to live without "activation without explicit init" detection. But the main purpose of this debug option is to detect double-activations (double call_rcu() use of a rcu_head before the callback is executed), which is correctly addressed here. This also detects potential internal RCU callback corruption, which would cause the callbacks to be executed twice. Signed-off-by: Mathieu Desnoyers <mathieu.desnoyers@efficios.com> CC: David S. Miller <davem@davemloft.net> CC: "Paul E. McKenney" <paulmck@linux.vnet.ibm.com> CC: akpm@linux-foundation.org CC: mingo@elte.hu CC: laijs@cn.fujitsu.com CC: dipankar@in.ibm.com CC: josh@joshtriplett.org CC: dvhltc@us.ibm.com CC: niv@us.ibm.com CC: tglx@linutronix.de CC: peterz@infradead.org CC: rostedt@goodmis.org CC: Valdis.Kletnieks@vt.edu CC: dhowells@redhat.com CC: eric.dumazet@gmail.com CC: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Reviewed-by: Lai Jiangshan <laijs@cn.fujitsu.com>
2010-05-10rcu: slim down rcutiny by removing rcu_scheduler_active and friendsPaul E. McKenney
TINY_RCU does not need rcu_scheduler_active unless CONFIG_DEBUG_LOCK_ALLOC. So conditionally compile rcu_scheduler_active in order to slim down rcutiny a bit more. Also gets rid of an EXPORT_SYMBOL_GPL, which is responsible for most of the slimming. Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com>
2010-05-06rcu: create rcu_my_thread_group_empty() wrapperPaul E. McKenney
Some RCU-lockdep splat repairs need to know whether they are running in a single-threaded process. Unfortunately, the thread_group_empty() primitive is defined in sched.h, and can induce #include hell. This commit therefore introduces a rcu_my_thread_group_empty() wrapper that is defined in rcupdate.c, thus avoiding the need to include sched.h everywhere. Signed-off-by: "Paul E. McKenney" <paulmck@linux.vnet.ibm.com>
2010-04-19rcu: Make RCU lockdep check the lockdep_recursion variablePaul E. McKenney
The lockdep facility temporarily disables lockdep checking by incrementing the current->lockdep_recursion variable. Such disabling happens in NMIs and in other situations where lockdep might expect to recurse on itself. This patch therefore checks current->lockdep_recursion, disabling RCU lockdep splats when this variable is non-zero. In addition, this patch removes the "likely()", as suggested by Lai Jiangshan. Reported-by: Frederic Weisbecker <fweisbec@gmail.com> Reported-by: David Miller <davem@davemloft.net> Tested-by: Frederic Weisbecker <fweisbec@gmail.com> Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: laijs@cn.fujitsu.com Cc: dipankar@in.ibm.com Cc: mathieu.desnoyers@polymtl.ca Cc: josh@joshtriplett.org Cc: dvhltc@us.ibm.com Cc: niv@us.ibm.com Cc: peterz@infradead.org Cc: rostedt@goodmis.org Cc: Valdis.Kletnieks@vt.edu Cc: dhowells@redhat.com Cc: eric.dumazet@gmail.com LKML-Reference: <20100415195039.GA22623@linux.vnet.ibm.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-03-16rcu: Make rcu_read_lock_bh_held() allow for disabled BHPaul E. McKenney
Disabling BH can stand in for rcu_read_lock_bh(), and this patch updates rcu_read_lock_bh_held() to allow for this. In order to avoid include-file hell, this function is moved out of line to kernel/rcupdate.c. This fixes a false positive RCU warning. Reported-by: Arnd Bergmann <arnd@arndb.de> Reported-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Acked-by: Lai Jiangshan <laijs@cn.fujitsu.com> Cc: dipankar@in.ibm.com Cc: mathieu.desnoyers@polymtl.ca Cc: josh@joshtriplett.org Cc: dvhltc@us.ibm.com Cc: niv@us.ibm.com Cc: peterz@infradead.org Cc: rostedt@goodmis.org Cc: Valdis.Kletnieks@vt.edu Cc: dhowells@redhat.com LKML-Reference: <20100316000343.GA25857@linux.vnet.ibm.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-02-26rcu: Export rcu_scheduler_activePaul E. McKenney
Kernel modules using rcu_read_lock_sched_held() must now have access to rcu_scheduler_active, so it must be exported. This should fix the fix for the boot-time RCU-lockdep splat. Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: laijs@cn.fujitsu.com Cc: dipankar@in.ibm.com Cc: mathieu.desnoyers@polymtl.ca Cc: josh@joshtriplett.org Cc: dvhltc@us.ibm.com Cc: niv@us.ibm.com Cc: peterz@infradead.org Cc: rostedt@goodmis.org Cc: Valdis.Kletnieks@vt.edu Cc: dhowells@redhat.com LKML-Reference: <20100226030230.GA7743@linux.vnet.ibm.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-02-26rcu: Make rcu_read_lock_sched_held() take boot time into accountPaul E. McKenney
Before the scheduler starts, all tasks are non-preemptible by definition. So, during that time, rcu_read_lock_sched_held() needs to always return "true". This patch makes that be so. Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: laijs@cn.fujitsu.com Cc: dipankar@in.ibm.com Cc: mathieu.desnoyers@polymtl.ca Cc: josh@joshtriplett.org Cc: dvhltc@us.ibm.com Cc: niv@us.ibm.com Cc: peterz@infradead.org Cc: rostedt@goodmis.org Cc: Valdis.Kletnieks@vt.edu Cc: dhowells@redhat.com LKML-Reference: <1267135607-7056-2-git-send-email-paulmck@linux.vnet.ibm.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-02-25rcu: Introduce lockdep-based checking to RCU read-side primitivesPaul E. McKenney
Inspection is proving insufficient to catch all RCU misuses, which is understandable given that rcu_dereference() might be protected by any of four different flavors of RCU (RCU, RCU-bh, RCU-sched, and SRCU), and might also/instead be protected by any of a number of locking primitives. It is therefore time to enlist the aid of lockdep. This set of patches is inspired by earlier work by Peter Zijlstra and Thomas Gleixner, and takes the following approach: o Set up separate lockdep classes for RCU, RCU-bh, and RCU-sched. o Set up separate lockdep classes for each instance of SRCU. o Create primitives that check for being in an RCU read-side critical section. These return exact answers if lockdep is fully enabled, but if unsure, report being in an RCU read-side critical section. (We want to avoid false positives!) The primitives are: For RCU: rcu_read_lock_held(void) For RCU-bh: rcu_read_lock_bh_held(void) For RCU-sched: rcu_read_lock_sched_held(void) For SRCU: srcu_read_lock_held(struct srcu_struct *sp) o Add rcu_dereference_check(), which takes a second argument in which one places a boolean expression based on the above primitives and/or lockdep_is_held(). o A new kernel configuration parameter, CONFIG_PROVE_RCU, enables rcu_dereference_check(). This depends on CONFIG_PROVE_LOCKING, and should be quite helpful during the transition period while CONFIG_PROVE_RCU-unaware patches are in flight. The existing rcu_dereference() primitive does no checking, but upcoming patches will change that. Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: laijs@cn.fujitsu.com Cc: dipankar@in.ibm.com Cc: mathieu.desnoyers@polymtl.ca Cc: josh@joshtriplett.org Cc: dvhltc@us.ibm.com Cc: niv@us.ibm.com Cc: peterz@infradead.org Cc: rostedt@goodmis.org Cc: Valdis.Kletnieks@vt.edu Cc: dhowells@redhat.com LKML-Reference: <1266887105-1528-1-git-send-email-paulmck@linux.vnet.ibm.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-11-22rcu: Re-arrange code to reduce #ifdef painPaul E. McKenney
Remove #ifdefs from kernel/rcupdate.c and include/linux/rcupdate.h by moving code to include/linux/rcutiny.h, include/linux/rcutree.h, and kernel/rcutree.c. Also remove some definitions that are no longer used. Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: laijs@cn.fujitsu.com Cc: dipankar@in.ibm.com Cc: mathieu.desnoyers@polymtl.ca Cc: josh@joshtriplett.org Cc: dvhltc@us.ibm.com Cc: niv@us.ibm.com Cc: peterz@infradead.org Cc: rostedt@goodmis.org Cc: Valdis.Kletnieks@vt.edu Cc: dhowells@redhat.com LKML-Reference: <1258908830885-git-send-email-> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-11-22rcu: Eliminate unneeded function wrappingPaul E. McKenney
The functions rcu_init() is a wrapper for __rcu_init(), and also sets up the CPU-hotplug notifier for rcu_barrier_cpu_hotplug(). But TINY_RCU doesn't need CPU-hotplug notification, and the rcu_barrier_cpu_hotplug() is a simple wrapper for rcu_cpu_notify(). So push rcu_init() out to kernel/rcutree.c and kernel/rcutiny.c and get rid of the wrapper function rcu_barrier_cpu_hotplug(). Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: laijs@cn.fujitsu.com Cc: dipankar@in.ibm.com Cc: mathieu.desnoyers@polymtl.ca Cc: josh@joshtriplett.org Cc: dvhltc@us.ibm.com Cc: niv@us.ibm.com Cc: peterz@infradead.org Cc: rostedt@goodmis.org Cc: Valdis.Kletnieks@vt.edu Cc: dhowells@redhat.com LKML-Reference: <12589088302320-git-send-email-> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-10-26rcu: "Tiny RCU", The Bloatwatch EditionPaul E. McKenney
This patch is a version of RCU designed for !SMP provided for a small-footprint RCU implementation. In particular, the implementation of synchronize_rcu() is extremely lightweight and high performance. It passes rcutorture testing in each of the four relevant configurations (combinations of NO_HZ and PREEMPT) on x86. This saves about 1K bytes compared to old Classic RCU (which is no longer in mainline), and more than three kilobytes compared to Hierarchical RCU (updated to 2.6.30): CONFIG_TREE_RCU: text data bss dec filename 183 4 0 187 kernel/rcupdate.o 2783 520 36 3339 kernel/rcutree.o 3526 Total (vs 4565 for v7) CONFIG_TREE_PREEMPT_RCU: text data bss dec filename 263 4 0 267 kernel/rcupdate.o 4594 776 52 5422 kernel/rcutree.o 5689 Total (6155 for v7) CONFIG_TINY_RCU: text data bss dec filename 96 4 0 100 kernel/rcupdate.o 734 24 0 758 kernel/rcutiny.o 858 Total (vs 848 for v7) The above is for x86. Your mileage may vary on other platforms. Further compression is possible, but is being procrastinated. Changes from v7 (http://lkml.org/lkml/2009/10/9/388) o Apply Lai Jiangshan's review comments (aside from might_sleep() in synchronize_sched(), which is covered by SMP builds). o Fix up expedited primitives. Changes from v6 (http://lkml.org/lkml/2009/9/23/293). o Forward ported to put it into the 2.6.33 stream. o Added lockdep support. o Make lightweight rcu_barrier. Changes from v5 (http://lkml.org/lkml/2009/6/23/12). o Ported to latest pre-2.6.32 merge window kernel. - Renamed rcu_qsctr_inc() to rcu_sched_qs(). - Renamed rcu_bh_qsctr_inc() to rcu_bh_qs(). - Provided trivial rcu_cpu_notify(). - Provided trivial exit_rcu(). - Provided trivial rcu_needs_cpu(). - Fixed up the rcu_*_enter/exit() functions in linux/hardirq.h. o Removed the dependence on EMBEDDED, with a view to making TINY_RCU default for !SMP at some time in the future. o Added (trivial) support for expedited grace periods. Changes from v4 (http://lkml.org/lkml/2009/5/2/91) include: o Squeeze the size down a bit further by removing the ->completed field from struct rcu_ctrlblk. o This permits synchronize_rcu() to become the empty function. Previous concerns about rcutorture were unfounded, as rcutorture correctly handles a constant value from rcu_batches_completed() and rcu_batches_completed_bh(). Changes from v3 (http://lkml.org/lkml/2009/3/29/221) include: o Changed rcu_batches_completed(), rcu_batches_completed_bh() rcu_enter_nohz(), rcu_exit_nohz(), rcu_nmi_enter(), and rcu_nmi_exit(), to be static inlines, as suggested by David Howells. Doing this saves about 100 bytes from rcutiny.o. (The numbers between v3 and this v4 of the patch are not directly comparable, since they are against different versions of Linux.) Changes from v2 (http://lkml.org/lkml/2009/2/3/333) include: o Fix whitespace issues. o Change short-circuit "||" operator to instead be "+" in order to fix performance bug noted by "kraai" on LWN. (http://lwn.net/Articles/324348/) Changes from v1 (http://lkml.org/lkml/2009/1/13/440) include: o This version depends on EMBEDDED as well as !SMP, as suggested by Ingo. o Updated rcu_needs_cpu() to unconditionally return zero, permitting the CPU to enter dynticks-idle mode at any time. This works because callbacks can be invoked upon entry to dynticks-idle mode. o Paul is now OK with this being included, based on a poll at the Kernel Miniconf at linux.conf.au, where about ten people said that they cared about saving 900 bytes on single-CPU systems. o Applies to both mainline and tip/core/rcu. Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Acked-by: David Howells <dhowells@redhat.com> Acked-by: Josh Triplett <josh@joshtriplett.org> Reviewed-by: Lai Jiangshan <laijs@cn.fujitsu.com> Cc: dipankar@in.ibm.com Cc: mathieu.desnoyers@polymtl.ca Cc: dvhltc@us.ibm.com Cc: niv@us.ibm.com Cc: peterz@infradead.org Cc: rostedt@goodmis.org Cc: Valdis.Kletnieks@vt.edu Cc: avi@redhat.com Cc: mtosatti@redhat.com LKML-Reference: <12565226351355-git-send-email-> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-10-07rcu: Move rcu_barrier() to rcutreePaul E. McKenney
Move the existing rcu_barrier() implementation to rcutree.c, consistent with the fact that the rcu_barrier() implementation is tied quite tightly to the RCU implementation. This opens the way to simplify and fix rcutree.c's rcu_barrier() implementation in a later patch. Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: laijs@cn.fujitsu.com Cc: dipankar@in.ibm.com Cc: akpm@linux-foundation.org Cc: mathieu.desnoyers@polymtl.ca Cc: josh@joshtriplett.org Cc: dvhltc@us.ibm.com Cc: niv@us.ibm.com Cc: peterz@infradead.org Cc: rostedt@goodmis.org Cc: Valdis.Kletnieks@vt.edu Cc: dhowells@redhat.com LKML-Reference: <12548908982563-git-send-email-> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-10-05rcu: Replace the rcu_barrier enum with pointer to call_rcu*() functionPaul E. McKenney
The rcu_barrier enum causes several problems: (1) you have to define the enum somewhere, and there is no convenient place, (2) the difference between TREE_RCU and TREE_PREEMPT_RCU causes problems when you need to map from rcu_barrier enum to struct rcu_state, (3) the switch statement are large, and (4) TINY_RCU really needs a different rcu_barrier() than do the treercu implementations. So replace it with a functionally equivalent but cleaner function pointer abstraction. Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Acked-by: Mathieu Desnoyers <mathieu.desnoyers@polymtl.ca> Cc: laijs@cn.fujitsu.com Cc: dipankar@in.ibm.com Cc: akpm@linux-foundation.org Cc: josh@joshtriplett.org Cc: dvhltc@us.ibm.com Cc: niv@us.ibm.com Cc: peterz@infradead.org Cc: rostedt@goodmis.org Cc: Valdis.Kletnieks@vt.edu Cc: dhowells@redhat.com LKML-Reference: <12541998232366-git-send-email-> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-10-05rcu: Fix rcu_lock_map build failure on CONFIG_PROVE_LOCKING=yPaul E. McKenney
Move the rcu_lock_map definition from rcutree.c to rcupdate.c so that TINY_RCU can use lockdep. Reported-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-09-23rcu: Clean up code to address Ingo's checkpatch feedbackPaul E. McKenney
Move declarations and update storage classes to make checkpatch happy. Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: laijs@cn.fujitsu.com Cc: dipankar@in.ibm.com Cc: akpm@linux-foundation.org Cc: mathieu.desnoyers@polymtl.ca Cc: josh@joshtriplett.org Cc: dvhltc@us.ibm.com Cc: niv@us.ibm.com Cc: peterz@infradead.org Cc: rostedt@goodmis.org Cc: Valdis.Kletnieks@vt.edu Cc: dhowells@redhat.com LKML-Reference: <12537246441701-git-send-email-> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-09-19rcu: Fix whitespace inconsistenciesPaul E. McKenney
Fix a number of whitespace ^Ierrors in the include/linux/rcu* and the kernel/rcu* files. Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: laijs@cn.fujitsu.com Cc: dipankar@in.ibm.com Cc: akpm@linux-foundation.org Cc: mathieu.desnoyers@polymtl.ca Cc: josh@joshtriplett.org Cc: dvhltc@us.ibm.com Cc: niv@us.ibm.com Cc: peterz@infradead.org Cc: rostedt@goodmis.org Cc: Valdis.Kletnieks@vt.edu LKML-Reference: <20090918172819.GA24405@linux.vnet.ibm.com> [ did more checkpatch fixlets ] Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-09-18rcu: Fix synchronize_rcu() for TREE_PREEMPT_RCUPaul E. McKenney
The redirection of synchronize_sched() to synchronize_rcu() was appropriate for TREE_RCU, but not for TREE_PREEMPT_RCU. Fix this by creating an underlying synchronize_sched(). TREE_RCU then redirects synchronize_rcu() to synchronize_sched(), while TREE_PREEMPT_RCU has its own version of synchronize_rcu(). Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: laijs@cn.fujitsu.com Cc: dipankar@in.ibm.com Cc: akpm@linux-foundation.org Cc: mathieu.desnoyers@polymtl.ca Cc: josh@joshtriplett.org Cc: dvhltc@us.ibm.com Cc: niv@us.ibm.com Cc: peterz@infradead.org Cc: rostedt@goodmis.org Cc: Valdis.Kletnieks@vt.edu LKML-Reference: <12528585111916-git-send-email-> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-08-19rcu: Delay rcu_barrier() wait until beginning of next CPU-hotunplug operation.Paul E. McKenney
Ingo Molnar reported this lockup: [ 200.380003] Hangcheck: hangcheck value past margin! [ 248.192003] INFO: task S99local:2974 blocked for more than 120 seconds. [ 248.194532] "echo 0 > /proc/sys/kernel/hung_task_timeout_secs" disables this message. [ 248.202330] S99local D 0000000c 6256 2974 2687 0x00000000 [ 248.208929] 9c7ebe90 00000086 6b67ef8b 0000000c 9f25a610 81a69869 00000001 820b6990 [ 248.216123] 820b6990 820b6990 9c6e4c20 9c6e4eb4 82c78990 00000000 6b993559 0000000c [ 248.220616] 9c7ebe90 8105f22a 9c6e4eb4 9c6e4c20 00000001 9c7ebe98 9c7ebeb4 81a65cb3 [ 248.229990] Call Trace: [ 248.234049] [<81a69869>] ? _spin_unlock_irqrestore+0x22/0x37 [ 248.239769] [<8105f22a>] ? prepare_to_wait+0x48/0x4e [ 248.244796] [<81a65cb3>] rcu_barrier_cpu_hotplug+0xaa/0xc9 [ 248.250343] [<8105f029>] ? autoremove_wake_function+0x0/0x38 [ 248.256063] [<81062cf2>] notifier_call_chain+0x49/0x71 [ 248.261263] [<81062da0>] raw_notifier_call_chain+0x11/0x13 [ 248.266809] [<81a0b475>] _cpu_down+0x272/0x288 [ 248.271316] [<81a0b4d5>] cpu_down+0x4a/0xa2 [ 248.275563] [<81a0c48a>] store_online+0x2a/0x5e [ 248.280156] [<81a0c460>] ? store_online+0x0/0x5e [ 248.284836] [<814ddc35>] sysdev_store+0x20/0x28 [ 248.289429] [<8112e403>] sysfs_write_file+0xb8/0xe3 [ 248.294369] [<8112e34b>] ? sysfs_write_file+0x0/0xe3 [ 248.299396] [<810e4c8f>] vfs_write+0x91/0x120 [ 248.303817] [<810e4dc1>] sys_write+0x40/0x65 [ 248.308150] [<81002d73>] sysenter_do_call+0x12/0x28 This change moves an RCU grace period delay off of the critical path for CPU-hotunplug operations. Since RCU callback migration is only performed on CPU-hotunplug operations, and since the rcu_barrier() race is provoked only by consecutive CPU-hotunplug operations, it is not necessary to delay the end of a given CPU-hotunplug operation. We can instead choose to delay the beginning of the next CPU-hotunplug operation. Reported-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: Josh Triplett <josht@linux.vnet.ibm.com> Cc: laijs@cn.fujitsu.com Cc: dipankar@in.ibm.com Cc: akpm@linux-foundation.org Cc: mathieu.desnoyers@polymtl.ca Cc: dvhltc@us.ibm.com Cc: niv@us.ibm.com Cc: peterz@infradead.org Cc: rostedt@goodmis.org Cc: hugh.dickins@tiscali.co.uk Cc: benh@kernel.crashing.org LKML-Reference: <20090819060614.GA14383@linux.vnet.ibm.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-08-15rcu: Simplify RCU CPU-hotplug notificationPaul E. McKenney
Use the new cpu_notifier() API to simplify RCU's CPU-hotplug notifiers, collapsing down to a single such notifier. This makes it trivial to provide the notifier-ordering guarantee that rcu_barrier() depends on. Also remove redundant open_softirq() calls from Hierarchical RCU notifier. Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: laijs@cn.fujitsu.com Cc: dipankar@in.ibm.com Cc: josht@linux.vnet.ibm.com Cc: akpm@linux-foundation.org Cc: mathieu.desnoyers@polymtl.ca Cc: dvhltc@us.ibm.com Cc: niv@us.ibm.com Cc: peterz@infradead.org Cc: rostedt@goodmis.org Cc: hugh.dickins@tiscali.co.uk Cc: benh@kernel.crashing.org LKML-Reference: <12503552312510-git-send-email-> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-07-03rcu: Add synchronize_sched_expedited() primitivePaul E. McKenney
This adds the synchronize_sched_expedited() primitive that implements the "big hammer" expedited RCU grace periods. This primitive is placed in kernel/sched.c rather than kernel/rcupdate.c due to its need to interact closely with the migration_thread() kthread. The idea is to wake up this kthread with req->task set to NULL, in response to which the kthread reports the quiescent state resulting from the kthread having been scheduled. Because this patch needs to fallback to the slow versions of the primitives in response to some races with CPU onlining and offlining, a new synchronize_rcu_bh() primitive is added as well. Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: akpm@linux-foundation.org Cc: torvalds@linux-foundation.org Cc: davem@davemloft.net Cc: dada1@cosmosbay.com Cc: zbr@ioremap.net Cc: jeff.chua.linux@gmail.com Cc: paulus@samba.org Cc: laijs@cn.fujitsu.com Cc: jengelh@medozas.de Cc: r000n@r000n.net Cc: benh@kernel.crashing.org Cc: mathieu.desnoyers@polymtl.ca LKML-Reference: <12459460982947-git-send-email-> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-04-15RCU: Don't try and predeclare inline funcs as it upsets some versions of gccDavid Howells
Don't try and predeclare inline funcs like this: static inline void wait_migrated_callbacks(void) ... static void _rcu_barrier(enum rcu_barrier type) { ... wait_migrated_callbacks(); } ... static inline void wait_migrated_callbacks(void) { wait_event(rcu_migrate_wq, !atomic_read(&rcu_migrate_type_count)); } as it upsets some versions of gcc under some circumstances: kernel/rcupdate.c: In function `_rcu_barrier': kernel/rcupdate.c:125: sorry, unimplemented: inlining failed in call to 'wait_migrated_callbacks': function body not available kernel/rcupdate.c:152: sorry, unimplemented: called from here This can be dealt with by simply putting the static variables (rcu_migrate_*) at the top, and moving the implementation of the function up so that it replaces its forward declaration. Signed-off-by: David Howells <dhowells@redhat.com> Cc: Dipankar Sarma <dipankar@in.ibm.com> Cc: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-03-31rcu: rcu_barrier VS cpu_hotplug: Ensure callbacks in dead cpu are migrated ↵Lai Jiangshan
to online cpu cpu hotplug may happen asynchronously, some rcu callbacks are maybe still on dead cpu, rcu_barrier() also needs to wait for these rcu callbacks to complete, so we must ensure callbacks in dead cpu are migrated to online cpu. Paul E. McKenney's review: Good stuff, Lai!!! Simpler than any of the approaches that I was considering, and, better yet, independent of the underlying RCU implementation!!! I was initially worried that wake_up() might wake only one of two possible wait_event()s, namely rcu_barrier() and the CPU_POST_DEAD code, but the fact that wait_event() clears WQ_FLAG_EXCLUSIVE avoids that issue. I was also worried about the fact that different RCU implementations have different mappings of call_rcu(), call_rcu_bh(), and call_rcu_sched(), but this is OK as well because we just get an extra (harmless) callback in the case that they map together (for example, Classic RCU has call_rcu_sched() mapping to call_rcu()). Overlap of CPU-hotplug operations is prevented by cpu_add_remove_lock, and any stray callbacks that arrive (for example, from irq handlers running on the dying CPU) either are ahead of the CPU_DYING callbacks on the one hand (and thus accounted for), or happened after the rcu_barrier() started on the other (and thus don't need to be accounted for). Signed-off-by: Lai Jiangshan <laijs@cn.fujitsu.com> Reviewed-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: Peter Zijlstra <peterz@infradead.org> LKML-Reference: <49C36476.1010400@cn.fujitsu.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-02-26rcu: Teach RCU that idle task is not quiscent state at bootPaul E. McKenney
This patch fixes a bug located by Vegard Nossum with the aid of kmemcheck, updated based on review comments from Nick Piggin, Ingo Molnar, and Andrew Morton. And cleans up the variable-name and function-name language. ;-) The boot CPU runs in the context of its idle thread during boot-up. During this time, idle_cpu(0) will always return nonzero, which will fool Classic and Hierarchical RCU into deciding that a large chunk of the boot-up sequence is a big long quiescent state. This in turn causes RCU to prematurely end grace periods during this time. This patch changes the rcutree.c and rcuclassic.c rcu_check_callbacks() function to ignore the idle task as a quiescent state until the system has started up the scheduler in rest_init(), introducing a new non-API function rcu_idle_now_means_idle() to inform RCU of this transition. RCU maintains an internal rcu_idle_cpu_truthful variable to track this state, which is then used by rcu_check_callback() to determine if it should believe idle_cpu(). Because this patch has the effect of disallowing RCU grace periods during long stretches of the boot-up sequence, this patch also introduces Josh Triplett's UP-only optimization that makes synchronize_rcu() be a no-op if num_online_cpus() returns 1. This allows boot-time code that calls synchronize_rcu() to proceed normally. Note, however, that RCU callbacks registered by call_rcu() will likely queue up until later in the boot sequence. Although rcuclassic and rcutree can also use this same optimization after boot completes, rcupreempt must restrict its use of this optimization to the portion of the boot sequence before the scheduler starts up, given that an rcupreempt RCU read-side critical section may be preeempted. In addition, this patch takes Nick Piggin's suggestion to make the system_state global variable be __read_mostly. Changes since v4: o Changes the name of the introduced function and variable to be less emotional. ;-) Changes since v3: o WARN_ON(nr_context_switches() > 0) to verify that RCU switches out of boot-time mode before the first context switch, as suggested by Nick Piggin. Changes since v2: o Created rcu_blocking_is_gp() internal-to-RCU API that determines whether a call to synchronize_rcu() is itself a grace period. o The definition of rcu_blocking_is_gp() for rcuclassic and rcutree checks to see if but a single CPU is online. o The definition of rcu_blocking_is_gp() for rcupreempt checks to see both if but a single CPU is online and if the system is still in early boot. This allows rcupreempt to again work correctly if running on a single CPU after booting is complete. o Added check to rcupreempt's synchronize_sched() for there being but one online CPU. Tested all three variants both SMP and !SMP, booted fine, passed a short rcutorture test on both x86 and Power. Located-by: Vegard Nossum <vegard.nossum@gmail.com> Tested-by: Vegard Nossum <vegard.nossum@gmail.com> Tested-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-01-05rcu: eliminate synchronize_rcu_xxx macroPaul E. McKenney
Impact: cleanup Expand macro into two files. The synchronize_rcu_xxx macro is quite ugly and it's only used by two callers, so expand it instead. This makes this code easier to change. Signed-off-by: Andi Kleen <ak@linux.intel.com> Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-10-21rcupdate: fix bug of rcu_barrier*()Lai Jiangshan
current rcu_barrier_bh() is like this: void rcu_barrier_bh(void) { BUG_ON(in_interrupt()); /* Take cpucontrol mutex to protect against CPU hotplug */ mutex_lock(&rcu_barrier_mutex); init_completion(&rcu_barrier_completion); atomic_set(&rcu_barrier_cpu_count, 0); /* * The queueing of callbacks in all CPUs must be atomic with * respect to RCU, otherwise one CPU may queue a callback, * wait for a grace period, decrement barrier count and call * complete(), while other CPUs have not yet queued anything. * So, we need to make sure that grace periods cannot complete * until all the callbacks are queued. */ rcu_read_lock(); on_each_cpu(rcu_barrier_func, (void *)RCU_BARRIER_BH, 1); rcu_read_unlock(); wait_for_completion(&rcu_barrier_completion); mutex_unlock(&rcu_barrier_mutex); } The inconsistency of the code and the comments show a bug here. rcu_read_lock() cannot make sure that "grace periods for RCU_BH cannot complete until all the callbacks are queued". it only make sure that race periods for RCU cannot complete until all the callbacks are queued. so we must use rcu_read_lock_bh() for rcu_barrier_bh(). like this: void rcu_barrier_bh(void) { ...... rcu_read_lock_bh(); on_each_cpu(rcu_barrier_func, (void *)RCU_BARRIER_BH, 1); rcu_read_unlock_bh(); ...... } and also rcu_barrier() rcu_barrier_sched() are implemented like this. it will bring a lot of duplicate code. My patch uses another way to fix this bug, please see the comment of my patch. Thank Paul E. McKenney for he rewrote the comment. Signed-off-by: Lai Jiangshan <laijs@cn.fujitsu.com> Reviewed-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-08-21rcu: fix synchronize_rcu() so that kernel-doc worksRandy Dunlap
Fix RCU's synchronize_rcu() so that it looks like a C function, enabling it to be recognized as a function with kernel-doc annotation. Warning(linux-2.6.26-git11//kernel/rcupdate.c:81): No description found for parameter 'synchronize_rcu' Warning(linux-2.6.26-git11//kernel/rcupdate.c:81): No description found for parameter 'call_rcu' [akpm@linux-foundation.org: fix comment] Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-07-15Merge branch 'generic-ipi-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'generic-ipi-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (22 commits) generic-ipi: more merge fallout generic-ipi: merge fix x86, visws: use mach-default/entry_arch.h x86, visws: fix generic-ipi build generic-ipi: fixlet generic-ipi: fix s390 build bug generic-ipi: fix linux-next tree build failure fix: "smp_call_function: get rid of the unused nonatomic/retry argument" fix: "smp_call_function: get rid of the unused nonatomic/retry argument" fix "smp_call_function: get rid of the unused nonatomic/retry argument" on_each_cpu(): kill unused 'retry' parameter smp_call_function: get rid of the unused nonatomic/retry argument sh: convert to generic helpers for IPI function calls parisc: convert to generic helpers for IPI function calls mips: convert to generic helpers for IPI function calls m32r: convert to generic helpers for IPI function calls arm: convert to generic helpers for IPI function calls alpha: convert to generic helpers for IPI function calls ia64: convert to generic helpers for IPI function calls powerpc: convert to generic helpers for IPI function calls ... Fix trivial conflicts due to rcu updates in kernel/rcupdate.c manually
2008-06-26on_each_cpu(): kill unused 'retry' parameterJens Axboe
It's not even passed on to smp_call_function() anymore, since that was removed. So kill it. Acked-by: Jeremy Fitzhardinge <jeremy.fitzhardinge@citrix.com> Reviewed-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-05-19rcu: add rcu_barrier_sched() and rcu_barrier_bh()Paul E. McKenney
Add rcu_barrier_sched() and rcu_barrier_bh(). With these in place, rcutorture no longer gives the occasional oops when repeatedly starting and stopping torturing rcu_bh. Also adds the API needed to flush out pre-existing call_rcu_sched() callbacks. Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Signed-off-by: Mathieu Desnoyers <mathieu.desnoyers@polymtl.ca> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-05-19rcu: add call_rcu_sched()Paul E. McKenney
Fourth cut of patch to provide the call_rcu_sched(). This is again to synchronize_sched() as call_rcu() is to synchronize_rcu(). Should be fine for experimental and -rt use, but not ready for inclusion. With some luck, I will be able to tell Andrew to come out of hiding on the next round. Passes multi-day rcutorture sessions with concurrent CPU hotplugging. Fixes since the first version include a bug that could result in indefinite blocking (spotted by Gautham Shenoy), better resiliency against CPU-hotplug operations, and other minor fixes. Fixes since the second version include reworking grace-period detection to avoid deadlocks that could happen when running concurrently with CPU hotplug, adding Mathieu's fix to avoid the softlockup messages, as well as Mathieu's fix to allow use earlier in boot. Fixes since the third version include a wrong-CPU bug spotted by Andrew, getting rid of the obsolete synchronize_kernel API that somehow snuck back in, merging spin_unlock() and local_irq_restore() in a few places, commenting the code that checks for quiescent states based on interrupting from user-mode execution or the idle loop, removing some inline attributes, and some code-style changes. Known/suspected shortcomings: o I still do not entirely trust the sleep/wakeup logic. Next step will be to use a private snapshot of the CPU online mask in rcu_sched_grace_period() -- if the CPU wasn't there at the start of the grace period, we don't need to hear from it. And the bit about accounting for changes in online CPUs inside of rcu_sched_grace_period() is ugly anyway. o It might be good for rcu_sched_grace_period() to invoke resched_cpu() when a given CPU wasn't responding quickly, but resched_cpu() is declared static... This patch also fixes a long-standing bug in the earlier preemptable-RCU implementation of synchronize_rcu() that could result in loss of concurrent external changes to a task's CPU affinity mask. I still cannot remember who reported this... Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Signed-off-by: Mathieu Desnoyers <mathieu.desnoyers@polymtl.ca> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-02-13rcupdate: fix commentPaul E. McKenney
This comment caused some consternation during fastcall removal. Make it truthful. Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-01-25Preempt-RCU: fix rcu_barrier for preemptive environment.Paul E. McKenney
Fix rcu_barrier() to work properly in preemptive kernel environment. Also, the ordering of callback must be preserved while moving callbacks to another CPU during CPU hotplug. Signed-off-by: Gautham R Shenoy <ego@in.ibm.com> Signed-off-by: Dipankar Sarma <dipankar@in.ibm.com> Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Reviewed-by: Steven Rostedt <srostedt@redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-01-25Preempt-RCU: reorganize RCU code into rcuclassic.c and rcupdate.cPaul E. McKenney
This patch re-organizes the RCU code to enable multiple implementations of RCU. Users of RCU continues to include rcupdate.h and the RCU interfaces remain the same. This is in preparation for subsequently merging the preemptible RCU implementation. Signed-off-by: Gautham R Shenoy <ego@in.ibm.com> Signed-off-by: Dipankar Sarma <dipankar@in.ibm.com> Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Reviewed-by: Steven Rostedt <srostedt@redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-01-25Preempt-RCU: Use softirq instead of tasklets forDipankar Sarma
This patch makes RCU use softirq instead of tasklets. It also adds a memory barrier after raising the softirq inorder to ensure that the cpu sees the most recently updated value of rcu->cur while processing callbacks. The discussion of the related theoretical race pointed out by James Huang can be found here --> http://lkml.org/lkml/2007/11/20/603 Signed-off-by: Gautham R Shenoy <ego@in.ibm.com> Signed-off-by: Steven Rostedt <rostedt@goodmis.org> Signed-off-by: Dipankar Sarma <dipankar@in.ibm.com> Reviewed-by: Steven Rostedt <srostedt@redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-01-22rcu: fix section mismatchRandy Dunlap
rcu_online_cpu() should be __cpuinit instead of __devinit. WARNING: vmlinux.o(.text+0x4b6d5): Section mismatch: reference to .init.text: (between 'rcu_cpu_notify' and 'wakeme_after_rcu') Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Cc: Sam Ravnborg <sam@ravnborg.org> Acked-by: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-17Clean up duplicate includes in kernel/Jesper Juhl
This patch cleans up duplicate includes in kernel/ Signed-off-by: Jesper Juhl <jesper.juhl@gmail.com> Acked-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Reviewed-by: Satyam Sharma <ssatyam@cse.iitk.ac.in> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-11lockdep: annotate rcu_read_{,un}lock{,_bh}Peter Zijlstra
lockdep annotate rcu_read_{,un}lock{,_bh} in order to catch imbalanced usage. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Ingo Molnar <mingo@elte.hu> Cc: Paul E. McKenney <paulmck@linux.vnet.ibm.com>
2007-05-09Add suspend-related notifications for CPU hotplugRafael J. Wysocki
Since nonboot CPUs are now disabled after tasks and devices have been frozen and the CPU hotplug infrastructure is used for this purpose, we need special CPU hotplug notifications that will help the CPU-hotplug-aware subsystems distinguish normal CPU hotplug events from CPU hotplug events related to a system-wide suspend or resume operation in progress. This patch introduces such notifications and causes them to be used during suspend and resume transitions. It also changes all of the CPU-hotplug-aware subsystems to take these notifications into consideration (for now they are handled in the same way as the corresponding "normal" ones). [oleg@tv-sign.ru: cleanups] Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Cc: Gautham R Shenoy <ego@in.ibm.com> Cc: Pavel Machek <pavel@ucw.cz> Signed-off-by: Oleg Nesterov <oleg@tv-sign.ru> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-12-07[PATCH] rcu: add a prefetch() in rcu_do_batch()Eric Dumazet
On some workloads, (for example when lot of close() syscalls are done), RCU qlen can be quite large, and RCU heads are no longer in cpu cache when rcu_do_batch() is called. This patch adds a prefetch() in rcu_do_batch() to give CPU a hint to bring back cache lines containing 'struct rcu_head's. Most list manipulations macros include prefetch(), but not open coded ones (at least with current C compilers :) ) I got a nice speedup on a trivial benchmark (3.48 us per iteration instead of 3.95 us on a 1.6 GHz Pentium-M) while (1) { pipe(p); close(fd[0]); close(fd[1]);} Signed-off-by: Eric Dumazet <dada1@cosmosbay.com> Cc: "Paul E. McKenney" <paulmck@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-04[PATCH] rcu: simplify/improve batch tuningOleg Nesterov
Kill a hard-to-calculate 'rsinterval' boot parameter and per-cpu rcu_data.last_rs_qlen. Instead, it adds adds a flag rcu_ctrlblk.signaled, which records the fact that one of CPUs has sent a resched IPI since the last rcu_start_batch(). Roughly speaking, we need two rcu_start_batch()s in order to move callbacks from ->nxtlist to ->donelist. This means that when ->qlen exceeds qhimark and continues to grow, we should send a resched IPI, and then do it again after we gone through a quiescent state. On the other hand, if it was already sent, we don't need to do it again when another CPU detects overflow of the queue. Signed-off-by: Oleg Nesterov <oleg@tv-sign.ru> Acked-by: Paul E. McKenney <paulmck@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-13[PATCH] rcu_do_batch: make ->qlen decrement irq safeOleg Nesterov
rcu_do_batch() decrements rdp->qlen with irqs enabled. This is not good, it can also be modified by call_rcu() from interrupt. Decrement ->qlen once with irqs disabled, after a main loop. Signed-off-by: Oleg Nesterov <oleg@tv-sign.ru> Cc: Dipankar Sarma <dipankar@in.ibm.com> Cc: "Paul E. McKenney" <paulmck@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-31[PATCH] cpu hotplug: replace __devinit* with __cpuinit* for cpu notificationsChandra Seetharaman
Few of the callback functions and notifier blocks that are associated with cpu notifications incorrectly have __devinit and __devinitdata. They should be __cpuinit and __cpuinitdata instead. It makes no functional difference but wastes text area when CONFIG_HOTPLUG is enabled and CONFIG_HOTPLUG_CPU is not. This patch fixes all those instances. Signed-off-by: Chandra Seetharaman <sekharan@us.ibm.com> Cc: Ashok Raj <ashok.raj@intel.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-03[PATCH] lockdep: locking init debugging improvementIngo Molnar
Locking init improvement: - introduce and use __SPIN_LOCK_UNLOCKED for array initializations, to pass in the name string of locks, used by debugging Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-27[PATCH] cpu hotplug: revert initdata patch submitted for 2.6.17Chandra Seetharaman
This patch reverts notifier_block changes made in 2.6.17 Signed-off-by: Chandra Seetharaman <sekharan@us.ibm.com> Cc: Ashok Raj <ashok.raj@intel.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-27[PATCH] cpu hotplug: revert init patch submitted for 2.6.17Chandra Seetharaman
In 2.6.17, there was a problem with cpu_notifiers and XFS. I provided a band-aid solution to solve that problem. In the process, i undid all the changes you both were making to ensure that these notifiers were available only at init time (unless CONFIG_HOTPLUG_CPU is defined). We deferred the real fix to 2.6.18. Here is a set of patches that fixes the XFS problem cleanly and makes the cpu notifiers available only at init time (unless CONFIG_HOTPLUG_CPU is defined). If CONFIG_HOTPLUG_CPU is defined then cpu notifiers are available at run time. This patch reverts the notifier_call changes made in 2.6.17 Signed-off-by: Chandra Seetharaman <sekharan@us.ibm.com> Cc: Ashok Raj <ashok.raj@intel.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-27[PATCH] rcutorture: add call_rcu_bh() operationsPaul E. McKenney
Add operations for the call_rcu_bh() variant of RCU. Also add an rcu_batches_completed_bh() function, which is needed by rcutorture. Signed-off-by: Paul E. McKenney <paulmck@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-23[PATCH] Make RCU API inaccessible to non-GPL Linux kernel modulesPaul E. McKenney
Remove synchronize_kernel() (deprecated 2-APR-2005 in http://lkml.org/lkml/2005/4/3/11) and makes the RCU API inaccessible to non-GPL Linux kernel modules (as was announced more than one year ago in http://lkml.org/lkml/2005/4/3/8). Tested on x86 and ppc64. Signed-off-by: "Paul E. McKenney" <paulmck@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
